Ah, I think I know why I didn't 'find' it - trying to run the command as regular user didn't work since it's in /usr/sbin and this path has been removed from the $PATH of regular users. I need to be root in order to have it available. @Werner thank you again for the pointer.
Rob Mills replied to Sancho's topic in Rockchip CPU Boxes
Hi guys, I too have one of these paperweights I'd like to use for a real HA instance to have as a backup if my actual server takes a dump. I was hoping for root access as I'm not a novice when it comes to custom bootloader and roms on other devices but this is a whole different monster. Any tips would be appreciated. - Yesterday
Blind55 replied to Blind55's topic in NanoPi R6S/R6C
Just as an update, for anyone who cares. The above setup worked well, but I couldn't help but attempting to get video hardware acceleration in a browser. Since my post above, Armbian support for the Nanopi R6S went platinum (thanks to @Efe Çetin), kernel 7 came out and mesa 26 should provide all that is needed for vaapi/v4l2 support in firefox. Unfortunately, minimal Armbian Debian with kernel 7 combined with mesa 26 looks to be some time away - that would allow me to run sway, and likely with firefox using video decode acceleration. OTOH, vendor kernel at 6.1 doesn't seem to allow sway to run at all. So I tried Armbian Debian 13 minimal with kernel 6.18, which runs sway just fine, but the mesa version is stuck at 25.2 which in the standard Debian package does not by default support the rockchip hardware yet, I think. In addition, there seems to be some incompatibility with the repository provided here (or I am doing something wrong, which I wouldn't deny). Fortunately, looking at the Armbian git files I saw that the standard Armbian Ubuntu Noble with vendor 6.1 and Gnome (KDE version doesn't run well) appears to a) work fine with wayland, and b) automatically uses the Amazingfate (liujianfeng1994) PPA. This provides chromium with video hardware decode support, and I can still set up jellyfin. So at this point, without having to compile everything myself from scratch, this is the best setup from my perspective. Shout out to @Efe Çetin for making it this convenient - which it truly is, even though Gnome isn't my preferred DM. -
armbianmonitor picks up the wrong temperature to show as "Tcpu". 19:40:09 1600/1600 MHz 0.63 12% 0% 12% 0% 0% 0% 34.9 °C 0/1 19:40:14 1600/1600 MHz 0.66 12% 0% 12% 0% 0% 0% 34.9 °C 0/1 19:40:19 614/ 614 MHz 0.60 5% 0% 4% 0% 0% 0% 34.9 °C 0/1 19:40:24 614/ 614 MHz 0.56 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:29 614/ 614 MHz 0.51 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:34 614/ 614 MHz 0.55 1% 0% 0% 0% 0% 0% 34.9 °C 0/1 19:40:39 1000/1000 MHz 0.51 3% 1% 1% 0% 0% 0% 34.9 °C 0/1 19:40:44 614/ 614 MHz 0.47 0% 0% 0% 0% 0% 0% 34.9 °C 0/1 Time CPU_cl0/CPU_cl1 load %cpu %sys %usr %nice %io %irq Tcpu C.St. 19:40:49 1600/1600 MHz 0.51 12% 3% 8% 0% 0% 0% 34.9 °C 0/1 19:40:54 1600/1600 MHz 0.55 15% 4% 10% 0% 0% 0% 34.9 °C 0/1 19:41:00 1600/1600 MHz 0.58 15% 4% 10% 0% 0% 0% 34.9 °C 0/1 19:41:05 1600/1600 MHz 0.70 15% 4% 10% 0% 0% 0% 34.9 °C 0/1^C Meanwhile in 'sensors': cluster1_thermal-virtual-0 Adapter: Virtual device temp1: +45.0°C nvme-pci-10100 Adapter: PCI adapter Composite: +34.9°C (low = -40.1°C, high = +119.8°C) (crit = +129.8°C) Sensor 1: +42.9°C (low = -40.1°C, high = +139.8°C) Sensor 2: +34.9°C (low = -40.1°C, high = +119.8°C) cluster0_thermal-virtual-0 Adapter: Virtual device temp1: +45.0°C So it shows the NVMe SSD temperature instead.
I have a Orange Pi Zero2W with Armbian. I flashed a SD-card, and then I copy the system and boot to a usb- hdd (sda) and the system boot to sda Want hdd because It write much data and USB 2 don't take mush more speed. But I get a warning about a file-error or something so I run fsck on sda(hdd) that was a systemdisk, but when I run I choose to do it read-only, but anyway it does not boot any more. I think I can take the usb-hdd and run fsck from another computer? I have one system with Ubuntu on a Intel 6 gen, and Raspberry pi 500 and 5. The Pi-machine have raspberry-pi OS and the other Ubuntu 24.04.Does the machine or system have any significans? Or is there another fix to fix so the /boot on SD-card can find sda on USB? /Cheers /Edit. I posted under Orange Pi Zero2, but that was wrong place, and get moved, but at the same time get my thread classed as solved, but the solving was just to get the question on right place. I have also cleared my question a little bit and I can not take away the other.
