Self-build minimal image for RockPI-S too big
dg4gg8cb9s replied to dg4gg8cb9s's topic in Radxa Rock Pi S
Thank you all, I appreciate your patience! 🙏 I'm not sure on how deep I should go here. I started to learn about the process to address the problem that 10mpbs ethernet not is not working on my Rockpi S and I now know enough to deal with this problem. So my feeling is to not go further but focus on the functional problem to solve it 😉 Thanks again! -
@SteeMani also did some commands prompted by chatgpt since it said it was manufactored by allwinner also related to cortex-a53, aida64 said it too, so i doubt that mine are using a allwinner h313 chip -
@Nick Aalright, ill do it - Today
What are we running as routers / firewalls these days?
Lara Woodward replied to blood's topic in Off-topic
Interesting to see so many setups, from x86 VMs on RPi4 to NanoPi and Proxmox-based systems. I’ve been following similar discussions on the Armbian Forum and it’s great to compare real-world experiences. Curious what others think about newer options like the NanoPi-R6S or SolidRun boards with more modern connectivity. You can checkout this website for property related discussion or more information. -
Context of the TV boxes section might be helpful, especially in the sticky thread re their status in Armbian.
Hi! @jwalds did yo mange to make hw decoding work with cedrus? (Note: you initially wrote cedar_ve, that's a different driver) I'm fighting with a nanopi duo2. If it works at your end I'd like to know your setup kernel version armbianEnv.txt whatelse has been installed, how could you please provide your dts / dto ? T.
Hi,any plans of porting Armbian to Ugoos AM9 s905x5 soc?
schunckt replied to schunckt's topic in Allwinner sunxi
Hi again! Quick update after i wrote that below. I found something very promising here https://codesandbox.io/p/github/NathanJohnNJ/BananaPi-Camcorder/master This is a different approach. Behind the scenes the cedar_ve driver gets used which also supports encoding accel. I think I'll give it a try but that may take some time ... (btw. this is where some confusion exists, at several places - there are two drivers: cedrus aka. sunxi-cedrus and cedar_ve) -------------------------------------------------------------------------------- Im not using X11, i am using direct frambebuffer. But i'm quite sure the output is not the root cause as output to null also doesnt work So for testing there is no need for SPI LCD ffmpeg -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - @robertoj Maybe you can test this above and watch the framerate. if that achieves the 30fps run again with trace ffmpeg -v trace -hwaccel drm -i Big_Buck_Bunny_720_10s_10MB.mp4 -f null - and provide me the console output? also tested again mpv just with the input file and debug output (but this time not the specific v4l request thread) mpv Big_Buck_Bunny_720_10s_10MB.mp4 --msg-level=vd=v,vo=v,vo/gpu/vaapi-egl=trace ... ... [vd] No hardware decoding requested. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1280x720 yuv420p auto/auto/auto/auto/auto CL=mpeg2/4/h264 of course tested different parmeters but mpv always falls back to soft. mpv Big_Buck_Bunny_720_10s_10MB.mp4 --msg-level=vd=v,vo=v,vo/gpu/vaapi-egl=trace --no-config --hwdec=yes [vd] Trying hardware decoding via h264_v4l2m2m-v4l2m2m-copy. [vd] Using underlying hw-decoder 'h264_v4l2m2m' [ffmpeg/video] h264_v4l2m2m: Could not find a valid device [ffmpeg/video] h264_v4l2m2m: can't configure decoder Could not open codec. -
What's wrong with just using the curl command? It will upload the logs to one of our paste servers and it will be nicely formatted and colorful. Way easier to read.
