Voltage stayed at 1.1v once cpuburn started.
Yeah, with Armbian settings we use 1.1V from 0-912 MHz and 1.3V for the upper clockspeeds. So the most interesting graph would be 18:30-20:30 with just SoC temperature and clockspeed. Can you please post that again?
Well, at least it's obvious from the graphs that cpuburn-a7 was not running at all (or to be more precise: it ran few milliseconds and then it crashed) so you ran into the same problem as @eperie above: Increasing load --> dropping voltage --> board freezing or starting to behave totally weird.
Ok, lesson learned. I shouldn't encourage users to run heavy stuff on boards with an inappropriate DC-IN connector. Since you either need ultra short USB cables that are rated 20AWG or 22AWG or power the board reliably with Dupont jumper wires through the 4 pin header next to the upright USB jack.
No problem, I happily volunteered, and Armbian saved me a ***lot*** if time while setting-up my nanopi-m1.
I had read about those power supply issues on the forum, but thought I would be fine with a 2A micro-USB power supply - it seems I was wrong: my cable is not short, and I am not sure about its gauge.
I powered the board with a MB102 breadboard power supply rated for 5V/1.2A directly on the 4 pins header using Dupond cables as suggested, and cpuburn-a7 hanged the board again. Looking now for a 5V switching power supply: I am not sure the breadboard power supply is doing the job. Thanks for the help.
The breadboard power supply is usually designed with AMS1117 regulator. Each regulator (3.3V, 5V) can handle 1A MAX output at best
note: it can handle the power of an Arduino Uno (USB) or Arduino minipro, a 1602 LCD, a current sensor but not much more components.
Yes, this is the case of mine - thanks.
There we go. Sorry, wasn't sure what was actually needed so I played it safe and included the same as the ones you linked further above on github.
Thanks. The problem was that cpufreq shares the same axis with other graphs so that the exact range of throttling clockspeeds was not visible. The graph above is better and we now know that NanoPi NEO with the rather unrealistic heavy cpuburn-a7 workload throttles down to ~480 MHz.
Fortunately 'normal' use cases for this board look differently but for tasks that need constant higher CPU utilization a heatsink looks mandatory.
3D printable enclosure appeared on the official wiki:
There's enough room for the official heatsink also and I would suppose that the upcoming NanoPi Air will share the same dimensions so a slightly different enclosure allowing to connect an external antenna might follow soon (or NanoPi Air relies on a PCB antenna only -- we'll see)
for everyone's interest more information (and pictures!) about this enclosure has been posted to thingiverse here: http://www.thingiverse.com/thing:1698298
So I installed the Jessie armbian image, grabbed tkaiser's .fex file ...
now I get this repeatedly in the kernel log.... ?
[ 7522.234589] [ARISC ERROR] :message process error
[ 7522.234650] [ARISC ERROR] :message addr   : f004b840
[ 7522.234687] [ARISC ERROR] :message state  : 5
[ 7522.234720] [ARISC ERROR] :message attr   : 2
[ 7522.234753] [ARISC ERROR] :message type   : 30
[ 7522.234786] [ARISC ERROR] :message result : ff
[ 7522.234817] [ARISC WARING] :callback not install
[ 7522.234857] [cpu_freq] ERR:set cpu frequency to 240MHz failed!
Edit:
the 240Mhz voltage level was missing... also the minimum frequency was still 480Mhz so I fixed that (and just changed 480Mhz level to 240Mhz also I don't think you need to do this though) and now it works fine.
this is on the naonpim1 image... I did update the nanopine.fex to the one linked to above.
If I modprobe sunxi_pwm I get a /dev/sunxi_pwm device and some sysfs interfaces but they don't seem to match up with any documentation I can find.
root@nanopi-neo:~# ls
a.out  test.c
root@nanopi-neo:~# armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU
01:21:22: 1008MHz  0.16   0%   0%   0%   0%   0%   0%   52°C
01:21:27: 1152MHz  0.14   0%   0%   0%   0%   0%   0%   52°C
01:21:32:  240MHz  0.13   0%   0%   0%   0%   0%   0%   52°C
01:21:37:  240MHz  0.12   4%   1%   0%   0%   1%   0%   53°C
01:21:42:  240MHz  0.19   1%   1%   0%   0%   0%   0%   55°C
01:21:47: 1008MHz  0.31   1%   1%   0%   0%   0%   0%   53°C
01:21:52:  240MHz  0.28   1%   1%   0%   0%   0%   0%   53°C
01:21:58:  240MHz  0.26   4%   2%   1%   0%   0%   0%   53°C
Board configuration / this file is the only difference. PWM - I haven't check this yet and it's possible that it's not properly configured.
Back from holiday - here are my CPU values with the first offical NanoPI  NEO Armbian image.
root@nanopineo:~# armbianmonitor -m
06:55:18: 1008MHz  0.49   4%   1%   1%   0%   1%   0%   55°C
06:55:23:  240MHz  0.45   4%   1%   1%   0%   1%   0%   55°C
06:55:29:  240MHz  0.42   4%   1%   1%   0%   1%   0%   54°C
06:55:34:  240MHz  0.38   4%   1%   1%   0%   1%   0%   54°C
06:55:39:  240MHz  0.35   4%   1%   1%   0%   1%   0%   54°C
06:55:44:  240MHz  0.33   4%   1%   1%   0%   1%   0%   54°C
06:55:49:  240MHz  0.30   3%   1%   1%   0%   1%   0%   54°C
06:55:55:  240MHz  0.28   3%   1%   1%   0%   1%   0%   54°C
I was able to get gpio 6 to turn on and off from sysfs but I still haven't figured out pwm.
The only thing in /sys/sunxi_pwm/sunxi_pwm is...
./dev
./power
./power/control
./power/async
./power/runtime_enabled
./power/runtime_active_kids
./power/runtime_active_time
./power/autosuspend_delay_ms
./power/runtime_status
./power/runtime_usage
./power/runtime_suspended_time
./subsystem
./uevent
my .fex file has the follwing..
[pwm0_para]
pwm_used = 1
pwm_positive = port:PA05<3><0><default><default>
[pwm1_para]
pwm_used = 0
pwm_positive = port:PA06<3><0><default><default>
Which might conflict with uart0?
So is it PA06 that is acutually the correct PWM output?
I was toggling the correct pin GPIO6 earlier with no effect on UART0. So I presume that is the case...
If have neither an idea nor the hardware here (and since there are some vendors out there that are totally surprised by different pin mappings they find on their own boards checking with real hardware is IMO mandatory -- but FriendlyARM can not be compared to lousy 'Team BPi')
I just wanted to point out that both pins that might be used for PWM are defined already as active (PA05 for uart0 and PA06 as GPIO pin -- this definition then has to be removed in case you want to try out pwm1)
Ok, I tried disabling the UART in the .fex (and it did end up disabled once I rebooted) but this didn't change anthing else as far as I could tell....
Edit:
running cpuburn-a7 ... I only have 1 core enabled and everything I am not using disabled in the .fex file. (this is an automatic AVR 32u4 board flasher so I don't need much ummph) Also the ram is running at 132Mhz.
22:07:21:  240MHz  0.44  12%   8%   0%   2%   0%   0%   39°C
22:07:27:  240MHz  0.49  76%  11%  61%   1%   0%   0%   40°C
22:07:33:  240MHz  0.53 100%   3%  95%   0%   0%   0%   40°C
22:07:39:  240MHz  0.56 100%   3%  95%   0%   0%   0%   40°C
22:07:45:  240MHz  0.60 100%   3%  95%   0%   0%   0%   40°C
22:07:50:  240MHz  0.71 100%   7%  90%   1%   0%   0%   40°C
22:07:56:  240MHz  0.83 100%   2%  97%   0%   0%   0%   40°C
22:08:01:  240MHz  0.84 100%   5%  91%   2%   0%   0%   40°C
22:08:07:  240MHz  0.94 100%   5%  91%   2%   0%   0%   40°C
My FriendlyARM package arrived yesterday and they included a bit more stuff than expected (NanoPi M1 too). I immediately started to build a NanoCluster just to realize that this was a very bad idea since I always confused boards and ended up in the meantime disassembling the 'cluster' and using a single board with mounted heatsink for the first round of tests
Based on some research how to lower consumption on H3 boards the last weeks I used then our new preliminary Armbian image for the NEO, simply adjusted DRAM clockspeed to the lower limit (needs a patch) and disabled cpu cores 1-3 to end up at 805 mW consumption. I simply added to /etc/rc.local
echo 0 >/sys/devices/system/cpu/cpu3/online
echo 0 >/sys/devices/system/cpu/cpu2/online
echo 0 >/sys/devices/system/cpu/cpu1/online
echo 132000 >/sys/devices/platform/sunxi-ddrfreq/devfreq/sunxi-ddrfreq/userspace/set_freq
dmesg -n1
Then I tried out FA's 'Ubuntu Core + Qt Embedded' image just to realize that there's something wrong since consumption was immediately at a very high level (above 1.5W I would assume) since this image starts '/opt/QtE-Demo/run.sh&' from within /etc/rc.local which might not be that useful on a device lacking display output. After killing these processes FA's image needed 1225 mW so our 805 mW are a nice improvement (two thirds).
