I've got an Pine64 a that was one of the Kickstarter models. For a couple of years I've been running OctoPrint on it to run my Qidi i-mates 3d printer. Recently I decided to update from jammy to noble, before I did that I made a backup of my OctoPrint settings and files through the OctoPrint GUI in case of problems. I got a really messed inconsistent with all sorts of dependencies errors because the apt dist-upgrade seemed to freeze and after several hours of no movement I rebooted. As expected it was the mess. I spent about an hour on fixing dependencies but decided it just wasn't worth it as the only thing running is OctoPrint. When I went to restore OctoPrint, I got an error message about not enough space. When I did a df -m , I had plenty of space on the main partition, I posted on the OctoPrint forum and it was pointed out that my /tmp was tiny. Would anyone have any ideas of what is going on and what I can do to fix it? Here's the OctoPrint Error: Uploading backup, this can take a while. Please wait... Restoring from backup... Unpacking backup to /tmp/tmpf_d22xwu...Removing temporary unpacked folderError while running restoreTraceback (most recent call last): File "/home/ageoffri/OctoPrint/lib/python3.12/site-packages/octoprint/plugins/backup/__init__.py", line 1243, in _restore_backup zip.extract(member, temp) File "/usr/lib/python3.12/zipfile/__init__.py", line 1726, in extract return self._extract_member(member, path, pwd) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.12/zipfile/__init__.py", line 1802, in _extract_member shutil.copyfileobj(source, target) File "/usr/lib/python3.12/shutil.py", line 204, in copyfileobj fdst_write(buf)OSError: [Errno 28] No space left on device Restore failed! Chec And here's the df -m : Filesystem 1M-blocks Used Available Use% Mounted on tmpfs 198 4 195 2% /run /dev/mmcblk0p1 59861 3078 56137 6% / tmpfs 988 1 988 1% /dev/shm tmpfs 5 0 5 0% /run/lock tmpfs 988 0 988 0% /tmp /dev/zram1 47 3 41 6% /var/log tmpfs 198 1 198 1% /run/user/1000
Im currently trying to implement gpu support, but ive been stuck on the same error since a few days. Heres my armbianmonitor -u output: https://paste.armbian.com/uforekotuw root@radxa-cubie-a5e:~# cat /sys/kernel/debug/pm_genpd/pm_genpd_summary domain status children performance /device runtime status managed by ------------------------------------------------------------------------------ pd1_gpu off-0 0 pd1_pcie off-0 0 pd1_nand off-0 0 pd1_de off-0 0 pd1_vo1 off-0 0 4510000.ethernet suspended 0 SW pd1_vo0 off-0 0 pd1_vi off-0 0 pd1_ve off-0 0 pd_riscv off-0 0 pd_sram off-0 0 pd_npu off-0 0 pd_dsp off-0 0 dmesg | grep -i "gpu\|mali" [ 1.836128] panfrost 1800000.gpu: clock rate = 432000000 [ 1.848131] panfrost 1800000.gpu: gpu soft reset timed out, attempting hard reset [ 1.858262] panfrost 1800000.gpu: gpu hard reset timed out [ 1.858486] panfrost 1800000.gpu: Fatal error during GPU init [ 1.858674] panfrost 1800000.gpu: probe with driver panfrost failed with error -110
You need to check the disk space, apparently you are out of space and the daemon is not logging.
Not yet, i'll try to contact him ! Thank you very muych
Success story: https://forums.raspberrypi.com/viewtopic.php?p=2322591#p2322591 with the 3.5 inch ili9488, graphics (wayland) and touch in raspberry pi 3b I hope this helps with making it work in orange pi zero 3 and 2w (only touch missing) -
@rockamal Write the image to the SD card using whichever method you prefer—Balena Etcher, Rufus, dd, etc. I installed it on Manjaro using gnome-disk-utility. Just insert it and power on the TV box, and it should boot from the microSD.
I'm more concerned about what version 5 might break. Still, I don't think anyone makes Facebook account in order to login to Armbian forums 😄 and GitHub is not far from those I am afraid By the end of the day, this would be a symbolic gesture that works against practical ways. I think most of people uses Google login connector. Do we have any stats for that?
If this worked for you, I propose to open a PR, so there is a GitHub record of your work. Add it here https://github.com/armbian/build/tree/main/patch/kernel/archive/sunxi-6.12 Here you also need to pay attention to add to series* files.
