  2. If this is improvement as described, please provide a PR to configs: https://github.com/armbian/build/blob/main/config/kernel/linux-meson64-current.config https://github.com/armbian/build/blob/main/config/kernel/linux-meson64-edge.config Thank you!
  3. I think your driver is already in armbian, but your chip is not identified. To get it working you can identify it in the ethernet node this way: mdio { compatible = "snps,dwmac-mdio"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; ====> compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22";
  4. I haven't identified exactly what module load or trigger causes the network device to appear - waiting for 10 seconds during generator execution doesn't do the trick, so there is something explicit that happens post-initramfs stage that allows wlan0 to be instantiated, and if I understand the comment thread correctly, having the initramfs handle it would be the intended fix. Have to do some testing to figure out which module/firmware/etc. though, so that will have to wait for a few days until I have some time with the system to experiment.
  5. Today
  6. I will get an ili9486 soon, but it is different to yours: it has a red PCB and does not have the serial-to-parallel chip like those made for raspberry.
  7. In case someone else needs MAX0621 support here are the original files sent to me from Maxio Tech and my modified patch file (my_v1_patch.patch) for kernel 6.12.24 Then : sudo modprobe -r dwmac_rk sudo modprobe -a maxio sudo modprobe -a dwmac_rk I made a startup script to do that but there must be a better way? maxio also needs to be selected (M) in kernel config phase of build script (Device Drivers -> Network Device Support -> PHY Deice Support and Infrastructure) Release Note.txt v1_patch.patch maxio.c README my_v1_patch.patch
  8. Armbian Weekly Highlights This summary highlights key updates to the Armbian build repository, including kernel adjustments, tooling fixes, and configuration changes. These contributions reflect ongoing efforts from the community to ensure system stability, compatibility, and enhanced performance across supported platforms. Rockchip: Fixing Broken EDGE Kernel Patch Commit by: @Igor Pecovnik View Commit › Add “Out of Date” Notice to Example Config Author: EvilOlaf View Commit › UFS Devices: Add Sector Size Variable Author: FantasyGmm View Commit › Update prepare-host.sh “This doesn’t feel right. The package exists across all main distros. Probably not needed in every case… but it’s toolchain-related, so worth revisiting if merged.” Author: Werner View Commit › Add New Host Build Dependency for Noble Author: EvilOlaf View Commit › rockchip64: Fix ATF Build & Bump to Latest Author: Werner View Commit › Allwinner: Bump to Latest Author: Igor Pecovnik View Commit › Fix ORAS Tooling Download – Add wget Moved wget to basic dependencies Cleaned up spacing Author: Werner View Commit › ZRAM Service Fix – mkfs Deprecation Author: Igor Pecovnik View Commit › Auto-Sync Board Config Status Author: Igor Pecovnik View Commit › Fix jq Filter Usage in apt-utils Author: Franklyn Tackitt View Commit › AIC Wi-Fi Driver Adjustment for Rockchip Author: Igor Pecovnik View Commit › BananaPi SM1: Fix Patch Naming “Do to my laziness these patches were submitted ugly. My bad.” Author: Patrick Yavitz View Commit › Btrfs Root on Subvolume Support Author: Igor Velkov View Commit › U-Boot v2025 for Sunxi: H616 Fixes, DTS Updates Author: The-going View Commit › Sunxi 6.13 Series Re-export Patches b10d00d Fix EMAC0/MDIO0 (rtl8211F) 61ad7ce Zero2W: Add Missing Nodes c019129 Update to v6.13.11 83d866a Add Sound Support for H616/618 c5fc8be PWM Nodes & Overlays f61dc0c Enable TV Output & Zero2W Patches 481b407 Cedrus V4L2: Add More Formats + DMA Update f2c4d41 Panfrost: Rework Power Domain Patches (v2) c129052 Switch from rkr5 to rkr5.1 Author: Mecid View Commit › Improve Example Config Handling Add BUILD_DESKTOP Automation 1469fda Fix Link & Create Proper Example c93edf5 Copy Example Config at First Start 554580a Remove Deprecated lib.config 1d9c78a Armbian is a community-driven project maintained by a group of dedicated individuals in their limited free time. We provide the platform and tools for collaboration, but fixing every bug is beyond our capacity. Even large, well-funded teams face similar limits. That’s why we rely on the community—not just for reporting issues, but for actively helping to resolve them. file:///tmp/lu1588574hd9ee8.tmp/lu1588574hd9fat_tmp_858a6d92.png View all commits and contribute at github.com/armbian/build file:///tmp/lu1588574hd9ee8.tmp/lu1588574hd9fat_tmp_7111f4e6.png Support Armbian development: Donate Today! The post Armbian Weekly Highlights first appeared on Armbian. View the full article
  9. Yes, I'm aware of that. I wanted to try it because it has a more up-to-date version of Podman, and will likely become stable by the end of the year.
