  2. I am Wayland Gnome Ubuntu 22 I executed the command you gave me, but it didn't work sudo gsettings set org.gnome.desktop.session idle-delay 0 (process:36816): dconf-WARNING **: 12:28:47.991: failed to commit changes to dconf: Cannot autolaunch D-Bus without X11 $DISPLAY
  3. @pessimism want are the PINouts of this board? I see you have connected to it with UART. Can you please map RX/TX/GND to GREY/WHITE/BLACK based on you photo. I have tried CP2102 usb adaptor, looks like same case as you had - no transmission on 1.5Mb speed. Meanwhile ordered CH340G.
  5. I don't know where these shortcuts link to, but I assume they both link to the same executable script which is the next generation version. I am not aware that any current Armbian image still ships the old version. So at the bottom-line there is no difference.
  6. The correct way to modify a kernel with patches is to use - ./compile kernel-patch BOARD=... BRANCH=... - review your patches and if you are satisfied move them to patch/ or the equivalent directory under userpatches/ - ./compile.sh kernel BOARD=... BRANCH=...
  7. moved You are using the wrong kernel branch. You need vendor 6.1.y kernel. This is also mentioned in the official documentation of Jellyfin.
  8. my bookworm installation is now over 1 year ago, has there been any further optimization in that time that should be adopted? Which setup combination is currently the most stable? Armbian 23.08.0-trunk Bookworm with Linux 6.6.8-edge-rockchip64 user@helios64:~# uname -a Linux helios64 6.6.8-edge-rockchip64 #1 SMP PREEMPT Wed Dec 20 16:02:07 UTC 2023 aarch64 GNU/Linux I have been successfully connecting my Helios64 to a 2.5G Unifi switch for some time now and recently noticed that it kept interrupting the transfer when transferring files via 1G client. I then deactivated the scatter/gather offloading option, but did not yet adjust the /etc/rc.local as described here...
  9. I did not realize there was a forum for orange pi plus, might be better there? https://forum.armbian.com/forum/250-orange-pi-5-plus/
  10. Yesterday
  11. I recently bought an orange pi plus and am using the armbian 6.12 server (https://dl.armbian.com/orangepi5-plus/Noble_current_server) I'm wanting to setup hardware acceleration for jellyfin but having trouble with the right steps. I'm using jellyfin inside docker on the orange pi inside armbian. I've found various tutorials but it seems like some of them reference things that no longer exist (like panfork seems to no longer be needed for latest mesa if I'm understanding correctly?), so wanting to see what I need to do to set this up. So it seems like I need to disable panthor and use mali instead, but I can't find in the armbian config menu the option to do that, and not sure if I know how to get the right mali. Any help would be greatly appreciated. armbianmonitor is at https://paste.armbian.com/nurazajipu I've seen these tutorials/posts for reference: * https://akashrajpurohit.com/blog/setup-jellyfin-with-hardware-acceleration-on-orange-pi-5-rockchip-rk3558/ * https://github.com/andyshrk/mesa/blob/panthor-v4/Panfrost-build-howto.md * https://forum.jellyfin.org/t-solved-hw-transcoding-rk3588-arch-not-working?pid=54084 * `https://forum.armbian.com/topic/49115-how-to-install-opencl-on-orangepi-5-plus/` * https://forum.jellyfin.org/t-rockchip-transcode-missing-dev-mali0
  12. Hello! If somebody search a resolution how to enable can interface (it`s necessery for 3d printers with can bus circuits) on orange pi distr - you can use attachment kernel conf for build image. You should palce it in `orange-build/external/config/kenrel` (with replace) or `orange-build/kernel` and load on kernel configuration. Other steps is default for building opi image: git clone https://github.com/orangepi-xunlong/orangepi-build mv -f ./linux-5.15-sun55iw3-current.config ./orangepi-build/external/config/kernel cd ./orangepi-build sudo ./build.sh BOARD=orangepi4a BRANCH=current BUILD_OPT=image RELEASE=jammy BUILD_MINIMAL=no BUILD_DESKTOP=no KERNEL_CONFIGURE=n If the OS does not detect the can0 interface - check if any CAN device is connected voron@voron:~$ lsusb Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 004: ID 1b3f:2247 Generalplus Technology Inc. GENERAL WEBCAM -------> Bus 001 Device 003: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter <--------- Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub linux-5.15-sun55iw3-current.config
  13. I don't understand what you are asking for. Can you be more specific?
  14. https://docs.armbian.com/Developer-Guide_Build-Commands If I read your post correctly, I think you want ./compile.sh kernel ... which will build the kernel debs but not the full image
  15. link from armbianmonitor - https://paste.next.armbian.com/kozaluhulo ..and ... can anybody / admin or moderator remove "my files" /old dts/ from posts above please .. ?? ..thanks...
  16. SO, I have working dts / dtb file for this device now.😃 It has working: - TF card / SD card slot - 2x USB ports (1+1) - HDMI - WIFI card - LAN 100Mbit - IR port - LEDs (red and blue) - CPU 4x - RAM 1GB - Serial console TODO: Nand flash - it will be good to have 8GB internal flash available for system AUDIO&CompositeVIDEO - yes, have sound will be good too .. JTAG - maybe ?? RTC - maybe ?? .. but, I'm not sure, if all of them is possible .... for this SOC... It runs on Armbian_25.2.1_Odroidc1_bookworm_current_6.12.13_minimal.img.xz image kernel is 6.12.17-current-meson - not latest one - because newer version have not 8198es module / driver meson8b-smp5000pro.dtb meson8b-smp5000pro.dts
  17. Does anyone know if it's possible to use the docker-shell to patch linux and compile, but NOT make the .img file? Maybe something like ./compile.sh unpack-linux ./compile.sh apply-patches ALL=THE_SETTINGS ./compile.sh build-kernel but not make .img I'm trying to change some network driver settings and want to just copy the new kernel module to my target board instead of flashing the entire SD card.
