  2. That is worrying, I wonder if there could potentially be issues with the RAM, which could either be faulty or clocked higher than a level it is stable at. Reffering back to the fex you provide earlier it suggest a dram value of 384, so you may have to the def_config file to include the line CONFIG_DRAM_CLK=384. Is the card just class 10 rated or is it an A1 SD card? https://docs.armbian.com/User-Guide_Getting-Started/ Strange it should auto login on first boot. What it should be request is to set a new root password then confirming that password. Could you please provide a screen shot of the login screen you are greeted with. Alternatively it may be possible to set the root password external to get around this issue. Please see: https://docs.armbian.com/User-Guide_Autoconfig/ Strange never encoutered that before, have you tried pulling the latest version of armbian build to see if it fixes it? Unfortunately I have not had a lot of luck in trying to get WSL2 to work so I have stuck with virtual box. Worth a shot with the pre-built images, but I dont believe the Cubieboard is in a much better state. best of luck Ryzer
  4. 5B+ on vendor (6.1.115) has all I/O related stuff fixed (since 6.1.84) as far as my testing (the one reported in the https://www.armbian.com/rock-5b-plus/ description). Looking into the broken gnome image though and will update here!
  5. Yes, that is the main idea, but sometimes things slipped trough. Images were tested (we aim to have two people on one platinum target to be able to provide better service, but perfection is still not possible), but here we ran into weird problem that CI compilation silently broke on u-boot recompilation, while local build works. We have a problem with build framework / compiler internals, unrelated to this specific hardware and problem only manifest on some u-boot variants. Right now, I don't have a clear picture, but we are working on it. This was introduced while moving framework to Noble, which is mandatory for some targets and there are some Python libraries troubles ... which are sometimes used for u-boot / ATF compile. Its a mess. Software maintenance within such extreme complexity is job that is never done. Generally speaking.
  6. Are platinum supported boards not tested on actual hardware before posting images? FYI we are on of radxas big partners that paid for the platinum membership so there is better support for this board, not sure if all the USB/wifi related driver issues were fixed?
  7. hi , can i use these image to boot armbian to my s805X Amlogic soc.
  8. Yeah, it was reported at GH too: https://github.com/armbian/build/issues/8227 Probably related: https://github.com/armbian/build/issues/8269 No solution yet.
  9. Hi, If you are having trouble sourcing a proper serial dongle, you could also try to set (or cap) the serial console's baudrate yourself in armbianEnv.txt. Use/replace the following: console=comfort extraargs=console=ttyS2,115200 earlyprintk=ttyS2,115200 This should prevent your bootscript from setting the kernel's serial baudrate to 1M5 and at least give you some kernel logging during booting. Not sure if the login prompt will follow the same baudrate, as `getty` (or one of it's variants) might use different default settings. Groetjes,
  10. I see this bug increasingly, and now even a lot of kernel panic and shutdowns, but I was able to get the login screen two or three more times. At the login I faced the same error: using root and 1234 I was told 'login incorrect'. I tried to check whether this is an SD card related issue, and I used h2testw to test my Class 10 SD card, and got no errors there. Then I tried to recompile armbian but repeatedly got this error: https://paste.armbian.eu/daxamubowe So I am unable to build now, but the next thing I am going to try is the Cubieboard pre-built image and see what happens. Thanks, Shivam
  11. the manufacturer hates us, that's it There is no method, they are all hobbyist experiments
  12. @maka into this file: https://github.com/hqnicolas/ubuntu-rockchip-joshua/blob/main/config/suites/noble.sh it makes refference to the kernel repo: https://github.com/hqnicolas/linux-rockchip that contains the dts file: https://github.com/hqnicolas/linux-rockchip/blob/arm64--dts--rockchip--add-rk3566-h96max-v56/arch/arm64/boot/dts/rockchip/rk3566-h96max-v56.dts That have the USB setup: &usb2phy0 { status = "okay"; }; &usb2phy1 { status = "disabled"; }; &usb_host0_ehci { status = "disabled"; }; &usb_host0_ohci { status = "disabled"; }; &usb_host1_ehci { status = "disabled"; }; &usb_host1_ohci { status = "disabled"; }; &usbdrd_dwc3 { dr_mode = "host"; extcon = <&usb2phy0>; status = "okay"; }; &usbdrd30 { status = "okay"; }; &usbhost_dwc3 { status = "okay"; }; &usbhost30 { status = "okay"; }; &pinctrl { usb { vcc5v0_otg_en: vcc5v0-otg-en { rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; }; }; There Are 3 Branches:
  13. Just a brief update to say that I've gotten overwhelmed with other things in my life. I still primarily suspect something is up with the connection to the serial console and that I should experiment there, as @Igor suggested. In three weeks time, I will have several days at my server's location with plenty of time to devote to this. I will try to get my hands on a machine with a USB-A port running something other than macOS.
