Noob distro inquiry? picture included.
Tomi Skies replied to Tomi Skies's topic in Allwinner CPU Boxes
@Nick A I think this is what you were asking for? [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 6.12.11-edge-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0, GNU ld (GNU Binutils for Ubuntu) 2.38) #1 SMP PREEMPT Thu Jan 23 11:23:05 EST 2025 [ 0.000000] Machine model: hechuang,x96-q LPDDR3 [ 0.000000] efi: UEFI not found. [ 0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable secmon@40000000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000040000000-0x000000004007ffff] [ 0.000000] node 0: [mem 0x0000000040080000-0x000000007fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff] [ 0.000000] cma: Reserved 64 MiB at 0x000000007ac00000 on node -1 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.4 [ 0.000000] No bootconfig data provided, so skipping bootconfig [ 0.000000] percpu: Embedded 33 pages/cpu s95832 r8192 d31144 u135168 [ 0.000000] pcpu-alloc: s95832 r8192 d31144 u135168 alloc=33*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] alternatives: applying boot alternatives [ 0.000000] Kernel command line: root=UUID=adc7b539-05e1-42cd-b4a4-263c1693e027 rootwait rootfstype=ext4 splash plymouth.ignore-serial-consoles console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=1709ba65-01 usb-storage.quirks= cgroup_enable=memory [ 0.000000] Unknown kernel command line parameters "splash ubootpart=1709ba65-01 cgroup_enable=memory", will be passed to user space. [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 262144 [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: SWIOTLB bounce buffer size adjusted to 1MB [ 0.000000] software IO TLB: area num 4. [ 0.000000] software IO TLB: mapped [mem 0x000000007aa80000-0x000000007ab80000] (1MB) [ 0.000000] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] ftrace: allocating 56722 entries in 222 pages [ 0.000000] ftrace: allocated 222 pages with 6 groups [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4. [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] Root IRQ handler: gic_handle_irq [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention. [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000748] Console: colour dummy device 80x25 [ 0.000764] printk: legacy console [tty1] enabled [ 0.000876] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000) [ 0.000894] pid_max: default: 32768 minimum: 301 [ 0.001130] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.001147] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.013413] rcu: Hierarchical SRCU implementation. [ 0.013438] rcu: Max phase no-delay instances is 1000. [ 0.013807] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level [ 0.018991] EFI services will not be available. [ 0.019666] smp: Bringing up secondary CPUs ... [ 0.023824] Detected VIPT I-cache on CPU1 [ 0.023982] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.030517] Detected VIPT I-cache on CPU2 [ 0.030671] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.037099] Detected VIPT I-cache on CPU3 [ 0.037253] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.037464] smp: Brought up 1 node, 4 CPUs [ 0.037485] SMP: Total of 4 processors activated. [ 0.037492] CPU: All CPU(s) started at EL2 [ 0.037511] CPU features: detected: 32-bit EL0 Support [ 0.037517] CPU features: detected: 32-bit EL1 Support [ 0.037526] CPU features: detected: CRC32 instructions [ 0.037595] alternatives: applying system-wide alternatives [ 0.039007] Memory: 899180K/1048576K available (16448K kernel code, 3734K rwdata, 13308K rodata, 8000K init, 599K bss, 79692K reserved, 65536K cma-reserved) [ 0.040011] devtmpfs: initialized [ 0.052347] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns [ 0.052395] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.056229] 22192 pages in range for non-PLT usage [ 0.056260] 513712 pages in range for PLT usage [ 0.056531] pinctrl core: initialized pinctrl subsystem [ 0.057495] DMI not present or invalid. [ 0.061191] NET: Registered PF_NETLINK/PF_ROUTE protocol family [ 0.064428] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations [ 0.066238] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.068571] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.068695] audit: initializing netlink subsys (disabled) [ 0.069173] audit: type=2000 audit(0.066:1): state=initialized audit_enabled=0 res=1 [ 0.070850] thermal_sys: Registered thermal governor 'fair_share' [ 0.070868] thermal_sys: Registered thermal governor 'bang_bang' [ 0.070876] thermal_sys: Registered thermal governor 'step_wise' [ 0.070882] thermal_sys: Registered thermal governor 'user_space' [ 0.070999] cpuidle: using governor ladder [ 0.071046] cpuidle: using governor menu [ 0.071268] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.071425] ASID allocator initialised with 65536 entries [ 0.072373] Serial: AMBA PL011 UART driver [ 0.078705] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.078872] /soc/interrupt-controller@3021000: Fixed dependency cycle(s) with /soc/interrupt-controller@3021000 [ 0.079079] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.079164] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.079196] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.079229] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.079316] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.080419] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.084849] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.085617] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.085778] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.085894] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.086007] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.086038] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000 [ 0.086400] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000 [ 0.086519] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000 [ 0.095254] /soc/hdmi@6000000: Fixed dependency cycle(s) with /connector [ 0.095412] /connector: Fixed dependency cycle(s) with /soc/hdmi@6000000 [ 0.099761] cryptd: max_cpu_qlen set to 1000 [ 0.100844] ACPI: Interpreter disabled. [ 0.101575] iommu: Default domain type: Translated [ 0.101597] iommu: DMA domain TLB invalidation policy: strict mode [ 0.105171] SCSI subsystem initialized [ 0.105250] libata version 3.00 loaded. [ 0.105555] usbcore: registered new interface driver usbfs [ 0.105605] usbcore: registered new interface driver hub [ 0.105664] usbcore: registered new device driver usb [ 0.106578] pps_core: LinuxPPS API ver. 1 registered [ 0.106588] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.106616] PTP clock support registered [ 0.106970] scmi_core: SCMI protocol bus registered [ 0.107591] Advanced Linux Sound Architecture Driver Initialized. [ 0.109299] clocksource: Switched to clocksource arch_sys_counter [ 1.264644] pnp: PnP ACPI: disabled [ 1.277952] NET: Registered PF_INET protocol family [ 1.278256] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear) [ 