Am 27.10.2020 um 07:45 schrieb flower:
Yes, all docker container and system together is around 1gb ram usage.
It uses zram after a while but that seems unrelated to that sync error.
I never saw my ram completely filled.
I dont use armbian nextcloud. I tweaked the mysql, redis, alpine variant which now runs stable on my old pc. Emby takes much ram there, but that container wasnt enabled on helios64.
how did you display this ingenious output?
I currently have a consumption of 88-90% on my Helios64 and suspect that a container is at fault.
edit:
ok with docker stats I got a similar output, but yours is even more "neat".
CONTAINER ID        NAME                CPU %               MEM USAGE / LIMIT     MEM %               NET I/O             BLOCK I/O           PIDS
7b42ac796d6f        pihole              0.13%               18.92MiB / 3.711GiB   0.50%               0B / 0B             2.87GB / 621MB      21
3d3d14ccf50d        unifi-controller    3.85%               938.7MiB / 3.711GiB   24.70%              0B / 0B             6.22GB / 8.44GB     124
711e02b8f517        iobroker            15.94%              977.9MiB / 3.711GiB   25.73%              0B / 0B             4.79GB / 59.5GB     144
ae4aba42dce4        embyserver          2.94%               928MiB / 3.711GiB     24.42%              0B / 0B             13.2GB / 423MB      39
0150a9f8edfb        portainer-ce        0.66%               14.87MiB / 3.711GiB   0.39%               5.95MB / 9.88MB     741MB / 136MB       15
apt install glances
it also has a web interface - but it is resource intensive
I am trying to setup LACP aggregation on my helios64 between the two ethernet ports on the helios64 and I noticed I can set the MTU of the 2.5G port up to 9000 but the 1G ethernet port top at 1500.
I use the 2.5G port as 1G as my network switch is gigabit only.
Can you confirm that the 'first' port (aka the 1G port) is not jumbo frame compliant ?
This error shows up when I try to change the size:
rk_gmac-dwmac fe300000.ethernet eth0: must be stopped to change its MTU
when the command is used:
# ip link set mtu 3000 eth0
RTNETLINK answers: Device or resource busy
Even when the link eth0 is down, the MTU cannot be changed.
Kernel version:
5.8.16-rockchip64 #20.08.14
Packages versions:
armbian-config : 20.08.20
armbian-firmware : 20.08.17
linux-dtb-current-rockchip64 : 20.08.14
linux-headers-current-rockchip64 : 20.08.14
linux-image-current-rockchip64 : 20.08.14
22 hours ago, AurelianRQ said:
Apparently Kobol team recommended to stay off the new kernels and to use their recommended ones. The problem is that every few days I get the Red System error led flashing and the box is not reachable so I have to force restart it so I can have access to it again
and many many others. I don't see network activity as well on the front panel, is that pending as well ? It would be nice to have something functional that does not crash . Is this a hardware issue or just software issue ?
Running your image 5.8.14-rockchip64 #20.08.10 SMP PREEMPT Tue Oct 13 16:58:01 CEST 2020 aarch64 GNU/Linux
It seem you get a kernel crash. You should connect to serial console to get the kernel crash log.
The network activity led is still not implemented yet.
20 hours ago, bverhagen said:
Hi all,
Last week I rendered my device unbootable by upgrading to 20.08.13 (it is stuck in U-boot rather than in starting the kernel though). This is 'known territory' though. So starting again from a vanilla install, 20.08.10 gets stuck in U-boot too, with the following error:
  Reveal hidden contents
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 928MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 928 MHz, current 856MHz
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 253
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
FwPartOffset=2000 , 100000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14792MB
FwPartOffset=2000 , 0
StorageInit ok = 66004
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3380ec0 signature is wrong
recovery gpt...
recovery gpt fail!
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xded88
RunBL31 0x40000
NOTICE:  BL31: v1.3(debug):42583b6
NOTICE:  BL31: Built : 07:55:13, Oct 15 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1190): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Sep 23 2020 - 17:44:09 +0200)
SoC: Rockchip rk3399
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
MMC:   mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from MMC... unable to select a mode
*** Warning - No block device, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Revision: 1.2 - 4GB non ECC
Net:   eth0: ethernet@fe300000
scanning bus for devices...
