  2. @Kiranmoy Saha I guess you have a box with NAND , not emmc You must use an old image that supports nand , typiclly kernel 4.4.xxx and follow 1st post jump start on nand Any newer kernel doesn't have nand support
  3. I don't know and I won't spend time investigating. We cannot provide support for 3rd party images/software.
  5. You just have to create the nginx folder in /var/log with owner www-data (it is not created automatically): mkdir /var/log/nginx chown -R www-data:www-data /var/log/nginx systemctl restart nginx
  6. Hi @jock, Thanks for the quick response. I’ve opened the box and attached the board images. On the back it says R29-MXQ-V2.1-221#. Sorry if I’m missing something—I’m a beginner. I thought rk322x-config runs only after Armbian boots. In my case, after flashing the image to eMMC and removing the SD, the box just blinks LED with no HDMI output. Only Multitool runs fine from SD. How can I run rk322x-config in this situation? Thanks again.
  7. These drivers should not differ much from each other, right? Anyway, I found a reasonable patch to fix this behavior. I couldn't see this in the Armbian kernel, but what I need is: patch.
  8. Not an Armbian kernel. You should ask at the place where you go the image with this kernel from.
  9. If the armbian-install way does not work, you can also write the image directly to the ssd, either with a different computer or, since you were already successfully booting from usb, download the image again and dd it to the ssd. No need to do partitioning beforehand, just write to the raw device since the image already contains the partition table iirc.
  10. Yesterday
  11. Hello, Armbian 25.8.1 on Helios64 BookWorm with Linux 6.12.42-current-rockchip64. I have my system booting from SD with OMV7 installed and several docker containers running. Everything is OK. Now I want to boot from emmc. Used armbian-install selecting option boot from emmc - system on emmc. Formatting and copying goes Ok, but when I reboot from emmc (extracting th SD card), OMV7 presents the web frontend, but can't log in. journalctl reports errors accessing the drives, and looking on /etc/fstab, there's only the / partition mounted. Inserting and mounting the SD card in /mnt/sdcard I can see that in /mnt/sdcard/etc/fstab there's a lot of drives ready to be mounted : eclapton@helios64:~$ cat /mnt/sdcard/etc/fstab UUID=a398270d-9378-4f2c-bedd-590b08234484 / ext4 noatime,nodiratime,defaults,commit=120,errors=remount-ro 0 1 tmpfs /tmp tmpfs defaults,nosuid 0 0 # >>> [openmediavault] /dev/disk/by-uuid/60c885fa-6af1-462c-bfa6-dc7fe706262f /srv/dev-disk-by-uuid-60c885fa-6af1-462c-bfa6-dc7fe706262f ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/a79a14c0-3cf4-4fb9-a6c6-838571351371 /srv/dev-disk-by-uuid-a79a14c0-3cf4-4fb9-a6c6-838571351371 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/7b71362f-4bb4-48b6-8867-37faaedef2eb /srv/dev-disk-by-uuid-7b71362f-4bb4-48b6-8867-37faaedef2eb ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/1f1ea692-d1bb-4539-a578-0647ef752770 /srv/dev-disk-by-uuid-1f1ea692-d1bb-4539-a578-0647ef752770 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 /dev/disk/by-uuid/fac27973-2eba-43b4-acd3-2c3c2b10a5d7 /srv/dev-disk-by-uuid-fac27973-2eba-43b4-acd3-2c3c2b10a5d7 ext4 defaults,nofail,user_xattr,usrquota,grpquota,acl 0 2 # <<< [openmediavault] So, I thought the actual fstab was going to be copied over, unless it has to be recreated each boot by OMV. Also, I tried to copy /srv/salt and /srv/pillar from the old system on the SD card to the new one on the emmc, as instructed un Kobol's webpage, and it helps making openmediavault-issue start, but the webpage doesn't still work. sudo systemctl status shows nginx is not able to start : eclapton@helios64:~$ sudo systemctl status nginx × nginx.service - A high performance web server and a reverse proxy server Loaded: loaded (/lib/systemd/system/nginx.service; enabled; preset: enabled) Active: failed (Result: exit-code) since Mon 2025-09-22 23:07:25 CEST; 57s ago Docs: man:nginx(8) Process: 40902 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE) CPU: 82ms sep 22 23:07:25 helios64 systemd[1]: Starting nginx.service - A high performance web server and a reverse proxy server... sep 22 23:07:25 helios64 nginx[40902]: 2025/09/22 23:07:25 [emerg] 40902#40902: open() "/var/log/nginx/error.log" failed (2: No such file or > sep 22 23:07:25 helios64 nginx[40902]: nginx: configuration file /etc/nginx/nginx.conf test failed sep 22 23:07:25 helios64 systemd[1]: nginx.service: Control process exited, code=exited, status=1/FAILURE sep 22 23:07:25 helios64 systemd[1]: nginx.service: Failed with result 'exit-code'. sep 22 23:07:25 helios64 systemd[1]: Failed to start nginx.service - A high performance web server and a reverse proxy server. I suspect there's somewhere I have to change /dev/mmcblk1p1 for /dev/mmcblk0p1... but where? What am I missing? Thanks for your help.
