moved to off-topic since op is not using Armbian.
OZPI v1 new image with Armbian v26.2 Debian stable (trixie)
TRay replied to TRay's topic in Allwinner sunxi
I'm sorry, but I don't really understand what a microSD card has to do with the problem above to perform system updates? - Today
I see that this configuration is a kernel build feature, not an armbian-developed function: https://cateee.net/lkddb/web-lkddb/INITRAMFS_SOURCE.html https://unix.stackexchange.com/questions/479415/how-does-linux-know-where-the-rootfs-is So, you can post your question in many more linux discussion places. I hope you get the answer (and share here). Have you ever got this INITRAMFS_SOURCE configuration work, outside of Armbian... for example building the kernel from source by itself?
Also, this TVBOX contains the less known S9012P wifi chip. However on this github repository some kind of unofficial driver support is available, can this driver get the wifi chip working on Armbian ?
All clear for the PCIe MSI: it is something with that Intel 7260 card. Today, I got two other M.2 Wifis: MT7922 and RTL8822ce, both seem to work on current and also on edge. Thus, I consider this as a success. Here's some screen blurb. // Sven-Ola
Minor update, I hardcoded usage of uboot debugging option and removed cache to force compiling uboot. But output from bootloader remained the same: U-Boot SPL 2024.01_armbian-2024.01-S866c-P7738-Ha5c2-Vcc17-Bf389-R448a (Jan 08 2026 - 10:33:14 +0000) DRAM: 512 MiB Trying to boot from MMC1 Maybe detailed logging was already enabled? But it still does not give me any hints. Especially my board does not contain any additional slots like emmc, only for micro sd card (I don't understand why bootloader tries to use mmc1) UPD: I find out question with a little bit similar problem (hang out on mmc1) but need time to understand the reason, maybe it has similar issue
The Rock Pi S completely freezes during OOMs
solaris3308 replied to solaris3308's topic in Radxa Rock Pi S
Thank you reply, brentr. I add some info. passmark run command param is -r 2 ,means only run memory test.By the way ,I rename "PerformanceTest_Linux_ARM64" to passmark.Which you can download from "https://www.passmark.com/products/pt_linux/download.php" or "https://www.passmark.com/downloads/PerformanceTest_Linux_ARM64.zip" The only reason ,I install xterm,is I need use resize command to resize serial console.And I install it at 4.4 kernel also. pi@Pi-s:~$ apt list --installed 7zip/stable,now 25.01+dfsg-1~deb13u1 arm64 [installed,automatic] adbd/stable,now 34.0.5-12 arm64 [installed] adduser/stable,now 3.152 all [installed,automatic] adwaita-icon-theme/stable,now 48.1-1 all [installed,automatic] alsa-utils/stable,now 1.2.14-1 arm64 [installed] android-libbase/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-libboringssl/stable,now 14.0.0+r45-2 arm64 [installed,automatic] android-libcutils/stable,now 1:34.0.5-12 arm64 [installed,automatic] android-liblog/stable,now 1:34.0.5-12 arm64 [installed,automatic] apt-utils/stable,now 3.0.3 arm64 [installed] apt/stable,now 3.0.3 arm64 [installed] armbian-bsp-cli-rockpi-s-current/now 25.11.2 arm64 [installed,local] armbian-config/unknown,now 26.2.0-trunk.126.1225.000141 all [installed] armbian-firmware/now 25.11.2 all [installed,local] at-spi2-common/stable,now 2.56.2-1 all [installed,automatic] avahi-daemon/stable,now 0.8-16 arm64 [installed,automatic] avahi-utils/stable,now 0.8-16 arm64 [installed] base-files/now 25.11.2-13.8+deb13u2-trixie arm64 [installed,local] base-passwd/stable,now 3.6.7 arm64 [installed] bash-completion/stable,now 1:2.16.0-7 all [installed] bash/stable,now 5.2.37-2+b5 arm64 [installed] bc/stable,now 1.07.1-4+b1 arm64 [installed] binutils-aarch64-linux-gnu/stable,now 2.44-3 arm64 [installed,automatic] binutils-common/stable,now 2.44-3 arm64 [installed,automatic] binutils/stable,now 2.44-3 arm64 [installed,automatic] bsdextrautils/stable,now 2.41-5 arm64 [installed,automatic] bsdutils/stable,now 1:2.41-5 arm64 [installed] btop/stable,now 1.3.2-0.1 arm64 [installed] btrfs-progs/stable,now 6.14-1 arm64 [installed] build-essential/stable,now 12.12 arm64 [installed] bzip2/stable,now 1.0.8-6 arm64 [installed,automatic] ca-certificates/stable,now 20250419 all [installed] console-setup-linux/stable,now 1.242~deb13u1 all [installed,automatic] console-setup/stable,now 1.242~deb13u1 all [installed] coreutils/stable,now 9.7-3 arm64 [installed] cpio/stable,now 2.15+dfsg-2 arm64 [installed,automatic] cpp-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-14/stable,now 14.2.0-19 arm64 [installed,automatic] cpp-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] cpp/stable,now 4:14.2.0-1 arm64 [installed,automatic] cron-daemon-common/stable,now 3.0pl1-197 all [installed,automatic] cron/stable,now 3.0pl1-197 arm64 [installed] curl/stable,now 8.14.1-2+deb13u2 arm64 [installed] cutecom/stable,now 0.51.0-1+b3 arm64 [installed] dash/stable,now 0.5.12-12 arm64 [installed] dbus-bin/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-daemon/stable,now 1.16.2-2 arm64 [installed,automatic] dbus-session-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-system-bus-common/stable,now 1.16.2-2 all [installed,automatic] dbus-user-session/stable,now 1.16.2-2 arm64 [installed] dbus/stable,now 1.16.2-2 arm64 [installed,automatic] dconf-gsettings-backend/stable,now 0.40.0-5 arm64 [installed,automatic] dconf-service/stable,now 0.40.0-5 arm64 [installed,automatic] debconf-utils/stable,now 1.5.91 all [installed] debconf/stable,now 1.5.91 all [installed] debian-archive-keyring/stable,now 2025.1 all [installed,automatic] debianutils/stable,now 5.23.2 arm64 [installed] debsums/stable,now 3.0.2.3 all [installed] device-tree-compiler/stable,now 1.7.2-2+b1 arm64 [installed] dialog/stable,now 1.3-20250116-1 arm64 [installed] diffutils/stable,now 1:3.10-4 arm64 [installed] dmidecode/stable,now 3.6-2 arm64 [installed] dmsetup/stable,now 2:1.02.205-2 arm64 [installed,automatic] dosfstools/stable,now 4.2-1.2 arm64 [installed] dpkg-dev/stable,now 1.22.21 all [installed,automatic] dpkg/stable,now 1.22.21 arm64 [installed] dracut-install/stable,now 106-6 arm64 [installed,automatic] e2fsprogs/stable,now 1.47.2-3+b3 arm64 [installed] ethtool/stable,now 1:6.14.2-1 arm64 [installed] fake-hwclock/stable,now 0.14 all [installed] fdisk/stable,now 2.41-5 arm64 [installed] figlet/stable,now 2.2.5-3+b2 arm64 [installed] file/stable,now 1:5.46-5 arm64 [installed] findutils/stable,now 4.10.0-3 arm64 [installed] fontconfig-config/stable,now 2.15.0-2.3 arm64 [installed,automatic] fontconfig/stable,now 2.15.0-2.3 arm64 [installed,automatic] fonts-dejavu-core/stable,now 2.37-8 all [installed,automatic] fonts-dejavu-mono/stable,now 2.37-8 all [installed,automatic] fping/stable,now 5.1-1+b1 arm64 [installed,automatic] g++-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] g++-14/stable,now 14.2.0-19 arm64 [installed,automatic] g++-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] g++/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc-14-aarch64-linux-gnu/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-14-base/stable,now 14.2.0-19 arm64 [installed] gcc-14/stable,now 14.2.0-19 arm64 [installed,automatic] gcc-aarch64-linux-gnu/stable,now 4:14.2.0-1 arm64 [installed,automatic] gcc/stable,now 4:14.2.0-1 arm64 [installed,automatic] gensio-bin/stable,now 2.8.13-7 arm64 [installed] git-man/stable,now 1:2.47.3-0+deb13u1 all [installed,automatic] git/stable,now 1:2.47.3-0+deb13u1 arm64 [installed] gpg/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgconf/stable,now 2.4.7-21+b3 arm64 [installed,automatic] gpgv/stable,now 2.4.7-21+b3 arm64 [installed] gpiod/stable,now 2.2.1-2+deb13u1 arm64 [installed] grep/stable,now 3.11-4+b1 arm64 [installed] groff-base/stable,now 1.23.0-9 arm64 [installed,automatic] gtk-update-icon-cache/stable,now 4.18.6+ds-2 arm64 [installed,automatic] gzip/stable,now 1.13-1 arm64 [installed] hicolor-icon-theme/stable,now 0.18-2 all [installed,automatic] hostname/stable,now 3.25 arm64 [installed] htop/stable,now 3.4.1-5 arm64 [installed] iftop/stable,now 1.0~pre4-9+b2 arm64 [installed] inetutils-telnet/stable,now 2:2.6-3 arm64 [installed,automatic] inetutils-traceroute/stable,now 2:2.6-3 arm64 [installed] init-system-helpers/stable,now 1.69~deb13u1 all [installed] init/stable,now 1.69~deb13u1 arm64 [installed] initramfs-tools-bin/stable,now 0.148.3 arm64 [installed,automatic] initramfs-tools-core/stable,now 0.148.3 all [installed,automatic] initramfs-tools/stable,now 0.148.3 all [installed] iproute2/stable,now 6.15.0-1 arm64 [installed] iputils-ping/stable,now 3:20240905-3 arm64 [installed] iw/stable,now 6.9-1+b1 arm64 [installed] jq/stable,now 1.7.1-6+deb13u1 arm64 [installed] kbd/stable,now 2.7.1-2 arm64 [installed,automatic] keyboard-configuration/stable,now 1.242~deb13u1 all [installed,automatic] klibc-utils/stable,now 2.0.14-1 arm64 [installed,automatic] kmod/stable,now 34.2-2 arm64 [installed,automatic] less/stable,now 668-1 arm64 [installed] libacl1/stable,now 2.3.2-2+b1 arm64 [installed] libaio1t64/stable,now 0.3.113-8+b1 arm64 [installed,automatic] libapparmor1/stable,now 4.1.0-1 arm64 [installed,automatic] libapt-pkg7.0/stable,now 3.0.3 arm64 [installed,automatic] libasan8/stable,now 14.2.0-19 arm64 [installed,automatic] libasound2-data/stable,now 1.2.14-1 all [installed,automatic] libasound2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libassuan9/stable,now 3.0.2-2 arm64 [installed,automatic] libatk-bridge2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatk1.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libatomic1/stable,now 14.2.0-19 arm64 [installed,automatic] libatopology2t64/stable,now 1.2.14-1 arm64 [installed,automatic] libatspi2.0-0t64/stable,now 2.56.2-1 arm64 [installed,automatic] libattr1/stable,now 1:2.5.2-3 arm64 [installed] libaudit-common/stable,now 1:4.0.2-2 all [installed] libaudit1/stable,now 1:4.0.2-2+b2 arm64 [installed] libavahi-client3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common-data/stable,now 0.8-16 arm64 [installed,automatic] libavahi-common3/stable,now 0.8-16 arm64 [installed,automatic] libavahi-core7/stable,now 0.8-16 arm64 [installed,automatic] libbinutils/stable,now 2.44-3 arm64 [installed,automatic] libblkid1/stable,now 2.41-5 arm64 [installed] libbpf1/stable,now 1:1.5.0-3 arm64 [installed,automatic] libbrotli1/stable,now 1.1.0-2+b7 arm64 [installed,automatic] libbsd0/stable,now 0.12.2-2 arm64 [installed,automatic] libbz2-1.0/stable,now 1.0.8-6 arm64 [installed] libc-bin/stable,now 2.41-12 arm64 [installed] libc-dev-bin/stable,now 2.41-12 arm64 [installed,automatic] libc-l10n/stable,now 2.41-12 all [installed,automatic] libc6-dev/stable,now 2.41-12 arm64 [installed,automatic] libc6/stable,now 2.41-12 arm64 [installed] libcaca0/stable,now 0.99.beta20-5 arm64 [installed,automatic] libcairo-gobject2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcairo2/stable,now 1.18.4-1+b1 arm64 [installed,automatic] libcap-ng0/stable,now 0.8.5-4+b1 arm64 [installed] libcap2-bin/stable,now 1:2.75-10+b1 arm64 [installed,automatic] libcap2/stable,now 1:2.75-10+b1 arm64 [installed] libcbor0.10/stable,now 0.10.2-2 arm64 [installed,automatic] libcc1-0/stable,now 