Console Service, SSH Service
Werner replied to jenseitz's topic in Software, Applications, Userspace
No idea what this version is. Take out microsd and shove it into your laptop/PC (running Linux) and mount it. Then check whats wrong. -
moved to offtopic
Description station-m2: move to rk35xx family Add legacy-5.10 and vendor-6.1 kernel for station-m2 This PR is depend on https://github.com/armbian/linux-rockchip/pull/187 and https://github.com/armbian/linux-rockchip/pull/186 How Has This Been Tested? [x] Almost all hardware functions(HDMI, WiFi, BT, GbE, USB...). [x] System startup. Checklist: [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [x] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [x] Any dependent changes have been merged and published in downstream modules View the full article
@Nick A thank you for your information 😀 Would it be possible to get your already patched sources for building the images you posted on pixeldrift? Can I download them on your github page? Any other way that I don't have to invent the wheel anew to create the same image myself? Thanks!!!
Newbie Using LinuxMint 21.3 I have been searching for answer to below question, and have been referred to UserSpace as it may have an answer. Referral from greg kh on Linusfoundation org. Question: Linux Mint 21.3 Using LibreCalc With USB RFID tag readers, (2 or more reader) most enter direct into open focus spreadsheet. However with no device number. Have same pid and vid. As the read from USB tag goes to the spreadsheet, can the device number eg 03 and the bus number eg 004 (either or both) be appended to the data read, into the spreadsheet. This would enable spreadsheet identify each reader and its location, to manipulate the tag reads by the location etc. If so, how do I go about setting up? This is a common issue with USB and HID, there is no device ID. A standard terminal script for LinuxMint would be great and make the USB devices more usable. Thankyou Charles Harris
This forum is related to Armbian. For general Orangepi questions consider asking in their forums. We don't use Android nor Batocera here.
Hi, I built a NAS with a Raspberry PI. It runs ARMBIAN 5.46, a SAMBA server and an NFS server. There are also 5 disks that are combined as RAID5. Since yesterday I can no longer log in, neither via SSH nor directly on the Raspberry Pi. When I try via SSH, I get the password query, the start message about the current status and then the connection is closed. When I log in directly to the system, I get the login query (username and password) and then the message "Module is unknown". Then the login request comes again. What can I do without reinstalling the system? Thanks for the help. Jens
Hello, sorry for my English. I have an Orange Pi 5 8gb and a 512gb nvme SSD. I would like to use it to install 2 operating systems (Android 12 + Batocera). This way, when starting the orange pi, it asks which operating system I want to start on. Is this possible?
Hi there, for years all run perfectly, but now i need a newer PHP for a project. cat /etc/debian_version shows 10.13. Can i now directly upgrade to Bookworm following the tipps in this thread or should i upgrade to Buster and then to bookworm?
I have been trying to use these two to achieve hard decoding:https://linux-sunxi.org/Sunxi-Cedrus and https://linux-sunxi.org/Cedrus /libvdpau-sunxi . libva-v4l2-request I used someone else's version because it was a lower version: https://github.com/kwizart/libva-v4l2-request/tree/HACK_HEVC It can be compiled and installed successfully under the 6.6 kernel libva info: VA-API version 1.17.0 libva info: User environment variable requested driver 'v4l2_request' libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/v4l2_request_drv_video.so libva info: Found init function __vaDriverInit_1_17 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.17 (libva 2.12.0) vainfo: Driver version: v4l2-request vainfo: Supported profile and entrypoints VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264High : VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264MultiviewHigh : VAEntrypointVLD VAProfileH264StereoHigh : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD Unfortunately, when I use vaapi, the kernel crashes,command:mpv -v --hwdec=vaapi The libvdpau-sunxi project compiles without modification, but some devices are no longer used in kernel 6.6 command:mpv -v --hwdec=vdpau There was no crash using vdpau, but as I said, the lack of a corresponding device caused it to become unusable and switch to soft decoding mpv -v --hwdec=vdpau IAmLegend-Trailer.mp4 [cplayer] Command line options: '-v' '--hwdec=vdpau' 'IAmLegend-Trailer.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.4-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'v' = '' (flags = 8) [cplayer] Setting option 'hwdec' = 'vdpau' (flags = 8) [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening IAmLegend-Trailer.mp4 [bdmv/bluray] Opening IAmLegend-Trailer.mp4 [file] Opening IAmLegend-Trailer.