kristofejro Posted March 17, 2020 Share Posted March 17, 2020 I would like to ask you for help with quotaon.service. I am struggling with it on my nanopi neo2 with armbian. ● quotaon.service - Enable File System Quotas Loaded: loaded (/lib/systemd/system/quotaon.service; static; vendor preset: enabled) Active: failed (Result: exit-code) since Tue 2020-03-17 20:00:48 CET; 59min ago Docs: man:quotaon(8) Process: 425 ExecStart=/sbin/quotaon -aug (code=exited, status=4) Main PID: 425 (code=exited, status=4) Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: Quota format not supported in kernel. Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: using /srv/dev-disk-by-label-HGST7K10001TB/aquota.user on /dev/sda1 [/srv/dev-disk-by-label-HGST7K1 Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: Quota format not supported in kernel. Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: using /srv/dev-disk-by-label-2TBWDRED/aquota.group on /dev/sdb1 [/srv/dev-disk-by-label-2TBWDRED]: Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: Quota format not supported in kernel. Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: using /srv/dev-disk-by-label-2TBWDRED/aquota.user on /dev/sdb1 [/srv/dev-disk-by-label-2TBWDRED]: N Mar 17 20:00:48 openmediavault quotaon[425]: quotaon: Quota format not supported in kernel. Mar 17 20:00:48 openmediavault systemd[1]: quotaon.service: Main process exited, code=exited, status=4/NOPERMISSION Mar 17 20:00:48 openmediavault systemd[1]: quotaon.service: Failed with result 'exit-code'. Mar 17 20:00:48 openmediavault systemd[1]: Failed to start Enable File System Quotas. I am on: Linux openmediavault 4.19.63-sunxi64 #5.92 SMP Fri Aug 2 00:18:27 CEST 2019 aarch64 GNU/Linux Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster What can be wrong? It used to work just fine. One important thing to add - this machine is dedicated to OpenMediaVault 5.3.8-1 (Usul) Thanks for any help. Link to comment Share on other sites More sharing options...
Igor Posted March 17, 2020 Share Posted March 17, 2020 1 hour ago, kristofejro said: Linux openmediavault 4.19.63-sunxi64 Is not armbian, but was most likely build with our tools. Anyway, if you need some support in kernel - check similar post with explanation what to do: Link to comment Share on other sites More sharing options...
Werner Posted March 18, 2020 Share Posted March 18, 2020 As far as for us the only thing missing I noticed so far is quota for XFS which should not matter I guess? Normal quota support is there. As stated above, complain either where you get the image or recreate your own image with adjusted kernel config Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 I have just performed fresh install of image from https://dl.armbian.com/nanopineo2/Buster_current and installed OMV with wget -O - https://github.com/OpenMediaVault-Plugin-Developers/installScript/raw/master/install | sudo bash uname -a Linux openmediavault 5.4.20-sunxi64 #20.02.1 SMP Mon Feb 17 02:37:37 CET 2020 aarch64 GNU/Linux So I assume the kernel from you guys. "complain either where you get the image" :-) ● quotaon.service - Enable File System Quotas Loaded: loaded (/lib/systemd/system/quotaon.service; static; vendor preset: enabled) Active: failed (Result: exit-code) since Wed 2020-03-18 13:39:52 CET; 45min ago Docs: man:quotaon(8) Process: 1004 ExecStart=/sbin/quotaon -aug (code=exited, status=4) Main PID: 1004 (code=exited, status=4) Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: Quota format not supported in kernel. Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: using /srv/dev-disk-by-label-HGST7K10001TB/aquota.user on /dev/sda1 [/srv/dev-disk-by-label-HGST7K Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: Quota format not supported in kernel. Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: using /srv/dev-disk-by-label-2TBWDRED/aquota.group on /dev/sdb1 [/srv/dev-disk-by-label-2TBWDRED]: Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: Quota format not supported in kernel. Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: using /srv/dev-disk-by-label-2TBWDRED/aquota.user on /dev/sdb1 [/srv/dev-disk-by-label-2TBWDRED]: Mar 18 13:39:52 openmediavault quotaon[1004]: quotaon: Quota format not supported in kernel. Mar 18 13:39:52 openmediavault systemd[1]: quotaon.service: Main process exited, code=exited, status=4/NOPERMISSION Mar 18 13:39:52 openmediavault systemd[1]: quotaon.service: Failed with result 'exit-code'. Mar 18 13:39:52 openmediavault systemd[1]: Failed to start Enable File System Quotas. Maybe I am doing something wrong? What is wrong with that service? Please help. Link to comment Share on other sites More sharing options...
Werner Posted March 18, 2020 Share Posted March 18, 2020 Try to modprobe the modules quota_v1 and quota_v2 manually. Try to add them to autoload at boot echo quota_v1 >> /etc/modules echo quota_v2 >> /etc/modules reboot now The only thing that is missing in the kernel config is QUOTA_TREE but no idea what this is for since there is not help text available.... Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 I have added these two modules as you advised. But after the restart lsmod | grep -i quota result is empty and service in the same state. Maybe something from OMV installation is messing? But how to find what is the problem? Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 I have found something similar: https://serverfault.com/questions/843994/ubuntu-quota-format-not-supported-in-kernel but don't know how it should be in armbian. Link to comment Share on other sites More sharing options...
