This 100% works - we are even running daily automated tests on Bookworm, Jammy and Noble. https://github.com/armbian/os/actions/runs/15362508470/job/43232345405 Manual test on Rockchip64 (Bananapi M7) with 6.12.28-current, latest kernel from daily repository. System: https://paste.armbian.com/tiwisuhugi Here is build log:
I2C not working on Orange Pi Zero2
Yordan Yanakiev replied to Yordan Yanakiev's topic in Allwinner sunxi
seems like the config should be distinguishing by models, not by .. idk even what it is. let say config->OrangePi2->hardware->peripherals->i2c->i2's enumerate. - Today
All the kernel panic options that you have shown here occur on v6.12.23. It all happens randomly. I suspect that this may be due to the presence of broken (faulty) blocks on the memory device. It's easy to check this.If you connect the SD card via an adapter to a Linux computer: sudo fsck.ext4 /dev/sdX1
Trouble getting hardware decoding to work on Rock 5 ITX
bucknaked posted a topic in Radxa Rock 5 ITX
I had this plan on utilizing the Radxa Rock 5 ITX+ as a Moonlight client device to stream games from my desktop computer to my living room TV, and using my 8BitDo Ultimate controller to play. On paper, the board has all the bells and whistles needed to do it, but I am having trouble getting hardware decoding of H264 and/or HEVC to work as expected. From what I gather, I need mesa-vpu support, but the documentation I find is very scattered, and repositories that once held the needed resources are no longer available. I am currently running Armbian_25.DBhsHKsx.2.2_Rock-5-itx_bookworm_vendor_6.1.99_cinnamon-backported-mesa_desktop.img (build date 21st of February, 2025), downloaded from Armbian.com. Hardware decoding does however not work, despite it being marked with "backported mesa". I've been at this for two weeks now with different images, including Armbian and Radxa OS, even going so far as trying to build Armbian myself from scratch. The image I am currently using is however the most stable I have experienced so far. Am I missing something? How do I get hardware decoding to work? Edit: Link to armbianmonitor output -
I assume should work with vendor. Maybe missing node in device tree. Maybe missing firmware blobs or same as above. Expected since neither SPI nor eMMC are present by default. Direct boot from NVMe isn't support by any Rockchip soc.
Almero Ramadhan Insan wibowo replied to jock's topic in Rockchip CPU Boxes
does anyone know how to get maskrom and uart on this rk3228a board from mxq pro 4k 5G since pushing the little button shows up as armlogic devices on device manager but the actual chip is rockchip and sorry for bad quality images - Yesterday
All Armbian board configurations files live in build/config/board/ Besides the Pcduino2 Cubieboard and OlinuXino-lime board, I don't know what other A10 boards still have some level of support. After that the next step would probably be to confirm that it works with uboot. Here you have another config file and dts. For any tweaks to uboot you will need to pass uboot-patch when running compile.sh. Note that when you do this you will need to open a new tab and navigate to cache/sources/u-boot-worktree/ Similiarly for the kernel you would navigate to cache/sources/kernel/ currently 6.12 is "current" while 6.14 is "edge" Hope this helps Ryzer -
For production, boxes are much more interesting than boards. We just need to deal with a honest manufacturer. The last dtb from @mmie4jbcu worked very well for me in a x88 pro 20.
thank you for your help
Build Image with Debian 12 VM on QubesOS
joejoe44 replied to joejoe44's topic in Advanced users - Development
That solves it thank you very much for your time! If I want to change between boards like Rockpro64, Raspberry Pi4, etc. is there anything that needs to be considered as far as "reset" to a fresh state. For the guide I am writing I would like to make sure there is no lingering configuration that could cause problems when switching between builds for different boards. -
How to enable sound on a server version of Armbian
Hooutoo replied to ubhelbr's topic in Orange Pi 5 Plus
All things being equal....... steve@fedora43:~$ uname -a Linux fedora43 6.16.0-0.rc0.250528gfeacb1774bd5.5.fc43.aarch64 #1 SMP PREEMPT_DYNAMIC Wed May 28 19:45:02 UTC 2025 aarch64 GNU/Linux kernel-6.16.0-0.rc0.250529g90b83efa6701.6.fc43. created by jforbes 6 hours ago for Fedora 43 . -
Armbian 24.2 is broken on Orange PI PC2
Yordan Yanakiev replied to Moklev's topic in Allwinner sunxi
Hello. I wonder if this issue is connected to my issue - to show something on i2c, while there is nothing, and not be able to communicate on it ? -
cubox-i beta.armbian.com bookworm armhf messed up?
