  2. And how to compile openvfd with this patch? How to apply this patch to openvfd?
  3. Not supported by forum software. Keeping Facebook and Google operational requires constant attention and adjustement, while others worked so far without troubles.
  4. Added instructions for joining your home lab: https://docs.armbian.com/WifiPerformance/#adding-a-new-device
  5. Hi and thank you for the advice. The USB end of the dongle goes to my desktop PC. I compared the time stamps of the last issue and found that the PC was actually switched off during the last issue, having been switched on 10 minutes after the last sysrq log entry. So for the moment I will watch the findings of auditd, although the startup msgs from yesterday looked somewhat suspicious (?): 2025-06-23T18:23:09.799581+02:00 bananapipro2 systemd[1]: Starting auditd.service - Security Auditing Service... 2025-06-23T18:23:09.910646+02:00 bananapipro2 auditd[18408]: Audit daemon is low on disk space for logging 2025-06-23T18:23:09.911684+02:00 bananapipro2 auditd[18408]: Audit daemon is suspending logging due to low disk space. 2025-06-23T18:23:09.912308+02:00 bananapipro2 auditd[18408]: No plugins found, not dispatching events 2025-06-23T18:23:09.917468+02:00 bananapipro2 auditd[18408]: Init complete, auditd 3.0.9 listening for events (startup state enable) 2025-06-23T18:23:10.181350+02:00 bananapipro2 systemd[1]: Started auditd.service - Security Auditing Service. Greetings.
  6. That should make it. You can always try to see if it works and search online if not.
  7. Is it enough to remove these entries from the dts file and recompile it to dtb? 3535-3540 openvfd { compatible = "open,vfd"; dev_name = "openvfd"; status = "okay"; phandle = <0x143>; }; 4031 openvfd = "/openvfd"; meson-sm1-x96-air-gbit.dts
  8. But how do I do that? These are the original Armbian .dtb entries. I didn't add anything and I don't know how to remove it.
  9. Armbian_25.2.2_Rock-5-itx_noble_vendor_6.1.99_gnome_desktop.img.xz I first tried this, as it was the first version offered at the top of the page. No matter what I tried, sound would *not* work. Not speakers, not HDMI, nada, zip. I then started trying earlier versions further down the page. Armbian_25.2.2_Rock-5-itx_bookworm_vendor_6.1.99_cinnamon-backported-mesa_desktop.img.xz And this one, sound *did* work, at least through the speaker jack anyway, but I suspect HDMI would too. I'm really suspecting something kernel related is going here (that "Rockchip BSP" note right above it makes me suspect that). In any case, I'd like to use the kernel where sound is working and put a gnome shell in front of it. Which I take means digging into the build system for armbian? I can figure that out on my own but before I get started on that, what I'm looking for from the forumistas, is an indication of which specific kernel I need to use to make sure sound works. What do I need to make sure to specify so I get the behavior of that second install that worked? And Cinnamon may be better or something, but gnome is what I'm used to.
  10. Hi team, You’re invited to our bi-weekly Armbian Newsletter coordination meeting. This meeting is open to anyone helping with the newsletter or interested in contributing in the future. We’ll be discussing how to: Strengthen the newsletter process and impact Expand our contributor base (occasional authors, vendors, community voices) Improve the flow of raw content from developers Get better feedback from readers Make sure the publishing process runs smoothly We're especially looking for: New ideas to make the newsletter more useful and engaging Someone to take on reviewing and approving the first draft before publication (Igor would like to delegate this going forward) Meeting Details When: [07/02/2025 @ 11am EST] Where: [DISCORD Armbian server: Lounge] Duration: ~45 minutes Frequency: Every two weeks
  11. FYI. HDMI out is broken on those board at the moment. Try to access the board remotely. We don't have people to maintain those old boards.
