 apt update && apt -y upgrade
1. armbian-config -> software -> softy
Bug fixes:
  • Syncthing
  • ZSH
  • Internet detection also works behind proxy
Cosmetical fixes:
  • UrBackup
  • Transmission
Removed:
  • Exagear (EOL)
2. armbian-config -> personal -> mirror
  On 3/11/2019 at 6:12 PM, hjoe said:
The headline still shows
"Armbian 5.75 stable"
Expand
for more information about the versions of your armbian-system-packages you could add the following to your
/etc/update-motd.d/10-armbian-header
ARMBIAN_bsp=$(more /etc/armbian-release|grep VERSION|cut -f 2 -d '=')
ARMBIAN_kernel=$(dpkg -s linux-image-$BRANCH-$LINUXFAMILY|grep Version|cut -f 2 -d ' ')
ARMBIAN_uboot=$(dpkg -s linux-u-boot-$BOARD-$BRANCH|grep Version|cut -f 2 -d ' ')
ARMBIAN_dtb=$(dpkg -s linux-dtb-$BRANCH-$LINUXFAMILY|grep Version|cut -f 2 -d ' ')
ARMBIAN_firmware=$(dpkg -s armbian-firmware|grep Version|cut -f 2 -d ' ')
ARMBIAN_config=$(dpkg -s armbian-config|grep Version|cut -f 2 -d ' ')
printf 'ARMBIAN bsp      : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_bsp"
printf 'ARMBIAN kernel   : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_kernel"
printf 'ARMBIAN u-boot   : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_uboot"
printf 'ARMBIAN dtb      : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_dtb"
printf 'ARMBIAN firmware : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_firmware"
printf 'ARMBIAN config   : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_config"
printf '\n'
printf 'ARMBIAN kernel   : \e[0;91m%s\x1B[0m   u-boot : \e[0;91m%s\x1B[0m   dtb : \e[0;91m%s\x1B[0m   firmware : \e[0;91m%s\x1B[0m  config : \e[0;91m%s\x1B[0m\n' "$ARMBIAN_kernel" "$ARMBIAN_uboot" "$ARMBIAN_dtb" "$ARMBIAN_firmware" "$ARMBIAN_config"
printf '\n'
this will give you the armbian-system-package-informations in different lines or
at the end in one line like in the attached image ;)
I like the armbian-system-packages  armbian header information. Will modify my rock64 to output the additional information.   Thanks for the tip!
printf '\n'
printf '\n'
Expand
I've added the setting to the header but I don't get the Kernel or DTB information. Not sure why.
I put your additional settings at the end of the file.
printf '\n'
printf '\n'
Expand
Expand
if config, u-boot and firmware does work then kernel and dtb should also work..
whats the result of
ECHO $BRANCH
and
ECHO $LINUXFAMILY
Did create a more compact version for me (and you?)
nano /etc/update-motd.d/10-armbian-header
printf '\n'
printf 'pkg-version kernel[\e[0;91m%s\x1B[0m] u-boot[\e[0;91m%s\x1B[0m] dtb[\e[0;91m%s\x1B[0m] firmware[\e[0;91m%s\x1B[0m] config[\e[0;91m%s\x1B[0m]\n' "$ARMBIAN_kernel" "$ARMBIAN_uboot" "$ARMBIAN_dtb" "$ARMBIAN_firmware" "$ARMBIAN_config"
printf '\n'
Expand
That was an excellent tip, thank you very much! :thumbup:
  • Igor changed the title to Updated armbian-config v5.81
v5.84
  • Added CPU speed and governor management
  • Fixed TVheadend install on Ubuntu
  • Improving two-factor authentication: once enabled, token is one for all local users
  • Added Meson64 overlay config (hardware configuration)