  10. Non-standard docker image can cause rebuild since it is now based on Noble. Thanks for the information, @Werner. That was all useful to know. I removed the attributes you noted and tried building again. The final image turned out OK, but still required compilation. Is this because the target is Trixie (not Bookworm) which is still unsupported, or is it just not possible now to create a custom image without also compiling a kernel?
  11. Yesterday
  12. I think I figured out the expert=yes switch a few days ago and built a test vendor kernel image. Works splendidly with the exception of an issue with screen not recovering from going to sleep or some such. Thanks for your assistance eselarm and Werner for the sharing of your expertise.
  13. @OP: you need to give more info - what board? - what user space (Ubuntu or Debian, what release)? You said this works on Ubuntu. That was not an SBC? Edit: This issue is known upstream. Ubuntu does not have a delta to Debian and hence should be affected as well. In any case, there is not much Armbian can or is likely going to do.
  14. Please be aware that trixie is as of now still unsupported
  15. Bug in NetPlan / systemd-networkd or bug in Armbian implementation? We have no options to maintain NetPlan or any other similar complex user space component. Armbian uses Ubuntu / Debian packages without changes as we are focused into Kernel space, framework, tools, build automation. If there is a workaround, we can push it somewhere. Like this one: https://github.com/armbian/build/commit/7f32a5853513745ee6aa55b6d3856ac67ec036e2 Forum is just fine. Armbian itself don't have resources to touch any of this, but someone might know something and help you / everyone. I briefly understand what is the problem, but no idea how to solve it.
  16. well.. just to answer your questions.. just because i really think you mishandled or completely misinterpreted what i said.. i didn't undervalued in any way the dedication and good work of everyone on this forum.. for the contrary! it's exactly for all that hard work, that i know that's it's really a lot simpler than it would be if this forum didn't exist! after the work done here, essencially most of the cases, if the chipset is the same it's simply install the right drivers and fly away! i'm saying this forum has done a great job doing our job very very very easy by comparison to what as already been done! now regarding your questions... no support: chipset is nothing more than a computer, and thanks to a lot of good people on this forum and others, if you understand about linux, all the hard work is done for us.. basically we just have to test the versions of armbian that will run on our boxes and make good use of the eyes to physically open the box and check the hardware we have to install the right drivers and put it working as best as possible. varying hardware quality: same answer as above.. varying hardware in general: once again, same answer as above.. no documentation: once again, same answer as above.. You said things for completely different questions than mine.. i simply don't understand why there are a lot of people saying bad things even if it's exactly the same hardware present on the box that exists on some development boards... i always were very close with computers, i know a lot of programming languages and in essence i am addicted to computers and generally everything related to technology.. for someone who knows how to deal with pratically everything i get my hands on in terms of messing with hardware and programming in several degrees, i really don't get it whats so hard just by oppening the 4 screws on the bottom of the boxes, and read the cpu, lan, wifi and Bluetooth and simply installing the basic system and it's drivers.. yes, its as simple as doing that after dealing with the bootloader, and that, with so much shares there are nowadays in the internet i can honestly say i never had any problem with any box i had in my hands.. and basically, there are a lot of boxes, i can say around 90% that have compatible firmwares, being the main and biggest problem for a lot of people, the wifi, the lan and the Bluetooth.. and after you know how to build your drivers, it's really so easy to get things going.. so yeah, in a tech perspective i think it's ridiculous to think that there are boxes impossible to get it working right.. it just takes a bit of work, but for anyone that knows how to deal with linux (and this forum is about armbian, essentially