17 minutes ago, balbes150 said:
Update TEST images  kernel 4.13.0-next_20170905. In these images there is USB support for S912.
Awesome! Will try this tonight already!
Another question: every time i upgrade, i loose the full setup i have on my SD card? Now that i've installed Docker, LXC etc i'd like to avoid it.
To enable USB you can only replace dtb file.
1 hour ago, Shimon said:
Nah, why waste so much space? The most efficient way to do it looks like that:
$ zcat Whatever_image_img.gz | sudo dd of=/dev/sdX bs=4M && sync
For xz compressed images use xzcat obviously.
What space, cp is simpler command than dd. This is more more efficient than yours:
xzcat Debian_testing_4.13.0_xfce.img.xz > /dev/sdX
On 05/09/2017 at 9:47 PM, fossxplorer said:
I can't get your updated image @balbes150 since Yandex Disk  seems to have issues
I can acces this: https://yadi.sk/d/kZHc0uQE34z5jR
Reboot your modem/router. I hope you have a reliable internet connection too,  you can test with Linux distributions that offer  checksum files.
1 hour ago, balbes150 said:
You mean kernel 4.13...There is no 3.14 kernel for today in your yandex folder.  Jerome brunet audio patches for S912 does have only spdif support.  Have someone tested spdif audio patches?
Thank you for your attention. Yes, I mean 4.13.0.
In images enabled sound via HDMI to s912 (and s905x). Work sound tested on a Tronsmart Vega S96 (s912). Sound works through HDMI on test files from the image. Once again - you need to have 1920x1080 resolution (you can go into desktop settings in the tools menu and select directly in the working system needs a permit).
Need a new kernel + dtb. You installed a new kernel and dtb ? After installation you need to copy the new version to "dtb.img".
I added patches to 4.13-rc1 kernel where was usb and spdif patches already. Added missing clocks and hdmi audio patches. Copied new a dtb.img file of course.  0005-clk-meson-gxbb-aoclk-Add-CEC-32k-clock.patch was missing, implementing now...
For proper operation of the patches, they should be used (in exact order as listed in source directory) and apply the kernel sources. See all options in my last git Armbian Assembly. By the way, You can get your own version of Armbian images (to edit the list of packages, change settings, etc.).
I tested yours Debian Xfce image, aplay -l list only spdif device and pulseaudio control shows only analog output.  Install wicd and xfce4-terminal instead networkmanager and xterminal. Use the xfce whisker menu. Your distro image is about 1.5 GB bigger than mine, so strip some packages. Your 86 patches are confusing, it is easier to copy whole source files from authors.  Using 200q dtb.
Is anyone running Docker aarch64/arm64v8 images on this? I'm able to run armhf/arm32v7 images, but all the arm64v8 images crash.
According to 'uname' it's 64-bits kernel so i wonder what the issue is with the Docker.
Why ?
If You are not satisfied with something in my images, gather your option. All source code freely available.
I do not give You to use other patches ?
On 7/19/2017 at 1:46 AM, gnthibault said:
ycomp: when your are logged as root, just run the install script in /home/root as suggested by debianxfce.
My question is related to vnc, I always get grey window when connecting to the tightvnc server. I use the latest 3.14 Ubuntu Mate (16.04) desktop image, but I am not connecting my box to a display. Can someone give me an example of xstartup file that works ? What bothers me for the moment is that log does not show error, bu still nothing but a grey screen ...
Edit, here is the solution (yaaayyy!):
Setup password with
vncpasswd /etc/vnc/vncpasswd
Then add the following lines to /etc/lightdm/lightdm.conf :
[VNCServer]
enabled=true
command=/usr/bin/Xvnc -rfbauth /etc/vnc/vncpasswd
port=5900
width=1280
height=1024
depth=24
I'm also testing tightvncserver and there are issues with LXDE. Mate-session works, but it can't automatically resize screen size. Also, when i used the box as a vncviewer, the resizing doesn't work, i get a black area at bottom for instance when i choose full screen.
I'd like to use one of the boxes as a vnc/spice client and another as a server :)
What kernel is used ?
On 4/5/2017 at 11:50 AM, kingul said:
@gnthibault I have 2GB of ram with 32GB rom. (Yoka TV KB2)
First time I tried with nand-sata-install, but it was a bad move, because bootloader was rewritten, I had to restore official image of my device.
After a little search I found /root/install.sh script and it worked perfectly.
I'm interested in an update (as I might want to purchase a Yoka KB2 with 3GB DDR4 RAM):
Did you solve the static IP problem completely, or do you need to use a dynamic IP still ?
How do the latest images work with the Yoka KB2 ?
On 9/4/2017 at 10:38 AM, fossxplorer said:
EDIT: have to admit i feel like a kid now after getting this to work!:beer: Love the 3G RAM on this box+ 1GbE.
