wvthoog Posted August 5, 2020 Posted August 5, 2020 The last time I've used this board was around December 2019. Building images or downloaded from Armbian.com and burning them on a SD card worked fine. Now i'm struggling to get it to boot from SD. Tried these images: https://redirect.armbian.com/orangepizeroplus2-h5/Buster_current https://redirect.armbian.com/orangepizeroplus2-h5/Focal_current Also build my own image (to include some extra modules) Armbian_20.08.0-trunk_Orangepizeroplus2-h5_bionic_current_5.7.12 All of them won't get passed "Starting kernel" Serial log: U-Boot SPL 2020.04-armbian (Aug 05 2020 - 07:58:29 +0200) DRAM: 512 MiB Trying to boot from MMC1 NOTICE: BL31: v2.3(debug):8dd1c3c-dirty NOTICE: BL31: Built : 07:58:26, Aug 5 2020 NOTICE: BL31: Detected Allwinner H5 SoC (1718) NOTICE: BL31: Found U-Boot DTB at 0x40908e8, model: OrangePi Zero Plus2 INFO: ARM GICv2 driver initialized INFO: Configuring SPC Controller NOTICE: PMIC: Assuming H5 reference regulator design INFO: BL31: Platform setup done INFO: BL31: Initializing runtime services INFO: BL31: cortex_a53: CPU workaround for 855873 was applied NOTICE: PSCI: System suspend is unavailable INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x4a000000 INFO: SPSR = 0x3c9 U-Boot 2020.04-armbian (Aug 05 2020 - 07:58:29 +0200) Allwinner Technology CPU: Allwinner H5 (SUN50I) Model: OrangePi Zero Plus2 DRAM: 512 MiB MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... Unable to use mmc 1:1... In: serial Out: serial Err: serial Net: No ethernet found. ** Reading file would overwrite reserved memory ** starting USB... No working controllers found Autoboot in 1 seconds, press <Space> to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3173 bytes read in 2 ms (1.5 MiB/s) ## Executing script at 4fc00000 U-boot loaded from SD Boot script loaded from mmc 201 bytes read in 2 ms (97.7 KiB/s) 31003 bytes read in 6 ms (4.9 MiB/s) 504 bytes read in 4 ms (123 KiB/s) Applying kernel provided DT overlay sun50i-h5-usbhost2.dtbo 504 bytes read in 5 ms (97.7 KiB/s) Applying kernel provided DT overlay sun50i-h5-usbhost3.dtbo 4191 bytes read in 5 ms (818.4 KiB/s) Applying kernel provided DT fixup script (sun50i-h5-fixup.scr) ## Executing script at 45000000 11032058 bytes read in 528 ms (19.9 MiB/s) 18784264 bytes read in 897 ms (20 MiB/s) ## Loading init Ramdisk from Legacy Image at 4fe00000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 11031994 Bytes = 10.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 4fa00000 Booting using the fdt blob at 0x4fa00000 Loading Ramdisk to 4957a000, end 49fff5ba ... OK Loading Device Tree to 000000004950a000, end 0000000049579fff ... OK Starting kernel ... Double checked that the SD card reader switch was not broken according to this link Switch is working fine. Am at a loss here. Can someone shed some light on howto resolve this. From the serial log it seems it wants to boot from emmc Power supply: 5v 3A Complete log with Verbosity set to 10 located at https://pastebin.com/Cq8BaKLK
martinayotte Posted August 5, 2020 Posted August 5, 2020 1 hour ago, wvthoog said: All of them won't get passed "Starting kernel" You should change "verbosity" to "7" in /boot/armbianEnv.txt to be able to see more details after "Starting kernel". EDIT: Sorry, I didn't saw your complete log URL ...
wvthoog Posted August 6, 2020 Author Posted August 6, 2020 So it seems it does boot from SD, but hangs somewhere during kernel loading. Could the Orange Pi be broken ?
Werner Posted August 6, 2020 Posted August 6, 2020 9 minutes ago, wvthoog said: So it seems it does boot from SD, but hangs somewhere during kernel loading. Could the Orange Pi be broken ? If you have switched the sd card as well as the power source and cable and somebody else with the same board can boot the same image flawless....then well the board might be broken.
wvthoog Posted August 6, 2020 Author Posted August 6, 2020 Would be my guess as well. But now something strange happened. Loaded an image for a Orange Pi Zero Plus (not Plus2 H5) and it booted. To be clear my board is definitely a Orange Pi Zero Plus2 H5 See log here: https://pastebin.com/SR3hywPM
Jelmer Posted November 11, 2021 Posted November 11, 2021 <removed> looks like my issue is not related because I don't see any starting kernel message.
