I tried to enable the I2S / PCM5102 service with AI, but unfortunately, despite numerous attempts, I couldn't. But anyone can use a USB audio card. Maybe someone else will figure out how to enable it 🙂 Best regards
Support for DP Alt Mode is now functional for the A7S running kernel 6.6. https://github.com/NickAlilovic/build/releases/tag/Radxa-cubie-A7S-v0.6.4
NanoPC-T6 LTS Reset button doesn't work on 6.18.x kernel
ando replied to ando's topic in NanoPC T6 LTS
yes, i've studied the schematic well to see if that gave any clues and I have learned that it ties into the Power Management Unit. It remains that the button doesn't work on mainline kernels but does on the vendor kernel. There must be some init step or configuration that's missing. -
https://docs.armbian.com/User-Guide_Armbian-Config/System/#desktop Should be straighforward to enable desktop on top of CLI.
Hi Gentleman, all desktop images disappeared for Opi 3B. Is there a chance that will be available later?
usual user replied to ando's topic in NanoPC T6 LTS
According to the circuit diagram, the reset button is connected to the hardware reset lines, so nothing can prevent forcing the reset state. -
Looks like the current-rockchip64 kernel that one receives with apt on PINE64 rockpro64 is 3.18.10 (6.18.10-current-rockchip64), vulnerable to copy-fail. This seems weird because if you go to https://armbian.com/boards/rockpro64 that page says that the "current" kernel for these systems is 6.18.26 and that is what you get when you download the image file. Is there an issue with updating the apt repos?
Things are still very sad with Ethernet. Is this could be related to some low-level timings in device configuration?
First of all, thanks for your reply. Even though you said there are no "vendor-lockin" i felt like so that's why i created a post on this forum as this issue came only after armbian os flash. As i said, after flashing armbian os, i was not able to use MASK button to bypass emmc boot and about a dozen of different os other than armbian failed to boot from SD card. Then i experimented on different methods including the PC connectivity but changing bootloader or os image didn't work as the mask communication is getting lost during flash command run. I deleted boot files from armbian boot partition to check if that fall back to SD card, but there was no luck. However armbian SD card boot still worked. So i confirmed that it is the change in bootloader that armbian made. Then i re installed armbian os inside emmc and used dd command to write the original bootloader images which is taken from the nanopi r6s official eflasher download link. It worked! Now i am able to install other os than armbian. Kindly fix this issue and acknowledge the same, otherwise people like me will think twice before testing latest armbian os next time. Best regards
Armbian does not have things like "vendor-lockin" or something and descriptions like "does not work" aren't much helpful as well. Either way, we cannot help with 3rd party OS since we neither know them nor deal with them, so I suggest to ask at the place where you got the image you are attempting to use get from, like http://friendlyarm.com/
Ah, this board has n out of tree dt as well which most likely overwrites the patch. Try adjusting this file: ~/build/patch/kernel/archive/rockchip64-6.18/dt/rk3576-nanopi-r76s.dts
I'll give it a go when ready for download 🙂 ljones
I am trying to get the ARM performance assessment setup working (I'm trying to get Mali profiling for OpenCL code) on the Rock 5B+, and I've hit a blocker. The main component to this is some kernel configuration (CONFIG_ARM_SPE_PMU) and a loadable module. Oddly, those work fine in a custom kernel build. What I am hitting appears to be some missing interrupt setup that renders all those components inert. (It has to be a custom build to get CONFIG_ARM_SPE_PMU set. The issue is that even with the kernel configured and the module loaded, the SPE component remains inactive. ARM has its own system report tool which analyzes a setup, and that tool is reporting an issue: And indeed, nothing seems to show in cat /proc/interrupts. The man page for the module suggests this is the issue: It says: KPTI is definitely disabled and the SPE PMU loads (it's in lsmod) but it still doesn’t show in /sys/bus/event_source/devices/. Nothing relevant seemed to show in dmesg either. Frankly, I have no idea where to look for the SPE interrupt, or how to set it up. If anybody has any pointers or suggestions, I'd be extremely grateful.
deleted my patch file in userpatches cp output/patch/kernel-rockchip64-current.patch patch/kernel/archive/rockchip64-6.18/rk3588-1300-arm64-dts-rock5t-eth-reset.patch definitely saw the patch get applied during the build ./compile.sh BOARD=rock-5t BRANCH=current RELEASE=trixie kernel-dtb # cat output/logs/log-kernel-dtb-cd035955-4094-4e6f-b86d-89fe0287a2ce.log.ans |grep eth-reset patch/kernel/archive/rockchip64-6.18/rk3588-1300-arm64-dts-rock5t-eth-reset.patch -> 223/230: rk3588-1300-arm64-dts-rock5t-eth-reset(:1) (+20/-0)[1M] {rk3588-rock-5t.dts} │ rk3588-1300-arm64-dts-rock5t-eth-reset copied the rk3588-rock-5t.dtb over to my Rock5t's /boot/dtb/rockchip/ folder, rebooted it and ..... it didn't work # dmesg |grep -e 'r8169\|RTL8125B' [ 2.286822] r8169 0003:31:00.0: enabling device (0000 -> 0003) [ 2.314767] r8169 0003:31:00.0 eth0: RTL8125B, 00:48:54:20:XX:XX, XID 641, IRQ 123 [ 2.314803] r8169 0003:31:00.0 eth0: jumbo features [frames: 16362 bytes, tx checksumming: ko] [ 2.347904] r8169 0003:31:00.0 enP3p49s0: renamed from eth0 [ 5.367059] Realtek Internal NBASE-T PHY r8169-3-3100:00: attached PHY driver (mii_bus:phy_addr=r8169-3-3100:00, irq=MAC) [ 5.560727] r8169 0003:31:00.0 enP3p49s0: Link is Down [ 7.870963] r8169 0003:31:00.0 enP3p49s0: Link is Up - 1Gbps/Full - flow control rx/tx So either I'm doing something wrong, 1st time building something on this build framework, or this patch just doesn't work on my Rock5t. Ethernet should be the same on the consumer and industrial boards right?
Hm, the sub-folder in userpatches might be wrong, not sure though. If in doubt just copy your patch directly into patch/kernel/archive/rockchip64-6.18/ Then it should be applied
Hi There, Board: NanoPi R6S I've flashed armbian OS via armbian imager tool + microSD card and installed the os into emmc using armbian-install. Os was working fine then i realize that the minimum required kernel drivers are not available (npu/tpu/gpu). I have tried to install more than a dozen operating systems including that I used before, but the booting process doesn't work. After lots of try I realized that only armbian os is getting booted from the SD card. Mask button which should bypass emmc and force to boot from microSD card is not working after flashing armbian os. I couldn't connect the NanoPi R6S via USB A to A link for direct flashing. When i flash os other than armbian, it does not boot and no output at HDMI. When MASK button is pressed before boot, the device seems using somewhat 3W current and stays on with red led, connected keybords will get power but no HDMI output. How to restore the bootloader and other required partitions with its original version so that i can start booting os other than armbian. Please help.
