  2. Tested right now and it works as expected. Logs: http://ix.io/1Hc0 1. Debian Stretch CLI image https://dl.armbian.com/bananapim2plus/Debian_stretch_next.7z 2. Creating user, running update (apt update and apt upgrade) 3. armbian-config -> network -> Hotspot 4. Connect with a mobile, no problem, running speedtest, speed as expected 5. Reboot 5. Connect with a mobile, no problem, running speedtest, speed as expected
  3. I give up. I thank everyone for help.I have too little knowledge to solve this.
  4. lzb
    armbianmonitor error
    Sorry for grave digging, but I have the same error messages in BananaPi M1: root@bananapi:~# armbianmonitor -m >> armmon.log /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.5: integer expression expected /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.3: integer expression expected /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.2: integer expression expected /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.2: integer expression expected /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.4: integer expression expected /usr/bin/armbianmonitor: line 385: read: read error: 0: Connection timed out /usr/bin/armbianmonitor: line 386: [: 43.4: integer expression expected *snip* root@bananapi:~# dmesg | tail [74843.472544] thermal thermal_zone0: failed to read out thermal zone (-110) [74961.592838] thermal thermal_zone0: failed to read out thermal zone (-110) [80058.430841] thermal thermal_zone0: failed to read out thermal zone (-110) [81036.963935] thermal thermal_zone0: failed to read out thermal zone (-110) [83488.688937] thermal thermal_zone0: failed to read out thermal zone (-110) [84273.576483] thermal thermal_zone0: failed to read out thermal zone (-110) [85252.109538] thermal thermal_zone0: failed to read out thermal zone (-110) [85553.122760] thermal thermal_zone0: failed to read out thermal zone (-110) [85660.618355] thermal thermal_zone0: failed to read out thermal zone (-110) [86133.835726] thermal thermal_zone0: failed to read out thermal zone (-110) root@bananapi:~# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/1HbP Please post the URL in the forum where you've been asked for. Not that I care about those errors, but maybe it can be pushed to fix some bug. I'm running armbianmonitor >> file because my BananaPi setup has small uptime (like, it freezes and I need to restart it - that's another story). PS Keep up the good work on Armbian!
  5. vivekpk
    Couldn't start AP(host) mode in Banana Pi M2+
    no its not working from armbian-config
  6. langerma
    Ethernet not working on SOPINE module
    okay...as i wanted to reinstall the boards i am going to test it this weekend
  7. Haha - SE's worries. I get paid if she waists my time or not.
  8. I followed all the help I could find in the forum as well as on the net. None however was specific to the Nanopi Neo Plus 2, so I thought I'd ask.
  9. Is it working when you use armbian-config way? network -> armbian-config?
  10. Igor
    When someone will confirm that its working, I will push update to the repository. Then, apt upgrade will make a difference. And manual u-boot update (from nand-sata-install menu) when important change is there.
  11. Because its a mess with those wireless chips. There are different versions of them and each needs different firmware settings ... Which one you have in mind?
  12. Today
  13. ilchenko Evgeny
    Orangepi 3 h6 allwiner chip
    Hi, friends. I noticed such an interesting feature. I have a 100 megabit Internet connection and on windows PC with uTorrent have a rate of about 10mb/sec download but if run download on Transmittion-deamon i have a maximum of 5mb/sec i.e. only half speed. Why?
  14. Hi i am trying to create a hotspot using Network Manager in my banana pi nmcli con add type wifi ifname wlan0 con-name Hostspot autoconnect yes ssid pducontroller nmcli con modify Hostspot 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared nmcli con modify Hostspot wifi-sec.key-mgmt wpa-psk nmcli con modify Hostspot wifi-sec.psk "verylongpassword" nmcli con up Hostspot But when I type nmcli con up Hostspot gives me an output Error: Connection activation failed. here is my system diagnosis information link
  15. just use the searchbox, right hand, top corner and look for: AP6212
  16. Petee
    Armbian for Amlogic S9xxx kernel 4.1x (>= ver 5.55)
    Did a nightly build update to the second TV Box here (TX9 Pro - Octocore, 3Gb, 1Gb NIC) and it is working well. Only thing though when logging in to the computer see the following stuff relating to RockPro64 changing from S912 when logging in. ____ _ ____ __ _ _ | _ \ ___ ___| | _| _ \ _ __ ___ / /_ | || | | |_) / _ \ / __| |/ / |_) | '__/ _ \ | '_ \| || |_ | _ < (_) | (__| <| __/| | | (_) | | (_) |__ _| |_| \_\___/ \___|_|\_\_| |_| \___/ \___/ |_| Welcome to ARMBIAN 5.82.190423 nightly Ubuntu 18.04.2 LTS 5.1.0-rc1-aml-s912 System load: 0.00 0.00 0.00 Up time: 8:33 hours Memory usage: 10 % of 2840MB Zram usage: 1 % of 1023Mb IP: 192.168.244.150 CPU temp: 44°C Usage of /: 14% of 29G Last login: Thu Apr 25 00:25:58 2019 from 192.168.244.232 Running a couple of automation pieces of software, docker and mono (CPU sucker)..it is hardly working...headless
  17. mrsufgi
    RockPi 4b 'board bring up'
    Don't, it doesn't work (tried it myself). I also tried all available images (5.79 with 5.0.0 kernel), non of them works.
  18. I've escalated my problem - I guess the SE will select another board. For curiosity sake, does anybody have any idea(s) about why the WIFI firmware is not working in linux kernel 4.19.36 (but in 4.19.20)?
  19. Igor
    NanoPC T4
    One is certain. You don't need any partitions since all boot stages are happening outside - at fixed positions. You only need a partition if you plan to boot Linux (from it). I am not sure if the type matters (depending from u-boot configuration I would say) ... you will need to dig deep into docs, if and where available.
  20. martinayotte
    They are there : https://dl.armbian.com/orangepi3/
  21. thexman
    SSH doesn't work on Orange Pi Zero
    @Mabrafs Fixed with latest kernel please read posts in this thread for more information
  22. https://github.com/friendlyarm/linux/blob/sunxi-4.14.y/arch/arm/boot/dts/sun8i-h3-nanopi.dtsi#L518-L523 It's also software problem.
  23. The USB OTG is not working - the microUSB connector data lines are not connected to the SoC (based on schematic rev1704) so Ethernet-over-USB will never work !!!
  24. The client require TCP access to this board via USB - I think they want to get debug info and remote syslog via this port. Sorry I am not the SE on this system so that is beyond my scope of worries.
  25. maddinthebrain
    Hi all, as the image for the Orange Pi 3 seems to be developing, when will be there a beta to try? Or a image that works redumantary? thx Martin
  26. I was able to fix the Ethernet-over-USB problem with the help of another (recent) post. I found the DTS file (after adding some oil on the rusty parts) for the my board @ "./cache/sources/linux-mainline/orange-pi-4.19/arch/arm64/boot/dts/allwinner/sun50i-h5-nanopi-neo-plus2.dts". After changing the USB setting to "otg", I created a patch file and added it to the build/patch/kernel/sunxi-{dev,next} directories. This great build system automatically applied it and I now see a usb0 interface after loading the g_ether module. I've attached my patch file which should work for any v4.19 kernel. So now only the Wifi issue remain board-nanopineoplus2-enable-otg.patch
  27. Merblud
    NanoPC T4
    As a result it is necessary to create the mbr partition? And why then the loader tries to look for the gpt partition? For example: GPT 0x3190d20 signature is wrong LoadTrust Addr:0x4000 Or nobody just knows what occurs in a blob from Rockchip?
