lucas24007 Posted May 4, 2019 Posted May 4, 2019 Hi everyone, I'm using a Nanopi NEO2 as a NAS (link : https://www.friendlyarm.com/index.php?route=product/product&product_id=222) and it's provided with an armbian jessie version. I did try to upgrade to Stretch but I was missing some repositories. Now I'm trying to install a fresh Armbian Stretch version but on first boot SSH is not enabled. How can I configure armbian ? I cannot connect keyboard/screen. Maybe there is another way to do it ? Other armbian/debian images ? Does anyone have a solution ?
Igor Posted May 4, 2019 Posted May 4, 2019 2 hours ago, lucas24007 said: Now I'm trying to install a fresh Armbian Stretch version but on first boot SSH is not enabled. How long do you wait?
lucas24007 Posted May 4, 2019 Author Posted May 4, 2019 I've tried to connect about 3 minutes after booting. I can't find on the doc if SSH is supposed to be enabled out of the box or not :/ Thanks for your help !
guidol Posted May 4, 2019 Posted May 4, 2019 7 minutes ago, lucas24007 said: I've tried to connect about 3 minutes after booting. I can't find on the doc if SSH is supposed to be enabled out of the box or not :/ on a normal armbian-image SSH and DHCP is enabled. So you have to check which DHCP-IP-address do you get for the Neo2 and then it shoudnt take more than a minute (when using a Class 10 microSD-card) before you can login via SSH User: root initial Password: 1234 (you will be forced to change it to a new one - and create a additional new user) (Done this many times here with my 3x NanoPi Neo2, 1x NanoPi Neo and 1x NanoPi Neo Core2)
lucas24007 Posted May 5, 2019 Author Posted May 5, 2019 Really strange. I've found which IP is linked to the mac address of the NanoPi Neo2 (btw the network component vendor is : Chiun Mai Communication Systems, Inc). It responds to my ping but when I'm trying to connect via ssh as root it says : ssh: connect to host 192.168.0.21 port 22: Connection refused It seems that DHCP is enabled but not SSH. I've used the image : Armbian_5.83_Nanopineo2_Debian_stretch_next_4.19.38.img The ethernet port's led is on (orange). Thanks for your help !
Igor Posted May 5, 2019 Posted May 5, 2019 59 minutes ago, lucas24007 said: Thanks for your help ! I would suggest you to check some those typical problems https://forum.armbian.com/forum/31-sd-card-and-psu-issues/ 59 minutes ago, lucas24007 said: I've used the image : Armbian_5.83_Nanopineo2_Debian_stretch_next_4.19.38.img Working without any problems. This is boot log: http://ix.io/1I5W, actual setup Spoiler and SSHing to the board works which means the problem is on your side. A problem with a board? Not sufficient powering? Bad cables? Bad SD card? If you are powering the board from computer, then another serial console will pup-up. You can login there and see why network is not up. If system gets that far ... [62873.971897] usb 1-3.4.1: new high-speed USB device number 24 using xhci_hcd [62874.072937] usb 1-3.4.1: New USB device found, idVendor=0525, idProduct=a4a7 [62874.072947] usb 1-3.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [62874.072954] usb 1-3.4.1: Product: Gadget Serial v2.4 [62874.072960] usb 1-3.4.1: Manufacturer: Linux 4.19.38-sunxi64 with musb-hdrc [62874.074956] cdc_acm 1-3.4.1:2.0: ttyACM0: USB ACM device sudo screen /dev/ttyACM0 115200
abigailrose Posted July 1, 2019 Posted July 1, 2019 I'm having this same issue with the same image. Nmap shows the ssh port (22) as closed
Igor Posted July 1, 2019 Posted July 1, 2019 4 hours ago, abigailrose said: I'm having this same issue with the same image. Nmap shows the ssh port (22) as closed We need serial console logs to understand more.
stavrakis Posted July 4, 2019 Posted July 4, 2019 If SSH is not enabled out of the box, you can mount the image, and manually enable SSH before booting from it. You will have to symlink the systemd script in order to enable. You can also edit sshd_config.
abigailrose Posted July 23, 2019 Posted July 23, 2019 I can't connect via serial console either. I have a USB/TTL cable (tested the cable to make sure it works by shorting white to green, text appears on my screen as expected), using picocom in a OS X terminal window. Picocom opens and I can connect to the serial device, but nothing happens after terminal ready, even when I plug the cable in before boot, I don't see boot logs, and I can't type anything into the window. I've tried both armbian distros, multiple installations of them, nmap shows port 22 closed and ssh connection is refused.
guidol Posted July 23, 2019 Posted July 23, 2019 4 hours ago, abigailrose said: I can't connect via serial console either. I have a USB/TTL cable (tested the cable to make sure it works by shorting white to green I dont know which one of the green/white cable is RX and which is TX, but the have to cross-connect RX -> TX TX -> RX and GND -> GND If your adapter does support it (via jumper setting), set it to 3.3V and your terminal program to 115.200 Baud
abigailrose Posted July 24, 2019 Posted July 24, 2019 19 hours ago, guidol said: I dont know which one of the green/white cable is RX and which is TX, but the have to cross-connect RX -> TX TX -> RX and GND -> GND I did this and now I get console output! But I'm still not sure of how to fix the ssh problem. 1
martinayotte Posted July 24, 2019 Posted July 24, 2019 22 minutes ago, abigailrose said: I did this and now I get console output! But I'm still not sure of how to fix the ssh problem. Since that you now been able to log into console using serial, check "ifconfig" to see network interfaces. Then try "nmtui" to enable interfaces.
ReefBum Posted August 24, 2019 Posted August 24, 2019 I had similar issue with Rock64 armbian buster trying to boot headless with USB WiFi I did change the boot firstrun txt to enable WiFi and set ssid/pass but it would never connect to AP for SSH access Unlike OP I had access to monitor, I found that the boot process stopped when asking to login root and change root password and create user Using monitor/keyboard, after changing root pass and creating user, I had to run armbian-config to have the WiFi connect After this it ran perfectly as headless and I was able to continue setup via SSH Would not been a good day had I been like OP with no access to monitor / keyboard