Hi @SteeMan I have the same device as @Levy Barbosa and was able to acquire the logs. I took two. The first one booting normally, the second one I kept the reset button pressed while taking the log. Here is what I am planning: 1 - Have armbian running via an USB 2 - Dump its current firmware (not sure yet how to do it, will search more on it) 3 - Write armbian directly to the eMMC to boot it directly from there (not sure if its possible, but aiming it.) I am going to paste them here, let me know if you rather have me uploading a TXT file, just so I would not if any other log is needed in the future. Normal booting: Terminal log file ----------------------------------------------- OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. <0>GXL:BL1:9ac50e:bb16dc;FEAT:BFFC39BE:100;POC:3;RCY:0;EMMC:0;READ:0;1.0;1.0;CHK:0; TE: 313337 BL2 Built : 10:47:34, Jan 14 2019. gxl g152d217 - guotai.shen@droid11-sz set vcck to 1120 mv set vddee to 1000 mv Board ID = 7 CPU clk: 984MHz DDR enable rdbi DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 912MHz bist_test rank: 0 1c 00 39 2e 13 49 1f 01 3e 2e 12 4b 28 28 28 28 28 28 27 27 27 28 28 28 693 - PASS Rank0: 1024MB-2T-13 AddrBus test pass! Set ddr ssc: ppm1000- eMMC boot @ 0 sw8 s emmc switch 3 ok BL2: rpmb counter: 0x00000024 emmc switch 0 ok OTP_ARB=00000001 Load FIP HDR from eMMC, src: 0x0000c200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3x from eMMC, src: 0x00010200, des: 0x01704000, size: 0x000f4000, part: 0 NOTICE: BL3-1: v1.0(release):3bc3888 NOTICE: BL3-1: Built : 11:28:51, May 10 2019 [BL31]: GXL CPU setup! NOTICE: BL3-1: GXL secure boot! NOTICE: BL3-1: BL33 decompress pass mpu_config_enable:system pre init ok dmc sec lock MVN_1=0x01010100 MVN_2=0x01010000 [Image: gxl_v1.1.3376-325f6f4 2019-05-27 16:25:06 shen.liu@droid11-sz] OPS=0x34 21 0d 34 00 37 2a 00 89 62 00 ac b5 67 13 99 02 [0.927393 Inits done] secure task start! high task start! low task start! INFO: BL3-2: ATOS-V2.4-239-g48b8c37d #1 Wed Feb 5 09:34:09 UTC 2020 arm INFO: BL3-2: Chip: GXL Rev: D (21:D - 30:2) INFO: BL3-2: crypto engine DMA INFO: BL3-2: secure time TEE INFO: BL3-2: CONFIG_DEVICE_SECURE 0xb200000e U-Boot 2015.01-gb7c1687 (Apr 08 2021 - 22:17:19) DRAM: 1 GiB Relocation Offset is: 36e85000 register usb cfg[0][1] = 0000000037f51148 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033e856b0 aml_priv->desc_buf = 0x0000000033e879f0 SDIO Port B: 0, SDIO Port C: 1 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [mmc_startup] mmc refix success init_part() 297: PART_TYPE_AML [mmc_init] mmc init success Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 start dts,buffer=0000000033e8a240,dt_addr=0000000033e99240 get_partition_from_dts() 71: ret 0 Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 parts: 17 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 set has_boot_slot = 0 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 0000000010000000 1 12: odm 0000000008000000 1 13: system 0000000050000000 1 14: product 0000000008000000 1 15: cache 0000000025000000 2 16: data ffffffffffffffff 4 init_part() 297: PART_TYPE_AML eMMC/TSD partition table have been checked OK! crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!! crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!! crc32_s:0x7fd3b243 == storage crc_pattern:0x7fd3b243!!! mmc env offset: 0x2c400000 In: serial Out: serial Err: serial reboot_mode=cold_boot itest - return true/false on integer compare Usage: itest [.b, .w, .l, .s] [*]value1 <op> [*]value2 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-2755: calc f2d3afb4, store f2d3afb4 _verify_dtb_checksum()-2755: calc f2d3afb4, store f2d3afb4 dtb_read()-2972: total valid 2 update_old_dtb()-2953: do nothing Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 vpu: clk_level in dts: 2 vpu: set clk: 200000000Hz, readback: 200000000Hz(0x501) vpu: vpu_clk_gate_init_off finish vpp: vpp_init cvbs: cpuid:0x21 cvbs: find performance_pal config hpd_state=0 vpp: vpp_matrix_update: 2 cvbs_performance_enhancement cvbs_config_hdmipll_gxl cvbs_set_vid2_clk vdac_enable: 1, module_sel:0x8 Net: dwmac.c9410000amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 CONFIG_AVB2: avb2 Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=2 reboot_mode:::: cold_boot amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x3fc00000 [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x3fc00000 [OSD]VPP_OFIFO_SIZE:0xfff00fff [CANVAS]addr=0x3fc00000 width=3840, height=2160 [OSD]osd_hw.free_dst_data: 0,719,0,575 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 Command: bcb uboot-command Start read misc partition datas! BCB hasn't any datas,exit! amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Invalid boot device ** Fail to detect device usb 0 get upgrade version failed Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 CONFIG_SYSTEM_AS_ROOT: systemroot system_mode: 1 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 CONFIG_AVB2: avb2 active_slot: normal [imgread]secureKernelImgSz=0x94a200 avb2: 1 Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal ab_suffix is avb_slot_verify.c:524: DEBUG: Loading vbmeta struct from partition 'vbmeta'. Verified using testkey [store]To run cmd[emmc dtb_read 0x00000000357695c0 0x40000] dtb_read_shortcut()-2813: short cut in... Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal avb verification: locked = 1, result = 0 ee_gate_off ... avb2: 1 ## Booting Android Image at 0x01080a00 ... reloc_addr =33f0a5a0 copy done Kernel command line: androidboot.dtbo_idx=0 buildvariant=user Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected find 1 dtbos dtbos to be applied: 0 Apply dtbo 0 Uncompressing Kernel Image ... OK kernel loaded at 0x01080000, end = 0x02958a00 libfdt fdt_getprop(): FDT_ERR_NOTFOUND Loading Device Tree to 000000001ffee000, end 000000001ffff4ba ... OK fdt_instaboot: no instaboot image Starting kernel ... uboot time: 6838532 us domain-0 init dvfs: 4 [ 0.000000@0] Reserved memory: unable to setup CMA region [ 0.232770@0] VMAP:handle_vmap_fault address ffffff802008c000 out of range [ 5.889934@2] init: Unable to set property 'ro.build.id' to 'PI' in property file '/system/build.prop': Read-only property was already set [ 5.897038@2] init: Unable to set property 'ro.build.version.incremental' to '20210409' in property file '/system/build.prop': Read-only property was already set [ 5.911478@2] init: Unable to set property 'ro.build.version.security_patch' to '2021-03-05' in property file '/system/build.prop': Read-only property was already set [ 5.926147@2] init: Unable to set property 'ro.build.date.utc' to '1619145388' in property file '/system/build.prop': Read-only property was already set [ 5.939635@2] init: Unable to set property 'ro.product.model' to 'IZY01' in property file '/system/build.prop': Read-only property was already set [ 5.952548@2] init: Unable to set property 'ro.product.brand' to 'Intelbras' in property file '/system/build.prop': Read-only property was already set [ 5.965901@2] init: Unable to set property 'ro.product.name' to 'IzyPlay' in property file '/system/build.prop': Read-only property was already set [ 5.978998@2] init: Unable to set property 'ro.product.device' to 'DV8038' in property file '/system/build.prop': Read-only property was already set [ 5.992358@2] init: Unable to set property 'ro.product.manufacturer' to 'SDMC' in property file '/system/build.prop': Read-only property was already set [ 6.005841@2] init: Unable to set property 'ro.wifi.channels' to '13' in property file '/system/build.prop': Read-only property was already set [ 6.018589@2] init: Unable to set property 'ro.build.fingerprint' to 'Intelbras/IzyPlay/DV8038:9/PI/20210409:user/release-keys' in property file '/system/build.prop': Read-only property was already set [ 6.038481@2] init: Unable to set property 'ro.product.first_api_level' to '28' in property file '/vendor/build.prop': Read-only property was already set [ 6.051357@2] selinux: avc: denied { set } for property=ro.net.pppoe pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.051357@2] [ 6.068258@2] init: Unable to set property 'ro.net.pppoe' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.081330@2] selinux: avc: denied { set } for property=persist.sys.dts.edid pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.081330@2] [ 6.099550@2] init: Unable to set property 'persist.sys.dts.edid' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.112706@2] selinux: avc: denied { set } for property=service.bootvideo pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.112706@2] [ 6.131353@2] init: Unable to set property 'service.bootvideo' to '0' in property file '/vendor/build.prop': SELinux permission check failed set property 'persist.sys.PQ.enable' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.602149@2] init: Unable to set property 'ro.nrdp.validation' to 'ninja_6' in property file '/vendor/build.prop': Read-only property was already set [ 6.614889@2] init: Unable to set property 'ro.nrdp.modelgroup' to 'SDMCs805' in property file '/vendor/build.prop': Read-only property was already set [ 6.628353@2] selinux: avc: denied { set } for property=sys.fb.bits pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.628353@2] [ 6.646453@2] init: Unable to set property 'sys.fb.bits' to '32' in property file '/vendor/build.prop': SELinux permission check failed [ 6.659515@2] selinux: avc: denied { set } for property=ro.adb.secure pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:exported_secure_prop:s0 tclass=property_service permissive=0 [ 6.659515@2] [ 6.677689@2] init: Unable to set property 'ro.adb.secure' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 6.689845@2] selinux: avc: denied { set } for property=persist.sys.app.rotation pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.689845@2] [ 6.709158@2] init: Unable to set property 'persist.sys.app.rotation' to 'original' in property file '/vendor/build.prop': SELinux permission check failed [ 6.725543@2] init: /recovery not specified in fstab [ 6.977780@2] init: Could not find service hosting interface android.hardware.keymaster@3.0::IKeymasterDevice/default [ 6.983791@2] init: Could not find service hosting interface android.hardware.keymaster@3.0::IKeymasterDevice/default MESSAGE: USER-TA:log_msg:70: KeymasterTA (info): app/ipc/keymaster_ipc.cpp, Line 752: Amlogic KEYMASTER 2.0! Build Time: Jun 19 2018 14:46:55 [ 7.498202@3] init: couldn't write 2976 to /dev/cpuset/camera-daemon/tasks: No such file or directory [ 7.767829@1] init: setpgid failed for console: Operation not permitted [ 7.879853@2] init: Failed to bind socket 'pdx/system/vr/display/client': No such file or directory [ 7.910205@2] init: Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory [ 7.947258@2] init: Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory [ 6.144032@2] selinux: avc: denied { set } for property=libplayer.livets.softdemux pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.144032@2] [ 6.163476@2] init: Unable to set property 'libplayer.livets.softdemux' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 6.176762@2] selinux: avc: denied { set } for property=libplayer.netts.recalcpts pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.176762@2] [ 6.196278@2] init: Unable to set property 'libplayer.netts.recalcpts' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 6.209516@2] selinux: avc: denied { set } for property=persist.fw.force_adoptable pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.209516@2] [ 6.229021@2] init: Unable to set property 'persist.fw.force_adoptable' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.242651@2] selinux: avc: denied { set } for property=sys.ignore.inativecec pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.242651@2] [ 6.261600@2] init: Unable to set property 'sys.ignore.inativecec' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.274701@2] selinux: avc: denied { set } for property=ro.sys.hdmiin.enable pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.274701@2] [ 6.293739@2] init: Unable to set property 'ro.sys.hdmiin.enable' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.306792@2] selinux: avc: denied { set } for property=mbx.hdmiin.switchfull pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.306792@2] [ 6.325964@2] init: Unable to set property 'mbx.hdmiin.switchfull' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.339174@2] selinux: avc: denied { set } for property=mbx.hdmiin.videolayer pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.339174@2] [ 6.358384@2] init: Unable to set property 'mbx.hdmiin.videolayer' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.371936@2] selinux: avc: denied { set } for property=ro.com.android.dateformat pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.371936@2] [ 6.391048@2] init: Unable to set property 'ro.com.android.dateformat' to 'MM-dd-yyyy' in property file '/vendor/build.prop': SELinux permission check failed [ 6.405572@2] selinux: avc: denied { set } for property=net.tethering.noprovisioning pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.405572@2] [ 6.424689@2] init: Unable to set property 'net.tethering.noprovisioning' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.439214@2] selinux: avc: denied { set } for property=ro.product.firmware pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.439214@2] [ 6.457345@2] init: Unable to set property 'ro.product.firmware' to '00502001' in property file '/vendor/build.prop': SELinux permission check failed [ 6.470652@2] selinux: avc: denied { set } for property=ro.product.otaupdateurl pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.470652@2] [ 6.489927@2] init: Unable to set property 'ro.product.otaupdateurl' to 'http://10.28.11.53:8080/otaupdate/update' in property file '/vendor/build.prop': SELinux permission check failed [ 6.506456@2] selinux: avc: denied { set } for property=ro.treble.enabled pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.506456@2] [ 6.525099@2] init: Unable to set property 'ro.treble.enabled' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.537847@2] selinux: avc: denied { set } for property=fw.disable_quota pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.537847@2] [ 6.556546@2] init: Unable to set property 'fw.disable_quota' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.569363@2] selinux: avc: denied { set } for property=persist.sys.PQ.enable pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.569363@2] t: Unable to set property 'ro.nrdp.validation' to 'ninja_6' in property file '/vendor/build.prop': Read-only property was already set [ 6.614889@2] init: Unable to set property 'ro.nrdp.modelgroup' to 'SDMCs805' in property file '/vendor/build.prop': Read-only property was already set [ 6.628353@2] selinux: avc: denied { set } for property=sys.fb.bits pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.628353@2] [ 6.646453@2] init: Unable to set property 'sys.fb.bits' to '32' in property file '/vendor/build.prop': SELinux permission check failed [ 6.659515@2] selinux: avc: denied { set } for property=ro.adb.secure pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:exported_secure_prop:s0 tclass=property_service permissive=0 [ 6.659515@2] [ 6.677689@2] init: Unable to set property 'ro.adb.secure' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 8.123657@0] android.hardware.health@2.0-impl: wakealarm_init: timerfd_create failed [ 8.335528@1] init: Could not find service hosting interface vendor.amlogic.hardware.hdmicec@1.0::IDroidHdmiCEC/default [ 8.355812@0] init: Could not find service hosting interface vendor.amlogic.hardware.systemcontrol@1.0::ISystemControl/default [ 8.429141@2] init: Could not find service hosting interface vendor.amlogic.hardware.systemcontrol@1.0::ISystemControl/default [ 8.519461@2] vfm_map_store:rm default [ 8.521327@0] vfm_map_store:add default decoder ppmgr deinterlace amvideo [ 8.545386@0] init: Could not find service hosting interface vendor.amlogic.hardware.hdmicec@1.0::IDroidHdmiCEC/default [ 