But since I found 805 mW quite a lot I used the modified NanoPi NEO image with an Orange Pi Lite and there consumption with exactly the same settings was just at 665 mW so switching to a different hardware saved another 140 mW (please take this with a grain of salt since even with identical settings there the hardware differs and there's no Ethernet physically available which might let H3's integrated PHY disable the Ethernet block at all? This test would've to be repeated with an Orange Pi One but I don't have one any more).
From left to right:Bildschirmfoto%202016-08-10%20um%2008.18
Since I used the heatsink a few first words regarding temperatures. NanoPi NEO with our new settings and heatsink applied reported 27°C while idling at 240 MHz, with FA's Ubuntu Core idling at 480 MHz 41°C were reported. Why such a difference? Since thermal readouts in Armbian are broken. :)
To be more precise: When we started supporting H3 boards half a year ago I immediately realized that thermal readouts are wrong as soon as we switch from Allwinner's legacy u-boot (2011.09) to mainline u-boot (2016.01 back at that time). We discussed this in linux-sunxi IRC but still have no idea why the readouts differ (maybe some clocks are set differently and this affects ADC conversion?). But based on a series of measurements I did back then we can assume that temperatures reported in Armbian are 10-15°C lower than when using BSP u-boot (that's why we start with throttling on H3 boards already at 70°C -- H3 is specified to run at up to 125°C so we use a lot of safety headroom).
The temperature mismatch can simply be checked with a thumb. 27°C as reported when running Armbian is less than my own temperature but touching the heatsink it feels slightly warmer. BTW: To ensure lowest idle operation possible I refrained from installing RPi-Monitor and did not use 'armbianmonitor -m' but just checked clockspeed and temperature every 2 seconds using
while true ; do echo "$(cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq) kHz, $(cat /sys/class/thermal/thermal_zone1/temp)C"; sleep 2; done
That's it for now. Next steps are some consumption measurements with different DRAM clockspeeds (since the 432 MHz FriendlyARM chose do not help that much with regards to energy savings but 264 MHz for example do and 132 MHz even more) and debugging why the boards quite often hang in u-boot.
26.6°C
91% Humidity
12:56:05: 1152MHz 0.05 0% 0% 0% 0% 0% 0% 36°C
12:56:10: 240MHz 0.05 0% 0% 0% 0% 0% 0% 36°C
12:56:15: 240MHz 0.04 0% 0% 0% 0% 0% 0% 36°C
12:56:21: 240MHz 0.04 0% 0% 0% 0% 0% 0% 35°C
12:56:26: 240MHz 0.04 0% 0% 0% 0% 0% 0% 36°C
12:56:31: 240MHz 0.03 0% 0% 0% 0% 0% 0% 35°C
12:56:36: 240MHz 0.03 0% 0% 0% 0% 0% 0% 36°C
12:56:42: 240MHz 0.03 0% 0% 0% 0% 0% 0% 36°C
12:56:47: 240MHz 0.03 0% 0% 0% 0% 0% 0% 35°C
12:56:52: 240MHz 0.02 0% 0% 0% 0% 0% 0% 36°C
12:56:57: 240MHz 0.02 0% 0% 0% 0% 0% 0% 36°C
12:57:03: 240MHz 0.02 0% 0% 0% 0% 0% 0% 36°C
12:57:08: 240MHz 0.02 0% 0% 0% 0% 0% 0% 36°C
12:57:13: 240MHz 0.02 0% 0% 0% 0% 0% 0% 36°C
12:57:18: 240MHz 0.02 0% 0% 0% 0% 0% 0% 35°C
12:57:23: 240MHz 0.01 0% 0% 0% 0% 0% 0% 36°C
12:57:29: 240MHz 0.01 0% 0% 0% 0% 0% 0% 36°C
12:57:34: 240MHz 0.08 0% 0% 0% 0% 0% 0% 35°C
12:57:39: 240MHz 0.08 0% 0% 0% 0% 0% 0% 36°C
12:57:44: 240MHz 0.07 0% 0% 0% 0% 0% 0% 36°C
12:57:50: 240MHz 0.07 0% 0% 0% 0% 0% 0% 35°C
12:57:55: 240MHz 0.06 0% 0% 0% 0% 0% 0% 36°C
12:58:00: 240MHz 0.06 0% 0% 0% 0% 0% 0% 36°C
12:58:05: 240MHz 0.05 0% 0% 0% 0% 0% 0% 36°C
12:58:10: 240MHz 0.05 0% 0% 0% 0% 0% 0% 36°C
12:58:16: 240MHz 0.04 0% 0% 0% 0% 0% 0% 35°C
12:58:21: 240MHz 0.04 0% 0% 0% 0% 0% 0% 36°C
12:58:26: 240MHz 0.04 0% 0% 0% 0% 0% 0% 36°C
12:58:31: 240MHz 0.03 0% 0% 0% 0% 0% 0% 35°C
12:58:37: 240MHz 0.03 0% 0% 0% 0% 0% 0% 36°C
I've rebooted my board 20+ times and haven't seen it hang... So, how often are we talking?
Pretty often, it must've been some 'noise' that prevented u-boot from doing autoboot (u-boot waits a few seconds for keystrokes and if none happen it resumes with booting. In my case something went wrong -- didn't had the time to check since currently DRAM clockspeed consumption tests do run)
BTW: Please don't consider any DRAM clockspeed below 408 MHz to be safe for productive use. It still needs a lot of testing whether we can decrease minimum DRAM clockspeed by patching the kernel :)
I am having troubles with getting audio from the sunxi audiocodec on my NanoPi NEO.
Please check post #2 here. Sorry, can't help more since I refrain from touching audio on Linux.
And again: NanoPi NEO got stuck on u-boot prompt again. I did some unattended testing regarding temperature and consumption figures when switching between 132 MHz and 672 MHz DRAM clockspeed and then the script did a reboot which looks like it would've failed but in reality the NEO is 'just' waiting for input. All I had to do was to connect serial console and then [enter], boot, [enter]:
=> boot
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2599 bytes read in 172 ms (14.6 KiB/s)
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
** File not found /boot/.verbose **
** File not found /boot/.next **
** File not found .next **
35300 bytes read in 577 ms (59.6 KiB/s)
3374488 bytes read in 410 ms (7.8 MiB/s)
5069480 bytes read in 535 ms (9 MiB/s)
Kernel image @ 0x42000000 [ 0x000000 - 0x4d5aa8 ]
## Loading init Ramdisk from Legacy Image at 43300000 ...
   Image Name:   uInitrd
   Data Size:    3374424 Bytes = 3.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
[sun8i_fixup]: From boot, get meminfo:
        Start:  0x40000000
ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1
ion_reserve_select: ion chipid  [0x2004620!
ion_reserve_common: ion reserve: [0x56000000, 0x60000000]!
Ubuntu 16.04.1 LTS nanopineo ttyS0
nanopineo login:
Pretty mean behaviour. Everytime I have serial console connected it did not happen, only in unattended mode :)
At least we now know at which consumption the NEO idles in u-boot 2016.07 with NanoPi M1 settings (816 MHz CPU, 624 MHz DRAM): 1100 mW. Good to know since I want to test out settings with greatly reduced consumption (480 MHz, 408 MHz DRAM for example -- the goal is to let NEO boot with less than 1W consumption while bringing up all 4 CPU cores)
Comparing NanoPi Neo schematics with, for example, Orange Pi Lite, Lite has level shifter and pull-up resistor on UART0 RX line, while RX line on Neo is floating.
So the problem can be very simple - Neo picks up noise on RX during boot if nothing is connected to UART0 RX pin. Solution - solder a resistor (i.e. 10kOhm) from 3.3V to RX. (WARNING: 2nd pin on Neo UART header is 5V, not 3.3V!)
Edit: There should be internal pull-ups in SoC, but whether SPL/U-boot activates them or not needs to be checked in source code.
Edit 2: U-boot seems to set pull-up for RX pin, but still there is difference in hardware implementation
Would be interesting whether there was a change between 2016.05 and 2016.07... but I definitely had the same behaviour with FA's OS image which uses u-boot 2011.09.
