0
Lucil
-bash: No such file or directory
I'm trying to run an executable on an OrangePi Prime. The message is:
-bash: <filename>: No such file or directory
The output of the file command on the executable is:
<filename>: ELF 32-bit LSB executable, ARM, EABI5 version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=xxx, not stripped
The app runs fine on OrangePi One, OrangePi Zero and Raspberry Pi.
Share this post
Link to post
Share on other sites
The OPiPrime is an H5 SoC, therefore a 64bits processor ...
You preferably need to recompile that executable as 64bits.
What is that application ?
If you can't, there still some workaround :
From an H3 board, copy the missing files from it /lib/arm-linux-gnueabihf/ along with some symlinks, example :
mkdir /lib/arm-linux-gnueabihf
scp <ip_of_h3>:/lib/arm-linux-gnueabihf/ld-2.24.so /lib/arm-linux-gnueabihf/ld-2.24.so
ln -s /lib/arm-linux-gnueabihf/ld-2.24.so /lib/ld-linux-armhf.so.3
scp <ip_of_h3>:/lib/arm-linux-gnueabihf/libc-2.24.so /lib/arm-linux-gnueabihf/libc-2.24.so
ln -s /lib/arm-linux-gnueabihf/libc-2.24.so /lib/arm-linux-gnueabihf/libc.so.6
That was enough for me to try a plain C 32bits executable on the H5 !
But maybe your will need more libs to be copied/symlinked ...
Share this post
Link to post
It's a comercial app, sources are closed. All platforms are supported (win, lin, mac), but ARM is provided just as a courtesy and I don't know if a 64 bit build can be made available.
Share this post
Link to post
Would it be possible to use a 32bit build made for another board?
Share this post
Link to post
Yes, you can have 32bit user land on 64bit board. This problem is generic and unrelated to Armbian.
Share this post
Link to post
I would rather install only the 32bits libraries needed as I explain above, leaving the rest of the OS to 64bits...
Share this post
Link to post
It's difficult to guess all the needed libs. I've installed the 32bit userland and now I get an "Illegal instruction" error. So that's why I was thinking of installing a complete 32bit build. Somewhat like RPi guys do and I guess it's because of them my ARM app build is 32bit, as the most widespread platform.
Share this post
Link to post
0
