DanielRuf Posted November 24, 2020 Share Posted November 24, 2020 Hi guys, I installed the latest Armbian (Buster) release for my Odroid HC4 and - after getting rid of Petitboot as that just wouldn't let me boot the image - it's working great so far. Only big problem I have is that it does not recognize any SATA devices, in neither of the two slots. I tried different HDDs / SSDs that I verified are recognized on a Windows PC and another Ubuntu PC. Did anyone get that working already? I assume the required Kernel drivers for the PCIe-Sata-chip are probably still missing. Many thanks and best regards Daniel 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted November 25, 2020 Author Share Posted November 25, 2020 Sorry, I forgot to attach my Armbianmonitor log: http://ix.io/2FlU 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted November 25, 2020 Share Posted November 25, 2020 20:17:03: 2100MHz 3.04 57% 28% 15% 0% 12% 1% 40.7°C 0/13 20:17:04: 2100MHz 3.04 52% 31% 12% 1% 4% 1% 41.5°C 0/13 20:17:04: 2100MHz 3.04 84% 29% 25% 1% 25% 2% 40.7°C 0/13 20:17:04: 2100MHz 3.04 82% 13% 20% 0% 46% 1% 40.8°C 0/13 20:17:05: 2100MHz 3.04 86% 13% 24% 0% 45% 1% 41.2°C 0/13 Could not find anything about the hard drives but something else that makes me wonder. Do you have a demanding task running that consumes 3 cores? 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted November 25, 2020 Author Share Posted November 25, 2020 Hi Werner, I didn't have the board booted up for long when creating the Log. In fact, I just booted it quickly just to create the Log so it might be post-bootup tasks. On the Board, there is nothing running except for a (quite empty) OMV install 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted November 25, 2020 Author Share Posted November 25, 2020 I did some googling and found that the SATA chipset of the HC4 seems to be quite unsuported in Linux because it apparently reports as an IDE device instead of an AHCI device. https://superuser.com/questions/363144/is-asmedia-asm1061-sata3-controller-supported-under-linux That might be part of the reason why it doesn't find a correct driver. 0 Quote Link to comment Share on other sites More sharing options...
JSchoeck Posted November 30, 2020 Share Posted November 30, 2020 @DanielRufHave you also tried it with the Ubuntu-based Focal Armbian image? Is there any chance it will behave differently? 0 Quote Link to comment Share on other sites More sharing options...
GeorgeP Posted November 30, 2020 Share Posted November 30, 2020 @DanielRuf I was thinking about getting one of these boards to put together a simple NAS for a friend but I would really need it to 'just work' - sadly I don't have the free time to tinker as much as I used to :-/ Do you know if the OEM supplied firmware (Ubuntu?) works OK? Thanks! 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted November 30, 2020 Author Share Posted November 30, 2020 vor 2 Minuten schrieb GeorgeP: @DanielRuf I was thinking about getting one of these boards to put together a simple NAS for a friend but I would really need it to 'just work' - sadly I don't have the free time to tinker as much as I used to :-/ Do you know if the OEM supplied firmware (Ubuntu?) works OK? Thanks! That was also my plan originally The original Ubuntu image should work (but OMV does not work on Ubuntu, in case you want to use that) and also the Debian image in the Odroid forum should work, which uses the stock Odroid Kernel. In the Odroid Board we found that apparently the 4.9-Kernel-Version of the Armbian image should also work, which I will try this evening. For reference, see https://forum.odroid.com/viewtopic.php?f=207&t=41019 0 Quote Link to comment Share on other sites More sharing options...
GeorgeP Posted November 30, 2020 Share Posted November 30, 2020 2 hours ago, DanielRuf said: That was also my plan originally The original Ubuntu image should work (but OMV does not work on Ubuntu, in case you want to use that) and also the Debian image in the Odroid forum should work, which uses the stock Odroid Kernel. In the Odroid Board we found that apparently the 4.9-Kernel-Version of the Armbian image should also work, which I will try this evening. For reference, see https://forum.odroid.com/viewtopic.php?f=207&t=41019 Thanks for the reply. I don't need OMV and I have no real need for a 'bleeding edge' kernel. so I think I will probably get one of the boards and go for Armbian with the 4.9 kernel. What's the stuff about "getting rid of petitboot"? - Don't the Odroid boards boot direct from SD? 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted November 30, 2020 Author Share Posted November 30, 2020 vor 2 Stunden schrieb GeorgeP: Thanks for the reply. I don't need OMV and I have no real need for a 'bleeding edge' kernel. so I think I will probably get one of the boards and go for Armbian with the 4.9 kernel. What's the stuff about "getting rid of petitboot"? - Don't the Odroid boards boot direct from SD? Well, at least for me that didn't work at all. I couldn't for the life of me get any other image than the Official Ubuntu Image with Petitboot installed on the eMMC (thats the stock bootloader of the HC4 that lets you select boot device, do network boot etc) Armbian didnt work, Meverick's Debian image also didn't. Just a black screen wih nothing happening after the Petitboot Boot-Timer. (In the Odroid forum, many users have the same problem) When I skipped Petitboot by removing it with flash_eraseall /dev/mtd0 from within the petitboot console, it worked flawlessly. That just boots the SD card image directly. Don't worry, you can restore Petitboot anytime by flashing it again via SD image, 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted December 1, 2020 Share Posted December 1, 2020 Perhaps this will fix SATA https://github.com/armbian/build/commit/d5171276a919ad663650920097c0ae3facbaec7c 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted December 1, 2020 Author Share Posted December 1, 2020 I will try to build an image from trunk this evening and will give feedback on if that's working 2 Quote Link to comment Share on other sites More sharing options...
JSchoeck Posted December 2, 2020 Share Posted December 2, 2020 Am 1.12.2020 um 09:24 schrieb DanielRuf: I will try to build an image from trunk this evening and will give feedback on if that's working Daniel did you have any success with the Armbian images by now? I'm also quite keen on keeping Petitboot on the HC4, but since you deleted it I guess that's your path and you're not trying to handle the boot situation in another way. 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted December 2, 2020 Author Share Posted December 2, 2020 vor 2 Minuten schrieb JSchoeck: Daniel did you have any success with the Armbian images by now? I'm also quite keen on keeping Petitboot on the HC4, but since you deleted it I guess that's your path and you're not trying to handle the boot situation in another way. Didn't have time to try the image yesterday, but planned it for today. Personally, I also didn't like the idea of removing Petitboot - but I just couldn't get it working another way. Updated Petitboot, tried the suggestions in the Odroid forum: Other monitor, other PSU.. No luck. 0 Quote Link to comment Share on other sites More sharing options...
DanielRuf Posted December 3, 2020 Author Share Posted December 3, 2020 Hi all, tried today’s nightly build today and it actually fixed it. Thanks! 3 Quote Link to comment Share on other sites More sharing options...
Solution Igor Posted December 3, 2020 Solution Share Posted December 3, 2020 1 hour ago, DanielRuf said: tried today’s nightly build today and it actually fixed it. Great news! Thank you for trying. I will update images ASAP. 1 Quote Link to comment Share on other sites More sharing options...
