juan Posted December 10, 2019 Posted December 10, 2019 Hi guys a having problems to boot the latest armbian buster 5.3.Y kernel on the orange pi win plus. I tested other older kernels(4.19 and 3.xx) and worked fine except for Bluetooth and WiFi hotspot. I am trying to upgrade to buster 5.3 but always as result kernel panic(same on bionic and stretch 5.3). power supply is ok and tested on 3 microsd card. this is the debug information from an ttyS0 consoles it is continues rebooting. need some help debug.txt
Werner Posted December 11, 2019 Posted December 11, 2019 Quote upgrade Just for the heck of it did you try using a fresh image on a different sd card?
juan Posted December 11, 2019 Author Posted December 11, 2019 I tried all of the https://www.armbian.com/orange-pi-win/ 5.3.y images. The 4.19 works perfect.
t-bob Posted December 11, 2019 Posted December 11, 2019 Best of luck with this one as I've never had any success with a 5.x dev image. If you install a 4.x image then use armbian-config to switch to the nightly stream you can get a 5.x kernel booting.
juan Posted December 16, 2019 Author Posted December 16, 2019 thanks t-bob , i changed to other kernels in armbian-config and choose 5.4.2-sunxi64 #19.11.3.349 now i have buster with kernel 5.4.2. hope apt update ,apt upgrade wont mess it up.
Igor Posted December 16, 2019 Posted December 16, 2019 3 hours ago, juan said: apt upgrade wont mess it up It will upgrade to more recent DEV kernels if you will run apt update and upgrade unless you choose to freeze kernel updating in armbian config or manually (not recommended).
LionG Posted December 17, 2019 Posted December 17, 2019 I have too problem with 5.3.* kernel on orange pi win plus. I was try update 4.19 to 5.3.* from nightly, its working but after some reboot already kernel panic.