  12. hi, i try to install the current IOT/minmal image on the intern ssd on a old thinclient. USB-Drive will ident as sda and the ssd as sdb. if i use on armbian-config the install script for install, he create two partitions (sdb1 &2 / efi & linux) but it only boot with usb drive. On the usb drive i has a BIOS boot partition, must i swaphis somehow to the ssd drive?
  13. PR: included fd6551 https://github.com/armbian/build/pull/8666
  14. Have an idea to improve Armbian’s framework or userspace tools? Share your feature requests here — the community wants to hear what will make your experience better.
  15. nice work @Eks Ma thanks for sharing!
  16. Open the box, read the silkscreen on the board, run rk322x-config and configure according to silkscreen name. Probably you have a r29/h20 board
  17. h96-m9s-rk3576_defconfig rk3576-h96-m9s.dts rk3576-h96-m9s1.dts rc.local h96-m9.config rk3576-h96-m9s.dts h96-m9.tvb Compile-configuration.zip
  18. thank you so much for the link, after trying some of the older tinkerboard .deb archives from there I was able to install one that didn't have the two missing deps eventually and, lo and behold, I could even feel the accelerated desktop from the login window, even before confirming it with the much snappier webgl aquarium test, that jumped from about one fps to almost 60 there are still some kinks, like h264ify being installed but not doing squat (youtube is still av1 and hangs the whole system), but I'll take what I got for now as for the SOC being 2017....I'm fully aware that like everything Asus makes, it becomes e-waste after 2 years, I could probably try to flip this board online for $1 and no one would buy it, but I still believe it should be enough for me to stream video from my NAS on my secondary TV using 5-15W, kind of like those crappy Android sticks that plug into HDMI and an extra USB port I have yet to decide if my next SBC should be a rk3588 board or just bite the bullet and get some N100 SBC that's probably cheaper (I live in Europe, Orange Pi 5 probably goes for more than a used PS5 with all the taxes), can run anything and won't be forever stuck on whatever this year's trending distro is
  19. Hi ! @jpm how exactly did you solve 2) Fixed cedar_ve compilation issues / kernel name ? I'm gettinf the same "modprobe: ERROR: could not insert 'cedar_ve': Exec format error" T.