  18. And here goes aptitude search: orangepiplus:~:% aptitude search '~i !~M' i adduser - add and remove users and groups i adwaita-icon-theme - default icon theme of GNOME i alsa-utils - Utilities for configuring and using ALSA i anacron - cron-like program that doesn't go by time i apport-gtk - GTK+ frontend for the apport crash report i apt - commandline package manager i apt-transport-https - transitional package for https support i apt-utils - package management related utility program i aptitude - terminal-based package manager i armbian-bsp-cli-orangepiplus-cu - Armbian CLI BSP for board 'orangepiplus' b i armbian-config - Armbian config: The Next Generation i armbian-firmware-full - Armbian - Linux firmware-full i armbian-zsh - Armbian improved ZShell (oh-my-zsh...) i automake - Tool for generating GNU Standards-complian i avahi-autoipd - Avahi IPv4LL network address configuration i avahi-daemon - Avahi mDNS/DNS-SD daemon i base-files - Armbian base system miscellaneous files i base-passwd - Debian base system master password and gro i bash - GNU Bourne Again SHell i bash-completion - programmable completion for the bash shell i bc - GNU bc arbitrary precision calculator lang i bison - YACC-compatible parser generator i bleachbit - delete unnecessary files from the system i blueman - Graphical bluetooth manager i bluez - Bluetooth tools and daemons i bluez-cups - Bluetooth printer driver for CUPS i bluez-tools - Set of tools to manage Bluetooth devices f i bridge-utils - Utilities for configuring the Linux Ethern i brltty - Access software for a blind person using a i brltty-x11 - Access software for a blind person using a i bsdutils - basic utilities from 4.4BSD-Lite i btrfs-progs - Checksumming Copy on Write Filesystem util i build-essential - Informational list of build-essential pack i busybox-initramfs - Standalone shell setup for initramfs i bzip2 - high-quality block-sorting file compressor i ca-certificates - Common CA certificates i caffeine - prevent the desktop becoming idle in full- i cifs-utils - Common Internet File System utilities i clang - C, C++ and Objective-C compiler (LLVM base i console-setup - console font and keymap setup program i console-setup-linux - Linux specific part of console-setup i coreutils - GNU core utilities i cpio - GNU cpio -- a program to manage archives o i cpufrequtils - utilities to deal with the cpufreq Linux k i cracklib-runtime - runtime support for password checker libra i cron - process scheduling daemon i cups - Common UNIX Printing System(tm) - PPD/driv i cups-bsd - Common UNIX Printing System(tm) - BSD comm i cups-client - Common UNIX Printing System(tm) - client p i cups-filters - OpenPrinting CUPS Filters - Main Package i curl - command line tool for transferring data wi i dash - POSIX-compliant shell i dbus - simple interprocess messaging system (syst i dbus-x11 - simple interprocess messaging system (X11 i dconf-cli - simple configuration storage system - util i debconf - Debian configuration management system i debconf-utils - debconf utilities i debianutils - Miscellaneous utilities specific to Debian i device-tree-compiler - Device Tree Compiler for Flat Device Trees i dialog - Displays user-friendly dialog boxes from s i dictionaries-common - spelling dictionaries - common utilities i diffutils - File comparison utilities i dirmngr - GNU privacy guard - network certificate ma i dmsetup - Linux Kernel Device Mapper userspace libra i dmz-cursor-theme - Style neutral, scalable cursor theme i doc-base - utilities to manage online documentation i dosfstools - utilities for making and checking MS-DOS F i dpkg - Debian package management system i e2fsprogs - ext2/ext3/ext4 file system utilities i emacs - GNU Emacs editor (metapackage) i emacs-nox - GNU Emacs editor (without GUI support) i ethtool - display or change Ethernet device settings i evince - Document (PostScript, PDF) viewer i evince-common - Document (PostScript, PDF) viewer - common i evtest - utility to monitor Linux input device even i expect - Automates interactive applications i f2fs-tools - Tools for Flash-Friendly File System i f3 - test real flash memory capacity i fake-hwclock - Save/restore system clock on machines with i fbi - Linux frame buffer image viewer i fbset - framebuffer device maintenance program i fdisk - collection of partitioning utilities i figlet - Make large character ASCII banners out of i findutils - utilities for finding files--find, xargs i flex - fast lexical analyzer generator i fontconfig - generic font configuration library - suppo i fontconfig-config - generic font configuration library - confi i fonts-arphic-ukai - "AR PL UKai" Chinese Unicode TrueType font i fonts-arphic-uming - "AR PL UMing" Chinese Unicode TrueType fon i fonts-dejavu-core - Vera font family derivate with additional i fonts-freefont-ttf - Freefont Serif, Sans and Mono Truetype fon i fonts-guru - Meta package to install all Punjabi fonts i fonts-guru-extra - Free fonts for Punjabi language i fonts-kacst - KACST free TrueType Arabic fonts i fonts-kacst-one - TrueType font designed for Arabic language i fonts-khmeros-core - KhmerOS Unicode fonts for the Khmer langua i fonts-liberation - fonts with the same metrics as Times, Aria i fonts-nanum - Nanum Korean fonts i fonts-opensymbol - OpenSymbol TrueType font i fonts-stix - Scientific and Technical Information eXcha i fonts-symbola - symbolic font providing emoji characters f i foomatic-db-compressed-ppds - OpenPrinting printer support - Compressed i fping - sends ICMP ECHO_REQUEST packets to network i gcc-10-base - GCC, the GNU Compiler Collection (base pac i gdebi - simple tool to view and install deb files i geany - fast and lightweight IDE i gimp - GNU Image Manipulation Program i gir1.2-appindicator3-0.1 - Typelib files for libappindicator3-1. i git - fast, scalable, distributed revision contr i gnome-disk-utility - manage and configure disk drives and media i gnome-font-viewer - font viewer for GNOME i gnome-screenshot - screenshot application for GNOME i gnupg - GNU privacy guard - a free PGP replacement i gnupg-l10n - GNU privacy guard - localization files i gnupg-utils - GNU privacy guard - utility programs i gparted - GNOME partition editor i gpg - GNU Privacy Guard -- minimalist public key i gpg-agent - GNU privacy guard - cryptographic agent i gpg-wks-client - GNU privacy guard - Web Key Service client i gpgconf - GNU privacy guard - core configuration uti i gpgsm - GNU privacy guard - S/MIME version i gpgv - GNU privacy guard - signature verification i grep - GNU grep, egrep and fgrep i gstreamer1.0-plugins-base-apps - GStreamer helper programs from the "base" i gstreamer1.0-pulseaudio - GStreamer plugin for PulseAudio (transitio i gtk-update-icon-cache - icon theme caching utility i gtk2-engines - theme engines for GTK+ 2.x i gtk2-engines-murrine - cairo-based gtk+-2.0 theme engine i gtk2-engines-pixbuf - pixbuf-based theme for GTK 2 i gzip - GNU compression utilities i haveged - Linux entropy source using the HAVEGE algo i hdparm - tune hard disk parameters for high perform i hexchat - IRC client for X based on X-Chat 2 i hicolor-icon-theme - default fallback theme for FreeDesktop.org i hostname - utility to set/show the host name or domai i hplip - HP Linux Printing and Imaging System (HPLI i hplip-gui - HP Linux Printing and Imaging - GUI utilit i html2text - advanced HTML to text converter i htop - interactive processes viewer i humanity-icon-theme - Humanity Icon theme i hunspell-en-us - English_american dictionary for hunspell i i2c-tools - heterogeneous set of I2C tools for Linux i ifenslave - configure network interfaces for parallel i ifupdown - high level tools to configure network inte i indicator-printers - indicator showing active print jobs i init - metapackage ensuring an init system is ins i init-system-helpers - helper tools for all init systems i initramfs-tools - generic modular initramfs generator (autom i initramfs-tools-bin - binaries used by initramfs-tools i initramfs-tools-core - generic modular initramfs generator (core i inputattach - utility to connect serial-attached periphe i iotop - simple top-like I/O monitor i iozone3 - Filesystem and Disk Benchmarking Tool i iperf3 - Internet Protocol bandwidth measuring tool i iproute2 - networking and traffic control tools i iptables - administration tools for packet filtering i iputils-arping - Tool to send ICMP echo requests to an ARP i iputils-ping - Tools to test the reachability of network i isc-dhcp-client - DHCP client for automatically obtaining an i iw - tool for configuring Linux wireless device i jq - lightweight and flexible command-line JSON i kbd - Linux console font and keytable utilities i kerneloops - kernel oops tracker i keyboard-configuration - system-wide keyboard preferences i keyutils - Linux Key Management Utilities i