linux) i see all that hate as comparable to someone in a Windows forum putting hate for someone saying they are having difficulties installing a driver on Windows on computers that are not from a bigger brand.. and for the kind of affirmation you made it looks like you think i'm one of those superfans of iptv that sells boxes with servers subscription 😂 but nop, not one of those.. i never wanted anything to do with it, but i sold a lot of android boxes to guys like that, so yeah, i know what you mean 😉 essentially, i had here in my country since 2013, a big website during almost 10 years called lojandroid.com, "loja" from that name is the equivallent to "store". Nowadays everyone knows what a android box is and it's sold even in supermarkets, but during at least in my first 3 years selling them, i can tell you i had sales on several portuguese marketplaces that didn't had another seller with android boxes beside me 😉 As i said before, i always loved messing with hardware, and for several years i sold lots of android boxes with all kind of servers installations, and yes, had a few times customers coming back asking for warranty for heating and freezing installations and/or corrupt installations on the ROM, but if you understand of computers as i think you do, for sure you know on demanding tasks like some uses on home servers, some of the uses sometimes asked too much for too long for the ROM memory or even the sdcards, it's very, very easy to corrupt data on memory, be it ROM, Sdcard or evens USB, ant that happens if it's a big well known cipset and model or not.. when its sdcard installation (the easiest for correcting problems, or simply maintenance) simply had to copy from my backup of the system i had for that model, burn to a new sdcard, and the customer just had to put the sdcard on the box, turn it on and voilá, a new system on a push of a button.. because yes, every model box i sold i made a backup of its original firmware and of mine with my modifications.. And yes, in some demanding tasks its a lot safer to recover just by using a system installed on the sdcards, and usually on that situations its resolved just by replacing a sdcard, a lot easier than trying to recover the internal memory of a chipset, that not always goes the best way.. The brand i sold a lot during the first years, was minix, and i can tell you that the some problems i had with the cheapest, also had with minix.. but the big question there is that 1 minix box price would pay around 3 boxes with the same hardware on white brands.. There will always exist the purists and normal people that know that the world is a lot bigger than the bigger brands.. but for the looks of you affirmations it looks like for example you dont know that for example nowadays the chinese eletric cars are becoming far superior than the most known brands.. Nowadays BYD, Polestar and a lot more brands are superior than the Teslas, but the teslas purists will say that it's not the same.. it's also the same things like Apple people say from the other brands or operating systems.. Nothing against teslas and iphones, in fact i adore teslas and even had two iphones, but in case of the iphone, me being me, i don't like to be locked, i also always messed a lot with the firmwares on my phones, and in Iphones, besides the jailbrake that just leaves it a bit more usable, i never got much to play concerning the things i like to do 😂 in conclusion, i'm not saying bad of the specific chipsets used for armbian! I just dont think that is white or black.. theres really of gray area in between, i for my experience know that the World is really a lot, lot, lot bigger than that, and chipsets simply are nothing more than a computer, and a lot easy to mess on that sense after getting the hang of it.. hope i gave someone a fun reading, and keep cool everyone 😉👍
  17. Interesting effect of changing the ili9488 10cm (4.0 inch) for a 9cm (3.5 inch) LCD, same resolution https://a.aliexpress.com/_mMKRqan https://a.aliexpress.com/_mqk0Qbv (I bought a similar with touch) maybe I need a different spi frequency update: I changed 40 MHz to 60 MHz and my new LCD works perfectly:) update: with 60 Hz, full screen video has a lot of noise and distortion. With 70Hz, there’s only white dots on black background with 50hz, the console shows wrong colors and video is white noise with 30 hz, console text and video are ok… but video looks 10 fps the touch panel in the smaller 9cm LCD does not work. Do not buy it!
