  2. @boggy Try my Transpeed 8K618T image. It includes the most critical DTS settings for this hardware. All your Dram settings in the dts have dram_type = <0x03> or DDR3. dram_para1 { device_type = "dram_para1"; dram_clk = <0x258>; dram_type = <0x03>; cd-gpios = <&pio 8 16 GPIO_ACTIVE_LOW>; /* PI16 */ sdmmc@04020000 { compatible = "allwinner,sunxi-mmc-v4p1x"; device_type = "sdc0"; . . . cd-gpios = <0x53 0x08 0x10 0x06 0x01 0x03 0xffffffff>;
  4. As title says. Here's the bash script I use to download the dependencies and compile the latest mesa: https://pastebin.com/1n7Sv0dZ How /boot/*Env* looks like right now: https://pastebin.com/mUqHs14Y And the error message I get when I try to run sway goes as follows: MESA: error: ZINK: failed to choose pdev libEGL warning: egl: failed to create dri2 screen [wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "DRI2: failed to create screen" MESA: error: ZINK: failed to choose pdev libEGL warning: egl: failed to create dri2 screen [wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "DRI2: failed to create screen" [wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "DRI2: failed to load driver" [wlr] [EGL] command: eglInitialize, error: EGL_NOT_INITIALIZED (0x3001), message: "eglInitialize" [wlr] [render/egl.c:268] Failed to initialize EGL [wlr] [render/egl.c:571] Failed to initialize EGL context [wlr] [render/gles2/renderer.c:499] Could not initialize EGL [wlr] [render/wlr_renderer.c:272] Could not initialize renderer [sway/server.c:236] Failed to create renderer Oddly enough, "eglinfo -B" shows that everything is fine: https://pastebin.com/6k05DcAS How my .bashrc looks like right now: https://pastebin.com/3W7Qib6U I've tried copying the firmware in (with "cd /lib/firmware sudo wget https://github.com/JeffyCN/mirrors/raw/libmali/firmware/g610/mali_csffw.bin sudo chmod 644 mali_csffw.bin"), forcing "card0" to be used with the env. value WLR_DRM_DEVICES=/dev/dri/card0, and panfrost with "MESA_LOADER_DRIVER_OVERRIDE=panfrost" and "GALLIUM_DRIVER=panfrost" but none of those options helped. I also added my user to "render" and "video" (with sudo usermod -aG video $USER and sudo usermod -aG render $USER), which also didn't do me any good. I also manually removed any trace of panfrost that was left into the system and reinstalled with "libgl1-mesa-dri" and manually compiling everything in again...and it also didn't worked. I don't know what else I should do, and I'm in the verge of reinstalling everything back in. Please help me. And thanks for reading.
  5. sven-ola
    @Łukasz Żywczyk Currently no prebuild nightly images. You are on your own. Grab a Debian Trixie on 64 bit PC (8G RAM, 16G Disk), then sudo apt-get install docker.io qemu-user git # add yourself to group docker, logout && login git clone https://github.com/armbian/build.git cd build && ./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie \ BUILD_MINIMAL=yes KERNEL_CONFIGURE=no KERNEL_BTF=no KERNEL_GIT=shallow should build your image in output/images/*.img ready to be used...
  6. Also: # apt install -y iptables # iptables -v iptables v1.8.11 (nftables): no command specified https://wiki.debian.org/nftables AFAIK using iptables syntax should still work, but nft is what you probably should learn to use instead. https://wiki.nftables.org/wiki-nftables/index.php/Moving_from_iptables_to_nftables
  7. Add to /etc/rc.local and reboot. echo "1" > /sys/devices/system/cpu/cpufreq/boost && echo "performance" | tee /sys/devices/system/cpu/cpu[0-9]/cpufreq/scaling_governor &&
  8. @Werner I understand, will wait for "Resolve" before marking this as Solution. Thank you for quick reply.
