wollik Posted May 11, 2020 Posted May 11, 2020 Hi forum members, when I try to install the kernel headers via: "sudo apt-get install kernel-headers-$(uname -r)" I gote these errors: Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package kernel-headers-4.19.62-sunxi E: Couldn't find any package by glob 'kernel-headers-4.19.62-sunxi' E: Couldn't find any package by regex 'kernel-headers-4.19.62-sunxi' In the /etc/apt/sources.list the lines with the deb-src links are comments. I've tried to uncomment these but got the same errors. So please can somwone point me right kernel-headers Armbian is using ? Many Thanks wollik
Igor Posted May 11, 2020 Posted May 11, 2020 16 minutes ago, wollik said: So please can somwone point me right kernel-headers Armbian is using ? We fix kernel headers only lately, since they were mainly broken before. With latest kernel, they are present. Install them via armbian-config to make sure.
wollik Posted May 11, 2020 Author Posted May 11, 2020 Hi Igor, thanks for this hint! But i still need the build directory and I have no idea how to get it created and filled with the tools to get the compilation done. compile with KDIR=/lib/modules/4.19.62-sunxi/build/, at /home/pi/tools/CAN/can4linux_svn273/can4linux CC = cc make -C /lib/modules/4.19.62-sunxi/build/ C=0 M=/home/pi/tools/CAN/can4linux_svn273/can4linux TARGET=BANANAPI modules make[1]: *** /lib/modules/4.19.62-sunxi/build/: No such file or directory. Stop. Makefile:664: recipe for target 'all' failed make: *** [all] Error 2 Please can you help again ? Many Thanks wollik
ning Posted June 27, 2020 Posted June 27, 2020 kernel-headers-$(uname -r) is not kernel header package name provided by armbian. the real name is linux-headers-next-sunxi_5.31 linux-headers-{branch}-{family}_{armbian version} is the syntax. it is in /etc/armbian-release , it is updated with board package, but I don't know whether kernel header package is update with board package? need @Igor to answer.
wollik Posted June 27, 2020 Author Posted June 27, 2020 Thanks to all, I ve updated to the latest image and installed the kernel headers via armbian-config. Regards WolliK 1
Igor Posted June 27, 2020 Posted June 27, 2020 1 hour ago, ning said: but I don't know whether kernel header package is update with board package? If installed, yes, otherwise not. This is the correct way: apt install linux-headers-${BRANCH}-${FAMILY}
bthoven Posted March 25, 2022 Posted March 25, 2022 I'm trying to compile a wifi driver for RTL8898ES chip on my S905x box which is running Armbian 20.10.1 Focal with Linux 5.9.0-arm-64. I can't get the kernel-headers installed either within the armbian-config menu or all the above apt install commands. It reported it can't find the kernel header files. sudo apt install linux-headers-${BRANCH}-${FAMILY} [sudo] password for bthoven: Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package linux-headers- bthoven@bthoven-X96:~$ sudo apt-get install kernel-headers-$(uname -r) Reading package lists... Done Building dependency tree Reading state information... Done E: Unable to locate package kernel-headers-5.9.0-arm-64 E: Couldn't find any package by glob 'kernel-headers-5.9.0-arm-64' E: Couldn't find any package by regex 'kernel-headers-5.9.0-arm-64' Anyone has succeeded doing it lately? Thanks
Igor Posted March 25, 2022 Posted March 25, 2022 source /etc/armbian-release apt install linux-headers-${BRANCH}-${LINUXFAMILY} Otherwise https://docs.armbian.com/User-Guide_Armbian-Config/ 43 minutes ago, bthoven said: Armbian 20.10.1 Focal with Linux 5.9.0-arm-64. Which will most likely fail since this is not official Armbian build.
Werner Posted March 25, 2022 Posted March 25, 2022 4 hours ago, bthoven said: box tvboxes are unsupported in general. Ask the person who gave you this image. https://docs.armbian.com/User-Guide_FAQ/#why-does-armbian-not-support-tv-boxes-the-market-is-huge
