Hello all,
I have this board and It's suffering crashes and reboots all day. I think  the logs are stored in RAM because I can't never find anything related to this issue. Is there anything I can do to find the cause?
Many thanks.
Regards.
Frist things first: armbianmonitor -u
Expand
That is correct. From the documentation:
/var/log is mounted as compressed device (zram, lzo), log2ram service saves logs to disk daily and on shutdown
Expand
This has two reasons: First it increases the lifetime of your sd card significantly because it avoids tons of small writes to it and 2nd writeing to zram is way faster than writing to sd card.
  "python3" (3688) uses deprecated CP15 Barrier instruction at 0xf6f30694
Expand
Just found via google. You can disable this "spam" with echo 2 >/proc/sys/abi/cp15_barrier
About your actual issue, sorry no idea :(
Expand
Yes, I found it as well, in fact I've to add this every time it reboots.
Sorry, I don't use the 4.4 kernel, I don't know what bugs are in it now. I don't have any problems on the 5.7 core (the system is on eMMC and NVMe).
And what about the fan control? Because I've downgraded to 4.4 because of that.
Expand
Everything works fine. The fan is controlled automatically. I use T4 to build images of LE and ArmbianTV (this is the maximum load on the entire system) and the fan works correctly (when  need to turn on the minimum speed, and when continue to increase the load goes to the maximum speed of rotation).
Yesterday I reinstalled on kernel 5.4.32 and it's working fine, just 24h without any reboot. The fan works fine and the temperature is stable around 50 degrees. Fingers cross!