1.347112] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 1.347168] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) [ 1.347278] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.347360] TCP bind hash table entries: 8192 (order: 6, 262144 bytes, linear) [ 1.347631] TCP: Hash tables configured (established 8192 bind 8192) [ 1.347829] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.347878] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.348142] NET: Registered PF_UNIX/PF_LOCAL protocol family [ 1.349136] RPC: Registered named UNIX socket transport module. [ 1.349160] RPC: Registered udp transport module. [ 1.349167] RPC: Registered tcp transport module. [ 1.349173] RPC: Registered tcp-with-tls transport module. [ 1.349179] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.349191] NET: Registered PF_XDP protocol family [ 1.349218] PCI: CLS 0 bytes, default 64 [ 1.349744] Trying to unpack rootfs image as initramfs... [ 1.357603] kvm [1]: nv: 554 coarse grained trap handlers [ 1.358468] kvm [1]: IPA Size Limit: 40 bits [ 1.362185] kvm [1]: vgic interrupt IRQ9 [ 1.362268] kvm [1]: Hyp nVHE mode initialized successfully [ 1.365769] Initialise system trusted keyrings [ 1.366320] workingset: timestamp_bits=46 max_order=18 bucket_order=0 [ 1.367238] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.368005] NFS: Registering the id_resolver key type [ 1.368079] Key type id_resolver registered [ 1.368087] Key type id_legacy registered [ 1.368128] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.368137] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering... [ 1.432380] NET: Registered PF_ALG protocol family [ 1.432434] Key type asymmetric registered [ 1.432443] Asymmetric key parser 'x509' registered [ 1.432451] Asymmetric key parser 'pkcs8' registered [ 1.432458] Key type pkcs7_test registered [ 1.432724] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 1.433146] io scheduler mq-deadline registered [ 1.433169] io scheduler kyber registered [ 1.433237] io scheduler bfq registered [ 1.448275] ledtrig-cpu: registered to indicate activity on CPUs [ 1.480564] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.486445] Serial: AMBA driver [ 1.518373] usbcore: registered new interface driver uas [ 1.518443] usbcore: registered new interface driver usb-storage [ 1.520054] mousedev: PS/2 mouse device common for all mice [ 1.522378] sun6i-rtc 7000000.rtc: registered as rtc0 [ 1.522450] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T00:00:08 UTC (86408) [ 1.530084] sdhci: Secure Digital Host Controller Interface driver [ 1.530108] sdhci: Copyright(c) Pierre Ossman [ 1.530569] Synopsys Designware Multimedia Card Interface Driver [ 1.533350] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.536789] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000000 [ 1.543257] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available [ 1.544271] watchdog: NMI not fully supported [ 1.544290] watchdog: Hard watchdog permanently disabled [ 1.560010] NET: Registered PF_PACKET protocol family [ 1.560493] Key type dns_resolver registered [ 1.577509] registered taskstats version 1 [ 1.578051] Loading compiled-in X.509 certificates [ 1.581712] zswap: loaded using pool zstd/zsmalloc [ 1.605540] sun8i-mixer 1100000.mixer: Adding to iommu group 0 [ 1.610387] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 1.624399] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver [ 1.626352] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-ph not found, using dummy regulator [ 1.631481] printk: legacy console [ttyS0] disabled [ 1.632221] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 286, base_baud = 1500000) is a 16550A [ 1.632334] printk: legacy console [ttyS0] enabled [ 1.634474] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pg not found, using dummy regulator [ 1.636489] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 287, base_baud = 1500000) is a 16550A [ 1.637038] serial serial0: tty port ttyS1 registered [ 1.642272] phy phy-5100400.phy.0: Changing dr_mode to 1 [ 1.643891] ehci-platform 5200000.usb: EHCI Host Controller [ 1.643959] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 1 [ 1.644182] ehci-platform 5200000.usb: irq 289, io mem 0x05200000 [ 1.646141] ehci-platform 5310000.usb: EHCI Host Controller [ 1.646195] ehci-platform 5310000.usb: new USB bus registered, assigned bus number 2 [ 1.646409] ehci-platform 5310000.usb: irq 290, io mem 0x05310000 [ 1.648884] ehci-platform 5311000.usb: EHCI Host Controller [ 1.648939] ehci-platform 5311000.usb: new USB bus registered, assigned bus number 3 [ 1.649129] ehci-platform 5311000.usb: irq 291, io mem 0x05311000 [ 1.652751] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00 [ 1.653247] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 1.653280] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.653291] usb usb1: Product: EHCI Host Controller [ 1.653300] usb usb1: Manufacturer: Linux 6.12.11-edge-sunxi64 ehci_hcd [ 1.653309] usb usb1: SerialNumber: 5200000.usb [ 1.653794] ohci-platform 5200400.usb: Generic Platform OHCI controller [ 1.653930] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests (id=vbus) [ 1.654662] hub 1-0:1.0: USB hub found [ 1.654764] hub 1-0:1.0: 1 port detected [ 1.655420] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 4 [ 1.655673] ohci-platform 5200400.usb: irq 293, io mem 0x05200400 [ 1.657364] ohci-platform 5310400.usb: Generic Platform OHCI controller [ 1.657416] ohci-platform 5310400.usb: new USB bus registered, assigned bus number 5 [ 1.657458] ohci-platform 5311400.usb: Generic Platform OHCI controller [ 1.657485] ohci-platform 5311400.usb: new USB bus registered, assigned bus number 6 [ 1.657621] ohci-platform 5310400.usb: irq 296, io mem 0x05310400 [ 1.657651] ohci-platform 5311400.usb: irq 295, io mem 0x05311400 [ 1.662738] ehci-platform 5310000.usb: USB 2.0 started, EHCI 1.00 [ 1.663180] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 1.663207] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.663218] usb usb2: Product: EHCI Host Controller [ 1.663227] usb usb2: Manufacturer: Linux 6.12.11-edge-sunxi64 ehci_hcd [ 1.663236] usb usb2: SerialNumber: 5310000.usb [ 1.664296] hub 2-0:1.0: USB hub found [ 1.664393] hub 2-0:1.0: 1 port detected [ 1.676059] ehci-platform 5311000.usb: USB 2.0 started, EHCI 1.00 [ 1.676529] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 1.676554] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.676564] usb usb3: Product: EHCI Host Controller [ 1.676574] usb usb3: Manufacturer: Linux 6.12.11-edge-sunxi64 ehci_hcd [ 1.676583] usb usb3: SerialNumber: 5311000.usb [ 1.677580] hub 3-0:1.0: USB hub found [ 1.677671] hub 3-0:1.0: 1 port detected [ 1.710376] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 1.710412] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.710423] usb usb4: Product: Generic Platform OHCI controller [ 1.710432] usb usb4: Manufacturer: Linux 6.12.11-edge-sunxi64 ohci_hcd [ 1.710441] usb usb4: SerialNumber: 5200400.usb [ 