  14. Does anyone know if this will be solved in new releases or should we use an old kernel 6.6.75 as alternative? Then the next question : can we avoid an update of the kernel when using the apt command upgrade? Already found the solution: Use armbian-config and disable upgrade of firmware
  15. I did not see the bt-gpio service starting on boot. Can you post the status ?
  16. Thank you for the suggestion. Unfortunately, it didn't help. Here is a boot log after your fix: bt_boot_fail_after_fix.txt
  17. klipper@transpeed-8k618-t:~/8821au-20210708$ sudo modprobe 8812au modprobe: ERROR: could not insert '8812au': Unknown symbol in module, or unknown parameter (see dmesg) klipper@transpeed-8k618-t:~/8821au-20210708$ sudo dmesg | grep 8812 [ 7.950162] module 8812au: .gnu.linkonce.this_module section size must match the kernel's built struct module size at run time klipper@transpeed-8k618-t:~/8821au-20210708$ dkms status rtl8812au/5.13.6-23, 6.12.11-edge-sunxi64, aarch64: installed rtl8821au/5.12.5.2, 6.12.11-edge-sunxi64, aarch64: installed I've compile a new image with MT7601U, it works. What should I do for rtl8812 to work?
  18. https://debug.armbian.de
  19. none of these are Armbian images. We do not support 3rd party OS.
  20. FYI latest image for rock 5B+ in downloads section is broken (Armbian_25.5.1_Rock-5b-plus_noble_vendor_6.1.115_gnome_desktop) Wont boot at all, previous 25.2.2 images works fine.
  21. Ok Tks, very hard work with nand. But, ok work for me with sd card. Could you tell me if the Wifi would work?
  22. Yesterday
  23. Can someone share a ready .dtb file with this patch. I am trying to run SPDIF in Tv-Box Vontar X3 with Amlogic S905x3 processor but I can't compile with this patch.
  24. Good morning: I've got a ROCK64 and it does't boot from few days. White; Red and Green led stand with light. nothing change even after minutes. I've tried rock64-debian-mrfixit-190531.img.xz, , freedombox-bookworm_all-arm64.img.xz, debian-12.11.0-arm64-netinst.iso, But never go further. Do you have an idea ? I've got a 5A power so should not be a problem.