Thanks for the explanation. IIRC I also had not a single problem yesterday when I used FA's PSU-ONECOM module to power the board. Will dig deeper tomorrow. The scheduled test for today will run the next 11 hours and I hope that I'm then not too tired to switch boards after midnight and let the same consumption monitoring test run again on OPi Lite.
If you can reproduce this hang at u-boot without connecting anything to serial port and can't with connected (and powered) serial adapter, then it's probably related to simplified schematics, otherwise try connecting only TX line (from board's side) to catch any possible messages without interfering with input.
Different debugging approach since it happened only once with FA's OS image but quite frequently with our NEO image. I downloaded our 5.14 image for Orange Pi One, flashed it and started NEO with this. No hang, then downloaded our new fex file as outlined on page 3 of this thread and disabled usb2 and usb3 since I wanted to have a look if then the frequent messages stop (they don't):
hub 1-0:1.0: connect-debounce failed, port 1 disabled
I've seen them on at least two different NEOs (one 512MiB, one 256MiB) and with both FA's Ubuntu as well as ours. NEO/512 running FA's Ubuntu:
HELLO! BOOT0 is starting!
boot0 version : 4.0.0
boot0 commit : 182eb92ae6fac135787d4fc7bfd0e02aa445155c
fel_flag = 0x00000000
rtc[0] value = 0x00000000
rtc[1] value = 0x00000000
rtc[2] value = 0x00000000
rtc[3] value = 0x00000000
rtc[4] value = 0x00000000
rtc[5] value = 0x00000000
rtc[6] value = 0x00000000
rtc[7] value = 0x00000000
DRAM DRIVE INFO: V1.3
the chip id is 0x00000081
READ DQS LCDL = 002c2c2c
DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 432 MHz
DRAM zq value: 003b3bfb
DRAM dram para1: 10f20200
DRAM dram para2: 00000001
DRAM workmode1: 000009f4
DRAM SIZE =512 M
odt delay
dram size =512
card boot number = 0
card no is 0
sdcard 0 line count 4
[mmc]: mmc driver ver 2015-04-13 16:07:39
[mmc]: ***Try SD card 0***
[mmc]: SD/MMC Card: 4bit, capacity: 7580MB
[mmc]: vendor: Man 00035344 Snr 49e841fe
[mmc]: product: SL08G
[mmc]: revision: 8.0
[mmc]: ***SD/MMC 0 init OK!!!***
sdcard 0 init ok
The size of uboot is 000e4000.
sum=2a2e0058
src_sum=2a2e0058
Succeed in loading uboot from sdmmc flash.
Ready to disable icache.
Jump to secend Boot.
SUNXI_NORMAL_MODE
[      0.416]e mode
U-Boot 2011.09-rc1-00000-g182eb92 (Jul 04 2016 - 10:10:53) Allwinner Technology
[      0.424]version: 1.1.0
[      0.427]uboot commit : 182eb92ae6fac135787d4fc7bfd0e02aa445155c
normal mode
[      0.438]pmbus:   ready
not set main pmu id
axp_probe error
[board_vendor] vid_used not used
[      0.478]PMU: pll1 1008 Mhz,PLL6=600 Mhz
AXI=336 Mhz,AHB=200 Mhz, APB1=100 Mhz
sid read already
fel key new mode
run key detect
no key found
no key input
dram_para_set start
dram_para_set end
normal mode
[      0.509]DRAM:  512 MiB
relocation Offset is: 15af2000
[box standby] read rtc = 0x0
[box_start_os] mag be start_type no use
user_gpio config
user_gpio ok
gic: normal or no secure os mode
workmode = 0
MMC:     0
[      0.593][mmc]: mmc driver ver 2015-04-13 14:50:00
[      0.598][mmc]: get sdc_phy_wipe fail.
[      0.602][mmc]: get sdc0 sdc_erase fail.
[      0.606][mmc]: get sdc_f_max fail,use default 50000000Hz
[      0.611][mmc]: get sdc_ex_dly_used fail,use default dly
[      0.617][mmc]: SUNXI SD/MMC: 0
[      0.630][mmc]: *Try SD card 0*
[      0.679][mmc]: CID 0x3534453 0x4c303847 0x8049e841 0xfe010687
[      0.684][mmc]: mmc clk 50000000
[      0.688][mmc]: SD/MMC Card: 4bit, capacity: 7580MB
[      0.692][mmc]: boot0 capacity: 0KB,boot1 capacity: 0KB
[      0.698][mmc]: ***SD/MMC 0 init OK!!!***
[      0.702][mmc]: erase_grp_size:0x1WrBlk * 0x200 = 0x200 Byte
[      0.708][mmc]: secure_feature 0x0
[      0.711][mmc]: secure_removal_type  0x0
[      0.715]sunxi flash init ok
script config pll_de to 864 Mhz
Not Found clk pll_video1 in script
script config pll_video to 297 Mhz
script config pll_periph0 to 600 Mhz
DRV_DISP_Init end
[disk_read_fs] no the partition
error: open tv_vdid.fex, maybe it is not exist
error: open disp_rsl.fex, maybe it is not exist
boot_disp.auto_hpd=1
auto hpd check has 100 times!
auto check no any connected, the output_type is 4
[      1.862]finally, output_type=0x4, output_mode=0x4, screen_id=0x0, disp_par0
try to read logic blk 0 without env partition
In:    serial
Out:   serial
Err:   serial
--------fastboot partitions--------
mbr not exist
base bootcmd=run setargs_mmc boot_normal
bootcmd set setargs_mmc
key 0
cant find rcvy value
cant find fstbt value
no misc partition is found
to be run cmd=run setargs_mmc boot_normal
[      1.910][mmc]: MMC Device 2 not found
[      1.914][mmc]: Can not find mmc dev
[      1.917][mmc]: read first backup failed in fun sdmmc_secure_storage_read l4
sunxi_secstorage_read fail
get secure storage map err
check user data form private
the private part isn't exist
WORK_MODE_BOOT
adver not need show
sunxi_bmp_logo_display
error: open bootlogo.bmp, maybe it is not exist
sunxi bmp info error : unable to open logo file bootlogo.bmp
[      1.953]Hit any key to stop autoboot:  0
## Booting kernel from Legacy Image at 40007800 ...
   Image Name:   Linux-3.4.39-h3
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4511456 Bytes = 4.3 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Loading Kernel Image ... OK
OK
[      4.425][mmc]: MMC Device 2 not found
[      4.429][mmc]:  mmc  not find,so not exit
[      4.433]
Starting kernel ...
        Start:  0x40000000
ion_reserve_select: ion chipid  [0x2c00081!
[    0.000000] Booting Linux on physical CPU 0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4.39-h3 (root@wwd-ubuntu) (gcc version 4.6.3 2016
[    0.000000] cma: CMA: reserved 160 MiB at 56000000
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0eca000 s11840 r8192 d12736 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty0 root=/devt
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 1048576 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memos
[    0.000000] Memory: 512MB = 512MB total
[    0.000000] Memory: 343172k/343172k available, 181116k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0897764   (8766 kB)
[    0.000000]       .init : 0xc0898000 - 0xc08e7e40   ( 320 kB)
[    0.000000]       .data : 0xc08e8000 - 0xc09622b8   ( 489 kB)
[    0.000000]        .bss : 0xc0962a6c - 0xc0a37630   ( 851 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:544
[    0.000000] Architected local timer running at 24.00MHz.
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 1789s
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty0] enabled
[    0.000996] Calibrating delay loop (skipped), value calculated using timer f)
[    0.001071] pid_max: default: 32768 minimum: 301
[    0.001450] Mount-cache hash table entries: 512
[    0.002568] Initializing cgroup subsys cpuacct
[    0.002611] Initializing cgroup subsys memory
[    0.002685] Initializing cgroup subsys devices
[    0.002716] Initializing cgroup subsys freezer
[    0.002746] Initializing cgroup subsys blkio
[    0.002793] Initializing cgroup subsys perf_event
[    0.002876] CPU: Testing write buffer coherency: ok
[    0.002958] ftrace: allocating 24050 entries in 71 pages
[    0.030365] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030420] [sunxi_smp_prepare_cpus] enter
[    0.030480] Setting up static identity map for 0x4061b9a0 - 0x4061b9f8
[    0.031607] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031748] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040276] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040398] Brought up 4 CPUs
[    0.040398] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.041100] devtmpfs: initialized
[    0.043894] wakeup src cnt is : 2.
[    0.043992] sunxi pm init
[    0.044153] pinctrl core: initialized pinctrl subsystem
[    0.056444] NET: Registered protocol family 16
[    0.057314] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.057314] script_sysfs_init success
[    0.057314] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.057314] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.057314] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint.