1.711497] hub 4-0:1.0: USB hub found [ 1.711580] hub 4-0:1.0: 1 port detected [ 1.713753] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 1.713786] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.713797] usb usb5: Product: Generic Platform OHCI controller [ 1.713806] usb usb5: Manufacturer: Linux 6.12.11-edge-sunxi64 ohci_hcd [ 1.713816] usb usb5: SerialNumber: 5310400.usb [ 1.714882] hub 5-0:1.0: USB hub found [ 1.714961] hub 5-0:1.0: 1 port detected [ 1.715819] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 1.715850] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.715861] usb usb6: Product: Generic Platform OHCI controller [ 1.715870] usb usb6: Manufacturer: Linux 6.12.11-edge-sunxi64 ohci_hcd [ 1.715879] usb usb6: SerialNumber: 5311400.usb [ 1.717008] hub 6-0:1.0: USB hub found [ 1.717104] hub 6-0:1.0: 1 port detected [ 2.171103] Freeing initrd memory: 15120K [ 2.642739] ehci-platform 5101000.usb: EHCI Host Controller [ 2.642775] ohci-platform 5101400.usb: Generic Platform OHCI controller [ 2.642826] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 8 [ 2.642826] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 7 [ 2.643037] ehci-platform 5101000.usb: irq 288, io mem 0x05101000 [ 2.643064] ohci-platform 5101400.usb: irq 292, io mem 0x05101400 [ 2.652664] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00 [ 2.653036] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12 [ 2.653051] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.653062] usb usb7: Product: EHCI Host Controller [ 2.653071] usb usb7: Manufacturer: Linux 6.12.11-edge-sunxi64 ehci_hcd [ 2.653080] usb usb7: SerialNumber: 5101000.usb [ 2.654032] hub 7-0:1.0: USB hub found [ 2.654096] hub 7-0:1.0: 1 port detected [ 2.700245] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12 [ 2.700276] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.700287] usb usb8: Product: Generic Platform OHCI controller [ 2.700297] usb usb8: Manufacturer: Linux 6.12.11-edge-sunxi64 ohci_hcd [ 2.700306] usb usb8: SerialNumber: 5101400.usb [ 2.701267] hub 8-0:1.0: USB hub found [ 2.701335] hub 8-0:1.0: 1 port detected [ 2.859796] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation. [ 2.860422] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver [ 2.862859] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator [ 2.864513] axp20x-i2c 0-0036: AXP20x variant AXP313a found [ 2.865313] axp20x-i2c 0-0036: AXP20X driver loaded [ 2.869396] vdd-dram: Bringing 1100000uV into 1200000-1200000uV [ 2.870982] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 2.874540] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq [ 2.875087] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pc not found, using dummy regulator [ 2.876429] sun4i-drm display-engine: Adding to iommu group 0 [ 2.893018] sun4i-drm display-engine: bound 1100000.mixer (ops sun8i_mixer_ops) [ 2.893430] sun4i-drm display-engine: bound 6510000.tcon-top (ops sun8i_tcon_top_ops) [ 2.894104] sun4i-drm display-engine: bound 6515000.lcd-controller (ops sun4i_tcon_ops) [ 2.894718] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY) [ 2.895637] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver [ 2.897414] sun4i-drm display-engine: bound 6000000.hdmi (ops sun8i_dw_hdmi_ops) [ 2.898644] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0 [ 2.905598] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode [ 2.905598] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 2.921204] mmc3: Failed to initialize a non-removable card [ 3.182647] usb 8-1: new full-speed USB device number 2 using ohci-platform [ 3.222685] mmc2: new DDR MMC card at address 0001 [ 3.224099] mmcblk2: mmc2:0001 P1J95K 7.30 GiB [ 3.228512] mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 [ 3.233698] mmcblk2boot0: mmc2:0001 P1J95K 2.00 MiB [ 3.236961] mmcblk2boot1: mmc2:0001 P1J95K 2.00 MiB [ 3.367675] Console: switching to colour frame buffer device 240x67 [ 3.390374] usb 8-1: New USB device found, idVendor=413c, idProduct=1003, bcdDevice= 1.00 [ 3.390399] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.390408] usb 8-1: Product: Dell USB Keyboard Hub [ 3.390415] usb 8-1: Manufacturer: Dell [ 3.396462] hub 8-1:1.0: USB hub found [ 3.398356] hub 8-1:1.0: 3 ports detected [ 3.403781] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device [ 3.411903] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator [ 3.414074] of_cfs_init [ 3.414132] of_cfs_init: OK [ 3.438659] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode [ 3.487368] mmc0: host does not support reading read-only switch, assuming write-enable [ 3.489155] mmc0: Problem switching card into high-speed mode! [ 3.489355] mmc0: new SDHC card at address 21f1 [ 3.490743] mmcblk0: mmc0:21f1 APPSD 7.50 GiB [ 3.494790] mmcblk0: p1 [ 3.542524] clk: Disabling unused clocks [ 3.542566] sun50i-h6-r-ccu 7010000.clock: Powering off unused clock r-apb2-rsb [ 3.542594] sun50i-h616-ccu 3001000.clock: Powering off unused clock bus-i2c3 [ 3.542670] sunxi-de33-clks 1008000.clock: Powering off unused clock wb-div [ 3.542680] sunxi-de33-clks 1008000.clock: Powering off unused clock mixer1-div [ 3.542720] sun50i-h616-ccu 3001000.clock: Powering off unused clock bus-pwm [ 3.542741] sun50i-h616-ccu 3001000.clock: Powering off unused clock bus-emac1 [ 3.542761] sun50i-h616-ccu 3001000.clock: Powering off unused clock bus-ve [ 3.542769] sun50i-h616-ccu 3001000.clock: Powering off unused clock bus-ce [ 3.542787] sun50i-h616-ccu 3001000.clock: Powering off unused clock ce [ 3.542800] sun50i-h616-ccu 3001000.clock: Powering off unused clock mbus-ce [ 3.542813] sun50i-h616-ccu 3001000.clock: Powering off unused clock cpux-apb [ 3.542820] sun50i-h616-ccu 3001000.clock: Powering off unused clock axi [ 3.542835] sun50i-h6-r-ccu 7010000.clock: Powering off unused clock r-apb1-twd [ 3.542860] PM: genpd: Disabling unused power domains [ 3.542882] ALSA device list: [ 3.542889] No soundcards found. [ 3.549765] Freeing unused kernel memory: 8000K [ 3.550055] Run /init as init process [ 3.550065] with arguments: [ 3.550072] /init [ 3.550077] splash [ 3.550082] with environment: [ 3.550086] HOME=/ [ 3.550091] TERM=linux [ 3.550095] ubootpart=1709ba65-01 [ 3.550100] cgroup_enable=memory [ 3.692752] usb 8-1.1: new full-speed USB device number 3 using ohci-platform [ 3.793527] usb 8-1.1: New USB device found, idVendor=413c, idProduct=2010, bcdDevice= 1.00 [ 3.793563] usb 8-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.793571] usb 8-1.1: Product: Dell USB Keyboard Hub [ 3.793577] usb 8-1.1: Manufacturer: Dell [ 3.869405] usb 8-1.3: new low-speed USB device number 4 using ohci-platform [ 3.911340] hid: raw HID events driver (C) Jiri Kosina [ 3.935176] usbcore: registered new interface driver usbhid [ 3.935211] usbhid: USB HID core driver [ 3.967475] usb 8-1.3: New USB device found, idVendor=03f0, idProduct=134a, bcdDevice= 1.00 [ 3.967518] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.967527] usb 8-1.3: Product: HP USB Optical Mouse [ 3.967533] usb 8-1.3: Manufacturer: PixArt [ 4.036015] input: Dell Dell USB Keyboard Hub as /devices/platform/soc/5101400.usb/usb8/8-1/8-1.1/8-1.1:1.0/0003:413C:2010.0001/input/input0 [ 4.187165] hid-generic 0003:413C:2010.