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
3185 bytes read in 5 ms (622.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
166 bytes read in 5 ms (32.2 KiB/s)
14089265 bytes read in 599 ms (22.4 MiB/s)
27275776 bytes read in 1156 ms (22.5 MiB/s)
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
2698 bytes read in 8 ms (329.1 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
## Executing script at 09000000
## Loading init Ramdisk from Legacy Image at 06000000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    14089201 Bytes = 13.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
   Loading Ramdisk to f5174000, end f5ee3bf1 ... OK
FDT and ATAGS support not compiled in - hanging
### ERROR ### Please RESET the board ###
Installing to either SD or the eMMC rendered the same issue.
I had to revert to 20.08.4 for my device to properly boot again (from SD, as eMMC does not work yet for this release). Since the 5.8.14 kernel is considered stable, I followed https://blog.kobol.io/2020/10/27/helios64-software-issue/ to upgrade to that kernel from 20.08.4 (using armbian-config). Fearing I would draw in the bad 5.8.16 kernel, I did not update anything else from 20.08.4. Unfortunately, this once again rendered my device unbootable, with the same error message as above. So for me, 20.08.10 seems to be not stable too. The Helios64 wiki claims it is though and many users of this forum seem to have no issues with 20.08.10 either.
After another fresh install of 20.08.4 - and no further upgrades - the Helios 64 is running stable for over a week now (it had been running on this version stable for a month previously too).
So this finally gets me to my question: Does anyone have any idea what goes wrong here? Does anyone have any suggestions on how to debug this? Why is my device unable to boot a fresh image for the 'stable' 20.08.10 release? At no point in the lifetime of the NAS did I tinker with U-boot.
You are using old U-Boot. It couldn't get the required device tree file. There was file renaming applied to Armbian 20.08.8 (released on 13 Oct 2020). You can do
1. Get serial console
2. When U-Boot appear, spam Enter key until you get U-Boot prompt (=> )
3. enter this command
setenv fdtfile "rockchip/rk3399-kobol-helios64.dtb"
bootd
4. After boot to Linux and login create symlink to new dtb
sudo ln -sf rk3399-kobol-helios64.dtb /boot/dtb/rockchip/rk3399-helios64.dtb
5. Upgrade the bootloader using armbian-config, System > Install > 5 Install/Update the bootloader on SD/eMMC
On next boot you should see U-Boot with more recent build date.
On 11/1/2020 at 11:28 AM, djurny said:
Have not checked if the buttons can be disabled in software yet (https://wiki.kobol.io/helios64/button/), perhaps the PMIC can be programmed in user space?
Unfortunately the Reset and Power button wired directly to PMIC and no configuration on the PMIC to disable it. However, short press Power button (graceful shutdown) can be disabled by editing /etc/systemd/logind.conf and set
HandlePowerKey=ignore
@wurmfood and @357up it could be an issue with the wire harness. Can you do more try by swapping the cable between the bay slots and sata ports in order to narrow down the problem to the wire harness. If it's the case then you can contact us to support@kobol.io and we will help you from there.
@AurelianRQ Regarding the issue for 2.5GbE port that doesn't perform properly when used in 1000Mb mode, unfortunately there is no fix that can be done by software. But it's actually pretty easy to fix on the board itself, it only requires to solder one wire between 2 points. Our mistake is that we didn't connect center tap of the 2.5Gb MAGJACK to 2.5V power rail (connected to ground instead) in order to provide common mode for MDI signals which is required for 1000Mb mode somehow. We will post a PCN bulletin to explain better this limitation and how to fix it for people who are up for a bit of soldering.
@aegiap Unfortunately your link aggregation is going to be impacted to the issue mentioned above. The 2.5GbE doesn't perform properly in 1000Mb mode.
19 minutes ago, gprovost said:
@AurelianRQRegarding the issue for 2.5GbE port that doesn't perform properly when used in 1000Mb mode, unfortunately there is no fix that can be done by software. But it's actually pretty easy to fix on the board itself, it only requires to solder one wire between 2 points. Our mistake is that we didn't connect center tap of the 2.5Gb MAGJACK to 2.5V power rail (connected to ground instead) in order to provide common mode for MDI signals which is required for 1000Mb mode somehow. We will post a PCN bulletin to explain better this limitation and how to fix it for people who are up for a bit of soldering.
