dale replied to Jean-Francois Lessard's topic in Amlogic meson
@Jean-Francois Lessard I'm sorry for the typo. Yes the controller is tm1628. ls /sys/class/leds --> shows empty. Dmesg doesn't show any message for tm16xx. I've attached the working overlay source for openvfd which I have the clock digits working at least with. (The full icons would be card, usb, Low wifi, hi wifi, apps and eth) openvfd_x98h.dts -
eselarm replied to bushw's topic in Advanced users - Development
When I got my ROCK3A around 2024-12-01 I thought it was a good idea to use a newest Linux userspace so I started with Armbian Ubuntu minimal image. Just getting to know the board HW and only SD-card and serial console and RJ45 that was fine, but soon the problems started. I managed to install NetworkManager and disable networkd, so I could copy a rather complex set of NM files from my other SBC, NanoPi-R6C that is using bridges VLANs and libvirt KVM. Same as I did earlier copy that same *.nmconnection files from RaspberryPi4 (PiOS bullseye/bookworm) . And just changing a cloned-mac address entry essentially in 1 .nmconnection file initially so my router assigns the correct IP address (just initial setting), changed that later. Long story short, it turns out that you need netplan.io and that generates .nmconnection files in /etc/NetworkManager/system-connections/, at least that was my conclusion after doing tricks with apt, maybe it is different, I did not want to waste time on it anymore. Same .nmconnection files (same content) are somewhere in /var or so, I forgot where and those seem to be generated from netplan yaml files. I once constructed yaml files to get 64-bit Ubuntu server image running on RPi4 when RPL only had 32-bit ARMv6 raspbian, but already then I thought never again that netplan stuff. I already removed all snapd stuff myself. So after wasting way too much time I just created a clone image on an SD-card from a Btrfs snapshot of my running NanoPi-R6C, copied some U-Boot and kernel and DTB files then done. Could start even VMs on dedicated VLANs etc. That by the way is also an issue with Ubuntu, they keep certain files needed for running KVM different from Bookworm, so VMs did not start, I needed to look at Ubuntu fora to figure out what the issue was. I forgot what as I wiped it all. So my opinion is more or less that Canonical has some vendor lock-ins here and there and/or 'cookies' to keep you stay with them (Ubuntu). Not internet-browser cookies, but goodies, like adding BSD code to Linux (ZFS). As the world of SBCs is almost exclusively about pre-installed images with most people not able to boot an iso CD-ROM and install Linux themselves, it is easy getting into peoples homes. For me, netplan is like hidden malware as I am unable to just install NetworkManager without also getting netplan and then needing to know/learn 3 network config scripting things. Opensuse Tumbleweed also has its own network managing tool (wicked), but at least that can be ignored if you want NetworkManager (dedicated switch in YaST). Same for Debian although manual apt packages and services actions. And then there is nmtui tool that works via serial console, so for me a key feature to configure networking initially in a good interactive way. It is much easier than reading yaml docs or nmcli command options docs. So lesson learned is that I avoid Armbian Ubuntu, also Armbian Bookworm minimal. Only if downloadable Armbian Bookworm images where NM is default I would maybe use, else just clone 1 of my own installations. For own image generation with Armbian build, there is option to use NM, so I noted that somewhere. Pity is that recommended/supported build host environment is Ubuntu. I did most builds on Armbian Bookworm lately, works fine. But last time I started it on Trixie it failed. Will try again sometime soon. - Today
To replace an image on the eMMC, the MASKROM mode is not necessary. It is only required when the firmware is so damaged that it no longer works, but the signature is still intact and the MASKROM code still executes it. To replace an image, it is sufficient to boot from a rootfs that is not on the eMMC and replace it from there. And the good thing about it is that no device-specific hacks are necessary, just a properly configured bootflow. Furthermore, it is also self-contained, as no external devices with special software or other dependencies are necessary. It can also be automated in such a way that it runs unattended and the user only has to start the process initially.
Wait @Nick A when a device is rooted, do i need a root manager??? -
@Nick A i flashed it to my card and it's not booting to armbian... -
Customizing image and customizing kernel are different tasks. For latter use the code { font-family: Consolas,"courier new"; color: crimson; background-color: rgba(0, 0, 0, 0.2); padding: 2px; font-size: 105%; } kernel-config command and then copy over the created config file from output to userpatches. The framework will look for custom kernel configuration files and uses them if they're detected. More details here: https://zuckerbude.org/armbian-using-kernel-config/
Thanks. I'll have to look into that. I expect that's for customizing the packages installed?
Armbian uses Netplan by default to manage network settings. But when it uses NetworkManager as renderer, it silently changes iptables rules—without asking, without telling. *Neither Netplan nor NetworkManager are supposed to manage firewall settings.* But they do it anyway, behind the scenes. That kind of behavior—making security changes without user consent—feels a lot like what malware does.
