Hi @KV1 looks like you are hitting this issue: https://github.com/MarvellEmbeddedProcessors/A3700-utils-marvell/issues/35 As you can see, Marvell is not very active in these repos. So you have two choices: 1) use older binutils/gcc (probably the easiest option), or 2) fix the issue with the source code. The fixes I'm seeing look simple enough to implement, and I will likely need to include them in the future when/if I update the github runners used to build releases. See also: https://community.arm.com/support-forums/f/compilers-and-libraries-forum/57077/binutils-2-44-and-gcc-15-1-0---dangerous-relocation-unsupported-relocation-error-when-trying-to-build-u-boot https://lists.denx.de/pipermail/u-boot/2025-May/589102.html
Nick explained above how to create such an image on your own.
@Alex Ling yeah, I have noticed it too. With Mesa (PanVk) recent updates, DX9 games can be played with Dxvk without dgVoodoo2 wrapper. -
Hello, I am trying to connect a ds3231 module to get time during boot (dns does'nt like 1970) and without internet connexion. I load a recent build UBUNTU 26.2.1 on the M5 but unfortunatly after 2 days of research with chatgpt , I ask to knowledge experience people if they know if it's possible and which kind of dts can make this module up and running. I did'nt identify a dtbo on the distribution , a made a lot of investigation , pin 3 and 5 og the 40pins connector is connect to the cpu with pullup resistor , i try a lot dts conf and nothing gave result. If some one did this kind of connexion thanks in advance. Gérard
Just an update. Upgraded to linux-image-current-rockchip64-26.2.0-trunk.655 (6.18.20) not sure whether it included this But unfortunately with the new linux-image-current-rockchip64-26.2.0-trunk.655 kernel still no audio/sound output from the Headphone Jack (Analog).. Edit: Downgraded to or Install linux-image-current-rockchip64-26.2.1 (6.18.10), Headphone Jack has audio/sound output. -
andrey.lobov replied to jock's topic in Rockchip CPU Boxes
@jock Thanks. My box is A95X R2 (rk3318), mainboard A95X R2_V20 (2019‑07‑02). Front panel board A95XCX1_IO_V1.0 (2019‑03‑05). The LED controller on the front panel is TM1628 (photo available). So I should use the tm16xx kernel driver (tm1628), not openvfd. I’ll try rk3318x-config to enable the front panel. If the board isn’t in the list, I can provide front/back photos and dtb. -
That's not an issue. These fixup scripts are only there to allow dt overlays being configurable via parameters rather than having hard-coded pins for example. About the actual issue, no clue. I suggest to try 7.0 kernel from "edge".
On other fora it is nowadays forbidden to post AI content. I would use same here. So you need to google yourself. Or just 'man dpkg'
There were changes merged fairly recently. Perhaps try this: https://github.com/armbian/build/pull/9600
Realvnc problem in Armbian. Black screen
SteeMan replied to Luis Delgado Garcia's topic in Amlogic CPU Boxes
You are not running Armbian. Ophub is a fork of Armbian. They do not contribute to Armbian development nor do they participate in these forums. You need to direct your questions to their support sites. -
@Abdullah Al HaDi Talking about custom roms, I did try to install ATV Xperience rom in it but it unfortunately ended up in a bootloop. But I had great success with Armbian (s90xx builds or idk what it was called). Besides armbian I had success with Manjaro too but I decided to stick with Armbian till the end of its lifetime. Yes the sbc is dead now, RIP...
Alex Ling replied to just_facking_about's topic in Radxa Dragon Q6A
After I added "snd-soc-wcd938x" to /etc/modules-load.d/modules.conf, the sound card can be detected as expected. -
Hi, Werner, thanks for replying. The problem is, when this happened, I cannot get wire or wireless connection. Neither can I login to the system using another pty. Odin2 is a gaming device thus there's no UART available. I tried to pass "console=tty0" to the kernel but I don't see any output on screen when it happened. Any suggestion to get more information? Thanks!
The output still seems truncated. Perhaps leave the device running for a while with the broken kernel (I suggest to build your own kernel package for either "current" or "edge" to rule out that this hasn't been solved in the mean time by something else) to catch multiple of these connection drops. Also add verbosity=8 to your /boot/armbianEnv.txt to catch as much data as possible.
