opfer15 Posted April 20, 2020 Share Posted April 20, 2020 (edited) Wow thanks thats a leap forward in using armbian on the M8S Pro L S912 LB, as it quits with the same error. Thanks for your explanation and help. Could you also point out, on how to dump and reflash uboot env with root terminal,twrp or fastboot as far as i checked against /dev/block/env it is the same enviroment as in your u-boot On 2/11/2020 at 1:04 AM, 5p0ng3b0b said: The solution: I didn't want to go down the uart/uboot route as I don't know where the tx/rx points are on this box and my eyesight isn't that great anymore. Plus my soldering days were over many years ago. I was able to boot into a twrp.zip via stock recovery, but there was no setenv command in the twrp console to enter the info manually. Perhaps there is a command I could enter to run the aml_autoscript from here, I have no idea. I decided the way forward was to extract the env partition with twrp (you can just as easily do it with dd or fastboot) and hack it before flashing it back. I opened the file up with a hex editor and could see what looked like a uboot environment with fatload commands etc, a 4 byte header at the start of the file then each command separated by a null byte. I'm looking at yet another brick if I bork it, so I'm not doing this with a hex editor. Convert it to a text file, make the changes and convert the text file back to the original 8mb image format was the plan. All I had to do was trim the trailing zeros and replace the remaining null bytes with a newline. I copied the file to my PC to do the job but it can all be done from a rooted box with busybox installed. Edited April 20, 2020 by opfer15 Link to comment Share on other sites More sharing options...
gabe5000 Posted April 21, 2020 Share Posted April 21, 2020 I've been using Armbian on my x96 air for about a month, without any issue. But yesterday I upgraded the system, there was a kernel update if I'm not mistaken. And since then my 5G wifi doesn't work. Also this morning my system freezed, completely, which never had happened before. What can I do? Maybe can I restore the previous kernel somehow? Link to comment Share on other sites More sharing options...
gabe5000 Posted April 21, 2020 Share Posted April 21, 2020 Now I cannot even poweroff: the system stops at "Detaching DM services". Link to comment Share on other sites More sharing options...
Franck E Posted April 25, 2020 Share Posted April 25, 2020 Just came across this site, and I am interested in testing Ubuntu Bionic version for s905x3 air. From what I read, it should be at least Armbian_20.05.0_Arm-64_bionic_current_5.6.0-rc6_desktop_20200326.img but cannot find it on this site... Can someone points me towards the latest img link please? Link to comment Share on other sites More sharing options...
Diamond Posted May 6, 2020 Share Posted May 6, 2020 On 4/25/2020 at 3:16 PM, Franck E said: Just came across this site, and I am interested in testing Ubuntu Bionic version for s905x3 air. From what I read, it should be at least Armbian_20.05.0_Arm-64_bionic_current_5.6.0-rc6_desktop_20200326.img but cannot find it on this site... Can someone points me towards the latest img link please? Check this https://yadi.sk/d/_rQgn_FosYuW0g/20.05/20200326 Link to comment Share on other sites More sharing options...
Diamond Posted May 6, 2020 Share Posted May 6, 2020 On 2/8/2020 at 11:54 PM, srx said: I've spent hours today playing with dtb parameters and whatnot. So far nothing. Yes, Android dtb and dtb in this image are different. But I can not just copy-paste it. It is all related and pretty difficult to understand. All I have is dmesg saying that SD card appeared, it is detected. Even partitions are detected and then it dissapears. But why it dissapears? SDXC card seems to appear, then dissapear, then appear again... [ 88.606168] mmc0: new high speed SDHC card at address aaaa [ 88.607742] mmcblk0: mmc0:aaaa SP32G 29.7 GiB [ 88.610100] mmcblk0: p1 p2 [ 89.637741] mmc0: card aaaa removed [ 89.731537] mmc0: error -84 whilst initialising SD card [ 90.824315] mmc0: error -84 whilst initialising SD card [ 91.912485] mmc0: error -84 whilst initialising SD card Keeps repeating the last message about once per second. /.../ Another card: [ 441.699628] mmc0: new high speed SDXC card at address aaaa [ 441.701190] mmcblk0: mmc0:aaaa SR64G 59.5 GiB [ 441.706375] mmcblk0: unable to read partition table [ 441.707109] mmc0: card aaaa removed [ 441.709786] udevd[2335]: inotify_add_watch(7, /dev/mmcblk0, 10) failed: No such file or directory [ 441.815132] mmc0: new high speed SDXC card at address aaaa [ 441.816655] mmcblk0: mmc0:aaaa SR64G 59.5 GiB [ 441.819250] mmcblk0: p1 p2 [ 441.890260] blk_update_request: I/O error, dev mmcblk0, sector 124735472 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [ 441.957930] blk_update_request: I/O error, dev mmcblk0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [ 442.031386] blk_update_request: I/O error, dev mmcblk0, sector 8 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0 [ 442.034128] blk_update_request: I/O error, dev mmcblk0, sector 8 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0 EDIT: The same card/image/kernel that gives endless -84 errors boots just fine in another device. I just changed dtb to match hardware and started it up in Nexbox A95X (s905x/2GB/8GB). No errors, starts just fine. In A95X F3 Air (S905x3/4GB/32GB) still no luck. I have no time to do more research at the moment. Maybe I'll try again next weekend. Hello, Have you manged to get Micro SD card work? I am having same problem with repeated error mmc1 error -84 whilst initialising sd card My box is X96 Air P3 - 4G RAM, 32G ROM My MicroSD card is SamsungEVO plus U1 32G. Detail: Link to comment Share on other sites More sharing options...
Azarael Posted May 6, 2020 Share Posted May 6, 2020 I've tried all the suggestions in this topic but still can't get the colors fixed on boot. Using the image from the other topic 'Single Armbian image for RK + AML + AW', writing to a micro sd card, edit the uEnv.txt to use meson-sm1-sei610.dtb and all boots fine except for the messed up colors. When the u-boot.sd is renamed to u-boot.ext, then the box won't boot at all. This is suggested at the start of this topic, but it's then said it doesn't work. Then there is a suggestion of downloading the latest fix, or applying an update consisting of three files. Not sure where these files are, or where the latest patch is, the only link mentioned at the start of this topic is now dead, but was able to download earlier. File was called 'boot.S905X3.7z' and contains boot.ini, s905_autoscript and u-boot.ext, but using these files also results in no boot. I noticed these files refer to the older uEnv.ini, and so are incompatible with the new uEnv.txt used in the 'Single Armbian Image' mentioned above. If I do need to use a specific image instead for the s905x3, then where can I find it? Does anyone have a suggestion on how to get the colors fixed for the 'Single Armbian Image' in the other topic? In case anyone is interested it's the Magicsee N5 Plus 4gb with internal SATA. If you have the same box and need help let me know, I've set up wifi, hard drive install, ethernet, vnc etc.. Link to comment Share on other sites More sharing options...
rapsacw Posted May 6, 2020 Share Posted May 6, 2020 1 hour ago, Azarael said: When the u-boot.sd is renamed to u-boot.ext, then the box won't boot at all. Try copying u-boot.sd to u-boot.ext instead of renaming. That worked for me (latest 'Single Armbian image for RK + AML + AW' + dtb entry in uEnv.txt). Link to comment Share on other sites More sharing options...
Azarael Posted May 7, 2020 Share Posted May 7, 2020 11 hours ago, rapsacw said: Try copying u-boot.sd to u-boot.ext instead of renaming. That worked for me (latest 'Single Armbian image for RK + AML + AW' + dtb entry in uEnv.txt). This does not work for me, and I think some others as well, as mentioned at the start of this topic. Link to comment Share on other sites More sharing options...
rapsacw Posted May 8, 2020 Share Posted May 8, 2020 22 hours ago, Azarael said: his does not work for me, and I think some others as well, as mentioned at the start of this topic. I have the same box as in the thread you linked to (but turns out with another wifi chip, so no wifi for me). In his next post he says its working for him. Just try this one more time; Download & write the latest universal image (bionic must work, haven't tried the others). Edit the dtb in uEnv.txt. Copy u-boot.sd to u-boot.ext. Start your box to the android recovery menu (toothpick or whatever your box uses for that). Select Update from external media so it installs aml_autoscript.zip that updates your u-boot. Reboot. This worked for me and others, but your box is different than mine. For the color fix the u-boot needs to be upgraded, if somehow your u-boot doesn't change than you would be stuck with the color problem (for now?). Link to comment Share on other sites More sharing options...
root-stas Posted May 8, 2020 Share Posted May 8, 2020 I bought H96 Max X3 box and have happy hour with DTB/Mesa/Panfrost cooking but stay on llvm renderer. At last two week people already run Panfrost on S905X3 (odroid-c4 board). Someone here get Mali-G31 (in S905X3) work with acceleration? Who here with similar box as H96 Max X3 (with S905X3), can you share your DTS/DTB files and few words about what is working and how your filing? Maybe some tall me how properly check panfrost kernel module is working or only loaded? My results after compare DTB from VIM3L / Odroid-C4 / H96 Max X3 Android 9 / and presented here by @ramoncio: BT now is working, for get this - put to folder "/lib/firmware/brcm" file bcm4335c0.hcd from: https://github.com/kszaq/brcmfmac_sdio-firmware-aml/blob/master/firmware/brcm/bcm4335c0.hcd with name "BCM4335C0.hcd" and reboot. IR works and gat messages from remote. System LED working and ready to configure. VFD need proper configuration on bus@40 but that is real. Don't get working yet 3D acceleration in X11 but dmesg tell me about proper loading wifi, eth, bt, vpu, gpu and fb. My files: https://drive.google.com/drive/folders/1FToRIJFOjJudNKrRr7S_GgNX0Q-3DmmF?usp=sharing Link to comment Share on other sites More sharing options...
Azarael Posted May 9, 2020 Share Posted May 9, 2020 On 5/8/2020 at 10:04 AM, rapsacw said: Download & write the latest universal image (bionic must work, haven't tried the others). Edit the dtb in uEnv.txt. Copy u-boot.sd to u-boot.ext. Start your box to the android recovery menu (toothpick or whatever your box uses for that). Select Update from external media so it installs aml_autoscript.zip that updates your u-boot. Reboot. Thanks Rapsacw, Didn't know about this, I thought that copying the u-boot.sd to u-boot.ext abd booting was enough. Although now the problem is the same as With the error E:mmap(0, R, PRIVATE, 6, 0) failed: Invalid argument E:Map of 'udisk/aml_autoscript.zip' failed E:failed to map file Installation aborted And I can't follow 5p0ng3b0b's fix unfortunately, perhaps their solution was before the image was Windows compatable? Any further help would be very appreciated Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 9, 2020 Share Posted May 9, 2020 15 hours ago, root-stas said: I bought H96 Max X3 box and have happy hour with DTB/Mesa/Panfrost cooking but stay on llvm renderer. At last two week people already run Panfrost on S905X3 (odroid-c4 board). Someone here get Mali-G31 (in S905X3) work with acceleration? Who here with similar box as H96 Max X3 (with S905X3), can you share your DTS/DTB files and few words about what is working and how your filing? Maybe some tall me how properly check panfrost kernel module is working or only loaded? My results after compare DTB from VIM3L / Odroid-C4 / H96 Max X3 Android 9 / and presented here by @ramoncio: BT now is working, for get this - put to folder "/lib/firmware/brcm" file bcm4335c0.hcd from: https://github.com/kszaq/brcmfmac_sdio-firmware-aml/blob/master/firmware/brcm/bcm4335c0.hcd with name "BCM4335C0.hcd" and reboot. IR works and gat messages from remote. System LED working and ready to configure. VFD need proper configuration on bus@40 but that is real. Don't get working yet 3D acceleration in X11 but dmesg tell me about proper loading wifi, eth, bt, vpu, gpu and fb. My files: https://drive.google.com/drive/folders/1FToRIJFOjJudNKrRr7S_GgNX0Q-3DmmF?usp=sharing Hi @root-stas, tried your bluetooth firmware workaround and while dmesg now loads the firmware: [ 7.869610] Bluetooth: hci1: BCM: chip id 86 [ 7.870145] Bluetooth: hci1: BCM: features 0x2f [ 7.871859] Bluetooth: hci1: BCM4335C0 [ 7.871864] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 7.872473] Bluetooth: hci1: BCM: firmware Patch file not found, tried: [ 7.872476] Bluetooth: hci1: BCM: 'brcm/BCM4335C0.hcd' [ 7.872478] Bluetooth: hci1: BCM: 'brcm/BCM.hcd' ..... [ 11.404186] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 11.404195] Bluetooth: BNEP filters: protocol multicast [ 11.404211] Bluetooth: BNEP socket layer initialized [ 11.474186] meson8b-dwmac ff3f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.474245] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 11.824573] rc rc0: two consecutive events of type space [ 12.367552] broken atomic modeset userspace detected, disabling atomic [ 14.095167] fuse: init (API version 7.31) [ 17.019866] Bluetooth: RFCOMM TTY layer initialized [ 17.019894] Bluetooth: RFCOMM socket layer initialized [ 17.019943] Bluetooth: RFCOMM ver 1.11 it does not find any device nor gets found by another bluetooth device nearby. Do you get the same dmesg output? Thanks! Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 9, 2020 Share Posted May 9, 2020 2 hours ago, Albert Barcelona said: Hi @root-stas, tried your bluetooth firmware workaround and while dmesg now loads the firmware: [ 7.869610] Bluetooth: hci1: BCM: chip id 86 [ 7.870145] Bluetooth: hci1: BCM: features 0x2f [ 7.871859] Bluetooth: hci1: BCM4335C0 [ 7.871864] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 7.872473] Bluetooth: hci1: BCM: firmware Patch file not found, tried: [ 7.872476] Bluetooth: hci1: BCM: 'brcm/BCM4335C0.hcd' [ 7.872478] Bluetooth: hci1: BCM: 'brcm/BCM.hcd' ..... [ 11.404186] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 11.404195] Bluetooth: BNEP filters: protocol multicast [ 11.404211] Bluetooth: BNEP socket layer initialized [ 11.474186] meson8b-dwmac ff3f0000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 11.474245] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 11.824573] rc rc0: two consecutive events of type space [ 12.367552] broken atomic modeset userspace detected, disabling atomic [ 14.095167] fuse: init (API version 7.31) [ 17.019866] Bluetooth: RFCOMM TTY layer initialized [ 17.019894] Bluetooth: RFCOMM socket layer initialized [ 17.019943] Bluetooth: RFCOMM ver 1.11 it does not find any device nor gets found by another bluetooth device nearby. Do you get the same dmesg output? Thanks! Hi @root-stas.. thanks for sharing your files. I've 'stolen' your h96 max x3 dtb and Ethernet works now at 1Gbps!!!! (do you mind if I share your file in the H96 Max X3 post I created?) Also sound seems to be 'closer to work'.. byt I get this on dmesg now: [16.926150] fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0 does sound work to you?? Bluetooth continues to 'apparently be on' but not really working: [ 8.092988] Bluetooth: hci1: BCM: chip id 86 [ 8.093475] Bluetooth: hci1: BCM: features 0x2f [ 8.095241] Bluetooth: hci1: BCM4335C0 [ 8.095246] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 8.095347] Bluetooth: hci1: BCM: firmware Patch file not found, tried: [ 8.095350] Bluetooth: hci1: BCM: 'brcm/BCM4335C0.hcd' [ 8.095351] Bluetooth: hci1: BCM: 'brcm/BCM.hcd' Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 9, 2020 Share Posted May 9, 2020 27 minutes ago, Albert Barcelona said: [16.926150] fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0 does sound work to you?? Now.. sound works if I plug a headset but no HDMI output Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 9, 2020 Share Posted May 9, 2020 (edited) On 2/7/2020 at 2:02 PM, dgm78 said: Hi! x96-max.dtb - eth and no sound sm1-sei610 - no eth and sound (I fix the eth in dtb, but now in conflict with sound). The conflict is: On the sound detection says that GPIOZ_2 is already used by eth. Find GPIOZ_2 and found: pinctrl-meson-g12a.c:static const unsigned int eth_rgmii_rx_clk_pins[] = { GPIOZ_2 }; pinctrl-meson-g12a.c:static const unsigned int tdm_c_din0_z_pins[] = { GPIOZ_2 }; Both variables (eth_rgmii_rx_clk_pins and tdm_c_din0_z_pins) pins and are used in DTB. Does anyone help me how to solve? Edit: Solved removing two references from audio-controller -> pinctrl-0 that was in conflict with ethernet. @dgm78: Could you please elaborate a little further? Did you edit the dts line? From what to what? Thank you!! Edited May 9, 2020 by Albert Barcelona Link to comment Share on other sites More sharing options...
