  2. hi guys, yesterdays announcement of Qualcomm Arduino UNO Q on some Dragonwing SoC ... but heard anybody about it already? how it can be open? some questions ... P.
  3. moved
  4. Not an Armbian image. If you want to use this one, try to get support from where you got the image from.
  5. Yesterday
  6. Hi @Hqnicolas first of all, thanks for all yours and other efforts on this project. I had an eye on it a few months back but only this week did I dig out my two boxes.. A few questions for you if you don't mind answering? I have two boxes, 2GB version I was using for development (Android image) and then full fledged 8GB version. Now, because the boxes were in storage for a year or two I thought I had the 4GB and 8GB version, do you happen to have somewhere the Bootloader image for the 2GB model? I've done a google but can only find the 4 and 8GB version. I was experimenting with Armbian and kinda bloated the image so I'll start from scratch. I went ahead and flashed Armbian on both now without issues, however, I've noticed the Wifi is quite slow on it - around 120-240KB/s download and ping to `1.1.1.1` gives around 30 - 300ms, I've had `top` going at the same time and don't see any high CPU utilization. The Wifi driver is something like `bcmrfm` or alike. Is this normal? I've got my 2GB version hooked up to serial out. I do remember seeing an output in plain English however I can't remember the settings, would you be able to tell me? I've tried the common baud rates with Minicom but no matter what I do I just get a garbled output. The link from previous messages for the SDCard holder is now invalid, could you point me to one that will fit nicely on the board? Finally, from your last post, I see you got the front display displaying data, could you point me in the right direction to code for this? Either C++ or Python will do. I do plan on a monitor for eth, wifi and with time + load + temp possibly. Thanks, Robert.
  7. I use ubunta jammy 1.0.8 for desktop, a 32 GB sd drive, and I was able to achieve a new result: the image was recorded (there were problems with the sd card) and now I just have a red light on all the time, and the operating system does not boot, so the image is not displayed on the monitor, no
  8. Hello, can someone help me with Armbian for this Android box, which seems to have a good configuration for a media center? I would like to know how to flash it and which firmware image I can install on it. Thank you. BBox 4K Specifications: Dimensions: 15x15x3.6cm SoC: Marvell BG4-CT Processor RAM: 2 GB Internal Memory: 16 GB 4K – UHD: Ultra HD, for 4 times better image quality DTS and Dolby sound with S/PDIF and HDMI audio output 128 GB TV recorder, to be completed with the media of your choice Connectivity: SD card reader / 2 USB 2.0 ports Wi-Fi Bluetooth
  9. Which image are you using to boot?
  10. Thanks for compiling that overlay in to a DTB - i've just tried putting that in to /boot/dtb/rockchip/rk3588-nanopc-t6.dtb, rebooted, and it successfully booted and used HS200 mode for the MMC! [ +0.015056] mmc0: SDHCI controller on fe2e0000.emmc [fe2e0000.emmc] using ADMA [ +0.006109] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode. [ +0.000031] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller. [ +0.000008] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a [ +0.000023] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 95,32 bit host data width,256 deep fifo [ +0.000004] mmc0: new HS200 MMC card at address 0001 [ +0.000045] dwmmc_rockchip fe2c0000.mmc: Got CD GPIO [ +0.000236] mmcblk0: mmc0:0001 A3A444 230 GiB [ +0.002488] mmcblk0: p1 [ +0.000267] mmcblk0boot0: mmc0:0001 A3A444 4.00 MiB [ +0.000759] mmcblk0boot1: mmc0:0001 A3A444 4.00 MiB [ +0.000672] mmcblk0rpmb: mmc0:0001 A3A444 4.00 MiB, chardev (243:0) I'm puzzled as to why that worked, but the overlay didn't work. I would have grabbed some logs if I could, but there was no display output so I think the only output would have been on the UART? Unfortunately, I bought the version that comes in a case and the UART is on the top side of the board that I can't access. Searching around, it doesn't look like it is easy to pop it out of the case either. Just in case putting it in to user overlays was wrong, I tried reverting to the original DTB, putting the overlay in /boot/dtb-6.12.44-current-rockchip64/rockchip/overlay/rockchip-rk3588-nanopc-t6-emmc.dtbo, activating it via armbian-config, and rebooting. Unfortunately I hit the same issue as before where it wouldn't boot. Is there a way I can debug why the overlay isn't working without getting access to the UART header on the top of the board?
