@jamesharton the Armbian images have been refreshed with the new DDR binary. Also thanks for sharing the pic.
I created this account just to thank you, man. Thank you so much, it worked perfectly here. Finally, my old TV box has another use besides collecting dust.
Has anyone managed to get armbian to work on the HK1 Rbox K8s H618?
Gwainer replied to Gwainer's topic in Allwinner CPU Boxes
I wouldn't mind open source but the problem is their prices got bumped up because of the ram and storage shortages. It's why I'm asking if someone has managed to get armbian running on this specific Tv box model or a similar one that has an allwiner H618 chip at the very least. -
Bump to uboot 2026.04 tested with kernel 7.0.5 no mods, just pure mainline Boot Logs: https://paste.armbian.com/ujumalanuc Github Pull request: https://github.com/armbian/build/pull/9804 -
extraargs=nvme_core.default_ps_max_latency_us=0 pcie_aspm=off pcie_port_pm=off to /boot/armbianEnv.txt fixes nvme detection the temperature is echo "$(( $(cat /sys/class/hwmon/hwmon0/temp1_input) / 1000 )) °C" if you copy the system to nvme and wanna boot with microsd (spi doesn't work for now): 1) it will actually boot but without boot mountpoint 2) mount /boot and /media/mmcboot manually 3) fix fstab
Regular changes in file /etc/armbian-leds.conf on ODroid-N2
iav replied to iav's topic in Software, Applications, Userspace
Wrote a PR to remedy the situation https://github.com/armbian/build/pull/9800 -
@humanus I took a second look at the log, I think it's probably due to the enabled eMMC. EDIT: I added the emmc part to my A7Z dts, it also crashes... So that's definitely the root cause. I disable it for A7S in my repo for now, you can compile it yourself with a Linux 6.18 kernel or wait for Nick. By the way A733 eMMC seems to use the same eMMC driver as A523, so probably mainline already supports it.
Wait for a few hours and see if it appears. My other theory, is that I removed the BCMHD DKMS driver and now the wifi is in a wrong state and hassling the CPU.
I have no eMMC and the card isn't UHS-II (I use WD Purple cards, they are UHS-I). I don't think I have any UHS-II cards at the moment... Could try a different one though.
@rm_ On my RV2, there's no such load. Mine waits at the GDM3 login screen (Wayland), it's booted via NVME, no Wifi nor BT configured, and I have a shell via Ethernet. I see a difference in IPI4 dubbed "IRQ work interrupts" which may cause this but I have no clue about the real root cause. There's a patch with comments on that: https://patchew.org/linux/25833c44051f02ea2fd95309652628e2b1607a1e.camel@lenze.com/ , however I have not investigated which of the patches / corrections are in the actual 6.18.26-current-spacemit. I have 53/57° C temp with cat $(find /sys -name temp), I presume yours is higher... interrupts
@humanus Thanks, just noticed the log. Interestingly looks like it's the mmc part. A few things I can think of: 1. emmc is only presented on A7A/S, so if you are using emmc or your board has an emmc, it might be a problem. You can try to disable sdc2 on device tree and see if it works. 1. sd card part is the same on A7A/S/Z, but I don't think my card is a UHS-II card. Looking at the log, it might be doing something with UHS-II, so it might be worth trying a different SD card to see if it behaves differently. If it does turn out to be related to UHS-II handling, I can look into a proper fix later. on.
A guide to installing Armbian on the H96 Max V11
Barrr replied to Maxxim's topic in Rockchip CPU Boxes
ok my findings root@rk3318-box:/boot# cat *Env.txt verbosity=1 bootlogo=true console=both overlay_prefix=rockchip fdtfile=rockchip/rk3318-box.dtb rootdev=UUID=a3e848f3-8d54-412d-9184-5bc40ab76686 rootfstype=ext4 overlays=hdmi-audio rk3318-box-cpu-hs rk3318-box-led-conf1 rk3318-box-wlan-ap6334 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u root@rk3318-box:/boot# sudo ln -s /usr/lib/firmware/brcm/brcmfmac4334-sdio.bin /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.bin ### it was missing according the log sudo rm /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt ### this one did not do the job , you could ofcourse backup ... sudo wget -O /usr/lib/firmware/brcm/brcmfmac4334-sdio.rockchip,rk3318-box.txt https://pastebin.com/raw/00gLSkKS ### the nvram hosted in this topic after the reboot the wifi worked fine for me -
@alexc @qq20739111 I would be very surprised if the UART log showed anything other than mine. You can find it attached above.