rapsacw Posted May 10, 2020 Share Posted May 10, 2020 On 5/9/2020 at 2:31 AM, Azarael said: .. E:mmap(0, R, PRIVATE, 6, 0) failed: Invalid argument E:Map of 'udisk/aml_autoscript.zip' failed E:failed to map file Installation aborted And I can't follow 5p0ng3b0b's fix unfortunately, perhaps their solution was before the image was Windows compatable? Any further help would be very appreciated You can try burning the image to a usb stick and run the update from there, or install the update while in android? Or best yet, ask someone who had the same problem for a solution? Link to comment Share on other sites More sharing options...
root-stas Posted May 11, 2020 Share Posted May 11, 2020 I'm here @Albert Barcelona there is my dmesg: Spoiler [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd050] [ 0.000000] Linux version 5.7.0-rc3-arm-64 (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)), GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.05.3 SMP PREEMPT Fri May 1 22:27:34 MSK 2020 [ 0.000000] Machine model: H96 Max X3 4/32 1GbE/WiFi-AC/BT4 [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 972032 [ 0.000000] DMA zone: 4096 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 261376 pages, LIFO batch:63 [ 0.000000] DMA32 zone: 11104 pages used for memmap [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 22 pages/cpu s51160 r8192 d30760 u90112 [ 0.000000] pcpu-alloc: s51160 r8192 d30760 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: ARM errata 1165522, 1530923 [ 0.000000] alternatives: patching kernel code [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 956832 [ 0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw video=1280x720 console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x389c9000-0x3c9c9000] (64MB) [ 0.000000] Memory: 2780616K/3888128K available (16124K kernel code, 1514K rwdata, 6980K rodata, 3904K init, 944K bss, 190008K reserved, 917504K cma-reserved) [ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x158 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000003] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000166] Console: colour dummy device 80x25 [ 0.000527] printk: console [tty0] enabled [ 0.000574] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000596] pid_max: default: 32768 minimum: 301 [ 0.000743] LSM: Security Framework initializing [ 0.000812] SELinux: Initializing. [ 0.000984] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001011] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002565] rcu: Hierarchical SRCU implementation. [ 0.005337] EFI services will not be available. [ 0.005688] smp: Bringing up secondary CPUs ... [ 0.006522] Detected VIPT I-cache on CPU1 [ 0.006584] CPU1: Booted secondary processor 0x0000000100 [0x411fd050] [ 0.007431] Detected VIPT I-cache on CPU2 [ 0.007471] CPU2: Booted secondary processor 0x0000000200 [0x411fd050] [ 0.008240] Detected VIPT I-cache on CPU3 [ 0.008276] CPU3: Booted secondary processor 0x0000000300 [0x411fd050] [ 0.008351] smp: Brought up 1 node, 4 CPUs [ 0.008421] SMP: Total of 4 processors activated. [ 0.008434] CPU features: detected: Privileged Access Never [ 0.008445] CPU features: detected: LSE atomic instructions [ 0.008455] CPU features: detected: User Access Override [ 0.008467] CPU features: detected: 32-bit EL0 Support [ 0.008478] CPU features: detected: Common not Private translations [ 0.008489] CPU features: detected: RAS Extension Support [ 0.008500] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.008517] CPU features: detected: CRC32 instructions [ 0.039142] CPU: All CPU(s) started at EL2 [ 0.041578] devtmpfs: initialized [ 0.054114] Registered cp15_barrier emulation handler [ 0.054143] Registered setend emulation handler [ 0.054161] KASLR disabled due to lack of seed [ 0.054493] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.054527] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.072709] xor: measuring software checksum speed [ 0.112296] 8regs : 2242.000 MB/sec [ 0.152333] 32regs : 2833.000 MB/sec [ 0.192378] arm64_neon: 2407.000 MB/sec [ 0.192395] xor: using function: 32regs (2833.000 MB/sec) [ 0.192459] pinctrl core: initialized pinctrl subsystem [ 0.193330] thermal_sys: Registered thermal governor 'step_wise' [ 0.193800] DMI not present or invalid. [ 0.194304] NET: Registered protocol family 16 [ 0.195804] DMA: preallocated 256 KiB pool for atomic allocations [ 0.195842] audit: initializing netlink subsys (disabled) [ 0.196019] audit: type=2000 audit(0.192:1): state=initialized audit_enabled=0 res=1 [ 0.197593] cpuidle: using governor ladder [ 0.197630] cpuidle: using governor menu [ 0.197957] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.198077] ASID allocator initialised with 65536 entries [ 0.199112] Serial: AMBA PL011 UART driver [ 0.218942] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.218974] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.218988] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.219004] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.223285] cryptd: max_cpu_qlen set to 1000 [ 0.296628] raid6: neonx8 gen() 2128 MB/s [ 0.364697] raid6: neonx8 xor() 1657 MB/s [ 0.432800] raid6: neonx4 gen() 2189 MB/s [ 0.500876] raid6: neonx4 xor() 1650 MB/s [ 0.568979] raid6: neonx2 gen() 2073 MB/s [ 0.637058] raid6: neonx2 xor() 1511 MB/s [ 0.705155] raid6: neonx1 gen() 1781 MB/s [ 0.773233] raid6: neonx1 xor() 1269 MB/s [ 0.841376] raid6: int64x8 gen() 1516 MB/s [ 0.909414] raid6: int64x8 xor() 778 MB/s [ 0.977521] raid6: int64x4 gen() 1645 MB/s [ 1.045588] raid6: int64x4 xor() 846 MB/s [ 1.113682] raid6: int64x2 gen() 1477 MB/s [ 1.181752] raid6: int64x2 xor() 759 MB/s [ 1.249875] raid6: int64x1 gen() 1132 MB/s [ 1.317936] raid6: int64x1 xor() 565 MB/s [ 1.317949] raid6: using algorithm neonx4 gen() 2189 MB/s [ 1.317961] raid6: .... xor() 1650 MB/s, rmw enabled [ 1.317973] raid6: using neon recovery algorithm [ 1.318537] ACPI: Interpreter disabled. [ 1.320044] VSYS_3V3: supplied by DC_IN [ 1.320488] iommu: Default domain type: Translated [ 1.320772] vgaarb: loaded [ 1.321356] SCSI subsystem initialized [ 1.321533] libata version 3.00 loaded. [ 1.321795] usbcore: registered new interface driver usbfs [ 1.321852] usbcore: registered new interface driver hub [ 1.321950] usbcore: registered new device driver usb [ 1.322377] pps_core: LinuxPPS API ver. 1 registered [ 1.322393] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.322421] PTP clock support registered [ 1.322458] EDAC MC: Ver: 3.0.0 [ 1.323138] FPGA manager framework [ 1.323248] Advanced Linux Sound Architecture Driver Initialized. [ 1.323851] NetLabel: Initializing [ 1.323868] NetLabel: domain hash size = 128 [ 1.323877] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.323939] NetLabel: unlabeled traffic allowed by default [ 1.324387] clocksource: Switched to clocksource arch_sys_counter [ 1.324644] VFS: Disk quotas dquot_6.6.0 [ 1.324713] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.324835] FS-Cache: Loaded [ 1.325511] pnp: PnP ACPI: disabled [ 1.333052] NET: Registered protocol family 2 [ 1.333575] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.333633] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.333825] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.334270] TCP: Hash tables configured (established 32768 bind 32768) [ 1.334401] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.334466] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.334694] NET: Registered protocol family 1 [ 1.335173] RPC: Registered named UNIX socket transport module. [ 1.335188] RPC: Registered udp transport module. [ 1.335199] RPC: Registered tcp transport module. [ 1.335211] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.335229] NET: Registered protocol family 44 [ 1.335250] PCI: CLS 0 bytes, default 64 [ 1.335466] Trying to unpack rootfs image as initramfs... [ 1.532768] Freeing initrd memory: 14552K [ 1.707014] Initialise system trusted keyrings [ 1.707215] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 1.715094] zbud: loaded [ 1.716885] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.717260] FS-Cache: Netfs 'nfs' registered for caching [ 1.717930] NFS: Registering the id_resolver key type [ 1.717966] Key type id_resolver registered [ 1.717977] Key type id_legacy registered [ 1.717996] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.718009] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.719340] FS-Cache: Netfs 'cifs' registered for caching [ 1.719717] Key type cifs.spnego registered [ 1.719739] Key type cifs.idmap registered [ 1.719758] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.720543] JFS: nTxBlock = 8192, nTxLock = 65536 [ 1.725955] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [ 1.728002] ocfs2: Registered cluster interface o2cb [ 1.728211] OCFS2 User DLM kernel interface loaded [ 1.730002] gfs2: GFS2 installed [ 1.750763] NET: Registered protocol family 38 [ 1.750797] Key type asymmetric registered [ 1.750812] Asymmetric key parser 'x509' registered [ 1.750825] Asymmetric key parser 'pkcs8' registered [ 1.750892] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.751097] io scheduler mq-deadline registered [ 1.751120] io scheduler kyber registered [ 1.751352] io scheduler bfq registered [ 1.768792] soc soc0: Amlogic Meson SM1 (Unknown) Revision 2b:c (10:2) Detected [ 1.770430] pwm-regulator: supplied by regulator-dummy [ 1.770668] VCC_3V3: supplied by VSYS_3V3 [ 1.770754] VCC_1V8: supplied by VCC_3V3 [ 1.770820] VDDIO_AO1V8: supplied by VSYS_3V3 [ 1.770891] EMMC_AO1V8: supplied by VCC_3V3 [ 1.774762] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [ 1.776949] Serial: AMBA driver [ 1.777327] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart [ 2.791268] printk: console [ttyAML0] enabled [ 2.796194] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 20, base_baud = 1500000) is a meson_uart [ 2.805030] serial serial0: tty port ttyAML6 registered [ 2.822607] brd: module loaded [ 2.831278] loop: module loaded [ 2.836256] libphy: Fixed MDIO Bus: probed [ 2.838552] VFIO - User Level meta-driver version: 0.3 [ 2.841013] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.846330] ehci-pci: EHCI PCI platform driver [ 2.850750] ehci-platform: EHCI generic platform driver [ 2.856016] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.862030] ohci-pci: OHCI PCI platform driver [ 2.866440] ohci-platform: OHCI generic platform driver [ 2.872039] usbcore: registered new interface driver usb-storage [ 2.877741] mousedev: PS/2 mouse device common for all mice [ 2.883982] i2c /dev entries driver [ 2.892800] sdhci: Secure Digital Host Controller Interface driver [ 2.893351] sdhci: Copyright(c) Pierre Ossman [ 2.897720] Synopsys Designware Multimedia Card Interface Driver [ 2.904586] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq [ 2.940571] meson-gx-mmc ffe05000.sd: Got CD GPIO [ 2.971615] mmc0: queuing unknown CIS tuple 0x80 (2 bytes) [ 2.973179] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq [ 2.979841] mmc0: queuing unknown CIS tuple 0x80 (7 bytes) [ 2.984557] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [ 3.006228] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.007902] ledtrig-cpu: registered to indicate activity on CPUs [ 3.014001] meson-sm: secure-monitor enabled [ 3.016840] hid: raw HID events driver (C) Jiri Kosina [ 3.021700] mmc1: new high speed SDXC card at address e624 [ 3.021808] usbcore: registered new interface driver usbhid [ 3.027641] mmcblk1: mmc1:e624 SU64G 59.5 GiB [ 3.032506] usbhid: USB HID core driver [ 3.039108] mmcblk1: p1 p2 [ 3.047807] no UART detected at 0x1 [ 3.052371] NET: Registered protocol family 17 [ 3.052715] Key type dns_resolver registered [ 3.055999] registered taskstats version 1 [ 3.059587] Loading compiled-in X.509 certificates [ 3.064442] zswap: loaded using pool lzo/zbud [ 3.069094] Key type ._fscrypt registered [ 3.072628] Key type .fscrypt registered [ 3.074284] random: fast init done [ 3.076478] Key type fscrypt-provisioning registered [ 3.085759] Btrfs loaded, crc32c=crc32c-generic [ 3.091863] mmc0: new high speed SDIO card at address 0001 [ 3.103103] Key type encrypted registered [ 3.119784] VCC_5V: supplied by DC_IN [ 3.120135] USB_PWR: supplied by VCC_5V [ 3.134636] mmc2: new HS200 MMC card at address 0001 [ 3.135368] mmcblk2: mmc2:0001 HBG4a2 29.1 GiB [ 3.138811] mmcblk2boot0: mmc2:0001 HBG4a2 partition 1 4.00 MiB [ 3.144683] mmcblk2boot1: mmc2:0001 HBG4a2 partition 2 4.00 MiB [ 3.150421] mmcblk2rpmb: mmc2:0001 HBG4a2 partition 3 4.00 MiB, chardev (241:0) [ 3.197854] meson-drm ff900000.vpu: Queued 2 outputs on vpu [ 3.198137] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.204476] meson-drm ff900000.vpu: CVBS Output connector not available [ 3.236436] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) [ 3.240987] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver [ 3.249102] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops) [ 3.256267] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 [ 3.538837] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 3.538895] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 3.538938] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 3.538981] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 3.539023] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: 16:9 [ 3.539066] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 3.539104] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 3.539147] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 3.539189] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 3.539229] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 3.539272] meson-dw-hdmi ff600000.hdmi-tx: video code: 4 [ 3.539312] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 3.539352] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 3.539392] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 3.539442] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 3.539547] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 3.539587] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 3.539627] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 3.539676] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) [ 3.616327] Console: switching to colour frame buffer device 160x45 [ 3.761175] meson-drm ff900000.vpu: fb0: mesondrmfb frame buffer device [ 3.768659] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found [ 3.774295] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found [ 3.780496] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock [ 3.786366] meson8b-dwmac ff3f0000.ethernet: no reset control found [ 3.793523] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 3.799660] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 [ 3.804822] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported [ 3.812239] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported [ 3.819652] meson8b-dwmac ff3f0000.ethernet: COE Type 2 [ 3.824824] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported [ 3.831813] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported [ 3.838227] meson8b-dwmac ff3f0000.ethernet: Normal descriptors [ 3.844059] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled [ 3.849837] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.858121] libphy: stmmac: probed [ 3.862152] dwc3-meson-g12a ffe09000.usb: USB2 ports: 2 [ 3.866329] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 [ 3.874447] dwc2 ff400000.usb: supply vusb_d not found, using dummy regulator [ 3.878630] dwc2 ff400000.usb: supply vusb_a not found, using dummy regulator [ 3.885854] dwc2 ff400000.usb: EPs: 7, dedicated fifos, 712 entries in SPRAM [ 3.893774] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.898098] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 3.905764] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 [ 3.915004] xhci-hcd xhci-hcd.3.auto: irq 29, io mem 0xff500000 [ 3.921097] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07 [ 3.929021] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.936174] usb usb1: Product: xHCI Host Controller [ 3.941004] usb usb1: Manufacturer: Linux 5.7.0-rc3-arm-64 xhci-hcd [ 3.947215] usb usb1: SerialNumber: xhci-hcd.3.auto [ 3.952459] hub 1-0:1.0: USB hub found [ 3.955768] hub 1-0:1.0: 2 ports detected [ 3.960006] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.965173] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 [ 3.972758] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 3.979254] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.987312] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07 [ 3.995431] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.002595] usb usb2: Product: xHCI Host Controller [ 4.002598] usb usb2: Manufacturer: Linux 5.7.0-rc3-arm-64 xhci-hcd [ 4.002602] usb usb2: SerialNumber: xhci-hcd.3.auto [ 4.018817] hub 2-0:1.0: USB hub found [ 4.022195] hub 2-0:1.0: 1 port detected [ 4.029493] simple-framebuffer chosen:framebuffer-hdmi: Can't parse width property [ 4.033586] simple-framebuffer: probe of chosen:framebuffer-hdmi failed with error -22 [ 4.042191] printk: console [netcon0] enabled [ 4.045723] netconsole: network logging started [ 4.050737] ALSA device list: [ 4.053157] No soundcards found. [ 4.058860] Freeing unused kernel memory: 3904K [ 4.061308] Run /init as init process [ 4.064606] with arguments: [ 4.064609] /init [ 4.064612] with environment: [ 4.064616] HOME=/ [ 4.064618] TERM=linux [ 4.292446] usb 1-2: new high-speed USB device number 2 using xhci-hcd [ 4.354535] input: adc-keys as /devices/platform/adc-keys/input/input0 [ 4.378901] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input1 [ 4.423451] meson-vrtc ff8000a8.rtc: registered as rtc0 [ 4.424557] libphy: mdio_mux: probed [ 4.432542] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 4.440733] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 4.445259] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.447670] libphy: mdio_mux: probed [ 4.452309] usb 1-2: Product: USB 2.0 Hub [ 4.491617] hub 1-2:1.0: USB hub found [ 4.493622] hub 1-2:1.0: 4 ports detected [ 4.880471] usb 1-2.2: new low-speed USB device number 3 using xhci-hcd [ 5.110089] usb 1-2.2: New USB device found, idVendor=0458, idProduct=0708, bcdDevice= 1.00 [ 5.112739] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 5.118316] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.134388] usb 1-2.2: Product: Multimedia Keyboard [ 5.134392] usb 1-2.2: Manufacturer: Genius [ 5.240017] input: Genius Multimedia Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.0/0003:0458:0708.0001/input/input2 [ 5.320874] hid-generic 0003:0458:0708.0001: input,hidraw0: USB HID v1.11 Keyboard [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input0 [ 5.350116] input: Genius Multimedia Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:0458:0708.0002/input/input3 [ 5.434558] hid-generic 0003:0458:0708.