harve186 Posted January 20, 2020 Posted January 20, 2020 I need the install php > 7.0 for Nextcloud 16.07. I have installed php 7.4 successfull but I don't get php7.4-gd installed php7.4-gd : Depends: libgd3 (>= 2.1.1) but it is not going to be installed When I try to install libgd3 I'm getting these errors libgd3 : Depends: libpng12-0 (>= 1.2.13-4) but it is not installable Depends: libwebp5 but it is not installable How get I solved this issue ??
Igor Posted January 20, 2020 Posted January 20, 2020 3 hours ago, harve186 said: How get I solved this issue ?? By using Google and Nextcloud support if exists. This is not specifically related to Armbian. Armbian has identical packages relation as Debian or Ubuntu. If you find a solution for them, you find solution for Armbian.
harve186 Posted January 21, 2020 Author Posted January 21, 2020 12 hours ago, Igor said: This is not specifically related to Armbian. NO, it is armbian related. Because in standard Jessy repro the php7.4-gd is available and I only need 'apt install php7.4-gd' But in armbian repo it is NOT available. So it is absolute armbian related !!!!!
Igor Posted January 21, 2020 Posted January 21, 2020 4 minutes ago, harve186 said: So it is absolute armbian related !!!!! Good, get Angel subscription and I will do a research on your cost and give you a detailed answer.
harve186 Posted January 21, 2020 Author Posted January 21, 2020 thx, but it seems I have found a working repo here https://stackoverflow.com/questions/55318499/install-php-gd-ext-on-debian
TRS-80 Posted January 21, 2020 Posted January 21, 2020 13 minutes ago, harve186 said: on-debian Seems I recall hearing that somewhere before...
Werner Posted January 22, 2020 Posted January 22, 2020 You know that the official support for Debian Jessie ends in June 2020, do you? So I am not sure if it is worth playing around with backports....