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard Hub] on usb-5101400.usb-1.1/input0 [ 4.189062] input: Dell Dell USB Keyboard Hub Consumer Control as /devices/platform/soc/5101400.usb/usb8/8-1/8-1.1/8-1.1:1.1/0003:413C:2010.0002/input/input1 [ 4.240301] input: Dell Dell USB Keyboard Hub System Control as /devices/platform/soc/5101400.usb/usb8/8-1/8-1.1/8-1.1:1.1/0003:413C:2010.0002/input/input2 [ 4.241275] hid-generic 0003:413C:2010.0002: input,hidraw1: USB HID v1.10 Device [Dell Dell USB Keyboard Hub] on usb-5101400.usb-1.1/input1 [ 4.242326] input: PixArt HP USB Optical Mouse as /devices/platform/soc/5101400.usb/usb8/8-1/8-1.3/8-1.3:1.0/0003:03F0:134A.0003/input/input3 [ 4.245341] hid-generic 0003:03F0:134A.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt HP USB Optical Mouse] on usb-5101400.usb-1.3/input0 [ 4.335600] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pa not found, using dummy regulator [ 4.336317] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 4.336350] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 4.336360] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 4.336855] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 4.337363] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 4.337432] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 4.340694] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 4.340727] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 4.340734] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 4.340744] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 4.340750] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 4.340756] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 4.656544] dwmac-sun8i 5030000.ethernet end0: renamed from eth0 [ 5.676500] EXT4-fs (mmcblk0p1): mounted filesystem adc7b539-05e1-42cd-b4a4-263c1693e027 ro with writeback data mode. Quota mode: disabled. [ 7.290999] systemd[1]: System time before build time, advancing clock. [ 7.299934] systemd[1]: Failed to find module 'autofs4' [ 7.404849] NET: Registered PF_INET6 protocol family [ 7.406580] Segment Routing with IPv6 [ 7.406651] In-situ OAM (IOAM) with IPv6 [ 7.507441] systemd[1]: systemd 252.36-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified) [ 7.507517] systemd[1]: Detected architecture arm64. [ 7.518713] systemd[1]: Hostname set to <x96q-lpddr3>. [ 7.532309] systemd[1]: Initializing machine ID from random generator. [ 7.532941] systemd[1]: Installed transient /etc/machine-id file. [ 8.787575] systemd[1]: /lib/systemd/system/aw859a-wifi.service:9: Support for option SysVStartPriority= has been removed and it is ignored [ 9.066096] systemd[1]: Queued start job for default target graphical.target. [ 9.115709] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe. [ 9.118998] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty. [ 9.121114] systemd[1]: Created slice user.slice - User and Session Slice. [ 9.121897] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch. [ 9.122489] systemd[1]: Starting of proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point unsupported. [ 9.122951] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0... [ 9.123354] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes. [ 9.123980] systemd[1]: Reached target slices.target - Slice Units. [ 9.124393] systemd[1]: Reached target swap.target - Swaps. [ 9.124715] systemd[1]: Reached target time-set.target - System Time Set. [ 9.125181] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes. [ 9.153859] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket. [ 9.155555] systemd[1]: Listening on syslog.socket - Syslog Socket. [ 9.157229] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket. [ 9.158317] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe. [ 9.160567] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket. [ 9.161863] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log). [ 9.163560] systemd[1]: Listening on systemd-journald.socket - Journal Socket. [ 9.174815] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket. [ 9.176617] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket. [ 9.178694] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages). [ 9.230140] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System... [ 9.239542] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System... [ 9.247406] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System... [ 9.248830] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab). [ 9.258760] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock... [ 9.266973] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout... [ 9.275291] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes... [ 9.284438] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs... [ 9.298121] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 9.308178] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 9.319756] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 9.329221] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse... [ 9.340135] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 9.341649] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root). [ 9.358269] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules... [ 9.369146] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems... [ 9.378018] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices... [ 9.392841] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System. [ 9.395185] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System. [ 9.397317] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System. [ 9.399035] fuse: init (API version 7.41) [ 9.402299] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock. [ 9.408590] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes. [ 9.414717] systemd[1]: modprobe@configfs.service: Deactivated successfully. [ 9.416649] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs. [ 9.421304] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 9.423219] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 9.427549] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 9.428875] loop: module loaded [ 9.430770] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 9.434794] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 9.435928] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 9.438805] systemd[1]: modprobe@fuse.service: Deactivated successfully. [ 9.441526] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse. [ 9.444086] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 9.445303] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 9.483701] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System... [ 9.494828] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System... [ 9.495829] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 9.504700] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules. [ 