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [file] stream level seek from 131072 to 126886094 [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: IAmLegend-Trailer.mp4 [find_files] Loading external files in . [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [lavf] select track 1 [cplayer] (+) Video --vid=1 (*) (h264 1920x816 23.976fps) [cplayer] (+) Audio --aid=1 (*) (aac 6ch 48000Hz) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 23.975986 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-vdpau... [vo/gpu] Loading hwdec drivers for format: 'vdpau' [vd] Could not create device. [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [ad] Codec list: [ad] aac - AAC (Advanced Audio Coding) [ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ad] Opening decoder aac [ad] Requesting 1 threads for decoding. [ad] Selected codec: aac (AAC (Advanced Audio Coding)) [af] User filter list: [af] (empty) [cplayer] Starting playback... [file] stream level seek from 126886145 to 57472 [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1920x816 yuv420p auto/auto/auto/auto/auto CL=mpeg2/4/h264 [vf] [in] 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [af] [in] 48000Hz 5.1 6ch floatp [af] [userspeed] 48000Hz 5.1 6ch floatp [af] [userspeed] (disabled) [af] [convert] 48000Hz 5.1 6ch floatp [ao] Trying audio driver 'pipewire' [ao/pipewire] requested format: 48000 Hz, 5.1 channels, floatp [ao/pipewire] Headers version: 0.3.65 [ao/pipewire] Library version: 0.3.65 [W][09924.973570] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][09924.973889] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory [ao] Trying audio driver 'pulse' [ao/pulse] requested format: 48000 Hz, 5.1 channels, floatp [ao/pulse] Library version: 16.1.0 [ao/pulse] Proto: 35 [ao/pulse] Server proto: 4294967295 [ao/pulse] Channel layouts: [ao/pulse] - #fl [ao/pulse] - #fr [ao/pulse] - #fc [ao/pulse] - #lfe [ao/pulse] - #bl [ao/pulse] - #br [ao/pulse] - #flc [ao/pulse] - #frc [ao/pulse] - #bc [ao/pulse] - #sl [ao/pulse] - #sr [ao/pulse] - #tc [ao/pulse] - #tfl [ao/pulse] - #tfc [ao/pulse] - #tfr [ao/pulse] - #tbl [ao/pulse] - #tbc [ao/pulse] - #tbr [ao/pulse] result: 5.1 [ao/pulse] device buffer: 6718 samples. [ao/pulse] using soft-buffer of 9600 samples. [cplayer] AO: [pulse] 48000Hz 5.1 6ch float [cplayer] AO: Description: PulseAudio audio output [autoconvert] inserting resampler [swresample] format change, reinitializing resampler [swresample] 48000Hz 5.1 floatp -> 48000Hz 5.1 float [af] [out] 48000Hz 5.1 6ch float [cplayer] VO: [gpu] 1920x816 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] DR path suspected slow/uncached, disabling..reconfig to 1920x816 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1920x816 [vo/gpu] Window size: 1920x816 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x816 (1:1) [vo/gpu] Video display: (0, 0) 1920x816 -> (0, 0) 1920x816 [vo/gpu] Video scale: 1.000000/1.000000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x816 [vo/gpu] Texture for plane 1: 960x408 [vo/gpu] Texture for plane 2: 960x408 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [cplayer] first video frame after restart shown [cplayer] audio ready [cplayer] starting audio playback [cplayer] playback restart complete @ 0.041708, audio=playing, video=playing [vo/gpu/x11] Disabling screensaver. [ao/pulse] starting AO [statusline] AV: 00:00:00 / 00:02:03 (0%) A-V: 0.000 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [statusline] AV: 00:00:06 / 00:02:03 (5%) A-V: 0.000 [cplayer] EOF code: 5 [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 [vo/gpu/x11] Enabling screensaver. That's all I've ever known and tried
WiFi performance benchmark tests act like a checkup for your wireless network. They assess speed, reliability, and overall health to identify any weaknesses and ensure your network runs smoothly for all your devices and activities. visit this: http://startrinity.com/InternetQuality/WifiSpeedStabilityTest.aspx
You have to check some points to troubleshoot this issue: Update Firefox: Outdated browsers can cause compatibility problems. Check for updates and install them if available. Test with Extensions Disabled: Temporarily disable extensions to see if they're interfering with MFA functionality. Clear Browsing Data: Clear cookies and cache from Firefox settings. This can resolve issues caused by outdated data. Enable JavaScript: Ensure JavaScript is enabled in Firefox settings, as it's crucial for many web features, including MFA. Allow Pop-ups (for the forum): Configure pop-up settings to allow them specifically from the forum website. MFA might require pop-ups for verification. Review Security Settings: Make sure your security settings aren't blocking essential elements for MFA to function properly. If the issue continues: If you've gone through these steps and still experience issues, contact the forum's technical support. They might have specific solutions or updates related to Firefox compatibility.