  9. I tried installing armbian on tx6 because I saw a .img file for the tanix tx6 to turn it as a Minecraft server but I quickly run into problems
  10. This week in Armbian development saw significant enhancements across multiple areas, including expanded board support and improved hardware compatibility. Notable additions include new images and configurations for Qidi X-6, X-7, and Ariaboard Photonicat2 mainboards, as well as refined kernel patch maintenance and updates for various platforms. The build system received important fixes, such as resolving compilation errors and device tree issues, alongside improvements in Docker utilities and offline mode detection. Several refactoring efforts streamlined backend processes and enhanced user interface elements. The team also introduced automatic fallback mechanisms for Hetzner server types, optimizing runner scaling. Overall, these updates reinforce Armbian's commitment to stability, broader hardware support, and a smoother user experience. ChangesAdd automatic fallback to smaller Hetzner server types with runner count scaling. by @igorpecovnik in armbian/actions#15Add board and board vendror image for Ariaboard Photonicat2. by @HackingGate in armbian/armbian.github.io#255Add image for Qidi X-7 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#257Add some board image. by @retro98boy in armbian/armbian.github.io#258Add support for dialog via new wrapper functions. by @igorpecovnik in armbian/configng#762Add support for qidi x-* boards. by @Shadowrom2020 in armbian/build#9564Change unit tests badge link in documentation. by @igorpecovnik in armbian/documentation#885Drop patches that landed upstream and fix two. by @igorpecovnik in armbian/build#9544edge: bump 7.0 to rc5. by @EvilOlaf in armbian/build#9580Enable BCACHE on Raspberry Pi build. by @aulanov in armbian/build#9550feat: offline mode detection with local asset cache. by @SuperKali in armbian/imager#117feat: settings refactoring, DiskArbitration device detection, and filename parser improvements. by @SuperKali in armbian/imager#114fix race condition and NULL ptr deref in PCIe threaded probe. by @AlomeProg in armbian/linux-rockchip#458fix(docker): add trixie support for upstream docker-ce to fix HomeAssistant installation. by @igorpecovnik in armbian/configng#765fix: correct dialog argument order causing box option errors. by @igorpecovnik in armbian/configng#768fix: resolve Phytium stmmac compilation errors for kernel 6.19. by @igorpecovnik in armbian/build#9545fix: settings modal reset, custom image manufacturer, and board detection setting. by @SuperKali in armbian/imager#116Image for Qidi X-6 Mainboard. by @Shadowrom2020 in armbian/armbian.github.io#256kernel patch maintenance. by @EvilOlaf in armbian/build#9562meson64-6.18: rewrite kernel config. by @EvilOlaf in armbian/build#9581mksklipad50: fix devicetree opp voltage settings. by @torte71 in armbian/build#9569OrangePi-RV2/R2S: rename board config from wip to csc. by @sven-ola in armbian/build#9560Qidi X-6: fix defconfig patch. by @Shadowrom2020 in armbian/build#9567refactor: add comprehensive Docker wrapper utilities with progress display. by @igorpecovnik in armbian/configng#769refactor: deduplicate hooks, add CSS design tokens, clean up backend. by @SuperKali in armbian/imager#115rockchip64-7.0: mekotronics-r58x-pro: analog sound: use SuperKali's new clock. by @rpardini in armbian/build#9554rockchip64: rk3588: add I2S MCLK output gate clocks for audio codec support. by @SuperKali in armbian/build#9548rockchip64: rk3588: update I2S MCLK gate patches to match upstream v3 and add u-boot clock IDs. by @SuperKali in armbian/build#9568sm8250: Fix application of Retroid Pocket 5/mini device trees. by @kay-lambdadelta in armbian/build#9572SpacemiT: Update ATFSOURCE, BOOTSOURCE and SD card support.. by @pyavitz in armbian/build#9552sunxi-6.18: remove stray commit from patch. by @EvilOlaf in armbian/build#9556sunxi: bump edge to 6.19.y, current to 6.18.y and legacy to 6.12.y. by @EvilOlaf in armbian/build#9381Update odroidxu4-current to 6.6.129. by @belegdol in armbian/build#9558Update VERSION. by @EvilOlaf in armbian/build#9553View the full article
  11. Yesterday
  12. Hello, can you please say, where i can find: Armbian_community_25.11.0-trunk.413_Aml-s9xx-box_plucky_edge_6.18.0-rc3.img thank you.