  11. That's already a topic (with a solution): https://forum.armbian.com/topic/55129-trixie-apt-warning-policy-will-reject-signature-within-a-year/
  12. I just updated my odroid hc2 from bookworm to trixie. Everything went find and the system is running. However, I now get the following message from "apt-get update": W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details W: http://apt.armbian.com/dists/trixie/InRelease: Policy will reject signature within a year, see --audit for details Using the --audit option I get: W: https://github.armbian.com/configng/dists/stable/InRelease: Policy will reject signature within a year, see --audit for details A: https://github.armbian.com/configng/dists/stable/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 is not bound: No binding signature at time 2025-10-06T08:29:30Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. W: http://apt.armbian.com/dists/trixie/InRelease: Policy will reject signature within a year, see --audit for details A: http://apt.armbian.com/dists/trixie/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 is not bound: No binding signature at time 2025-10-07T19:06:52Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. So a key is missing. Where can I get it? And how to install it? Jürgen
  13. Screenshot is in the original post, it still looks the same now.
  14. Please show screenshots of the selection menu step by step when you are trying to install the OS on eMMC. Show me what you see that I cannot see.
  15. The provider's admin console, to be more precise, I'm sorry.
  16. Hello SliTaz community, I would like to know how I could install SliTaz on an Android TV box powered by a Rockchip RK3229 processor. I understand that the standard SliTaz ISO is for x86 architecture, but my device uses ARM. Is there any ARM-compatible version of SliTaz that could run on this hardware? Or is there a way to build a custom ARM rootfs with the SliTaz ARM toolchain and use it with a compatible kernel and bootloader? Any help, guidance, or example would be greatly appreciated! Thanks in advance!
  17. @werner, thanks for the information and the clarification on my concern in the documentation. This sounds like an interesting project, I do believe I'll give it a try. Again, thank you for the encouragement and the pointers.
  18. Admittedly, I had not tested the DTBO at runtime so far, but only applied it statically to the base DTB and checked whether all desired changes were made as intended. Now I am running my device with the applied overlay and I get the following: [ 0.940862] mmc0: new HS200 MMC card at address 0001 [ 0.941665] mmcblk0: mmc0:0001 A3A561 57.6 GiB [ 0.943039] mmcblk0: p1 p2 [ 0.943767] mmcblk0boot0: mmc0:0001 A3A561 4.00 MiB [ 0.945199] mmcblk0boot1: mmc0:0001 A3A561 4.00 MiB [ 0.946661] mmcblk0rpmb: mmc0:0001 A3A561 16.0 MiB, chardev (506:0) So everything is as expected, and yes, I have ensured that my system is running with the applied overlay. In the past, I have at least once noticed far too late that my system was running in a fallback, and a feature to be tested was not applied at all. That's just the disadvantage of a fail-safe system that only leaves a non-functional system in an extreme exceptional situation. Since you haven't provided meaningful logs, I can't say what is going wrong on your end. To rule out an error when applying the overlay, you could start your system with this DTB (rk3588-nanopc-t6.dtb) , which already contains the overlay applied statically.
  19. Thank you. What do you suggest I do? I'm not sure that the "update bootloader" choices are showing the correct devices either.
  20. What exactly have you installed on the SD card (version, image name), and what steps have you used to install?
  21. same problem, and 25.11.0-trunk.129 img dont work
  22. On 99% of the devices I know, eMMC is initialized in the OS as /dev/mmcblk0, but there are cases when this is not the case. # find real mmcblk device numbered 0, 1, 2 for eMMC, SD for ret in $(find /dev -name 'mmcblk[0-2]' -and -type b) do if [ -b ${ret}boot0 ];then emmc_dev=$ret else sd_dev=$ret fi done This part of the code was implemented due to the fact that on some eMCC platforms there can be both /dev/mmsblk0 and /dev/mmcblk1(2) This works for chips that provide boot0\boot1 partitions to write the bootloader. I think we can add more sophisticated logic to handle this exception for these chips. You can add here the name of the chip on your device. The translation may not be accurate. Please specify if something is not clear.
  23. Hi, I have the same TV Box and would like to install Armbian Linux. Could someone tell me which version to install and how?
  24. I have a TV box with 1.5 GB lpddr3 that has been running Manjaro Arm without any problems for a long time. I used this TV box to add lpddr3 support to the dram driver many years ago. You can get the latest patch for 6GBIT lpddr3 support here: https://github.com/iuncuim/manjaro-h616/blob/main/uboot-t98-h2b-lp3/0007-shrink-ram.patch
  25. From the Circuit Schematic it looks like the Radxa Rock 5B+ RK3588 GPIO0-C0 is the fan I/O, GPIO pin 24, if thats correct. I will verify I can access this on the Armbian distro.
