Hi all,
I use a cubieboard3 as a web server. For several months, joomla tells me that I am PHP 7.0.33-0 + deb9u7et that I need to update my version of php to 7.3 or later. In the updates of the bone, I never see these updates of PHP, must it be done manually and how? I am in Debian Stretch with Armbian Linux 4.19.62-sunxi.
Thank you
François
4.19.62-sunxi
Expand
Armbian marked Stretch as EOS. The current supported release is Buster.
4.19.62-sunxi
Expand
Outdated as well. You probably missed the versioning change last year.
php to 7.3
Expand
You either should ask at Debian forums/search if there are backports for Stretch or update to Debian Buster.
Expand
@Club AC-News
I checked on my old FOX G20 with Kernel 4.9.124 and debian-stretch and in the normal debian-repositories there is only PHP v7.0
But it seem that you are not the only one who needs >= v7.3 on stretch :)
And YES you have to add something manually:
before you can install a new php-version:
sudo apt-get update
sudo apt-get upgrade
sudo apt install ca-certificates apt-transport-https
wget -q https://packages.sury.org/php/apt.gpg -O- | sudo apt-key add -
echo "deb https://packages.sury.org/php/ stretch main" | sudo tee /etc/apt/sources.list.d/php.list
after that
for PHP v7.3:
sudo apt install php7.3
sudo apt install php7.3-cli php7.3-common php7.3-curl php7.3-mbstring php7.3-mysql php7.3-xml
or
for PHP v7.4:
sudo apt install php7.4
sudo apt install php7.4-cli php7.4-common php7.4-curl php7.4-mbstring php7.4-mysql php7.4-xml
for additonal informations (like configuring Apache/Nginx-Webserver to run PHP) check the following URLs:
https://tecnstuff.net/how-to-install-php-on-debian-9/
https://tecadmin.net/install-php-debian-9-stretch/