  13. Subject: X88MAX RK3328 - Cannot boot from SD/USB, need help installing Armbian Hello Armbian Community, I'm trying to install Armbian on my X88 RK3328 TV box but facing multiple issues. Need your expert help! Device Information: Model: X88MAX.p2.0.01.d4 SoC: Rockchip RK3328 Android Version: Android 9 (SDK 28) Board: Blue PCB (Hugsun design similar to T9) Storage: 4GB RAM + eMMC Buttons: Power button only (no visible reset button) What I've Tried: 1. SD Card Boot: Downloaded: Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz Downloaded: multitool_rk3318-3328.img Flashed to Netac SD card using BalenaEtcher (verified) SD card is detected in Android environment Problem: Box always boots Android, ignores SD card completely 2. USB Boot: Flashed Multitool to USB flash drive Problem: Same result - boots Android, ignores USB 3. Reset Button Method: Tried holding reset button (inside AV port) while powering on Problem: No change, still boots Android 4. Rooting Attempts: Tried KingRoot - stuck on "checking state" forever Device confirmed NOT ROOTED (Root Checker app) Problem: Cannot root to install from Android 5. Maskrom Mode: Have AndroidTool v2.38 ready Problem: PC shows "No Devices Found" when trying to enter Maskrom Current Status: ✅ SD card slot works (Android detects it) ✅ Multitool files accessible on SD card ✅ Have all necessary images downloaded ❌ Cannot boot from SD or USB ❌ Cannot root Android ❌ Cannot enter Maskrom mode My Goal: Install pure Armbian (not Android + Linux apps) for better performance and native Linux experience. Questions: Does anyone have X88 RK3328 working with Armbian? If yes, what method did you use? Is there a specific Armbian build for X88 boards? The generic Rk3318-box image doesn't boot. How to enter Maskrom mode on X88? PC shows "No Devices Found" - am I missing something? Can I convert Armbian .img to Rockchip firmware format for USB Burning Tool? Any X88-specific instructions or device tree files I should use? What I Have Ready: ✅ Armbian image (Rk3318-box minimal) ✅ Multitool image ✅ AndroidTool v2.38 ✅ USB-A to USB-A cable ✅ Willing to backup original Android first Any help or X88-specific guidance would be greatly appreciated! Thanks in advance! 🙏 Device: X88MAX.p2.0.01.d4 SoC: RK3328 (Chip Tag: 33 32 32 48, Flag: RK322H) Storage: Samsung eMMC 64GB FlashID: 45 4D 4D 43 20 Status: Successfully in LOADER mode via RKDevTool v2.86 Android: Backed up and ready Problem: - SD/USB boot ignored by bootloader - Android not rootable (KingRoot fails) - Need Armbian in Rockchip firmware format What I Have: - Device in LOADER mode ✓ - Full Android backup ✓ - RKDevTool v2.86 working ✓ - Armbian_community_26.2.0-trunk.606_Rk3318-box_trixie_current_6.18.18_minimal.img.xz What I Need: - parameter.txt for X88 RK3328 - Armbian partitions in Rockchip format - Or .update file for X88 Tag: @jock Anyone successfully flashed Armbian on X88 RK3328?
  14. Anyone got the dedicated Fan header working correctly? It won't spin at all. Enabled the fanctrl overlay. changed pwm rate,the fan won't budge.. Tried stress the CPU but this only cause shutdown
  15. PanVK’s new framebuffer abstraction for Mali GPUs removes OpenGL-specific constraints, unlocking more flexible tiled rendering features in Vulkan. View the full article
  16. Hi, i have amlogic s805 tv box from mxq, how do i run armbian onecloud? bc none of this helped me.
  17. I installed the patch files with "Pb143" in the name on Friday, but unfortunately there was no improvement. Here are the logs: https://paste.armbian.com/dovedafali Can you tell me if I can test something with this? If so, what exactly do I need to do?