  25. i think there is not even useable nand support in the mainline allwinner kernel, so chances are close to zero to get this working currently
  26. Update maintainers and board status synced status from the database rename to .csc where we don't have anyone If you want to become a board maintainer, adjust data here. Ref: Board Maintainers Procedures and Guidelines Contribute View the full article
  27. Description Attempt to work towards one U-Boot bootscript for (at least) mvebu, sunxi and rockchip64. This adds: (Aligned) load address calculations This will remove the need to update any kernel_load_addr_r or ramdisk_addr_r in case kernel image increases. Calculation is based on either Flat kernel image image_size + text_offset as specified in the vmlinux(/Image) header info Compressed kernel image filesize (vmlinuz/zImage) Clear warnings to user in case files are not found, not able to load or application failed. Merge of armbianEnv.txt kernel options was attempted for sunxi, mvebu and rockchip64. DT folder determination based on sunxi approach. DT file determination based on sunxi approach. Compat with /boot/dtb/fdtfile.dtb and /boot/dtb/vendor/fdtfile.dtb. Simplified some constructs by assuming U-Boot has successfully sourced us with a set of pre-set variables, like ${prefix} ${devtype} etc. Actively set the ${kernel_comp_*} parameters based on calculations of load addresses. Ability to select different kernel/initrd by setting kver in armbianEnv.txt Also: Any warning or error includes a 10 second delay to make sure the user is able to see and read them. Any "informative" message added by the bootscript can be silenced by setting verbosity to 0 Attempted to make the bootscript 'reentrant' in away: all variables required for proper (re)execution are set, which should allow for the entire bootscript to be re-run on a next boot_target. All variables used in for-loops are actively cleared from the environment to ensure for loops work as expected. Any pre-set variable that might be used in next boot_target will be reset whenever necessary. Documentation summary for feature / change [ ] short description (copy / paste of PR title) [x] summary (description relevant for end users) Load address calculation can be disabled by adding load_addr_calc=off to armbianEnv.txt Load address calculation OBOE avoidance can be disabled by adding align_overlap_oboe_avoidance=off to armbianEnv.txt User can set custom fdtdir and fdtfile in armbianEnv.txt, but make sure to only specify DT filename in fdtfile. fdtdir will be used to both load DT, DT overlays and fixup scripts [ ] example of usage (how to see this in function) How Has This Been Tested? [x] Orangepi Zero (first gen):[12:39:52] U-Boot SPL 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) [12:39:52] DRAM: 512 MiB [12:39:52] Trying to boot from MMC1 [12:39:53] ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 [12:39:53] U-Boot 2024.01-armbian-2024.01-S866c-P6b16-Ha5c2-V367a-Bb703-R448a (Apr 29 2025 - 02:50:09 +0000) Allwinner Technology [12:39:53] CPU: Allwinner H3 (SUN8I 1680) [12:39:53] Model: Xunlong Orange Pi Zero [12:39:53] DRAM: 512 MiB [12:39:53] Core: 70 devices, 19 uclasses, devicetree: separate [12:39:53] WDT: Not starting watchdog@1c20ca0 [12:39:53] MMC: mmc@1c0f000: 0, mmc@1c10000: 1 [12:39:53] Loading Environment from FAT... Unable to use mmc 0:1... [12:39:53] In: serial,usbkbd [12:39:53] Out: serial [12:39:53] Err: serial [12:39:53] Starting SCP... [12:39:53] Net: SCP/INF: Crust v0.6.10000 [12:39:53] eth0: ethernet@1c30000 [12:39:53] starting USB... [12:39:53] Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus [12:39:53] USB EHCI 1.00 [12:39:53] Bus usb@1c1a400: USB OHCI 1.0 [12:39:53] Bus usb@1c1b000: USB EHCI 1.00 [12:39:53] Bus usb@1c1b400: USB OHCI 1.0 [12:39:53] Bus usb@1c1c000: USB EHCI 1.00 [12:39:53] Bus usb@1c1c400: USB OHCI 1.0 [12:39:53] scanning bus usb@1c1a000 for devices... 