Werner Posted September 7, 2020 Posted September 7, 2020 At the moment there are three different saved actions that kind of cover the same thing: Complain about missing data I suggest to merge those to one standardized reply that covers missing data and armbianmonitor -u as well as tips. Something like this (with a bit of additional formatting): Quote Your support topic is lacking of important debugging information. Please edit and fix! Please describe your setup as best as possible so we know what your operating environment is like. Name of your board with all details, version number, take a picture if you are not sure what you have Name of the image you installed or logs if you can boot the board: armbianmonitor -u (paste URL to your forum post) If your board does not boot, provide a log from serial console (UART) or at least make and attach a picture, where it stops. Describe the problem the best you can and provide all necessary info that we can reproduce the problem. If anything is attached to the board, supply all details Tips: use spoiler when adding a long text, use when adding a code, be concise. Will unhide and add this reply. 1
Werner Posted September 12, 2020 Author Posted September 12, 2020 Since nobody else has an opinion here I assume my suggestion is fine. I'll leave it open for a while and merge the changes probably in about 48h.
Igor Posted September 12, 2020 Posted September 12, 2020 1 hour ago, Werner said: I assume my suggestion is fine Yes, I didn't notice it Also check if we have an extra field for (title -> prefix -> armbianmonitor) when adding a new post. That might help a bit.
Werner Posted September 12, 2020 Author Posted September 12, 2020 10 hours ago, Igor said: an extra field for (title -> prefix -> armbianmonitor) There is:
Igor Posted September 12, 2020 Posted September 12, 2020 7 minutes ago, Werner said: There is: Missing somewhere?
Werner Posted September 12, 2020 Author Posted September 12, 2020 9 minutes ago, Igor said: Missing somewhere? Yeah, RK3399. This one is missing the "new topic rules" as well.
Igor Posted September 12, 2020 Posted September 12, 2020 24 minutes ago, Werner said: This one is missing the "new topic rules" as well. Fixed. 1
Tido Posted September 14, 2020 Posted September 14, 2020 On 9/7/2020 at 7:57 PM, Werner said: Something like this ( the link to the explaining forum post of armbianmonitor -u was quite valuable, I think // sent from mobile phone //
Solution Werner Posted September 14, 2020 Author Solution Posted September 14, 2020 It is. I'll fix that. Edit: fixed 1