[    0.057314] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.057314] script config pll_video to 297 Mhz
[    0.057314] script config pll_de to 864 Mhz
[    0.057314] script config pll_ve to 402 Mhz
[    0.064134] bio: create slab <bio-0> at 0
[    0.070085] [ARISC] :sunxi-arisc driver v1.04
[    0.080329] [ARISC] :arisc version: [v0.1.58]
[    0.178085] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.178223] pwm module init!
[    0.180483] SCSI subsystem initialized
[    0.180716] usbcore: registered new interface driver usbfs
[    0.180814] usbcore: registered new interface driver hub
[    0.190048] usbcore: registered new device driver usb
[    0.190186] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.190216] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.190242] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.191470] Linux video capture interface: v2.00
[    0.191767] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.192386] Bluetooth: Core ver 2.16
[    0.192455] NET: Registered protocol family 31
[    0.192481] Bluetooth: HCI device and connection manager initialized
[    0.192513] Bluetooth: HCI socket layer initialized
[    0.192540] Bluetooth: L2CAP socket layer initialized
[    0.192575] Bluetooth: SCO socket layer initialized
[    0.192833] Switching to clocksource arch_sys_counter
[    0.204270] FS-Cache: Loaded
[    0.204629] CacheFiles: Loaded
[    0.216767] NET: Registered protocol family 2
[    0.217099] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.217710] TCP established hash table entries: 16384 (order: 5, 131072 byte)
[    0.218003] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.218265] TCP: Hash tables configured (established 16384 bind 16384)
[    0.218294] TCP: reno registered
[    0.218317] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.218358] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.218686] NET: Registered protocol family 1
[    0.219122] RPC: Registered named UNIX socket transport module.
[    0.219157] RPC: Registered udp transport module.
[    0.219178] RPC: Registered tcp transport module.
[    0.219200] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.219713] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 countee
[    0.219856] sunxi_reg_init enter
[    0.220703] audit: initializing netlink socket (disabled)
[    0.220774] type=2000 audit(0.220:1): initialized
[    0.223275] NTFS driver 2.1.30 [Flags: R/W].
[    0.223606] fuse init (API version 7.18)
[    0.223974] msgmni has been set to 990
[    0.225455] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    0.225509] io scheduler noop registered
[    0.225530] io scheduler deadline registered
[    0.225602] io scheduler cfq registered (default)
[    0.226094] [DISP]disp_module_init
[    0.226436] cmdline,init_disp=
[    0.226478] cmdline,disp=
[    0.239133] [DISP] Fb_map_kernel_logo,line:926:Fb_map_kernel_logo failed!
[    0.254409] Console: switching to colour frame buffer device 160x45
[    0.270886] [DISP]disp_module_init finish
[    0.271246] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.271426] sw_uart_get_devinfo()1503 - uart1 has no uart_regulator.
[    0.271601] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.271775] sw_uart_get_devinfo()1503 - uart3 has no uart_regulator.
[    0.272556] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.272733] sw_uart_pm()890 - uart0 clk is already enable
[    0.272890] sw_console_setup()1233 - console setup baud 115200 parity n bitsn
[    0.383843] console [ttyS0] enabled
[    1.315856] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    1.475285] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    1.486702] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    1.498675] [drm] Initialized drm 1.1.0 20060810
[    1.512461] loop: module loaded
[    1.520609] sunxi_spi_chan_cfg()1383 - [spi-0] has no spi_regulator.
[    1.532183] sunxi_spi_chan_cfg()1383 - [spi-1] has no spi_regulator.
[    1.544286] spi spi0: master is unqueued, this is deprecated
[    1.555343] tun: Universal TUN/TAP device driver, 1.6
[    1.565327] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.577542] PPP generic driver version 2.4.2
[    1.586831] PPP BSD Compression module registered
[    1.596361] PPP Deflate Compression module registered
[    1.607177] PPP MPPE Compression module registered
[    1.616801] NET: Registered protocol family 24
[    1.625997] PPTP driver version 0.8.5
[    1.634529] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.666255] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (Er
[    1.679691] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus nu1
[    1.693302] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.720038] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.731716] hub 1-0:1.0: USB hub found
[    1.740221] hub 1-0:1.0: 1 port detected
[    1.769274] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (Er
[    1.782615] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus nu2
[    1.796015] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    1.820046] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    1.831607] hub 2-0:1.0: USB hub found
[    1.840126] hub 2-0:1.0: 1 port detected
[    1.869174] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (Er
[    1.882574] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus nu3
[    1.895992] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    1.920043] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    1.931746] hub 3-0:1.0: USB hub found
[    1.940448] hub 3-0:1.0: 1 port detected
[    1.969567] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (Er
[    1.982998] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus nu4
[    1.996399] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    2.020039] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    2.031734] hub 4-0:1.0: USB hub found
[    2.040597] hub 4-0:1.0: 1 port detected
[    2.049876] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.081420] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI)r
[    2.094616] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus nu5
[    2.107662] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.174580] hub 5-0:1.0: USB hub found
[    2.183347] hub 5-0:1.0: 1 port detected
[    2.212725] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI)r
[    2.225994] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus nu6
[    2.239187] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    2.314600] hub 6-0:1.0: USB hub found
[    2.323525] hub 6-0:1.0: 1 port detected
[    2.352923] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI)r
[    2.366245] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus nu7
[    2.379470] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    2.454601] hub 7-0:1.0: USB hub found
[    2.463486] hub 7-0:1.0: 1 port detected
[    2.492901] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI)r
[    2.506251] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus nu8
[    2.519531] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    2.594587] hub 8-0:1.0: USB hub found
[    2.603518] hub 8-0:1.0: 1 port detected
[    2.612914] Initializing USB Mass Storage driver...
[    2.623205] usbcore: registered new interface driver usb-storage
[    2.634565] USB Mass Storage support registered.
[    2.644449] usbcore: registered new interface driver ums-alauda
[    2.655810] usbcore: registered new interface driver ums-cypress
[    2.667253] usbcore: registered new interface driver ums-datafab
[    2.678563] usbcore: registered new interface driver ums_eneub6250
[    2.689987] usbcore: registered new interface driver ums-freecom
[    2.701139] usbcore: registered new interface driver ums-isd200
[    2.712214] usbcore: registered new interface driver ums-jumpshot
[    2.723376] usbcore: registered new interface driver ums-karma
[    2.734224] usbcore: registered new interface driver ums-onetouch
[    2.745259] usbcore: registered new interface driver ums-realtek
[    2.756103] usbcore: registered new interface driver ums-sddr09
[    2.766773] usbcore: registered new interface driver ums-sddr55
[    2.777404] usbcore: registered new interface driver ums-usbat
[    2.787926] usbcore: registered new interface driver usbserial
[    2.798308] usbserial: USB Serial Driver core
[    2.807015] usbcore: registered new interface driver option
[    2.817073] USB Serial support registered for GSM modem (1-port)
[    2.828282] file system registered
[    2.837672] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    2.849274] android_usb gadget: Number of LUNs=3
[    2.858322]  lun0: LUN: removable file: (no medium)
[    2.867636]  lun1: LUN: removable file: (no medium)
[    2.876815]  lun2: LUN: removable file: (no medium)
[    2.886282] android_usb gadget: android_usb ready
[    2.896080] mousedev: PS/2 mouse device common for all mice
[    2.907038] ls_fetch_sysconfig_para: ls_unused.
[    2.916230] [RTC] WARNING: Rtc time will be wrong!!
[    2.925318] [RTC] WARNING: use *internal OSC* as clock source
[    2.935632] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    2.946778] i2c /dev entries driver
[    2.954889] IR RC5(x) protocol handler initialized
[    2.964140] tscdev_init: tsc driver is disabled
[    2.973256] Driver for 1-wire Dallas network protocol.
[    2.982774] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    2.993639] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->stt
[    3.012616] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    3.023940] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    3.034161] timeout_to_interv, line 167
[    3.034169] interv_to_timeout, line 189
[    3.034178] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual tc
[    3.063822] device-mapper: uevent: version 1.0.3
[    3.073337] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-m
[    3.087017] Bluetooth: HCI UART driver ver 2.2
[    3.096238] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failedq
[    3.112406] no red_led, ignore it!
[    3.122651] usbcore: registered new interface driver usbhid
[    3.133284] usbhid: USB HID core driver
[    3.143427] script_get_item audio_pa_ctrl not found
[    3.157202] asoc: sndcodec <-> sunxi-codec mapping ok
[    3.172762] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.184718] oprofile: using arm/armv7-ca7
[    3.194094] u32 classifier
[    3.201807]     Actions configured
[    3.210347] Netfilter messages via NETLINK v0.30.