  20. Since it's an external driver, @Vincenzoernst1 you will still need to do all the process: Edit /boot/armbianEnv.txt to load the overlay user_overlays=tm16xx sudo apt install linux-headers-$(uname -r) # if it works, thats nice #if it doesn't you're cocked. Kernel module and display service Option 1: build and install in a single command Builds then installs module and service git clone https://github.com/jefflessard/tm16xx-display.git cd tm16xx-display make install Option 2: step by step commands make clean make module sudo make module-install sudo make service-install Check your display configuration display-service -c 3 phase display check Check that all leds are ON Check the order of digits and segment mapping (you should see "1234") Check each led name (ex: LAN icon is ON while "LAN" text is shown on the digits) I will include this section into a pull request: /dts-v1/; /plugin/; #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/leds/common.h> #include <dt-bindings/pinctrl/rockchip.h> &{/} { i2c-display { compatible = "i2c-gpio"; sda-gpios = <&gpio0 RK_PB4 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; scl-gpios = <&gpio0 RK_PB3 (GPIO_ACTIVE_HIGH | GPIO_OPEN_DRAIN)>; i2c-gpio,delay-us = <5>; #address-cells = <1>; #size-cells = <0>; display@24 { compatible = "fdhisi,fd6551"; reg = <0x24>; digits { #address-cells = <1>; #size-cells = <0>; digit@0 { reg = <0>; segments = <1 3>, <1 1>, <1 2>, <1 6>, <1 4>, <1 5>, <1 0>; }; digit@1 { reg = <1>; segments = <2 3>, <2 1>, <2 2>, <2 6>, <2 4>, <2 5>, <2 0>; }; digit@2 { reg = <2>; segments = <3 3>, <3 1>, <3 2>, <3 6>, <3 4>, <3 5>, <3 0>; }; digit@3 { reg = <3>; segments = <4 3>, <4 1>, <4 2>, <4 6>, <4 4>, <4 5>, <4 0>; }; }; leds { #address-cells = <2>; #size-cells = <0>; led@0,0 { reg = <0 0>; function = LED_FUNCTION_ALARM; }; led@0,1 { reg = <0 1>; function = LED_FUNCTION_USB; }; led@0,3 { reg = <0 3>; function = "play"; }; led@0,2 { reg = <0 2>; function = "pause"; }; led@0,4 { reg = <0 4>; function = "colon"; }; led@0,5 { reg = <0 5>; function = LED_FUNCTION_LAN; }; led@0,6 { reg = <0 6>; function = LED_FUNCTION_WLAN; }; }; }; }; };
  21. Hi @jock, Thanks a lot for your work on these RK322x boards. I have an MXQ Pro (RK3229, 2GB RAM / 16GB eMMC). I was able to boot Multitool from SD and successfully create a backup of the eMMC. However, when I burn an Armbian image to flash, the box doesn’t boot—LED blinks, but nothing shows up on HDMI. I’ve tried a few different images with the same result. Could you please guide me on how to debug this?
  22. thanks for all the work you put in to this application. i've done this on most all of my systems and it was a bit tedious and fiddley. with just a few tweeks it ran through with no errors on my hc4 with bookworm. one question, why remove bash-completion and command-not-found packages?
  23. Linux 6.1.31-sun50iw9 #1.0.4 SMP Wed Aug 6 19:06:53 UTC 2025 aarch64 GNU/Linux I couldn't find any known kernel issues.
  24. A crash in the Linux kernel's module loader is not really ZFS's fault, though, right? There's nothing about `resolve_symbol` that's part of ZFS.
  25. I think official stand from open ZFS project is: "ZFS is not designed for 32-bit kernels" ... it still might work(ed). IMO stay on kernel 6.6.y. I doubt there is anything wrong on Armbian side ... worth experimenting with Ubuntu Noble minimal image to rule out possible headers incompatibility.