Description The app icon of armbian-config is broken for a long time, fix it. How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [x] Just editing ~/.local/share/applications/armbian-config.desktop, and see armbian-config icon from app menu of gnome3. Checklist: Please delete options that are not relevant. [x] My code follows the style guidelines of this project [x] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [x] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
Dear Community, Currently Im playin with my Banana Pi M2 Berry and therefore I need a fusion of the LATEST Armbian -System with the compilers needed by the Boards Offical "GPIO-Libarys", which are outdated 7years ago. The most important libary would be the RPi.GPIO. RPi.GPIO The problem is, that this libary was using python2 and python3, python2 isnt my future i think, but for compiling the lib with python3 I need some pip-packages and the right arm-gcc compiler = 4.8 i think. DO i may need a cross-compile libary or whats are the requirements to build the lib on the latest system? To avoid hardware-determiner ERRORS, Im using the folder and its scripts/configs used in the offical Raspbian build for this device. The goal: The Latest Armbian-build with re-supported libarys like rpi.gpio or wiringpi! If there is someone who would like to update the GPIO-Controlling Libarys for Banana Pi with me, i'd be gratefull if some people let me know by pn, e-mail or github! Thanks, BlackLeakz
Your box has a H616.. The problem is due to your box having a different PMIC (Power Management IC). https://linux-sunxi.org/AXP_PMICs I think you would have better luck booting an OrangePi Zero2 image. I would extract your boxes dts file and compare it with OrangePi Zero2. Make sure the voltages are correct. axp305: pmic@745 { compatible = "x-powers,axp305", "x-powers,axp805", "x-powers,axp806"; interrupt-controller; #interrupt-cells = <1>; reg = <0x745>; x-powers,self-working-mode; vina-supply = <®_vcc5v>; vinb-supply = <®_vcc5v>; vinc-supply = <®_vcc5v>; vind-supply = <®_vcc5v>; vine-supply = <®_vcc5v>; aldoin-supply = <®_vcc5v>; bldoin-supply = <®_vcc5v>; cldoin-supply = <®_vcc5v>; regulators { reg_aldo1: aldo1 { regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-sys"; }; reg_aldo2: aldo2 { /* 3.3V on headers */ regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc3v3-ext"; }; reg_aldo3: aldo3 { /* 3.3V on headers */ regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc3v3-ext2"; }; reg_bldo1: bldo1 { regulator-always-on; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-name = "vcc1v8"; }; bldo2 { /* unused */ }; bldo3 { /* unused */ }; bldo4 { /* unused */ }; cldo1 { /* reserved */ }; cldo2 { /* unused */ }; cldo3 { /* unused */ }; reg_dcdca: dcdca { regulator-always-on; regulator-min-microvolt = <810000>; regulator-max-microvolt = <1100000>; regulator-name = "vdd-cpu"; }; reg_dcdcc: dcdcc { regulator-always-on; regulator-min-microvolt = <810000>; regulator-max-microvolt = <990000>; regulator-name = "vdd-gpu-sys"; }; reg_dcdcd: dcdcd { regulator-always-on; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; regulator-name = "vdd-dram"; }; reg_dcdce: dcdce { regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-eth-mmc"; }; sw { /* unused */ }; }; }; };
I'd be interested in understanding better what is going on to enable the toothpick to switch boot order. So by default it seems that the boot order looks for u-boot on emmc first (as it doesn't boot from an SD card with a valid u-boot when inserted). But something happens with the pressing of the button that causes the boot order to change from emmc first to SD first. And that change seems to be persistent from your description. That would imply that some state information (boot order) is being stored somewhere as sometimes it boots emmc first and other times it boots SD card first. Where and how does this process work?
Description Boots cleanly from sdcard even when OEM uboot is installed on EMMC (was having optee errors using radxa uboot when OEM was on EMMC) -Boot 2024.04-armbian (May 13 2024 - 20:34:52 +0000) Model: FriendlyElec NanoPC-T6 DRAM: 16 GiB Core: 338 devices, 30 uclasses, devicetree: separate MMC: mmc@fe2c0000: 1, mmc@fe2e0000: 0 Loading Environment from nowhere... OK In: serial@feb50000 Out: serial@feb50000 Err: serial@feb50000 Model: FriendlyElec NanoPC-T6 rockchip_dnl_key_pressed: no saradc device found Net: No ethernet found. Hit any key to stop autoboot: 0 Scanning for bootflows in all bootdevs View the full article
Tested Noble XFCE on ASUS Tinkerboard S - RK3288: System boots HDMI ok eMMC ok sdcard ok USB2.0 ok Ethernet ok, throughput ok (> 900mbps) Wireless ok (rtl8723bs), throughput ok (~70 mbps on 2.4ghz 802.11n network) Bluetooth ok, streamed same music from same smartphone as opi4 lts; some occasional hiccups but link is stable Analog audio codec ok dmesg is lamenting: ff540000.usb device "Waiting for Host Mode timed out", USB 2.0 host ports yet works fine ff580000.usb softreset failed, but USB OTG port is occupied by PSU SPI device is not found (there is no SPI device on my tinkerboard) mmc1 (wifi) incurs in an issue on first initialization, but succeeds on next attempt and wifi/bt seems to work pretty fine
@Nick A: Yes, I found a suitable plastic tool to press the uboot button through the audio jack during powering up. The symptom is, when the button is pressed (and released after power up), serial output remains absolutely silent (so the uboot button pressing is sensed!), when uboot button is not pressed, the standard boot process is visible... I enclose an earlier saved stock firmware boot log, if you can get any hints out of that... I also checked on the linux machine, that the SD card contains the Armbian image, which can be mounted, files are browsable... t95h_x24_stock_firmware_boot.txt
Tested Noble XFCE on Orange Pi 4 LTS - RK3399: System boots HDMI ok eMMC ok Sdcard ok USB 2.0 and USB 3.0 ok Ethernet ok, throughtput ok (> 900mbps) Wireless ok, throughput ok (~80 mbps on 2.4ghz 802.11n network) Bluetooth ok, streamed some music from smartphone Analog Audio codec is fine dmesg is clean with no particular errors