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input1 [ 5.632512] usb 1-2.3: new full-speed USB device number 4 using xhci-hcd [ 5.851640] usb 1-2.3: New USB device found, idVendor=1ea7, idProduct=0030, bcdDevice= 2.00 [ 5.864317] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 5.875883] usb 1-2.3: Product: USB Gaming Mouse [ 6.018402] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.0/0003:1EA7:0030.0003/input/input4 [ 6.055863] systemd[1]: System time before build time, advancing clock. [ 6.098597] hid-generic 0003:1EA7:0030.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.3/input0 [ 6.115823] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.1/0003:1EA7:0030.0004/input/input5 [ 6.131907] hid-generic 0003:1EA7:0030.0004: input,hidraw3: USB HID v1.10 Mouse [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.3/input1 [ 6.146675] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.2/0003:1EA7:0030.0005/input/input6 [ 6.162106] input: USB Gaming Mouse Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.2/0003:1EA7:0030.0005/input/input7 [ 6.241002] input: USB Gaming Mouse System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.3/1-2.3:1.2/0003:1EA7:0030.0005/input/input8 [ 6.268289] hid-generic 0003:1EA7:0030.0005: input,hiddev1,hidraw4: USB HID v1.10 Device [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.3/input2 [ 6.308743] NET: Registered protocol family 10 [ 6.370940] Segment Routing with IPv6 [ 6.412791] systemd[1]: systemd 245.4-4ubuntu3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid) [ 6.443175] systemd[1]: Detected architecture arm64. [ 6.508463] systemd[1]: Set hostname to <arm-64>. [ 7.172589] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly. [ 7.453435] random: systemd: uninitialized urandom read (16 bytes read) [ 7.462292] systemd[1]: Created slice system-modprobe.slice. [ 7.471035] random: systemd: uninitialized urandom read (16 bytes read) [ 7.477094] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 7.486025] random: systemd: uninitialized urandom read (16 bytes read) [ 7.491722] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 7.501861] systemd[1]: Created slice User and Session Slice. [ 7.509357] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 7.518594] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 7.528202] systemd[1]: Reached target User and Group Name Lookups. [ 7.537707] systemd[1]: Reached target Remote File Systems. [ 7.544450] systemd[1]: Reached target Slices. [ 7.550843] systemd[1]: Reached target Swap. [ 7.556965] systemd[1]: Reached target System Time Set. [ 7.563290] systemd[1]: Listening on Syslog Socket. [ 7.569293] systemd[1]: Listening on fsck to fsckd communication Socket. [ 7.575845] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 7.582871] systemd[1]: Listening on Journal Audit Socket. [ 7.588281] systemd[1]: Listening on Journal Socket (/dev/log). [ 7.594077] systemd[1]: Listening on Journal Socket. [ 7.599544] systemd[1]: Listening on udev Control Socket. [ 7.604820] systemd[1]: Listening on udev Kernel Socket. [ 7.613215] systemd[1]: Mounting Huge Pages File System... [ 7.622317] systemd[1]: Mounting POSIX Message Queue File System... [ 7.631644] systemd[1]: Mounting Kernel Debug File System... [ 7.636957] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 7.647229] systemd[1]: Starting Journal Service... [ 7.657504] systemd[1]: Starting Restore / save the current clock... [ 7.668574] systemd[1]: Starting Set the console keyboard layout... [ 7.693059] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 7.701168] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 7.710775] systemd[1]: Started Nameserver information manager. [ 7.716812] systemd[1]: Reached target Network (Pre). [ 7.725505] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 7.731647] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 7.737552] systemd[1]: Starting Load Kernel Modules... [ 7.753054] systemd[1]: Starting Remount Root and Kernel File Systems... [ 7.763130] systemd[1]: Starting udev Coldplug all Devices... [ 7.777477] systemd[1]: Mounted Huge Pages File System. [ 7.782732] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 7.783321] systemd[1]: Mounted POSIX Message Queue File System. [ 7.799113] systemd[1]: Mounted Kernel Debug File System. [ 7.806620] systemd[1]: Finished Restore / save the current clock. [ 7.814814] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 7.827675] systemd[1]: Finished Remount Root and Kernel File Systems. [ 7.834314] openvfd: loading out-of-tree module taints kernel. [ 7.839677] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 7.845575] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 7.859078] systemd[1]: Starting Load/Save Random Seed... [ 7.869234] systemd[1]: Starting Create System Users... [ 7.876846] systemd[1]: Finished Load Kernel Modules. [ 7.883725] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 7.893180] systemd[1]: Mounting Kernel Configuration File System... [ 7.908114] systemd[1]: Starting Apply Kernel Variables... [ 7.916830] systemd[1]: Mounted Kernel Configuration File System. [ 7.952807] systemd[1]: Finished Create System Users. [ 7.962999] systemd[1]: Starting Create Static Device Nodes in /dev... [ 8.002732] systemd[1]: Finished Apply Kernel Variables. [ 8.010744] systemd[1]: Finished Set the console keyboard layout. [ 8.020131] systemd[1]: Finished Create Static Device Nodes in /dev. [ 8.024615] systemd[1]: Reached target Local File Systems (Pre). [ 8.032486] systemd[1]: Mounting /tmp... [ 8.039419] systemd[1]: Starting udev Kernel Device Manager... [ 8.045722] systemd[1]: Mounted /tmp. [ 8.191151] systemd[1]: Finished udev Coldplug all Devices. [ 8.199647] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 8.220025] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 8.273936] systemd[1]: Started Journal Service. [ 8.306013] systemd-journald[408]: Received client request to flush runtime journal. [ 8.737780] mc: Linux media interface: v0.10 [ 8.766954] videodev: Linux video capture interface: v2.00 [ 8.820908] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present! [ 8.826231] axg-sound-card sound: snd-soc-dummy-dai <-> ff6601c0.audio-controller mapping ok [ 8.826981] axg-sound-card sound: snd-soc-dummy-dai <-> ff660200.audio-controller mapping ok [ 8.827682] axg-sound-card sound: snd-soc-dummy-dai <-> ff660240.audio-controller mapping ok [ 8.828198] axg-sound-card sound: I2S IN B <-> TDM Pad mapping ok [ 8.828209] axg-sound-card sound: snd-soc-dummy-dai <-> TDM Loopback mapping ok [ 8.828223] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok [ 8.828318] axg-sound-card sound: ASoC: no DMI vendor name! [ 8.848434] Registered IR keymap rc-khadas [ 8.859576] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 8.868289] IR NEC protocol handler initialized [ 8.896540] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 [ 8.896689] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter [ 8.896870] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input10 [ 8.898504] meson-ir ff808000.ir: receiver initialized [ 8.984794] panfrost ffe40000.gpu: clock rate = 799999987 [ 8.984836] panfrost ffe40000.gpu: supply mali not found, using dummy regulator [ 8.985043] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 [ 8.985050] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400 [ 8.985054] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 8.985057] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1 [ 8.995375] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 [ 9.253678] Bluetooth: Core ver 2.22 [ 9.253684] Bluetooth: Starting self testing [ 9.265309] Bluetooth: ECDH test passed in 11337 usecs [ 9.267318] Bluetooth: SMP test passed in 1888 usecs [ 9.267342] Bluetooth: Finished self testing [ 9.267436] NET: Registered protocol family 31 [ 9.267440] Bluetooth: HCI device and connection manager initialized [ 9.267455] Bluetooth: HCI socket layer initialized [ 9.267462] Bluetooth: L2CAP socket layer initialized [ 9.267476] Bluetooth: SCO socket layer initialized [ 9.315969] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 9.333415] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 9.430442] brcmfmac: F1 signature read @0x18000000=0x16024335 [ 9.431560] Bluetooth: HCI UART driver ver 2.3 [ 9.431577] Bluetooth: HCI UART protocol H4 registered [ 9.431587] Bluetooth: HCI UART protocol BCSP registered [ 9.431713] Bluetooth: HCI UART protocol LL registered [ 9.431716] Bluetooth: HCI UART protocol ATH3K registered [ 9.431780] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 9.432336] Bluetooth: HCI UART protocol Intel registered [ 9.433320] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator [ 9.433400] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator [ 9.433817] Bluetooth: HCI UART protocol Broadcom registered [ 9.435359] Bluetooth: HCI UART protocol QCA registered [ 9.435496] Bluetooth: HCI UART protocol AG6XX registered [ 9.435565] Bluetooth: HCI UART protocol Marvell registered [ 9.438409] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 9.438696] usbcore: registered new interface driver brcmfmac [ 9.486143] random: crng init done [ 9.486155] random: 7 urandom warning(s) missed due to ratelimiting [ 9.821694] Bluetooth: hci1: BCM: chip id 86 [ 9.822332] Bluetooth: hci1: BCM: features 0x2f [ 9.824097] Bluetooth: hci1: BCM4335C0 [ 9.824113] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 10.741074] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0671 [ 11.276412] rc rc0: two consecutive events of type space [ 11.614117] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=30) [ 11.624416] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found [ 11.624431] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW [ 11.624442] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rgmii link mode [ 11.744621] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 11.744749] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 11.748630] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4339/2 wl0: Aug 11 2018 06:13:33 version 6.37.39.99 (r694622 CY) [ 12.328891] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 12.328897] Bluetooth: BNEP filters: protocol multicast [ 12.328910] Bluetooth: BNEP socket layer initialized [ 22.689458] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready If you want use my DTB - better now is test8 version. For share - mention me in description (link to GDrive, DTB in WIP state and changing if I get success with VFD (front screen) or GPU, people need know about that). I tests different HDMI display and sound stop working on one of them, looks like magic in kernel In DTB aux sound driver is completely different them in stock android DTB, maybe that is problem. On 5/9/2020 at 6:14 PM, Albert Barcelona said: [ 8.095351] Bluetooth: hci1: BCM: 'brcm/BCM.hcd' Try remove that and reboot. On 5/9/2020 at 6:14 PM, Albert Barcelona said: [16.926150] fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0 That is happened when display don't properly connected at loading kernel time, in test8 DTB that is gone, kernel try solve wrong DTB records! In brcm folder you have 4339-sdio.txt file, make symlink with name - brcmfmac4339-sdio.khadas,vim3l.txt , that is for wifi, but bt maybe need that too. Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 12, 2020 Share Posted May 12, 2020 Thanks @root-stas I've used your test8 dtb and compared my dmesg with yours and I have found where the hdmi problem happens: [ 2.898291] OF: /soc/vpu@ff900000: could not get #power-domain-cells for /soc/bus@ff600000/bus@34400/pinctrl@40/bank@40 [ 2.905345] meson-drm ff900000.vpu: Queued 2 outputs on vpu [ 2.911406] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.917483] meson-drm ff900000.vpu: CVBS Output connector not available [ 2.923982] meson-drm ff900000.vpu: failed to bind ff600000.hdmi-tx (ops meson_dw_hdmi_ops): -517 [ 2.932738] meson-drm ff900000.vpu: Couldn't bind all components [ 2.938842] meson-drm ff900000.vpu: master bind failed: -517 The mesage: 20.005163] fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0 continues to be there with test8 file. I suppose the issue is related to the HDMI. Any clue????? Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 12, 2020 Share Posted May 12, 2020 37 minutes ago, Albert Barcelona said: Thanks @root-stas I've used your test8 dtb and compared my dmesg with yours and I have found where the hdmi problem happens: [ 2.898291] OF: /soc/vpu@ff900000: could not get #power-domain-cells for /soc/bus@ff600000/bus@34400/pinctrl@40/bank@40 [ 2.905345] meson-drm ff900000.vpu: Queued 2 outputs on vpu [ 2.911406] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.917483] meson-drm ff900000.vpu: CVBS Output connector not available [ 2.923982] meson-drm ff900000.vpu: failed to bind ff600000.hdmi-tx (ops meson_dw_hdmi_ops): -517 [ 2.932738] meson-drm ff900000.vpu: Couldn't bind all components [ 2.938842] meson-drm ff900000.vpu: master bind failed: -517 The mesage: 20.005163] fe.dai-link-0: ASoC: no backend DAIs enabled for fe.dai-link-0 continues to be there with test8 file. I suppose the issue is related to the HDMI. Any clue????? Actually.. when 'decompiling' your test8 dtb to dts I get the following warning: albert@asl-h96:~/dtbs$ dtc -I dtb -O dts -o test8.dts /boot/dtb/h96max-x3-test8.dtb test8.dts: Warning (unit_address_vs_reg): /soc/bus@ff600000/bus@34400/pinctrl@40: node has a unit name, but no reg property test8.dts: Warning (unit_address_vs_reg): /soc/bus@ff800000/sys-ctrl@0/pinctrl@14: node has a unit name, but no reg property test8.dts: Warning (unit_address_format): /soc/bus@ff800000/rtc@0a8: unit name should not have leading 0s test8.dts: Warning (power_domains_property): /soc/vpu@ff900000: Missing property '#power-domain-cells' in node /soc/bus@ff600000/bus@34400/pinctrl@40/bank@40 or bad phandle (referred from power-domains[0]) test8.dts: Warning (gpios_property): /meson-vfd: Missing property '#gpio-cells' in node /emmc-pwrseq or bad phandle (referred from gpios[4]) What is this #power-domain-cells property? seems to be the key. Yet, the vpu@ff9900000 reads exactly as in the meson-610: vpu@ff900000 { reg = < 0x00 0xff900000 0x00 0x100000 0x00 0xff63c000 0x00 0x1000 >; Link to comment Share on other sites More sharing options...