Igor replied to monetschemist's topic in Other families
Beta repository. - should be on servers where we push on directly and this error can't occur (unless something broke down) - is the same quality as other Linux distributions (there is no other distro that would maintain those custom devices) - currently assembly is broken as some patches are failing and thus (beta) repo is not getting any updates until its fixed https://github.com/armbian/os/actions/runs/15337468717/job/43160986093 -
Since you are on current you cannot expect a major bump until the next LTS kernel is released. current will receive security fixes only. If you want something more recent you need to switch to edge kernels which follow non-LTS mainline kernel releases.
Hi Providing logs with PASTE_SERVER_HOST=paste.armbian.de armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed.
/_\ _ _ _ __ | |__(_)__ _ _ _ / _ \| '_| ' \| '_ \ / _` | ' \ /_/ \_\_| |_|_|_|_.__/_\__,_|_||_| v25.5.1 for Orange Pi Zero2W running Armbian Linux 6.12.23-current-sunxi64 Packages: Ubuntu stable (noble) Updates: Kernel upgrade enabled and 17 packages available for upgrade Support: DIY (community maintained) IPv4: (LAN) 192.168.***.***, 192.168.***.*** (WAN) ***.***.***.*** IPv6: *** Performance: Load: 11% Up time: 4 min Local users: 3 Memory usage: 24% of 1.93G CPU temp: 45°C Usage of /: 10% of 58G Commands: Configuration : armbian-config Upgrade : armbian-upgrade Monitoring : htop orangepi@orangepizero2w:~$ It boots into xfce wifi works, eth works and hdmi work. 2gb board with keyboard plugged into expansion board.
How to install ARMBIAN to Amlogic S805X, SDMC DV8040 STB
SteeMan replied to remolaan's topic in Amlogic CPU Boxes
@remolaan I think this is the most current info that may help you: -
I own a CM3588 NAS board from FriendlyElec. The eMMC drive was factory-installed with the FriendlyElec version of OpenMediaVault, and any other FriendlyElec or Armbian image could be booted from an SD card. After installing the current version of Armbian OpenMediaVault (Debian 12 Bookworm - Armbian Linux v6.1 Build Date: Mar 6, 2025) on eMMC and updating bootloader via armbian-config (option Boot from eMMC + system on eMMC), nothing else can be booted from the SD card except Armbian images. Please, is there a simple way to fix bootloader back to original option of booting FriendlyElec images from SD card without having to erase entire eMMC drive? Boot from SD card does not work even for FriendlyElec automatic eflasher (SD to eMMC) images. I have Windows 11 and RKDevTool 3.30 is quite confusing and too complex software for me. PS. Does the CM3588 NAS board have SPI NOR flash? And how can I upload UEFI 1.1 boot (https://github.com/edk2-porting/edk2-rk3588) to eMMC or to SPI NOR?
Hello again, I am struggling to install armbian on my H96Max (blue PCB RK3318_V1.4, 4G/64G). The Armbian_22.11.0-trunk_Rk3318-box_bullseye_edge_5.19.15_minimal.img image works OK (at least for the display). All the new images fail to initialise the display (a 4K HDMI monitor), either using *_minimal.img or *_gnome_desktop.img I managed to install the latest (Armbian_community_25.8.0-trunk.8_Rk3318-box_noble_current_6.12.28_gnome_desktop.img) image using the serial console. Kernel is 6.12.28 I can now connect using ssh on ethernet (the WIFI does not work yet...) I get in syslog and dmesg a LOT of the following errors: [ 2683.281403] ------------[ cut here ]------------ [ 2683.281441] [CRTC:38:crtc-0] vblank wait timed out [ 2683.281570] WARNING: CPU: 1 PID: 50 at drivers/gpu/drm/drm_atomic_helper.c:1682 drm_atomic_helper_wait_for_vblanks.part.0+0x238/0x25c [ 2683.281629] Modules linked in: cfg80211 rfcomm algif_hash algif_skcipher af_alg bnep sunrpc snd_soc_hdmi_codec hci_uart btqca hantro_vpu btrtl btintel crct10dif_ce rockchip_vdec(C) v4l2_jpeg v4l2_vp9 btbcm rockchip_rga v4l2_h264 bluetooth videobuf2_dma_contig snd_soc_spdif_tx gpio_ir_recv videobuf2_dma_sg rc_core v4l2_mem2mem rfkill videobuf2_memops videobuf2_v4l2 dw_hdmi_i2s_audio videodev dw_hdmi_cec lima snd_soc_simple_card videobuf2_common snd_soc_rockchip_spdif snd_soc_rockchip_i2s snd_soc_rk3328 snd_soc_simple_card_utils