  18. Honestly I was quite tired of playing with kernels where things are not working as expected. It's not a criticism towards the armbian developers community, but despite the ongoing effort, a stable maturity of the kernel\sotware is not reached yet. For my personal use cases, I need: - server mode and no vendor Radxa Os. - SATA working - audio working Despite some overoptimistic initail tests with the 6.1.99 vendor kernel, at the end of the day SATA is not stable enough. Sometimes I've to turn off/on the device up to 3 / 4 times before having the SATA drives detected. Taken by an overwhelming frustration, I took the risk and removed the R29 resistor as described here. Now SATA is working as expected everytime at least with vendor kernel 6.1.99: I need this version also because it has the audio drivers working correctly. I hope that a definitive software solution can be found in the near future without the need of hardware hacks.
  19. tested sd card: No difference iperf3 from client to Helios around 20mb/s I tested another local 2.5Gbit transfer client (arch arm) - server (armbian) 2.34Gbit/s (292mbit/s) and reverse 326mbit/s (40mb/s) Maybe a setup problem with the switch or with arm-arch client drivers Nevertheless thank you for your help! ;)
  20. Dear friends, in the end, I’ll answer myself... I have thoroughly studied the entire documentation from both Orange Pi and the RK3588 datasheet, and I am almost certain — unless I made a mistake — that there is no PCM function on the pins listed in the documentation for the Orange Pi 5 MAX. I have created a map of all the pins and their functions in various modes, and I hope it will be useful to someone.
  21. Why? Will cause recompilation on every build This does not exist anymore IIRC. Non-standard docker image can cause rebuild since it is now based on Noble. This is not needed since it is default behavior. Also unneeded since default is yes already.
  22. You know one can have multiple DE's installed and select which one to use at login? sudo tasksel kde-desktop lets you add KDE Plasma for every Debian based install. Important note is that RK3588 needs a pretty new mainline kernel otherwise forget KDE. With vendor kernel it should be no issue. So if you want to use KDE Plasma, no new image or install is needed. But maybe you only want to build an image and not use it.
  23. I apologize if this is a basic question. I'm trying to make a minimal Orange Pi Zero 3 Trixie image with a btrfs file system and NetworkManager for the networking stack using Docker without having to compile a new kernel (i.e., I just want to use the precompiled kernel found in the CSC version). I created a `config-myimage.conf` file under `build/userpatches`: BOARD=orangepizero3 BRANCH=current RELEASE=trixie CLEAN_LEVEL=cache KERNEL_CONFIGURE=no BUILD_KSRC=no BUILD_MINIMAL=yes NETWORKING_STACK=network-manager DOCKER_ARMBIAN_BASE_IMAGE=ubuntu:jammy ROOTFS_TYPE=btrfs BTRFS_COMPRESSION=zlib CONSOLE_AUTOLOGIN=yes #BOOTSIZE=96 # need larger boot size to prevent 'disk out of space' # on kernel upgrade BOOTSIZE=256 COMPRESS_OUTPUTIMAGE='sha,xz' EXTRAWIFI=yes function user_config__010_modify_package_list() { # adds additional packages to the package cache add_packages_to_rootfs btrfs-progs neovim pmount nmap tmux # edit this list to remove packages from cache remove_packages nano } I then ran `./compile.sh myimage`, but it launches into kernel compilation. I did this once before uisng bookworm, but I can't remember how....