That's sad.
Any information about the jumbo frame support on the working ethernet port ?
Hello, after setting up my Helios64 kit, flashing an SD card, and setting up the serial, i connect to picocom and nobody's home.
there are no HDD installed yet because I am testing the board itself, but it will not boot. I have tried multiple known-good sandisk microsds, both the armbian and ubuntu version (whatever was current as of 1 Nov) with no success.
would maskrom mode be my first logical step to recovery?
Has anyone tried moving Armbian OS over from the emmc to a sata drive? Any advantages to doing this? I found this in a banana pi forum:https://wiki.daniel-keil.de/projekte/banana-pro/install-armbian-to-a-sata-drive
Had no problem with general install of armbian to the emmc and updating firmware thru armbian-config (worked like a charm).
vor 12 Stunden schrieb gprovost:
Soldering? No problem here !
I can help users from Germany to fix their helios board once the solution is released.
On 11/1/2020 at 7:29 PM, TonyMac32 said:
power delivery through USB-C.
Oh and mode switching.  So if it set to the mode you want by default it should be ok, but the better question is why was it eating clock cycles
So far I have found that the I2C bus generates ~20k interrupts sec:
root@helios64:/proc# cat interrupts && sleep 10 && cat interrupts
<snip>
 43:    4107025          0          0          0          0          0     GICv3  88 Level     ff3d0000.i2c
<snip>
 43:    4311805          0          0          0          0          0     GICv3  88 Level     ff3d0000.i2c
but I don't know what exactly that means. A simple i2cdetect on that bus generates 351 interrupts. So it's not bits.
Had no problem with general install of armbian to the emmc and up: dating firmware thru armbian-config (worked like a charm).
Yes I did. I wrote about it in the comments section of sata in the wiki: https://wiki.kobol.io/helios64/sata/
Is the U-Boot image installed on the SPI Flash? If not is it possible to install it there?
The instructions on the Wiki page say to write it to the microSD card and have the board boot from the microSD.
Yes we are aware of that, something wrong with fusb302 driver, @aprayoga is looking into it.
I just tried to copy my Armbian install from the SD Card to the eMMC, but I'm not sure it has been successful, how can I be sure?
For information, I also encrypted my HDDs using LUKS and I use MergerFS to pool their data.
Boot sequence from serial console
DDR Version 1.24 20191016
In
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x82
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x2
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 323
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=61056MB
StorageInit ok = 66065
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
Load OK, addr=0x200000, size=0xdcfd8
RunBL31 0x40000
INFO:    SPSR = 0x3c9
U-Boot 2020.07-armbian (Oct 13 2020 - 16:49:59 +0200)
Reset cause: RST
DRAM:  3.9 GiB
PMIC:  RK808
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Scanning mmc 1:1...
16452750 bytes read in 700 ms (22.4 MiB/s)
79946 bytes read in 10 ms (7.6 MiB/s)
   Image Name:   uInitrd
   Data Size:    16452686 Bytes = 15.7 MiB
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f4f35000, end f5ee5c4e ... OK
   Loading Device Tree to 00000000f4eb9000, end 00000000f4f34fff ... OK
Starting kernel ...
