4 hours ago, haajee said:
Is it possible to add the bluetooth and sound fix to the armbian kernel/firmware? After every kernel update  sound and bluetooth stops working and it´s clear this fix works. :) Should be really nice!
It is fixed for some time already. It's just that there were no releases built for the board in the meantime.
It is however part of v20.05.1 - after you upgrade you should not see it disappearing again.
I has upgraded and even with a clean image Focal Desktop from here doesn´t Bluetooth works... Bleutoothctl list doesn´t show the bluetooth module also. hciconfig shows the adapter but with status down. When i try to start with hciconfig hci0 up i got the error messge: Can't init device hci0: Operation not supported (95).
Did you change the mac address of the interface by using `btmgmt` according to this message?
Without it the device is using default mac address from firmware and thus is set to `DOWN RAW` status.
Hmm this week i thought i has restored the driver HCD file with the other mac adress. Restored again and it´s ok, But better: i have bluetooth now working i wanted. I stream from my orangepi music to a bluetooth device and it works like a charm. I have used this 2 site for reference:
https://wiki.archlinux.org/index.php/Bluetooth_headset
http://mygeeks014.blogspot.com/2017/05/audio-streaming-to-bluetooth-speaker.html
Very very nice! Thank you all.
Oh and btw i got contineusly the error
bluetoothd[808]: a2dp-sink profile connect failed for F2:BF:67:4E:E2:A6: Protocol not available
The solution therefore is to run manually bluetooth-modules-discover.
pactl load-module module-bluetooth-discover
On 7/16/2020 at 8:20 PM, Alex_ro said:
hi!
i am install this patch,
mic not work.
on image  'OrangePi_4_ubuntu_bionic_desktop_linux4.4.179_v1.3.img' mic work
oh,this patch was out of date,and it is use of mainline.you can use the armbian's image latest
Hi everyone, My orangepi4 3.5mm jack isn't sound suddenly. I think isn't driver problem, because I flashed orange pi official image(include Linux and Android). I guess the sound ic rt5651 was broke (I send my board to orange pi, but was told me the repair cost up to 50% the product price and excluded ic rt5651 cost, finally I give up). so, I have reservations about my rt5651 sound patch and I hope armbian think whether remove that patch.@piter75
  • Igor unpinned this topic