klibc-utils - small utilities built with klibc for early i kmod - tools for managing Linux kernel modules i language-pack-gnome-de - GNOME translation updates for language Ger i language-pack-gnome-en - GNOME translation updates for language Eng i language-pack-gnome-es - GNOME translation updates for language Spa i language-pack-gnome-fr - GNOME translation updates for language Fre i language-pack-gnome-it - GNOME translation updates for language Ita i language-pack-gnome-pt - GNOME translation updates for language Por i language-pack-gnome-ru - GNOME translation updates for language Rus i language-pack-gnome-sl - GNOME translation updates for language Slo i laptop-detect - system chassis type checker i less - pager program similar to more i libacl1 - access control list - shared library i libapparmor1 - changehat AppArmor library i libargon2-1 - memory-hard hashing function - runtime lib i libasn1-8-heimdal - Heimdal Kerberos - ASN.1 library i libassuan0 - IPC library for the GnuPG components i libatk-adaptor - AT-SPI 2 toolkit bridge i libatk1.0-data - Common files for the ATK accessibility too i libattr1 - extended attribute handling - shared libra i libaudit-common - Dynamic library for security auditing - co i libaudit1 - Dynamic library for security auditing i libavahi-client3 - Avahi client library i libavahi-common-data - Avahi common data files i libavahi-common3 - Avahi common library i libblkid-dev - block device ID library - headers i libblkid1 - block device ID library i libbsd0 - utility functions from BSD systems - share i libbz2-1.0 - high-quality block-sorting file compressor i libc-bin - GNU C Library: Binaries i libc-dev-bin - GNU C Library: Development binaries i libc6 - GNU C Library: Shared libraries i libc6-dev - GNU C Library: Development Libraries and H i libcairo2 - Cairo 2D vector graphics library i libcap-ng0 - alternate POSIX capabilities library i libcap2 - POSIX 1003.1e capabilities (library) i libcap2-bin - POSIX 1003.1e capabilities (utilities) i libcom-err2 - common error description library i libcrack2 - pro-active password checker library i libcrypt-dev - libcrypt development files i libcrypt1 - libcrypt shared library i libcryptsetup12 - disk encryption support - shared library i libdatrie1 - Double-array trie library i libdbus-1-3 - simple interprocess messaging system (libr i libdconf1 - simple configuration storage system - runt i libdebconfclient0 - Debian Configuration Management System (C- i libdevmapper1.02.1 - Linux Kernel Device Mapper userspace libra i libdigest-sha-perl - Perl extension for SHA-1/224/256/384/512, i libdpkg-perl - Dpkg perl modules i libestr0 - Helper functions for handling strings (lib i libexpat1 - XML parsing C library - runtime library i libfastjson4 - fast json library for C i libfdisk1 - fdisk partitioning library i libffi-dev - Foreign Function Interface library (develo i libffi7 - Foreign Function Interface library runtime i libfont-afm-perl - Perl interface to Adobe Font Metrics files i libfontconfig1 - generic font configuration library - runti i libfontembed1 - OpenPrinting CUPS Filters - Font Embed Sha i libfontenc1 - X11 font encoding library i libfreetype6 - FreeType 2 font engine, shared library fil i libfribidi0 - Free Implementation of the Unicode BiDi al i libgail-common - GNOME Accessibility Implementation Library i libgcc-s1 - GCC support library i libgcrypt20 - LGPL Crypto library - runtime library i libgdk-pixbuf2.0-0 - GDK Pixbuf library (transitional package) i libgdk-pixbuf2.0-common - GDK Pixbuf library - data files i libglib2.0-bin - Programs for the GLib library i libglib2.0-data - Common files for GLib library i libglib2.0-dev - Development files for the GLib library i libglib2.0-dev-bin - Development utilities for the GLib library i libgmp10 - Multiprecision arithmetic library i libgpg-error0 - GnuPG development runtime library i libgraphite2-3 - Font rendering engine for Complex Scripts i libgsettings-qt1 - library to access GSettings from Qt (share i libgssapi-krb5-2 - MIT Kerberos runtime libraries - krb5 GSS- i libgssapi3-heimdal - Heimdal Kerberos - GSSAPI support library i libgtk2.0-bin - programs for the GTK graphical user interf i libgtk2.0-common - common files for the GTK graphical user in i libharfbuzz0b - OpenType text shaping engine (shared libra i libhcrypto4-heimdal - Heimdal Kerberos - crypto library i libheimbase1-heimdal - Heimdal Kerberos - Base library i libheimntlm0-heimdal - Heimdal Kerberos - NTLM support library i libhx509-5-heimdal - Heimdal Kerberos - X509 support library i libidn2-0 - Internationalized domain names (IDNA2008/T i libip4tc2 - netfilter libip4tc library i libjbig0 - JBIGkit libraries i libjpeg-turbo8 - libjpeg-turbo JPEG runtime library i libjpeg8 - Independent JPEG Group's JPEG runtime libr i libk5crypto3 - MIT Kerberos runtime libraries - Crypto Li i libkeyutils1 - Linux Key Management Utilities (library) i libklibc - minimal libc subset for use with initramfs i libkmod2 - libkmod shared library i libkrb5-26-heimdal - Heimdal Kerberos - libraries i libkrb5-3 - MIT Kerberos runtime libraries i libkrb5support0 - MIT Kerberos runtime libraries - Support l i libksba8 - X.509 and CMS support library i libldap-common - OpenLDAP common files for libraries i liblocale-gettext-perl - module using libc functions for internatio i liblz4-1 - Fast LZ compression algorithm library - ru i liblzma5 - XZ-format compression library i libmnl0 - minimalistic Netlink communication library i libmount-dev - device mounting library - headers i libmount1 - device mounting library i libncurses6 - shared libraries for terminal handling i libncursesw6 - shared libraries for terminal handling (wi i libnewt0.52 - Not Erik's Windowing Toolkit - text mode w i libnl-3-200 - library for dealing with netlink sockets i libnl-3-dev - development library and headers for libnl- i libnl-genl-3-200 - library for dealing with netlink sockets - i libnl-genl-3-dev - development library and headers for libnl- i libnotify-bin - sends desktop notifications to a notificat i libnss-myhostname - nss module providing fallback resolution f i libp11-kit0 - library for loading and coordinating acces i libpam-gnome-keyring - PAM module to unlock the GNOME keyring upo i libpam-modules - Pluggable Authentication Modules for PAM i libpam-modules-bin - Pluggable Authentication Modules for PAM - i libpam-runtime - Runtime support for the PAM library i libpam-systemd - system and service manager - PAM module i libpam0g - Pluggable Authentication Modules library i libpango-1.0-0 - Layout and rendering of internationalized i libpangocairo-1.0-0 - Layout and rendering of internationalized i libpangoft2-1.0-0 - Layout and rendering of internationalized i libpcre16-3 - Old Perl 5 Compatible Regular Expression L i libpcre2-16-0 - New Perl Compatible Regular Expression Lib i libpcre2-32-0 - New Perl Compatible Regular Expression Lib i libpcre2-8-0 - New Perl Compatible Regular Expression Lib i libpcre2-dev - New Perl Compatible Regular Expression Lib i libpcre3 - Old Perl 5 Compatible Regular Expression L i libpcre3-dev - Old Perl 5 Compatible Regular Expression L i libpcre32-3 - Old Perl 5 Compatible Regular Expression L i libpcrecpp0v5 - Old Perl 5 Compatible Regular Expression L i libpixman-1-0 - pixel-manipulation library for X and cairo i libpopt0 - lib for parsing cmdline parameters i libproc-processtable-perl - Perl library for accessing process table i i libprocps8 - library for accessing process information i libproxy1-plugin-gsettings - transitional package for libproxy GSetting i libproxy1-plugin-networkmanager - transitional package for libproxy NetworkM i libpython3-stdlib - interactive high-level object-oriented lan i libroken18-heimdal - Heimdal Kerberos - roken support library i librsvg2-2 - SAX-based renderer library for SVG files ( i librsvg2-common - SAX-based renderer library for SVG files ( i libsasl2-2 - Cyrus SASL - authentication abstraction li i libsasl2-modules-db - Cyrus SASL - pluggable authentication modu i libseccomp2 - high level interface to Linux seccomp filt i libselinux1 - SELinux runtime shared libraries i libselinux1-dev - SELinux development headers i libsemanage-common - Common files for SELinux policy management i libslang2 - S-Lang programming library - runtime versi i libsmartcols1 - smart column output alignment library i libsqlite3-0 - SQLite 3 shared library i libss2 - command-line interface parsing library i libssl-dev - Secure Sockets Layer toolkit - development i libstdc++6 - GNU Standard C++ Library v3 i libsystemd0 - systemd utility library i libtasn1-6 - Manage ASN.1 structures (runtime) i libthai-data - Data files for Thai language support libra i libthai0 - Thai language support library i libtiff5 - Tag Image File Format (TIFF) library i libtinfo6 - shared low-level terminfo library