[    3.220488] nf_conntrack version 0.5.0 (7922 buckets, 31688 max)
[    3.227832] mmc0: new high speed SDHC card at address aaaa
[    3.228355] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    3.229753]  mmcblk0: p1 p2
[    3.230656] *******************sd init ok*******************
[    3.273288] ctnetlink v0.93: registering with nfnetlink.
[    3.283615] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.295734] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.306901] xt_time: kernel timezone is -0000
[    3.316236] IPv4 over IPv4 tunneling driver
[    3.325675] gre: GRE over IPv4 demultiplexor driver
[    3.335421] ip_gre: GRE over IPv4 tunneling driver
[    3.345792] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.356380] arp_tables: (C) 2002 David S. Miller
[    3.366022] TCP: cubic registered
[    3.374103] Initializing XFRM netlink socket
[    3.383436] NET: Registered protocol family 10
[    3.393954] Mobile IPv6
[    3.401102] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.411691] IPv6 over IPv4 tunneling driver
[    3.421822] NET: Registered protocol family 17
[    3.431152] NET: Registered protocol family 15
[    3.440574] Bluetooth: RFCOMM TTY layer initialized
[    3.450300] Bluetooth: RFCOMM socket layer initialized
[    3.460243] Bluetooth: RFCOMM ver 1.11
[    3.468433] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    3.478252] Bluetooth: BNEP filters: protocol multicast
[    3.487940] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.498480] L2TP core driver, V2.0
[    3.506161] PPPoL2TP kernel driver, V2.0
[    3.514329] L2TP IP encapsulation support (L2TPv3)
[    3.523493] L2TP netlink interface
[    3.531006] L2TP ethernet pseudowire support (L2TPv3)
[    3.540489] VFP support v0.3: implementor 41 architecture 2 part 30 variant 5
[    3.552710] ThumbEE CPU extension supported.
[    3.561076] Registering SWP/SWPB emulation handler
[    3.571691] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:00:08)
[    3.584757] ths_fetch_sysconfig_para: type err  device_used = 1.
[    3.597001] CPU Budget:Register notifier
[    3.605423] CPU Budget:register Success
[    3.613661] sunxi-budget-cooling sunxi-budget-cooling: Cooling device regist0
[    3.631146] ALSA device list:
[    3.638605]   #0: audiocodec
[    3.645930]   #1: sndhdmi
[    3.717300] EXT4-fs (mmcblk0p2): recovery complete
[    3.728239] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. )
[    3.741505] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    3.752353] Freeing init memory: 316K
[    3.988420] systemd[1]: Failed to insert module 'kdbus': Function not implemd
[    4.340147] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[    4.500524] systemd[1]: systemd 225 running in system mode. (+PAM +AUDIT +SE)
[    4.542484] systemd[1]: Detected architecture arm.
[    4.593550] systemd[1]: Set hostname to <FriendlyARM>.
[    4.871569] systemd[1]: display-manager.service: Cannot add dependency job, .
[    4.895061] systemd[1]: Created slice Root Slice.
[    4.909963] systemd[1]: Reached target Encrypted Volumes.
[    4.925902] systemd[1]: Listening on Journal Audit Socket.
[    4.941854] systemd[1]: Listening on Journal Socket.
[    4.957016] systemd[1]: Reached target Remote File Systems (Pre).
[    4.973866] systemd[1]: Started Dispatch Password Requests to Console Direct.
[    4.993179] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.011617] systemd[1]: Listening on udev Kernel Socket.
[    5.028258] systemd[1]: Started Forward Password Requests to Wall Directory .
[    5.047578] systemd[1]: Reached target Paths.
[    5.063424] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.081072] systemd[1]: Listening on udev Control Socket.
[    5.098465] systemd[1]: Created slice User and Session Slice.
[    5.116253] systemd[1]: Created slice System Slice.
[    5.132931] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.231084] systemd[1]: Starting Journal Service...
[    5.431091] systemd[1]: Starting udev Coldplug all Devices...
[    5.620866] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.641922] systemd[1]: Reached target Slices.
[    5.770703] systemd[1]: Starting Create list of required static device nodes.
[    5.870908] systemd[1]: Starting Load Kernel Modules...
[    5.980450] systemd[1]: Mounting Debug File System...
[    6.030554] systemd[1]: Created slice system-getty.slice.
[    6.049439] systemd[1]: Reached target Swap.
[    6.079183] systemd[1]: Mounted Debug File System.
[    6.097833] systemd[1]: Started Journal Service.
[    6.750143] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[    9.170140] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   11.580131] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   13.990118] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   16.400108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   18.810128] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   21.220130] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   23.630132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   26.040132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   28.450131] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   30.860108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   33.270132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   35.680116] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   38.090165] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   40.500067] hub 1-0:1.0: connect-debounce failed, port 1 disabled
Ubuntu 15.10 FriendlyARM ttyS0
FriendlyARM login: [   42.910140] hub 1-0:1.0: connect-debounce failed, port 1 d
[   45.320119] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   47.730130] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   50.140158] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   52.550105] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   54.960121] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   57.370130] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   59.780129] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   62.190132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   64.600104] hub 1-0:1.0: connect-debounce failed, port 1 disabled
The very same NEO starting Armbian 5.14 for OPi One the first time:
U-Boot SPL 2016.05-armbian (Jun 23 2016 - 09:03:24)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2016.05-armbian (Jun 23 2016 - 09:03:24 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi One
DRAM:  512 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
Scanning mmc 0:1...
2465 bytes read in 182 ms (12.7 KiB/s)
   Warning: value of pin is still 0
0 bytes read in 131 ms (0 Bytes/s)
35908 bytes read in 506 ms (68.4 KiB/s)
3136501 bytes read in 3213 ms (953.1 KiB/s)
5011808 bytes read in 5077 ms (963.9 KiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x4c7960 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Data Size:    3136437 Bytes = 3 MiB
Starting kernel ...
        Start:  0x40000000
[    0.000000] Linux version 3.4.112-sun8i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) )6
[    0.000000] PERCPU: Embedded 8 pages/cpu @c0fed000 s11968 r8192 d12608 u32768
[    0.000000] Kernel command line: console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgr7
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 338944k/338944k available, 185344k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc095326c   (9517 kB)
[    0.000000]       .init : 0xc0954000 - 0xc09a5ec0   ( 328 kB)
[    0.000000]       .data : 0xc09a6000 - 0xc0a1f4d0   ( 486 kB)
[    0.000000]        .bss : 0xc0a1fc84 - 0xc0b5a910   (1260 kB)
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] console [tty1] enabled
[    0.001049] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=240000)
[    0.001117] pid_max: default: 32768 minimum: 301
[    0.001469] Mount-cache hash table entries: 512
[    0.002463] Initializing cgroup subsys cpuacct
[    0.002503] Initializing cgroup subsys memory
[    0.002569] Initializing cgroup subsys devices
[    0.002602] Initializing cgroup subsys freezer
[    0.002634] Initializing cgroup subsys blkio
[    0.002679] Initializing cgroup subsys perf_event
[    0.002786] CPU: Testing write buffer coherency: ok
[    0.002863] ftrace: allocating 25613 entries in 76 pages
[    0.030307] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.030353] [sunxi_smp_prepare_cpus] enter
[    0.030404] Setting up static identity map for 0x4068c118 - 0x4068c170
[    0.031401] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.031534] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.040488] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.040609] Brought up 4 CPUs
[    0.040609] SMP: Total of 4 processors activated (19200.00 BogoMIPS).
[    0.040991] devtmpfs: initialized
[    0.050837] wakeup src cnt is : 2.
[    0.050930] sunxi pm init
[    0.051080] pinctrl core: initialized pinctrl subsystem
[    0.057522] NET: Registered protocol family 16
[    0.058512] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.058512] script_sysfs_init success
[    0.058512] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl
[    0.058512] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.058512] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.058512] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.058512] script config pll_video to 297 Mhz
[    0.058512] script config pll_de to 864 Mhz
[    0.058512] script config pll_ve to 402 Mhz
[    0.063416] bio: create slab <bio-0> at 0
[    0.070106] [ARISC] :sunxi-arisc driver v1.04
[    0.087678] [ARISC] :arisc version: [v0.1.58]
[    0.174485] [ARISC] :sunxi-arisc driver v1.04 startup succeeded
[    0.176092] SCSI subsystem initialized
[    0.176092] usbcore: registered new interface driver usbfs
[    0.176092] usbcore: registered new interface driver hub
[    0.176092] usbcore: registered new device driver usb
[    0.176092] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[    0.176092] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[    0.176092] twi_chan_cfg()340 - [twi2] has no twi_regulator.
