Igor Posted May 5, 2019 Posted May 5, 2019 added support for boards that export temperature elsewhere (for example meson64-next/dev)
lxde-OSIREN Posted May 6, 2019 Posted May 6, 2019 apt-get install lm-sensors shows core temperatures, but the new htop shows temperatures now?
guidol Posted May 6, 2019 Posted May 6, 2019 23 minutes ago, ftp-bin2fex said: but the new htop shows temperatures now? yes it does The following packages will be upgraded: htop Need to get 75.8 kB of archives. Get:1 https://apt.armbian.com stretch/main arm64 htop arm64 2.1.2-3 [75.8 kB] Fetched 75.8 kB in 1s (56.4 kB/s) Unpacking htop (2.1.2-3) over (2.1.1-3) ...
lxde-OSIREN Posted May 6, 2019 Posted May 6, 2019 that's good, I setup up custom watercooling for poweredge 1950 harpertown cpu and I had setup an app to check lm-sensors from android, would always be 49 degrees, so the server never made noise again but sometimes it would get pretty hot and shutdown, even blew off the water on the mobo and the end. Specific core temperatures would be even better for htop.
Igor Posted August 2, 2019 Author Posted August 2, 2019 Fixed on Buster and Disco with apt update / upgrade. 1
_r9 Posted August 29, 2019 Posted August 29, 2019 That's really an open minded extension for htop. Fast and simple! I've recognized an issue with temperature on my clearfog pro with Debian buster and stretch. Clearfog Base (Debian Buster) works htop version buster: 2.2.0-3~armbian5.92+1 bpi-m64 (Debian Buster) works htop version buster: 2.2.0-3~armbian5.92+12.1.2-3 bpi-m2+ (Debian Stretch) works htop version stretch: 2.1.2-3 Clearfog pro (Debian Buster and Stretch) doesn't work on a stretch and a buster installation htop version buster: 2.2.0-3~armbian5.92+1 htop version stretch: 2.1.2-3
Igor Posted August 29, 2019 Author Posted August 29, 2019 3 hours ago, _r9 said: doesn't work on a stretch and a buster installation This probably related to the fact that temp values are not on the (standard) locations where htop searches for values. A workaround could be implemented or fix htop ... once
guidol Posted August 30, 2019 Posted August 30, 2019 2 hours ago, guidol said: maybe symbolic-links as workaround? some time ago I had this on a NanoPi K1 Plus: temperature for armbian-monitor and welcome-screen (NPi K1 Plus stable): cd /etc/armbianmonitor/datasources/ ln -s /sys/devices/virtual/thermal/thermal_zone0/temp soctemp ln -s /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp Missing temp in armbianmonitor: find /sys/devices/ -name temp /sys/devices/virtual/thermal/thermal_zone0/temp /sys/devices/virtual/thermal/thermal_zone1/temp Switch zone0 to zone1 for soctemp: rm /etc/armbianmonitor/datasources/soctemp ln -s /sys/devices/virtual/thermal/thermal_zone1/temp /etc/armbianmonitor/datasources/soctemp =================================================================================== cd /etc/armbianmonitor/datasources/ ln -s /sys/devices/virtual/thermal/thermal_zone0/temp soctemp ln -s /sys/devices/virtual/thermal/thermal_zone0/temp /etc/armbianmonitor/datasources/soctemp /usr/lib/file ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp My ln -s /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp cat /sys/devices/virtual/thermal/thermal_zone0/temp cat /sys/devices/virtual/thermal/thermal_zone0/temp echo 'nameserver 192.168.6.3' >> /etc/resolv.conf echo 200000 > /sys/devices/system/cpu/cpufreq/ondemand/sampling_rate ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp /usr/lib/armbian/armbian-hardware-monitor # SoC temp: check sun7i legacy exception first, then standard path(s) if [[ -f /sys/class/hwmon/hwmon0/temp1_input ]]; then # usual convention with modern kernels ln -fs /sys/class/hwmon/hwmon0/temp1_input /etc/armbianmonitor/datasources/soctemp fi ===================================================================================
@lex Posted August 30, 2019 Posted August 30, 2019 The path is hard coded in the HTOP for the cpu temp. I think the problem is that some boards (kernel) use the hwmon driver and sometimes different kernel config. I think the best approach would be to traverse /sys and try to find the label for the cputemp / gputemp / regulators, etc.. But what exactly look for to be Universal? In my x64 for example, same Intel, different kernel configs (server vs desktop) points to different locations: cat /sys/devices/platform/coretemp.0/hwmon/hwmon1/temp2_label Core 0 cat /sys/devices/platform/coretemp.0/hwmon/hwmon1/temp3_label Core 1 cat /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp2_label Core 0