9.506983] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System. [ 9.511814] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System. [ 9.529183] EXT4-fs (mmcblk0p1): re-mounted adc7b539-05e1-42cd-b4a4-263c1693e027 r/w. Quota mode: disabled. [ 9.540338] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables... [ 9.557415] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems. [ 9.560346] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 9.567747] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed... [ 9.577404] systemd[1]: Starting systemd-sysusers.service - Create System Users... [ 9.631572] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables. [ 9.680103] systemd[1]: Finished systemd-sysusers.service - Create System Users. [ 9.700560] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev... [ 9.786179] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout. [ 9.809458] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev. [ 9.811050] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems. [ 9.837183] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files... [ 10.132786] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices. [ 10.153759] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization... [ 10.155208] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files. [ 10.171427] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen... [ 10.324770] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen. [ 10.327210] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 10.328206] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch. [ 10.328824] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes. [ 10.366219] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0. [ 10.443448] systemd[1]: Mounting tmp.mount - /tmp... [ 10.474694] systemd[1]: Mounted tmp.mount - /tmp. [ 10.477641] systemd[1]: Reached target local-fs.target - Local File Systems. [ 10.490995] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 10.502306] systemd[1]: Starting console-setup.service - Set console font and keymap... [ 10.513376] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data... [ 10.533951] systemd[1]: systemd-binfmt.service - Set Up Additional Binary Formats was skipped because of an unmet condition check (ConditionPathIsMountPoint=/proc/sys/fs/binfmt_misc). [ 10.563759] systemd[1]: Received SIGRTMIN+20 from PID 141 (plymouthd). [ 10.589551] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data. [ 11.326056] random: crng init done [ 11.472969] zram: Added device: zram0 [ 11.501246] zram: Added device: zram1 [ 11.509968] zram: Added device: zram2 [ 13.039809] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget. [ 13.063290] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 13.188176] mc: Linux media interface: v0.10 [ 13.253093] systemd[1]: Finished systemd-random-seed.service - Load/Save Random Seed. [ 13.255296] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes). [ 13.263784] ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture [ 13.263830] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22 [ 13.264186] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22 [ 13.269834] panfrost 1800000.gpu: clock rate = 432000000 [ 13.269890] panfrost 1800000.gpu: bus_clock rate = 200000000 [ 13.273844] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 [ 13.273882] panfrost 1800000.gpu: features: 00000000,000027f7, issues: 00000000,00000400 [ 13.273892] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 13.273903] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1 [ 13.284970] [drm] Initialized panfrost 1.2.0 for 1800000.gpu on minor 1 [ 13.303840] systemd[1]: Starting systemd-machine-id-commit.service - Commit a transient machine-id on disk... [ 13.493329] Bluetooth: Core ver 2.22 [ 13.493617] NET: Registered PF_BLUETOOTH protocol family [ 13.493641] Bluetooth: HCI device and connection manager initialized [ 13.493674] Bluetooth: HCI socket layer initialized [ 13.493687] Bluetooth: L2CAP socket layer initialized [ 13.493746] Bluetooth: SCO socket layer initialized [ 13.544623] videodev: Linux video capture interface: v2.00 [ 13.554709] Registered IR keymap rc-beelink-gs1 [ 19.640645] IR NEC protocol handler initialized [ 19.663005] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0 [ 19.663497] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter [ 19.663806] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input4 [ 19.664982] sunxi-ir 7040000.ir: initialized sunXi IR driver [ 19.688327] zram0: detected capacity change from 0 to 992008 [ 24.259192] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 24.307216] Bluetooth: HCI UART driver ver 2.3 [ 24.307275] Bluetooth: HCI UART protocol H4 registered [ 24.307285] Bluetooth: HCI UART protocol BCSP registered [ 24.307510] Bluetooth: HCI UART protocol LL registered [ 24.307540] Bluetooth: HCI UART protocol ATH3K registered [ 24.307674] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 24.308233] Bluetooth: HCI UART protocol Intel registered [ 24.309588] hci_uart_bcm serial0-0: setup of GPIO device-wakeup failed: -517 [ 24.310020] Bluetooth: HCI UART protocol Broadcom registered [ 24.310215] Bluetooth: HCI UART protocol QCA registered [ 24.310324] Bluetooth: HCI UART protocol Marvell registered [ 24.334184] Adding 496000k swap on /dev/zram0. Priority:5 extents:1 across:496000k SS [ 32.016777] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned. [ 32.022146] cedrus 1c0e000.video-codec: Adding to iommu group 0 [ 32.024590] cedrus 1c0e000.video-codec: Device registered as /dev/video0 [ 32.027857] hci_uart_bcm serial0-0: setup of GPIO device-wakeup failed: -517 [ 32.085774] zram1: detected capacity change from 0 to 102400 [ 40.552790] systemd[1]: armbian-zram-config.service: start operation timed out. Terminating. [ 40.557542] systemd[1]: armbian-zram-config.service: Main process exited, code=killed, status=15/TERM [ 40.558509] systemd[1]: armbian-zram-config.service: Failed with result 'timeout'. [ 40.560789] systemd[1]: Failed to start armbian-zram-config.service - Armbian ZRAM config. [ 40.607552] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging... [ 41.285702] systemd[1]: etc-machine\x2did.mount: Deactivated successfully. [ 41.290677] systemd[1]: Finished systemd-machine-id-commit.service - Commit a transient machine-id on disk. [ 42.085251] platform sound-spdif: deferred probe pending: asoc-simple-card: parse error [ 42.085476] hci_uart_bcm serial0-0: setup of GPIO device-wakeup failed: -517 [ 42.161461] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid). [ 42.161806] systemd[1]: Starting of proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point unsupported. [ 42.163819] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages). [ 42.200734] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config... [ 42.220397] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod... [ 42.237360] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore... [ 42.257587] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop... [ 