8.575919@0] init: Could not find service hosting interface vendor.amlogic.hardware.systemcontrol@1.0::ISystemControl/default the package has 87 fws totally. The TA ver is v0.2 The fw ver is v0.2 the fw with 480 KB will be loaded. [ 8.614739@1] init: Subcontext init could not set 'ro.radio.noril' to 'true': Read-only property was already set dmicec@1.0::IDroidHdmiCEC/default [ 8.641382@0] meson-mmc: sdio: resp_timeout,vstat:0xa3ff2800,virqc:3fff [ 8.642358@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8 [ 8.649963@0] meson-mmc: sdio: resp_timeout,vstat:0xa3ff2800,virqc:3fff [ 8.655295@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8 [ 8.666466@0] meson-mmc: sdio: resp_timeout,vstat:0xa3ff2800,virqc:3fff [ 8.668230@0] meson-mmc: sdio: err: wait for irq service, bus_fsm:0x8 [ 8.681930@1] init: Subcontext init could not set 'ro.oem.key1' to 'ATV00104319': Read-only property was already set [ 8.708463@0] init: Could not start service 'factoryreset' as part of class 'main': Cannot find '/vendor/bin/factoryreset.sh': No such file or directory [ 8.905477@2] init: Failed to open file '/d/mmc0/mmc0:0001/ext_csd': No such file or directory [ 8.956764@1] init: Could not start service 'wifi_detect' as part of class 'main': Cannot find '/vendor/bin/sdmc_wifi_detect': No such file or directory [HDCP-TA] read hdcp key(hdcp_tx22.bin) ret = 0xFFFF0008 [HDCP-TA] read hdcp key(hdcp_tx14.bin) ret = 0xFFFF0008 ERROR SECURITY_KEY_READ 1 [HDCP-TA] read hdcp key(hdcp_rx14.bin) ret = 0xFFFF0006 [ 8.721681@1] init: Could not start service 'ir_leds_blink' as part of class 'main': Cannot find '/vendor/bin/ir_blink': No such file or directory [ 8.751238@3] init: couldn't write 3059 to /dev/cpuset/camera-daemon/tasks: No such file or directory [ 6.689845@2] selinux: avc: denied { set } for property=persist.sys.app.rotation pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.689845@2] [ 6.709158@2] init: Unable to set property 'persist.sys.app.rotation' to 'original' in property file '/vendor/build.prop': SELinux permission check failed [ 6.725543@2] init: /recovery not specified in fstab [ 6.977780@2] init: Could not find service hosting interface android.hardware.keymaster@3.0::IKeymasterDevice/default [ 6.983791@2] init: Could not find service hosting interface android.hardware.keymaster@3.0::IKeymasterDevice/default MESSAGE: USER-TA:log_msg:70: KeymasterTA (info): app/ipc/keymaster_ipc.cpp, Line 752: Amlogic KEYMASTER 2.0! Build Time: Jun 19 2018 14:46:55 [ 7.498202@3] init: couldn't write 2976 to /dev/cpuset/camera-daemon/tasks: No such file or directory [ 7.767829@1] init: setpgid failed for console: Operation not permitted [ 7.879853@2] init: Failed to bind socket 'pdx/system/vr/display/client': No such file or directory [ 7.910205@2] init: Failed to bind socket 'pdx/system/vr/display/manager': No such file or directory [ 7.947258@2] init: Failed to bind socket 'pdx/system/vr/display/vsync': No such file or directory console:/ # 6.081330@2] [ 6.099550@2] init: Unable to set property 'persist.sys.dts.edid' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.112706@2] selinux: avc: denied { set } for property=service.bootvideo pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.112706@2] [ 6.131353@2] init: Unable to set property 'service.bootvideo' to '0' in property file '/vendor/build.prop': SELinux permission check failed [ 6.144032@2] selinux: avc: denied { set } for property=libplayer.livets.softdemux pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.144032@2] [ 6.163476@2] init: Unable to set property 'libplayer.livets.softdemux' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 6.176762@2] selinux: avc: denied { set } for property=libplayer.netts.recalcpts pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.176762@2] [ 6.196278@2] init: Unable to set property 'libplayer.netts.recalcpts' to '1' in property file '/vendor/build.prop': SELinux permission check failed [ 6.209516@2] selinux: avc: denied { set } for property=persist.fw.force_adoptable pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.209516@2] [ 6.229021@2] init: Unable to set property 'persist.fw.force_adoptable' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.242651@2] selinux: avc: denied { set } for property=sys.ignore.inativecec pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.242651@2] [ 6.261600@2] init: Unable to set property 'sys.ignore.inativecec' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.274701@2] selinux: avc: denied { set } for property=ro.sys.hdmiin.enable pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.274701@2] [ 6.293739@2] init: Unable to set property 'ro.sys.hdmiin.enable' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.306792@2] selinux: avc: denied { set } for property=mbx.hdmiin.switchfull pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.306792@2] [ 6.325964@2] init: Unable to set property 'mbx.hdmiin.switchfull' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.339174@2] selinux: avc: denied { set } for property=mbx.hdmiin.videolayer pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.339174@2] [ 6.358384@2] init: Unable to set property 'mbx.hdmiin.videolayer' to 'false' in property file '/vendor/build.prop': SELinux permission check failed [ 6.371936@2] selinux: avc: denied { set } for property=ro.com.android.dateformat pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.371936@2] [ 6.391048@2] init: Unable to set property 'ro.com.android.dateformat' to 'MM-dd-yyyy' in property file '/vendor/build.prop': SELinux permission check failed [ 6.405572@2] selinux: avc: denied { set } for property=net.tethering.noprovisioning pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=0 [ 6.405572@2] [ 6.424689@2] init: Unable to set property 'net.tethering.noprovisioning' to 'true' in property file '/vendor/build.prop': SELinux permission check failed [ 6.439214@2] selinux: avc: denied { set } for property=ro.product.firmware pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.439214@2] [ 6.457345@2] init: Unable to set property 'ro.product.firmware' to '00502001' in property file '/vendor/build.prop': SELinux permission check failed [ 6.470652@2] selinux: avc: denied { set } for property=ro.product.otaupdateurl pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.470652@2] [ 6.489927@2] init: Unable to set property 'ro.product.otaupdateurl' to 'http://10.28.11.53:8080/otaupdate/update' in property file '/vendor/build.prop': SELinux permission check failed [ 6.506456@2] selinux: avc: denied { set } for property=ro.treble.enabled pid=1 uid=0 gid=0 scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0 [ 6.506456@2] [ 6.525099@2] init: Unable to set property[ 8.905477@2] ini[ 10.906965@0] cectx c810023c.aocec: init_cec_port_info phy_addr:0, port num:1 [ 10.908545@0] cectx c810023c.aocec: port_seq=0x0 [ 10.913546@0] cectx c810023c.aocec: portinfo id:0 arc:0 phy:1000,type:0 [ 21.907015@3] cectx c810023c.aocec: init_cec_port_info phy_addr:0, port num:1 [ 21.908525@3] cectx c810023c.aocec: port_seq=0x0 [ 21.913196@3] cectx c810023c.aocec: portinfo id:0 arc:0 phy:1000,type:0 Playready TA Start Playready TA Exit! Playready TA_DestroyEntryPoint! OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. set ta time 1777644040 OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. [ 94.217875@0] binder_alloc: 4709: binder_alloc_buf size 1056768 failed, no address space [ 94.221143@0] binder_alloc: allocated: 184 (num: 3 largest: 168), free: 1040200 (num: 1 largest: 1040200) [ 107.113192@0] unifykey: key_unify_init() already inited! [ 107.113771@0] unifykey: name: usid, size 37 [ 107.117434@0] unifykey: key_unify_init() already inited! OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. ----------------------------------------------- End log file This one with the reset button pressed: Terminal log file ----------------------------------------------- OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. [ 428.570277@1] unifykey: key_unify_init() already inited! [ 428.571318@1] unifykey: name: usid, size 37 [ 428.575539@1] unifykey: key_unify_init() already inited! OEMCrypto_GetOEMPublicCertificate: Provisioning method = 2. [ 441.929160@0] unifykey: key_unify_init() already inited! [ 441.929656@0] unifykey: name: usid, size 37 [ 441.933533@0] unifykey: key_unify_init() already inited! GXL:BL1:9ac50e:bb16dc;FEAT:BFFC39BE:100;POC:3;RCY:0;EMMC:0;READ:0;1.0;1.0;CHK:0; TE: 315899 BL2 Built : 10:47:34, Jan 14 2019. gxl g152d217 - guotai.shen@droid11-sz set vcck to 1120 mv set vddee to 1000 mv Board ID = 7 CPU clk: 984MHz DDR enable rdbi DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 912MHz bist_test rank: 0 1b 00 37 2f 14 4a 1e 00 3d 2f 13 4b 28 28 28 28 28 28 28 28 28 29 29 29 693 - PASS Rank0: 1024MB-2T-13 AddrBus test pass! Set ddr ssc: ppm1000- eMMC boot @ 0 sw8 s emmc switch 3 ok BL2: rpmb counter: 0x00000024 emmc switch 0 ok OTP_ARB=00000001 Load FIP HDR from eMMC, src: 0x0000c200, des: 0x01700000, size: 0x00004000, part: 0 Load BL3x from eMMC, src: 0x00010200, des: 0x01704000, size: 0x000f4000, part: 0 NOTICE: BL3-1: v1.0(release):3bc3888 NOTICE: BL3-1: Built : 11:28:51, May 10 2019 [BL31]: GXL CPU setup! NOTICE: BL3-1: GXL secure boot! NOTICE: BL3-1: BL33 decompress pass mpu_config_enable:system pre init ok dmc sec lock MVN_1=0x01010100 MVN_2=0x01010000 [Image: gxl_v1.1.3376-325f6f4 2019-05-27 16:25:06 shen.liu@droid11-sz] OPS=0x34 21 0d 34 00 37 2a 00 89 62 00 ac b5 67 13 99 02 [0.932030 Inits done] secure task start! high task start! low task start! INFO: BL3-2: ATOS-V2.4-239-g48b8c37d #1 Wed Feb 5 09:34:09 UTC 2020 arm INFO: BL3-2: Chip: GXL Rev: D (21:D - 30:2) INFO: BL3-2: crypto engine DMA INFO: BL3-2: secure time TEE INFO: BL3-2: CONFIG_DEVICE_SECURE 0xb200000e U-Boot 2015.01-gb7c1687 (Apr 08 2021 - 22:17:19) DRAM: 1 GiB Relocation Offset is: 36e85000 register usb cfg[0][1] = 0000000037f51148 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000033e856b0 aml_priv->desc_buf = 0x0000000033e879f0 SDIO Port B: 0, SDIO Port C: 1 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 40000000 [mmc_startup] mmc refix success init_part() 297: PART_TYPE_AML [mmc_init] mmc init success Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 start dts,buffer=0000000033e8a240,dt_addr=0000000033e99240 get_partition_from_dts() 71: ret 0 Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 parts: 17 00: logo 0000000000800000 1 01: recovery 0000000001800000 1 02: misc 0000000000800000 1 03: dtbo 0000000000800000 1 04: cri_data 0000000000800000 2 05: param 0000000001000000 2 06: boot 0000000001000000 1 set has_boot_slot = 0 07: rsv 0000000001000000 1 08: metadata 0000000001000000 1 09: vbmeta 0000000000200000 1 10: tee 0000000002000000 1 11: vendor 0000000010000000 1 12: odm 0000000008000000 1 13: system 0000000050000000 1 14: product 0000000008000000 1 15: cache 0000000025000000 2 16: data ffffffffffffffff 4 init_part() 297: PART_TYPE_AML eMMC/TSD partition table have been checked OK! crc32_s:0x1577dad == storage crc_pattern:0x1577dad!!! crc32_s:0xee152b83 == storage crc_pattern:0xee152b83!!! crc32_s:0x7fd3b243 == storage crc_pattern:0x7fd3b243!!! mmc env offset: 0x2c400000 In: serial Out: serial Err: serial reboot_mode=cold_boot itest - return true/false on integer compare Usage: itest [.b, .w, .l, .s] [*]value1 <op> [*]value2 [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-2755: calc f2d3afb4, store f2d3afb4 _verify_dtb_checksum()-2755: calc f2d3afb4, store f2d3afb4 dtb_read()-2972: total valid 2 update_old_dtb()-2953: do nothing Amlogic multi-dtb tool Multi dtb detected checkhw: hwid = 11 Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p241 variant: v2-1g dtb 0 soc: gxl plat: p241 vari: 1g dtb 1 soc: gxl plat: p241 vari: v2-1g Find match dtb: 1 vpu: clk_level in dts: 2 vpu: set clk: 200000000Hz, readback: 200000000Hz(0x501) vpu: vpu_clk_gate_init_off finish vpp: vpp_init cvbs: cpuid:0x21 cvbs: find performance_pal config hpd_state=0 vpp: vpp_matrix_update: 2 cvbs_performance_enhancement cvbs_config_hdmipll_gxl cvbs_set_vid2_clk vdac_enable: 1, module_sel:0x8 Net: dwmac.c9410000amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 CONFIG_AVB2: avb2 Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=2 reboot_mode:::: cold_boot amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x3fc00000 [OSD]load fb addr from dts:/meson-fb [OSD]fb_addr for logo: 0x3fc00000 [OSD]VPP_OFIFO_SIZE:0xfff00fff [CANVAS]addr=0x3fc00000 width=3840, height=2160 [OSD]osd_hw.free_dst_data: 0,719,0,575 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[oemkey] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 0 detect upgrade key gpio: pin GPIOAO_2 (gpio 102) value is 0 InUsbBurn noSof card out co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 [MSG]mmcinfo failed! co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 co-phase 0x2, tx-dly 0, clock 400000 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found [imgread]secureKernelImgSz=0xf14a00 avb2: 1 Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal ab_suffix is avb_slot_verify.c:524: DEBUG: Loading vbmeta struct from partition 'vbmeta'. Verified using testkey [store]To run cmd[emmc dtb_read 0x00000000357695c0 0x40000] dtb_read_shortcut()-2813: short cut in... Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal avb verification: locked = 1, result = 0 ee_gate_off ... avb2: 1 ## Booting Android Image at 0x01080a00 ... reloc_addr =33f0a5a0 copy done Kernel command line: androidboot.dtbo_idx=0 buildvariant=user Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected find 1 dtbos dtbos to be applied: 0 Apply dtbo 0 Uncompressing Kernel Image ... OK kernel loaded at 0x01080000, end = 0x02958a00 libfdt fdt_getprop(): FDT_ERR_NOTFOUND Loading Ramdisk to 338a9000, end 33e729db ... OK Loading Device Tree to 000000001ffee000, end 000000001ffff4ba ... OK fdt_instaboot: no instaboot image Starting kernel ... uboot time: 10673245 us domain-0 init dvfs: 4 efuse_pw_en: 0x17 mgSz=0xf14a00 avb2: 1 Start read misc partition datas! info->magic = info->version_major = 1 info->version_minor = 0 info->slots[0].priority = 15 info->slots[0].tries_remaining = 7 info->slots[0].successful_boot = 0 info->slots[1].priority = 14 info->slots[1].tries_remaining = 7 info->slots[1].successful_boot = 0 info->crc32 = -1075449479 active slot = 0 active_slot is normal ab_suffix is avb_slot_verify.c:524: DEBUG: Loading vbmeta struct from partition 'vbmeta'. [ 0.000000@0] Reserved memory: unable to setup CMA region [ 0.232780@0] VMAP:handle_vmap_fault address ffffff802008c000 out of range [ 0.232811@0] VMAP:handle_vmap_fault PC is:ffffff800923ffac, copy_mount_options, LR is:ffffff800923ff18 copy_mount_options [ 0.232823@0] VMAP:handle_vmap_fault task:32 kdevtmpfs, stack:ffffff8020088000, ffffffc039b4c920 [ 0.292767@0] codec_mm_module_init [ 0.308808@0] clkmsr c110875c.meson_clk_msr: failed to get msr ring reg0 [ 0.318963@0] cvbs_out: chrdev devno 263192576 for disp [ 0.605302@0] dmi: Firmware registration failed. [ 0.609965@0] vout: error: invalid vinfo1. current vmode is not supported [ 1.113429@0] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.136727@0] c81004c0.serial: clock gate not found [ 1.201690@0] c1108700.serial: clock gate not found [ 1.208084@0] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port [ 1.221872@0] meson-remote c8100580.rc: don't find the node <led_blink> [ 1.222855@0] meson-remote c8100580.rc: don't find the node <led_blink_frq> [ 1.242998@0] get fclk_div5 err [ 1.243029@0] vdin_drv_probe: vdin cannot get msr clk !!! [ 1.246410@0] get fclk_div5 err [ 1.249154@0] vdin_drv_probe: vdin cannot get msr clk !!! [ 1.258102@0] amlvideo2 probe called [ 1.258499@0] amlvideo2 probe called [ 1.262238@0] PPMGRDRV: err: ppmgr_driver_probe called [ 1.275314@0] meson-mmc: >>>>>>>>hostbase ffffff800852e000, dmode [ 1.322938@0] meson-mmc: >>>>>>>>hostbase ffffff8008538000, dmode [ 1.364658@0] meson-mmc: >>>>>>>>hostbase ffffff8008584000, dmode [ 1.405674@0] cectx c810023c.aocec: cec driver date:Ver 2019/1/7 [ 1.405674@0] [ 1.408712@0] cectx