I been testing new install in pendrive, the os boot in rpi4, but no in rpi5
The multitool running from SD card. It behaves like armbian when an armbian image is flashed to the emmc, freezing just like armbian does. Multitool works stable again when booted from the sd after I erase the emmc thru it. Armbian freezes wherever it boots from, with or without clearing the emmc
BTT since at least Buster provides in their vendor image a script to solve issues with the Wifi. And yes it in some conditions may have some issues with the network coming up, I even run in some issues with ethernet. They are solvable by restarting the networkdevice (either ethernet or wifi) with NetworkManager as well as with systemd-networkd. From history. The CB1 Buster vendor image from BTT as well as the vendor image for Bookworm, which actually you still can download at BTTs website contain a scrit that solves the issue by checking the network state all 5 seconds and in case restart the device. I personally used the vendor Buster image and the vendor Bookworm image on the CB1 to operate Openmediavault on it and believe me reliable Network is essential for a NAS. So yes those scripts work. I finally moved to the Armbian general Trixie image, just I was courious, but I took those scripts from bookworm with me. I even copied them to my "vault" of nice to have things for any device that needs reliable network. So I suggest to get yourself A vendor Bookworm image and loop mount it. No need to flash it. (if you are on Windoof, you need to flash it and have a look at the boot partition . At least I don't know a way to mount a partion inside a dd image of a blockdvice stored with sparse option.) Then have a look at the boot partion. There is a folder scripts. Interesing ther: /scripts/btt_init.sh /script/connect_wifi.sh what they do is, they start btt_init.sh in /etc/rc.local, which means always when the system boots at the very end of the boot process and btt init.sh starts a lot of those scripts in background mode, which meens if they have an endless loop, they never die. Only thing u need is connect_wifi.sh from there, so you can hash out all other or directly start connect_wifi.sh like they do.. #!/bin/bash # original BTT code, where the device name is set to a variable in the system.cfg: # cfg_file=/boot/system.cfg #enter the name of the wlandevice to check here: WLAN=wlan0 log_file=/boot/scripts/wifi.log IFS=\" sta_mount=0 wifi_path="/etc/NetworkManager/system-connections/" function connect_wifi() { # whether there is configured wifi in the history if [[ `sudo nmcli c s | grep wifi | awk '{ for(i=NF-2; i<=NF; i++){ $i="" }; print $0 }'` =~ "${WIFI_SSID}" ]] ; then set_wifi_path="${wifi_path}${WIFI_SSID}.nmconnection" if [[ -e ${set_wifi_path} ]]; then psk=`sudo cat ${set_wifi_path} | grep ^psk | awk -F '=' '{print $2}'` if [[ ${psk} == $WIFI_PASSWD ]]; then # both ssid & passwd matched. sys_now_wifi=`sudo nmcli c s --active | grep wlan0 | awk '{ for(i=NF-2; i<=NF; i++){ $i="" }; print $0 }' | awk '{t=length($0)}END{print substr($0, 0, t-3)}'` if [[ ${sys_now_wifi} != $WIFI_SSID ]]; then sudo nmcli c up ${WIFI_SSID} echo " ===> SSID & PSK is same as history, switch to: $WIFI_SSID " >> $log_file fi echo " ===> Now is: $WIFI_SSID, need not to do anything" >> $log_file return 0 else # psk don't match, remove and reconnect. sudo nmcli c delete ${WIFI_SSID} echo " ===> Remove all: $WIFI_SSID " >> $log_file fi else # remove all WIFI_SSID info (Theoretically, never execute to here). sudo nmcli c delete ${WIFI_SSID} echo " ===> Remove all: $WIFI_SSID " >> $log_file fi fi # connect to the new wifi if [[ `sudo nmcli device wifi list` =~ $WIFI_SSID ]] then if [[ ! `sudo nmcli dev wifi connect $WIFI_SSID password $WIFI_PASSWD ifname $wlan` =~ "successfully" ]] then echo " ===> Specify the WPA encryption method: $WIFI_SSID " >> $log_file sudo nmcli c modify $WIFI_SSID wifi-sec.key-mgmt wpa-psk sudo nmcli dev wifi connect $WIFI_SSID password $WIFI_PASSWD ifname $wlan fi else echo " ===> Hide wifi_ssid: $WIFI_SSID " >> $log_file sudo nmcli c add type wifi con-name $WIFI_SSID ifname $wlan ssid $WIFI_SSID sudo nmcli c modify $WIFI_SSID wifi-sec.key-mgmt wpa-psk wifi-sec.psk $WIFI_PASSWD sudo nmcli c up $WIFI_SSID fi } function Env_init() { exec 1> /dev/null # without check_interval set, we risk a 0 sleep = busy loop if [ ! "$check_interval" ]; then echo $(date)" ===> No check interval set!" >> $log_file exit 1 fi # enable wlan [[ $(ifconfig | grep $wlan) == "" ]] && sudo nmcli radio wifi on connect_wifi sleep 6 } function is_network() { if [ $# -eq 0 ]; then get_ip=`ip route | grep "$eth proto kernel" | awk '{print $9}'` if [ -n "${get_ip}" ]; then Result=yes else get_ip=`ip route | grep "$wlan proto kernel" | awk '{print $9}'` fi else get_ip=`ip route | grep "$1 proto kernel" | awk '{print $9}'` fi if [ -n "${get_ip}" ]; then Result=yes else Result=no fi echo $Result } function startWifi_sta() { sta_mount=`expr $sta_mount + 1` echo $(date)" .... sta connecting...$sta_mount..." >> $log_file sleep 2 } function startWifi() { [[ $(ifconfig | grep $wlan) == "" ]] && nmcli radio wifi on # 确保wlan连接启动了 if [[ $sta_mount -le 2 ]]; then nmcli device connect $wlan # 连接wifi echo $(date)" .... $wlan connecting..." >> $log_file sleep 2 [[ $(is_network $wlan) == no ]] && startWifi_sta [[ $(is_network $wlan) == yes ]] && sta_mount=0 && echo $(date)" [O.K.] $wlan connected!" >> $log_file else echo $(date)" xxxx $wlan connection failure..." >> $log_file fi } source $cfg_file grep -e "^WIFI_SSID" ${cfg_file} > /dev/null STATUS=$? if [ ${STATUS} -eq 0 ]; then Env_init sleep 20 while [ 1 ]; do if [[ $(is_network) == no ]]; then # 没有网络连接 echo -e $(date)" ==== No network connection..." >> $log_file startWifi sleep 6 # 更改间隔时间,因为有些服务启动较慢,试验后,改的间隔长一点有用 fi sleep $check_interval done fi This script assumes you are using NetworkManager to manga the wifi.. if you don't one can modify it for systemd-networkd also.. :-)
I did not look well enough and also at a local PDF copy of the wiki which I see is more than 2 years old. Same text is there, but not in red at that time. I think I noticed it at the I was soldering the wire, but I clearly forgot the typing the message i this topic. Anyway, I have no good idea how to solve your remote power issue. I use a MOSFET that has low Vgs on (works directly on 3.3V , but is not for common GND. Else PoE managed switch where I can toggle power when fatal lockup or so. Or else instruct someone to pull the plug, wait 10 seconds, stick it back in again. If you use CoW filesystems, it is no problem to do this.
Thiago Escaliante replied to SteeMan's topic in FAQ
One interesting thing I discovered today is that you can actually boot from a flash drive, if you don't have a SD Card! In my case, I would have to buy a SD Card and had a flash drive laying around so I thought I might just give it a try, worked on an Arm Cortex-A53 CPU. I used u-boot-s905x-912 for .ext and meson-gxl-s905x-p212.dtb. -
Btw. do you know if: 1. Is it possible to use the internal dvb-s tuner in the wetek play 2 with tvheadend? "dmesg | grep -i dvb" showed nothing (an external usb dvb-c wintv solohd was found). 2. Is hardware acellerated "Moonlight Gamestream" possible? In newer/latest Libreelec, the Wetek Play 2 Tuner isnt supported and hardware accelerated x264 is buggy. I think these problems also exist in armbian, or? 🙏
Thanks @bedna Ive now got it working with read write execute on the share via Windows. I searched the Ubuntu forums and foud a couple of posts relating to the issue I was hving with an exfat formatted hard drive. For anyone else searching this forum the answer was to edit the fstab file as follows: To enable read-write access for an exFAT drive in /etc/fstab, add rw,uid=1000,gid=1000,umask=000 to the options field. Using umask=000 ensures all users have read/write access, while setting the uid and gid to your user ID (typically 1000) assigns ownership to your account. Also from Reddit Linux Add this to your /etc/fstab file (replacing the UUID and mount point): UUID=XXXX-XXXX /mnt/exfat exfat defaults,uid=1000,gid=1000,umask=000,nofail 0 0 Key Options Explained rw: Explicitly mounts the drive as read-write. uid=1000,gid=1000: Sets the user and group owner to your user account, preventing root-only lockouts. Use the id command to check your actual UID if needed. umask=000: Sets permissions to 777 (read/write/execute for all), which is usually necessary because exFAT doesn't support native Linux permissions. nofail: Allows the system to boot even if the drive is unplugged. To remove the guest share that appeared all I did was remove the [Global] settings inserted from the Samba wiki i.e. [global] map to guest = Bad User log file = /var/log/samba/%m log level = 1 server role = standalone server [guest] # This share allows anonymous (guest) access # without authentication path = /srv/samba/guest/ read only = no guest ok = yes guest only = yes All working correctly now. I just need to mount the board in a small plastic box and change the IP address to a static one on my daughters subnet.🙂
https://paste.armbian.com/xacimaxamo here's the output from the build from Bigtreetech repo (https://github.com/bigtreetech/build)
status of armbian-configng?
Igor replied to jimg's topic in Framework and userspace feature requests
Did you ran apt update + upgrade + reboot before ? Edit: we might add warning if installed and running kernel version differs. I ran into this problem myself.