  24. I found the dts setting about "ethernet@5020000" was different between kernel 5.15.93 and kernel 6.1.47. We need to make sure the following things are correct: 1. Ethernet driver uses the correct clock/reset 2. GPIO reset can be pulled up 3. MDIO can correctly go to PHY 4. Pinmux correctly sets Ethernet pins #Kernnel 5.15.93-sunxi64 ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac\0allwinner,sun50i-a64-emac"; syscon = <0x31>; reg = <0x5020000 0x10000>; interrupts = <0x00 0x0c 0x04>; interrupt-names = "macirq"; resets = <0x04 0x21>; reset-names = "stmmaceth"; clocks = <0x04 0x54>; clock-names = "stmmaceth"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x32>; phy-mode = "rgmii-id"; phy-handle = <0x33>; phy-supply = <0x34>; phy-io-supply = <0x35>; allwinner,rx-delay-ps = <0xc8>; allwinner,tx-delay-ps = <0xc8>; phandle = <0x78>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x79>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x01>; reset-gpios = <0x1f 0x03 0x0e 0x01>; reset-assert-us = <0x3a98>; reset-deassert-us = <0x9c40>; phandle = <0x33>; }; }; }; #Kernel 6.1.47-current-sunxi64 ethernet@5020000 { compatible = "allwinner,sun50i-h6-emac\0allwinner,sun50i-a64-emac"; syscon = <0x32>; reg = <0x5020000 0x10000>; interrupts = <0x00 0x0c 0x04>; interrupt-names = "macirq"; resets = <0x06 0x21>; reset-names = "stmmaceth"; clocks = <0x06 0x54>; clock-names = "stmmaceth"; status = "okay"; pinctrl-names = "default"; pinctrl-0 = <0x33>; phy-mode = "rgmii-id"; phy-handle = <0x34>; phy-supply = <0x2e>; phy-io-supply = <0x35>; allwinner,rx-delay-ps = <0xc8>; allwinner,tx-delay-ps = <0xc8>; phandle = <0x79>; mdio { compatible = "snps,dwmac-mdio"; #address-cells = <0x01>; #size-cells = <0x00>; phandle = <0x7a>; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x01>; reset-gpios = <0x1e 0x03 0x0e 0x01>; reset-assert-us = <0x3a98>; reset-deassert-us = <0x9c40>; phandle = <0x34>; }; }; };
  25. To troubleshoot this thing I would just boot from another sd card with a fresh bookworm image leaving your system on emmc or on another sd untouched. In 'sudo ethtool -i <interface>' the name of your 2.5G interface has to be inserted - 'ifconfig' will reveal it (I renamed mine to end1). If the rtl_nic firmware is recognized correctly it will display: root@grid:~# sudo ethtool -i end1 driver: r8152 version: v1.12.13 firmware-version: rtl8156a-2 v2 04/27/23 ...
  26. I am trying to downgrade to kernel 5.15.93-sunxi64 and found the eth0 is worked. pi@orangepi3:~$ dmesg | grep eth0 [ 18.467932] dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL) [ 18.468969] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 18.469701] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found [ 18.469727] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available [ 18.469734] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW [ 18.475463] dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii-id link mode [ 20.510690] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 20.510735] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  27. See https://github.com/canonical/netplan/pull/456#discussion_r1569065581 The way the netplan + networkd integration is designed requires all the network devices (wlan0 in particular) to exist at /sbin/init time - otherwise, the netplan generator disables `systemd-networkd-wait-online.service` which also causes `network-online.target` to be reached early. In particular, this breaks any network FS mounts on boot. Of note, I tried logging in to file the bug via the dev contribution platform, but it looks I'm blocked from JIRA access, so am filing it here instead.
  28. My log : https://paste.armbian.com/idomububex I find the phy issue stiil happened in OranpePi3 when using Kernel 6.1.47-current-sunxi64 and 6.12.20-current-sunxi64. @Jack07 @JohnnyLaw Do you still have same issue when using 6.X.X verion kernel?