  18. logs are incomplete. dmesg is missing completely which would be the most relevant. moved to staging
  19. Why would you use an image for the Zero 3 for the 5B? You cannot simply shove an image for a random board into yours and assume it works...
  20. This is latest edge version 6.18. Should be easily reproducible on your end, effects all rock 5B+ boards and this board is a platinum supported board.
  21. Hi all, Over the past few months working on the A7Z, I’ve successfully ported a number of BSP drivers to Linux 6.18. The code is available here: https://github.com/alexcaoys/allwinner-bsp/tree/linux-6.18.y It’s currently tested on 6.18.19 and should, in theory, work with newer 6.18.y releases. I’ve tried to reuse as much upstream (mainline) drivers as possible, and have also upstreamed support for PCK600 and ET7304 used on the A7Z. Hopefully this helps accelerate ongoing mainline efforts. Feedback, issues, and PRs are very welcome. I may also look into creating branches for Linux 7.x in the future.
  22. Last week
  23. Pami, I have not personally found any LLM capable of generating working DTS files no matter what. It seems to be too niche for the LLM to understand. This DTS could potentially be a good starting ground for the pi, replacing "bcm2835" which refers to the pi zero 1, with "bcm2710" which refers to the pi zero 2. The github repository I linked is a good guide to getting the red displays working for a voron printer using panel-mipi driver, and I referenced it to create the DTS I use for the rock pi 4b. Also, try lowering the SPI speed to 20, 16, or 10 MHz, then raise it when you verify it works. I was frustrating myself for weeks thinking my DTS was broken, when it was fine the entire time, just my SPI speed was too high. robertoj: I appreciate your help, but I believe the issue I have with the red display (I have the same one as pami sent) is a combination of SPI commands being sent at the wrong interval (at the end of the clock cycle instead of in line), as well as insufficient SPI speed - where the display freezes above 24 MHz, and shows extreme visual tearing below it. At RGB666, its too much data for a measly 20MHz SPI rate, and the board does not support any other RGB modes in SPI. Since the TE pin is not exposed on the board, I cannot sync the SPI writes to the display. At least, that is my theory. I've given up on using an SPI display, and instead transitioned to an RGB Parallel display, which uses one gpio pin per color bit. Note that, at least in the display datasheet I received, the display actually does have the pins needed to drive it over DPI RGB Parallel. You can drive the board in 16, 18, or 24 bit mode over DPI RGB Parallel. These pins are not exposed on the board, but you could use an FPC breakout board to interface with these pins, and drive the display in DPI RGB parallel instead (accounting for the backlight voltage needed). The advantage of using RGB Parallel is it natively uses the GPU (RGB Parallel is the same technology as VGA) and has very fast refresh rate. For anyone here in future, any DPI hats that exist, like the adafruit kippah or othermod dpi topper, do not have the correct pinout to interface with this specific ili9486/8, but if you were to rearrange the pins on either the HATS or with an intermediary FPC PCB, then they would work plug and play.
  24. Hello, i tried "Armbian_community_26.2.0-trunk.606_Radxa-cubie-a5e_trixie_edge_6.19.8_minimal.img" and wlan didn't work, i think the device tree is broken Radxa-cubie-a5e kernel 6.19.x as a quick fix, I copy the kernel 6.18.x "sun55i-a527-cubie-a5e.dtb" file to the /boot/dtb/allwinner directory to get wlan working.
  25. hi, I installed in usb the last version and boot. something wrong happen here, only left these two upgrades, I tried again with backup-img and falied to boot again
  26. moved to off-topic since not directly related to armbian.
  27. Ok after trying a speeker switcher, switching from cinnimon to the kde version, finnally I tried flashing with the offical armbian flasher, and I tried a bunch of old online solutions that looked similar. Still my headphone doesn't work. I think it is due to armbian thinking the built in sound card is the headphones. But on a positive note the weird unmounting of armbian when my chromebook sleeps or when the lid is closed does not occur on armbian kde. So far kde is more stable than cinnimon.
  28. @José Manuel Márquez Luque try these images https://github.com/NickAlilovic/build/releases/tag/20250306