14.2.0-19 arm64 [installed,automatic] libcloudproviders0/stable,now 0.3.6-2 arm64 [installed,automatic] libcolord2/stable,now 1.4.7-3 arm64 [installed,automatic] libcom-err2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libcrypt-dev/stable,now 1:4.4.38-1 arm64 [installed,automatic] libcrypt1/stable,now 1:4.4.38-1 arm64 [installed] libctf-nobfd0/stable,now 2.44-3 arm64 [installed,automatic] libctf0/stable,now 2.44-3 arm64 [installed,automatic] libcups2t64/stable,now 2.4.10-3+deb13u2 arm64 [installed,automatic] libcurl3t64-gnutls/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libcurl4t64/stable,now 8.14.1-2+deb13u2 arm64 [installed,automatic] libdaemon0/stable,now 0.14-7.1+b3 arm64 [installed,automatic] libdatrie1/stable,now 0.2.13-3+b1 arm64 [installed,automatic] libdb5.3t64/stable,now 5.3.28+dfsg2-9 arm64 [installed] libdbus-1-3/stable,now 1.16.2-2 arm64 [installed,automatic] libdconf1/stable,now 0.40.0-5 arm64 [installed,automatic] libdebconfclient0/stable,now 0.280 arm64 [installed] libdeflate0/stable,now 1.23-2 arm64 [installed,automatic] libdevmapper1.02.1/stable,now 2:1.02.205-2 arm64 [installed,automatic] libdialog15/stable,now 1.3-20250116-1 arm64 [installed,automatic] libdouble-conversion3/stable,now 3.3.1-1 arm64 [installed,automatic] libdpkg-perl/stable,now 1.22.21 all [installed,automatic] libdrm-amdgpu1/stable,now 2.4.124-2 arm64 [installed,automatic] libdrm-common/stable,now 2.4.124-2 all [installed,automatic] libdrm2/stable,now 2.4.124-2 arm64 [installed,automatic] libedit2/stable,now 3.1-20250104-1 arm64 [installed,automatic] libegl-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libegl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libelf1t64/stable,now 0.192-4 arm64 [installed,automatic] libepoxy0/stable,now 1.5.10-2 arm64 [installed,automatic] liberror-perl/stable,now 0.17030-1 all [installed,automatic] libestr0/stable,now 0.1.11-2 arm64 [installed,automatic] libevdev2/stable,now 1.13.4+dfsg-1 arm64 [installed,automatic] libexpat1/stable,now 2.7.1-2 arm64 [installed,automatic] libext2fs2t64/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libfastjson4/stable,now 1.2304.0-2 arm64 [installed,automatic] libfdisk1/stable,now 2.41-5 arm64 [installed,automatic] libfdt1/stable,now 1.7.2-2+b1 arm64 [installed,automatic] libffi8/stable,now 3.4.8-2 arm64 [installed,automatic] libfftw3-single3/stable,now 3.3.10-2+b1 arm64 [installed,automatic] libfido2-1/stable,now 1.15.0-1+b1 arm64 [installed,automatic] libfile-fnmatch-perl/stable,now 0.02-3+b4 arm64 [installed,automatic] libfontconfig1/stable,now 2.15.0-2.3 arm64 [installed,automatic] libfreetype6/stable,now 2.13.3+dfsg-1 arm64 [installed,automatic] libfribidi0/stable,now 1.0.16-1 arm64 [installed,automatic] libgbm1/stable,now 25.0.7-2 arm64 [installed,automatic] libgcc-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libgcc-s1/stable,now 14.2.0-19 arm64 [installed] libgcrypt20/stable,now 1.11.0-7 arm64 [installed,automatic] libgdbm-compat4t64/stable,now 1.24-2 arm64 [installed,automatic] libgdbm6t64/stable,now 1.24-2 arm64 [installed,automatic] libgdk-pixbuf-2.0-0/stable,now 2.42.12+dfsg-4 arm64 [installed,automatic] libgdk-pixbuf2.0-common/stable,now 2.42.12+dfsg-4 all [installed,automatic] libgensio6t64/stable,now 2.8.13-7 arm64 [installed,automatic] libgl1-mesa-dri/stable,now 25.0.7-2 arm64 [installed,automatic] libgl1/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglib2.0-0t64/stable,now 2.84.4-3~deb13u1 arm64 [installed,automatic] libglvnd0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libglx-mesa0/stable,now 25.0.7-2 arm64 [installed,automatic] libglx0/stable,now 1.7.0-1+b2 arm64 [installed,automatic] libgmp10/stable,now 2:6.3.0+dfsg-3 arm64 [installed] libgnutls30t64/stable,now 3.8.9-3 arm64 [installed,automatic] libgomp1/stable,now 14.2.0-19 arm64 [installed,automatic] libgpg-error0/stable,now 1.51-4 arm64 [installed,automatic] libgpiod3/stable,now 2.2.1-2+deb13u1 arm64 [installed,automatic] libgpm2/stable,now 1.20.7-11+b2 arm64 [installed,automatic] libgprofng0/stable,now 2.44-3 arm64 [installed,automatic] libgraphite2-3/stable,now 1.3.14-2+b1 arm64 [installed,automatic] libgssapi-krb5-2/stable,now 1.21.3-5 arm64 [installed,automatic] libgtk-3-0t64/stable,now 3.24.49-3 arm64 [installed,automatic] libgtk-3-common/stable,now 3.24.49-3 all [installed,automatic] libgudev-1.0-0/stable,now 238-6 arm64 [installed,automatic] libharfbuzz0b/stable,now 10.2.0-1+b1 arm64 [installed,automatic] libhogweed6t64/stable,now 3.10.1-1 arm64 [installed,automatic] libhwasan0/stable,now 14.2.0-19 arm64 [installed,automatic] libice6/stable,now 2:1.1.1-1 arm64 [installed,automatic] libicu76/stable,now 76.1-4 arm64 [installed,automatic] libidn2-0/stable,now 2.3.8-2 arm64 [installed,automatic] libiniparser4/stable,now 4.2.6-1 arm64 [installed,automatic] libinput-bin/stable,now 1.28.1-1 arm64 [installed,automatic] libinput10/stable,now 1.28.1-1 arm64 [installed,automatic] libisl23/stable,now 0.27-1 arm64 [installed,automatic] libitm1/stable,now 14.2.0-19 arm64 [installed,automatic] libjansson4/stable,now 2.14-2+b3 arm64 [installed,automatic] libjbig0/stable,now 2.1-6.1+b2 arm64 [installed,automatic] libjpeg62-turbo/stable,now 1:2.1.5-4 arm64 [installed,automatic] libjq1/stable,now 1.7.1-6+deb13u1 arm64 [installed,automatic] libk5crypto3/stable,now 1.21.3-5 arm64 [installed,automatic] libkeyutils1/stable,now 1.6.3-6 arm64 [installed,automatic] libklibc/stable,now 2.0.14-1 arm64 [installed,automatic] libkmod2/stable,now 34.2-2 arm64 [installed,automatic] libkrb5-3/stable,now 1.21.3-5 arm64 [installed,automatic] libkrb5support0/stable,now 1.21.3-5 arm64 [installed,automatic] libksba8/stable,now 1.6.7-2+b1 arm64 [installed,automatic] liblastlog2-2/stable,now 2.41-5 arm64 [installed] liblcms2-2/stable,now 2.16-2 arm64 [installed,automatic] libldap2/stable,now 2.6.10+dfsg-1 arm64 [installed,automatic] liblerc4/stable,now 4.0.0+ds-5 arm64 [installed,automatic] libllvm19/stable,now 1:19.1.7-3+b1 arm64 [installed,automatic] liblocale-gettext-perl/stable,now 1.07-7+b1 arm64 [installed,automatic] liblognorm5/stable,now 2.0.6-5 arm64 [installed,automatic] liblsan0/stable,now 14.2.0-19 arm64 [installed,automatic] liblsof0/stable,now 4.99.4+dfsg-2 arm64 [installed,automatic] liblua5.4-0/stable,now 5.4.7-1+b2 arm64 [installed,automatic] libluajit-5.1-2/stable,now 2.1.0+openresty20250117-2 arm64 [installed,automatic] libluajit-5.1-common/stable,now 2.1.0+openresty20250117-2 all [installed,automa> liblz1/stable,now 1.15-3 arm64 [installed,automatic] liblz4-1/stable,now 1.10.0-4 arm64 [installed,automatic] liblzma5/stable,now 5.8.1-1 arm64 [installed] liblzo2-2/stable,now 2.10-3+b1 arm64 [installed,automatic] libmagic-mgc/stable,now 1:5.46-5 arm64 [installed,automatic] libmagic1t64/stable,now 1:5.46-5 arm64 [installed,automatic] libmariadb3/stable,now 1:11.8.3-0+deb13u1 arm64 [installed,automatic] libmd0/stable,now 1.1.0-2+b1 arm64 [installed] libmd4c0/stable,now 0.5.2-2+b1 arm64 [installed,automatic] libmnl0/stable,now 1.0.5-3 arm64 [installed,automatic] libmount1/stable,now 2.41-5 arm64 [installed] libmpc3/stable,now 1.3.1-1+b3 arm64 [installed,automatic] libmpfr6/stable,now 4.2.2-1 arm64 [installed,automatic] libmtdev1t64/stable,now 1.1.7-1 arm64 [installed,automatic] libncurses5/now 6.4-4 arm64 [installed,local] libncurses6/stable,now 6.5+20250216-2 arm64 [installed] libncursesw6/stable,now 6.5+20250216-2 arm64 [installed,automatic] libnetplan1/stable,now 1.1.2-7 arm64 [installed,automatic] libnettle8t64/stable,now 3.10.1-1 arm64 [installed,automatic] libnewt0.52/stable,now 0.52.25-1 arm64 [installed,automatic] libnghttp2-14/stable,now 1.64.0-1.1 arm64 [installed,automatic] libnghttp3-9/stable,now 1.8.0-1 arm64 [installed,automatic] libngtcp2-16/stable,now 1.11.0-1 arm64 [installed,automatic] libngtcp2-crypto-gnutls8/stable,now 1.11.0-1 arm64 [installed,automatic] libnl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-genl-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnl-route-3-200/stable,now 3.7.0-2 arm64 [installed,automatic] libnpth0t64/stable,now 1.8-3 arm64 [installed,automatic] libnss-mdns/stable,now 0.15.1-4+b1 arm64 [installed] libonig5/stable,now 6.9.9-1+b1 arm64 [installed,automatic] libopenipmi0t64/stable,now 2.0.37-1 arm64 [installed,automatic] libp11-kit0/stable,now 0.25.5-3 arm64 [installed,automatic] libpam-modules-bin/stable,now 1.7.0-5 arm64 [installed] libpam-modules/stable,now 1.7.0-5 arm64 [installed] libpam-runtime/stable,now 1.7.0-5 all [installed] libpam-systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libpam0g/stable,now 1.7.0-5 arm64 [installed] libpango-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangocairo-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libpangoft2-1.0-0/stable,now 1.56.3-1 arm64 [installed,automatic] libparted2t64/stable,now 3.6-5 arm64 [installed,automatic] libpcap0.8t64/stable,now 1.10.5-2 arm64 [installed,automatic] libpci3/stable,now 1:3.13.0-2 arm64 [installed,automatic] libpcre2-16-0/stable,now 10.46-1~deb13u1 arm64 [installed,automatic] libpcre2-8-0/stable,now 10.46-1~deb13u1 arm64 [installed] libpcsclite1/stable,now 2.3.3-1 arm64 [installed,automatic] libperl5.40/stable,now 5.40.1-6 arm64 [installed,automatic] libpipeline1/stable,now 1.5.8-1 arm64 [installed,automatic] libpixman-1-0/stable,now 0.44.0-3 arm64 [installed,automatic] libpng16-16t64/stable-security,now 1.6.48-1+deb13u1 arm64 [installed,automatic] libpopt0/stable,now 1.19+dfsg-2 arm64 [installed,automatic] libpq5/stable,now 17.6-0+deb13u1 arm64 [installed,automatic] libproc2-0/stable,now 2:4.0.4-9 arm64 [installed,automatic] libprotobuf32t64/stable,now 3.21.12-11 arm64 [installed,automatic] libproxychains4/stable,now 4.17-3 arm64 [installed,automatic] libpsl5t64/stable,now 0.21.2-1.1+b1 arm64 [installed,automatic] libpython3-stdlib/stable,now 3.13.5-1 arm64 [installed,automatic] libpython3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13-stdlib/stable,now 3.13.5-2 arm64 [installed,automatic] libpython3.13/stable,now 3.13.5-2 arm64 [installed,automatic] libqt5core5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5dbus5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5gui5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5network5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libqt5serialport5/stable,now 5.15.15-2 arm64 [installed,automatic] libqt5widgets5t64/stable,now 5.15.15+dfsg-6 arm64 [installed,automatic] libreadline8t64/stable,now 8.2-6 arm64 [installed,automatic] libreiserfscore0t64/stable,now 1:3.6.27-9 arm64 [installed,automatic] librtmp1/stable,now 2.4+20151223.gitfa8646d.1-2+b5 arm64 [installed,automatic] libsamplerate0/stable,now 0.2.2-4+b2 arm64 [installed,automatic] libsasl2-2/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsasl2-modules-db/stable,now 2.1.28+dfsg1-9 arm64 [installed,automatic] libsctp1/stable,now 1.0.21+dfsg-1 arm64 [installed,automatic] libseccomp2/stable,now 2.6.0-2 arm64 [installed,automatic] libselinux1/stable,now 3.8.1-1 arm64 [installed] libsemanage-common/stable,now 3.8.1-1 all [installed,automatic] libsemanage2/stable,now 3.8.1-1 arm64 [installed,automatic] libsensors-config/stable,now 1:3.6.2-2 all [installed,automatic] libsensors5/stable,now 1:3.6.2-2 arm64 [installed,automatic] libsepol2/stable,now 3.8.1-1 arm64 [installed,automatic] libsframe1/stable,now 2.44-3 arm64 [installed,automatic] libsharpyuv0/stable,now 1.5.0-0.1 arm64 [installed,automatic] libslang2/stable,now 2.3.3-5+b2 arm64 [installed,automatic] libsm6/stable,now 2:1.2.6-1 arm64 [installed,automatic] libsmartcols1/stable,now 2.41-5 arm64 [installed] libsqlite3-0/stable,now 3.46.1-7 arm64 [installed] libss2/stable,now 1.47.2-3+b3 arm64 [installed,automatic] libssh2-1t64/stable,now 1.11.1-1 arm64 [installed,automatic] libssl3t64/stable,now 3.5.4-1~deb13u1 arm64 [installed] libstdc++-14-dev/stable,now 14.2.0-19 arm64 [installed,automatic] libstdc++6/stable,now 14.2.0-19 arm64 [installed,automatic] libsystemd-shared/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] libsystemd0/stable,now 257.9-1~deb13u1 arm64 [installed] libtasn1-6/stable,now 4.20.0-2 arm64 [installed,automatic] libtext-charwidth-perl/stable,now 0.04-11+b4 arm64 [installed,automatic] libtext-iconv-perl/stable,now 1.7-8+b4 arm64 [installed,automatic] libtext-wrapi18n-perl/stable,now 0.06-10 all [installed,automatic] libthai-data/stable,now 0.1.29-2 all [installed,automatic] libthai0/stable,now 0.1.29-2+b1 arm64 [installed,automatic] libtiff6/stable,stable-security,now 4.7.0-3+deb13u1 arm64 [installed,automatic] libtinfo5/now 6.4-4 arm64 [installed,local] libtinfo6/stable,now 6.5+20250216-2 arm64 [installed] libtirpc-common/stable,now 1.3.6+ds-1 all [installed,automatic] libtirpc3t64/stable,now 1.3.6+ds-1 arm64 [installed,automatic] libtsan2/stable,now 14.2.0-19 arm64 [installed,automatic] libubsan1/stable,now 14.2.0-19 arm64 [installed,automatic] libuchardet0/stable,now 0.0.8-1+b2 arm64 [installed,automatic] libudev1/stable,now 257.9-1~deb13u1 arm64 [installed] libunistring5/stable,now 1.3-2 arm64 [installed,automatic] libusb-1.0-0/stable,now 2:1.0.28-1 arm64 [installed,automatic] libutempter0/stable,now 1.2.1-4 arm64 [installed,automatic] libuuid1/stable,now 2.41-5 arm64 [installed] libvulkan1/stable,now 1.4.309.0-1 arm64 [installed,automatic] libwacom-common/stable,now 2.14.0-1 all [installed,automatic] libwacom9/stable,now 2.14.0-1 arm64 [installed,automatic] libwayland-client0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-cursor0/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-egl1/stable,now 1.23.1-3 arm64 [installed,automatic] libwayland-server0/stable,now 1.23.1-3 arm64 [installed,automatic] libwebp7/stable,now 1.5.0-0.1 arm64 [installed,automatic] libwrap0/stable,now 7.6.q-36 arm64 [installed,automatic] libwtmpdb0/stable,now 0.73.0-3+deb13u1 arm64 [installed,automatic] libx11-6/stable,now 2:1.8.12-1 arm64 [installed,automatic] libx11-data/stable,now 2:1.8.12-1 all [installed,automatic] libx11-xcb1/stable,now 2:1.8.12-1 arm64 [installed,automatic] libxau6/stable,now 1:1.0.11-1 arm64 [installed,automatic] libxaw7/stable,now 2:1.0.16-1 arm64 [installed,automatic] libxcb-dri3-0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-glx0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-icccm4/stable,now 0.4.2-1 arm64 [installed,automatic] libxcb-image0/stable,now 0.4.0-2+b2 arm64 [installed,automatic] libxcb-keysyms1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-present0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-randr0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-render-util0/stable,now 0.3.10-1 arm64 [installed,automatic] libxcb-render0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shape0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-shm0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-sync1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-util1/stable,now 0.4.1-1 arm64 [installed,automatic] libxcb-xfixes0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinerama0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xinput0/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb-xkb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcb1/stable,now 1.17.0-2+b1 arm64 [installed,automatic] libxcomposite1/stable,now 1:0.4.6-1 arm64 [installed,automatic] libxcursor1/stable,now 1:1.2.3-1 arm64 [installed,automatic] libxdamage1/stable,now 1:1.1.6-1+b2 arm64 [installed,automatic] libxdmcp6/stable,now 1:1.1.5-1 arm64 [installed,automatic] libxext6/stable,now 2:1.3.4-1+b3 arm64 [installed,automatic] libxfixes3/stable,now 1:6.0.0-2+b4 arm64 [installed,automatic] libxft2/stable,now 2.3.6-1+b4 arm64 [installed,automatic] libxi6/stable,now 2:1.8.2-1 arm64 [installed,automatic] libxinerama1/stable,now 2:1.1.4-3+b4 arm64 [installed,automatic] libxkbcommon-x11-0/stable,now 1.7.0-2 arm64 [installed,automatic] libxkbcommon0/stable,now 1.7.0-2 arm64 [installed,automatic] libxml2/stable,now 2.12.7+dfsg+really2.9.14-2.1+deb13u2 arm64 [installed,automa> libxmu6/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxmuu1/stable,now 2:1.1.3-3+b4 arm64 [installed,automatic] libxpm4/stable,now 1:3.5.17-1+b3 arm64 [installed,automatic] libxrandr2/stable,now 2:1.5.4-1+b3 arm64 [installed,automatic] libxrender1/stable,now 1:0.9.12-1 arm64 [installed,automatic] libxshmfence1/stable,now 1.3.3-1 arm64 [installed,automatic] libxt6t64/stable,now 1:1.2.1-1.2+b2 arm64 [installed,automatic] libxtables12/stable,now 1.8.11-2 arm64 [installed,automatic] libxxf86vm1/stable,now 1:1.1.4-1+b4 arm64 [installed,automatic] libxxhash0/stable,now 0.8.3-2 arm64 [installed,automatic] libyaml-0-2/stable,now 0.2.5-2 arm64 [installed,automatic] libz3-4/stable,now 4.13.3-1 arm64 [installed,automatic] libzstd1/stable,now 1.5.7+dfsg-1 arm64 [installed] links/stable,now 