  12. I've noticed some other threads about Banana Pi builds not booting. I tried the 6.12v built on Jun 19 and that's when my device stopped booting. It won't even power on. I suspect the firmware update is corrupting the MicroSD card. I originally had an older build running and ran an update/upgrade and my system wouldn't boot (won't power on) after that. I purchased a new MicroSD card, and my system booted with an older build. Not realizing my MicroSD would get corrupted, I tried updating/upgrading again and I'm back to not booting. I don't have enough MicroSD cards to pinpoint the exact package. My working build is from 6.6.17, 24.5.0-trunk.58. It appears the archive is even older than that! Is there any way to revive a MicroSD card? I'm using SDFormatter to prep the card and Win32DiskImager to write the image.
  13. Your commands looks ok, but you need to use hk1-x3, not hk1-box Your runtime device-tree do contains the display-controller under /proc/device-tree/i2c-display. So your correctly copying your dtb, but device-tree/i2c-display/sda-gpios and device-tree/i2c-display/scl-gpios shows pin of hk1-box, not hk1-x3. You also need to remove any references to OpenVFD from your device tree. This will create conflicts if you have multiple nodes using the same pins. Your dmesg also has some messages about the i2c bus on which is connected your display controller: [ 3.787786] gpio-576 (sda): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 3.792897] gpio-577 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file [ 3.802509] i2c-gpio i2c-display: using lines 576 (SDA) and 577 (SCL) If course, you need to first configure the right pins by using hk1-x3 (and removing openvfd). Then you can investigate remaining i2c issues, if any.
  14. Here are the actions I take with the dtb file. Maybe I'm doing something wrong here? # cd /home/INSTALKI # git clone https://github.com/jefflessard/tm16xx-display.git # cd tm16xx-display # cp /boot/dtb/amlogic/meson-sm1-x96-air-gbit.dtb original.dtb # make hk1-box.dtb ORIGINAL_DTB=original.dtb # cp release/hk1-box.dtb /boot/dtb/amlogic/meson-sm1-x96-air-gbit.dtb # reboot
  15. In the /proc/device-tree directory I do not see any "tm16xx" entry but there is an "openvfd" entry. Attached is the /proc/device-tree directory and the dmesg output. device-tree.tar.gz dmseg.txt
  16. looks like a kernel oops does the unit run properly afterwards?
  17. Thank you for that information. From a cursory look, it seems as if that is only binary images, no source (violating GPL).
  18. I will try to make that easier and more automatic with APA, eventually.
  19. Thank you for letting us know as it allows an interested party to more easily bisect the regression.
  20. download all files attenmented . sudo cp *.dtbo /boot/dtb/allwinner/overlay open /boot/armbianEnv.txt , add this line: overlays=spi-spidev spidev1_1 and reboot, you should find and use /dev/spidev1.1 sun50i-h616-spidev1_0.dtbo sun50i-h616-spidev1_0.dtso sun50i-h616-spidev1_1.dtbo sun50i-h616-spidev1_1.dtso