c810023c.aocec: not find 'port_num' [ 1.413325@0] cectx c810023c.aocec: using cec:0 [ 1.417582@0] cectx c810023c.aocec: get sleep state error! [ 1.423053@0] cectx c810023c.aocec: no hdmirx regs [ 1.427606@0] cectx c810023c.aocec: no hhi regs [ 1.432116@0] cectx c810023c.aocec: no periphs regs [ 1.436874@0] cectx c810023c.aocec: not find 'output' [ 1.446186@0] cectx c810023c.aocec: irq cnt:1 [ 1.447448@0] cectx c810023c.aocec: wakeup_reason:0x0 [ 1.451342@3] cectx c810023c.aocec: cev val1: 0x0;val2: 0x0 [ 1.456741@3] cectx c810023c.aocec: aml_cec_probe success end [ 1.500395@3] defendkey c8834500.defendkey: Reserved memory is not enough! [ 1.508953@3] snd_pcm_dai: aml audio pcm dai pinmux set error! [ 1.510988@3] meson-gxl-pinctrl pinctrl@4b0: pin GPIODV_24 already requested by c1108500.i2c; cannot claim for d0042000.snd_dmic [ 1.520660@3] meson-gxl-pinctrl pinctrl@4b0: pin-73 (d0042000.snd_dmic) status -22 [ 1.528150@3] meson-gxl-pinctrl pinctrl@4b0: could not request pin 73 (GPIODV_24) from group dmic_in_dv24 on device pinctrl-meson [ 1.539787@3] snd_dmic d0042000.snd_dmic: Error applying setting, reverse things back [ 1.547558@3] snd_dmic d0042000.snd_dmic: pinctrls error! [ 1.553602@3] spdif-dit spdif_codec: audio_spdif_out_mute can't get pinctrl [ 1.559899@3] spdif-dit spdif_codec: audio_spdif_in_mute can't get pinctrl [ 1.566611@3] spdif-dit spdif_codec: audio_spdif_in can't get pinctrl [ 1.786402@3] aml_meson_snd_card aml_sound_meson: ASoC: no source widget found for LOUTL [ 1.788912@3] aml_meson_snd_card aml_sound_meson: ASoC: Failed to add route LOUTL -> direct -> Ext Spk [ 1.798095@3] aml_meson_snd_card aml_sound_meson: ASoC: no source widget found for LOUTR [ 1.806104@3] aml_meson_snd_card aml_sound_meson: ASoC: Failed to add route LOUTR -> direct -> Ext Spk [ 2.356007@3] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19) [ 2.357781@3] usb usb2: Unsupported device [ 2.479442@2] thermal: read num_of_pp failed [ 2.774292@2] init: Init cannot set 'ro.boot.selinux' to 'permissive': Read-only property was already set [ 2.778390@2] init: Init cannot set 'ro.boot.selinux' to 'permissive': Read-only property was already set [ 2.807119@2] init: waitid failed: No child processes [ 2.811722@2] init: Unable to set property 'ro.product.first_api_level' to '28' in property file '/prop.default': Read-only property was already set [ 2.822498@2] init: Unable to set property 'ro.treble.enabled' to 'true' in property file '/prop.default': Read-only property was already set [ 2.833683@2] init: Unable to set property 'ro.adb.secure' to '1' in property file '/prop.default': Read-only property was already set [ 2.852316@2] init: Unable to read config file '/system/etc/init': open() failed: No such file or directory [ 2.856701@2] init: Unable to read config file '/product/etc/init': open() failed: No such file or directory [ 2.866440@2] init: Unable to read config file '/odm/etc/init': open() failed: No such file or directory [ 2.875842@2] init: Unable to read config file '/vendor/etc/init': open() failed: No such file or directory [ 2.898792@1] ueventd: Unable to read config file '/vendor/ueventd.rc': open() failed: No such file or directory [ 2.903600@1] ueventd: Unable to read config file '/odm/ueventd.rc': open() failed: No such file or directory [ 2.913543@1] ueventd: Unable to read config file '/ueventd.amlogic.rc': open() failed: No such file or directory [ 3.544760@2] init: setpgid failed for console: Operation not permitted [ 0.000267] Starting recovery (pid 2730) on Sun Jan 1 00:00:14 2017 [ 0.000574] led_ctrl_init in [ 0.000593] recovery filesystem table [ 0.000609] ========================= [ 0.000624] 0 /odm ext4 /dev/block/odm 0 [ 0.000648] 1 /product ext4 /dev/block/product 0 [ 0.000663] 2 /vendor ext4 /dev/block/vendor 0 [ 0.000678] 3 /bootloader emmc /dev/block/bootloader 0 [ 0.000693] 4 /logo emmc /dev/block/logo 0 [ 0.000708] 5 /vbmeta emmc /dev/block/vbmeta 0 [ 0.000723] 6 /recovery emmc /dev/block/recovery 0 [ 0.000738] 7 /boot emmc /dev/block/boot 0 [ 0.000752] 8 /misc emmc /dev/block/misc 0 [ 0.000767] 9 / ext4 /dev/block/system 0 [ 0.000784] 10 /vendor ext4 /dev/block/vendor 0 [ 0.000799] 11 /odm ext4 /dev/block/odm 0 [ 0.000815] 12 /param ext4 /dev/block/param 0 [ 0.000829] 13 /product ext4 /dev/block/product 0 [ 0.000845] 14 /metadata ext4 /dev/block/metadata 0 [ 0.000859] 15 /tee ext4 /dev/block/tee 0 [ 0.000874] 16 /cache ext4 /dev/block/cache 0 [ 0.000889] 17 /data ext4 /dev/block/data 0 [ 0.000904] 18 /sdcard vfat /dev/block/mmcblk1p1 0 [ 0.000919] 19 /sdcard vfat /dev/block/mmcblk1p2 0 [ 0.000933] 20 /sdcard vfat /dev/block/mmcblk1p3 0 [ 0.000948] 21 /sdcard vfat /dev/block/mmcblk1p4 0 [ 0.000962] 22 /sdcard vfat /dev/block/mmcblk1p5 0 [ 0.000977] 23 /sdcard vfat /dev/block/mmcblk1p6 0 [ 0.000992] 24 /sdcard vfat /dev/block/mmcblk2p1 0 [ 0.001007] 25 /sdcard vfat /dev/block/mmcblk2p2 0 [ 0.001021] 26 /sdcard vfat /dev/block/mmcblk2p3 0 [ 0.001035] 27 /sdcard vfat /dev/block/mmcblk2p4 0 [ 0.001054] 28 /sdcard vfat /dev/block/mmcblk2p5 0 [ 0.001070] 29 /sdcard vfat /dev/block/mmcblk2p6 0 [ 0.001085] 30 /sdcard vfat /dev/block/mmcblk 0 [ 0.001099] 31 /udisk auto /dev/block/sd## 0 [ 0.001113] 32 /tmp ramdisk ramdisk 0 [ 0.001127] # [ 3.827385@3] meson-gxl-pinctrl pinctrl@4b0: request() failed for pin 22 [ 3.828453@3] meson-gxl-pinctrl pinctrl@4b0: pin-22 (aml_sound_meson) status -22 [ 3.835813@3] meson-gxl-pinctrl pinctrl@4b0: could not request pin 22 (GPIOH_6) from group i2s_am_clk on device pinctrl-meson [ 3.847090@3] aml_meson_snd_card aml_sound_meson: Error applying setting, reverse things back [ 2.022123] E:failed to mount /udisk (No such file or directory) [ 2.022735] W:try mount /dev/block/mmcblk1p1 ... [ 2.122967] W:try mount /dev/block/mmcblk1p1 ... [ 2.223206] W:try mount /dev/block/mmcblk1p1 ... [ 2.323437] W:try mount /dev/block/mmcblk1p1 ... [ 2.423658] W:try mount /dev/block/mmcblk1p1 ... [ 2.523885] W:try mount /dev/block/mmcblk1p1 ... [ 2.624114] W:try mount /dev/block/mmcblk1p1 ... [ 2.724369] W:try mount /dev/block/mmcblk1p1 ... [ 2.824599] W:try mount /dev/block/mmcblk1p1 ... [ 2.924827] W:try mount /dev/block/mmcblk1p1 ... [ 3.025058] W:try mount /dev/block/mmcblk1p1 ... [ 3.125296] W:try mount /dev/block/mmcblk1p1 ... [ 3.225524] W:try mount /dev/block/mmcblk1p1 ... [ 3.325753] W:try mount /dev/block/mmcblk1p1 ... [ 3.425980] W:try mount /dev/block/mmcblk1p1 ... [ 3.526203] W:try mount /dev/block/mmcblk1p1 ... [ 3.626419] W:try mount /dev/block/mmcblk1p1 ... [ 3.726720] W:try mount /dev/block/mmcblk1p1 ... [ 3.826870] W:try mount /dev/block/mmcblk1p1 ... [ 3.927019] W:try mount /dev/block/mmcblk1p1 ... [ 4.029552] E:failed to mount /sdcard (No such file or directory) [ 4.034195] E:Can't read /cache/recovery/last_locale: No such file or directory[ 7.592926@0] systemcontrol: [ubootenv] upgrade_step is not a ubootenv variable. [ 7.600347@3] selinux: avc: denied { set } for property=const.filesystem.mode pid=2730 uid=0 gid=0 scontext=u:r:recovery:s0 tcontext=u:object_r:aml_display_prop:s0 tclass=property_service permissive=1 [ 7.600347@3] [ 7.619424@3] systemcontrol: /etc/mesondisplay.cfg:12: Expected keyword, got '/etc/mesondisplay.cfg:12'.systemcontrol: getBootEnv key:ubootenv.var.reboot_mode_android value:normalsystemcontrol: reboot_mode :normal [ 4.034322] locale is [en-US] [ 4.034363] stage is [] [ 4.034400] reason is [(null)] [ 7.660021@3] init: No such service 'hdcp_tx22' for ctl.stop [ 7.684027@0] selinux: avc: denied { set } for property=vendor.display-size pid=2730 uid=0 gid=0 scontext=u:r:recovery:s0 tcontext=u:object_r:netflix_prop:s0 tclass=property_service permissive=1 [ 7.684027@0] [ 7.699611@1] selinux: avc: denied { set } for property=persist.vendor.sys.hdr.state pid=2730 uid=0 gid=0 scontext=u:r:recovery:s0 tcontext=u:object_r:vendor_persist_prop:s0 tclass=property_service permissive=1 [ 7.699611@1] [ 5.038907] loaded /etc/recovery.kl [ 5.038964] skipping malformed recovery.lk line: back_door [ 5.038986] recovery key map table: [ 5.039000] 0 type:select