  26. I grabbed the "Armbian 25.8.1 Bookworm Minimal / IOT" image from https://www.armbian.com/tinkerboard/, landed it on a microSD card, booted it, and ran apt update apt upgrade apt install linux-headers-current-rockchip apt install zfs-dkms zfsutils-linux This gets me linux-image-current-rockchip 25.8.1 (kernel 6.12.44-current-rockchip) and a module built from zfs-dkms 2.3.2-2~bpo12+2. So far so good. And then I ran modprobe zfs.ko and was rewarded with the following panic in the kernel's module loader: [ 1128.728803] spl: loading out-of-tree module taints kernel. [ 1128.859152] zfs: module license 'CDDL' taints kernel. [ 1128.859178] Disabling lock debugging due to kernel taint [ 1128.859401] zfs: module license taints kernel. [ 1128.860612] 8<--- cut here --- [ 1128.860624] Unable to handle kernel paging request at virtual address 5e4f51d0 when read [ 1128.860641] [5e4f51d0] *pgd=00000000 [ 1128.860663] Internal error: Oops: 5 [#1] SMP ARM [ 1128.865857] Modules linked in: spl(O) zram zsmalloc snd_soc_hdmi_codec snd_usb_audio snd_soc_simple_card binfmt_misc snd_soc_rockchip_i2s snd_soc_simple_card_utils snd_hwdep hantro_vpu snd_usbmidi_lib rockchip_vdec(C) snd_ump snd_soc_core r8723bs(C) rockchip_rga rockchip_iep snd_rawmidi v4l2_vp9 panfrost snd_pcm_dmaengine v4l2_jpeg rk_crypto snd_seq_device v4l2_h264 dw_hdmi_i2s_audio snd_pcm videobuf2_dma_contig gpu_sched dw_hdmi_cec v4l2_mem2mem snd_timer syscon_reboot_mode crypto_engine reboot_mode snd dw_wdt rk3288_gpiomem soundcore rockchip_thermal cpufreq_dt fuse gpio_keys realtek [ 1128.924379] CPU: 3 UID: 0 PID: 20465 Comm: modprobe Tainted: P C O 6.12.44-current-rockchip #1 [ 1128.935373] Tainted: [P]=PROPRIETARY_MODULE, [C]=CRAP, [O]=OOT_MODULE [ 1128.942570] Hardware name: Rockchip (Device Tree) [ 1128.947822] PC is at resolve_symbol+0xf8/0x368 [ 1128.952795] LR is at cmp_name+0x14/0x18 [ 1128.957081] pc : [<b01ac790>] lr : [<b01ab960>] psr: 90010013 [ 1128.964083] sp : f1f1dd68 ip : f1f1dca8 fp : f1f1ddbc [ 1128.969919] r10: f1f1ded0 r9 : af1f81dc r8 : af1f62ac [ 1128.975755] r7 : af2489c0 r6 : af248c48 r5 : f1f1de48 r4 : af52c300 [ 1128.983049] r3 : 00000000 r2 : 5e4f51c0 r1 : 00000000 r0 : 00000001 [ 1128.990342] Flags: NzcV IRQs on FIQs on Mode SVC_32 ISA ARM Segment none [ 1128.998318] Control: 10c5387d Table: 0364c06a DAC: 00000051 [ 1129.004737] Register r0 information: non-paged memory [ 1129.010383] Register r1 information: NULL pointer [ 1129.015639] Register r2 information: non-paged memory [ 1129.021283] Register r3 information: NULL pointer [ 1129.026538] Register r4 information: 201-page vmalloc region starting at 0xaf514000 allocated at load_module+0x744/0x1b34 [ 1129.038795] Register r5 information: 2-page vmalloc region starting at 0xf1f1c000 allocated at kernel_clone+0xac/0x340 [ 1129.050759] Register r6 information: 5-page vmalloc region starting at 0xaf247000 allocated at load_module+0x744/0x1b34 [ 1129.062820] Register r7 information: 5-page vmalloc region starting at 0xaf247000 allocated at load_module+0x744/0x1b34 [ 1129.074881] Register r8 information: 3-page vmalloc region starting at 0xaf1f6000 allocated at load_module+0x744/0x1b34 [ 1129.086942] Register r9 information: 3-page vmalloc region starting at 0xaf1f6000 allocated at load_module+0x744/0x1b34 [ 1129.099003] Register r10 information: 2-page vmalloc region starting at 0xf1f1c000 allocated at kernel_clone+0xac/0x340 [ 1129.111062] Register r11 information: 2-page vmalloc region starting at 0xf1f1c000 allocated at kernel_clone+0xac/0x340 [ 1129.123120] Register r12 information: 2-page vmalloc region starting at 0xf1f1c000 allocated at kernel_clone+0xac/0x340 [ 