  21. what is this? [code] [ 20.585289] ------------[ cut here ]------------ [ 20.585313] memcpy: detected field-spanning write (size 16) of single field "vif->key[pairwise][key_index]" at drivers/net/wireless/uwe5622/unisocwifi/cfg80211.c:714 (size 0) [ 20.585442] WARNING: CPU: 0 PID: 863 at drivers/net/wireless/uwe5622/unisocwifi/cfg80211.c:714 sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585498] Modules linked in: overlay sprdwl_ng sunxi_addr cfg80211 sunrpc zram snd_soc_hdmi_codec sunxi_cedrus(C) v4l2_mem2mem videobuf2_dma_contig polyval_ce videobuf2_memops videobuf2_v4l2 polyval_generic binfmt_misc videodev snd_soc_sunxi_machine dw_hdmi_i2s_audio panfrost dw_hdmi_cec sun50i_h6_prcm_ppu snd_soc_sunxi_ahub videobuf2_common gpu_sched snd_soc_sunxi_ahub_dam mc drm_shmem_helper display_connector dump_reg cpufreq_dt sch_fq_codel sprdbt_tty uwe5622_bsp_sdio rfkill fuse motorcomm dwmac_sun8i mdio_mux sun6i_rtc_ccu [ 20.585645] CPU: 0 UID: 0 PID: 863 Comm: wpa_supplicant Tainted: G C 6.15.0-edge-sunxi64 #1 NONE [ 20.585657] Tainted: [C]=CRAP [ 20.585661] Hardware name: OrangePi Zero3 (DT) [ 20.585667] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 20.585675] pc : sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585701] lr : sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] [ 20.585725] sp : ffff80008494b740 [ 20.585730] x29: ffff80008494b740 x28: ffff0000c1d32180 x27: ffff0000c08fb080 [ 20.585745] x26: 0000000000000000 x25: ffff0000c4600a40 x24: ffff0000c4600000 [ 20.585758] x23: 0000000000000004 x22: 0000000000000004 x21: 0000000000000010 [ 20.585772] x20: 0000000000000000 x19: ffff80008494b790 x18: 00000000ffffffff [ 20.585785] x17: 0000000000000000 x16: 0000000000000000 x15: 7269772f74656e2f [ 20.585799] x14: 7372657669726420 x13: 30386766632f6966 x12: ffff8000823482d0 [ 20.585813] x11: 0000000000000001 x10: 0000000000000001 x9 : ffff8000800df178 [ 20.585826] x8 : c0000000ffffefff x7 : ffff8000822f00e8 x6 : 0000000000000001 [ 20.585840] x5 : ffff0000ff734708 x4 : 0000000000000000 x3 : 0000000000000027 [ 20.585853] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000c1d32180 [ 20.585868] Call trace: [ 20.585874] sprdwl_cfg80211_add_key+0x124/0x138 [sprdwl_ng] (P) [ 20.585901] nl80211_new_key+0x1c4/0x320 [cfg80211] [ 20.586017] genl_family_rcv_msg_doit+0xe8/0x160 [ 20.586032] genl_rcv_msg+0x218/0x298 [ 20.586040] netlink_rcv_skb+0x68/0x140 [ 20.586053] genl_rcv+0x40/0x60 [ 20.586060] netlink_unicast+0x2f4/0x358 [ 20.586071] netlink_sendmsg+0x1b0/0x408 [ 20.586082] __sock_sendmsg+0x64/0xc0 [ 20.586093] ____sys_sendmsg+0x24c/0x2c0 [ 20.586101] ___sys_sendmsg+0xb8/0x118 [ 20.586110] __sys_sendmsg+0xa4/0x110 [ 20.586119] __arm64_sys_sendmsg+0x2c/0x40 [ 20.586128] invoke_syscall+0x50/0x120 [ 20.586142] el0_svc_common.constprop.0+0x48/0xf0 [ 20.586153] do_el0_svc+0x24/0x38 [ 20.586163] el0_svc+0x30/0xd0 [ 20.586175] el0t_64_sync_handler+0x10c/0x138 [ 20.586185] el0t_64_sync+0x198/0x1a0 [ 20.586195] ---[ end trace 0000000000000000 ]--- [/code]
  22. @KrzyPacu your Android DTS confirms the pinout of hk1-x3 fd628_dev { compatible = "amlogic,fd628_dev"; fd628_gpio_clk = <0x12 0x41 0x00>; fd628_gpio_dat = <0x12 0x40 0x00>; status = "okay"; }; 0x40 is data pin 64 0x41 is clock pin 65 So there must be something wrong with how you are copying the dtb to boot. Maybe to the wrong location. Ensure you have the proper dtb loaded at runtime by inspecting /proc/device-tree
  23. Yesterday
  24. Moved to Community supported forum as this isn't a standard support board.
  25. OrangePi 4A Bluetooth Mouse Keyboard connectivity issue Solved The solution to the problem when mouse pairs / connects with BT but doesnt work Prebuilt kernel files are available https://github.com/defencedog/orangepi4A/blob/main/Bluetooth%20Mouse%20Not%20Working%20Solved.md
  26. Yes it worked fine on the other Armbian OS. Unfortunately it still doesn't work. android-vontar-x3.dts