Hi @qq20739111, Thanks for testing! It looks like your system may be getting stuck during boot. The SHA256 hash will change every time you rebuild the image. The best way to debug this is by connecting to the UART console, since it should show exactly where the boot process is failing. That said, I’ve also made some updates to the 6.18 kernel, including changes for the A7A and A7S device trees, along with enabling the Ethernet port. Unfortunately I don’t have either an A7A or A7S on hand, so I haven’t been able to test those changes myself. Nick hasn’t updated the Armbian build yet, but you can also try building the kernel yourself and manually replacing the kernel image and DTBs in the /boot directory for testing.
@Nick A I compiled the image for version 6.18.19 using the parameters you preset, but the system fails to boot correctly on the A7S. Upon power-up, the green LED stays solid for about 15 seconds. Then, the green LED flashes once, and the blue LED turns solid (unlike the official system where the blue LED blinks). After that, the system becomes unresponsive. There is no signal output on the DP interface, and the Ethernet port indicator light does not turn on even when a cable is connected. Here is the hash value of the compiled file. I'm not sure if there was an issue with my compilation process, as the network connection dropped several times, and it took a few attempts to finally complete the build. Image: Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a7s_trixie_edge_6.18.19_xfce_desktop.img sha256: a7c6baf463b233bad0abb08d2fcfde7ac107509d69fada77ebaafc2bd00979c5
Immament major changes in rk3588s-orangepi-5* DTS files.
Werner replied to Rocksheep's topic in Advanced users - Development
perhaps the patch is no longer necessary once this lands upstream. We will see once we get there- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
It is not that one. The 2.0 load was just cosmetic, the CPU was actually idle. But with this one it is actually doing something, which is also increasing heat (if no fan). With the expanded core list, you can see the CPU5 and CPU7 have "system" load of 49% and 36%. On a fully idle system. Interrupts file attached. It seems pretty normal to me. interrupts
If i recall correctly this patch is causing problems: patch/kernel/archive/rockchip64-7.0/rk3588-1221-arm64-fix-typec-for-orangepi-5-5b.patch After split the code it wants to patch has will be moved from arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5.dtsi to arch/arm64/boot/dts/rockchip/rk3588s-orangepi-5-5b.dtsi Anyway I'm not sure what this patch meant to fix. Can't find much info on it but it looks like the altmodes block is advertising DP mode over USB-C so enables port to transmit direct video and audio signals. Please someone correct me on this one if I'm wrong. If so it adds future to the system rather then fixing it. I think its better to leave it at default source - host mode.
- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
Why should they?- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
I was just giving heads up. Basically patch is ready with only few "naming disagreements" and reviewers wants to push it upstream soon probably still within 7.1 release candidate. Once it will happen all the builds for orange pi 5/5b/pro and so on will fail so its worth to be prepared.
- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
Hi Werner. I have done so already around half an hour ago.
- 2 replies
- ROCK 5 ITX
- ROCK 5C
- (and 11 more)
feel free to send a pr replacing the current patch for review
- 2 replies
- ROCK 5 ITX
- ROCK 5C
- (and 11 more)
If you want to do the work you can open a pr including these changes into Armbian. However I believe all opi5* boards are in decent state I'd simply wait for upstream . the patchew link is dead btw.- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
Hi. According to this patch Orange pi 5 Pro DTS (which BTW i use for my successful Orange Pi 5 Pro edge build) there will be a split of DTSI files. Most of the code in rk3588s-orangepi-5.dtsi will be transferred to new rk3588s-orangepi-5-5b.dtsi. In my current build for Orange Pi 5 and 5 Pro I have: rk3588s-orangepi-5-5b.dtsi rk3588s-orangepi-5b.dts rk3588s-orangepi-5.dts rk3588s-orangepi-5.dtsi rk3588s-orangepi-5-pro.dts. Please note I have Orange Pi 5 Pro with SPI chip soldered on so for Orange Pi 5 Pro build with EMMC (99.99% of cases) in rk3588s-orangepi-5-pro.dts set: /* SFC */ &sfc { status = "disabled"; }; and &sdhci { status = "okay"; }; rk3588s-orangepi-5-pro.dts rk3588s-orangepi-5b.dts rk3588s-orangepi-5-5b.dtsi rk3588s-orangepi-5.dtsi rk3588s-orangepi-5.dts
- 5 replies
- Orange Pi 5 Pro
- Orange Pi 5
(and 1 more)
Tagged with:
