bbayin 0 Posted December 25, 2019 Share Posted December 25, 2019 Previously worked, but not now. I am stuck in the login line and cannot login with the keyboard from the putty screen. I cant login with keyboard on USB2. Also HDMI not working. HDMI previously worked too. I am newbie. Thanks in advance. I cant remember which version loaded on the eMMC. U-Boot SPL 2019.04-armbian (Jul 06 2019 - 20:55:41 +0200) DRAM: 2048 MiB Trying to boot from MMC2 NOTICE: BL31: v2.1(debug):bb2d778-dirty NOTICE: BL31: Built : 20:55:33, Jul 6 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc079e78, model: OrangePi 3 INFO: ARM GICv2 driver initialized NOTICE: PMIC: Probing AXP805 NOTICE: PMIC: AXP805 detected INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.04-armbian (Jul 06 2019 - 20:55:41 +0200) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from EXT4... Card did not respond to voltage select! In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3042 bytes read in 1 ms (2.9 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 0 ms Card did not respond to voltage select! 29583 bytes read in 5 ms (5.6 MiB/s) 4161 bytes read in 3 ms (1.3 MiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 9135838 bytes read in 923 ms (9.4 MiB/s) 15147016 bytes read in 1530 ms (9.4 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9135774 Bytes = 8.7 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 49749000, end 49fff69e ... OK Loading Device Tree to 00000000496d9000, end 0000000049748fff ... OK Starting kernel ... Ubuntu 18.04.3 LTS orangepi3 ttyS0 orangepi3 login: And This one is Armbian_19.11.4_Orangepi3_bionic_current_5.4.6_desktop with SDCard boot. (2019-12-23) U-Boot SPL 2019.10-armbian (Dec 23 2019 - 09:47:42 +0100) DRAM: 2048 MiB Trying to boot from MMC1 NOTICE: BL31: v2.2(debug):aeb3d83-dirty NOTICE: BL31: Built : 09:47:34, Dec 23 2019 NOTICE: BL31: Detected Allwinner H6 SoC (1728) NOTICE: BL31: Found U-Boot DTB at 0xc07f048, model: OrangePi 3 INFO: ARM GICv2 driver initialized INFO: PMIC: Probing AXP805 on I2C INFO: PMIC: aldo1 voltage: 3.300V INFO: PMIC: aldo2 voltage: 3.300V INFO: PMIC: aldo3 voltage: 3.300V INFO: PMIC: bldo1 voltage: 1.800V INFO: PMIC: bldo2 voltage: 1.800V INFO: PMIC: bldo3 voltage: 1.800V INFO: PMIC: cldo1 voltage: 3.300V INFO: PMIC: dcdcd voltage: 0.960V INFO: PMIC: dcdce voltage: 1.200V INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2019.10-armbian (Dec 23 2019 - 09:47:42 +0100) Allwinner Technology CPU: Allwinner H6 (SUN50I) Model: OrangePi 3 DRAM: 2 GiB MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: No ethernet found. Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3033 bytes read in 12 ms (246.1 KiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 165 bytes read in 7 ms (22.5 KiB/s) 31388 bytes read in 39 ms (785.2 KiB/s) 4161 bytes read in 40 ms (101.6 KiB/s) Applying kernel provided DT fixup script (sun50i-h6-fixup.scr) ## Executing script at 44000000 9549521 bytes read in 1010 ms (9 MiB/s) 15685640 bytes read in 1650 ms (9.1 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9549457 Bytes = 9.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 496e4000, end 49fff691 ... OK Loading Device Tree to 0000000049673000, end 00000000496e3fff ... OK Starting kernel ... [ 17.213687] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1 [ 17.222692] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 17.386257] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1 [ 17.395289] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 17.428555] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1 [ 17.437574] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 17.466272] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1 [ 17.475285] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 17.504444] dwmac-sun8i 5020000.ethernet eth0: no phy at addr -1 [ 17.513515] dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Armbian 19.11.4 Bionic ttyS0 orangepi3 login: 0 Quote Link to post Share on other sites
Igor 2200 Posted December 26, 2019 Share Posted December 26, 2019 1 hour ago, bbayin said: dwmac-sun8i 5020000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Yes, I can confirm that I also notice those problems, but didn't have time to look yet. However I do have HDMI. Perhaps this blacks out by random ... also possible. In any case, there is still some work. 0 Quote Link to post Share on other sites