[    0.176092] Linux video capture interface: v2.00
[    0.176092] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.176092] cfg80211: Calling CRDA to update world regulatory domain
[    0.176092] Switching to clocksource arch_sys_counter
[    0.194124] FS-Cache: Loaded
[    0.194441] CacheFiles: Loaded
[    0.205860] NET: Registered protocol family 2
[    0.217239] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.217819] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.218090] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    0.218383] TCP: Hash tables configured (established 16384 bind 16384)
[    0.218410] TCP: reno registered
[    0.218432] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.218473] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.218816] NET: Registered protocol family 1
[    0.219225] RPC: Registered named UNIX socket transport module.
[    0.219256] RPC: Registered udp transport module.
[    0.219277] RPC: Registered tcp transport module.
[    0.219298] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.219503] Trying to unpack rootfs image as initramfs...
[    0.420268] Freeing initrd memory: 3060K
[    0.420840] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available
[    0.420993] sunxi_reg_init enter
[    0.421941] audit: initializing netlink socket (disabled)
[    0.422008] type=2000 audit(0.420:1): initialized
[    0.423893] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.424861] NFS: Registering the id_resolver key type
[    0.425272] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.425306] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.426085] NTFS driver 2.1.30 [Flags: R/W].
[    0.426405] fuse init (API version 7.18)
[    0.427197] Btrfs loaded
[    0.427235] msgmni has been set to 987
[    0.428682] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.428730] io scheduler noop registered
[    0.428750] io scheduler deadline registered
[    0.428831] io scheduler cfq registered (default)
[    0.429257] [DISP]disp_module_init
[    0.429582] cmdline,init_disp=
[    0.429628] cmdline,disp=
[    0.438707] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed!
[    0.455134] Console: switching to colour frame buffer device 160x45
[    0.472676] [DISP]disp_module_init finish
[    0.473023] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[    0.473514] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    0.473693] sw_uart_pm()890 - uart0 clk is already enable
[    0.473858] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.585346] console [ttyS0] enabled
[    1.568892] brd: module loaded
[    1.722129] loop: module loaded
[    1.731092] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    1.743473] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
[    1.756309] spi spi0: master is unqueued, this is deprecated
[    1.768082] tun: Universal TUN/TAP device driver, 1.6
[    1.778800] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.791755] PPP generic driver version 2.4.2
[    1.801799] PPP BSD Compression module registered
[    1.812094] PPP Deflate Compression module registered
[    1.825335] PPP MPPE Compression module registered
[    1.835728] NET: Registered protocol family 24
[    1.845725] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.878168] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.892393] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    1.906741] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    1.930031] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    1.942500] hub 1-0:1.0: USB hub found
[    1.951822] hub 1-0:1.0: 1 port detected
[    1.981603] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.995705] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2
[    2.009810] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000
[    2.040049] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00
[    2.052283] hub 2-0:1.0: USB hub found
[    2.061470] hub 2-0:1.0: 1 port detected
[    2.091118] sunxi-ehci sunxi-ehci.3: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.105092] sunxi-ehci sunxi-ehci.3: new USB bus registered, assigned bus number 3
[    2.119119] sunxi-ehci sunxi-ehci.3: irq 108, io mem 0xf1c1c000
[    2.150041] sunxi-ehci sunxi-ehci.3: USB 0.0 started, EHCI 1.00
[    2.162221] hub 3-0:1.0: USB hub found
[    2.171432] hub 3-0:1.0: 1 port detected
[    2.201064] sunxi-ehci sunxi-ehci.4: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.215100] sunxi-ehci sunxi-ehci.4: new USB bus registered, assigned bus number 4
[    2.229158] sunxi-ehci sunxi-ehci.4: irq 110, io mem 0xf1c1d000
[    2.260038] sunxi-ehci sunxi-ehci.4: USB 0.0 started, EHCI 1.00
[    2.272286] hub 4-0:1.0: USB hub found
[    2.281677] hub 4-0:1.0: 1 port detected
[    2.291496] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.323550] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.337271] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 5
[    2.350880] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    2.424584] hub 5-0:1.0: USB hub found
[    2.433824] hub 5-0:1.0: 1 port detected
[    2.463501] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.477066] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 6
[    2.490583] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400
[    2.564574] hub 6-0:1.0: USB hub found
[    2.573786] hub 6-0:1.0: 1 port detected
[    2.603573] sunxi-ohci sunxi-ohci.3: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.617281] sunxi-ohci sunxi-ohci.3: new USB bus registered, assigned bus number 7
[    2.630892] sunxi-ohci sunxi-ohci.3: irq 109, io mem 0xf1c1c400
[    2.704558] hub 7-0:1.0: USB hub found
[    2.713795] hub 7-0:1.0: 1 port detected
[    2.743575] sunxi-ohci sunxi-ohci.4: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    2.757286] sunxi-ohci sunxi-ohci.4: new USB bus registered, assigned bus number 8
[    2.770920] sunxi-ohci sunxi-ohci.4: irq 111, io mem 0xf1c1d400
[    2.844521] hub 8-0:1.0: USB hub found
[    2.853807] hub 8-0:1.0: 1 port detected
[    2.863490] Initializing USB Mass Storage driver...
[    2.874112] usbcore: registered new interface driver usb-storage
[    2.885813] USB Mass Storage support registered.
[    2.896037] usbcore: registered new interface driver ums-alauda
[    2.907744] usbcore: registered new interface driver ums-cypress
[    2.919535] usbcore: registered new interface driver ums-datafab
[    2.931184] usbcore: registered new interface driver ums_eneub6250
[    2.942951] usbcore: registered new interface driver ums-freecom
[    2.954439] usbcore: registered new interface driver ums-isd200
[    2.965829] usbcore: registered new interface driver ums-jumpshot
[    2.977292] usbcore: registered new interface driver ums-karma
[    2.988445] usbcore: registered new interface driver ums-onetouch
[    2.999768] usbcore: registered new interface driver ums-realtek
[    3.011040] usbcore: registered new interface driver ums-sddr09
[    3.022004] usbcore: registered new interface driver ums-sddr55
[    3.032919] usbcore: registered new interface driver ums-usbat
[    3.044421] mousedev: PS/2 mouse device common for all mice
[    3.055126] sunxikbd_init failed.
[    3.063561] ls_fetch_sysconfig_para: type err  device_used = -1073060236.
[    3.075476] =========script_get_err============
[    3.085056] [RTC] WARNING: Rtc time will be wrong!!
[    3.094757] [RTC] WARNING: use *internal OSC* as clock source
[    3.105677] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    3.117446] i2c /dev entries driver
[    3.126047] IR RC5(x) protocol handler initialized
[    3.136246] twi_start()434 - [i2c0] START can't sendout!
[    3.146685] twi_start()434 - [i2c0] START can't sendout!
[    3.157014] twi_start()434 - [i2c0] START can't sendout!
[    3.167241] twi_start()434 - [i2c0] START can't sendout!
[    3.177433] twi_start()434 - [i2c0] START can't sendout!
[    3.187477] twi_start()434 - [i2c0] START can't sendout!
[    3.197422] twi_start()434 - [i2c0] START can't sendout!
[    3.207270] twi_start()434 - [i2c0] START can't sendout!
[    3.217011] twi_start()434 - [i2c0] START can't sendout!
[    3.226721] twi_start()434 - [i2c0] START can't sendout!
[    3.236278] twi_start()434 - [i2c0] START can't sendout!
[    3.245737] twi_start()434 - [i2c0] START can't sendout!
[    3.255107] twi_start()434 - [i2c0] START can't sendout!
[    3.264364] twi_start()434 - [i2c0] START can't sendout!
[    3.273586] twi_start()434 - [i2c0] START can't sendout!
[    3.282669] twi_start()434 - [i2c0] START can't sendout!
[    3.291654] twi_start()434 - [i2c0] START can't sendout!
[    3.300544] twi_start()434 - [i2c0] START can't sendout!
[    3.309317] twi_start()434 - [i2c0] START can't sendout!
[    3.318064] twi_start()434 - [i2c0] START can't sendout!
[    3.326728] twi_start()434 - [i2c0] START can't sendout!
[    3.335286] twi_start()434 - [i2c0] START can't sendout!
[    3.343734] twi_start()434 - [i2c0] START can't sendout!
[    3.352077] twi_start()434 - [i2c0] START can't sendout!
[    3.360411] twi_start()434 - [i2c0] START can't sendout!
[    3.368705] twi_start()434 - [i2c0] START can't sendout!
[    3.376984] twi_start()434 - [i2c0] START can't sendout!