Trouble getting hardware decoding to work on Rock 5 ITX
DavidFajardo replied to bucknaked's topic in Radxa Rock 5 ITX
All good now? -
fwiw I was able to build a set of Armbian kernel packages based on 6.16-rc1 and this patchset: https://lore.kernel.org/all/20250619173007.3367034-1-wens@kernel.org/ If it works, no clue, don't have the hw. Just played around. https://github.com/armbian/build/pull/8330
as I've not been running X11, I can't really help with this, but among the things, check the logs during X startup (normally /var/log/*), that could lead to the cause. note also that more recently, the display systems are running wayland rather than X11. that could cause xfce etc to fail if it is expecting an X11 based setup it is also recommended to bootup in the uart console (debug) port using a usb-uart dongle. - the benefits are numerous, the boot messages are mostly presented - it provides you with a console to login and check things while the system is running e.g. to login and check dmesg and other logs - essential especially when re-wiring network configuration
Once we do the major bump to v5 we should focus on getting Github to work and - if reasonable - drop commercial proprietary logins like Facebook and so on. Less pain, more freedom
Werner replied to Reluctant Linux User's topic in Radxa Rock 5 ITX
Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. -
Abraham Tamayo replied to sicxnull's topic in Allwinner CPU Boxes
Wow Tnx A LOT .. @Nick A .. your img work perfect to me .. download that image Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img burn to sd sudo dd if=/ISO/H313/Armbian-unofficial_25.05.0-trunk_X98h_bookworm_edge_6.12.11_server.img of=/dev/sdk bs=4M intro with ssh ssh root@192.168.X.X check the partitions lsblk burn to emmc dd if=/dev/mmcblk1 of=/dev/mmcblk0 bs=4M status=progress e2fsck -f /dev/mmcblk0p1 resize2fs /dev/mmcblk0p1 turn off = shutdown -r now remove the SD, reboot Enjoy. If dont works, try with gparted .. sudo apt-get install gparted sudo gparted resize -
I have orange pi zero 3 4gb, I had gnome installed but when i installed xfce with lightdm and rebooted, its stuck on the armbian splash screen with the loading wheel, any assistance?
@Nick_SlTried everything, the same module in a raspberry pi 4 works, but in the orange pi 4A no, I tried to get the output signals using an oscilloscope, the signals are inconsistent and have a lot of noise, maybe there is an issue with the i2c kernel driver.
Indeed. Comparing sources between kernel 6.12 and 6.15, I could only spot one difference in the drm_atomic_helper_connector_hdmi_check() function so I have tested applying this via a patch and the build compiled successfully. Testing the build I found that reboot now works and shutdown finishes with just a blank display. If it is indeed the same issue then this patch will likely fix the problem. Based on what I found it may impact certain Rockchip Socs also: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/gpu/drm/display/drm_hdmi_state_helper.c?h=linux-6.15.y&id=0d337b40ca1e532af42516d9e9024baad466319a drv-drm-atomic-helper-null-pointer-fix.patch Thanks Ryzer
And how to compile openvfd with this patch? How to apply this patch to openvfd?
Not supported by forum software. Keeping Facebook and Google operational requires constant attention and adjustement, while others worked so far without troubles.
Added instructions for joining your home lab: https://docs.armbian.com/WifiPerformance/#adding-a-new-device
Hi and thank you for the advice. The USB end of the dongle goes to my desktop PC. I compared the time stamps of the last issue and found that the PC was actually switched off during the last issue, having been switched on 10 minutes after the last sysrq log entry. So for the moment I will watch the findings of auditd, although the startup msgs from yesterday looked somewhat suspicious (?): 2025-06-23T18:23:09.799581+02:00 bananapipro2 systemd[1]: Starting auditd.service - Security Auditing Service... 2025-06-23T18:23:09.910646+02:00 bananapipro2 auditd[18408]: Audit daemon is low on disk space for logging 2025-06-23T18:23:09.911684+02:00 bananapipro2 auditd[18408]: Audit daemon is suspending logging due to low disk space. 2025-06-23T18:23:09.912308+02:00 bananapipro2 auditd[18408]: No plugins found, not dispatching events 2025-06-23T18:23:09.917468+02:00 bananapipro2 auditd[18408]: Init complete, auditd 3.0.9 listening for events (startup state enable) 2025-06-23T18:23:10.181350+02:00 bananapipro2 systemd[1]: Started auditd.service - Security Auditing Service. Greetings.
That should make it. You can always try to see if it works and search online if not. -
KrzyPacu replied to Jean-Francois Lessard's topic in Amlogic meson
Is it enough to remove these entries from the dts file and recompile it to dtb? 3535-3540 openvfd { compatible = "open,vfd"; dev_name = "openvfd"; status = "okay"; phandle = <0x143>; }; 4031 openvfd = "/openvfd"; meson-sm1-x96-air-gbit.dts -
But how do I do that? These are the original Armbian .dtb entries. I didn't add anything and I don't know how to remove it. -
Armbian_25.2.2_Rock-5-itx_noble_vendor_6.1.99_gnome_desktop.img.xz I first tried this, as it was the first version offered at the top of the page. No matter what I tried, sound would *not* work. Not speakers, not HDMI, nada, zip. I then started trying earlier versions further down the page. Armbian_25.2.2_Rock-5-itx_bookworm_vendor_6.1.99_cinnamon-backported-mesa_desktop.img.xz And this one, sound *did* work, at least through the speaker jack anyway, but I suspect HDMI would too. I'm really suspecting something kernel related is going here (that "Rockchip BSP" note right above it makes me suspect that). In any case, I'd like to use the kernel where sound is working and put a gnome shell in front of it. Which I take means digging into the build system for armbian? I can figure that out on my own but before I get started on that, what I'm looking for from the forumistas, is an indication of which specific kernel I need to use to make sure sound works. What do I need to make sure to specify so I get the behavior of that second install that worked? And Cinnamon may be better or something, but gnome is what I'm used to.