The Tall Man replied to dg4gg8cb9s's topic in Radxa Rock Pi S
You can also build from the release version, though I'm not sure it's fully that version for everything since the build process downloads updates from the internet. https://github.com/armbian/build/releases/tag/v25.8.1 At the top of that page, you can see how many commits have been added to main since the release of v25.8.1. You can download the source code at the bottom where it says Assets. - Yesterday
Share your displaying configuration by running "neofetch" and post it here. If your X11 is running on top of framebuffer, instead of DRM, it wont work. I also would like to get more debug from cedrus, linux's v4l2... but at least you can add -v to mpv to get more debug You only need the ffmpeg plugins offered by the original poster of the v4l2-request thread This is tested with mpv player only. v4l2-util and -ctl are only useful for webcams and video capture devices. v4l2loopback is not involved here. I don't have it I have an orange pi zero LTS, but I havent tested it there (I would use an SPI LCD, since it doesn't have an HDMI prot) -
robertoj replied to bushw's topic in Software, Applications, Userspace
For debian problems, do what I do: Get the cheapest raspberry Recreate the problem Ask the question in the raspberry forum Apply solution to Armbian XD -
Oh, sorry, I didn't notice the non-existent 6 and read it as Helios64. Of course, my description of the boot method is not limited to Rockchip devices; it works on all for which a mainline U-Boot is available. I have used it on iMX6, LX2160A and S922X devices, but my remaining devices are all based on Rockchip. The solutions are too varied to present a turnkey solution here. However, I am sure that only a corresponding configuration for implementation is required to achieve the desired behavior, but for that, the U-Boot documentation must be consulted to decide which solution should be chosen.
- 12 replies
1
- Helios 4
- Nanopi Neo 3
(and 1 more)
Tagged with:
Thank you for your answer. My board is not Rockchip-based, we have been generalizing the discussion for quite a while now. Well, and this is where it would get interesting but ...
- 12 replies
- Helios 4
- Nanopi Neo 3
(and 1 more)
Tagged with:
Since the RK3399 U-Boot can use an HDMI display and a USB keyboard, I would simply configure a jumpstart option in the boot flow that mounts a different root filesystem. When booting, you just have to select this option. If interacting with the firmware console is too complicated, the recovery system can be placed on a removable storage device. In this way, in case of need, only the rescue media needs to be connected and the system restarted; no firmware console access is required. A completely firmware-controlled fallback mechanism is also possible, but it requires further special configuration of the firmware. Read this thread to understand what I mean by my statement.
- 12 replies
1
- Helios 4
- Nanopi Neo 3
(and 1 more)
Tagged with:
If tester is not available, I'd try powering failing ports with their respective cables but feeding them from pins powering other ports (eg with wires from some molex cable, just need to be careful with polarity and shortcuts) and then powering working ports from pins on the board feeding failing ports - to exclude failure of the power rail feeding these ports on the board. If cables are faulty, I'd check them for electrical connections and if they are ok, would replace capacitors.
Link on Tinkerboard S Wiki Page leads to Online Casino
laibsch replied to darkside40's topic in Off-topic
What I like to do in such a case is link to archive.org. some spam got posted to this thread which I removed, so I felt like I might as well add an answer at the same time -
fair enough, no idea where i would get the right android image from for my unknown box so I guess I am stuffed putting Armbian on my box. never mind, will repurpose an old laptop when corelec updates for the s905x2 stop thanks for the help
You are missing something. The boot process starts with the uboot from the emmc (even if ultimately booting the SD card). And coreelec changes the uboot environment of the emmc in ways that are incompatible with with the armbian code. So you need to reflash a fresh android image if you want to use armbian as that will restore the basic state that armbian is expecting.
the guide has a warning: Note: If you have previously run other distributions on the box such as coreelec the below installation will not work. You will need to restore the original android firmware before attempting the install. coreelec changes the boot environment in ways that are incompatible with these Armbian builds. I have run coreelec but only ever from an SD card, I don't think the firmware has ever been changed as if I remove the SD card it boots into the original android system. Is this likely to be true or am I again missing something.
HP Pavilion8 core processor, 32Gig RAM laptop. I wanted to limit information to limit time for digging into it, but here they are: log-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.log.ans summary-build-322ed1c8-a4db-4873-85ac-be8e6a87fbd6.md
laibsch replied to dg4gg8cb9s's topic in Radxa Rock Pi S
dig through the github actions, how the images are compiled is public information ;-) -
probably time for the serial console my suspicion tells me that it will be hard to get proper logs otherwise my suspicion is that some umounts does not come back. <- try to unmount everything you can before the reboot and see if that helps.