42.260023] systemd[1]: systemd-binfmt.service - Set Up Additional Binary Formats was skipped because of an unmet condition check (ConditionPathIsMountPoint=/proc/sys/fs/binfmt_misc). [ 42.275448] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization. [ 42.285658] systemd[1]: modprobe@dm_mod.service: Deactivated successfully. [ 42.287986] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod. [ 42.293825] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully. [ 42.300535] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore. [ 42.307205] systemd[1]: modprobe@loop.service: Deactivated successfully. [ 42.308915] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop. [ 42.353396] systemd[1]: Starting brltty.service - Braille Device Support... [ 42.354256] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore). [ 42.354896] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met. [ 42.617401] zram2: detected capacity change from 0 to 992008 [ 42.668120] Adding 496000k swap on /dev/zram2. Priority:5 extents:1 across:496000k SS [ 42.705025] zram: Added device: zram3 [ 42.771250] zram3: detected capacity change from 0 to 102400 [ 42.843419] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config. [ 43.075807] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging. [ 43.117222] systemd[1]: Starting systemd-journald.service - Journal Service... [ 43.549216] systemd[1]: Started brltty.service - Braille Device Support. [ 43.601315] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input5 [ 43.602007] systemd[1]: Started systemd-journald.service - Journal Service. [ 43.726191] systemd-journald[480]: Received client request to flush runtime journal. [ 124.562914] EXT4-fs (mmcblk0p1): resizing filesystem from 1185792 to 1924096 blocks [ 126.533018] EXT4-fs (mmcblk0p1): resized filesystem to 1924096 [ 183.983018] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 184.017032] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 184.017964] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600' [ 184.077310] ********************************************************** [ 184.077315] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** [ 184.077319] ** ** [ 184.077323] ** trace_printk() being used. Allocating extra memory. ** [ 184.077327] ** ** [ 184.077330] ** This means that this is a DEBUG kernel and it is ** [ 184.077334] ** unsafe for production use. ** [ 184.077338] ** ** [ 184.077342] ** If you see this message and you are not debugging ** [ 184.077346] ** the kernel, report this immediately to your vendor! ** [ 184.077350] ** ** [ 184.077354] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE ** [ 184.077357] ********************************************************** [ 184.110553] WCN: marlin_init entry! [ 184.111730] WCN: wcn config bt wake host [ 184.112213] WCN_ERR: dts node for bt_wake not found [ 184.112236] WCN: marlin2 parse_dt some para not config [ 184.112265] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840 [ 184.118837] sdiohal:sdiohal_init ok [ 184.125265] WCN: marlin_probe ok! [ 184.132054] hci_uart_bcm serial0-0: setup of GPIO device-wakeup failed: -517 [ 184.229635] WCN: start_marlin [MARLIN_WIFI] [ 184.229680] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1 [ 184.229694] WCN: the first power on start [ 184.332674] WCN: marlin chip en dummy pull up -- need manually set GPIO [ 184.356038] sdiohal:sdiohal_scan_card [ 184.534890] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid [ 185.233336] systemd-journald[480]: Received client request to relinquish /var/log/journal/4a30f185f8cf4182b75beed1259d890a access. [ 185.933778] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 185.933816] Bluetooth: BNEP filters: protocol multicast [ 185.933844] Bluetooth: BNEP socket layer initialized [ 186.936103] sdiohal err:wait scan card time out [ 190.136029] WCN_ERR: wait SDIO rescan card time out [ 190.136066] WCN_ERR: chip power on fail [ 190.136075] sdiohal:sdiohal_runtime_put entry [ 190.136082] sdiohal err:sdiohal_runtime_put line 1756 not have card [ 190.168436] sdiohal err:sdiohal_tx_thread line 152 not have card [ 193.336022] sprdwl:[WIFI_CMD_SYNC_VERSION]timeout [ 193.336066] sprdwl:ctx_id:0 cmd: WIFI_CMD_SYNC_VERSION[9] rsp timeout (mstime = 190165), num=1 [ 193.336091] sprdwl:SYNC CMD ERROR!! [ 193.336237] sprdwl:sprdwl_tx_deinit cmd not yet transmited, cmd_send:1, cmd_poped:0 [ 195.138463] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 195.141410] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 195.141475] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found [ 195.141489] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available [ 195.141498] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW [ 195.145723] hci_uart_bcm serial0-0: setup of GPIO device-wakeup failed: -517 [ 195.148537] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode [ 198.190763] dwmac-sun8i 5030000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx [ 202.557187] sprdwl:sprdwl_msg_deinit ref not ok! wait for pop! [ 205.581021] unisoc_wifi unisoc_wifi: probe with driver unisoc_wifi failed with error -1 [ 261.451914] systemd-journald[480]: Received client request to flush runtime journal. [ 357.759123] systemd-journald[480]: Received client request to relinquish /var/log/journal/4a30f185f8cf4182b75beed1259d890a access. [ 476.858514] dwmac-sun8i 5030000.ethernet end0: Link is Down [ 479.900088] dwmac-sun8i 5030000.ethernet end0: Link is Up - 100Mbps/Full - flow control rx/tx [ 625.780074] hdmi-audio-codec hdmi-audio-codec.5.auto: Only one simultaneous stream supported! [ 625.780137] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 - Today
Thanks for the answer, @amazingfate! I guess there might be e bug in the driver. Once I have more time (if I have) I will issue a bug report to the kernel devs and will try ti test and send required info. Regards, Tano
I have completed a build for the turing-rk1 SBC with an aim toward getting a functioning graphical console, and possibly installing desktop packages later. I built an image without issue that picked up kernel 6.17.2. git commit: 09160da3b9c1231cf20837e8c857f7e605130449 main branch Command used: ./compile.sh RELEASE=trixie CARD=turing-rk1 BRANCH=edge Image created: Armbian-unofficial_25.11.0-trunk_Turing-rk1_trixie_edge_6.17.2.img When booted, I get an error from dmesg about VOP drivers and HDMI video does not turn on. Is this normal for this board or am I doing something wrong? [ 0.965616] rckchip-drm display-subsystem: [drm:rockchip_drm_platform_probe] *ERROR* No available vop found for display-subsystem. The git commit that introduced this board in Armbian does appear to include GPU support, though I'm not really sure if that means the HDMI output should be working. https://github.com/armbian/build/commit/d564431dc2e2a16dff8d21391603702b43de06b1#diff-1d2956e936e3a376577f803ce53091b41ed47e906602165217f78912496eac63 Maybe I need to build w/ kernel 6.11.x to enable GPU support with these patches? Can someone clarify?