It's using 6-7W when i run stress-ng --cpu 8 --io 2 --vm 1 --vm-bytes 1G --timeout 300s. Really nice!
Quite nice indeed - and a very low power usage. :)
-How fast do the cores run ... 8 x 1 GHz or 4 x 2 GHz + 4 x 1 GHz ?
Yep :) When all cores enabled, it's 4 x 1.512Ghz + 4 x 1Ggz according to lshw -c cpu.
root@amlogic:~# cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
100000 250000 500000 667000 1000000 1200000 1512000
root@amlogic:~#
I've only seen big cores at 1512Mhz even when i disable the small 4 cores. How can we get 2Ghz?
This information is indeed very useful! :)
4 x 1.5 + 4 x 1.0 (10) ... against 4 x 2 GHz (8) .
Remembering there's a small loss of speed due to things that requires single-threading/tasking ... That's close to 4x2 against 8 x 1; but if compiling/building software, the speed gain will probably be more noticable.
-But I do believe that there *is* a performance gain; or perhaps a 'responsiveness gain'.
(Eg. the PC I'm using at the moment sometimes stalls while moving the windows, typing or when moving the mouse. After several seconds (up to a minute), the window wil move or the mouse arrow will move).
Having multiple cores can in those cases make the computer/device more responsive.
root@amlogic:~#
That I don't know, but I remember reading a while back, that it was only possible to run at 4x2 GHz or 8 x 1 GHz.
This means that someone must have done something to improve it. ;)
I've been battling with myself about whether I should purchase a bunch of MiQi devices for a build-farm or a bunch of Yoka-boxes (I will be purchasing a MacchiatoBIN as build-master either way).
Why do you trust even in these 1512MHz? Care to remember what Willy Tarreau discovered when trying to use Amlogic SoCs for his build farms: http://wiki.ant-computing.com/Choosing_a_processor_for_a_build_farm#Very_interesting_discoveries_about_cheating_vendors_-_2016.2F07.2F09
Your consumption numbers also look suspicious but the tool you used is pretty lightweight. When I tested with a NanoPi M3 last year (octa-core A53 with up to 1.4 GHz) I would've to search for another PSU to power the board when allowing the 1400 MHz since consumption was too high for my 5V/2.5A 5V/2A PSU (IIRC with cpuburn-a53 1300 MHz was the maximum).
You could try this NEON optimized Linpack here: https://github.com/ehoutsma/StabilityTester to get a clue. Maybe stabilitytester.sh already runs out of the box (trying to walk through available cpufreq/dvfs OPP) but at least you can check for dependencies and how to call xhpl64. Testing individually by sending CPU cores 0-3 or 4-7 offline is an option too :)
Edit: NanoPi M3 tests back then (it was even worse and with the Linpack not even running at 1GHz on all 8 cores was possible): https://forum.armbian.com/index.php?/topic/1285-nanopi-m3-cheap-8-core-35/&do=findComment&comment=14697
@Jens Bauer
Sure, i'd have loved to put a bigger heatsink and a small fan, if that helps to achieve higher speeds.
But now as @tkaiser mentions it, i can recall the Amlogic cheating revelations i read at CNX-soft thoug!
Here is what i got from StabilityTester:
Done testing stability by using both ondemand and performance scaling governors:
Frequency: 667000    Voltage: 3300000    Success: 1    Result:        0.0048034
Frequency: 1000000    Voltage: 3300000    Success: 1    Result:        0.0048034
Frequency: 1200000    Voltage: 3300000    Success: 1    Result:        0.0048034
Although the thermal readings doesn't work on this box:
Testing frequency 1200000
Soc temp:cat: /sys/class/thermal/thermal_zone0/temp: No such file or directory
Soc temp:      CPU Freq: 1200000     CPU Core: 3300000     cat: /sys/class/thermal/thermal_zone0/temp: No such file or directory
Anyway, i guess i'm also subject to their cheating since i can get max 1.2Ghz even with all small cores disabled. :angry:
After a reboot of the box:
root@amlogic:~# for i in {0..7};do cat /sys/devices/system/cpu/cpu$i/cpufreq/scaling_governor;done
cat: /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor: No such file or directory
cat: /sys/devices/system/cpu/cpu7/cpufreq/scaling_governor: No such file or directory
I can't see cpufreq module to load, hmm.