value:28 key:97 28 15 158 -1 -1 [ 5.039016] 1 type:down value:108 key:108 114 109 -1 -1 -1 [ 5.039030] 2 type:up value:103 key:103 104 115 -1 -1 -1 [ 5.039045] [ 5.039058] loaded /etc/recovery.kl [ 5.039072] skipping malformed recovery.lk line: back_door [ 5.039087] recovery key map table: [ 5.039101] 0 type:select value:28 key:97 28 15 158 -1 -1 [ 5.039115] 1 type:down value:108 key:108 114 109 -1 -1 -1 [ 5.039130] 2 type:up value:103 key:103 104 115 -1 -1 -1 [ 5.039144] [ 5.039157] W:Failed to read max brightness: No such file or directory [ 5.039172] I:Screensaver disabled [ 5.039186] cannot find/open a drm device: No such file or directory [ 5.039201] fb0 reports (possibly inaccurate): [ 5.039216] vi.bits_per_pixel = 32 [ 5.039230] vi.red.offset = 16 .length = 8 [ 5.039244] vi.green.offset = 8 .length = 8 [ 5.039258] vi.blue.offset = 0 .length = 8 [ 5.074880] framebuffer: 0 (1280 x 720) [ 5.165868] erasing_text: en (47 x 19 @ 700) [ 5.168412] no_command_text: en (83 x 19 @ 700) [ 5.170989] error_text: en (33 x 19 @ 700) [ 5.784010] installing_text: en (156 x 19 @ 700) peed-profile [ 6.509285] pm.dexopt.first-boot=quicken [ 6.509301] ro.adb.secure=1 [ 6.509315] ro.secure=1 [ 6.509329] sys.usb.config=mtp [ 6.509342] sys.usb.configfs=1 [ 6.509357] log.tag.stats_log=I [ 6.509371] ro.logd.size.stats=64K [ 6.509384] ro.af.client_heap_size_kbyte=1536 [ 6.509399] ro.audio.mapvalue=0,0,0,0 [ 6.509413] ro.media.maxmem=419430400 [ 6.509426] ro.media.camera_usb.faceback=false [ 6.509441] ro.media.camera_preview.maxsize=1920x1080 [ 6.509455] ro.media.camera_preview.usemjpeg=1 [ 6.509470] ro.media.camera_preview.limitedrate=1920x1080x30,1280x720x30,640x480x30,320x240x28 [ 6.509485] drm.service.enable=true [ 6.509500] media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm [ 6.509516] media.wfd.use-pcm-audio=false [ 6.509530] media.wfd.video-bitrate=2000000 [ 6.509544] media.wfd.videoframerate=24 [ 6.509558] media.wfd.videoresolution-type=1 [ 6.509572] media.wfd.videoresolution-group=0 [ 6.509586] media.secmem.version=1 [ 6.509600] media.decoder.vfm.defmap=decoder [ 6.509614] media.decoder.vfm.drmmap=decoder [ 6.509628] media.amplayer.enable=true [ 6.509641] media.amplayer.thumbnail=true [ 6.509655] media.amplayer.dropwaitxms=100 [ 6.509669] media.amplayer.seekkeyframe=true [ 6.509683] media.amplayer.dsource4local=1 [ 6.509697] media.amplayer.enable-acodecs=ac3,eac3,rm,dts [ 6.509711] media.amplayer.widevineenable=true [ 6.509725] media.libplayer.seek.fwdsearch=1 [ 6.509740] media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod,bluray_mod [ 6.509755] media.libplayer.curlenable=true [ 6.509769] media.amsuperplayer.enable=true [ 6.509783] media.amsuperplayer.defplayer=PV_PLAYER [ 6.509797] media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER [ 6.509811] media.html5videowin.enable=1 [ 6.509825] persist.vendor.media.bootvideo=0050 [ 6.509839] ro.nrdp.modelgroup=SDMCs805 [ 6.509853] ro.nrdp.validation=ninja_6 [ 6.509867] ro.vendor.nrdp.audio.mixer.buffersize=1024 [ 6.509881] ro.vendor.nrdp.modelgroup=SDMCs805 [ 6.509895] ro.vendor.nrdp.validation=ninja_6 [ 6.509935] vendor.display-size=720x576 [ 6.509951] ro.boot.oem.key1=ATV00104319 [ 6.509965] pm.dexopt.shared=speed [ 6.509979] pm.dexopt.inactive=verify [ 6.509992] ro.boot.serialno=[REDACTED] [ 6.510006] ro.serialno=[REDACTED] [ 6.510020] service.adb.tcp.port=5555 [ 6.510034] security.perf_harden=1 [ 6.510047] net.bt.name=Android [ 6.510061] net.tethering.noprovisioning=true [ 6.510075] sys.fb.bits=32 [ 6.510089] sys.ignore.inativecec=true [ 6.510102] persist.sys.PQ.enable=true [ 6.510116] persist.sys.app.rotation=original [ 6.510130] persist.sys.dts.edid=false [ 6.510144] persist.sys.usb.config=mtp [ 6.510158] service.bootvideo=0 [ 6.510172] ro.vendor.app.optimization=true [ 6.510185] ro.vendor.vndk.version=26.1.0 [ 6.510199] ro.vendor.build.version.nts_patch=2019-10-17 [ 6.510214] ro.vendor.product.cpu.abilist=armeabi-v7a,armeabi [ 6.510228] ro.vendor.product.cpu.abilist32=armeabi-v7a,armeabi [ 6.510243] ro.vendor.product.cpu.abilist64= [ 6.510257] ro.vendor.autoconnectbt.isneed=false [ 6.510271] ro.vendor.autoconnectbt.btclass=50c [ 6.510285] ro.vendor.autoconnectbt.macprefix=00:CD:FF [ 6.510299] ro.vendor.autoconnectbt.rssilimit=70 [ 6.510314] ro.vendor.autoconnectbt.nameprefix=Amlogic_RC [ 6.510328] vendor.omx.osd_maxwidth=1280 [ 6.510342] vendor.omx.osd_maxheight=720 [ 6.510356] vendor.bluetooth.enable_timeout_ms=11000 [ 6.510370] persist.vendor.rtkbt.bdaddr_path=none [ 6.510384] persist.vendor.bluetooth.rtkcoex=true [ 6.841642] persist.vendor.bluetooth.prefferedrole=master [ 6.841670] persist.vendor.rtkbtadvdisable=false [ 6.841686] persist.vendor.sys.hdr.state=2 [ 6.841701] persist.vendor.sys.sdr.state=0 [ 6.841715] ro.vendor.platform.is.tv=0 [ 6.841729] ro.vendor.platform.is.supportHDR=false [ 6.841743] ro.vendor.platform.has.mbxuimode=true [ 6.841757] ro.vendor.platform.has.realoutputmode=true [ 6.841772] ro.vendor.platform.hdmi.device_type=4 [ 6.841786] ro.vendor.platform.need.display.hdmicec=true [ 6.841800] ro.vendor.platform.disable.audiorawout=false [ 6.841814] ro.vendor.platform.support.4k=false [ 6.841829] ro.vendor.platform.support.dts=true [ 6.841843] ro.vendor.platform.support.dolby=true [ 6.841857] ro.vendor.build.security_patch= [ 6.841871] ro.crypto.volume.filenames_mode=aes-256-cts [ 6.841885] [ 6.841898] Supported API: 3 [ 6.841912] #####bootable/recovery/recovery.cpp main 1791 [ 6.841970] #####bootable/recovery/recovery.cpp recopy_update_package 1538 fopen /cache/recovery/backup failed! (No such file or directory) [ 6.841989] #####bootable/recovery/recovery.cpp main 1795 update_package:(null) [ 6.842005] I:Saving locale "en-US" [ 6.509301] ro.adb.secure=1 [ 6.509315] ro.secure=1 [ 6.509329] sys.usb.config=mtp [ 6.509342] sys.usb.configfs=1 [ 6.509357] log.tag.stats_log=I [ 6.509371] ro.logd.size.stats=64K [ 6.509384] ro.af.client_heap_size_kbyte=1536 [ 6.509399] ro.audio.mapvalue=0,0,0,0 [ 6.509413] ro.media.maxmem=419430400 [ 6.509426] ro.media.camera_usb.faceback=false [ 6.509441] ro.media.camera_preview.maxsize=1920x1080 [ 6.509455] ro.media.camera_preview.usemjpeg=1 [ 6.509470] ro.media.camera_preview.limitedrate=1920x1080x30,1280x720x30,640x480x30,320x240x28 [ 6.509485] drm.service.enable=true [ 6.509500] media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma,wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm,aac_latm,rm [ 6.509516] media.wfd.use-pcm-audio=false [ 6.509530] media.wfd.video-bitrate=2000000 [ 6.509544] media.wfd.videoframerate=24 [ 6.509558] media.wfd.videoresolution-type=1 [ 6.509572] media.wfd.videoresolution-group=0 [ 6.509586] media.secmem.version=1 [ 6.509600] media.decoder.vfm.defmap=decoder [ 6.509614] media.decoder.vfm.drmmap=decoder [ 6.509628] media.amplayer.enable=true [ 6.509641] media.amplayer.thumbnail=true [ 6.509655] media.amplayer.dropwaitxms=100 [ 6.509669] media.amplayer.seekkeyframe=true [ 6.509683] media.amplayer.dsource4local=1 [ 6.509697] media.amplayer.enable-acodecs=ac3,eac3,rm,dts [ 6.509711] media.amplayer.widevineenable=true [ 6.509725] media.libplayer.seek.fwdsearch=1 [ 6.509740] media.libplayer.modules=vhls_mod,dash_mod,curl_mod,prhls_mod,vm_mod,bluray_mod [ 6.509755] media.libplayer.curlenable=true [ 6.509769] media.amsuperplayer.enable=true [ 6.509783] media.amsuperplayer.defplayer=PV_PLAYER [ 6.509797] media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER [ 6.509811] media.html5videowin.enable=1 [ 6.509825] persist.vendor.media.bootvideo=0050 [ 6.509839] ro.nrdp.modelgroup=SDMCs805 [ 6.509853] ro.nrdp.validation=ninja_6 [ 6.509867] ro.vendor.nrdp.audio.mixer.buffersize=1024 [ 6.509881] ro.vendor.nrdp.modelgroup=SDMCs805 [ 6.509895] ro.vendor.nrdp.validation=ninja_6 [ 6.509935] vendor.display-size=720x576 [ 6.509951] ro.boot.oem.key1=ATV00104319 [ 6.509965] pm.dexopt.shared=speed [ 6.509979] pm.dexopt.inactive=verify [ 6.509992] ro.boot.serialno=[REDACTED] [ 6.510006] ro.serialno=[REDACTED] [ 6.510020] service.adb.tcp.port=5555 [ 6.510034] security.perf_harden=1 [ 6.510047] net.bt.name=Android [ 6.510061] net.tethering.noprovisioning=true [ 6.510075] sys.fb.bits=32 [ 6.510089] sys.ignore.inativecec=true [ 6.510102] persist.sys.PQ.enable=true [ 6.510116] persist.sys.app.rotation=original [ 6.510130] persist.sys.dts.edid=false [ 6.510144] persist.sys.usb.config=mtp [ 6.510158] service.bootvideo=0 [ 6.510172] ro.vendor.app.optimization=true [ 6.510185] ro.vendor.vndk.version=26.1.0 [ 6.510199] ro.vendor.build.version.nts_patch=2019-10-17 [ 6.510214] ro.vendor.product.cpu.abilist=armeabi-v7a,armeabi [ 6.510228] ro.vendor.product.cpu.abilist32=armeabi-v7a,armeabi [ 6.510243] ro.vendor.product.cpu.abilist64= [ 6.510257] ro.vendor.autoconnectbt.isneed=false [ 6.510271] ro.vendor.autoconnectbt.btclass=50c [ 6.510285] ro.vendor.autoconnectbt.macprefix=00:CD:FF [ 6.510299] ro.vendor.autoconnectbt.rssilimit=70 [ 6.510314] ro.vendor.autoconnectbt.nameprefix=Amlogic_RC [ 6.510328] vendor.omx.osd_maxwidth=1280 [ 6.510342] vendor.omx.osd_maxheight=720 [ 6.510356] vendor.bluetooth.enable_timeout_ms=11000 [ 6.510370] persist.vendor.rtkbt.bdaddr_path=none [ 6.510384] persist.vendor.bluetooth.rtkcoex=true [ 6.841642] persist.vendor.bluetooth.prefferedrole=master [ 6.841670] persist.vendor.rtkbtadvdisable=false [ 6.841686] persist.vendor.sys.hdr.state=2 [ 6.841701] persist.vendor.sys.sdr.state=0 [ 6.841715] ro.vendor.platform.is.tv=0 [ 6.841729] ro.vendor.platform.is.supportHDR=false [ 6.841743] ro.vendor.platform.has.mbxuimode=true [ 6.841757] ro.vendor.platform.has.realoutputmode=true [ 6.841772] ro.vendor.platform.hdmi.device_type=4 [ 6.841786] ro.vendor.platform.need.display.hdmicec=true [ 6.841800] ro.vendor.platform.disable.audiorawout=false [ 6.841814] ro.vendor.platform.support.4k=false [ 6.841829] ro.vendor.platform.support.dts=true [ 6.841843] ro.vendor.platform.support.dolby=true [ 6.841857] ro.vendor.build.security_patch= [ 6.841871] ro.crypto.volume.filenames_mode=aes-256-cts [ 6.841885] [ 6.841898] Supported API: 3 [ 6.841912] #####bootable/recovery/recovery.cpp main 1791 [ 6.841970] #####bootable/recovery/recovery.cpp recopy_update_package 1538 fopen /cache/recovery/backup failed! (No such file or directory) [ 6.841989] #####bootable/recovery/recovery.cpp main 1795 update_package:(null) [ 6.842005] I:Saving locale "en-US" 6.177150] ro.product.manufacturer=Amlogic [ 6.177164] ro.baseband=unknown [ 6.177178] ro.bootmode=unknown [ 6.177191] ro.hardware=amlogic [ 6.177205] ro.revision=0 [ 6.177219] ro.bootimage.build.date=Wed Mar 31 21:18:16 CST 2021 [ 6.177233] ro.bootimage.build.date.utc=1617196696 [ 6.177248] ro.bootimage.build.fingerprint=Amlogic/curie/curie:9/PI/20210331:user/release-keys [ 6.177263] ro.bootloader=unknown [ 6.177277] ro.debuggable=0 [ 6.177291] ro.property_service.version=2 [ 6.177305] sys.usb.state=mtp [ 6.177318] sys.usb.controller=c9100000.dwc2_a [ 6.177332] persist.sys.hdmi.keep_awake=false [ 6.177346] persist.sys.media.avsync=true [ 6.177360] persist.sys.dalvik.vm.lib.2=libart.so [ 6.177375] ro.sf.lcd_density=213 [ 6.177389] ro.sf.disable_triple_buffer=1 [ 6.177402] ro.boot.wificountrycode=XZ [ 6.177416] ro.hdmi.device_type=4 [ 6.177430] ro.radio.noril=false [ 6.177444] ro.zygote=zygote32 [ 6.177457] ro.opengles.version=131072 [ 6.177471] drm.service.enabled=1 [ 6.177485] camera.disable_zsl_mode=1 [ 6.177499] ro.config.low_ram=false [ 6.177513] ro.dalvik.vm.native.bridge=0 [ 6.177526] dalvik.vm.isa.arm.variant=cortex-a9 [ 6.177540] dalvik.vm.isa.arm.features=default [ 6.177555] dalvik.vm.dexopt.secondary=true [ 6.177569] dalvik.vm.usejit=true [ 6.177582] dalvik.vm.heapsize=384m [ 6.177596] dalvik.vm.dex2oat-Xms=64m [ 6.177610] dalvik.vm.dex2oat-Xmx=512m [ 6.177624] dalvik.vm.heapmaxfree=8m [ 6.177637] dalvik.vm.heapminfree=512k [ 6.177651] dalvik.vm.heapstartsize=8m [ 6.177665] dalvik.vm.appimageformat=lz4 [ 6.177679] dalvik.vm.usejitprofiles=true [ 6.177693] dalvik.vm.heapgrowthlimit=256m [ 6.177707] dalvik.vm.stack-trace-dir=/data/anr [ 6.177721] dalvik.vm.image-dex2oat-Xms=64m [ 6.177735] dalvik.vm.image-dex2oat-Xmx=64m [ 6.177749] dalvik.vm.heaptargetutilization=0.75 [ 6.177763] ro.boot.fake_battery=42 [ 6.177777] ro.vndk.version=28 [ 6.177790] ro.board.platform=gxl [ 6.177804] ro.vendor.build.date=Wed Mar 31 21:18:16 CST 2021 [ 6.177819] ro.vendor.build.date.utc=1617196696 [ 6.177833] ro.vendor.build.fingerprint=Amlogic/curie/curie:9/PI/20210331:user/release-keys [ 6.177848] ro.carrier=unknown [ 6.177862] ro.product.cpu.abilist32=armeabi-v7a,armeabi [ 6.177876] ro.product.cpu.abilist64= [ 6.177890] ro.product.board=curie [ 6.177904] ro.product.vendor.name=curie [ 6.177918] ro.product.vendor.brand=Amlogic [ 6.177932] ro.product.vendor.model=curie [ 6.177946] ro.product.vendor.device=curie [ 6.177960] ro.product.vendor.manufacturer=Amlogic [ 6.177974] ro.product.first_api_level=28 [ 6.177988] wifi.direct.interface=p2p0 [ 6.178002] wifi.interface=wlan0 [ 6.178016] ro.build.fingerprint=Amlogic/curie/curie:9/PI/20210331:user/release-keys [ 6.178030] pm.dexopt.boot=verify [ 6.178044] pm.dexopt.ab-ota=speed-profile [ 6.178058] pm.dexopt.install=speed-profile ----------------------------------------------- End log file
ok so here's what I did: git clone https://github.com/armbian/build cd build ./compile.sh BOARD=rock-5t BRANCH=current kernel-patch edited build/cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dts ended up with: /home/marv/rock5t/build/output/patch/kernel-rockchip64-current.patch cp output/patch/kernel-rockchip64-current.patch userpatches/kernel/rockchip64-current/ ./compile.sh BOARD=rock-5t BRANCH=current RELEASE=trixie kernel-dtb copied the new cache/sources/linux-kernel-worktree/6.18__rockchip64__arm64/arch/arm64/boot/dts/rockchip/rk3588-rock-5t.dtb over to my Rock5t /boot/dtb/rockchip/ folder, rebooted it, nothing changed, no 2ed nic. https://paste.armbian.com/muwoxuqoza kernel-rockchip64-current.patch
@Nick A Awesome!
Hello. I'm trying to run Armbian on an Acemak KII TV box (Amlogic S812 processor). From the page https://armbian.com/boards/aml-s805-mxq I downloaded the Armbian image Armbian_community_26.2.0-trunk.792_Aml-s805-mxq_trixie_current_6.12.28_minimal.img Using Win32DiskImager, I burned the Armbian image to a MicroSD card. In the armbianEnv.txt file, in the dtb_file line, I specified the path: dtb_file=/dtb/meson8m2-mxiii-plus.dtb I inserted the MicroSD card into the TV box. The TV box boots, Ethernet works, but there is no HDMI signal on the monitor. I tried specifying different dtb file variants in armbianEnv.txt. I found that if I specify the path dtb_file=/dtb/ meson8b-mxq.dtb , HDMI works (the console is displayed), but Ethernet doesn't. I decompiled the meson8b-mxq.dtb and meson8m2-mxiii-plus.dtb files, but I can't combine the files so that both Ethernet and HDMI work. I've attached the decompiled files. Please help me prepare a combined .dtb file meson8m2-mxiii-plus.dts meson8b-mxq.dts
Composite TV OUT WORKING in Orange Pi One H3, 6.12 current
Error1429 replied to Error1429's topic in Orange Pi One
In case someone finds this useful, I found a way to change the display mode from NTSC (default) to PAL NTSC to PAL: xrandr --output Composite-1 --set "TV mode" PAL xrandr --output Composite-1 --mode 720x576i PAL to NTSC: xrandr --output Composite-1 --set "TV mode" NTSC xrandr --output Composite-1 --mode 720x480i I thought I would have to recompile the whole kernel because the patch isn't working properly but these two commands did the trick. I don't know how to make this permanent but it works in the terminal. -
At the very end of each compile.sh run there is a "curl" command which allows to upload the full build log to a paste service. This can also be done automatically by adding "SHARE_LOG=yes" to the command line. The URL is present at the very end of the process.
I tried logging it but doing a `|grep` or any `> file.log` to `./compile.sh` and the script DOES NOT like it. I had to CTRL+C out of the compile to get that log... it seems to build the dtb's at the beginning of the compilation (good thing for me)