bbayin 0 Posted December 26, 2019 Author Share Posted December 26, 2019 Thanks for reply. I tried with old led tv this morning and HDMI is worked. Previously i tried with samsung smart tvs 3 HDMI connections and it doesnt worked. But now i cant got audio on HDMI connection. I dont try analog audio output. 0 Quote Link to post Share on other sites
Igor 2200 Posted December 26, 2019 Share Posted December 26, 2019 8 minutes ago, bbayin said: Thanks for reply. I tried with old led tv this morning and HDMI is worked. Previously i tried with samsung smart tvs 3 HDMI connections and it doesnt worked. But now i cant got audio on HDMI connection. I dont try analog audio output. Not sure if we have HDMI audio driver enabled yet. First support stage is focused to server cases, general stability ... things like multimedia comes later. 0 Quote Link to post Share on other sites
jernej 212 Posted December 26, 2019 Share Posted December 26, 2019 @bbayin Can you try this kernel patch to see if it helps with your "no HDMI output" issue? https://github.com/jernejsk/linux-1/commit/8c3e6bc8a98212a18536d54e23421036891e832b If so, I'll send fix upstream. 0 Quote Link to post Share on other sites
bbayin 0 Posted December 26, 2019 Author Share Posted December 26, 2019 10 hours ago, Igor said: Not sure if we have HDMI audio driver enabled yet. First support stage is focused to server cases, general stability ... things like multimedia comes later. Of course it is. I wanted to point out the problem I was experiencing because you are doing a good job. I'm trying to understand something myself from the forum. 10 hours ago, jernej said: @bbayin Can you try this kernel patch to see if it helps with your "no HDMI output" issue? https://github.com/jernejsk/linux-1/commit/8c3e6bc8a98212a18536d54e23421036891e832b If so, I'll send fix upstream. I haven't got file like "sun8i_hdmi_phy.c". Do I need to create and put this file on my own? There is a file named sun6i_mipi_dsi.ko instead. 0 Quote Link to post Share on other sites
jernej 212 Posted December 26, 2019 Share Posted December 26, 2019 @bbayin that is fix for kernel source - you need to rebuild kernel with that patch. 0 Quote Link to post Share on other sites
bbayin 0 Posted December 26, 2019 Author Share Posted December 26, 2019 @jernej so i will wait for now. Thanks for your help 0 Quote Link to post Share on other sites
jernej 212 Posted December 27, 2019 Share Posted December 27, 2019 wait for what? Until someone confirms that this actually fixes something, it's not going anywhere. 0 Quote Link to post Share on other sites
megi 17 Posted December 27, 2019 Share Posted December 27, 2019 On 12/26/2019 at 1:15 AM, Igor said: Yes, I can confirm that I also notice those problems, but didn't have time to look yet. However I do have HDMI. Perhaps this blacks out by random ... also possible. In any case, there is still some work. The reason for gphy not working is this: INFO: PMIC: aldo2 voltage: 3.300V ATF is enabling aldo2 which is half of the phy supply, whithout enabling the other half. When Linux enables the other half later on, it's too late and phy is in a broken state. The phy regulators have to be enabled at the same time. This bug was discussed on IRC, but it looks like nobody fixed this, and the broken code got pushed to ATF master, where the Armbian is pulling it from. The fix is to downgrade ATF. The issue is basically that ATF is enabling all AXP regulators that are referenced by anything in the DTS, which is non-sensical. Device drivers should be enabling regulators for the devices they manage in a proper order. 0 Quote Link to post Share on other sites
Igor 2200 Posted December 27, 2019 Share Posted December 27, 2019 1 hour ago, megi said: The fix is to downgrade ATF. Thank you for the tip! Solved this way: https://github.com/armbian/build/commit/b7a329854d8d65297222cfa9932b9cd432b361cc 0 Quote Link to post Share on other sites
bbayin 0 Posted December 27, 2019 Author Share Posted December 27, 2019 6 hours ago, jernej said: wait for what? Until someone confirms that this actually fixes something, it's not going anywhere. Youre right but i dont know how rebuild and fix kernel. 0 Quote Link to post Share on other sites
martinayotte 674 Posted December 27, 2019 Share Posted December 27, 2019 5 hours ago, Igor said: Solved this way: https://github.com/armbian/build/commit/b7a329854d8d65297222cfa9932b9cd432b361cc I'm confirm this is the fix ! I've done a 5.5.0-rc2 build yesterday and figured out that I've lost the ETH0 that was working in my previous 5.4.1 build. I've only updated the U-Boot with the ATF v2.2, and it came back ... 0 Quote Link to post Share on other sites