Igor Posted March 18, 2020 Share Posted March 18, 2020 3 hours ago, kristofejro said: complain either where you get the image Kernel is still a community work We will help with clues and ideas, but ultimately its on you to do the research and find out why you are experienced those trobles. Perhaps folks at OMV are more familiar with this problem. I would say Quota must work, but it has been decades since I last used this feature ... Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 I am reasearching all the time But I am just an amateur and you guys are pros. I have found out that on other operating systems I have these modules Ubuntu: ls -l /lib/modules/4.15.0-91-generic/kernel/fs/quota/ -rw-r--r-- 1 root root 19409 Feb 28 11:45 quota_tree.ko -rw-r--r-- 1 root root 9769 Feb 28 11:45 quota_v1.ko -rw-r--r-- 1 root root 14065 Feb 28 11:45 quota_v2.ko Raspbian: ls -l /lib/modules/4.19.97-v8+/kernel/fs/quota/ -rw-r--r-- 1 root root 22984 Feb 3 13:50 quota_tree.ko -rw-r--r-- 1 root root 11760 Feb 3 13:50 quota_v1.ko -rw-r--r-- 1 root root 16712 Feb 3 13:50 quota_v2.ko Armbian missing: ls -l /lib/modules/5.4.20-sunxi64/kernel/fs/ drwxr-xr-x 2 root root 4096 Feb 17 11:55 cachefiles drwxr-xr-x 2 root root 4096 Feb 17 11:55 ceph drwxr-xr-x 2 root root 4096 Feb 17 11:55 cifs drwxr-xr-x 2 root root 4096 Feb 17 11:55 ecryptfs drwxr-xr-x 2 root root 4096 Feb 17 11:55 fscache drwxr-xr-x 2 root root 4096 Feb 17 11:55 fuse drwxr-xr-x 2 root root 4096 Feb 17 11:55 isofs drwxr-xr-x 4 root root 4096 Feb 17 11:55 nfs drwxr-xr-x 2 root root 4096 Feb 17 11:55 nls drwxr-xr-x 2 root root 4096 Feb 17 11:55 ntfs drwxr-xr-x 2 root root 4096 Feb 17 11:55 overlayfs drwxr-xr-x 2 root root 4096 Feb 17 11:55 udf drwxr-xr-x 2 root root 4096 Feb 17 11:55 xfs I have also checked if it is in Armbian_20.02.1_Nanopineo2_buster_current_5.4.20.img But there is no such module. Should it be like taht? Link to comment Share on other sites More sharing options...
Igor Posted March 18, 2020 Share Posted March 18, 2020 Missing module is good since we have it build into the kernel. Perhaps it has to be as a module? linux-sunxi64-current.config:CONFIG_QUOTA=y 7 minutes ago, kristofejro said: But I am just an amateur and you guys are pros. That's a very common, but very wrong assumption. Nobody knows everything - we need to invest our personal time to solve troubles. Sometimes we will find them faster than you, sometimes not. Until you don't pay us, we are amateurs. Link to comment Share on other sites More sharing options...
Werner Posted March 18, 2020 Share Posted March 18, 2020 Aight, got it. The value is name CONFIG_QFMT_V2 and CONFIG_QFMT_V1 which are not set. I'll try to see if it throws errors at build and if not I push a new config which will include both modules. And no. I am an amateur just like most users here Edit: Pushed 1 Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 What should I do now? Link to comment Share on other sites More sharing options...
Werner Posted March 18, 2020 Share Posted March 18, 2020 You have quite a bunch of options: a) Wait for a new official stable build which will be in a few month b) Check back tomorrow at the download page if there is a nightly image for your board available and get it c) Use the build script from github and create your own image from scratch with the recent changes immediately. Spoiler d) Wait about half an hour and check back here and I may provide you a premade image here https://laet.pw/index.php/s/M2eXJKll5sdnlBN/download?path=%2FMär18&files=Armbian_20.05.0-trunk_Nanopineo2_buster_current_5.4.25.img.gz Link to comment Share on other sites More sharing options...
kristofejro Posted March 18, 2020 Author Share Posted March 18, 2020 Really appreciate youe effort Werner. Does it mean I have to reflash everything from scratch? Would it be possible to introduce your changes without reflashing? Sorry for so many questions. Link to comment Share on other sites More sharing options...
Igor Posted March 18, 2020 Share Posted March 18, 2020 9 minutes ago, kristofejro said: Does it mean I have to reflash everything from scratch? Explained here which is why I will not repeat myself: Link to comment Share on other sites More sharing options...
kristofejro Posted March 19, 2020 Author Share Posted March 19, 2020 Thanks guys for your help. Link to comment Share on other sites More sharing options...
