jwp1000 Posted August 26, 2019 Share Posted August 26, 2019 Hi Team I have two brand new Orange PI Zero LTS. Is this supported with the normal Zero download? Thanks 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted August 27, 2019 Share Posted August 27, 2019 Xulung states that the hardware is basically identical. They just rearranged stuff to reduce wire length and various other optimizations like that. So yes, the software is the same in every aspect. 0 Quote Link to comment Share on other sites More sharing options...
jwp1000 Posted August 27, 2019 Author Share Posted August 27, 2019 Hi Werner, yes I downloaded the software and it worked just as it had with the prior version of Debian no problem. Debian Buster seems really stable. Please note it's almost always better to get a local purchased power supply. I got mine from Conrad for Raspberry 3B and it works great with both my new OrangePI Zero LTS. 0 Quote Link to comment Share on other sites More sharing options...
renaudrenaud Posted February 12, 2021 Share Posted February 12, 2021 Question: does the so so WIFI is better with the LTS than the original Pi Zero? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted February 13, 2021 Share Posted February 13, 2021 No. Same crappy chip. 0 Quote Link to comment Share on other sites More sharing options...
DeterminedOpier Posted May 10, 2023 Share Posted May 10, 2023 The newer H3 version of the LTS does not seem to work at all with available images, though I haven't tried it yet on the OpiPC image. It has that same Pulse chip that I don't think the OpiPC has on it. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 12, 2023 Share Posted May 12, 2023 On 5/10/2023 at 4:32 AM, DeterminedOpier said: The newer H3 version of the LTS does not seem to work at all with available images Can you post a hires picture of pcb from both sides? 0 Quote Link to comment Share on other sites More sharing options...
mc510 Posted May 19, 2023 Share Posted May 19, 2023 On 5/9/2023 at 7:32 PM, DeterminedOpier said: The newer H3 version of the LTS does not seem to work at all with available images FWIW, I just received a new OPi0 LTS H3 today and popped in a microsd with Armbian 23.02 Bullseye. Started up properly and seems to be working fine. Haven't pushed the wifi at all hard yet, but even that has been okay so far. 0 Quote Link to comment Share on other sites More sharing options...
johhen Posted June 5, 2023 Share Posted June 5, 2023 (edited) FWIW - I have an H3 OrangePi Zero LTS on my desk - 23.5.1 Jammy/Bookworm were unbootable, hanging on Starting Kernel... Armbian_23.5.1_Orangepizero_jammy_current_6.1.30.img.xz Armbian_23.5.1_Orangepizero_bookworm_current_6.1.30_minimal.img.xz Using Armbian_23.02.2_Orangepizero_bullseye_current_5.15.93_minimal.img.xz It booted straight away. Edited June 5, 2023 by johhen 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted June 5, 2023 Share Posted June 5, 2023 Known issue. Either stick with the older release for now or go for edge based: https://github.com/armbian/community 0 Quote Link to comment Share on other sites More sharing options...
