After installation, /etc/apt/apt.conf.d/50unattended-upgrades is empty.
What is the proper origins to automatically install at least security patches?
9 hours ago, mbarmem said:
Any possibility to send an email notification after running unattended-upgrades?
Anything is possible. See manual if this is build in otherwise make scripts ...
I updated to armbian 20.02.
Now 50unattended-upgrades is removed and 02-armbian-periodic is set to default.
How can i permanently save unattended-upgrade config-files?
Did not try this by myself yet, but you could give "dpkg-reconfigure unattended-upgrades" a shot.
20 minutes ago, Henrik said:
Packages that were upgraded:
 linux-buster-root-current-bananapi linux-dtb-current-sunxi
 linux-image-current-sunxi linux-u-boot-bananapi-current
After the upgrade:
Any other ideas to save config permanently ?
Make your config file and run "dpkg-divert --no-rename --add /path/to/configfile" -- this should prevent any upgrades from touching or even renaming the config file.
I will give it a try.
dpkg-divert --no-rename --add /etc/apt/apt.conf.d/02-armbian-periodic
dpkg-divert --no-rename --add /etc/apt/apt.conf.d/50unattended-upgrades