2.29-2+b3 arm64 [installed] linux-base/stable,now 4.12 all [installed] linux-dtb-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-image-current-rockchip64/now 25.11.2 arm64 [installed,local] linux-libc-dev/stable,now 6.12.57-1 all [installed,automatic] linux-u-boot-rockpi-s-current/now 25.11.2 arm64 [installed,local] lm-sensors/stable,now 1:3.6.2-2 arm64 [installed] lmbench/stable,now 3.0-a9+debian.1-9 arm64 [installed] locales/stable,now 2.41-12 all [installed] login.defs/stable,now 1:4.17.4-2 all [installed] login/stable,now 1:4.16.0-2+really2.41-5 arm64 [installed] logrotate/stable,now 3.22.0-1+b2 arm64 [installed] logsave/stable,now 1.47.2-3+b3 arm64 [installed,automatic] lsb-release/stable,now 12.1-1 all [installed,automatic] lshw/stable,now 02.19.git.2021.06.19.996aaad9c7-2.1 arm64 [installed] lsof/stable,now 4.99.4+dfsg-2 arm64 [installed] make/stable,now 4.4.1-2 arm64 [installed,automatic] man-db/stable,now 2.13.1-1 arm64 [installed] mariadb-common/stable,now 1:11.8.3-0+deb13u1 all [installed,automatic] mawk/stable,now 1.3.4.20250131-1 arm64 [installed] media-types/stable,now 13.0.0 all [installed,automatic] mesa-libgallium/stable,now 25.0.7-2 arm64 [installed,automatic] minicom/stable,now 2.10-1 arm64 [installed] mmc-utils/stable,now 0+git20240329.f757f413-1+b1 arm64 [installed] mount/stable,now 2.41-5 arm64 [installed] mtd-utils/stable,now 1:2.3.0-1 arm64 [installed] mysql-common/stable,now 5.8+1.1.1 all [installed,automatic] nano/stable,now 8.4-1 arm64 [installed] ncurses-base/stable,now 6.5+20250216-2 all [installed] ncurses-bin/stable,now 6.5+20250216-2 arm64 [installed] ncurses-term/stable,now 6.5+20250216-2 all [installed] netbase/stable,now 6.5 all [installed,automatic] netplan-generator/stable,now 1.1.2-7 arm64 [installed,automatic] netplan.io/stable,now 1.1.2-7 arm64 [installed] openssh-client/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssh-server/stable,now 1:10.0p1-7 arm64 [installed] openssh-sftp-server/stable,now 1:10.0p1-7 arm64 [installed,automatic] openssl-provider-legacy/stable,now 3.5.4-1~deb13u1 arm64 [installed] openssl/stable,now 3.5.4-1~deb13u1 arm64 [installed,automatic] p7zip-full/stable,now 16.02+transitional.1 all [installed] parted/stable,now 3.6-5 arm64 [installed] passwd/stable,now 1:4.17.4-2 arm64 [installed] patch/stable,now 2.8-2 arm64 [installed,automatic] pci.ids/stable,now 0.0~2025.06.09-1 all [installed,automatic] perl-base/stable,now 5.40.1-6 arm64 [installed] perl-modules-5.40/stable,now 5.40.1-6 all [installed,automatic] perl/stable,now 5.40.1-6 arm64 [installed,automatic] picocom/stable,now 3.1-4+b1 arm64 [installed] powertop/stable,now 2.15-4 arm64 [installed] procps/stable,now 2:4.0.4-9 arm64 [installed,automatic] proxychains4/stable,now 4.17-3 arm64 [installed] psmisc/stable,now 23.7-2 arm64 [installed] putty-tools/stable,now 0.83-3 arm64 [installed,automatic] putty/stable,now 0.83-3 arm64 [installed] pv/stable,now 1.9.31-1 arm64 [installed,automatic] python3-cffi-backend/stable,now 1.17.1-3 arm64 [installed,automatic] python3-minimal/stable,now 3.13.5-1 arm64 [installed,automatic] python3-netplan/stable,now 1.1.2-7 arm64 [installed,automatic] python3-psutil/stable,now 7.0.0-2 arm64 [installed,automatic] python3-typing-extensions/stable,now 4.13.2-1 all [installed,automatic] python3-urwid/stable,now 2.6.16-1 arm64 [installed,automatic] python3-wcwidth/stable,now 0.2.13+dfsg1-1 all [installed,automatic] python3-yaml/stable,now 6.0.2-1+b2 arm64 [installed,automatic] python3.13-minimal/stable,now 3.13.5-2 arm64 [installed,automatic] python3.13/stable,now 3.13.5-2 arm64 [installed,automatic] python3/stable,now 3.13.5-1 arm64 [installed,automatic] readline-common/stable,now 8.2-6 all [installed,automatic] rfkill/stable,now 2.41-5 arm64 [installed] rockusb/stable,now 0.2.0-2+b2 arm64 [installed] rpcsvc-proto/stable,now 1.4.3-1+b1 arm64 [installed,automatic] rsync/stable,now 3.4.1+ds1-5 arm64 [installed] rsyslog/stable,now 8.2504.0-1 arm64 [installed] runit-helper/stable,now 2.16.4 all [installed,automatic] s-tui/stable,now 1.1.6-1.2 all [installed] sed/stable,now 4.9-2+b1 arm64 [installed] sensible-utils/stable,now 0.0.25 all [installed,automatic] ser2net/stable,now 4.6.4-1 arm64 [installed] shared-mime-info/stable,now 2.4-5+b2 arm64 [installed,automatic] sqv/stable,now 1.3.0-3 arm64 [installed,automatic] stress/stable,now 1.0.7-1+b1 arm64 [installed] sudo/stable,now 1.9.16p2-3 arm64 [installed] sysbench/stable,now 1.0.20+ds-7+b1 arm64 [installed] sysstat/stable,now 12.7.5-2+b2 arm64 [installed] systemd-resolved/stable,now 257.9-1~deb13u1 arm64 [installed] systemd-sysv/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] systemd-timesyncd/stable,now 257.9-1~deb13u1 arm64 [installed] systemd/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] sysvinit-utils/stable,now 3.14-4 arm64 [installed] tar/stable,now 1.35+dfsg-3.1 arm64 [installed] telnet/stable,now 0.17+2.6-3 all [installed] tio/stable,now 3.9-1 arm64 [installed] toilet-fonts/stable,now 0.3-3 all [installed,automatic] toilet/stable,now 0.3-3 arm64 [installed] tree/stable,now 2.2.1-1 arm64 [installed] tzdata/stable,now 2025b-4+deb13u1 all [installed] u-boot-tools/stable,now 2025.01-3 arm64 [installed] ucf/stable,now 3.0052 all [installed,automatic] udev/stable,now 257.9-1~deb13u1 arm64 [installed,automatic] usbutils/stable,now 1:018-2 arm64 [installed] util-linux/stable,now 2.41-5 arm64 [installed] wavemon/stable,now 0.9.1-1+b1 arm64 [installed] wget/stable,now 1.25.0-2 arm64 [installed] whiptail/stable,now 0.52.25-1 arm64 [installed,automatic] wireguard-tools/stable,now 1.0.20210914-3 