Maybe not? root@rp-satellite-01:~# for X in 0 1;do echo "mmcblk${X}: $(cat /sys/block/mmcblk${X}/device/type)";done mmcblk0: SD mmcblk1: SD root@rp-satellite-01:~# lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS sdb 8:16 1 238.3G 0 disk └─sdb1 8:17 1 238.3G 0 part /media/usb mmcblk1 179:0 0 59.6G 0 disk └─mmcblk1p1 179:1 0 59G 0 part /var/log.hdd / mmcblk0 179:32 0 3.6G 0 disk └─mmcblk0p1 179:33 0 3.5G 0 part zram0 252:0 0 233.1M 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk root@rp-satellite-01:~#
Collabora is proud to sponsor this year's annual GStreamer conference, taking place in London, UK. Join us as we showcase the latest with machine learning analytics, WirePlumber, and more. View the full article
Orange Pi 5 Pro - extend SPI4 to 5 chipselect
Rafael Junio replied to Rafael Junio's topic in Rockchip
I was able to extend, thanks everyone for the support. I attached my final dts, I also changed from spi4 to spi1, because I double check the pinount and spi4 is not mapped. In the original pinout armbian spi1 = orange pi 5 pro spi4. rk3588s-spi1-5cs-spidev.dts -
Thanks for your sharing! While I was trying to perform the upgrade for a Pine64, I happily notice that the latest release of armbian-config actually have an option for the distro upgrade. By following the wizard, Debian was upgrade to trixie.
Try an apt full-upgrade. The libraspberrypi packages have been deprecated recently (e.g. June/July) and recent RPI packages shouldn't depend on them, including raspi-firmware.
How to help Armbian about the new Orange pi sbc, orange pi 6 plus?
Werner replied to olivetree's topic in New boards
Hi, difficult task since there is no support for the whole chip family in the framework yet, but first steps are here:https://github.com/armbian/build/pull/8364 I suggest to start by getting familiar with the framework and how the mentioned pending pr it put together. moved -
Hello! I have an RPi5 8GB board that I bought off of AliExpress, along with a Waveshare PoE M.2 HAT+ ( https://www.waveshare.com/poe-m.2-hat-plus-b.htm ) Initially I tried to use the Noble XFCE image, by following the recommended installation procedure via rpi-imager via a USB drive, hoping to install the system to a Toshiba (Kioxia) NVMe drive. The RPI5 was connected to a CrowView Note. What I saw was that the firmware loaded up the necessary files from the USB drive (then later the micro-SD card), and the initramfs loaded up too, then systemd started up, and probably when the screen usually goes blank for a short time (probably switching to KMS), here, the signal completely drops, and apparently nothing happens. (The messages scroll too fast, and then disappear, and I can't make out anything from the screen content.) I tried looking on the network to see whether the RPi5 comes up at all, but no. Since then, I tried to eliminate elements from my setup to see whether that makes any difference: I removed the Waveshare HAT Swtiched to using a micro-SD card instead of the USB thumb drive Tried to boot it without the CrowView Note Tried using the Noble Server image to eliminate any possible problems with the graphical UI but none of these helped. I now have the bare RPi5 with an active heatsink, and it's still not booting properly. What should I try? Should I try to get serial console working so that I at least see the boot messages? Is there an activity LED on the RPI5 where I could at least configure a heartbeat so that I could check whether the OS is alive at all? Since the OS can't be installed, I can't really submit much diagnostic information.
@going Yes, git is a pain in ass. I think it's better to teach everyone the git commands. Maybe someone will learn from my instructions and contribute to the mainline Linux kernel and Armbian. Transpeed 8k618-t Tv box will always be supported because I learned how to use git commands and submit patches. I hope others will do the same. A lot of the patches are mainlined for h618. I don't think it will be too long before Armbian only needs a Transpeed 8k618 board config to build an image. But of course there's different variations of the same box. I hope this thread helps them because I won't be here forever.
The way the Debian .iso installer does it: sudo apt-get -o APT::Install-Recommends="true" install task-lxqt-desktop That will install a fully functional desktop with a minimal set of applications. If you set Install-Recommends to false, or any other way of installing it (i.e. lxqt), in my experience, the result may not be quite functional.
@remlei I'did uploading this imagem, is minimal, i hope help you! https://drive.google.com/file/d/1esroAyxq2D2kJ5XPB2_pofQ473B-h1_S/view
Dont write that "fbi works correctly", when it is not. The display remains white, and the kernel doesn't show any errors. * Re-check your wiring * Disconnect the touch part of the LCD pins * Try reversing the polarity: dc-gpios = <&pio 2 6 1>; << change the 1 to 0 reset-gpios = <&pio 2 9 1>; << change the 1 to 0 If the CPU is successful sending the reset signal, the data/command, the chip select and any bytes through SPI, at least the LCD should turn black.
Robert Steinman replied to Hqnicolas's topic in Rockchip CPU Boxes
@Hqnicolas Thanks for your response and apologies being so slow to reply busy IRL and then I forgot I used Google to sign up to this site.... yeah... Okay thanks - I thought it would just be a changing of timing so to speak on x86. In this case if I plan to develop for something I also go for the lowest variant of it, ofc, at this time both were Android. Rather code closer to the "metal" than bringing a whole web browser in to say "hello world" The images came from a link on this thread; either yourself or another member. Yeah I noticed a certain lag on the ethernet with 1GBit connection -- it has all the resources available yet it pings hard and downloads fluctuate. My plans for this Armbian is WiFi Repeater (router is broadcom and no Open- or DD-WRT alternative) to relay the signal. I don't want mesh, I don't need a TPLink account. The box will provide some services to Orange/Raspberry Pi systems. Right. I'm against AI So last thing I'd do. A link was provided but as I said expired. I'm sure there's differences in SDCard holders so didn't want to order two of the wrong type! Ah obrigado! I think your link may have solved it. I'll look in to it a bit in the future. Amazing how an Firestick turned me to Chinese TV boxes which are quite capable once you get rid of the Spyware. What I will say is, I think these boxes may have poor solder joints on the WiFi sub board, was hoping it was a misconfiguration my 8G model no longer recognizes the Wifi board, when I get the SD card holders I'll reflow it ad see. dmesg, lsusb, lspci know nothing of it. my 2G box the WiFi is fine. Regards -
I know this is older, but you need fping6 as well. See inside my install script for Zabbix server https://github.com/sgjava/install-zabbix/blob/589abd9527b1dbd505776a4c80afe8e515aef878/scripts/install.sh#L210
I simply don't need or want a desktop or anything with icons. I do use a few things on occasion that have toolbars like libre office or krita, gimp, ink scape, and kicad. But otherwise I have no use for all that mess of desktop window management and mousing. Xfce is ok for a half day of installing stuff. But otherwise I have no use for that stuff.
