I am changing the file/folder permission using chown  but is it not permanent
chown proxy:proxy a.log
 ls -l
total 0
-rw-r--r-- 1 proxy proxy 0 Apr 10 07:30 a.log
Now after some time that include reboot
 ls -l
total 0
-rw-r--r-- 1 root root 0 Apr 10 07:30 a.log
I am using armbian on orange pi zero plus
uname -r
5.4.14-sunxi64
Hi Ramon,
This is actually a different problem, in that /sys (sysfs) is a virtual filesystem and not actually something on the SD card. In that sense, there's nothing to save boot-to-boot.
It's also a deprecated interface, so you may just want to look into the newer interface.
If you do want to use the GPIO that way, you can do one of a few things:
  • Make a script that configures your GPIO on every boot (such as rc.local)
  • Write a udev rule that sets ownership of gpio files in sysfs
  • Just run your application with setuid root privileges
As a kick in the right direction, I have this in "/etc/udev/rules.d/50-gpio.rules".
KERNEL=="gpio*", GROUP="users"
Then need to trigger udev, or reboot. Afterwards ...
tparys@hobbes:~$ ls -l /dev/gpiochip*
crw-rw---- 1 root users 254, 0 Mar 20 20:58 /dev/gpiochip0
crw-rw---- 1 root users 254, 1 Mar 20 20:58 /dev/gpiochip1
crw-rw---- 1 root users 254, 2 Mar 20 20:58 /dev/gpiochip2
crw-rw---- 1 root users 254, 3 Mar 20 20:58 /dev/gpiochip3
crw-rw---- 1 root users 254, 4 Mar 20 20:58 /dev/gpiochip4
Then make sure gpiod is installed (sudo apt-get install gpiod). Then do something like this, or read man pages for gpioget / gpioset.
# Reading GPIO chip 1, line 3
gpioget 1 3
# Setting that GPIO to 1 (high
gpioset 1 3=1