1 USB Device(s) found [12:39:54] scanning bus usb@1c1a400 for devices... 1 USB Device(s) found [12:39:55] scanning bus usb@1c1b000 for devices... 1 USB Device(s) found [12:39:56] scanning bus usb@1c1b400 for devices... 1 USB Device(s) found [12:39:57] scanning bus usb@1c1c000 for devices... 1 USB Device(s) found [12:39:59] scanning bus usb@1c1c400 for devices... 1 USB Device(s) found [12:40:00] scanning usb for storage devices... 0 Storage Device(s) found [12:40:00] Autoboot in 1 seconds, press <Space> to stop [12:40:01] switch to partitions #0, OK [12:40:01] mmc0 is current device [12:40:01] Scanning mmc 0:1... [12:40:01] Found U-Boot script /boot/boot.scr [12:40:01] 18117 bytes read in 4 ms (4.3 MiB/s) [12:40:01] ## Executing script at 43100000 [12:40:01] Boot script loaded from mmc 0:1. [12:40:01] 687 bytes read in 3 ms (223.6 KiB/s) [12:40:01] Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. [12:40:01] Found mainline kernel configuration. [12:40:01] 35473 bytes read in 11 ms (3.1 MiB/s) [12:40:01] Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. [12:40:01] Working FDT set to 43000000 [12:40:01] Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). [12:40:01] 504 bytes read in 10 ms (48.8 KiB/s) [12:40:01] Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). [12:40:01] 617 bytes read in 10 ms (59.6 KiB/s) [12:40:01] Applied DT overlay tve (/boot/dtb/overlay/sun8i-h3-tve.dtbo). [12:40:01] 374 bytes read in 9 ms (40 KiB/s) [12:40:01] Applied DT overlay i2c0 (/boot/dtb/overlay/sun8i-h3-i2c0.dtbo). [12:40:01] Loading user provided DT overlay(s) from /boot/overlay-user to 0x45000000 .. [12:40:01] 835 bytes read in 3 ms (271.5 KiB/s) [12:40:01] Applied user DT overlay rtc0-i2c-ds3231-rtc1-soc (/boot/overlay-user/rtc0-i2c-ds3231-rtc1-soc.dtbo). [12:40:01] 4185 bytes read in 10 ms (408.2 KiB/s) [12:40:01] ## Executing script at 45000000 [12:40:01] Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. [12:40:02] 10554192 bytes read in 441 ms (22.8 MiB/s) [12:40:02] Loaded compressed kernel image /boot/zImage to 4300a000. [12:40:02] Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. [12:40:02] 11621101 bytes read in 484 ms (22.9 MiB/s) [12:40:02] Loaded initial ramdisk /boot/uInitrd to 43a1b000. [12:40:02] Unknown command 'kaslrseed' - try 'help' [12:40:02] Not able to prepare for KASLR. [12:40:02] Kernel commandline arguments: [12:40:02] root=/dev/nfs [12:40:02] rootfstype=nfs [12:40:02] rootwait [12:40:02] splash=verbose [12:40:02] earlycon [12:40:02] console=ttyS0,115200 [12:40:02] consoleblank=0 [12:40:02] loglevel=8 [12:40:02] ubootpart=81f6566a-01 [12:40:02] usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u [12:40:02] dwc_otg.fiq_enable=0 [12:40:02] net.ifnames=0 [12:40:02] ipv6.disable=1 [12:40:02] rw [12:40:02] nfsroot=192.168.2.34:/export/rootfs/blippi [12:40:02] ip=dhcp [12:40:02] nfsrootdebug [12:40:02] nfs.enable_ino64=0 [12:40:02] cgroup_enable=cpuset [12:40:02] cgroup_memory=1 [12:40:02] cgroup_enable=memory [12:40:02] Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] [12:40:02] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... [12:40:02] Image Name: uInitrd [12:40:02] Image Type: ARM Linux RAMDisk Image (gzip compressed) [12:40:02] Data Size: 11621037 Bytes = 11.1 MiB [12:40:02] Load Address: 00000000 [12:40:02] Entry Point: 00000000 [12:40:02] Verifying Checksum ... OK [12:40:02] ## Flattened Device Tree blob at 43000000 [12:40:02] Booting using the fdt blob at 0x43000000 [12:40:02] Working FDT set to 43000000 [12:40:02] Loading Ramdisk to 494ea000, end 49fff2ad ... OK [12:40:02] Loading Device Tree to 494de000, end 494e9fff ... OK [12:40:02] Working FDT set to 494de000 [12:40:02] Starting kernel ... [12:40:03] [ 