EDIT:
root@amlogic:~# ll  /lib/modules/4.13.0-rc7-next-20170901-amlogics905x/kernel/drivers/cpufreq/cppc_cpufreq.ko
-rw-r--r-- 1 root root 7840 Sep  1 17:26 /lib/modules/4.13.0-rc7-next-20170901-amlogics905x/kernel/drivers/cpufreq/cppc_cpufreq.ko
root@amlogic:~# modprobe cppc_cpufreq
modprobe: ERROR: could not insert 'cppc_cpufreq': No such device
EDIT2:
Seems some of the files are messed up by apt-get update or install of other files;
root@amlogic:~# ll -th /boot/
total 47M
-rwxr-xr-x  1 root root 5.0M Sep 12 21:33 initrd.img-4.13.0-rc7-next-20170901-amlogics905x*
-rwxr-xr-x  1 root root 5.0M Sep 12 21:33 uInitrd*
-rwxr-xr-x  1 root root  25K Sep  7 10:10 dtb.img*
drwxr-xr-x 23 root root 4.0K Sep  6 13:06 ../
-rwxr-xr-x  1 root root 1.6K Sep  1 17:30 armbian_first_run.txt*
-rwxr-xr-x  1 root root  718 Sep  1 17:30 aml_autoscript*
-rwxr-xr-x  1 root root  651 Sep  1 17:30 aml_autoscript.zip*
-rwxr-xr-x  1 root root 1.6K Sep  1 17:30 s905_autoscript*
-rwxr-xr-x  1 root root 1.5K Sep  1 17:30 s905_autoscript.cmd*
-rwxr-xr-x  1 root root  38K Sep  1 17:30 boot.bmp*
-rwxr-xr-x  1 root root 4.8K Sep  1 17:30 boot-desktop.png*
-rwxr-xr-x  1 root root 1.1K Sep  1 17:30 hdmi.sh*
drwxr-xr-x  2 root root 4.0K Sep  1 17:29 dtb/
drwxr-xr-x  2 root root 4.0K Sep  1 17:29 dtb-4.13.0-rc7-next-20170901-amlogics905x/
-rwxr-xr-x  1 root root  23K Sep  1 17:26 old_dtb.img*
-rwxr-xr-x  1 root root 143K Sep  1 17:26 config-4.13.0-rc7-next-20170901-amlogics905x*
-rwxr-xr-x  1 root root 3.5M Sep  1 17:26 System.map-4.13.0-rc7-next-20170901-amlogics905x*
-rwxr-xr-x  1 root root  17M Sep  1 17:26 vmlinuz-4.13.0-rc7-next-20170901-amlogics905x*
-rwxr-xr-x  1 root root  17M Sep  1 17:26 zImage*
drwxr-xr-x  4 root root  16K Jan  1  1970 ./
EDIT3: i replaced the whole /boot with latest release + copied back dtb.img. Problem solved. I think one of the package dependency messed up with uInitrd and initrd.img-4.13.0-rc7-next-20170901-amlogics905x.
That is so annoying.
-But please make sure that it actually is the CPU that needs to be blamed and not the RAM-speed.
I'd like to see a comparison of a TV-box having DDR4 RAM installed against one that has DDR3 RAM installed - I wonder if it makes any difference at all.
(Since this is a S912 thread I've restricted myself from comparing to other CPU vendors, but it seems that Amlogic is not the most interesting vendor anymore).
Well, I'm surprised why people expect $anything from TV boxes. These things aren't for Linux enthusiasts but for clueless people that only buy numbers (8 CPU cores vs. 4 cores --> 8! 2 GB DRAM vs. 3 GB DRAM --> 3! $30 vs. $28 --> 28!). They have to look performant by specs while they have to be as cheap as possible for their target audience to buy them. Why does someone think both can work at the same time?
This means manufacturers don't have to take care about performance but only about cluelessness (use 8 cores even if it's totally useless since the competitors also use 8 cores now so you are not able to sell faster boxes with less CPU cores anymore in the markets where they make money, put recycled DRAM on the PCB and combine it with an u-boot that dynamically tunes DRAM clockspeed down until the box doesn't immediately crash so you as manufaturer can afford putting 3 GB crappy/slow DRAM on board since customers would never buy your box with 2 GB faster DRAM)
And then this kind of 'cheating' also happens everywhere. Don't know exactly how it works with Amlogic (since I consider all their SoCs not worth a look, might change if a dev board relying on Amlogic A113D appears) but I know how it's done with Allwinner and there it's easy: the 'board support packages' (BSP) TV box vendors get contains a kernel with a list of cpufreq operation points (that's the entire 'up to x.x GHz' thing) that does not need to have any relationship with reality (Allwinner sets 1536 MHz here for A64 as an example). Then there are other settings defining how voltage and clockspeed relates (DVFS) and then there's another settings defining thermal behaviour. The result is that the TV box will be marketed as 'up to 1.5GHz', the real settings already prevent everything above 1152 MHz and due to shitty thermal design of most boxes the SoC won't even see those 1.1GHz when running under constant load since already throttled down to less than 1 GHz. And their target audience is happy since in Android's CPU-Z and stupid benchmarks like Geekbench '4 cores @ 1536 MHz' is listed and that's all they care about,
IMO interesting read: https://www.cnx-software.com/2017/09/12/factory-price-of-some-tv-boxes-and-accessories/#comments