@Nick A full log (failed): [💲|🌱] Starting main configuration [💲|🌱] Using REVISION from [ main VERSION file: '25.05.0-trunk' ] [💲|🌿] Enabling extension [ armbian-config ] [💲|🌱] Sourcing family configuration [ /home/nguye/build/config/sources/families/sun50iw9.conf ] [💲|🌿] Enabling extension [ sunxi-tools ] [💲|✅] change-tracking: after sourcing family config [ KERNEL_MAJOR_MINOR='6.12' ] [💲|✅] change-tracking: after sourcing family config [ KERNELBRANCH='tag:v6.12.11' ] [💲|✅] change-tracking: after sourcing family config [ LINUXFAMILY='sunxi64' # (was: 'sun50iw9') ] [💲|✅] change-tracking: after sourcing family config [ KERNELPATCHDIR='archive/warpme-6.12' ] [💲|✅] change-tracking: after sourcing family config [ BOOTBRANCH='tag:v2025.01' ] [💲|✅] change-tracking: after sourcing family config [ BOOTPATCHDIR='u-boot-h616' ] [💲|✅] change-tracking: after sourcing family config [ ATFBRANCH='tag:lts-v2.10.14' ] [💲|✅] change-tracking: after sourcing family config [ NETWORKING_STACK='network-manager' ] [💲|🌱] Sourcing arch configuration [ arm64.conf ] [💲|✅] change-tracking: after sourcing arm64 arch [ ATFDIR='arm-trusted-firmware' ] [💲|🌱] Using NETWORKING_STACK [ NETWORKING_STACK: network-manager ] [💲|🌱] Adding networking extensions [ net-network-manager, net-chrony ] [💲|🌿] Enabling extension [ net-network-manager ] [💲|🌿] Enabling extension [ net-chrony ] [💲|🌱] Extension manager [ processed 17 Extension Methods calls and 27 Extension Method implementations ] [💲|🌱] x96q-lpddr3 [ Using allwinner/sun50i-h313-x96-q-lpddr3.dtb for edge ] [💲|💥] Error 1 occurred in SUBSHELL [ SUBSHELL at /home/nguye/build/lib/functions/configuration/config-desktop.sh:48 ] [💲|💥] Cleaning up [ please wait for cleanups to finish ] [💲|🌿] ANSI log file built; inspect it by running: [ less -RS output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans ] [💲|🌱] Share log manually: [ use one of the commands below (or add SHARE_LOG=yes next time!) ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.de/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.next.armbian.com/log ] [💲|🌿] Share log manually: [ curl --data-binary @output/logs/log-build-5e1956f5-4bb3-4cdf-b026-7bcfa7d1794e.log.ans https://paste.armbian.eu/log ] nguye@DESKTOP-IFEAUMD:~/build$ EDIT: it continued while i tried Debian 12 Next i choosed xfce config_base (onlyone) internet -
@Nick A i choosed x96q-lpddr3 (csc) Allwinner H313 TVB with 2gigs of ram and emmc (my box uses emmc) debian 11 image with desktop enviroment -
by the way i don't see any options with allwinner h313 and 1gb ram, can i just choose the 2gb x96q? -
@Nick A Oh.. -
@Ducdanh Nguyen on the other side of the board it has two capacitors. I don’t think that’s it. -
The Tall Man replied to ずっと一人's topic in Orange Pi 5 Plus
Thanks, I am aware of that. But that's an Ubuntu that's using the barebones vendor kernel. I need a fuller kernel than that, and Debian. As it turns out, in looking at recent updates here, it looks like the audio issue has been addressed within the past few days, and that it's an easy fix (as I thought it would be): https://patchwork.kernel.org/project/linux-rockchip/list/ I have yet to try that out, but it looks like I can either wait for the update in the bleeding edge kernel (if it's not already present) or modify the devicetree myself with the fix they discovered. -
That seems to have gone away. ? SNILMERG... Now using very small but 1920x1080 screen, xfce terminal text is about 7 microns tall, way too small for my ancient eyes, Simplified keyboard. ctrl&shift&+ magnify's text but when big enough to read, bottom of xfce4 terminal is offscreen below bottom of screen, so cannot see command line. Is there a keycode combo that expands text independently from terminal window size? Thank you.
dimaxus replied to ずっと一人's topic in Orange Pi 5 Plus
The most interesting thing is that everything works fine for joshua-riek Ubuntu 24.04 with the 6.1 kernel https://joshua-riek.github.io/ubuntu-rockchip-download/boards/orangepi-5-plus.html -
laibsch replied to Stefal's topic in Raspberry Pi
Armbian kernel and BSP Debian/Ubuntu userland -
robertoj replied to Stefal's topic in Raspberry Pi
With the armbian build system, you can build either Bookworm or Trixie You will always get the latest Bookworm or the latest Trixie packages in a freshly built armbian OS. This is what's meant by "always rolling release"... not to be understood as "always sid or Trixie". Independently, the armbian build system will let you choose a stable Linux version, or the latest available from Armbian (edge). -
You are still using an old Linux. You need Linux 6.13 or newer. You need to build your own Armbian OS. Also, don't forget the cma=256M kernel argument -
Stefal replied to Stefal's topic in Raspberry Pi
Ho ! That's a new thing isn't it ? And IMHO, a strange choice. Is there a way to disable that rolling release during the image building process? -
SteeMan replied to Stefal's topic in Raspberry Pi
Stable images can only be built by Armbian. All user built images are essentially rolling releases. But once booted into an image, you can use armbian-config to switch to the stable apt repositories, which means you won't get bug fixes or security updates to the kernel, but instead you get a stable kernel build released once every three months.