gpu_sched drm_shmem_helper mc snd_soc_core rk_crypto snd_compress rng_core snd_pcm_dmaengine snd_pcm snd_timer snd soundcore cpufreq_dt joydev zram zsmalloc binfmt_misc sch_fq_codel dm_mod autofs4 dwmac_rk stmmac_platform stmmac pcs_xpcs nvmem_rockchip_efuse rockchipdrm dw_hdmi_qp gpio_syscon dw_hdmi cec dw_mipi_dsi analogix_dp drm_display_helper adc_keys [ 2683.282340] CPU: 1 UID: 0 PID: 50 Comm: kworker/u16:2 Tainted: G B WC 6.12.28-current-rockchip64 #1 [ 2683.282375] Tainted: [B]=BAD_PAGE, [W]=WARN, [C]=CRAP [ 2683.282389] Hardware name: Rockchip RK3318 BOX (DT) [ 2683.282409] Workqueue: events_unbound commit_work [ 2683.282446] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 2683.282471] pc : drm_atomic_helper_wait_for_vblanks.part.0+0x238/0x25c [ 2683.282499] lr : drm_atomic_helper_wait_for_vblanks.part.0+0x238/0x25c [ 2683.282531] sp : ffff8000809dbcb0 [ 2683.282542] x29: ffff8000809dbce0 x28: 00000000000007d5 x27: 0000000000000000 [ 2683.282580] x26: 0000000000000001 x25: 0000000000000000 x24: ffff6d33cdf68000 [ 2683.282616] x23: 0000000000000001 x22: 0000000000000000 x21: ffff6d33cc6f6280 [ 2683.282654] x20: ffff6d33cdf70080 x19: 0000000000000000 x18: ffffffffffffffff [ 2683.282691] x17: 000000040044ffff x16: 00500072b5503510 x15: ffff8000809db860 [ 2683.282727] x14: 00000000ffffffea x13: ffff8000809db9f8 x12: ffffd4f64aa4ac10 [ 2683.282768] x11: 0000000000032030 x10: 0000000000031fe0 x9 : 0000000000024330 [ 2683.282805] x8 : c0000000fffff822 x7 : ffffd4f64a99aa18 x6 : 0000000000084bb0 [ 2683.282842] x5 : ffff6d34be7424c8 x4 : 0000000000000000 x3 : 0000000000000027 [ 2683.282878] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff6d33c4c4c600 [ 2683.282918] Call trace: [ 2683.282932] drm_atomic_helper_wait_for_vblanks.part.0+0x238/0x25c [ 2683.282962] drm_atomic_helper_commit_tail_rpm+0x84/0xa0 [ 2683.282992] commit_tail+0xa4/0x18c [ 2683.283019] commit_work+0x14/0x20 [ 2683.283043] process_one_work+0x16c/0x3e4 [ 2683.283073] worker_thread+0x2d0/0x3d8 [ 2683.283097] kthread+0x10c/0x110 [ 2683.283123] ret_from_fork+0x10/0x20 [ 2683.283151] ---[ end trace 0000000000000000 ]--- This seems to come from the accelerated graphic driver. The corresponding function can be seen there: drm_atomic_helper.c This function waits for receiving a vertical blanking pulse that never comes, so the warning at line 1679 is triggered. I don't intend to do hard-core graphics so I don't care about graphic performance. In fact this lovely box will be used for hosting a headless server. Is there a way to use a legacy or un-accelerated graphic driver? If not, how could I remove entirely the graphic subsystem and use only character mode? Thanks! Michel EDIT: In fact the first warning occurs when switching to the colour frame buffer device: ... rk_gmac-dwmac ff550000.ethernet: Enable RX Mitigation via HW Watchdog Timer May 29 19:00:08 h96max kernel: rk_gmac-dwmac ff550000.ethernet: device MAC address de:10:75:60:c0:cb May 29 19:00:08 h96max kernel: Console: switching to colour frame buffer device 160x45 May 29 19:00:08 h96max kernel: ------------[ cut here ]------------ May 29 19:00:08 h96max kernel: [CRTC:38:crtc-0] vblank wait timed out May 29 19:00:08 h96max kernel: WARNING: CPU: 0 PID: 74 at drivers/gpu/drm/drm_atomic_helper.c:1682 drm_atomic_helper_wait_for_vblanks.part.0+0x238/0x25c May 29 19:00:08 h96max kernel: Modules linked in: dwmac_rk stmmac_platform stmmac pcs_xpcs nvmem_rockchip_efuse gpio_syscon rockchipdrm dw_hdmi_qp dw_hdmi cec dw_mipi_dsi analogix_dp drm_display_helper adc_keys May 29 19:00:08 h96max kernel: CPU: 0 UID: 0 PID: 74 Comm: kworker/u16:5 Tainted: G B 6.12.28-current-rockchip64 #1 May 29 19:00:08 h96max kernel: Tainted: [B]=BAD_PAGE ... So I suspect that not switching to a FB could solve my problem
👍 Thanks!
Great news and thank you for reporting back. Do you have any idea what they changed or where they host their sources so we can have a look? There is for example this. There is another user who reported running into problems that sounded a lot like yours. -
Pusillus replied to Igor's topic in Software, Applications, Userspace
Thanks Igor for your work!