due to network limitations, how to compile Ubuntu 22.04 Gnome OS image in offline mode, build.sh need to download many debs,can I download them in advance,then install them locally. I have already downloaded kernel and uboot.
need help regarding wifi, i tried different server img and found no working wifi, should i just install armbian full or keep searching,,,,,plus is latest recommended or older versions......my device is 1gb ram with 8 rom, it may sound cheap, but i got this piece for free just tryin to repurpose it rather than getting a pi, i need it only for klipper, i got no lan ports left(lan ports are filled with different uses), only wifi, or should i just give up
Thank you so much for your help and explaining how it should work! I tried all the cores that you ordered - it only worked on this: #unnamed -a Linux orangepi5-plus 6.16.4-edge-rockchip64 #1 SMP PREEMPT Thu Aug 28 14:34:51 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux I put it like this: @apt install linux-image-edge-rockchip64 linux-headers-edge-rockchip64 The old cores were not suitable because the wifi card 0002:21:00.0 Network controller: MEDIATEK Corp. Device 7925 refuses to run on cores less than 6.12.X I bow low to you! cat /boot/armbianEnv.txt verbosity=1 bootlogo=true console=both overlay_prefix=rockchip-rk3588 fdtfile=rockchip/rk3588-orangepi-5-plus.dtb rootdev=UUID=e08e0355-09a7-41ad-a6db-fa17566a7f12 rootfstype=ext4 extraargs=cma=1G usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u With the extraargs=cma=1G parameter, videos in the browser somehow load faster.
Not planned but should be possible. A good start would be to copy the mentioend 2f and extract the device tree from official image and add it to vendor kernel source. If you're lucky that's all what's needed to get it to work.
moved to offtopic. not using Armbian. If you need support with that image, ask at the place where you downloaded from.
Anybody running a 100% wayland system?
robertoj replied to robertoj's topic in Software, Applications, Userspace
I got my issue resolved with labwc+greetd+nwg-hello See this link https://github.com/nwg-piotr/nwg-hello/issues/43 Please check it and post any corrections if needed Getting rpi-greeter (no python) and wf-panel-pi (combines panel and launcher in compact form) would be ideal, but not resolved yet. If anyone is interested in getting rpi-greeter working, this is my partial progress, and I still cannot make it start under lightdm, without any X11: sudo apt install lightdm accountsservice polkitd These might be needed. I installed them the day after I installed greetd and ngw-hello. Note: I am working from a minimal debian trixie image appmenu-gtk-module-common libaccountsservice-dev gir1.2-accountsservice-1.0 liblightdm-gobject-dev liblightdm-gobject-1-0 libgtk-3-dev gnome-common nasm ~$ mkdir rpi-greeter ; cd rpi-greeter wget https://github.com/raspberrypi-ui/pi-greeter/archive/refs/heads/master.zip unzip master.zip ; cd rpi-greeter-master autogen.sh ./configure make sudo make install Change /etc/lightdm/lightdm.conf with: greeter-session=pi-greeter-labwc Test with: $ sudo lightdm --test-mode --debug or $ sudo systemctl start lightdm $ journalctl -b -u lightdm.service The error is: Oct 13 22:01:49 orangepizero3 lightdm[845]: Error updating user /org/freedesktop/Accounts/User1000: GDBus.Error:org.freedesktop.Accounts.Error.PermissionDenied: Not authorized: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.PolicyKit1 was not provided by any .service files DEBUG: Could not run plymouth --ping: Failed to execute child process ?plymouth? (No such file or directory) I think I am very close to getting rpi-greeter working. What could be missing? I see that in a raspberry pi, the folder /etc/xdg/labwc-greeter/ exists, with 3 files inside, but in armbian, it doesn't exist. Should it be created by sudo make install? sudo nano /var/log/lightdm/lightdm.log: Nothing weird. Only: [+0.07s] DEBUG: Session pid=6392: Running command /usr/bin/labwc -C /etc/xdg/labwc-greeter/ (and this folder /etc/xdg/labwc-greeter/ does not exist) In raspberry: /etc/xdg/labwc-greeter/ contains autostart, rc.xml and environment sudo nano /var/log/lightdm/seat0-greeter.log: ** (process:6392): WARNING **: 00:23:07.745: Failed to open CK session: GDBus.Error:org.freedesktop.DBus.E> 00:00:00.000 [ERROR] [../src/main.c:202] XDG_RUNTIME_DIR is unset The etc/xdg/labwc-greeter/autostart, etc files come from a package named raspberrypi-ui-mods (raspberry$ dpkg -S /etc/xdg/labwc-greeter/autostart) What part of https://github.com/raspberrypi-ui/raspberrypi-ui-mods would get my lightdm+labwc+rpigreeter working? Copying the /etc/xdg/labwc-greeter/ folder with the 3 files, with the same permissions, allow the pi-greeter to display (it is very plain), but after entering the password, the text mode display shows for 2 seconds, then the labwc black background and cursor shows for 1/4 second, then returns to the login screen. Found this error in the log: /etc/xdg/labwc-greeter//autostart: 2: /usr/bin/kanshi: not found Final part of solution: lightdm should contain: user-session=LXDE-pi-labwc Create file /usr/share/wayland-sessions/ LXDE-pi-labwc.desktop: [Desktop Entry] Type=Application Name=Labwc Desktop on Wayland Exec=/usr/bin/labwc rpi-greeter does not allow selection of other sessions: only labwc -
Hello friends, I'm trying to install Armban from sd card or usb disk on a x96 max+ box( s905x3 confirmed, 4gb ram+ 32gb flash, realtek wifi and samsund emmc or nand). but nothing works. tried minimal and CLI but non of them works. I've done this before for another box(s905), but this one is giving me a hard time. Tried almost all dtb files, and renamed u-boot file as per instruction above( didn't patch the dtb file (as I felt it's already done for S905x3 in latest community image I used(Ubuntu 25.04 (Plucky) , Ubuntu 24.04 (Noble)). Tried installing from usb flash drive and sd card to make sure it's not about medium, no success. Some times the device enters into recovery menu( I think the toothpick method works but as it cannot detect a bootable media goes into recovery menu). and most of the times it goes into a loop ( I see boot logo and then restarts) from both usb and sd card. any Idea? someone said, they were able to boot from 24.5 desktop, but I was unable to find the exact same image to download. cheers, Ignore the message. found out what was wrong and fix it.