[    3.385249] twi_start()434 - [i2c1] START can't sendout!
[    3.393500] twi_start()434 - [i2c1] START can't sendout!
[    3.401729] twi_start()434 - [i2c1] START can't sendout!
[    3.409933] twi_start()434 - [i2c1] START can't sendout!
[    3.418127] twi_start()434 - [i2c1] START can't sendout!
[    3.426301] twi_start()434 - [i2c1] START can't sendout!
[    3.434456] twi_start()434 - [i2c1] START can't sendout!
[    3.442603] twi_start()434 - [i2c1] START can't sendout!
[    3.450741] twi_start()434 - [i2c1] START can't sendout!
[    3.458759] twi_start()434 - [i2c1] START can't sendout!
[    3.466686] twi_start()434 - [i2c1] START can't sendout!
[    3.474490] twi_start()434 - [i2c1] START can't sendout!
[    3.482169] twi_start()434 - [i2c1] START can't sendout!
[    3.489750] twi_start()434 - [i2c1] START can't sendout!
[    3.497282] twi_start()434 - [i2c1] START can't sendout!
[    3.504686] twi_start()434 - [i2c1] START can't sendout!
[    3.511966] twi_start()434 - [i2c1] START can't sendout!
[    3.519147] twi_start()434 - [i2c1] START can't sendout!
[    3.526248] twi_start()434 - [i2c1] START can't sendout!
[    3.533348] twi_start()434 - [i2c1] START can't sendout!
[    3.540447] twi_start()434 - [i2c1] START can't sendout!
[    3.547531] twi_start()434 - [i2c1] START can't sendout!
[    3.554625] twi_start()434 - [i2c1] START can't sendout!
[    3.561723] twi_start()434 - [i2c1] START can't sendout!
[    3.561985] twi_start()434 - [i2c1] START can't sendout!
[    3.562244] twi_start()434 - [i2c1] START can't sendout!
[    3.562502] twi_start()434 - [i2c1] START can't sendout!
[    3.562614] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    3.562806] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    3.562968] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    3.562979] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    3.562988] timeout_to_interv, line 167
[    3.562995] interv_to_timeout, line 189
[    3.563003] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    3.648866] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[    3.660434] [cpu_freq] ERR:get cpu extremity frequency from sysconfig failed, use max_freq
[    3.677849] no blue_led, ignore it!
[    3.684383] no led_0, ignore it!
[    3.690286] no led_1, ignore it!
[    3.696166] no led_2, ignore it!
[    3.702054] no led_3, ignore it!
[    3.707934] no led_4, ignore it!
[    3.713824] no led_5, ignore it!
[    3.719715] no led_6, ignore it!
[    3.728600] no led_7, ignore it!
[    3.735074] usbcore: registered new interface driver usbhid
[    3.743551] usbhid: USB HID core driver
[    3.754255] asoc: sndcodec <-> sunxi-codec mapping ok
[    3.763184] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly!
[    3.776420] [I2S]snddaudio cannot find any using configuration for controllers, return directly!
[    3.788171] mmc0: new high speed SDHC card at address aaaa
[    3.788649] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    3.789979]  mmcblk0: p1
[    3.790528] mmcblk mmc0:aaaa: Card claimed for testing.
[    3.790539] mmc0:aaaa: SL08G 7.40 GiB
[    3.790556] *******************sd init ok*******************
[    3.837556] [DAUDIO0] driver not init,just return.
[    3.849404] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok
[    3.859681] oprofile: using arm/armv7-ca7
[    3.867613] u32 classifier
[    3.873910]     Actions configured
[    3.881188] IPv4 over IPv4 tunneling driver
[    3.889794] TCP: bic registered
[    3.896763] TCP: cubic registered
[    3.903927] TCP: westwood registered
[    3.911423] TCP: highspeed registered
[    3.919039] TCP: hybla registered
[    3.926307] TCP: htcp registered
[    3.933505] TCP: vegas registered
[    3.940836] TCP: veno registered
[    3.948084] TCP: scalable registered
[    3.955772] TCP: lp registered
[    3.962811] TCP: yeah registered
[    3.969910] TCP: illinois registered
[    3.977302] Initializing XFRM netlink socket
[    3.985641] NET: Registered protocol family 10
[    3.994999] NET: Registered protocol family 17
[    4.003353] NET: Registered protocol family 15
[    4.011580] Registering the dns_resolver key type
[    4.020376] VFP support v0.3: ehci_irq: highspeed device connect
[    4.030210] ThumbEE CPU extension supported.
[    4.038007] Registering SWP/SWPB emulation handler
[    4.046976] registered taskstats version 1
[    4.055111] cmdline,disp=
[    4.092224] ths_fetch_sysconfig_para: type err  device_used = 1.
[    4.103595] CPU Budget:corekeeper enabled
[    4.111650] CPU Budget:Register notifier
[    4.119399] CPU Budget:register Success
[    4.127088] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0
[    4.143667] ALSA device list:
[    4.150637]   #0: audiocodec
[    4.157382]   #1: sndhdmi
[    4.164454] Freeing init memory: 324K
[    4.421726] vmouse_input_dev_open
[    4.480161] vmouse_input_dev_close
[    4.600063] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[    4.700070] [DISP] disp_device_attached_and_enable,line:159:ehci_irq: highspeed device connect
[    7.010152] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[    9.420125] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   11.830124] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   14.240108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   16.650123] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   19.060131] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   21.470106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   23.880106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   26.290124] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   28.700106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   31.110119] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   33.520098] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   35.930122] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   38.340107] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   40.750124] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   43.160123] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   45.570109] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   47.980127] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   50.390105] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   52.800106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   55.210108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   57.620111] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   60.030135] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   62.440105] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   64.850106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   67.260128] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   69.670125] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   72.080153] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   74.490107] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   76.900121] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   79.310106] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   79.716379] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
[   80.178550] systemd[1]: System time before build time, advancing clock.
[   80.790524] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +)
[   80.824725] systemd[1]: Detected architecture arm.
[   80.866764] systemd[1]: Set hostname to <orangepione>.
[   81.238876] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   81.256578] systemd[1]: Listening on udev Control Socket.
[   81.269834] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   81.286433] systemd[1]: Reached target Remote File Systems (Pre).
[   81.301669] systemd[1]: Created slice User and Session Slice.
[   81.316589] systemd[1]: Listening on udev Kernel Socket.
[   81.331480] systemd[1]: Listening on Journal Socket.
[   81.346112] systemd[1]: Reached target Remote File Systems.
[   81.361942] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   81.379989] systemd[1]: Listening on Journal Audit Socket.
[   81.396683] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   81.416196] systemd[1]: Listening on fsck to fsckd communication Socket.
[   81.435114] systemd[1]: Reached target Swap.
[   81.451676] systemd[1]: Listening on Journal Socket (/dev/log).
[   81.470217] systemd[1]: Listening on Syslog Socket.
[   81.487727] systemd[1]: Created slice System Slice.
[   81.640976] systemd[1]: Starting File System Check on Root Device...
[   81.710126] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   81.780975] systemd[1]: Starting Load Kernel Modules...
[   81.817343] systemd[1]: Reached target Slices.
[   81.990381] systemd[1]: Mounting POSIX Message Queue File System...
[   82.160848] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   82.210503] systemd[1]: Created slice system-getty.slice.
[   82.270404] systemd[1]: Mounting Debug File System...
[   82.370662] systemd[1]: Starting Restore / save the current clock...
[   82.440650] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   82.459946] systemd[1]: Reached target Encrypted Volumes.
[   82.550458] systemd[1]: Starting Nameserver information manager...
[   82.663040] systemd[1]: Mounted POSIX Message Queue File System.
[   82.681667] systemd[1]: Mounted Debug File System.
[   82.820149] systemd[1]: Started Load Kernel Modules.
[   83.000237] systemd[1]: Started Create list of required static device nodes for the current kernel.
[   83.160137] systemd[1]: Started Restore / save the current clock.
[   83.475009] systemd[1]: Time has been changed
[   83.611022] systemd[1]: Started Nameserver information manager.
[   83.780826] systemd[1]: Started File System Check Daemon to report status.
[   83.890751] systemd[1]: Starting Create Static Device Nodes in /dev...
[   84.000561] systemd[1]: Mounting FUSE Control File System...
[   84.110618] systemd[1]: Starting Apply Kernel Variables...
[   84.136680] systemd[1]: Mounted FUSE Control File System.