0.000000] Booting Linux on physical CPU 0x0 [x] Orangepi zero (first gen): OKU-Boot SPL 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) DRAM: 256 MiB Trying to boot from MMC1 ns16550_serial serial@1c28000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19 U-Boot 2024.01-armbian (Feb 23 2024 - 10:47:39 +0000) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi Zero DRAM: 256 MiB Core: 70 devices, 19 uclasses, devicetree: separate WDT: Not starting watchdog@1c20ca0 MMC: mmc@1c0f000: 0, mmc@1c10000: 1 Loading Environment from FAT... Unable to use mmc 0:1... In: serial,usbkbd Out: serial Err: serial Starting SCP... Net: SCP/INF: Crust v0.6.10000 eth0: ethernet@1c30000 starting USB... Bus usb@1c1a000: sun4i_usb_phy phy@1c19400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@1c1a400: USB OHCI 1.0 Bus usb@1c1b000: USB EHCI 1.00 Bus usb@1c1b400: USB OHCI 1.0 Bus usb@1c1c000: USB EHCI 1.00 Bus usb@1c1c400: USB OHCI 1.0 scanning bus usb@1c1a000 for devices... 1 USB Device(s) found scanning bus usb@1c1a400 for devices... 1 USB Device(s) found scanning bus usb@1c1b000 for devices... 1 USB Device(s) found scanning bus usb@1c1b400 for devices... 1 USB Device(s) found scanning bus usb@1c1c000 for devices... 1 USB Device(s) found scanning bus usb@1c1c400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 18202 bytes read in 5 ms (3.5 MiB/s) ## Executing script at 43100000 Boot script loaded from mmc 0:1. 265 bytes read in 4 ms (64.5 KiB/s) Loaded/imported environment /boot/armbianEnv.txt to/from 0x45000000. Found mainline kernel configuration. 35473 bytes read in 9 ms (3.8 MiB/s) Loaded DT /boot/dtb/sun8i-h2-plus-orangepi-zero.dtb to 0x43000000. Working FDT set to 43000000 Loading kernel provided DT overlay(s) from /boot/dtb/overlay to 0x45000000 .. 504 bytes read in 11 ms (43.9 KiB/s) Applied DT overlay usbhost2 (/boot/dtb/overlay/sun8i-h3-usbhost2.dtbo). 504 bytes read in 12 ms (41 KiB/s) Applied DT overlay usbhost3 (/boot/dtb/overlay/sun8i-h3-usbhost3.dtbo). 4185 bytes read in 11 ms (371.1 KiB/s) ## Executing script at 45000000 Loaded/sourced fixup script /boot/dtb/overlay/sun8i-h3-fixup.scr to/at 0x45000000. 10554192 bytes read in 442 ms (22.8 MiB/s) Loaded compressed kernel image /boot/zImage to 4300a000. Using compressed kernel image filesize 0xa10b50 bytes to calculate initial ramdisk load address. 11867098 bytes read in 497 ms (22.8 MiB/s) Loaded initial ramdisk /boot/uInitrd to 43a1b000. Unknown command 'kaslrseed' - try 'help' Not able to prepare for KASLR. Kernel commandline arguments: root=PARTUUID=1c01f668-02 rootfstype=f2fs rootwait splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=8 ubootpart=1c01f668-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u,0x174c:0x55aa:u net.ifnames=0 ipv6.disable=1 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory Kernel image @ 0x4300a000 [ 0x000000 - 0xa10b50 ] ## Loading init Ramdisk from Legacy Image at 43a1b000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 11867034 Bytes = 11.3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Working FDT set to 43000000 Loading Ramdisk to 494ae000, end 49fff39a ... OK Loading Device Tree to 494a2000, end 494adfff ... OK Working FDT set to 494a2000 Starting kernel ... Checklist: [ ] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [ ] My changes generate no new warnings New warnings introduced: Environment load failed Environment import failed DT load/application failed DT (user) overlay load/application failed Initial ramdisk load failed Kernel image load failed Boot failed [x] Any dependent changes have been merged and published in downstream modules Prequisite U-Boot setexpr command already merged via https://github.com/armbian/build/pull/8260. View the full article
  28. I understand, but would I be able to do it officially?