for term i libu2f-udev - Universal 2nd Factor (U2F) — transitional i libudev1 - libudev shared library i libunistring2 - Unicode string library for C i libuuid1 - Universally Unique ID library i libuv1 - asynchronous event notification library - i libwind0-heimdal - Heimdal Kerberos - stringprep implementati i libwmf0.2-7-gtk - Windows metafile conversion GTK pixbuf plu i libwrap0-dev - Wietse Venema's TCP wrappers library, deve i libx11-6 - X11 client-side library i libx11-data - X11 client-side library i libxau6 - X11 authorisation library i libxcb-render0 - X C Binding, render extension i libxcb-shm0 - X C Binding, shm extension i libxcb1 - X C Binding i libxcomposite1 - X11 Composite extension library i libxcursor1 - X cursor management library i libxdamage1 - X11 damaged region extension library i libxdmcp6 - X11 Display Manager Control Protocol libra i libxext6 - X11 miscellaneous extension library i libxfixes3 - X11 miscellaneous 'fixes' extension librar i libxi6 - X11 Input extension library i libxinerama1 - X11 Xinerama extension library i libxml2 - GNOME XML library i libxrandr2 - X11 RandR extension library i libxrender1 - X Rendering Extension client library i libxtables12 - netfilter xtables library i libzstd1 - fast lossless compression algorithm i lightdm - Display Manager i lightdm-settings - LightDM Settings Configuration Tool i linux-base - Linux image base package i linux-dtb-current-sunxi - Armbian Linux current DTBs in /boot/dtb-6. i linux-image-current-sunxi - Armbian Linux current kernel image 6.12.20 i linux-libc-dev - Armbian Linux support headers for userspac i linux-u-boot-orangepiplus-curre - Das U-Boot for orangepiplus i lm-sensors - utilities to read temperature/voltage/fan i locales - GNU C Library: National Language (locale) i login - system login tools i logrotate - Log rotation utility i logsave - save the output of a command in a log file i lsb-base - transitional package for Linux Standard Ba i lsof - utility to list open files i lxtask - LXDE task manager i lz4 - Fast LZ compression algorithm library - to i mawk - Pattern scanning and text processing langu i mc - Midnight Commander - a powerful file manag i meld - graphical tool to diff and merge files i mime-support - transitional package i mmc-utils - Userspace tools for MMC/SD devices i mount - tools for mounting and manipulating filesy i mousepad - simple Xfce oriented text editor i mousetweaks - mouse accessibility enhancements for the G i nano - small, friendly text editor inspired by Pi i ncurses-base - basic terminal type definitions i ncurses-bin - terminal-related programs and man pages i ncurses-term - additional terminal type definitions i net-tools - NET-3 networking toolkit i netbase - Basic TCP/IP networking system i netcat-openbsd - TCP/IP swiss army knife i network-manager - network management framework (daemon and u i network-manager-gnome - network management framework (GNOME fronte i network-manager-l2tp - network management framework (L2TP plugin i network-manager-openconnect - network management framework (OpenConnect i network-manager-openvpn - network management framework (OpenVPN plug i network-manager-pptp - network management framework (PPTP plugin i network-manager-ssh - network management framework (SSH plugin c i network-manager-vpnc - network management framework (VPNC plugin i nocache - bypass/minimize file system caching for a i notepadqq - Notepad++-like editor for Linux i ntfs-3g - read/write NTFS driver for FUSE i numix-gtk-theme - Numix GTK Theme i numix-icon-theme - modern icon theme from the Numix project i numix-icon-theme-circle - Circle icon theme from the Numix project i openprinting-ppds - OpenPrinting printer support - PostScript i openssh-server - secure shell (SSH) server, for secure acce i openssl - Secure Sockets Layer toolkit - cryptograph i orca - Scriptable screen reader i p7zip-full - transitional package i pamix - Pulseaudio terminal mixer based in pavucon i parted - disk partition manipulator i passwd - change and administer password and group d i pasystray - PulseAudio controller for the system tray i pavucontrol - PulseAudio Volume Control i pavucontrol-qt - Qt port of volume control pavucontrol i pavumeter - PulseAudio Volume Meter i pciutils - PCI utilities i perl - Larry Wall's Practical Extraction and Repo i perl-base - minimal Perl system i pinentry-curses - curses-based PIN or pass-phrase entry dial i pkg-config - manage compile and link flags for librarie i policykit-1 - transitional package for polkitd and pkexe i policykit-desktop-privileges - run common desktop actions without passwor i printer-driver-all - printer drivers metapackage i printer-driver-gutenprint - printer drivers for CUPS i procps - /proc file system utilities i profile-sync-daemon - Symlink and sync browser profile directori i psmisc - utilities that use the proc file system i pulseaudio-module-bluetooth - Bluetooth module for PulseAudio sound serv i putty - Telnet/SSH client for X i pv - Shell pipeline element to meter data passi i python3 - interactive high-level object-oriented lan i python3-apt - Python 3 interface to libapt-pkg i python3-lib2to3 - Interactive high-level object-oriented lan i python3-minimal - minimal subset of the Python language (def i qrencode - QR Code encoder into PNG image i readline-common - GNU readline and history libraries, common i redshift - Adjusts the color temperature of your scre i regexxer - visual search and replace tool using Perl i remmina - GTK+ Remote Desktop Client i rfkill - tool for enabling and disabling wireless d i rng-tools-debian - daemon to use a Hardware RNG (classic vers i rsync - fast, versatile, remote (and local) file-c i rsyslog - reliable system and kernel logging daemon i samba - SMB/CIFS file, print, and login server for i samba-common-bin - Samba common files used by both the server i screen - terminal multiplexer with VT100/ANSI termi i sed - GNU stream editor for filtering/transformi i sensible-utils - Utilities for sensible alternative selecti i shared-mime-info - FreeDesktop.org shared MIME database and s i simple-scan - Simple Scanning Utility i slick-greeter - Slick-looking LightDM greeter i smartmontools - control and monitor storage systems using i smbclient - command-line SMB/CIFS clients for Unix i spice-vdagent - Spice agent for Linux i stress - tool to impose load on and stress test a c i sudo - Provide limited super user privileges to s i sunxi-tools - tools for working with Allwinner (sunxi) A i sysfsutils - sysfs query tool and boot-time setup i sysstat - system performance tools for Linux i system-config-printer - graphical interface to configure the print i system-config-printer-common - backend and the translation files for syst i systemd - system and service manager i systemd-sysv - system and service manager - SysV compatib i sysvinit-utils - System-V-like utilities i tar - GNU version of the tar archiving utility i terminator - multiple GNOME terminals in one window i thunar-volman - Thunar extension for volumes management i toilet - display large colourful characters in text i transmission-remote-gtk - GTK+ interface for the Transmission BitTor i tzdata - time zone and daylight-saving time data i u-boot-tools - companion tools for Das U-Boot bootloader i ubuntu-drivers-common - Detect and install additional Ubuntu drive i ubuntu-keyring - GnuPG keys of the Ubuntu archive i ubuntu-mono - Ubuntu Mono Icon theme i ucf - Update Configuration File(s): preserve use i udev - /dev/ and hotplug management daemon i unattended-upgrades - automatic installation of security upgrade i unicode-data - Property data for the Unicode character se i unzip - De-archiver for .zip files i update-inetd - inetd configuration file updater i update-manager-core - manage release upgrades i update-notifier-common - Files shared between update-notifier and o i usbutils - Linux USB utilities i util-linux - miscellaneous system utilities i uuid-dev - Universally Unique ID library - headers an i viewnior - simple, fast and elegant image viewer i vim - Vi IMproved - enhanced vi editor i vlan - ifupdown integration for vlan configuratio i wamerican - American English dictionary words for /usr i wbrazilian - Brazilian Portuguese wordlist i wbritish - British English dictionary words for /usr/ i wfrench - French dictionary words for /usr/share/dic i wget - retrieves files from the web i whiptail - Displays user-friendly dialog boxes from s i wireguard-tools - fast, modern, secure kernel VPN tunnel (us i wireless-regdb - wireless regulatory database i wireless-tools - Tools for manipulating Linux Wireless Exte i witalian - Italian dictionary words for /usr/share/di i wpasupplicant - client support for WPA and WPA2 (IEEE 802. i wportuguese - European Portuguese wordlist i wspanish - Spanish dictionary words for /usr/share/di i wswiss - Swiss (German) orthography wordlist i x11-apps - X applications i x11-xserver-utils - X server utilities i x11vnc - VNC server to allow remote access to an ex i xbacklight - simple utility to set the backlight level i xcursor-themes - Base X cursor themes i xdg-user-dirs - tool to manage well known user directories i xdg-user-dirs-gtk - tool to manage well known user directories i xfce4 - Meta-package for the Xfce Lightweight Desk i xfce4-notifyd - simple, visually-appealing notification da i xfce4-screenshooter - screenshots utility for Xfce i xfce4-terminal - Xfce terminal emulator i xfonts-100dpi - 100 dpi fonts for X i xfonts-75dpi - 75 dpi fonts for X i xfonts-base - standard fonts for X i xfonts-encodings - Encodings for X.Org fonts i xfonts-scalable - scalable fonts for X i xfonts-utils - X Window System font utility programs i xinit - X server initialisation tool i xkb-data - X Keyboard Extension (XKB) configuration d i xorg-docs-core - Core documentation for the X.org X Window i xrdp - Remote Desktop Protocol (RDP) server i xscreensaver - Screensaver daemon and frontend for X11 i xserver-xorg-core - Xorg X server - core server i xserver-xorg-input-all - X.Org X server -- input driver metapackage i xterm - X terminal emulator i xtermcontrol - dynamic configuration of xterm properties i xtermset - change the characteristics of an xterm i xwallpaper - utility for setting image files as X wallp i zip - Archiver for .zip files i zlib1g - compression library - runtime i zlib1g-dev - compression library - development orangepiplus:~:% orangepiplus:~:% aptitude search '~i !~M' i adduser - add and remove users and groups i adwaita-icon-theme - default icon theme of GNOME i alsa-utils - Utilities for configuring and using ALSA i anacron - cron-like program that doesn't go by time i apport-gtk - GTK+ frontend for the apport crash report i apt - commandline package manager i apt-transport-https - transitional package for https support i apt-utils - package management related utility program i aptitude - terminal-based package manager i armbian-bsp-cli-orangepiplus-cu - Armbian CLI BSP for board 'orangepiplus' b i armbian-config - Armbian config: The Next Generation i armbian-firmware-full - Armbian - Linux firmware-full i armbian-zsh - Armbian improved ZShell (oh-my-zsh...) i automake - Tool for generating GNU Standards-complian i avahi-autoipd - Avahi IPv4LL network address configuration i avahi-daemon - Avahi mDNS/DNS-SD daemon i base-files - Armbian base system miscellaneous files i base-passwd - Debian base system master password and gro i bash - GNU Bourne Again SHell i bash-completion - programmable completion for the bash shell i bc - GNU bc arbitrary precision calculator lang i bison - YACC-compatible parser generator i bleachbit - delete unnecessary files from the system i blueman - Graphical bluetooth manager i bluez - Bluetooth tools and daemons i bluez-cups - Bluetooth printer driver for CUPS i bluez-tools - Set of tools to manage Bluetooth devices f i bridge-utils - Utilities for configuring the Linux Ethern i brltty - Access software for a blind person using a i brltty-x11 - Access software for a blind person using a i bsdutils - basic utilities from 4.4BSD-Lite i btrfs-progs - Checksumming Copy on Write Filesystem util i build-essential - Informational list of build-essential pack i busybox-initramfs - Standalone shell setup for initramfs i bzip2 - high-quality block-sorting file compressor i ca-certificates - Common CA certificates i caffeine - prevent the desktop becoming idle in full- i cifs-utils - Common Internet File System utilities i clang - C, C++ and Objective-C compiler (LLVM base i console-setup - console font and keymap setup program i console-setup-linux - Linux specific part of console-setup i coreutils - GNU core utilities i cpio - GNU cpio -- a program to manage archives o i cpufrequtils - utilities to deal with the cpufreq Linux k i cracklib-runtime - runtime support for password checker libra i cron - process scheduling daemon i cups - Common UNIX Printing System(tm) - PPD/driv i cups-bsd - Common UNIX Printing System(tm) - BSD comm i cups-client - Common UNIX Printing System(tm) - client p i cups-filters - OpenPrinting CUPS Filters - Main Package i curl - command line tool for transferring data wi i dash - POSIX-compliant shell i dbus - simple interprocess messaging system (syst i dbus-x11 - simple interprocess messaging system (X11 i dconf-cli - simple configuration storage system - util i debconf - Debian configuration management system i debconf-utils - debconf utilities i debianutils - Miscellaneous utilities specific to Debian i device-tree-compiler - Device Tree Compiler for Flat Device Trees i dialog - Displays user-friendly dialog boxes from s i dictionaries-common - spelling dictionaries - common utilities i diffutils - File comparison utilities i dirmngr - GNU privacy guard - network certificate ma i dmsetup - Linux Kernel Device Mapper userspace libra i dmz-cursor-theme - Style neutral, scalable cursor theme i doc-base - utilities to manage online documentation i dosfstools - utilities for making and checking MS-DOS F i dpkg - Debian package management system i e2fsprogs - ext2/ext3/ext4 file system utilities i emacs - GNU Emacs editor (metapackage) i emacs-nox - GNU Emacs editor (without GUI support) i ethtool - display or change Ethernet device settings i evince - Document (PostScript, PDF) viewer i evince-common - Document (PostScript, PDF) viewer - common i evtest - utility to monitor Linux input device even i expect - Automates interactive applications i f2fs-tools - Tools for Flash-Friendly File System i f3 - test real flash memory capacity i fake-hwclock - Save/restore system clock on machines with i fbi - Linux frame buffer image viewer i fbset - framebuffer device maintenance program i fdisk - collection of partitioning utilities i figlet - Make large character ASCII banners out of i findutils - utilities for finding files--find, xargs i flex - fast lexical analyzer generator i fontconfig - generic font configuration library - suppo i fontconfig-config - generic font configuration library - confi i fonts-arphic-ukai - "AR PL UKai" Chinese Unicode TrueType font i fonts-arphic-uming - "AR PL UMing" Chinese Unicode TrueType fon i fonts-dejavu-core - Vera font family derivate with additional i fonts-freefont-ttf - Freefont Serif, Sans and Mono Truetype fon i fonts-guru - Meta package to install all Punjabi fonts i fonts-guru-extra - Free fonts for Punjabi language i fonts-kacst - KACST free TrueType Arabic fonts i fonts-kacst-one - TrueType font designed for Arabic language i fonts-khmeros-core - KhmerOS Unicode fonts for the Khmer langua i fonts-liberation - fonts with the same metrics as Times, Aria i fonts-nanum - Nanum Korean fonts i fonts-opensymbol - OpenSymbol TrueType font i fonts-stix - Scientific and Technical Information eXcha i fonts-symbola - symbolic font providing emoji characters f i foomatic-db-compressed-ppds - OpenPrinting printer support - Compressed i fping - sends ICMP ECHO_REQUEST packets to network i gcc-10-base - GCC, the GNU Compiler Collection (base pac i gdebi - simple tool to view and install deb files i geany - fast and lightweight IDE i gimp - GNU Image Manipulation Program i gir1.2-appindicator3-0.1 - Typelib files for libappindicator3-1. i git - fast, scalable, distributed revision contr i gnome-disk-utility - manage and configure disk drives and media i gnome-font-viewer - font viewer for GNOME i gnome-screenshot - screenshot application for GNOME i gnupg - GNU privacy guard - a free PGP replacement i gnupg-l10n - GNU privacy guard - localization files i gnupg-utils - GNU privacy guard - utility programs i gparted - GNOME partition editor i gpg - GNU Privacy Guard -- minimalist public key i gpg-agent - GNU privacy guard - cryptographic agent i gpg-wks-client - GNU privacy guard - Web Key Service client i gpgconf - GNU privacy guard - core configuration uti i gpgsm - GNU privacy guard - S/MIME version i gpgv - GNU privacy guard - signature verification i grep - GNU grep, egrep and fgrep i gstreamer1.0-plugins-base-apps - GStreamer helper programs from the "base" i gstreamer1.0-pulseaudio - GStreamer plugin for PulseAudio (transitio i gtk-update-icon-cache - icon theme caching utility i gtk2-engines - theme engines for GTK+ 2.x i gtk2-engines-murrine - cairo-based gtk+-2.0 theme engine i gtk2-engines-pixbuf - pixbuf-based theme for GTK 2 i gzip - GNU compression utilities i haveged - Linux entropy source using the HAVEGE algo i hdparm - tune hard disk parameters for high perform i hexchat - IRC client for X based on X-Chat 2 i hicolor-icon-theme - default fallback theme for FreeDesktop.org i hostname - utility to set/show the host name or domai i hplip - HP Linux Printing and Imaging System (HPLI i hplip-gui - HP Linux