openmediavault 5.5.14-1 (Usul) helios64 ttyS2
Output from df
axel@helios64:~$ df
Filesystem                                  1K-blocks       Used  Available Use% Mounted on
udev                                          1869984          0    1869984   0% /dev
tmpfs                                          389128      10396     378732   3% /run
/dev/mmcblk0p1                               60910176    5312260   54945884   9% /
tmpfs                                         1945632          0    1945632   0% /dev/shm
tmpfs                                            5120          0       5120   0% /run/lock
tmpfs                                         1945632          0    1945632   0% /sys/fs/cgroup
tmpfs                                         1945632         12    1945620   1% /tmp
folder2ram                                    1945632      14632    1931000   1% /var/log
folder2ram                                    1945632          0    1945632   0% /var/tmp
folder2ram                                    1945632        484    1945148   1% /var/lib/openmediavault/rrd
folder2ram                                    1945632        724    1944908   1% /var/spool
folder2ram                                    1945632      13988    1931644   1% /var/lib/rrdcached
folder2ram                                    1945632          4    1945628   1% /var/lib/monit
folder2ram                                    1945632       1288    1944344   1% /var/cache/samba
/dev/mapper/sda-crypt                      2883204744 1150794608 1732393752  40% /srv/dev-disk-by-label-parity1
/dev/mapper/sdb-crypt                      2883204744 1127952968 1755235392  40% /srv/dev-disk-by-label-data1
/dev/mapper/sdc-crypt                      2883204744 1127947312 1755241048  40% /srv/dev-disk-by-label-data2
tmpfs                                          389124          0     389124   0% /run/user/1000
pool0:65b1923f-43cc-499b-b4c3-265b982c7f8a 5766409488 2255900280 3510476440  40% /srv/65b1923f-43cc-499b-b4c3-265b982c7f8a
/etc/fstab
axel@helios64:~$ cat /etc/fstab
UUID=a79a14c0-3cf4-4fb9-a6c6-838571351371 / ext4 defaults,noatime,nodiratime,commit=600,errors=remount-ro 0 1
tmpfs /tmp tmpfs defaults,nosuid 0 0
# >>> [openmediavault]
As far as I can see it booted from sd, or at least the root file system is an 64GB sd card. To boot from emmc you have to remove the sd card.
OK, thanks.
Welp, I removed the SD card and it did not boot to eMMC.
picocom v2.2
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 1500000
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
send_cmd is    : sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Type [C-a] [C-h] to see available commands
Terminal ready
[ 5681.802401] reboot: Power down
[ 5�DDR Version 1.24 20191016
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
ChipType = 0x10, 254
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67773
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Card did not respond to voltage select!
mmc0(part 0) is current device
Scanning mmc 0:1...
Wrong image format for "source" command
SCRIPT FAILED: continuing...
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus dwc3 for devices... 4 USB Device(s) found
Device 0: unknown device
Speed: 1000, full duplex
BOOTP broadcast 1
DHCP client bound to address 192.168.0.110 (2 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/01-64-62-66-d0-03-7c
Retrieving file: pxelinux.cfg/C0A8006E
Retrieving file: pxelinux.cfg/default-arm-rk3399-helios64
Config file not found
BOOTP broadcast 1
DHCP client bound to address 192.168.0.110 (3 ms)
BOOTP broadcast 1
DHCP client bound to address 192.168.0.110 (1 ms)
=> DDR Version 1.24 20191016
vor 2 Stunden schrieb axeleroy:
  Versteckten Inhalt anzeigen
picocom v2.2
flowcontrol    : none
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : no
imap is        :
omap is        :
Terminal ready
In
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
OUT
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14910MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
SecureMode = 0
recovery gpt...
recovery gpt fail!
No find bl30.bin
No find bl32.bin
RunBL31 0x40000
INFO:    SPSR = 0x3c9
Reset cause: POR
DRAM:  3.9 GiB
PMIC:  RK808
In:    serial
Out:   serial
Err:   serial
Model: Helios64
Scanning mmc 0:1...
starting USB...
USB XHCI 1.10
BOOTP broadcast 1
BOOTP broadcast 1
BOOTP broadcast 1
use the command df -h to show from which storage the system was loaded.
If it says /dev/mmcblk1p1 it is the eMMC and if it says /dev/mmcblk0p1 it is still your microSD.
You can also tell from the memory size whether it is the eMMC (has 15GB) or your microSD.
root@helios64:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            1.8G     0  1.8G   0% /dev
tmpfs           381M   37M  344M  10% /run
/dev/mmcblk1p1   15G  7.8G  5.7G  59% /
tmpfs           1.9G     0  1.9G   0% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
tmpfs           1.9G  4.0K  1.9G   1% /tmp
Hi all,
A few days ago, I started my backup scripting on the Helios64 box. This is an rsync that will grab files from the Helios4 box and stores it on local disk. To my surprise, the backup took over 20 hours. At the time I did not think much of it, as it was a new month, and every new month means a new non-incremental backup will take place.
Yesterday I decided to have a closer look at what had happened. To my surprise, I found that eth0 was running at 100Mbps?
Settings for eth0:
        Supported ports: [ TP MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
        Link partner advertised pause frame use: Symmetric
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 100Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 0
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: ug
        Wake-on: d
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
Now I know for a fact that the switch connected to it, is capable of 1Gbps. After changing the cabling, I managed to rule out at least all the cables I have lying around - as all reported 100Mbps, short cables, long cables, cables that were working fine in the Helios4 box.