medmouncef Posted May 13, 2020 Share Posted May 13, 2020 On 2/21/2020 at 8:42 PM, 5p0ng3b0b said: Get DTB file from recovery.PARTITION file. Here is a second take a getting DTB file as extracting via /sys/firmware/devicetree/base using dtc didn't appear to work . This time get DTB from recovery.PARTITION file using termux. Firstly on a PC, download and unzip stock tvbox image. Then unpack firmware.img file with amlogic unpacker. Now transfer the recovery.PARTITION file to termux home folder. The DTB file is embedded in this file so now just extract it. I already installed git, python, perl and wget etc to termux. Hide contents #Install binwalk git clone https://github.com/ReFirmLabs/binwalk.git cd binwalk python setup.py install cd ..; rm -Rf binwalk #Get split_bootimg.pl script wget https://gist.githubusercontent.com/jberkel/1087743/raw/45046f87176dfacdc22af4290f89a0d2e0df1dbb/split_bootimg.pl chmod +x split_bootimg.pl #Split recovery.PARTITION ./split_bootimg.pl recovery.PARTITION #Unpack recovery.PARTITION-second.gz gunzip recovery.PARTITION-second.gz #Get offset of embedded DTB in recovery.PARTITION-second DTBOFFSET=$(binwalk -R "\xD0\x0D\xFE\xED" recovery.PARTITION-second | awk 'NR > 3 { print $1}' | head -n 1) #Get length of DTB in recovery.PARTITION-second DTBLEN=$((16#$(dd if=recovery.PARTITION-second bs=1 skip=$(($DTBOFFSET + 4)) count=4 status=none | od -tx1 | head -n 1 | cut -d ' ' -f 2- | sed 's/ //g' ))) #Now extract and create dtb file dd if=recovery.PARTITION-second of=mybox.dtb bs=1 skip=$DTBOFFSET count=$DTBLEN The resulting file was 76,302 bytes in my case from a magicsee N5 plus box. I still can't test yet because I haven't got it to boot from external storage but can confirm the dtc command worked on it. dtc -I dtb -O dts -o mybox.dts mybox.dtb Update: This also worked from a recovery image file created by dd if=/dev/block/recovery of=recovery.PARTITION so this can be done completely from rooted device and without access to stock firmware. Produced an identicle DTB. n5plus.dtb 85.55 kB · 32 downloads n5plus.dts 97.16 kB · 30 downloads Bonjour. Have you encountered this problem? $ gunzip recovery.PARTITION-second.gz $ gzip: recovery.PARTITION-second.gz: not in gzip format I searched on Google but did not find an adequate solution. Thanks for your help Link to comment Share on other sites More sharing options...
root-stas Posted May 13, 2020 Share Posted May 13, 2020 @Albert Barcelona try new one h96max-x2-test-bus80-gpu-volt.dtb: https://drive.google.com/open?id=1BU_k61jUr1ivvDHCXvnfJOc-BHpNq3Dx I'm fix vpu wrong link to gpio, proper link is power domain as kernel tell. And add power records in gpu section to fix error from panfrost, but X11 don't get 3D yet. I have sound over hdmi, cant test AV and SPDIF, someone can test here? Link to comment Share on other sites More sharing options...
root-stas Posted May 13, 2020 Share Posted May 13, 2020 11 hours ago, medmouncef said: Bonjour. Have you encountered this problem? $ gunzip recovery.PARTITION-second.gz $ gzip: recovery.PARTITION-second.gz: not in gzip format I searched on Google but did not find an adequate solution. Thanks for your help If the box is rooted, install X-plore on the box and copy “root/dev/dtb.img” or “root/dev/dtb" anywhere you want. And use dtc to convert that file to dts. Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 13, 2020 Share Posted May 13, 2020 3 hours ago, root-stas said: @Albert Barcelona try new one h96max-x2-test-bus80-gpu-volt.dtb: https://drive.google.com/open?id=1BU_k61jUr1ivvDHCXvnfJOc-BHpNq3Dx I'm fix vpu wrong link to gpio, proper link is power domain as kernel tell. And add power records in gpu section to fix error from panfrost, but X11 don't get 3D yet. I have sound over hdmi, cant test AV and SPDIF, someone can test here? @root-stas: Thanks for sharing! Seems you really know about this! Unfortuntely HDMI audio continues not to work. Apparently no changes for me on behaviour from test8 file. Here's my last dmesg (with the new h96max-x2-test-bus80-gpu-volt.dtb) https://paste.ubuntu.com/p/KYNQPPvwMn/ And here the audio devices list: albert@asl-h96:~$ aplay -l **** List of PLAYBACK Hardware Devices **** card 0: AMLG12 [AMLG12], device 0: fe.dai-link-0 (*) [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: AMLG12 [AMLG12], device 1: fe.dai-link-1 (*) [] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: AMLG12 [AMLG12], device 2: fe.dai-link-2 (*) [] Subdevices: 1/1 Subdevice #0: subdevice #0 albert@asl-h96:~$ Again; thanks for keeping up! Link to comment Share on other sites More sharing options...
root-stas Posted May 13, 2020 Share Posted May 13, 2020 (edited) You welcome, we on same boat That's my last dmesg: Spoiler [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd050] [ 0.000000] Linux version 5.7.0-rc4-arm-64 (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)), GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.05.4 SMP PREEMPT Sun May 10 13:21:46 MSK 2020 [ 0.000000] Machine model: H96 Max X3 4/32 1GbE/WiFi-AC/BT4 [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 972032 [ 0.000000] DMA zone: 4096 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 261376 pages, LIFO batch:63 [ 0.000000] DMA32 zone: 11104 pages used for memmap [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 22 pages/cpu s51160 r8192 d30760 u90112 [ 0.000000] pcpu-alloc: s51160 r8192 d30760 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: ARM errata 1165522, 1530923 [ 0.000000] alternatives: patching kernel code [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 956832 [ 0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw video=1280x720 console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x38a97000-0x3ca97000] (64MB) [ 0.000000] Memory: 2781180K/3888128K available (16316K kernel code, 1518K rwdata, 7024K rodata, 3904K init, 945K bss, 189444K reserved, 917504K cma-reserved) [ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x158 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000179] Console: colour dummy device 80x25 [ 0.000541] printk: console [tty0] enabled [ 0.000586] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000610] pid_max: default: 32768 minimum: 301 [ 0.000752] LSM: Security Framework initializing [ 0.000818] SELinux: Initializing. [ 0.000983] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001010] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002577] rcu: Hierarchical SRCU implementation. [ 0.005355] EFI services will not be available. [ 0.005713] smp: Bringing up secondary CPUs ... [ 0.006544] Detected VIPT I-cache on CPU1 [ 0.006606] CPU1: Booted secondary processor 0x0000000100 [0x411fd050] [ 0.007449] Detected VIPT I-cache on CPU2 [ 0.007484] CPU2: Booted secondary processor 0x0000000200 [0x411fd050] [ 0.008258] Detected VIPT I-cache on CPU3 [ 0.008294] CPU3: Booted secondary processor 0x0000000300 [0x411fd050] [ 0.008374] smp: Brought up 1 node, 4 CPUs [ 0.008442] SMP: Total of 4 processors activated. [ 0.008455] CPU features: detected: Privileged Access Never [ 0.008466] CPU features: detected: LSE atomic instructions [ 0.008477] CPU features: detected: User Access Override [ 0.008488] CPU features: detected: 32-bit EL0 Support [ 0.008499] CPU features: detected: Common not Private translations [ 0.008511] CPU features: detected: RAS Extension Support [ 0.008521] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.008537] CPU features: detected: CRC32 instructions [ 0.039690] CPU: All CPU(s) started at EL2 [ 0.042122] devtmpfs: initialized [ 0.053662] Registered cp15_barrier emulation handler [ 0.053693] Registered setend emulation handler [ 0.053712] KASLR disabled due to lack of seed [ 0.054027] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.054061] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.072232] xor: measuring software checksum speed [ 0.108844] 8regs : 2242.000 MB/sec [ 0.148881] 32regs : 2833.000 MB/sec [ 0.188927] arm64_neon: 2407.000 MB/sec [ 0.188939] xor: using function: 32regs (2833.000 MB/sec) [ 0.189004] pinctrl core: initialized pinctrl subsystem [ 0.189833] thermal_sys: Registered thermal governor 'step_wise' [ 0.190303] DMI not present or invalid. [ 0.190807] NET: Registered protocol family 16 [ 0.192302] DMA: preallocated 256 KiB pool for atomic allocations [ 0.192340] audit: initializing netlink subsys (disabled) [ 0.192514] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1 [ 0.194036] cpuidle: using governor ladder [ 0.194072] cpuidle: using governor menu [ 0.194390] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.194507] ASID allocator initialised with 65536 entries [ 0.195592] Serial: AMBA PL011 UART driver [ 0.215245] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.215276] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.215291] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.215306] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.219511] cryptd: max_cpu_qlen set to 1000 [ 0.293174] raid6: neonx8 gen() 2131 MB/s [ 0.361257] raid6: neonx8 xor() 1657 MB/s [ 0.429389] raid6: neonx4 gen() 2193 MB/s [ 0.497431] raid6: neonx4 xor() 1649 MB/s [ 0.565500] raid6: neonx2 gen() 2084 MB/s [ 0.633558] raid6: neonx2 xor() 1509 MB/s [ 0.701624] raid6: neonx1 gen() 1790 MB/s [ 0.769691] raid6: neonx1 xor() 1270 MB/s [ 0.837781] raid6: int64x8 gen() 1516 MB/s [ 0.905830] raid6: int64x8 xor() 781 MB/s [ 0.973879] raid6: int64x4 gen() 1646 MB/s [ 1.041945] raid6: int64x4 xor() 848 MB/s [ 1.110020] raid6: int64x2 gen() 1479 MB/s [ 1.178085] raid6: int64x2 xor() 756 MB/s [ 1.246135] raid6: int64x1 gen() 1107 MB/s [ 1.314198] raid6: int64x1 xor() 570 MB/s [ 1.314212] raid6: using algorithm neonx4 gen() 2193 MB/s [ 1.314224] raid6: .... xor() 1649 MB/s, rmw enabled [ 1.314235] raid6: using neon recovery algorithm [ 1.314829] ACPI: Interpreter disabled. [ 1.316368] VSYS_3V3: supplied by DC_IN [ 1.316863] iommu: Default domain type: Translated [ 1.317152] vgaarb: loaded [ 1.317667] SCSI subsystem initialized [ 1.317857] libata version 3.00 loaded. [ 1.318120] usbcore: registered new interface driver usbfs [ 1.318180] usbcore: registered new interface driver hub [ 1.318258] usbcore: registered new device driver usb [ 1.318719] pps_core: LinuxPPS API ver. 1 registered [ 1.318733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.318762] PTP clock support registered [ 1.318793] EDAC MC: Ver: 3.0.0 [ 1.319526] FPGA manager framework [ 1.319641] Advanced Linux Sound Architecture Driver Initialized. [ 1.320242] NetLabel: Initializing [ 1.320259] NetLabel: domain hash size = 128 [ 1.320268] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.320331] NetLabel: unlabeled traffic allowed by default [ 1.320796] clocksource: Switched to clocksource arch_sys_counter [ 1.321068] VFS: Disk quotas dquot_6.6.0 [ 1.321138] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.321260] FS-Cache: Loaded [ 1.321657] pnp: PnP ACPI: disabled [ 1.329064] NET: Registered protocol family 2 [ 1.329567] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.329622] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.329810] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.330249] TCP: Hash tables configured (established 32768 bind 32768) [ 1.330390] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.330466] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.330719] NET: Registered protocol family 1 [ 1.331198] RPC: Registered named UNIX socket transport module. [ 1.331215] RPC: Registered udp transport module. [ 1.331225] RPC: Registered tcp transport module. [ 1.331235] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.331251] NET: Registered protocol family 44 [ 1.331274] PCI: CLS 0 bytes, default 64 [ 1.331494] Trying to unpack rootfs image as initramfs... [ 1.519157] Freeing initrd memory: 13728K [ 1.691239] Initialise system trusted keyrings [ 1.691453] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 1.699067] zbud: loaded [ 1.700833] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.701211] FS-Cache: Netfs 'nfs' registered for caching [ 1.701877] NFS: Registering the id_resolver key type [ 1.701911] Key type id_resolver registered [ 1.701921] Key type id_legacy registered [ 1.701940] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.701954] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.703239] FS-Cache: Netfs 'cifs' registered for caching [ 1.703572] Key type cifs.spnego registered [ 1.703598] Key type cifs.idmap registered [ 1.703614] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.704341] JFS: nTxBlock = 8192, nTxLock = 65536 [ 1.709726] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [ 1.711704] ocfs2: Registered cluster interface o2cb [ 1.711905] OCFS2 User DLM kernel interface loaded [ 1.713647] gfs2: GFS2 installed [ 1.714839] aufs 5.x-rcN-20200413 [ 1.734282] NET: Registered protocol family 38 [ 1.734317] Key type asymmetric registered [ 1.734331] Asymmetric key parser 'x509' registered [ 1.734342] Asymmetric key parser 'pkcs8' registered [ 1.734421] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.734631] io scheduler mq-deadline registered [ 1.734653] io scheduler kyber registered [ 1.734871] io scheduler bfq registered [ 1.752506] soc soc0: Amlogic Meson SM1 (Unknown) Revision 2b:c (10:2) Detected [ 1.754232] pwm-regulator: supplied by regulator-dummy [ 1.754486] VCC_3V3: supplied by VSYS_3V3 [ 1.754560] VCC_1V8: supplied by VCC_3V3 [ 1.754636] VDDIO_AO1V8: supplied by VSYS_3V3 [ 1.754712] EMMC_AO1V8: supplied by VCC_3V3 [ 1.754904] pwm-regulator: supplied by regulator-dummy [ 1.758934] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [ 1.761172] Serial: AMBA driver [ 1.761567] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart [ 2.783963] printk: console [ttyAML0] enabled [ 2.788916] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 20, base_baud = 1500000) is a meson_uart [ 2.797707] serial serial0: tty port ttyAML6 registered [ 2.815822] brd: module loaded [ 2.824562] loop: module loaded [ 2.829773] libphy: Fixed MDIO Bus: probed [ 2.832082] VFIO - User Level meta-driver version: 0.3 [ 2.834675] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.839862] ehci-pci: EHCI PCI platform driver [ 2.844279] ehci-platform: EHCI generic platform driver [ 2.849569] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.855537] ohci-pci: OHCI PCI platform driver [ 2.859961] ohci-platform: OHCI generic platform driver [ 2.865612] usbcore: registered new interface driver usb-storage [ 2.871253] mousedev: PS/2 mouse device common for all mice [ 2.877562] i2c /dev entries driver [ 2.886595] sdhci: Secure Digital Host Controller Interface driver [ 2.887147] sdhci: Copyright(c) Pierre Ossman [ 2.891519] Synopsys Designware Multimedia Card Interface Driver [ 2.898357] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq [ 2.934207] meson-gx-mmc ffe05000.sd: Got CD GPIO [ 2.966200] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq [ 2.966546] mmc0: queuing unknown CIS tuple 0x80 (2 bytes) [ 2.975683] mmc0: queuing unknown CIS tuple 0x80 (7 bytes) [ 2.979178] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.995409] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.997784] ledtrig-cpu: registered to indicate activity on CPUs [ 3.002226] meson-sm: secure-monitor enabled [ 3.005178] mmc1: new high speed SDXC card at address e624 [ 3.006001] hid: raw HID events driver (C) Jiri Kosina [ 3.012033] mmcblk1: mmc1:e624 SU64G 59.5 GiB [ 3.016555] usbcore: registered new interface driver usbhid [ 3.022508] mmcblk1: p1 p2 [ 3.026191] usbhid: USB HID core driver [ 3.039784] no UART detected at 0x1 [ 3.043993] NET: Registered protocol family 17 [ 3.044266] Key type dns_resolver registered [ 3.047794] registered taskstats version 1 [ 3.051232] Loading compiled-in X.509 certificates [ 3.055976] zswap: loaded using pool lzo/zbud [ 3.060641] Key type ._fscrypt registered [ 3.064150] Key type .fscrypt registered [ 3.068030] Key type fscrypt-provisioning registered [ 3.068800] random: fast init done [ 3.073980] Btrfs loaded, crc32c=crc32c-generic [ 3.087293] mmc0: new high speed SDIO card at address 0001 [ 3.097094] Key type encrypted registered [ 3.117234] VCC_5V: supplied