Thanks Nick A for the A7S image! I've been trying out v0.6.4 using Sway on top of the server image w/ a pair of Viture Luma Pro AR glasses as a display. A few things I noticed: - It seems like a display needs to be plugged in at some point during boot for DP to work, but can be unplugged and replugged afterwards without breaking anything. I'd guess that this is the same issue @qq20739111 noted. - Audio over DP doesn't seem to work, and I don't see any sinks available through pactl. Fwiw, I've at least verified DP audio to work on the vendor image, and Bluetooth audio to work on this one. If it'd be useful, here are some boot logs taken over UART: DP plugged in at boot, display output works - https://paste.armbian.eu/vuvoyufuto.yaml DP plugged in after boot finished, no display output - https://paste.armbian.eu/ohoqorupiy.yaml
Fsck system fs read-only, but don't boot
Johan Nilsson replied to Johan Nilsson's topic in Allwinner sunxi
Off course do I have Orange Pi Zero2W, as I wrote in the beginning, but I thougt there also was an 2E verion and thoungt that orange pi zero 2 was a "over group" with only diffence ethernet and wifi. -
I started to have similar issue with recent rolling release (after 26.2.1) mainline kernels: 6.18.2x, 7.0.x, 7.1.0-rc. https://paste.armbian.com/yobewudugo The log seems having all previous boot logs of this board and 6.18.10, 6.18.8 and 6.1.115 can enumerate NVMe SSD but others can't. I did a PCI rescan with 7.1.0-rc2 after booting the board and NVMe SSD was found and corresponding kernel log can be found in the 1st kernel log. I have Armbian image on SD card, btw. sudo bash -c "echo 1 > /sys/bus/pci/rescan"
There is no such device. The only device with E and W suffix I know exist are the Radxa Zero 3W and 3E. Double-check what hardware you actually have.
Sorry. I thought opiZero2 was booth opiZero2W and 2E. -
No, probably not. CI takes days to catch up. Best is to use the build framework to create an up-to-date image/kernel This happens automatically after a few days.
It should be available on any armbian installation oob. You can also get it here: https://github.com/armbian/build/blob/main/packages/bsp/common/usr/sbin/armbian-add-overlay
this is my [fix plan](https://github.com/icecreamzhao/rock5b-plus-fan-fix)
@humanus I thought Nick was referring to version 6.6, but I must have misunderstood. Since I knew 6.18 was still in development, I assumed he meant 6.6. Turns out he was actually talking about 6.18.
Hello everyone, I urgently need help, as I am on the verge of throwing my Khadas out the window. I bought a used Khadas Vim3L HTPC Kit (S905D3) and want to use it for Navidrome and Audiobookshelf. The FLAC files are located on an external 2.5" WD Elements hard drive, first I intended to format this hard drive to ext4 and set it up in the setup process but it doesnt work and the first thing now is to setup the system,i will add the hd later. Currently, the Vim boots into CoreELEC (which appears to be installed on the internal storage of the vim). Im a total noob and thats my first vim / Board. I just can't seem to get it to work; no matter what I do, it always boots into CoreELEC. I have flashed the recommended Debian 13 (Trixie) → Minimal / CLI image (Armbian_25.11.1_Khadas-vim3l_trixie_current_6.12.58_minimal.oowow.img.xz) using balenaEtcher—onto two different SD cards as well as a USB stick, and I am attempting to boot from them. I have tried various key combinations, but nothing works. For example, when I attempt the method suggested by ChatGPT: Recovery Button Method Unplug the power supply Insert the SD card Hold down the FUNCTION button Briefly press RESET Continue holding the FUNCTION button for another 2–3 seconds I briefly see the Khadas logo, and then it reboots; this process then gets stuck in a loop. I tried using three different power adapters and usb-c cables, thinking that might be the issue... but it was always the same result. I tried a different SD card and various USB sticks and different formats always the same outcome. As a test, I even selected a different image just to see if it would progress any further, but again, I just saw the Khadas logo followed by a boot loop. As soon as I remove the SD card or USB stick, it boots back into CoreELEC from the internal storage. Now I’ve read on another site that I shouldn't use BalenaEtcher, but instead format the SD card/USB stick to FAT32 and place the image in the root directory. I did exactly that and tested it on both the USB 3.0 and 2.0 ports and with the SD because it boots before usb ?!?. Then: disconnect the power supply. Insert the USB stick. Connect HDMI + keyboard. Hold down the FUNCTION button. Plug in the power supply. Immediately press RESET briefly. Continue holding FUNCTION for another 3–5 seconds. And once again, I only see the Khadas logo for a sec and am stuck in a boot loop. Could someone please give me a direct link or the name of the correct image, and tell me the right key combination I need to press or let me know what I'm doing wrong? A step by step guide for an idiot would be great and sorry if the question is stupid, i watched youtube videos, read in the forum etc. but i dont get it, i need really your help. Thank you
@ebin-dev good idea, I can try that. For the moment I seem to have a stable system running 25.11.2 with the 6.12.58 kernel and the l2-cache and op1-opp patches loaded as kernel overlays. My use case for the Helios64 is as a NAS with OMV8 and ZFS. Who is the maintainer of this board now ? I'm happy to test images on my hardware and it would be good if the latest builds worked out of the gate without having to patch them.
