SaiHou Posted August 29, 2019 Posted August 29, 2019 Hello everyone, I am looking for an answer regarding the Orange Pi PC2 Armbian OS is 32-bit or 64-bit version? Thanks in advance. Best regards, SaiHou
SaiHou Posted August 29, 2019 Author Posted August 29, 2019 On 8/29/2019 at 1:14 PM, guidol said: armbian for OPi PC2 H5-CPU is 64bit (aarch64) Expand @guidol, Thanks for the info. Is it possible to get 32-bit Armbian for it to run on OPi PC2? Regards.
martinayotte Posted August 29, 2019 Posted August 29, 2019 On 8/29/2019 at 1:24 PM, SaiHou said: Is it possible to get 32-bit Armbian for it to run on OPi PC2? Expand No ! Armbian is built for native capabilties ! But why do you need it in 32 bits ? If you have a closed source application which is only available in 32 bits, you can still install required 32 bits libraries, such libc ... 1
SaiHou Posted August 29, 2019 Author Posted August 29, 2019 On 8/29/2019 at 1:29 PM, martinayotte said: No ! Armbian is built for native capabilties ! But why do you need it in 32 bits ? If you have a closed source application which is only available in 32 bits, you can still install required 32 bits libraries, such libc ... Expand @martinayotte, Thanks for the reply. I don't know what version of OS does Raspbian Stretch / Buster is... But for sure some application package cannot be installed in "aarch64" or "meson64" due to no such packages available. That is why I ask such "question" in this forum. I have OPi PC (H3) and most what Raspbian packages can installed, the same as armbian for OPi PC also can be installed. I think I stick back to OPi PC (H3). I am just beginner, so not much knowledge I have on armbian or raspbian. Thanks mates.
Igor Posted August 29, 2019 Posted August 29, 2019 On 8/29/2019 at 2:37 PM, SaiHou said: But for sure some application package cannot be installed Expand 1
SaiHou Posted August 29, 2019 Author Posted August 29, 2019 On 8/29/2019 at 3:32 PM, Igor said: Expand @Igor, Thanks for the info. I refer to the page you shared and follow the instructions and now it works on my Nano Pi K2 Amlogic S905. Really appreciated your support team here. Best regards.