_r9 Posted September 13, 2019 Posted September 13, 2019 Hey guys, thanks for helping me out and sorry for the late response. I checked the thermal_zone as @guidoldescriped cat /sys/devices/virtual/thermal/thermal_zone0/temp 84164 I also checked the link inside _/etc/armbianmonitor/datasources_ ls -l total 0 lrwxrwxrwx 1 root root 47 Aug 28 10:40 soctemp -> /sys/devices/virtual/thermal/thermal_zone0/temp It's all the same on the Clearfog pro as it is on the Clearfog base @lex I cannot find a value like *temp[0-9]_label* But maybe this output can help find /sys/devices/ |grep temp[0-9] /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:0f/hwmon/hwmon7/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:04/hwmon/hwmon6/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:02/hwmon/hwmon4/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:00/hwmon/hwmon2/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:03/hwmon/hwmon5/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:04/mdio_bus/mv88e6xxx-0/mv88e6xxx-0:01/hwmon/hwmon3/temp1_input /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_max_alarm /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_crit /sys/devices/platform/soc/soc:internal-regs/f1072004.mdio/mdio_bus/f1072004.mdio-mii/f1072004.mdio-mii:00/hwmon/hwmon0/temp1_input /sys/devices/virtual/thermal/thermal_zone0/hwmon1/temp1_input @Igor I have also noticed that the *CpuFreq[1-9]: ... MHz* section is missing in the htop frontend too, on all of my _Clearfog Pro_ devices When I open up the /usr/bin/htop it looks like that there you can see the hardcoded files u: ^@^@^@show processes of a single user^@ H: ^@^@^@hide/show user process threads^@^@ K: ^@^@^@hide/show kernel threads^@^@^@^@ F: ^@^@^@cursor follows process^@^@ F6 + -: ^@^@^@expand/collapse tree^@^@^@^@ P M T: ^@^@^@sort by CPU%, MEM% or TIME^@^@ I: ^@^@^@invert sort order^@^@^@ F6 > .: ^@^@^@select sort column^@^@Environment of process %d - %s^@^@Could not read process environment.^@Refresh^@"^@^@^@/sys/class/thermal/thermal_zone0/temp^@^@^@/sys/devices/virtual/thermal/thermal_zone0/temp^@/sys/class/hwmon/hwmon0/temp1_input^@/sys/devices/system/cpu/cpu%d/cpufreq/cpuinfo_cur_freq^@^@/sys/devices/platform/soc/7081400.i2c/i2c-0/0-0036/regulator/regulator.1/microvolts^@/sys/devices/platform/soc/1f02400.i2c/i2c-4/4-0065/regulator/regulator.5/microvolts^@/sys/devices/platform/ff3c0000.i2c/i2c-0/0-001b/regulator/regulator.12/microvolts^@^@^@/sys/devices/platform/ff3c0000.i2c/i2c-0/0-0040/regulator/regulator.9/microvolts^@^@^@^@/sys/devices/system/cpu/cpu%d/cpufreq/cpuinfo_max_freq^@^@/proc/uptime^@^@^@^@%64lf^@^@^@/proc/loadavg^@^@^@%32lf %32lf %32lf %32d/%32d %32d^@^@^@^@/proc/sys/kernel/pid_max^@^@^@^@/proc/%d/environ^@^@^@^@ 0 Cancel^@^@^@ 1 SI The following files are available cat /sys/devices/virtual/thermal/thermal_zone0/temp 66548 cat /sys/class/hwmon/hwmon0/temp1_input 62000 cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq cat: /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq: No such file or directory cat /sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq cat: /sys/devices/system/cpu/cpu1/cpufreq/cpuinfo_cur_freq: No such file or directory This is all exactly the same on my Clearfog Base. But now I can see that on the Clearfog Base the CpuFreq is 0 Mhz. So the issue changed to Clearfog Base: Shows 0 MHz because the hardcoded files are missing Clerafog Pro: Doesn't show that sections at all. It looks like this htop doesn't have this features at all Aaaaaahhhhhh!!!! Ok inside htop on the Clearfog Pro's I had to configure the Frequency and Temperature. Solution Enter htop Press F2 Another Update On my Clearfog Pro does the file **/sys/devices/system/cpu/cpufreq/policy0/scaling_cur_freq** exist and its content switches between 800 and 1600 this is shown in htop On the Clearfog Base is the whole directory **/sys/devices/system/cpu/cpufreq/** empty
@lex Posted September 13, 2019 Posted September 13, 2019 Please check if you have: cat /sys/class/hwmon/hwmon0/name
_r9 Posted September 14, 2019 Posted September 14, 2019 @lex yes this file exists on both devices with following content cat /sys/class/hwmon/hwmon0/name f1072004mdiomii00
@lex Posted September 14, 2019 Posted September 14, 2019 According to this: https://github.com/armbian/build/blob/master/packages/bsp/helios4/90-helios4-hwmon.rules , it is not related to CPU temp. My guess is just a missing kernel config.