Printing and Imaging - GUI utilit i html2text - advanced HTML to text converter i htop - interactive processes viewer i humanity-icon-theme - Humanity Icon theme i hunspell-en-us - English_american dictionary for hunspell i i2c-tools - heterogeneous set of I2C tools for Linux i ifenslave - configure network interfaces for parallel i ifupdown - high level tools to configure network inte i indicator-printers - indicator showing active print jobs i init - metapackage ensuring an init system is ins i init-system-helpers - helper tools for all init systems i initramfs-tools - generic modular initramfs generator (autom i initramfs-tools-bin - binaries used by initramfs-tools i initramfs-tools-core - generic modular initramfs generator (core i inputattach - utility to connect serial-attached periphe i iotop - simple top-like I/O monitor i iozone3 - Filesystem and Disk Benchmarking Tool i iperf3 - Internet Protocol bandwidth measuring tool i iproute2 - networking and traffic control tools i iptables - administration tools for packet filtering i iputils-arping - Tool to send ICMP echo requests to an ARP i iputils-ping - Tools to test the reachability of network i isc-dhcp-client - DHCP client for automatically obtaining an i iw - tool for configuring Linux wireless device i jq - lightweight and flexible command-line JSON i kbd - Linux console font and keytable utilities i kerneloops - kernel oops tracker i keyboard-configuration - system-wide keyboard preferences i keyutils - Linux Key Management Utilities i klibc-utils - small utilities built with klibc for early i kmod - tools for managing Linux kernel modules i language-pack-gnome-de - GNOME translation updates for language Ger i language-pack-gnome-en - GNOME translation updates for language Eng i language-pack-gnome-es - GNOME translation updates for language Spa i language-pack-gnome-fr - GNOME translation updates for language Fre i language-pack-gnome-it - GNOME translation updates for language Ita i language-pack-gnome-pt - GNOME translation updates for language Por i language-pack-gnome-ru - GNOME translation updates for language Rus i language-pack-gnome-sl - GNOME translation updates for language Slo i laptop-detect - system chassis type checker i less - pager program similar to more i libacl1 - access control list - shared library i libapparmor1 - changehat AppArmor library i libargon2-1 - memory-hard hashing function - runtime lib i libasn1-8-heimdal - Heimdal Kerberos - ASN.1 library i libassuan0 - IPC library for the GnuPG components i libatk-adaptor - AT-SPI 2 toolkit bridge i libatk1.0-data - Common files for the ATK accessibility too i libattr1 - extended attribute handling - shared libra i libaudit-common - Dynamic library for security auditing - co i libaudit1 - Dynamic library for security auditing i libavahi-client3 - Avahi client library i libavahi-common-data - Avahi common data files i libavahi-common3 - Avahi common library i libblkid-dev - block device ID library - headers i libblkid1 - block device ID library i libbsd0 - utility functions from BSD systems - share i libbz2-1.0 - high-quality block-sorting file compressor i libc-bin - GNU C Library: Binaries i libc-dev-bin - GNU C Library: Development binaries i libc6 - GNU C Library: Shared libraries i libc6-dev - GNU C Library: Development Libraries and H i libcairo2 - Cairo 2D vector graphics library i libcap-ng0 - alternate POSIX capabilities library i libcap2 - POSIX 1003.1e capabilities (library) i libcap2-bin - POSIX 1003.1e capabilities (utilities) i libcom-err2 - common error description library i libcrack2 - pro-active password checker library i libcrypt-dev - libcrypt development files i libcrypt1 - libcrypt shared library i libcryptsetup12 - disk encryption support - shared library i libdatrie1 - Double-array trie library i libdbus-1-3 - simple interprocess messaging system (libr i libdconf1 - simple configuration storage system - runt i libdebconfclient0 - Debian Configuration Management System (C- i libdevmapper1.02.1 - Linux Kernel Device Mapper userspace libra i libdigest-sha-perl - Perl extension for SHA-1/224/256/384/512, i libdpkg-perl - Dpkg perl modules i libestr0 - Helper functions for handling strings (lib i libexpat1 - XML parsing C library - runtime library i libfastjson4 - fast json library for C i libfdisk1 - fdisk partitioning library i libffi-dev - Foreign Function Interface library (develo i libffi7 - Foreign Function Interface library runtime i libfont-afm-perl - Perl interface to Adobe Font Metrics files i libfontconfig1 - generic font configuration library - runti i libfontembed1 - OpenPrinting CUPS Filters - Font Embed Sha i libfontenc1 - X11 font encoding library i libfreetype6 - FreeType 2 font engine, shared library fil i libfribidi0 - Free Implementation of the Unicode BiDi al i libgail-common - GNOME Accessibility Implementation Library i libgcc-s1 - GCC support library i libgcrypt20 - LGPL Crypto library - runtime library i libgdk-pixbuf2.0-0 - GDK Pixbuf library (transitional package) i libgdk-pixbuf2.0-common - GDK Pixbuf library - data files i libglib2.0-bin - Programs for the GLib library i libglib2.0-data - Common files for GLib library i libglib2.0-dev - Development files for the GLib library i libglib2.0-dev-bin - Development utilities for the GLib library i libgmp10 - Multiprecision arithmetic library i libgpg-error0 - GnuPG development runtime library i libgraphite2-3 - Font rendering engine for Complex Scripts i libgsettings-qt1 - library to access GSettings from Qt (share i libgssapi-krb5-2 - MIT Kerberos runtime libraries - krb5 GSS- i libgssapi3-heimdal - Heimdal Kerberos - GSSAPI support library i libgtk2.0-bin - programs for the GTK graphical user interf i libgtk2.0-common - common files for the GTK graphical user in i libharfbuzz0b - OpenType text shaping engine (shared libra i libhcrypto4-heimdal - Heimdal Kerberos - crypto library i libheimbase1-heimdal - Heimdal Kerberos - Base library i libheimntlm0-heimdal - Heimdal Kerberos - NTLM support library i libhx509-5-heimdal - Heimdal Kerberos - X509 support library i libidn2-0 - Internationalized domain names (IDNA2008/T i libip4tc2 - netfilter libip4tc library i libjbig0 - JBIGkit libraries i libjpeg-turbo8 - libjpeg-turbo JPEG runtime library i libjpeg8 - Independent JPEG Group's JPEG runtime libr i libk5crypto3 - MIT Kerberos runtime libraries - Crypto Li i libkeyutils1 - Linux Key Management Utilities (library) i libklibc - minimal libc subset for use with initramfs i libkmod2 - libkmod shared library i libkrb5-26-heimdal - Heimdal Kerberos - libraries i libkrb5-3 - MIT Kerberos runtime libraries i libkrb5support0 - MIT Kerberos runtime libraries - Support l i libksba8 - X.509 and CMS support library i libldap-common - OpenLDAP common files for libraries i liblocale-gettext-perl - module using libc functions for internatio i liblz4-1 - Fast LZ compression algorithm library - ru i liblzma5 - XZ-format compression library i libmnl0 - minimalistic Netlink communication library i libmount-dev - device mounting library - headers i libmount1 - device mounting library i libncurses6 - shared libraries for terminal handling i libncursesw6 - shared libraries for terminal handling (wi i libnewt0.52 - Not Erik's Windowing Toolkit - text mode w i libnl-3-200 - library for dealing with netlink sockets i libnl-3-dev - development library and headers for libnl- i libnl-genl-3-200 - library for dealing with netlink sockets - i libnl-genl-3-dev - development library and headers for libnl- i libnotify-bin - sends desktop notifications to a notificat i libnss-myhostname - nss module providing fallback resolution f i libp11-kit0 - library for loading and coordinating acces i libpam-gnome-keyring - PAM module to unlock the GNOME keyring upo i libpam-modules - Pluggable Authentication Modules for PAM i libpam-modules-bin - Pluggable Authentication Modules for PAM - i libpam-runtime - Runtime support for the PAM library i libpam-systemd - system and service manager - PAM module i libpam0g - Pluggable Authentication Modules library i libpango-1.0-0 - Layout and rendering of internationalized i libpangocairo-1.0-0 - Layout and rendering of internationalized i libpangoft2-1.0-0 - Layout and rendering of internationalized i libpcre16-3 - Old Perl 5 Compatible Regular Expression L i libpcre2-16-0 - New Perl Compatible Regular Expression Lib i libpcre2-32-0 - New Perl Compatible Regular Expression Lib i libpcre2-8-0 - New Perl Compatible Regular Expression Lib i libpcre2-dev - New Perl Compatible Regular Expression Lib i libpcre3 - Old Perl 5 Compatible Regular Expression L i libpcre3-dev - Old Perl 5 Compatible Regular Expression L i libpcre32-3 - Old Perl 5 Compatible Regular Expression L i libpcrecpp0v5 - Old Perl 5 Compatible Regular Expression L i libpixman-1-0 - pixel-manipulation library for X