arm64 [installed] wireless-regdb/stable,now 2025.07.10-1 all [installed] wpasupplicant/stable,now 2:2.10-24 arm64 [installed] x11-common/stable,now 1:7.7+24+deb13u1 all [installed,automatic] xauth/stable,now 1:1.1.2-1.1 arm64 [installed] xbitmaps/stable,now 1.1.1-2.2 all [installed,automatic] xkb-data/stable,now 2.42-1 all [installed,automatic] xterm/stable,now 398-1 arm64 [installed] xz-utils/stable,now 5.8.1-1 arm64 [installed,automatic] zlib1g/stable,now 1:1.3.dfsg+really1.3.1-1+b1 arm64 [installed] pi@Pi-s:~$ pi@Pi-s:~$ lsmod Module Size Used by 8723ds 1327104 0 hci_uart 135168 0 btqca 20480 1 hci_uart btrtl 28672 1 hci_uart snd_soc_rk3308 65536 1 crct10dif_ce 12288 1 btintel 49152 1 hci_uart snd_soc_rockchip_i2s_tdm 24576 2 snd_soc_simple_card 20480 0 btbcm 20480 1 hci_uart snd_soc_simple_card_utils 24576 1 snd_soc_simple_card bluetooth 671744 6 btrtl,btqca,btintel,hci_uart,btbcm snd_soc_core 204800 4 snd_soc_rockchip_i2s_tdm,snd_soc_rk3308,snd_soc_simple_card_utils,snd_soc_simple_card snd_compress 24576 1 snd_soc_core snd_pcm_dmaengine 12288 1 snd_soc_core snd_pcm 106496 4 snd_compress,snd_soc_simple_card_utils,snd_soc_core,snd_pcm_dmaengine snd_timer 36864 1 snd_pcm snd 77824 4 snd_timer,snd_compress,snd_soc_core,snd_pcm soundcore 12288 1 snd cpufreq_dt 16384 0 cfg80211 815104 1 8723ds rfkill 24576 4 bluetooth,cfg80211 zram 36864 2 842_decompress 16384 1 zram 842_compress 20480 1 zram binfmt_misc 20480 1 usb_f_acm 16384 1 u_serial 28672 1 usb_f_acm g_serial 12288 0 libcomposite 65536 2 g_serial,usb_f_acm nfnetlink 16384 2 ip_tables 28672 0 x_tables 36864 1 ip_tables autofs4 45056 2 realtek 40960 1 dwmac_rk 28672 0 stmmac_platform 20480 1 dwmac_rk stmmac 241664 3 stmmac_platform,dwmac_rk pcs_xpcs 28672 1 stmmac pi@Pi-s:~$ -
I'm trying to start sound. The device is created, but the error is "Write error: -5,Input/output error." The logs show the entry [ 7.411495] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743313] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743325] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743391] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan0 busy [ 20.743400] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan1 busy [ 20.743409] sun6i-dma 7121000.dma-controller: private_candidate: dma1chan2 busy Why is it busy? # speaker-test -Dhw:2 -r48000 -c2 -tsine -f1000 speaker-test 1.2.14 Playback device is hw:2 Stream parameters are 48000Hz, S16_LE, 2 channels Sine wave rate is 1000.0000Hz Rate set to 48000Hz (requested 48000Hz) Buffer size range from 32 to 131072 Period size ra[ 194.914904] sun6i-dma 7121000.dma-controller: vchan 0000000060790fd8: txd 00000000925572c7[2]: submitted [194.914931] dma dma1chan2: vchan 0000000060790fd8: issued [ 194.914968] sun6i-dma 7121000.dma-controller: pchan 0: alloc vchan 0000000060790fd8 [194.914980] dma dma1chan2: [ 194.914980] desc: p - 0x00000000a9840060 v - 0x00000000be392dcf [ 194.914980] c - 0x03820481 s - 0xa9a00000 d - 0x07116020 [ 194.914980] l - 0x0000bb80 p - 0x00000008 n - 0xa9840040 [ 194.914998] sun6i-dma 7121000.dma-controller: Common register: [ 194.914998] mask0(0000): 0x00000002 [ 194.914998] mask1(0004): 0x00000000 [ 194.914998] pend0(0010): 0x00000000 [ 194.914998] pend1(0014): 0x00000000 [ 194.914998] stats(0030): 0x00000001 [194.915015] sun6i-dma 7121000.dma-controller: Chan 0 reg: [ 194.915015] ___en(0000): 0x00000001 [ 194.915015] pause(0004): 0x00000000 [ 194.915015] start(0008): 0xa9840060 [ 194.915015] __cfg(000c): 0x00000000 [ 194.915015] __src(0010): 0x00000000 [ 194.915015] __dst(0014): 0x00000000 [194.915015] count(0018): 0x00000000 [ 194.915015] _para(001c): 0x00000000 [194.915015] nge from 16 to 65536 Periods = 4 was set period_size = 12000 was set buffer_size = 48000 0 - Front Left Write error: -5,Input/output error xrun_recovery failed: -5,Input/output error Transfer failed: Input/output error
I use etckeeper on my ODroid-N2. he sends me changes to my /etc/once a day. And regularly I get this change: armbian-leds.conf | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-) diff --git a/armbian-leds.conf b/armbian-leds.conf index 8108230..537ea6f 100644 --- a/armbian-leds.conf +++ b/armbian-leds.conf @@ -5,5 +5,5 @@ invert=0 [/sys/class/leds/rtw88-1-1.1:1.0] trigger=phy0tpt -brightness=1 +brightness=0 What is this mess? What is it for?
If anyone wants to make an image for the v1.1 board I dumped the bootloader from the v1.1 board which can be found here: https://www.mediafire.com/file/v41ojct50vqnbbp/bootloader-dump.bin/file
update armbian dts ,Give to those in need use sudo armbian-add-overlay ***.dts this dts can avaible rtl8211f on h618 /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h618"; fragment@0 { target = <&mmc1>; __overlay__ { status = "disabled"; }; }; fragment@1 { target = <&emac1>; __overlay__ { status = "disabled"; }; }; fragment@2 { target = <&pio>; __overlay__ { x98h_rgmii_pins: x98h-rgmii-pins { pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15"; function = "emac0"; drive-strength = <40>; }; }; }; /* 3. 配置千兆网卡 */ fragment@3 { target = <&emac0>; __overlay__ { pinctrl-names = "default"; pinctrl-0 = <&x98h_rgmii_pins>; phy-mode = "rgmii"; phy-handle = <&rgmii_phy>; phy-io-supply = <®_aldo1>; allwinner,tx-delay-ps = <700>; allwinner,rx-delay-ps = <3100>; status = "okay"; mdio { rgmii_phy: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; reset-gpios = <&pio 8 16 1>; reset-assert-us = <30000>; reset-deassert-us = <150000>; }; }; }; }; };
https://drive.google.com/drive/folders/1dx0TApPAEjFDz24Rm22J4jgtIbJrYYHC?usp=drive_link build log: url for test...