@Werner The overlay solution worked - thank you ! Is armbian-add-overlay a separate package/command ? I managed to enable it by creating a rockchip-rk3588-usb-host.dts file in the /boot//dtb-7.0.5-edge-rockchip64/rockchip/overlay folder, compiling it to ockchip-rk3588-usb-host.dtbo with the device tree compiler (dtc) and then using armbian-config to enable the loading of the usb-host overlay.
I have just cleaned-up / changed (again) things w.r.t. network names for my Nanopi-R6C. Same as Nanopi-R4S, it has 'wan' and 'lan', where wan is on-chip ethernet and lan is external PCIe connected. Double check for the R4S, but I am almost sure. So a mainline kernel in principle just numbers them eth<x> depending on timing and other things. New kernel behavior is that the on-chip gets named end0 and for my Nanopi-R6C the external gets named enP3p49s0, as that represents how it is HW connected via PCI-e. That is 7.0.<x-flavor> generic distro kernel. Then Armbian has 2 udev rules to rename to wan? and lan?. That is where the problem was and is for me as I use various different bootloader/firmware. I removed those udev rules as I run standard main distros as well and I need the names for bridges and vlans etc future proof and I don't care about names wan and lan (not using it as router). But if you want to keep that naming, check bootloader version (U-Boot I guess for you) and also udev rules and maybe other patches for RK3399 and/or R4S.
@Werner Do you think Armbian Edge with Linux 7.1 is available and works on OrangePI RV2 already? If so I'd love to get that image. As I understand it the SoC's support has been fully mainlined in Linux 7. (By the way request to admin to lift my messaging quota. Will edit this request away in a few hours.) I just checked inside Armbian Imager, and Armbian Edge is not available there - the same two images as are on https://armbian.com/boards/orangepirv2 are in there, that's all.
Support for 7.1 has been merged yesterday https://github.com/armbian/build/pull/9784
I verified the overlay above working with diy kernel 7.1.0-rc1 and kernel 6.18.10 from apt repo.
@sven-ola Hi sven-ola! Thanks a ton for making RV2 work on Armbian! I'll go about trying to make an RV2 start for the first time shortly. Interfacing it via the serial port is fine, and equally fine is connecting it via HDMI and USB to screen and keyboard, right? As for boot media, will booting the Armbian Debian image from a USB storage device work out of the box or must I install some image on an onboard flash chip first, if so what's the URL to that? And then: Do you think it makes any sense for me to use the Armbian Edge which has kernel 6.19 right now, does it seem stable? If so can you provide an URL to it (upload it on armbian.org or mega.nz etc.) On SpaceMIT's mainlining page https://github.com/spacemit-com/linux/wiki#user-content-K1_SoC I see that the PCI support got an update in 6.19, would this be a reason to use Armbian Edge. This URL is linked: https://lore.kernel.org/all/20251013153526.2276556-1-elder@riscstar.com/ . I have no idea if this update has been backported to the 6.18 kernel used. The 6.19 and 6.18 kernels used, where are they taken from actually? At least for 6.18 I think the repo is https://github.com/jmontleon/linux-spacemit/ or https://github.com/spacemit-com/linux-k1x , do you use it? And for clarity, there is no Armbian with Linux 7.1 yet right? Otherwise just downloading the Armbian with 6.18 from https://armbian.com/boards/orangepirv2 . For CLI and packages and no desktop, the Debian flavour is preferable I guess. At this point do you think PCI and USB interfaces are stable in Armbian or Armbian Edge? Thanks!
OK, I checked and the USB port is already set to host: The USB-A port is still not functional, but - as said in my previous reply - the USB-C port is working fine.