1129.135179] Process modprobe (pid: 20465, stack limit = 0xf191b45c) [ 1129.142183] Stack: (0xf1f1dd68 to 0xf1f1e000) [ 1129.147050] dd60: b01abd14 af52c3fc 00000000 f26174f8 00000100 af2489c0 [ 1129.156193] dd80: 00000000 af1f62ac 00000000 e7df2e2d b4795600 00005a2b f26174f8 f26bcb48 [ 1129.165334] dda0: af6dc2b4 00000000 0006a3d0 f1f1ded0 f1f1deb4 f1f1ddc0 b01ae384 b01ac6a4 [ 1129.174476] ddc0: b02f81d4 b02f2340 f26bcbc0 00000000 00000003 004d6d38 00000000 00000001 [ 1129.183618] dde0: 00000000 b4795600 f26bc508 00000000 af52c3fc 0000001e 00000000 b132bdb0 [ 1129.192759] de00: 00000000 af52c300 af52c300 b1bd8b84 af52c30c b1c8a1a4 00000000 00000001 [ 1129.201901] de20: b5b7e600 f26bcbc0 00459bc0 00459bc0 f1f1de5c f1f1de40 00459bc0 00000000 [ 1129.211041] de40: 7fffffff b5b7e600 00000000 00000000 00000000 00000000 00000000 00000000 [ 1129.220182] de60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 1129.229324] de80: 00000000 e7df2e2d 00000002 00000000 b5b7e600 004d6d38 b5b7e600 b1c8a5b4 [ 1129.238465] dea0: bbba0708 b5b7e600 f1f1df3c f1f1deb8 b01aeedc b01ad31c f1f1decc 7fffffff [ 1129.247607] dec0: 00000000 00000002 00000000 f2263000 f2576523 f24d6640 f2263000 00459bc0 [ 1129.256749] dee0: f26bc508 f26bc388 f25e9c54 0008272c 000a7eac 000a5a90 000c5d78 00000000 [ 1129.265890] df00: 000a5a80 00000028 00000029 00000016 00000000 0000001e 00000000 e7df2e2d [ 1129.275031] df20: 00000001 000000f6 b1c8a1a4 00000001 f1f1dfa4 f1f1df40 b01af2ac b01aee50 [ 1129.284172] df40: 00000000 00000000 004d6d38 b1c8a58c bbba0708 00000000 b1c8a58c 00000000 [ 1129.293314] df60: 00000000 f1f1df64 f1f1df64 fffffffc 00000000 e7df2e2d 000000c0 004d8ad8 [ 1129.302456] df80: 00fa74bc 22b57200 0000017b b01002c8 b4795600 0000017b 00000000 f1f1dfa8 [ 1129.311598] dfa0: b0100060 b01af108 004d8ad8 00fa74bc 00000004 004d6d38 00000000 004d86bc [ 1129.320738] dfc0: 004d8ad8 00fa74bc 22b57200 0000017b 00fa7520 00000000 00000000 004d50bc [ 1129.329879] dfe0: aeb5c0e8 aeb5c0d8 004cf149 a6bc3002 40070030 00000004 00000000 00000000 [ 1129.339018] Call trace: [ 1129.341845] resolve_symbol from load_module+0x1074/0x1b34 [ 1129.347983] r10:f1f1ded0 r9:0006a3d0 r8:00000000 r7:af6dc2b4 r6:f26bcb48 r5:f26174f8 [ 1129.356735] r4:00005a2b [ 1129.359559] load_module from init_module_from_file+0x98/0xd4 [ 1129.365987] r10:b5b7e600 r9:bbba0708 r8:b1c8a5b4 r7:b5b7e600 r6:004d6d38 r5:b5b7e600 [ 1129.374738] r4:00000000 [ 1129.377562] init_module_from_file from sys_finit_module+0x1b0/0x310 [ 1129.384670] r6:00000001 r5:b1c8a1a4 r4:000000f6 [ 1129.389826] sys_finit_module from ret_fast_syscall+0x0/0x54 [ 1129.396154] Exception stack(0xf1f1dfa8 to 0xf1f1dff0) [ 1129.401798] dfa0: 004d8ad8 00fa74bc 00000004 004d6d38 00000000 004d86bc [ 1129.410939] dfc0: 004d8ad8 00fa74bc 22b57200 0000017b 00fa7520 00000000 00000000 004d50bc [ 1129.420079] dfe0: aeb5c0e8 aeb5c0d8 004cf149 a6bc3002 [ 1129.425724] r10:0000017b r9:b4795600 r8:b01002c8 r7:0000017b r6:22b57200 r5:00fa74bc [ 1129.434475] r4:004d8ad8 [ 1129.437302] Code: ea00004a e5922000 e1520006 0a000047 (e5923010) [ 1129.444162] ---[ end trace 0000000000000000 ]--- I have been unable to find debug symbols or a way to get an objdump of the loaded kernel (probably I am just missing something). Please advise what more I can tell you to be useful. I am unable to run armbianmonitor; after the above, lsmod hangs, and upon boot, the machine attempts to load zfs.ko which again crashes as above and userspace is pretty direly stuck. FWIW, I am happily running ZFS on a Tinkerboard with an older system, specifically linux-image-current-rockchip 24.11.1 (which is kernel 6.6.63-current-rockchip) and zfs-dkms 2.2.2-0ubuntu9.1.