by DC_IN [ 3.117565] USB_PWR: supplied by VCC_5V [ 3.142764] mmc2: new HS200 MMC card at address 0001 [ 3.143497] mmcblk2: mmc2:0001 HBG4a2 29.1 GiB [ 3.146962] mmcblk2boot0: mmc2:0001 HBG4a2 partition 1 4.00 MiB [ 3.152870] mmcblk2boot1: mmc2:0001 HBG4a2 partition 2 4.00 MiB [ 3.158550] mmcblk2rpmb: mmc2:0001 HBG4a2 partition 3 4.00 MiB, chardev (241:0) [ 3.194972] meson-drm ff900000.vpu: Queued 2 outputs on vpu [ 3.195241] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.201606] meson-drm ff900000.vpu: CVBS Output connector not available [ 3.232845] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) [ 3.237415] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver [ 3.245511] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops) [ 3.252695] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 [ 3.529195] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 3.529220] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 3.529242] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 3.529260] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 3.529279] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: 16:9 [ 3.529297] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 3.529312] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 3.529332] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 3.529349] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 3.529367] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 3.529384] meson-dw-hdmi ff600000.hdmi-tx: video code: 4 [ 3.529401] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 3.529420] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 3.529436] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 3.529456] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 3.529505] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 3.529521] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 3.529536] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 3.529558] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) [ 3.609128] Console: switching to colour frame buffer device 160x45 [ 3.751608] meson-drm ff900000.vpu: fb0: mesondrmfb frame buffer device [ 3.759048] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found [ 3.764733] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found [ 3.770923] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock [ 3.776806] meson8b-dwmac ff3f0000.ethernet: no reset control found [ 3.783908] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 3.790106] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 [ 3.795254] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported [ 3.802668] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported [ 3.810085] meson8b-dwmac ff3f0000.ethernet: COE Type 2 [ 3.815256] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported [ 3.822243] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported [ 3.828657] meson8b-dwmac ff3f0000.ethernet: Normal descriptors [ 3.834495] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled [ 3.840269] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.848559] libphy: stmmac: probed [ 3.852583] dwc3-meson-g12a ffe09000.usb: USB2 ports: 1 [ 3.856765] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 [ 3.863961] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.867389] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 3.875060] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 [ 3.884301] xhci-hcd xhci-hcd.3.auto: irq 28, io mem 0xff500000 [ 3.890402] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07 [ 3.898323] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.905477] usb usb1: Product: xHCI Host Controller [ 3.910305] usb usb1: Manufacturer: Linux 5.7.0-rc4-arm-64 xhci-hcd [ 3.916516] usb usb1: SerialNumber: xhci-hcd.3.auto [ 3.921767] hub 1-0:1.0: USB hub found [ 3.925079] hub 1-0:1.0: 2 ports detected [ 3.929318] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.934464] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 [ 3.942056] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 3.948551] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.956613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07 [ 3.964730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.971889] usb usb2: Product: xHCI Host Controller [ 3.976718] usb usb2: Manufacturer: Linux 5.7.0-rc4-arm-64 xhci-hcd [ 3.982929] usb usb2: SerialNumber: xhci-hcd.3.auto [ 3.988095] hub 2-0:1.0: USB hub found [ 3.991486] hub 2-0:1.0: 1 port detected [ 3.998821] printk: console [netcon0] enabled [ 4.000447] netconsole: network logging started [ 4.004711] ALSA device list: [ 4.007090] No soundcards found. [ 4.011901] Freeing unused kernel memory: 3904K [ 4.015063] Run /init as init process [ 4.018553] with arguments: [ 4.018556] /init [ 4.018557] with environment: [ 4.018560] HOME=/ [ 4.018562] TERM=linux [ 4.264857] usb 1-2: new high-speed USB device number 2 using xhci-hcd [ 4.360020] libphy: mdio_mux: probed [ 4.413252] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 4.415550] libphy: mdio_mux: probed [ 4.415815] meson-vrtc ff8000a8.rtc: registered as rtc0 [ 4.417575] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.417581] usb 1-2: Product: USB 2.0 Hub [ 4.420989] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 4.492945] hub 1-2:1.0: USB hub found [ 4.496078] hub 1-2:1.0: 4 ports detected [ 4.884850] usb 1-2.2: new low-speed USB device number 3 using xhci-hcd [ 5.116972] usb 1-2.2: New USB device found, idVendor=0458, idProduct=0708, bcdDevice= 1.00 [ 5.127923] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.135149] usb 1-2.2: Product: Multimedia Keyboard [ 5.139980] usb 1-2.2: Manufacturer: Genius [ 5.240033] input: Genius Multimedia Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.0/0003:0458:0708.0001/input/input0 [ 5.321352] hid-generic 0003:0458:0708.0001: input,hidraw0: USB HID v1.11 Keyboard [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input0 [ 5.344953] input: Genius Multimedia Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:0458:0708.0002/input/input1 [ 5.453319] hid-generic 0003:0458:0708.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input1 [ 5.647369] usb 1-2.4: new full-speed USB device number 4 using xhci-hcd [ 5.896147] usb 1-2.4: New USB device found, idVendor=1ea7, idProduct=0030, bcdDevice= 2.00 [ 5.907868] usb 1-2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 5.915082] usb 1-2.4: Product: USB Gaming Mouse [ 6.053710] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.0/0003:1EA7:0030.0003/input/input2 [ 6.167490] hid-generic 0003:1EA7:0030.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input0 [ 6.185931] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.1/0003:1EA7:0030.0004/input/input3 [ 6.201732] hid-generic 0003:1EA7:0030.0004: input,hidraw3: USB HID v1.10 Mouse [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input1 [ 6.217056] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input4 [ 6.233058] input: USB Gaming Mouse Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input5 [ 6.311484] input: USB Gaming Mouse System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input6 [ 6.391725] hid-generic 0003:1EA7:0030.0005: input,hiddev1,hidraw4: USB HID v1.10 Device [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input2 [ 11.506529] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 12.331186] systemd[1]: System time before build time, advancing clock. [ 12.514254] NET: Registered protocol family 10 [ 12.578049] Segment Routing with IPv6 [ 12.636365] systemd[1]: systemd 245.4-4ubuntu3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid) [ 12.669379] systemd[1]: Detected architecture arm64. [ 12.741560] systemd[1]: Set hostname to <arm-64>. [ 13.175304] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly. [ 13.480383] random: systemd: uninitialized urandom read (16 bytes read) [ 13.489038] systemd[1]: Created slice system-modprobe.slice. [ 13.498258] random: systemd: uninitialized urandom read (16 bytes read) [ 13.503794] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 13.512482] random: systemd: uninitialized urandom read (16 bytes read) [ 13.517829] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 13.527646] systemd[1]: Created slice User and Session Slice. [ 13.534326] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 13.542399] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 13.551603] systemd[1]: Reached target User and Group Name Lookups. [ 13.560340] systemd[1]: Reached target Remote File Systems. [ 13.565768] systemd[1]: Reached target Slices. [ 13.570976] systemd[1]: Reached target Swap. [ 13.576164] systemd[1]: Reached target System Time Set. [ 13.589931] systemd[1]: Listening on Syslog Socket. [ 13.601165] systemd[1]: Listening on fsck to fsckd communication Socket. [ 13.610262] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 13.617229] systemd[1]: Listening on Journal Audit Socket. [ 13.622636] systemd[1]: Listening on Journal Socket (/dev/log). [ 13.628413] systemd[1]: Listening on Journal Socket. [ 13.633944] systemd[1]: Listening on udev Control Socket. [ 13.639179] systemd[1]: Listening on udev Kernel Socket. [ 13.647526] systemd[1]: Mounting Huge Pages File System... [ 13.656556] systemd[1]: Mounting POSIX Message Queue File System... [ 13.666050] systemd[1]: Mounting Kernel Debug File System... [ 13.671318] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 13.682480] systemd[1]: Starting Restore / save the current clock... [ 13.693688] systemd[1]: Starting Set the console keyboard layout... [ 13.703938] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 13.712168] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 13.721872] systemd[1]: Started Nameserver information manager. [ 13.727955] systemd[1]: Reached target Network (Pre). [ 13.737903] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 13.744081] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 13.750288] systemd[1]: Starting Load Kernel Modules... [ 13.765294] systemd[1]: Starting Remount Root and Kernel File Systems... [ 13.775425] systemd[1]: Starting udev Coldplug all Devices... [ 13.786054] systemd[1]: Mounted Huge Pages File System. [ 13.791718] systemd[1]: Mounted POSIX Message Queue File System. [ 13.796432] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 13.805158] systemd[1]: Mounted Kernel Debug File System. [ 13.812277] systemd[1]: Finished Restore / save the current clock. [ 13.820322] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 13.832697] systemd[1]: Finished Load Kernel Modules. [ 13.840137] systemd[1]: Finished Remount Root and Kernel File Systems. [ 13.847906] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 13.858292] systemd[1]: Mounting Kernel Configuration File System... [ 13.867178] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 13.872690] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 13.885412] systemd[1]: Starting Load/Save Random Seed... [ 13.895536] systemd[1]: Starting Apply Kernel Variables... [ 13.905208] systemd[1]: Starting Create System Users... [ 13.914536] systemd[1]: Mounted Kernel Configuration File System. [ 13.970109] systemd[1]: Finished Create System Users. [ 13.979720] systemd[1]: Starting Create Static Device Nodes in /dev... [ 13.988001] systemd[1]: Finished Set the console keyboard layout. [ 13.993623] systemd[1]: Finished Apply Kernel Variables. [ 14.029759] systemd[1]: Finished Create Static Device Nodes in /dev. [ 14.033011] systemd[1]: Reached target Local File Systems (Pre). [ 14.040579] systemd[1]: Mounting /tmp... [ 14.048214] systemd[1]: Starting udev Kernel Device Manager... [ 14.054687] systemd[1]: Mounted /tmp. [ 14.107587] systemd[1]: Finished udev Coldplug all Devices. [ 14.118853] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 14.142738] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 14.264479] systemd[1]: Started udev Kernel Device Manager. [ 14.269750] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 14.270270] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 14.277063] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 14.277189] systemd[1]: Reached target Local Encrypted Volumes. [ 14.595853] systemd[1]: Found device /dev/ttyS2. [ 14.668882] mc: Linux media interface: v0.10 [ 14.715661] videodev: Linux video capture interface: v2.00 [ 14.763599] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 14.815282] systemd[1]: Found device /dev/ttyAML0. [ 14.841246] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present! [ 14.860934] Registered IR keymap rc-khadas [ 14.881222] IR NEC protocol handler initialized [ 14.908963] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 [ 14.917176] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter [ 14.917318] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input8 [ 14.929163] meson-ir ff808000.ir: receiver initialized [ 14.993479] axg-sound-card sound: snd-soc-dummy-dai <-> ff6601c0.audio-controller mapping ok [ 14.994777] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 14.995679] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 14.996346] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 14.997202] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 14.997663] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 14.998155] axg-sound-card sound: snd-soc-dummy-dai <-> ff660200.audio-controller mapping ok [ 14.998426] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 14.998941] axg-sound-card sound: snd-soc-dummy-dai <-> ff660240.audio-controller mapping ok [ 14.999021] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 14.999510] axg-sound-card sound: I2S IN B <-> TDM Pad mapping ok [ 14.999525] axg-sound-card sound: snd-soc-dummy-dai <-> TDM Loopback mapping ok [ 14.999536] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok [ 14.999636] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 14.999661] axg-sound-card sound: ASoC: no DMI vendor name! [ 15.000054] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.007164] panfrost ffe40000.gpu: clock rate = 799999987 [ 15.008698] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 [ 15.008707] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400 [ 15.008712] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 15.008714] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1 [ 15.021657] debugfs: Directory 'ffe40000.gpu-mali' with parent 'VDDGPU' already present! [ 15.022761] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 [ 15.134284] Bluetooth: Core ver 2.22 [ 15.134290] Bluetooth: Starting self testing [ 15.157668] Bluetooth: ECDH test passed in 22818 usecs [ 15.168541] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 15.170466] Bluetooth: SMP test passed in 12427 usecs [ 15.170508] Bluetooth: Finished self testing [ 15.170603] NET: Registered protocol family 31 [ 15.170606] Bluetooth: HCI device and connection manager initialized [ 15.170620] Bluetooth: HCI socket layer initialized [ 15.170627] Bluetooth: L2CAP socket layer initialized [ 15.170641] Bluetooth: SCO socket layer initialized [ 15.194625] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 15.201469] systemd[1]: Found device /sys/subsystem/net/devices/eth0. [ 15.256871] rc rc0: two consecutive events of type space [ 15.326451] brcmfmac: F1 signature read @0x18000000=0x16024335 [ 15.332965] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 15.333760] usbcore: registered new interface driver brcmfmac [ 15.366502] Bluetooth: HCI UART driver ver 2.3 [ 15.366510] Bluetooth: HCI UART protocol H4 registered [ 15.366512] Bluetooth: HCI UART protocol BCSP registered [ 15.366567] Bluetooth: HCI UART protocol LL registered [ 15.366569] Bluetooth: HCI UART protocol ATH3K registered [ 15.366596] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 15.366917] Bluetooth: HCI UART protocol Intel registered [ 15.367224] Bluetooth: HCI UART protocol Broadcom registered [ 15.367267] Bluetooth: HCI UART protocol QCA registered [ 15.367269] Bluetooth: HCI UART protocol AG6XX registered [ 15.367295] Bluetooth: HCI UART protocol Marvell registered [ 15.367373] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator [ 15.367443] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator [ 15.382737] systemd[1]: Found device /dev/disk/by-label/BOOT. [ 15.419659] random: crng init done [ 15.419670] random: 7 urandom warning(s) missed due to ratelimiting [ 15.434159] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 15.434517] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 15.437990] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 15.438273] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 15.438513] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 15.438586] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 15.438930] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 15.439008] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 15.443012] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT... [ 15.472331] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 15.472551] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.478269] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 15.499015] systemd[1]: Started File System Check Daemon to report status. [ 15.510154] systemd[1]: Finished Load/Save Random Seed. [ 15.534798] systemd[1]: Started Load/Save RF Kill Switch Status. [ 15.620220] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 15.620696] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 15.620978] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 15.621175] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 15.621239] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 15.621547] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 15.621606] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 15.621724] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 15.621811] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.753916] Bluetooth: hci1: BCM: chip id 86 [ 15.754431] Bluetooth: hci1: BCM: features 0x2f [ 15.756137] Bluetooth: hci1: BCM4335C0 [ 15.756146] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 15.957887] systemd[1]: Finished File System Check on /dev/disk/by-label/BOOT. [ 15.966084] systemd[1]: Mounting /boot... [ 16.056735] systemd[1]: Mounted /boot. [ 16.061967] systemd[1]: Reached target Local File Systems. [ 16.070553] systemd[1]: Starting Armbian ZRAM config... [ 16.076615] systemd[1]: Starting Set console font and keymap... [ 16.083104] systemd[1]: Started ifup for eth0. [ 16.089835] systemd[1]: Starting Raise network interfaces... [ 16.096401] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 16.102091] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 16.102248] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 16.104742] systemd[1]: Finished Set console font and keymap. [ 16.158845] systemd[1]: plymouth-read-write.service: Succeeded. [ 16.161231] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 16.496538] zram: Added device: zram0 [ 16.498633] zram: Added device: zram1 [ 16.502313] zram: Added device: zram2 [ 16.546133] zram1: detected capacity change from 0 to 1073741824 [ 16.552881] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=29) [ 16.564847] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found [ 16.564861] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW [ 16.564871] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rgmii link mode [ 16.585747] systemd[1]: Finished Raise network interfaces. [ 16.608878] Adding 1048572k swap on /dev/zram1. Priority:5 extents:1 across:1048572k SSFS [ 16.625497] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0671 [ 16.702029] zram0: detected capacity change from 0 to 52428800 [ 16.768291] systemd[1]: Finished Armbian ZRAM config. [ 16.784016] systemd[1]: Starting Armbian memory supported logging... [ 16.860837] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 16.860902] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) [ 17.653040] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 17.653169] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 17.657024] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4339/2 wl0: Aug 11 2018 06:13:33 version 6.37.39.99 (r694622 CY) [ 18.664967] systemd[1]: Finished Armbian memory supported logging. [ 18.674094] systemd[1]: Starting Journal Service... [ 19.224948] systemd[1]: Started Journal Service. [ 19.250917] systemd-journald[777]: Received client request to flush runtime journal. [ 21.184596] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 21.184604] Bluetooth: BNEP filters: protocol multicast [ 21.184619] Bluetooth: BNEP socket layer initialized [ 26.828968] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 26.828976] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 26.828980] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 26.828983] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 26.828985] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: No Data [ 26.828988] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 26.828990] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 26.828993] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 26.828996] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 26.828999] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 26.829001] meson-dw-hdmi ff600000.hdmi-tx: video code: 0 [ 26.829004] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 26.829007] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 26.829009] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 26.829012] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 26.829028] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 26.829030] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 26.829033] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 26.829036] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) [ 28.460628] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) [ 28.460637] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 [ 28.460644] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-4-playback event failed: -22 [ 28.485599] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) [ 28.485608] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 [ 28.485615] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-4-playback event failed: -22 [ 28.977590] Bluetooth: RFCOMM TTY layer initialized [ 28.977617] Bluetooth: RFCOMM socket layer initialized [ 28.977652] Bluetooth: RFCOMM ver 1.11 [ 29.177550] overlayfs: "xino" feature enabled using 2 upper inode bits. [ 29.283822] overlayfs: "xino" feature enabled using 2 upper inode bits. [ 29.894059] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 29.958508] fuse: init (API version 7.31) [ 31.437103] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 31.437113] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 31.437116] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 31.437119] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 31.437121] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: No Data [ 31.437124] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 31.437127] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 31.437130] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 31.437133] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 31.437136] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 31.437139] meson-dw-hdmi ff600000.hdmi-tx: video code: 0 [ 31.437141] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 31.437144] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 31.437147] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 31.437150] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 31.437167] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 31.437170] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 31.437172] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 31.437175] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) I'm on 5.7.0-rc4 kernel Focal Desktop and you on older one, @Albert Barcelona try change that (boot from usb latest @balbes150 images). On my TV and PC monitor now sound work. Or hdmi on your and my box connected to different SoC legs... My aplay -l output is same. Edited May 13, 2020 by root-stas Link to comment Share on other sites More sharing options...
Albert Barcelona Posted May 13, 2020 Share Posted May 13, 2020 1 hour ago, root-stas said: You welcome, we on same boat That's my last dmesg: Reveal hidden contents [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd050] [ 0.000000] Linux version 5.7.0-rc4-arm-64 (root@vbox) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)), GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #20.05.4 SMP PREEMPT Sun May 10 13:21:46 MSK 2020 [ 0.000000] Machine model: H96 Max X3 4/32 1GbE/WiFi-AC/BT4 [ 0.000000] efi: UEFI not found. [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000b5800000, size 896 MiB [ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool [ 0.000000] On node 0 totalpages: 972032 [ 0.000000] DMA zone: 4096 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 261376 pages, LIFO batch:63 [ 0.000000] DMA32 zone: 11104 pages used for memmap [ 0.000000] DMA32 zone: 710656 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 22 pages/cpu s51160 r8192 d30760 u90112 [ 0.000000] pcpu-alloc: s51160 r8192 d30760 u90112 alloc=22*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: Virtualization Host Extensions [ 0.000000] CPU features: detected: ARM errata 1165522, 1530923 [ 0.000000] alternatives: patching kernel code [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 956832 [ 0.000000] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw video=1280x720 console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x38a97000-0x3ca97000] (64MB) [ 0.000000] Memory: 2781180K/3888128K available (16316K kernel code, 1518K rwdata, 7024K rodata, 3904K init, 945K bss, 189444K reserved, 917504K cma-reserved) [ 0.000000] random: get_random_u64 called from cache_random_seq_create+0x84/0x158 with crng_init=0 [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] irq_meson_gpio: 100 to 8 gpio interrupt mux initialized [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000179] Console: colour dummy device 80x25 [ 0.000541] printk: console [tty0] enabled [ 0.000586] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.000610] pid_max: default: 32768 minimum: 301 [ 0.000752] LSM: Security Framework initializing [ 0.000818] SELinux: Initializing. [ 0.000983] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.001010] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002577] rcu: Hierarchical SRCU implementation. [ 0.005355] EFI services will not be available. [ 0.005713] smp: Bringing up secondary CPUs ... [ 0.006544] Detected VIPT I-cache on CPU1 [ 0.006606] CPU1: Booted secondary processor 0x0000000100 [0x411fd050] [ 0.007449] Detected VIPT I-cache on CPU2 [ 0.007484] CPU2: Booted secondary processor 0x0000000200 [0x411fd050] [ 0.008258] Detected VIPT I-cache on CPU3 [ 0.008294] CPU3: Booted secondary processor 0x0000000300 [0x411fd050] [ 0.008374] smp: Brought up 1 node, 4 CPUs [ 0.008442] SMP: Total of 4 processors activated. [ 0.008455] CPU features: detected: Privileged Access Never [ 0.008466] CPU features: detected: LSE atomic instructions [ 0.008477] CPU features: detected: User Access Override [ 0.008488] CPU features: detected: 32-bit EL0 Support [ 0.008499] CPU features: detected: Common not Private translations [ 0.008511] CPU features: detected: RAS Extension Support [ 0.008521] CPU features: detected: Data cache clean to the PoU not required for I/D coherence [ 0.008537] CPU features: detected: CRC32 instructions [ 0.039690] CPU: All CPU(s) started at EL2 [ 0.042122] devtmpfs: initialized [ 0.053662] Registered cp15_barrier emulation handler [ 0.053693] Registered setend emulation handler [ 0.053712] KASLR disabled due to lack of seed [ 0.054027] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.054061] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.072232] xor: measuring software checksum speed [ 0.108844] 8regs : 2242.000 MB/sec [ 0.148881] 32regs : 2833.000 MB/sec [ 0.188927] arm64_neon: 2407.000 MB/sec [ 0.188939] xor: using function: 32regs (2833.000 MB/sec) [ 0.189004] pinctrl core: initialized pinctrl subsystem [ 0.189833] thermal_sys: Registered thermal governor 'step_wise' [ 0.190303] DMI not present or invalid. [ 0.190807] NET: Registered protocol family 16 [ 0.192302] DMA: preallocated 256 KiB pool for atomic allocations [ 0.192340] audit: initializing netlink subsys (disabled) [ 0.192514] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1 [ 0.194036] cpuidle: using governor ladder [ 0.194072] cpuidle: using governor menu [ 0.194390] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.194507] ASID allocator initialised with 65536 entries [ 0.195592] Serial: AMBA PL011 UART driver [ 0.215245] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.215276] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.215291] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.215306] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.219511] cryptd: max_cpu_qlen set to 1000 [ 0.293174] raid6: neonx8 gen() 2131 MB/s [ 0.361257] raid6: neonx8 xor() 1657 MB/s [ 0.429389] raid6: neonx4 gen() 2193 MB/s [ 0.497431] raid6: neonx4 xor() 1649 MB/s [ 0.565500] raid6: neonx2 gen() 2084 MB/s [ 0.633558] raid6: neonx2 xor() 1509 MB/s [ 0.701624] raid6: neonx1 gen() 1790 MB/s [ 0.769691] raid6: neonx1 xor() 1270 MB/s [ 0.837781] raid6: int64x8 gen() 1516 MB/s [ 0.905830] raid6: int64x8 xor() 781 MB/s [ 0.973879] raid6: int64x4 gen() 1646 MB/s [ 1.041945] raid6: int64x4 xor() 848 MB/s [ 1.110020] raid6: int64x2 gen() 1479 MB/s [ 1.178085] raid6: int64x2 xor() 756 MB/s [ 1.246135] raid6: int64x1 gen() 1107 MB/s [ 1.314198] raid6: int64x1 xor() 570 MB/s [ 1.314212] raid6: using algorithm neonx4 gen() 2193 MB/s [ 1.314224] raid6: .... xor() 1649 MB/s, rmw enabled [ 1.314235] raid6: using neon recovery algorithm [ 1.314829] ACPI: Interpreter disabled. [ 1.316368] VSYS_3V3: supplied by DC_IN [ 1.316863] iommu: Default domain type: Translated [ 1.317152] vgaarb: loaded [ 1.317667] SCSI subsystem initialized [ 1.317857] libata version 3.00 loaded. [ 1.318120] usbcore: registered new interface driver usbfs [ 1.318180] usbcore: registered new interface driver hub [ 1.318258] usbcore: registered new device driver usb [ 1.318719] pps_core: LinuxPPS API ver. 1 registered [ 1.318733] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.318762] PTP clock support registered [ 1.318793] EDAC MC: Ver: 3.0.0 [ 1.319526] FPGA manager framework [ 1.319641] Advanced Linux Sound Architecture Driver Initialized. [ 1.320242] NetLabel: Initializing [ 1.320259] NetLabel: domain hash size = 128 [ 1.320268] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.320331] NetLabel: unlabeled traffic allowed by default [ 1.320796] clocksource: Switched to clocksource arch_sys_counter [ 1.321068] VFS: Disk quotas dquot_6.6.0 [ 1.321138] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.321260] FS-Cache: Loaded [ 1.321657] pnp: PnP ACPI: disabled [ 1.329064] NET: Registered protocol family 2 [ 1.329567] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear) [ 1.329622] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear) [ 1.329810] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear) [ 1.330249] TCP: Hash tables configured (established 32768 bind 32768) [ 1.330390] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.330466] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear) [ 1.330719] NET: Registered protocol family 1 [ 1.331198] RPC: Registered named UNIX socket transport module. [ 1.331215] RPC: Registered udp transport module. [ 1.331225] RPC: Registered tcp transport module. [ 1.331235] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.331251] NET: Registered protocol family 44 [ 1.331274] PCI: CLS 0 bytes, default 64 [ 1.331494] Trying to unpack rootfs image as initramfs... [ 1.519157] Freeing initrd memory: 13728K [ 1.691239] Initialise system trusted keyrings [ 1.691453] workingset: timestamp_bits=46 max_order=20 bucket_order=0 [ 1.699067] zbud: loaded [ 1.700833] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 1.701211] FS-Cache: Netfs 'nfs' registered for caching [ 1.701877] NFS: Registering the id_resolver key type [ 1.701911] Key type id_resolver registered [ 1.701921] Key type id_legacy registered [ 1.701940] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 1.701954] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 1.703239] FS-Cache: Netfs 'cifs' registered for caching [ 1.703572] Key type cifs.spnego registered [ 1.703598] Key type cifs.idmap registered [ 1.703614] ntfs: driver 2.1.32 [Flags: R/W]. [ 1.704341] JFS: nTxBlock = 8192, nTxLock = 65536 [ 1.709726] SGI XFS with ACLs, security attributes, realtime, quota, no debug enabled [ 1.711704] ocfs2: Registered cluster interface o2cb [ 1.711905] OCFS2 User DLM kernel interface loaded [ 1.713647] gfs2: GFS2 installed [ 1.714839] aufs 5.x-rcN-20200413 [ 1.734282] NET: Registered protocol family 38 [ 1.734317] Key type asymmetric registered [ 1.734331] Asymmetric key parser 'x509' registered [ 1.734342] Asymmetric key parser 'pkcs8' registered [ 1.734421] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.734631] io scheduler mq-deadline registered [ 1.734653] io scheduler kyber registered [ 1.734871] io scheduler bfq registered [ 1.752506] soc soc0: Amlogic Meson SM1 (Unknown) Revision 2b:c (10:2) Detected [ 1.754232] pwm-regulator: supplied by regulator-dummy [ 1.754486] VCC_3V3: supplied by VSYS_3V3 [ 1.754560] VCC_1V8: supplied by VCC_3V3 [ 1.754636] VDDIO_AO1V8: supplied by VSYS_3V3 [ 1.754712] EMMC_AO1V8: supplied by VCC_3V3 [ 1.754904] pwm-regulator: supplied by regulator-dummy [ 1.758934] Serial: 8250/16550 driver, 5 ports, IRQ sharing enabled [ 1.761172] Serial: AMBA driver [ 1.761567] ff803000.serial: ttyAML0 at MMIO 0xff803000 (irq = 14, base_baud = 1500000) is a meson_uart [ 2.783963] printk: console [ttyAML0] enabled [ 2.788916] ffd24000.serial: ttyAML6 at MMIO 0xffd24000 (irq = 20, base_baud = 1500000) is a meson_uart [ 2.797707] serial serial0: tty port ttyAML6 registered [ 2.815822] brd: module loaded [ 2.824562] loop: module loaded [ 2.829773] libphy: Fixed MDIO Bus: probed [ 2.832082] VFIO - User Level meta-driver version: 0.3 [ 2.834675] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.839862] ehci-pci: EHCI PCI platform driver [ 2.844279] ehci-platform: EHCI generic platform driver [ 2.849569] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.855537] ohci-pci: OHCI PCI platform driver [ 2.859961] ohci-platform: OHCI generic platform driver [ 2.865612] usbcore: registered new interface driver usb-storage [ 2.871253] mousedev: PS/2 mouse device common for all mice [ 2.877562] i2c /dev entries driver [ 2.886595] sdhci: Secure Digital Host Controller Interface driver [ 2.887147] sdhci: Copyright(c) Pierre Ossman [ 2.891519] Synopsys Designware Multimedia Card Interface Driver [ 2.898357] meson-gx-mmc ffe03000.sd: allocated mmc-pwrseq [ 2.934207] meson-gx-mmc ffe05000.sd: Got CD GPIO [ 2.966200] meson-gx-mmc ffe07000.mmc: allocated mmc-pwrseq [ 2.966546] mmc0: queuing unknown CIS tuple 0x80 (2 bytes) [ 2.975683] mmc0: queuing unknown CIS tuple 0x80 (7 bytes) [ 2.979178] mmc0: queuing unknown CIS tuple 0x80 (3 bytes) [ 2.995409] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.997784] ledtrig-cpu: registered to indicate activity on CPUs [ 3.002226] meson-sm: secure-monitor enabled [ 3.005178] mmc1: new high speed SDXC card at address e624 [ 3.006001] hid: raw HID events driver (C) Jiri Kosina [ 3.012033] mmcblk1: mmc1:e624 SU64G 59.5 GiB [ 3.016555] usbcore: registered new interface driver usbhid [ 3.022508] mmcblk1: p1 p2 [ 3.026191] usbhid: USB HID core driver [ 3.039784] no UART detected at 0x1 [ 3.043993] NET: Registered protocol family 17 [ 3.044266] Key type dns_resolver registered [ 3.047794] registered taskstats version 1 [ 3.051232] Loading compiled-in X.509 certificates [ 3.055976] zswap: loaded using pool lzo/zbud [ 3.060641] Key type ._fscrypt registered [ 3.064150] Key type .fscrypt registered [ 3.068030] Key type fscrypt-provisioning registered [ 3.068800] random: fast init done [ 3.073980] Btrfs loaded, crc32c=crc32c-generic [ 3.087293] mmc0: new high speed SDIO card at address 0001 [ 3.097094] Key type encrypted registered [ 3.117234] VCC_5V: supplied by DC_IN [ 3.117565] USB_PWR: supplied by VCC_5V [ 3.142764] mmc2: new HS200 MMC card at address 0001 [ 3.143497] mmcblk2: mmc2:0001 HBG4a2 29.1 GiB [ 3.146962] mmcblk2boot0: mmc2:0001 HBG4a2 partition 1 4.00 MiB [ 3.152870] mmcblk2boot1: mmc2:0001 HBG4a2 partition 2 4.00 MiB [ 3.158550] mmcblk2rpmb: mmc2:0001 HBG4a2 partition 3 4.00 MiB, chardev (241:0) [ 3.194972] meson-drm ff900000.vpu: Queued 2 outputs on vpu [ 3.195241] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 3.201606] meson-drm ff900000.vpu: CVBS Output connector not available [ 3.232845] meson-dw-hdmi ff600000.hdmi-tx: Detected HDMI TX controller v2.01a with HDCP (meson_dw_hdmi_phy) [ 3.237415] meson-dw-hdmi ff600000.hdmi-tx: registered DesignWare HDMI I2C bus driver [ 3.245511] meson-drm ff900000.vpu: bound ff600000.hdmi-tx (ops meson_dw_hdmi_ops) [ 3.252695] [drm] Initialized meson 1.0.0 20161109 for ff900000.vpu on minor 0 [ 3.529195] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 3.529220] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 3.529242] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 3.529260] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 3.529279] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: 16:9 [ 3.529297] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 3.529312] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 3.529332] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 3.529349] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 3.529367] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 3.529384] meson-dw-hdmi ff600000.hdmi-tx: video code: 4 [ 3.529401] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 3.529420] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 3.529436] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 3.529456] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 3.529505] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 3.529521] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 3.529536] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 3.529558] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) [ 3.609128] Console: switching to colour frame buffer device 160x45 [ 3.751608] meson-drm ff900000.vpu: fb0: mesondrmfb frame buffer device [ 3.759048] meson8b-dwmac ff3f0000.ethernet: IRQ eth_wake_irq not found [ 3.764733] meson8b-dwmac ff3f0000.ethernet: IRQ eth_lpi not found [ 3.770923] meson8b-dwmac ff3f0000.ethernet: PTP uses main clock [ 3.776806] meson8b-dwmac ff3f0000.ethernet: no reset control found [ 3.783908] meson8b-dwmac ff3f0000.ethernet: User ID: 0x11, Synopsys ID: 0x37 [ 3.790106] meson8b-dwmac ff3f0000.ethernet: DWMAC1000 [ 3.795254] meson8b-dwmac ff3f0000.ethernet: DMA HW capability register supported [ 3.802668] meson8b-dwmac ff3f0000.ethernet: RX Checksum Offload Engine supported [ 3.810085] meson8b-dwmac ff3f0000.ethernet: COE Type 2 [ 3.815256] meson8b-dwmac ff3f0000.ethernet: TX Checksum insertion supported [ 3.822243] meson8b-dwmac ff3f0000.ethernet: Wake-Up On Lan supported [ 3.828657] meson8b-dwmac ff3f0000.ethernet: Normal descriptors [ 3.834495] meson8b-dwmac ff3f0000.ethernet: Ring mode enabled [ 3.840269] meson8b-dwmac ff3f0000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 3.848559] libphy: stmmac: probed [ 3.852583] dwc3-meson-g12a ffe09000.usb: USB2 ports: 1 [ 3.856765] dwc3-meson-g12a ffe09000.usb: USB3 ports: 1 [ 3.863961] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.867389] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1 [ 3.875060] xhci-hcd xhci-hcd.3.auto: hcc params 0x0228fe6c hci version 0x110 quirks 0x0000000000010010 [ 3.884301] xhci-hcd xhci-hcd.3.auto: irq 28, io mem 0xff500000 [ 3.890402] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.07 [ 3.898323] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.905477] usb usb1: Product: xHCI Host Controller [ 3.910305] usb usb1: Manufacturer: Linux 5.7.0-rc4-arm-64 xhci-hcd [ 3.916516] usb usb1: SerialNumber: xhci-hcd.3.auto [ 3.921767] hub 1-0:1.0: USB hub found [ 3.925079] hub 1-0:1.0: 2 ports detected [ 3.929318] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 3.934464] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2 [ 3.942056] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed [ 3.948551] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.956613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.07 [ 3.964730] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.971889] usb usb2: Product: xHCI Host Controller [ 3.976718] usb usb2: Manufacturer: Linux 5.7.0-rc4-arm-64 xhci-hcd [ 3.982929] usb usb2: SerialNumber: xhci-hcd.3.auto [ 3.988095] hub 2-0:1.0: USB hub found [ 3.991486] hub 2-0:1.0: 1 port detected [ 3.998821] printk: console [netcon0] enabled [ 4.000447] netconsole: network logging started [ 4.004711] ALSA device list: [ 4.007090] No soundcards found. [ 4.011901] Freeing unused kernel memory: 3904K [ 4.015063] Run /init as init process [ 4.018553] with arguments: [ 4.018556] /init [ 4.018557] with environment: [ 4.018560] HOME=/ [ 4.018562] TERM=linux [ 4.264857] usb 1-2: new high-speed USB device number 2 using xhci-hcd [ 4.360020] libphy: mdio_mux: probed [ 4.413252] usb 1-2: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11 [ 4.415550] libphy: mdio_mux: probed [ 4.415815] meson-vrtc ff8000a8.rtc: registered as rtc0 [ 4.417575] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 4.417581] usb 1-2: Product: USB 2.0 Hub [ 4.420989] meson-vrtc ff8000a8.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4) [ 4.492945] hub 1-2:1.0: USB hub found [ 4.496078] hub 1-2:1.0: 4 ports detected [ 4.884850] usb 1-2.2: new low-speed USB device number 3 using xhci-hcd [ 5.116972] usb 1-2.2: New USB device found, idVendor=0458, idProduct=0708, bcdDevice= 1.00 [ 5.127923] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.135149] usb 1-2.2: Product: Multimedia Keyboard [ 5.139980] usb 1-2.2: Manufacturer: Genius [ 5.240033] input: Genius Multimedia Keyboard as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.0/0003:0458:0708.0001/input/input0 [ 5.321352] hid-generic 0003:0458:0708.0001: input,hidraw0: USB HID v1.11 Keyboard [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input0 [ 5.344953] input: Genius Multimedia Keyboard Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.2/1-2.2:1.1/0003:0458:0708.0002/input/input1 [ 5.453319] hid-generic 0003:0458:0708.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Genius Multimedia Keyboard] on usb-xhci-hcd.3.auto-2.2/input1 [ 5.647369] usb 1-2.4: new full-speed USB device number 4 using xhci-hcd [ 5.896147] usb 1-2.4: New USB device found, idVendor=1ea7, idProduct=0030, bcdDevice= 2.00 [ 5.907868] usb 1-2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 5.915082] usb 1-2.4: Product: USB Gaming Mouse [ 6.053710] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.0/0003:1EA7:0030.0003/input/input2 [ 6.167490] hid-generic 0003:1EA7:0030.0003: input,hidraw2: USB HID v1.10 Keyboard [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input0 [ 6.185931] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.1/0003:1EA7:0030.0004/input/input3 [ 6.201732] hid-generic 0003:1EA7:0030.0004: input,hidraw3: USB HID v1.10 Mouse [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input1 [ 6.217056] input: USB Gaming Mouse as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input4 [ 6.233058] input: USB Gaming Mouse Consumer Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input5 [ 6.311484] input: USB Gaming Mouse System Control as /devices/platform/soc/ffe09000.usb/ff500000.usb/xhci-hcd.3.auto/usb1/1-2/1-2.4/1-2.4:1.2/0003:1EA7:0030.0005/input/input6 [ 6.391725] hid-generic 0003:1EA7:0030.0005: input,hiddev1,hidraw4: USB HID v1.10 Device [USB Gaming Mouse] on usb-xhci-hcd.3.auto-2.4/input2 [ 11.506529] EXT4-fs (mmcblk1p2): mounted filesystem with writeback data mode. Opts: data=writeback [ 12.331186] systemd[1]: System time before build time, advancing clock. [ 12.514254] NET: Registered protocol family 10 [ 12.578049] Segment Routing with IPv6 [ 12.636365] systemd[1]: systemd 245.4-4ubuntu3 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid) [ 12.669379] systemd[1]: Detected architecture arm64. [ 12.741560] systemd[1]: Set hostname to <arm-64>. [ 13.175304] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; please update the unit file accordingly. [ 13.480383] random: systemd: uninitialized urandom read (16 bytes read) [ 13.489038] systemd[1]: Created slice system-modprobe.slice. [ 13.498258] random: systemd: uninitialized urandom read (16 bytes read) [ 13.503794] systemd[1]: Created slice system-serial\x2dgetty.slice. [ 13.512482] random: systemd: uninitialized urandom read (16 bytes read) [ 13.517829] systemd[1]: Created slice system-systemd\x2dfsck.slice. [ 13.527646] systemd[1]: Created slice User and Session Slice. [ 13.534326] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 13.542399] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 13.551603] systemd[1]: Reached target User and Group Name Lookups. [ 13.560340] systemd[1]: Reached target Remote File Systems. [ 13.565768] systemd[1]: Reached target Slices. [ 13.570976] systemd[1]: Reached target Swap. [ 13.576164] systemd[1]: Reached target System Time Set. [ 13.589931] systemd[1]: Listening on Syslog Socket. [ 13.601165] systemd[1]: Listening on fsck to fsckd communication Socket. [ 13.610262] systemd[1]: Listening on initctl Compatibility Named Pipe. [ 13.617229] systemd[1]: Listening on Journal Audit Socket. [ 13.622636] systemd[1]: Listening on Journal Socket (/dev/log). [ 13.628413] systemd[1]: Listening on Journal Socket. [ 13.633944] systemd[1]: Listening on udev Control Socket. [ 13.639179] systemd[1]: Listening on udev Kernel Socket. [ 13.647526] systemd[1]: Mounting Huge Pages File System... [ 13.656556] systemd[1]: Mounting POSIX Message Queue File System... [ 13.666050] systemd[1]: Mounting Kernel Debug File System... [ 13.671318] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 13.682480] systemd[1]: Starting Restore / save the current clock... [ 13.693688] systemd[1]: Starting Set the console keyboard layout... [ 13.703938] systemd[1]: Starting Create list of static device nodes for the current kernel... [ 13.712168] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped. [ 13.721872] systemd[1]: Started Nameserver information manager. [ 13.727955] systemd[1]: Reached target Network (Pre). [ 13.737903] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 13.744081] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 13.750288] systemd[1]: Starting Load Kernel Modules... [ 13.765294] systemd[1]: Starting Remount Root and Kernel File Systems... [ 13.775425] systemd[1]: Starting udev Coldplug all Devices... [ 13.786054] systemd[1]: Mounted Huge Pages File System. [ 13.791718] systemd[1]: Mounted POSIX Message Queue File System. [ 13.796432] EXT4-fs (mmcblk1p2): re-mounted. Opts: commit=600,errors=remount-ro [ 13.805158] systemd[1]: Mounted Kernel Debug File System. [ 13.812277] systemd[1]: Finished Restore / save the current clock. [ 13.820322] systemd[1]: Finished Create list of static device nodes for the current kernel. [ 13.832697] systemd[1]: Finished Load Kernel Modules. [ 13.840137] systemd[1]: Finished Remount Root and Kernel File Systems. [ 13.847906] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 13.858292] systemd[1]: Mounting Kernel Configuration File System... [ 13.867178] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 13.872690] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 13.885412] systemd[1]: Starting Load/Save Random Seed... [ 13.895536] systemd[1]: Starting Apply Kernel Variables... [ 13.905208] systemd[1]: Starting Create System Users... [ 13.914536] systemd[1]: Mounted Kernel Configuration File System. [ 13.970109] systemd[1]: Finished Create System Users. [ 13.979720] systemd[1]: Starting Create Static Device Nodes in /dev... [ 13.988001] systemd[1]: Finished Set the console keyboard layout. [ 13.993623] systemd[1]: Finished Apply Kernel