Beurett Posted September 23, 2019 Posted September 23, 2019 Hi, I'm Nanopi M4 user with Armbian Buster 5.95 and kernel 4.4.190-rk3399. I found some weird behavior that put label which indicates big.LITTLE wrongly to each core. please refer this: https://forum.armbian.com/topic/11698-nanopi-m4-htop-recognizes-all-cores-as-little-cores Installed htop version is: 2.2.0-3~armbian5.92+1 arm64.
guidol Posted October 28, 2019 Posted October 28, 2019 Strange (for me) I got one NanoPi Neo2 LTS (1GB) and 2 NanoPi Neo2 non-LTS (512MB) and alle three got the same dev-armbian: non-LTS: Debian Buster with Armbian Linux 5.3.7-sunxi64 package bsp-kernel[5.98.191027] u-boot[5.90] dtb[5.98.191027] firmware[5.98] config[5.98] armbian branch [dev] LTS: Debian Buster with Armbian Linux 5.3.7-sunxi64 package bsp-kernel[5.98.191027] u-boot[5.98] dtb[5.98.191027] firmware[5.98] config[5.98] armbian branch [dev] but on the LTS Neo2 htop does show temperature and CPU-Speeds and on the 2 non-LTS it doesnt show it The armbian on the LTS Neo2 was complied fresh yesterday and the armbian on the 2 non-LTS is updated via apt update/upgrade. On all three armbianmonitor and the login does show the temperature. Quote This probably related to the fact that temp values are not on the (standard) locations where htop searches for values. A workaround could be implemented or fix htop ... once @Igor where can I read about /check the (standard) locations? I want to see whats missing on the non-LTS Neo2. htop version is on all three devices 2.2.0-3~armbian5.92+1 arm64
Igor Posted October 28, 2019 Author Posted October 28, 2019 5 minutes ago, guidol said: it doesnt show It shows values 0 or nothing at all? If this is the case, then htop user configuration is either wrong, missing has wrong permissions ... htop config is inside your home directory, .system/htop/something ...
guidol Posted October 28, 2019 Posted October 28, 2019 11 minutes ago, Igor said: It shows values 0 or nothing at all? If this is the case, then htop user configuration is either wrong, missing has wrong permissions ... htop config is inside your home directory, .system/htop/something ... Many Thanks! htop didnt show anything on the non-LTS Neo2 = upgraded armbian. I copied the content of the ~/.config/htop/htoprc from the working to the non-working Neo2 and now htop does show temperature and cpu-speeds also on the other system non-working htoprc: Spoiler # Beware! This file is rewritten by htop when settings are changed in the interface. # The parser is also very primitive, and not human-friendly. fields=0 48 17 18 38 39 40 2 46 47 49 1 sort_key=40 sort_direction=1 hide_threads=0 hide_kernel_threads=1 hide_userland_threads=0 shadow_other_users=0 show_thread_names=0 show_program_path=1 highlight_base_name=0 highlight_megabytes=1 highlight_threads=1 tree_view=0 header_margin=1 detailed_cpu_time=0 cpu_count_from_zero=0 update_process_names=0 account_guest_in_cpu_meter=0 color_scheme=0 delay=15 left_meters=AllCPUs Memory Swap left_meter_modes=1 1 1 right_meters=Tasks LoadAverage Uptime right_meter_modes=2 2 2 working htoprc: Spoiler # Beware! This file is rewritten by htop when settings are changed in the interface. # The parser is also very primitive, and not human-friendly. fields=0 48 17 18 38 39 40 2 46 47 49 1 sort_key=46 sort_direction=1 hide_threads=0 hide_kernel_threads=1 hide_userland_threads=0 shadow_other_users=0 show_thread_names=0 show_program_path=1 highlight_base_name=0 highlight_megabytes=1 highlight_threads=1 tree_view=0 header_margin=1 detailed_cpu_time=0 cpu_count_from_zero=0 update_process_names=0 account_guest_in_cpu_meter=0 color_scheme=0 delay=15 left_meters=AllCPUs Memory Swap CpuTemp left_meter_modes=1 1 1 2 right_meters=Hostname Tasks LoadAverage Uptime CpuFreq(1) CpuFreq(2) CpuFreq(3) CpuFreq(4) right_meter_modes=2 2 2 2 2 2 2 2 1
schwar3kat Posted October 28, 2019 Posted October 28, 2019 Thanks @Guidol, I had the same issue with Orange Pi Zero Plus. One showed Cpu Temp And Cpu Frequency. Two did not show the options. ~/.config/htop/htoprc was blank on the two that did not work. Changing settings on htop did not populate the file and settings were lost between sessions. File permissions were the same for all three. I copied the working htoprc to the other two and this solved the problem. 1
guidol Posted October 28, 2019 Posted October 28, 2019 5 minutes ago, Elektrický said: ~/.config/htop/htoprc was blank on the two that did not work. File permissions were the same for all three. I also had on all 3 Neo2 the same file-permissions: ls -l ~/.config/htop/htoprc -rw-r--r-- 1 root root 738 Okt 28 10:29 /root/.config/htop/htoprc and only on my non-root user guido there was a htop-directory, but no htoprc - maybe because I didnt started htop as guido in the past