Next up, was to try an intermediate 1Gbps switch: This worked; Helios64 showed 1000Mbps speed - but - it did not show any network activity, the box was unreachable from the outside and the box was not able to reach anything on the outside.
After connecting the original cable back, it flipped to 100Mbps again, but at least connectivity was there.
Anyone have any idea on what to check next?
Thanks,
Groetjes,
Edited by djurny
Issue was cabling after all.
23 hours ago, axeleroy said:
Scanning mmc 0:1...
The boot.scr script is damaged. You can try to recreate it. Boot from sd once again, mount the emmc filesystem and recreate
mkdir /tmp/mmc
mount /dev/mmc/mmcblk1p1 /tmp/mmc
chroot /tmp/mmc mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Well according to your ethtool ouput. Your switch only advertise 10 and 100baseT/Full. What switch model it is ?
I think you need to try again with the other switch you mentioned about. What switch model it is ?
Both are Zyxel switches, one is 16 ports GS1100 -16 and the other is 8 ports GS-108Bv3. Both are Gbps capable, as shown by other devices connected to the same switch:
Helios4:
                                     1000baseT/Full
Just now, I tried yet another set of cables to connect to the Helios64 box, and it seems I have bought several batches of cat "5e" cables, with stress on "5e". Looks like a cabling issue still. I never noticed this, as most are connected to either Raspberry Pi2b or OrangePi zero devices (see ethtool output from one of the Pis below, connected to the same 16ports Gbps capable switch). I already ordered another batch of [apparently] shielded cat 6 cables, hopefully they are indeed shielded, cat 6 and not cat "6".
Raspberry Pi2b:
Please disregard my previous post.
Thanks,
Groetjes,
What is a normal CPU temperature on idle? Mine is never lower than 40°C, at an ambient temperature of 19°C, which makes me wonder how much electricity it draws. Is it possible that the GPU is actively doing nothing, or something like that? If so, can it be switched off?
The NAS has been placed vertically, with the CPU on bottom. The disk in slot 5 is 22°C.
On 10/7/2020 at 7:45 PM, gprovost said:
Could you please send us an email to support@kobol.io with some pictures in order to check what's wrong with your enclosure unit.
When I received my Helios64 - the case was out of whack -- the alignment was off by about 1/4 inch (3-5mm or so)....
since it was out of whack -- I gave it one - with a rubber mallet - worked perfectly -
a gentle but sharp tap - once on both sides (I'll go through my phone later today to see if I took pictures)
Rich
Mine is running somewhere around 44 - 52°C - at an ambient temperature of 23°C.
CPU frequency for both Big and Little cores are around 408 MHz according to 'htop'
Weird, htop on my Helios doesn't seem to be the armbian version anymore: no temperature, no frequency.
Could you please share your APT sources.list so I can check I didn't accidentally overwrite mine.
T
Cool, well I can do that I guess if that does not void the warranty in this case, Honestly to get a 300 E switch to manage 2.5 or 100 E adapters that I don't even know they work, I prefer to fix it the easy way if possible. Thanks and I guess waiting for your details.
@AurelianRQ You post is a bit messed up (can you edit/fix it ?).
You can find multi-gigabit switch at 150euros check Zyxel XGS1010-12 or even QNAP QSW-1105-5T. As for the instruction to fix the 1000Mb mode on the 2.5Gbe port, it was posted above.
Assembled my first (of two) helios64s. I needed to insulate the chassis around the leds, but the USB-C connector fit perfectly into the back panel opening. I noticed a problem with the sata cable for slot 1 where it passes under the chassis to reach the board socket. The chassis has a sharp edge that presses onto the cable, so I padded it with some electrical tape.
In the box containing the system board there was a plastic bag with two jumper plugs and two screws and a threaded spacer. What is the purpose of the spacer and screws?
I had stability problems using Windows to install OS to eMMC. Windows recognized the eMMC as a storage device for a few seconds after helios64 started but then it disappeared. It finally worked after about 10 tries. I was using a USB3 extension cable to reach my pc - perhaps that was the cause.
Thanks,
Jeff