and cairo i libpopt0 - lib for parsing cmdline parameters i libproc-processtable-perl - Perl library for accessing process table i i libprocps8 - library for accessing process information i libproxy1-plugin-gsettings - transitional package for libproxy GSetting i libproxy1-plugin-networkmanager - transitional package for libproxy NetworkM i libpython3-stdlib - interactive high-level object-oriented lan i libroken18-heimdal - Heimdal Kerberos - roken support library i librsvg2-2 - SAX-based renderer library for SVG files ( i librsvg2-common - SAX-based renderer library for SVG files ( i libsasl2-2 - Cyrus SASL - authentication abstraction li i libsasl2-modules-db - Cyrus SASL - pluggable authentication modu i libseccomp2 - high level interface to Linux seccomp filt i libselinux1 - SELinux runtime shared libraries i libselinux1-dev - SELinux development headers i libsemanage-common - Common files for SELinux policy management i libslang2 - S-Lang programming library - runtime versi i libsmartcols1 - smart column output alignment library i libsqlite3-0 - SQLite 3 shared library i libss2 - command-line interface parsing library i libssl-dev - Secure Sockets Layer toolkit - development i libstdc++6 - GNU Standard C++ Library v3 i libsystemd0 - systemd utility library i libtasn1-6 - Manage ASN.1 structures (runtime) i libthai-data - Data files for Thai language support libra i libthai0 - Thai language support library i libtiff5 - Tag Image File Format (TIFF) library i libtinfo6 - shared low-level terminfo library for term i libu2f-udev - Universal 2nd Factor (U2F) — transitional i libudev1 - libudev shared library i libunistring2 - Unicode string library for C i libuuid1 - Universally Unique ID library i libuv1 - asynchronous event notification library - i libwind0-heimdal - Heimdal Kerberos - stringprep implementati i libwmf0.2-7-gtk - Windows metafile conversion GTK pixbuf plu i libwrap0-dev - Wietse Venema's TCP wrappers library, deve i libx11-6 - X11 client-side library i libx11-data - X11 client-side library i libxau6 - X11 authorisation library i libxcb-render0 - X C Binding, render extension i libxcb-shm0 - X C Binding, shm extension i libxcb1 - X C Binding i libxcomposite1 - X11 Composite extension library i libxcursor1 - X cursor management library i libxdamage1 - X11 damaged region extension library i libxdmcp6 - X11 Display Manager Control Protocol libra i libxext6 - X11 miscellaneous extension library i libxfixes3 - X11 miscellaneous 'fixes' extension librar i libxi6 - X11 Input extension library i libxinerama1 - X11 Xinerama extension library i libxml2 - GNOME XML library i libxrandr2 - X11 RandR extension library i libxrender1 - X Rendering Extension client library i libxtables12 - netfilter xtables library i libzstd1 - fast lossless compression algorithm i lightdm - Display Manager i lightdm-settings - LightDM Settings Configuration Tool i linux-base - Linux image base package i linux-dtb-current-sunxi - Armbian Linux current DTBs in /boot/dtb-6. i linux-image-current-sunxi - Armbian Linux current kernel image 6.12.20 i linux-libc-dev - Armbian Linux support headers for userspac i linux-u-boot-orangepiplus-curre - Das U-Boot for orangepiplus i lm-sensors - utilities to read temperature/voltage/fan i locales - GNU C Library: National Language (locale) i login - system login tools i logrotate - Log rotation utility i logsave - save the output of a command in a log file i lsb-base - transitional package for Linux Standard Ba i lsof - utility to list open files i lxtask - LXDE task manager i lz4 - Fast LZ compression algorithm library - to i mawk - Pattern scanning and text processing langu i mc - Midnight Commander - a powerful file manag i meld - graphical tool to diff and merge files i mime-support - transitional package i mmc-utils - Userspace tools for MMC/SD devices i mount - tools for mounting and manipulating filesy i mousepad - simple Xfce oriented text editor i mousetweaks - mouse accessibility enhancements for the G i nano - small, friendly text editor inspired by Pi i ncurses-base - basic terminal type definitions i ncurses-bin - terminal-related programs and man pages i ncurses-term - additional terminal type definitions i net-tools - NET-3 networking toolkit i netbase - Basic TCP/IP networking system i netcat-openbsd - TCP/IP swiss army knife i network-manager - network management framework (daemon and u i network-manager-gnome - network management framework (GNOME fronte i network-manager-l2tp - network management framework (L2TP plugin i network-manager-openconnect - network management framework (OpenConnect i network-manager-openvpn - network management framework (OpenVPN plug i network-manager-pptp - network management framework (PPTP plugin i network-manager-ssh - network management framework (SSH plugin c i network-manager-vpnc - network management framework (VPNC plugin i nocache - bypass/minimize file system caching for a i notepadqq - Notepad++-like editor for Linux i ntfs-3g - read/write NTFS driver for FUSE i numix-gtk-theme - Numix GTK Theme i numix-icon-theme - modern icon theme from the Numix project i numix-icon-theme-circle - Circle icon theme from the Numix project i openprinting-ppds - OpenPrinting printer support - PostScript i openssh-server - secure shell (SSH) server, for secure acce i openssl - Secure Sockets Layer toolkit - cryptograph i orca - Scriptable screen reader i p7zip-full - transitional package i pamix - Pulseaudio terminal mixer based in pavucon i parted - disk partition manipulator i passwd - change and administer password and group d i pasystray - PulseAudio controller for the system tray i pavucontrol - PulseAudio Volume Control i pavucontrol-qt - Qt port of volume control pavucontrol i pavumeter - PulseAudio Volume Meter i pciutils - PCI utilities i perl - Larry Wall's Practical Extraction and Repo i perl-base - minimal Perl system i pinentry-curses - curses-based PIN or pass-phrase entry dial i pkg-config - manage compile and link flags for librarie i policykit-1 - transitional package for polkitd and pkexe i policykit-desktop-privileges - run common desktop actions without passwor i printer-driver-all - printer drivers metapackage i printer-driver-gutenprint - printer drivers for CUPS i procps - /proc file system utilities i profile-sync-daemon - Symlink and sync browser profile directori i psmisc - utilities that use the proc file system i pulseaudio-module-bluetooth - Bluetooth module for PulseAudio sound serv i putty - Telnet/SSH client for X i pv - Shell pipeline element to meter data passi i python3 - interactive high-level object-oriented lan i python3-apt - Python 3 interface to libapt-pkg i python3-lib2to3 - Interactive high-level object-oriented lan i python3-minimal - minimal subset of the Python language (def i qrencode - QR Code encoder into PNG image i readline-common - GNU readline and history libraries, common i redshift - Adjusts the color temperature of your scre i regexxer - visual search and replace tool using Perl i remmina - GTK+ Remote Desktop Client i rfkill - tool for enabling and disabling wireless d i rng-tools-debian - daemon to use a Hardware RNG (classic vers i rsync - fast, versatile, remote (and local) file-c i rsyslog - reliable system and kernel logging daemon i samba - SMB/CIFS file, print, and login server for i samba-common-bin - Samba common files used by both the server i screen - terminal multiplexer with VT100/ANSI termi i sed - GNU stream editor for filtering/transformi i sensible-utils - Utilities for sensible alternative selecti i shared-mime-info - FreeDesktop.org shared MIME database and s i simple-scan - Simple Scanning Utility i slick-greeter - Slick-looking LightDM greeter i smartmontools - control and monitor storage systems using i smbclient - command-line SMB/CIFS clients for Unix i spice-vdagent - Spice agent for Linux i stress - tool to impose load on and stress test a c i sudo - Provide limited super user privileges to s i sunxi-tools - tools for working with Allwinner (sunxi) A i sysfsutils - sysfs query tool and boot-time setup i sysstat - system performance tools for Linux i system-config-printer - graphical interface to configure the print i system-config-printer-common - backend and the translation files for syst i systemd - system and service manager i systemd-sysv - system and service manager - SysV compatib i sysvinit-utils - System-V-like utilities i tar - GNU version of the tar archiving utility i terminator - multiple GNOME terminals in one window i thunar-volman - Thunar extension for volumes management i toilet - display large colourful characters in text i transmission-remote-gtk - GTK+ interface for the Transmission BitTor i tzdata - time zone and daylight-saving time data i u-boot-tools - companion tools for Das U-Boot bootloader i ubuntu-drivers-common - Detect and install