[   84.150128] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   86.550156] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   88.960103] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   91.370160] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   93.780134] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   96.190114] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[   98.600132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
Ubuntu 16.04 LTS orangepione ttyS0
orangepione login: [  101.010070] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  103.420168] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  105.830128] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  108.240169] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  110.650134] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  113.060190] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  115.470155] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  117.880133] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  120.290132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  122.700146] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  125.130102] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  127.540119] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  129.950137] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  132.360111] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  134.770096] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  137.180059] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  139.590111] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  142.000132] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  144.410115] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  146.820108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  149.230119] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  151.640129] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  154.060143] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  156.470114] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  158.880134] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  161.290113] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  163.700142] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  166.110120] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  168.520109] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  170.930115] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  173.340156] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  175.750114] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  178.160140] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  180.570115] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  182.980273] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  185.440129] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  187.850116] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  190.260112] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  192.670114] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  195.080099] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  197.480113] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  199.890111] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  202.300122] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  204.710104] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  207.110118] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  209.510120] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  211.910058] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  214.310048] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  216.710059] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  219.110209] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  221.510170] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  223.910151] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  226.310090] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  228.710053] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  231.110190] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  233.510128] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  235.910069] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  238.310159] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  240.740155] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  243.150134] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  245.570069] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  247.980157] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  250.390107] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  252.800108] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  255.210118] hub 1-0:1.0: connect-debounce failed, port 1 disabled
[  255.640725] sunxi_wdt_ioctl err, line 420
[  256.601553] Restarting system.
[  256.609485] Restarting Linux version 3.4.112-sun8i (root@pluton) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-16
[  256.609497]
Full debug output (a bit scary regarding ehci_irq): http://sprunge.us/SZaR (on the other NEO with my patched kernel currently doing DRAM consumption tests there is no such message -- strange)
I let the board reboot now automatically a few hours (11 reboots without any problem already passed) and wil then replace/update u-boot with 2016.07.
Edit: nothing connected to the board except Ethernet while reboot tests are running.
Yeah I am using the M1 image with modified .fex and a kernel with your patch + built in SPI LCD module.
I can't test he LCD module yet though... don't have it yet.
The serial converter I am using is a Silicon Labs  CP2102 board.it has LEDs on the TX and RX likes which may be acting as pull downs... I haven't booted it much without the serial console attached.
Also, duing my testing I have powered it from both a large USB power pack as well as my laptop's USB port with a short usb cable.
That is a bit of myth in some people's thinkings. If they were acting like that, it would means that LED is in conducting mode.
Same thing applied when LED is connected in Sink mode, it doesn't act as PullUp, otherwise it will glow ... :rolleyes:
Well, reboot is the wrong test (worked 80 times flawlessly with 2016.05 and 2016.07). I switched to issuesing 'poweroff', then waited until the board shut down, cut power and then let the board do a cold boot again.
Couldn't reproduce it any more reliably so I gave up and do some other testing now. At least I prepared u-boot settings that start H3 boards with 408 MHz DRAM clock and 480 MHz CPU. They work and I use them now to wait for the next occurence of the 'stalled in u-boot' situation since I can then measure new idle consumption in u-boot :)
Changes compared to NEO defaults:
root@armbian:/var/git/Armbian# cat userpatches/kernel/sun8i-default/0028-h3-limit-dram-clock-to-132-mhz.patch
diff --git a/drivers/devfreq/dramfreq/sunxi-ddrfreq.c b/drivers/devfreq/dramfreq/sunxi-ddrfreq.c
index c7c20b7..7581087 100755
--- a/drivers/devfreq/dramfreq/sunxi-ddrfreq.c
+++ b/drivers/devfreq/dramfreq/sunxi-ddrfreq.c
@@ -1666,7 +1666,7 @@ static __devinit int sunxi_ddrfreq_probe(struct platform_device *pdev)
 	if (sunxi_ddrfreq_min < SUNXI_DDRFREQ_MINFREQ_MIN)
 		sunxi_ddrfreq_min = sunxi_ddrfreq_max / 3;
 #elif defined(CONFIG_ARCH_SUN8IW7P1)
-	sunxi_ddrfreq_min = 408000;
+	sunxi_ddrfreq_min = 132000;
 #else
 	type = script_get_item("dram_para", "dram_tpr12", &val);
 	if (SCIRPT_ITEM_VALUE_TYPE_INT != type) {
root@armbian:/var/git/Armbian# tail -n35 userpatches/u-boot/u-boot-default/u-boot-99-add-missing-boards.patch
+CONFIG_SY8106A_VOUT1_VOLT=1100
+CONFIG_SYS_CLK_FREQ=1008000000
diff --git a/configs/FriendlyARM_NanoPi_NEO_defconfig b/configs/FriendlyARM_NanoPi_NEO_defconfig
new file mode 100644
index 0000000..83fae20
--- /dev/null
+++ b/configs/FriendlyARM_NanoPi_NEO_defconfig
@@ -0,0 +1,27 @@
+CONFIG_ARM=y
+CONFIG_ARCH_SUNXI=y
+CONFIG_MACH_SUN8I_H3=y
+CONFIG_DRAM_CLK=408
+CONFIG_DRAM_ZQ=3881979
+CONFIG_DRAM_ODT_EN=y
+# CONFIG_VIDEO is not set
+CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc"
+# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
+CONFIG_SPL=y
+CONFIG_HUSH_PARSER=y
+CONFIG_CMD_BOOTZ=y
+# CONFIG_CMD_IMLS is not set
+# CONFIG_CMD_FLASH is not set
+CONFIG_CMD_MMC=y
+# CONFIG_CMD_FPGA is not set
+CONFIG_CMD_DHCP=y
+CONFIG_CMD_MII=y
+CONFIG_CMD_PING=y
+CONFIG_CMD_EXT2=y
+CONFIG_CMD_EXT4=y
+CONFIG_CMD_FAT=y
+CONFIG_CMD_FS_GENERIC=y
+#CONFIG_SY8106A_POWER=y
+# CONFIG_USB_EHCI_HCD is not set
+CONFIG_GPIO=y
+CONFIG_SYS_CLK_FREQ=480000000
root@armbian:/var/git/Armbian/lib# git diff
diff --git a/config/boards/nanopineo.conf b/config/boards/nanopineo.conf
index 8e5c7f8..e1b4857 100644
--- a/config/boards/nanopineo.conf
+++ b/config/boards/nanopineo.conf
@@ -1,11 +1,11 @@
 # H3 quad core 256/512MB SoC Headless
 BOARD_NAME="NanoPi Neo"
 LINUXFAMILY=sun8i
-BOOTCONFIG=FriendlyARM_NanoPi_M1_defconfig
+BOOTCONFIG=FriendlyARM_NanoPi_NEO_defconfig
 MODULES="#gpio_sunxi #w1-sunxi #w1-gpio #w1-therm #sunxi-cir"
-MODULES_NEXT="brcmfmac"
+MODULES_NEXT=""
 CPUMIN=240000
-CPUMAX=1200000
+CPUMAX=912000
 CLI_TARGET="jessie:default"
 DESKTOP_TARGET="jessie:default"
 KERNEL_TARGET="default,dev"
diff --git a/config/fex/nanopineo.fex b/config/fex/nanopineo.fex
index db0037a..83daeab 100644
--- a/config/fex/nanopineo.fex
+++ b/config/fex/nanopineo.fex
@@ -106,7 +106,7 @@ pll_periph1 = 600
 pll_de = 864
 [dram_para]
-dram_clk = 432
+dram_clk = 624
 dram_type = 3
 dram_zq = 0x3b3bfb
 dram_odt_en = 1
@@ -284,7 +284,7 @@ ths_trip2_0 = 105
 cooler_count = 11
 cooler0 = "1200000 4 4294967295 0"
 cooler1 = "1008000 4 4294967295 0"
-cooler2 = "816000 4 4294967295 0"
+cooler2 = "912000 4 4294967295 0"
 cooler3 = "720000 4 4294967295 0"
 cooler4 = "648000 4 4294967295 0"
 cooler5 = "480000 4 4294967295 0"
@@ -531,7 +531,7 @@ usb_regulator_vol = 0
 usb_not_suspend = 0
 [usbc2]
-usb_used = 1
+usb_used = 0
 usb_drv_vbus_gpio =
 usb_restrict_gpio =
 usb_host_init_state = 1
@@ -541,7 +541,7 @@ usb_regulator_vol = 0
 usb_not_suspend = 0
 [usbc3]
-usb_used = 1
+usb_used = 0
 usb_drv_vbus_gpio =
 usb_restrict_gpio =
@@ -838,4 +838,4 @@ w1_used = 1
 gpio = 20
 [corekeeper]
-corekeeper_enabled = 1
+corekeeper_enabled = 0
Archive with .debs and script.bin here: sun8i-dram-downclocking.tar