Variables. [ 14.029759] systemd[1]: Finished Create Static Device Nodes in /dev. [ 14.033011] systemd[1]: Reached target Local File Systems (Pre). [ 14.040579] systemd[1]: Mounting /tmp... [ 14.048214] systemd[1]: Starting udev Kernel Device Manager... [ 14.054687] systemd[1]: Mounted /tmp. [ 14.107587] systemd[1]: Finished udev Coldplug all Devices. [ 14.118853] systemd[1]: Starting Helper to synchronize boot up for ifupdown... [ 14.142738] systemd[1]: Finished Helper to synchronize boot up for ifupdown. [ 14.264479] systemd[1]: Started udev Kernel Device Manager. [ 14.269750] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 14.270270] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 14.277063] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 14.277189] systemd[1]: Reached target Local Encrypted Volumes. [ 14.595853] systemd[1]: Found device /dev/ttyS2. [ 14.668882] mc: Linux media interface: v0.10 [ 14.715661] videodev: Linux video capture interface: v2.00 [ 14.763599] meson_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 14.815282] systemd[1]: Found device /dev/ttyAML0. [ 14.841246] debugfs: Directory 'ff800280.cec' with parent 'regmap' already present! [ 14.860934] Registered IR keymap rc-khadas [ 14.881222] IR NEC protocol handler initialized [ 14.908963] rc rc0: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0 [ 14.917176] rc rc0: lirc_dev: driver meson-ir registered at minor = 0, raw IR receiver, no transmitter [ 14.917318] input: meson-ir as /devices/platform/soc/ff800000.bus/ff808000.ir/rc/rc0/input8 [ 14.929163] meson-ir ff808000.ir: receiver initialized [ 14.993479] axg-sound-card sound: snd-soc-dummy-dai <-> ff6601c0.audio-controller mapping ok [ 14.994777] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 14.995679] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 14.996346] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 14.997202] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 14.997663] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 14.998155] axg-sound-card sound: snd-soc-dummy-dai <-> ff660200.audio-controller mapping ok [ 14.998426] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 14.998941] axg-sound-card sound: snd-soc-dummy-dai <-> ff660240.audio-controller mapping ok [ 14.999021] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 14.999510] axg-sound-card sound: I2S IN B <-> TDM Pad mapping ok [ 14.999525] axg-sound-card sound: snd-soc-dummy-dai <-> TDM Loopback mapping ok [ 14.999536] axg-sound-card sound: i2s-hifi <-> I2S OUT mapping ok [ 14.999636] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 14.999661] axg-sound-card sound: ASoC: no DMI vendor name! [ 15.000054] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.007164] panfrost ffe40000.gpu: clock rate = 799999987 [ 15.008698] panfrost ffe40000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0 [ 15.008707] panfrost ffe40000.gpu: features: 00000000,3fde77ff, issues: 00000000,00000400 [ 15.008712] panfrost ffe40000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7 [ 15.008714] panfrost ffe40000.gpu: shader_present=0x1 l2_present=0x1 [ 15.021657] debugfs: Directory 'ffe40000.gpu-mali' with parent 'VDDGPU' already present! [ 15.022761] [drm] Initialized panfrost 1.1.0 20180908 for ffe40000.gpu on minor 1 [ 15.134284] Bluetooth: Core ver 2.22 [ 15.134290] Bluetooth: Starting self testing [ 15.157668] Bluetooth: ECDH test passed in 22818 usecs [ 15.168541] cfg80211: Loading compiled-in X.509 certificates for regulatory database [ 15.170466] Bluetooth: SMP test passed in 12427 usecs [ 15.170508] Bluetooth: Finished self testing [ 15.170603] NET: Registered protocol family 31 [ 15.170606] Bluetooth: HCI device and connection manager initialized [ 15.170620] Bluetooth: HCI socket layer initialized [ 15.170627] Bluetooth: L2CAP socket layer initialized [ 15.170641] Bluetooth: SCO socket layer initialized [ 15.194625] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7' [ 15.201469] systemd[1]: Found device /sys/subsystem/net/devices/eth0. [ 15.256871] rc rc0: two consecutive events of type space [ 15.326451] brcmfmac: F1 signature read @0x18000000=0x16024335 [ 15.332965] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 15.333760] usbcore: registered new interface driver brcmfmac [ 15.366502] Bluetooth: HCI UART driver ver 2.3 [ 15.366510] Bluetooth: HCI UART protocol H4 registered [ 15.366512] Bluetooth: HCI UART protocol BCSP registered [ 15.366567] Bluetooth: HCI UART protocol LL registered [ 15.366569] Bluetooth: HCI UART protocol ATH3K registered [ 15.366596] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 15.366917] Bluetooth: HCI UART protocol Intel registered [ 15.367224] Bluetooth: HCI UART protocol Broadcom registered [ 15.367267] Bluetooth: HCI UART protocol QCA registered [ 15.367269] Bluetooth: HCI UART protocol AG6XX registered [ 15.367295] Bluetooth: HCI UART protocol Marvell registered [ 15.367373] hci_uart_bcm serial0-0: supply vbat not found, using dummy regulator [ 15.367443] hci_uart_bcm serial0-0: supply vddio not found, using dummy regulator [ 15.382737] systemd[1]: Found device /dev/disk/by-label/BOOT. [ 15.419659] random: crng init done [ 15.419670] random: 7 urandom warning(s) missed due to ratelimiting [ 15.434159] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 15.434517] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 15.437990] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 15.438273] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 15.438513] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 15.438586] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 15.438930] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 15.439008] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 15.443012] systemd[1]: Starting File System Check on /dev/disk/by-label/BOOT... [ 15.472331] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 15.472551] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.478269] systemd[1]: Starting Load/Save RF Kill Switch Status... [ 15.499015] systemd[1]: Started File System Check Daemon to report status. [ 15.510154] systemd[1]: Finished Load/Save Random Seed. [ 15.534798] systemd[1]: Started Load/Save RF Kill Switch Status. [ 15.620220] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped. [ 15.620696] systemd[1]: Condition check resulted in FUSE Control File System being skipped. [ 15.620978] systemd[1]: Condition check resulted in Kernel Trace File System being skipped. [ 15.621175] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped. [ 15.621239] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped. [ 15.621547] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 15.621606] systemd[1]: Condition check resulted in File System Check on Root Device being skipped. [ 15.621724] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 15.621811] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped. [ 15.753916] Bluetooth: hci1: BCM: chip id 86 [ 15.754431] Bluetooth: hci1: BCM: features 0x2f [ 15.756137] Bluetooth: hci1: BCM4335C0 [ 15.756146] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0000 [ 15.957887] systemd[1]: Finished File System Check on /dev/disk/by-label/BOOT. [ 15.966084] systemd[1]: Mounting /boot... [ 16.056735] systemd[1]: Mounted /boot. [ 16.061967] systemd[1]: Reached target Local File Systems. [ 16.070553] systemd[1]: Starting Armbian ZRAM config... [ 16.076615] systemd[1]: Starting Set console font and keymap... [ 16.083104] systemd[1]: Started ifup for eth0. [ 16.089835] systemd[1]: Starting Raise network interfaces... [ 16.096401] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data... [ 16.102091] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped. [ 16.102248] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 16.104742] systemd[1]: Finished Set console font and keymap. [ 16.158845] systemd[1]: plymouth-read-write.service: Succeeded. [ 16.161231] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data. [ 16.496538] zram: Added device: zram0 [ 16.498633] zram: Added device: zram1 [ 16.502313] zram: Added device: zram2 [ 16.546133] zram1: detected capacity change from 0 to 1073741824 [ 16.552881] meson8b-dwmac ff3f0000.ethernet eth0: PHY [0.0:00] driver [RTL8211F Gigabit Ethernet] (irq=29) [ 16.564847] meson8b-dwmac ff3f0000.ethernet eth0: No Safety Features support found [ 16.564861] meson8b-dwmac ff3f0000.ethernet eth0: PTP not supported by HW [ 16.564871] meson8b-dwmac ff3f0000.ethernet eth0: configuring for phy/rgmii link mode [ 16.585747] systemd[1]: Finished Raise network interfaces. [ 16.608878] Adding 1048572k swap on /dev/zram1. Priority:5 extents:1 across:1048572k SSFS [ 16.625497] Bluetooth: hci1: BCM4335C0 (003.001.009) build 0671 [ 16.702029] zram0: detected capacity change from 0 to 52428800 [ 16.768291] systemd[1]: Finished Armbian ZRAM config. [ 16.784016] systemd[1]: Starting Armbian memory supported logging... [ 16.860837] EXT4-fs (zram0): mounted filesystem without journal. Opts: discard [ 16.860902] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff) [ 17.653040] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4339-sdio for chip BCM4339/2 [ 17.653169] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 17.657024] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4339/2 wl0: Aug 11 2018 06:13:33 version 6.37.39.99 (r694622 CY) [ 18.664967] systemd[1]: Finished Armbian memory supported logging. [ 18.674094] systemd[1]: Starting Journal Service... [ 19.224948] systemd[1]: Started Journal Service. [ 19.250917] systemd-journald[777]: Received client request to flush runtime journal. [ 21.184596] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 21.184604] Bluetooth: BNEP filters: protocol multicast [ 21.184619] Bluetooth: BNEP socket layer initialized [ 26.828968] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 26.828976] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 26.828980] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 26.828983] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 26.828985] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: No Data [ 26.828988] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 26.828990] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 26.828993] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 26.828996] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 26.828999] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 26.829001] meson-dw-hdmi ff600000.hdmi-tx: video code: 0 [ 26.829004] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 26.829007] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 26.829009] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 26.829012] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 26.829028] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 26.829030] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 26.829033] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 26.829036] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) [ 28.460628] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) [ 28.460637] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 [ 28.460644] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-4-playback event failed: -22 [ 28.485599] hdmi-audio-codec hdmi-audio-codec.1.auto: Not able to map channels to speakers (-22) [ 28.485608] hdmi-audio-codec hdmi-audio-codec.1.auto: ASoC: can't set i2s-hifi hw params: -22 [ 28.485615] axg-sound-card sound: ASoC: PRE_PMU: be.dai-link-4-playback event failed: -22 [ 28.977590] Bluetooth: RFCOMM TTY layer initialized [ 28.977617] Bluetooth: RFCOMM socket layer initialized [ 28.977652] Bluetooth: RFCOMM ver 1.11 [ 29.177550] overlayfs: "xino" feature enabled using 2 upper inode bits. [ 29.283822] overlayfs: "xino" feature enabled using 2 upper inode bits. [ 29.894059] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 29.958508] fuse: init (API version 7.31) [ 31.437103] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13 [ 31.437113] meson-dw-hdmi ff600000.hdmi-tx: colorspace: YCbCr 4:4:4 [ 31.437116] meson-dw-hdmi ff600000.hdmi-tx: scan mode: Underscan [ 31.437119] meson-dw-hdmi ff600000.hdmi-tx: colorimetry: ITU709 [ 31.437121] meson-dw-hdmi ff600000.hdmi-tx: picture aspect: No Data [ 31.437124] meson-dw-hdmi ff600000.hdmi-tx: active aspect: Same as Picture [ 31.437127] meson-dw-hdmi ff600000.hdmi-tx: itc: No Data [ 31.437130] meson-dw-hdmi ff600000.hdmi-tx: extended colorimetry: xvYCC 709 [ 31.437133] meson-dw-hdmi ff600000.hdmi-tx: quantization range: Default [ 31.437136] meson-dw-hdmi ff600000.hdmi-tx: nups: Unknown Non-uniform Scaling [ 31.437139] meson-dw-hdmi ff600000.hdmi-tx: video code: 0 [ 31.437141] meson-dw-hdmi ff600000.hdmi-tx: ycc quantization range: Limited [ 31.437144] meson-dw-hdmi ff600000.hdmi-tx: hdmi content type: Graphics [ 31.437147] meson-dw-hdmi ff600000.hdmi-tx: pixel repeat: 0 [ 31.437150] meson-dw-hdmi ff600000.hdmi-tx: bar top 0, bottom 0, left 0, right 0 [ 31.437167] meson-dw-hdmi ff600000.hdmi-tx: HDMI infoframe: Source Product Description (SPD), version 1, length 25 [ 31.437170] meson-dw-hdmi ff600000.hdmi-tx: vendor: DW [ 31.437172] meson-dw-hdmi ff600000.hdmi-tx: product: HDMI [ 31.437175] meson-dw-hdmi ff600000.hdmi-tx: source device information: PC General (0x9) I'm on 5.7.0-rc4 kernel Focal Desktop and you on older one, @Albert Barcelona try change that (boot from usb latest @balbes150 images). On my TV and PC monitor now sound work. Or hdmi on your and my box connected to different SoC legs... My aplay -l output is same. Ok, thanks!. Will try now.. I'll post results in the other thread. I believe it is better to keep the discussion in the H96 Max X3 thread. Link to comment Share on other sites More sharing options...
hippo5329 Posted May 14, 2020 Share Posted May 14, 2020 The TX3 S905X3 failed to poweroff/reboot with 20200510 and 20200514. The 20200502 does not have such issue. {OK] Reached target Power-Off. [ ...] systemd-shutdown[1]Syncing filesystems and block devices. ... [...] Powering off. And stop here without real poweroff or reboot. 1 Link to comment Share on other sites More sharing options...
root-stas Posted May 15, 2020 Share Posted May 15, 2020 (edited) 15 hours ago, hippo5329 said: The TX3 S905X3 failed to poweroff/reboot with 20200510 and 20200514. The 20200502 does not have such issue. {OK] Reached target Power-Off. [ ...] systemd-shutdown[1]Syncing filesystems and block devices. ... [...] Powering off. And stop here without real poweroff or reboot. Try different DTB file. I'm clean from wrong records own DTB file and system start reboot properly. Edited May 15, 2020 by root-stas Link to comment Share on other sites More sharing options...
Teddybee Posted May 15, 2020 Share Posted May 15, 2020 I have an X99 Max Plus box. The dtb is extracted from the original android 9. The dtb's original name is sm1_ac213_4g.dtb, but it has some different content in it than the others. Unfortunately the latest ubuntu, Armbian_20.05.4_Arm-64_focal_current_5.7.0-rc5, don't want to boot with it. Could somebody help me? I will attached the dtb, if somebody needed(as soon as I figure out how to do that in this forum). Link to comment Share on other sites More sharing options...
root-stas Posted May 16, 2020 Share Posted May 16, 2020 (edited) 11 hours ago, Teddybee said: I have an X99 Max Plus box. The dtb is extracted from the original android 9. The dtb's original name is sm1_ac213_4g.dtb, but it has some different content in it than the others. Unfortunately the latest ubuntu, Armbian_20.05.4_Arm-64_focal_current_5.7.0-rc5, don't want to boot with it. Could somebody help me? I will attached the dtb, if somebody needed(as soon as I figure out how to do that in this forum). Use khadas-vim3l or sei610 dtb files as starting point, check wat is don't working on them and google here how to fix that in dtb file. X88 Pro X3 / X99 Max Plus / Transpeed X3 Plus TV Box has same board, try find solution for them and use yourself. In your box WiFi/BT is SP6255 - clone of AP6255. Try that driver BCM43455C0 for wifi. Edited May 16, 2020 by root-stas Link to comment Share on other sites More sharing options...