additional Ubuntu drive i ubuntu-keyring - GnuPG keys of the Ubuntu archive i ubuntu-mono - Ubuntu Mono Icon theme i ucf - Update Configuration File(s): preserve use i udev - /dev/ and hotplug management daemon i unattended-upgrades - automatic installation of security upgrade i unicode-data - Property data for the Unicode character se i unzip - De-archiver for .zip files i update-inetd - inetd configuration file updater i update-manager-core - manage release upgrades i update-notifier-common - Files shared between update-notifier and o i usbutils - Linux USB utilities i util-linux - miscellaneous system utilities i uuid-dev - Universally Unique ID library - headers an i viewnior - simple, fast and elegant image viewer i vim - Vi IMproved - enhanced vi editor i vlan - ifupdown integration for vlan configuratio i wamerican - American English dictionary words for /usr i wbrazilian - Brazilian Portuguese wordlist i wbritish - British English dictionary words for /usr/ i wfrench - French dictionary words for /usr/share/dic i wget - retrieves files from the web i whiptail - Displays user-friendly dialog boxes from s i wireguard-tools - fast, modern, secure kernel VPN tunnel (us i wireless-regdb - wireless regulatory database i wireless-tools - Tools for manipulating Linux Wireless Exte i witalian - Italian dictionary words for /usr/share/di i wpasupplicant - client support for WPA and WPA2 (IEEE 802. i wportuguese - European Portuguese wordlist i wspanish - Spanish dictionary words for /usr/share/di i wswiss - Swiss (German) orthography wordlist i x11-apps - X applications i x11-xserver-utils - X server utilities i x11vnc - VNC server to allow remote access to an ex i xbacklight - simple utility to set the backlight level i xcursor-themes - Base X cursor themes i xdg-user-dirs - tool to manage well known user directories i xdg-user-dirs-gtk - tool to manage well known user directories i xfce4 - Meta-package for the Xfce Lightweight Desk i xfce4-notifyd - simple, visually-appealing notification da i xfce4-screenshooter - screenshots utility for Xfce i xfce4-terminal - Xfce terminal emulator i xfonts-100dpi - 100 dpi fonts for X i xfonts-75dpi - 75 dpi fonts for X i xfonts-base - standard fonts for X i xfonts-encodings - Encodings for X.Org fonts i xfonts-scalable - scalable fonts for X i xfonts-utils - X Window System font utility programs i xinit - X server initialisation tool i xkb-data - X Keyboard Extension (XKB) configuration d i xorg-docs-core - Core documentation for the X.org X Window i xrdp - Remote Desktop Protocol (RDP) server i xscreensaver - Screensaver daemon and frontend for X11 i xserver-xorg-core - Xorg X server - core server i xserver-xorg-input-all - X.Org X server -- input driver metapackage i xterm - X terminal emulator i xtermcontrol - dynamic configuration of xterm properties i xtermset - change the characteristics of an xterm i xwallpaper - utility for setting image files as X wallp i zip - Archiver for .zip files i zlib1g - compression library - runtime i zlib1g-dev - compression library - development orangepiplus:~:%
  19. For generating torrent files we use: - automatically generated public trackers https://trackerslist.com/#/ lists - web seeds on our servers to secure up to 70 (stable, community builds on around 10) places with 100% file availability Goal for providing torrent download option is maximizing download speed - for you! With torrent protocol, one can not have control where files are and also we don't have own trackers, but we use public ones in automatic way, thus we don't have control on which trackers our files are announced. All files are digitally signed, so nothing to worry about. Edit: if name "pirate" or something else bothers you, here you can submit a fix with some grep -v https://github.com/armbian/os/blob/main/userpatches/gha/chunks/650.per-chunk-images_job.yaml#L139 Perhaps porn and pirate ?
  20. No, thank you for trying to sort this out Yes, it was first installed as focal image; later updated release to jammy. I do run sudo armbian-upgrade which is a fancy way of doing apt update/upgrade. Saves an extra command. At this moment it says "all packages are up to date" using both armbian-upgrade and using classic apt update/upgrade commands. At this moment I am not sure why there are so many manual packages... I have for sure not installed that many lol. Some could have been installed as a dependency, but would this then be shown as installed manually? I have done just that, 19 packages were removed. Not sure why there were so many manually installed packages. Yes, probably the reason was that it was accidentally disconnected (it has a weak physical link to the board when messing around lol). But I will keep an eye on it after primary problem is solved. I did try updating after cleaning the packages. Same problem, attaching as screenshot. During update attempt all went to shite, GUI decided to commit a sudoku, see attached screenshot. Probably I have uninstalled something, I shouldnt. Restarted the system. Fonts are now back but it looks very different Probably this was not manually installed font package. I will share my aptitude output in next message so I don't lose track.
  21. The orange pi zero LTS has analog video under Armbian, because: * the LibreElec project had kernel patches that added the driver code for the same SBC * I carefully modified those patches so they would fit the Armbian version of Linux, correct all compilation errors, and all errors I saw. It was a month long effort If you see that Radxa has video output in the official distribution, do you see any source changes to enable it?
  22. Is anyone using the orange pi zero LTS or 3, with any ilitek LCD, with spi-gpio driver? I had my LTS working with ili9341 and spi-gpio last year... but the touch is not working now... I think I changed the wiring or the DTS in the running system but I can't tell.
  23. So, i should use armbian-config in terminal and armbian-configNG in Gnome.
  24. Hi @datatech451 - glad to hear I am not alone. Yep - I fiddled with SuperCeleron, ATVx and custom launchers a few years back. I have an old pc with LibreElec around here somewhere too. But today I am no longer trying to keep Android going on this one. I moved on to Firesticks since then and the remote control is a big factor on why we stay there. But for the S912 - I am focusing on the mediaserver side and thinking of adding photo backup of my phone. I am just in the tinkering and learning phase. I've had Plex working and have been trialing Jellyfin lately. It works well to stream locally to my firesticks. Big Buck Bunny of course and it seems pretty solid. But I am not doing 4k BBB or anything. But still testing and troubleshooting random issues and craziness. In fact - I put Portainer on board. Jellyfin in a Docker. Homarr in a Docker, Grafana in a Docker, Adguard in a Docker and Cockpit... But lots of things not working exactly right but I think because I overload it. Really trying to push it to the limits just to see and learn. Burning that all down today and doing a fresh build with just what I need - Jellyfin, Cockpit and Adguard. I'm gonna skip Docker this time and I bet I get it all working well enough to learn the next level. As for cooling - I bought some extra heat sinks but never made it further. I am a little worried about pulling the existing sink off - don't want to crack the cpu. Feels more solid than thermal paste - more like thermal glue. But yes - seems to get HOT in a hurry when it is busy. This box has a heat sink plus heat tape and a piece of sheet metal. I am betting that is no longer standard build. BTW - I fiddled with my watt meter and this thing just sips... Seems to idle around 3.6 to 4.1 watts. Did some measurements during 2 hours of streaming, and did some math it seems it would only use about 2.9 kWh per month if on all the time. My spinning HDD uses more than that - could justify that SSD upgrade in the future. I found another box with a S905 (I think) in my recycle bin - I might look at optimizing that for retro gaming. We will see what happens next. Do you have a favorite gaming ROM or experience? Anyway - best of luck and keep the faith!
  25. I assume the armbian-config shortcut is a left-over from the old version of this tool: https://github.com/armbian/config It has been replaced with https://github.com/armbian/configng
  26. In Gnome, there are two shortcuts, armbian-config and armbian-configNG. What's the difference?
  27. You can check this way: type armbian-upgrade armbian-upgrade is /usr/bin/armbian-upgrade cat /usr/bin/armbian-upgrade #!/bin/bash trap "exit" INT TERM [[ $EUID != 0 ]] && exec sudo "$0" "$@" apt update apt -y upgrade apt clean apt -y autoremove exit 0
  28. Does running ambian-upgrade do the exact same thing as running apt update and apt upgrade?