Problem building from source code
Daniel Andersen replied to Eric Johnson's topic in Software, Applications, Userspace
It is already an old thread, but if someone stumbles over this situation, that compile.sh breaks at update-binfmt errors, check if qemu-user-binfmt is installed on the host linux system. do: sudo apt install qemu-user and you should be fine again. -
Great! Thanks a lot! I will try it to se if Diablo II can run tonight! -
@chris178 I am currently working on a solution. Radxa typically uses rsetup and extlinux.conf to load overlays during boot; however, Armbian uses armbian-config along with boot.cmd and boot.scr. I have decided to use armbian-config to load the overlays instead.
http://blog.armbian.com/content/images/2026/01/githubhighlights-2.webpThis week’s Armbian development saw significant kernel upgrades across multiple platforms, including meson64, rockchip64, and UEFI, with several branches bumped to versions 6.18 and 6.19. Notable hardware support enhancements were introduced, such as SPI controller support for Allwinner A523, new board additions like mixtile-core3588e, and improved compatibility for devices including Radxa and Youyeetoo. The build system received stability and performance improvements, featuring parallel repository generation, refined CI scripts, and fixes for repository management in concurrent environments. Kernel configuration updates enabled additional filesystems and tickless idle for mvebu devices. Several patches addressed hardware initialization, network, and desktop issues, while deprecated packages were removed for a leaner build. Overall, the changelog reflects a strong focus on expanding hardware support, refining build infrastructure, and maintaining kernel currency. add allwinner: a523: Support SPI controllers patch series. by @EvilOlaf in armbian/build#9124allow build on forky host. by @amazingfate in armbian/build#9153CI: add watchdog action script and adjust log cleaning parameter. by @igorpecovnik in armbian/build#9147Fix repository management script for parallel execution. by @igorpecovnik in armbian/build#9163fix: replace comm with grep to support uutils coreutils. by @cantalupo555 in armbian/build#9148kernel configs - enable EROFS as module, ditto overlayfs & F2FS. by @tabrisnet in armbian/build#9135kernel: mvebu: enable tickless idle. by @neheb in armbian/build#9139meson64-6.19: de-bork PCIe, again (missed a patch from 6.18). by @rpardini in armbian/build#9151meson64: bump edge to 6.19; current 6.12 -> 6.18. by @EvilOlaf in armbian/build#9069meson64: bump edge to 6.19; current 6.12 -> 6.18 (nonsquash). by @rpardini in armbian/build#9146Missing variable in board config - address JSON matrix warnings. by @igorpecovnik in armbian/build#9144mixtile-core3588e: add board with vendor and edge branches (Joshua Riek + fixes). by @rpardini in armbian/build#9119Modify radxa-e54c board config to fix leds, network and Gnome desktop init.. by @schwar3kat in armbian/build#9111radxa-cubie-a5e: maint and fixes. by @EvilOlaf in armbian/build#9152Remove libfuse2t64 from package list. by @igorpecovnik in armbian/build#9155Repo tools: add parallel repository generation support. by @igorpecovnik in armbian/build#9150Revert few Rabbit's suggestions that broke repository management. by @igorpecovnik in armbian/build#9156rockchip64-6.18: Enable HDMI1 and audio for HDMI0/1 on CM3588-NAS. by @rpardini in armbian/build#9138rockchip64: add edge kernel support for Youyeetoo YY3588. by @SuperKali in armbian/build#9137rockchip64: fix broken patch in 6.18.3, rewrite everything. by @EvilOlaf in armbian/build#9157uefi-all: bump edge to 6.19 (except loong64); legacy 6.6 -> 6.12; current/cloud 6.12 -> 6.18. by @EvilOlaf in armbian/build#9086uefi-loong64-edge: bump to 6.19. by @amazingfate in armbian/build#9149View the full article
So the workaround is to set cpu freq max to 1 MHz. I still have to use a ghetto cooler 5000 when running a process that maxes out the CPU. Seems Duo running 10C+ at idle with latest kernel and Noble. I can live with that as long as I know. The default is 1.2 MHz max which runs too hot at 1.3V.
Java UIO Java UIO offers robust Java interfaces optimized for Linux Userspace IO, emphasizing high performance. Engineered from scratch, it leverages contemporary kernel APIs, libraries, and cutting-edge code generation methodologies, embodying a state-of-the-art cross-platform solution. Rather than reinventing established paradigms, Java UIO harnesses existing standards, avoiding redundant development commonly observed in other IO libraries. Seamlessly supporting JDK 25 LTS, this framework integrates Project Lombok to streamline code, enhancing readability and conciseness. 🌍 The 32-bit & FFM Reality With Java 25, there is no more support for X86_32, and ARM32 has limited JDKs available. While FFM (Foreign Function & Memory API) is the future, it is not supported on X86_32 or ARM32. For now, JavaUIO moves into the future providing a high-performance path for ARM32, while fully supporting ARM64 and X86_64.
Werner replied to Meestor_X's topic in Allwinner sunxi
I guess the image was built from a pending pull request for testing before merge. Since it has been merged now it should work. Make sure your framework clone is up to date (git pull). -
Oh, I understand. Camera, hardware video decoder and hardware video encoder - they all appear now as /dev/videoX devices, because new hardware videocodec accelerator driver (or standalone video decoder and video encoder drivers) became V4L2 kind of driver. Also thanks for the reference link.
Critique or improve my method to get a lightweight LabWC desktop
Thank you for testing my instructions I was on vacation, and I didn't remember to check this until now Which LCD are you using? Which kernel driver are you using for it? All the questions in your post depend on the LCD model and the driver you used. (I am using panel-mipi-dbi, which I know that it has lost its ability to display X11 graphics since a few months ago) Can you 100% say that you don't have X11? You don't need to use the same kernel version I use. The newer version you have is preferable 🆗 I am glad you can use the Trixie labwc. Personally, I am using Bookworm in the meantime, since its the only way I know to get H264 hardware acceleration. With Trixie's labwc, do you ever get desktop crashes when you log out? -
Current way of installing is as written on the download pages. It was verified with latest v24.11.2 image.
@Ducdanh Nguyen, virtually every adapter will work. I'm using DFRobot multiplexer v.1.0 (FT232R-based): https://wiki.dfrobot.com/Multi_USB_RS232_RS485_TTL_Converter__SKU_TEL0070_
