  2. I have seen kernel updates for my system since you began this thread. You could check for a latest update, and see if the issue self-corrects. Do you know when the latest zfs-dkms package was updated? Perhaps it's just getting too out of sync with the kernels. If all else fails, you can build the kernel yourself: https://docs.armbian.com/Developer-Guide_Build-Preparation/ ...and in the kernel config, be sure that zfs modules are included. From the kernel config screen, you can do a search for zfs, and see what comes up. If there are zfs modules available there, this would be a different approach that would probably replace the use of the zfs-dkms package.
  3. Thank's for your prompt reply. Attached, you'll find the logs. SD boot fails with Armbian image on SD : bootlogM5Armbian.log SD boot success with ubuntu 20.4 (provided by BPI site) on SD : bootlogM5BPIUbuntu.log Regards Guy bootlogM5Armbian.log bootlogM5BPIUbuntu.log
  5. By some miracle of faith, yesterday at the last second before I gave up, I simply put Armbian_24.2.5_Rk322x-box_bookworm_current_6.6.22_minimal.img directly onto the SD card, and incredibly it loaded and I can use everything smoothly on the RK3229 (R329Q_V3.1), including running it on 5.0ghz Wi-Fi... but now the question is, can I put it on the NAND card? If it's not worth it, I'm thinking of leaving it on my SD card, then I'll buy other SD cards for my Raspberry Pi 1 b+ and another TV box I have (I haven't seen the card yet). I'm building a minilab. actually minilab(not working again) A computer with an AMD A4-4000 + 8GB RAM with Proxmox. A Raspy with Dietipi, Pihole, and Adguard. A TVBox-1 for observability (Grafana stack). A TVBox-2 to act as a redundancy node for TVBox-1 and a test server. Speaking directly, I took the image and ran the commands I saw on some postmarketos forums about recording directly via rkdev: rkdeveloptool wl 0x0 rockchip-rk322x-exemple.img
  6. i too am facing this problem, i bought this box for round 1500 inr with armbian in mind i thought it would be h3 but it was h313 and then i also noticed that the fonts looked different on the soc, well here i am. the main purpose for this purchase was installing armbian to run home assistant server but that aint gonna happen and raspberry pi's and other alternatives are too expensive still not what i bought it for but yeah gotta live with it now btw any updates on this
  7. Hello community Here are the versions I’m using: Kernel: 5.15.48-sunxi OS: Linux nanopineo 5.15.48-sunxi #22.05.3 SMP Wed Feb 19 15:56:03 UTC 2025 armv7l GNU/Linux I’m having a problem. Sometimes, during boot, I see the following log: After this message, the system halts. The only way to fix it is to flash the image again or to boot from an SD card and mount the EMMC which fixes the file system. I noticed that the device doesn’t use the overlay_prefix variable from /boot/armbianEnv.txt. It shows this message: I tried adding the overlay_prefix variable manually in the boot.cmd file, but it didn’t help. Previously, I changed: to Could that be the cause? I changed it back to default but the problem still happens. Do you have any ideas what could be wrong?
  8. I think it's easier than that. I looked into the postinst file for kernel headers on my Ubuntu machine, and I found this: #!/bin/sh set -e version=6.17.0-7-generic if [ "$1" != configure ]; then exit 0 fi if [ -d /etc/kernel/header_postinst.d ]; then DEB_MAINT_PARAMS="$*" run-parts --report --exit-on-error --arg=$version \ /etc/kernel/header_postinst.d fi exit 0 The postinst script for the headers package doesn't have anything similar, so we should add it this part related to execute the scripts under `/etc/kernel/header_postinst.d`. Can you do that or should we add someone else to the discussion? EDIT: Debian does something similar. Same goal, just a different code: #!/bin/sh -e version=6.12.48+deb13-amd64 linux-run-hooks headers postinst $version -- "$@" exit 0
  9. Yes That's on us
  10. @Jeeva Kandasamy it’s on this page https://github.com/NickAlilovic/build/tree/v20250306
  11. Latest compile for odroid xu4 does have a desktop. Any reason why?
  12. Same answer and further reasoning as here:
  13. better in which way? performance? driver support? size? from our pov the better the support conditions, the more likely to recommend. https://www.armbian.com/download/?device_support=Standard support Is one platinum? Go for it? If not, check standard support. If one is in this category, go for it. If not, check further down for community support.
  14. I think the upstream kernel has fixed it recently. Could your try the patch? https://git.kernel.org/pub/scm/linux/kernel/git/next/linux-next.git/commit/?id=a28352cf2d2f8380e7aca8cb61682396dca7a991
  15. Thank you for the answer. @Nick A
  16. Yesterday
  17. @snow https://linux-sunxi.org/FEL/USBBoot I haven’t tried this before.
  18. Agreed. A check if the package is installed (and if not install it beforehand) would be sufficient too. PRs to fix this are highly appreciated. https://github.com/armbian/build/blob/main/packages/bsp/common/usr/bin/armbian-install
  19. You'll spend the money once. Then you'll have the result thereafter. I would suggest deciding what you want, then spending whatever it costs. Orange PI is "cheap", not just in price, but in hardware reliability as well as software support. I'm not aware of such issues with Radxa. RK3588 is more powerful than Raspberry PI, but as you say Raspberry PI has great community and support. Perhaps the question is - What do you need it for? Raspberry PI might be powerful enough for your needs.
  20. I have an Orange PI 5 Plus, and both USB-C connectors (including the one used for power delivery) are faulty. Also the second HDMI output is corrupted. Clearly their manufacturer leaves a lot to be desired.
  21. sudo rm -rf /var/lib/apt/lists/* sudo apt clean sudo apt update sudo apt upgrade works for me.
  22. Thank you for your quick answer, Jimbolaya. Yes, I did try different cables all with the same result. I wonder if there is another way to access the serial console, J13 perhaps? Albeit with some required soldering, I suppose. Then remains the question of which headers exactly relate to GND, TX and RX.
  23. I noticed this problem a long time ago, but now I feel it is important to fix it: I get a slim black bar on the left side, and a portion of the pixels on the right get "cropped" because they don't fit in the LCD display area? Do you get the same in your LCD? Do you know a way to fix it? I am talking about this LCD: RED PCB LCD https://www.aliexpress.us/item/3256802847521952.html?
  24. Last week
  25. Update: It works now, however the power LED doesn't seem to light up, but the video card is detected in /dev
  26. I have managed to successfully install Armbian onto the DELL Wyse3040 As mentioned above, the way to do this is to use a PE environment that works on these devices. I used an old version of Hiren's BootCD and booted from it. Then I used a NTFS formatted flash drive with the unzipped image and used Roadkill's Disk Image to write it to the eMMC And it works, beautifully