  27. Would you mind sending this as pull request? https://github.com/armbian/build/pulls
  28. diff --git a/config/sources/families/mvebu64.conf b/config/sources/families/mvebu64.conf index 90b0a97d4..1a78ace60 100644 --- a/config/sources/families/mvebu64.conf +++ b/config/sources/families/mvebu64.conf @@ -28,7 +28,8 @@ BOOTSCRIPT_OUTPUT='boot.scr' OVERLAY_DIR="/boot/dtb/marvell/overlay" ATFSOURCE='https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git' ATFDIR='arm-trusted-firmware-espressobin' -ATFBRANCH='tag:v2.8' +ATFBRANCH='tag:v2.10' +#ATFBRANCH='tag:v2.8' ATF_USE_GCC='> 7.2' if [[ "${SKIP_EXTERNAL_TOOLCHAINS}" == "yes" ]]; then @@ -126,7 +127,7 @@ uboot_custom_postprocess() { local atfdir="$SRC/cache/sources/$ATFDIR/${ATFBRANCH##*:}" local ubootdir="$SRC/cache/sources/u-boot-worktree/$BOOTDIR/${BOOTBRANCH##*:}" local moxbootdir="$SRC/cache/sources/mox-boot" - cd $atfdir + cd $atfdir if [[ $BOARD = macchiatobin-doubleshot ]]; then run_host_command_logged make distclean @@ -139,6 +140,9 @@ uboot_custom_postprocess() { run_host_command_logged cp -pv build/a80x0_mcbin/release/flash-image.bin $ubootdir/$FILENAME else cd $moxbootdir +#$HL + [[ -f Makefile ]] && sed -i "s/aarch64-unknown-linux-gnu-/aarch64-linux-gnu-/" Makefile + [[ -f wtmi/a53_helper/Makefile ]] && sed -i "s/aarch64-unknown-linux-gnu-/aarch64-linux-gnu-/" wtmi/a53_helper/Makefile make clean # @TODO: rpardini: why? run_host_command_logged "CFLAGS=-fdiagnostics-color=always" pipetty make CROSS_CM3=$ATF2 wtmi_app.bin cd $atfdir diff --git a/lib/functions/compilation/atf.sh b/lib/functions/compilation/atf.sh index 2c6b55408..7205c0366 100644 --- a/lib/functions/compilation/atf.sh +++ b/lib/functions/compilation/atf.sh @@ -71,7 +71,8 @@ compile_atf() { display_alert "Binutils version for ATF" "${binutils_version}" "info" if linux-version compare "${binutils_version}" ge "2.39"; then display_alert "Binutils version for ATF" ">= 2.39, adding --no-warn-rwx-segment" "info" - binutils_flags_atf="-Wl,--no-warn-rwx-segment" + #binutils_flags_atf="-Wl,--no-warn-rwx-segment" + binutils_flags_atf="--no-warn-rwx-segment" fi # - ENABLE_BACKTRACE="0" has been added to workaround a regression in ATF. Check: https://github.com/armbian/build/issues/1157 with the patch, I am able to generate a image to run a espressobin v5 board, it should be ok for v7 board.
