On 2/5/2021 at 11:20 PM, JMCC said:
Probably some Kernel patches being used in LibreELEC. I am not sure whether they updated to mainline yet, or are still using legacy, check that out too.
The image I tried, which is still current, as far as I can see, uses 4.4.154, so they don't seem to have switched to mainline yet.  As far as I can see though all components necessary for video playback are SoC-specific.  Since I understand that the Legacy Multimedia Framework does support HDR playback on the RK3399, but, as it turns out, not on the Rock Pi 4B, I'd expect the reason to be something specific to the configuration of that board.  If some specific patch was necessary for the VOP, HDMI, or DRM drivers say, wouldn't that prevent playback on all RK3399-based machines?
That's why I was looking at the .dts files specific to the Rock Pi 4B, comparing with other RK3399 boards and with the libreelec versions.  Do you by any chance see any error messages in my kernel logs that aren't there in your case, to use as clues to direct my search?  Or perhaps any messages that seem to be missing?  Compared to the libreelec logs, the main differences are the lines about the various supply properties that failed to be looked up, which are there in my logs but not in libreelec and also output like the following, which is there in libreelec, seemingly after every mode change, but missing for me:
[   86.448357] dwhdmi-rockchip ff940000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[   86.448384] dwhdmi-rockchip ff940000.hdmi:     colorspace: YCbCr 4:2:2
[   86.448401] dwhdmi-rockchip ff940000.hdmi:     scan mode: Underscan
[   86.448418] dwhdmi-rockchip ff940000.hdmi:     colorimetry: Extended
[   86.448433] dwhdmi-rockchip ff940000.hdmi:     picture aspect: No Data
[   86.448448] dwhdmi-rockchip ff940000.hdmi:     active aspect: Same as Picture
[   86.448462] dwhdmi-rockchip ff940000.hdmi:     itc: IT Content
[   86.448476] dwhdmi-rockchip ff940000.hdmi:     extended colorimetry: BT.2020
[   86.448490] dwhdmi-rockchip ff940000.hdmi:     quantization range: Limited
[   86.448505] dwhdmi-rockchip ff940000.hdmi:     nups: Unknown Non-uniform Scaling
[   86.448519] dwhdmi-rockchip ff940000.hdmi:     video code: 0
[   86.448534] dwhdmi-rockchip ff940000.hdmi:     ycc quantization range: Limited
[   86.448548] dwhdmi-rockchip ff940000.hdmi:     hdmi content type: Graphics
[   86.448562] dwhdmi-rockchip ff940000.hdmi:     pixel repeat: 0
[   86.448578] dwhdmi-rockchip ff940000.hdmi:     bar top 0, bottom 0, left 0, right 0
[   86.448608] dwhdmi-rockchip ff940000.hdmi: HDMI infoframe: Vendor, version 1, length 5
[   86.448623] dwhdmi-rockchip ff940000.hdmi:     HDMI VIC: 3
[   86.448649] dwhdmi-rockchip ff940000.hdmi: HDMI infoframe: Dynamic Range and Mastering, version 1, length 26
[   86.448664] dwhdmi-rockchip ff940000.hdmi: length: 26
[   86.448677] dwhdmi-rockchip ff940000.hdmi: eotf: 2
[   86.448692] dwhdmi-rockchip ff940000.hdmi: x[0]: 34000
[   86.448706] dwhdmi-rockchip ff940000.hdmi: y[0]: 16000
[   86.448720] dwhdmi-rockchip ff940000.hdmi: x[1]: 13250
[   86.448734] dwhdmi-rockchip ff940000.hdmi: y[1]: 34500
[   86.448747] dwhdmi-rockchip ff940000.hdmi: x[2]: 7500
[   86.448761] dwhdmi-rockchip ff940000.hdmi: y[2]: 3000
[   86.448774] dwhdmi-rockchip ff940000.hdmi: white point x: 15635
[   86.448788] dwhdmi-rockchip ff940000.hdmi: white point y: 16450
[   86.448802] dwhdmi-rockchip ff940000.hdmi: max_mastering_display_luminance: 4000
[   86.448817] dwhdmi-rockchip ff940000.hdmi: min_mastering_display_luminance: 50
[   86.448830] dwhdmi-rockchip ff940000.hdmi: max_cll: 457
[   86.448844] dwhdmi-rockchip ff940000.hdmi: max_fall: 179
Since this mentions HDR mastering specs, it seems to be highly relevant, but I can't figure out why I'm not receiving this infoframes (or if perhaps I'm receiving them, but they aren't printed out).
LE master branch and thus nightly images are using mainline kernel for a long time. But yes, download page will give you LE 9 based images, which are 4.4 based. LE10 is not that far away.
Well, the framework can play HEVC 10-bit HDR content, but I don't know if it can switch the display to HDR, since I don't have such a display to test :(. The user cooperation as testers is necessary for that, I appreciate your getting involved with that.
For the time being, can you send me a link to some HDR content that is causing playback trouble? So far, all the materials I tested worked fine, and I tried even 160 Mbps videos.
Can you also make some other test? Simply do
apt install librockchip-mpp1=1.4.0-1
And then try again to play your HDR content.
[EDIT]: And please try all three available players: mpv in command line,  Rockchip GST player, and Kodi.
On 1/6/2021 at 4:53 PM, TheGuv said:
I'm trying this on my Helios64 RK3399 system but I'm getting severe glitches and missing 'tiles', many long pauses and freezes in the desktop and a bunch of GPU errors and soft resets in the logs
I noticed there has been quite a few updates recently which I have applied, but sadly the Mali errors, glitches and pauses continue for me.  ¯\_(ツ)_/¯
Hello
i modified armbian build  script to get board images with 32bit userland and 64bit kernel.
most time i´m using the rockpi4b board.  because of the 32bit userland i only get the armhf package (tinkerboard) but they only suppoert t76x mali .
is there a way you can provide a t86x package for the 32bit userland?! or how can i make it myself?
18 minutes ago, verplant23 said:
quite short answer
As I said, you can download the deb from the rockchip-linux github. The repo name is rk-rootfs-build, IIRC.
19 minutes ago, verplant23 said:
some guidance you can give?
Download the deb and install it :)
20 minutes ago, verplant23 said:
no special magic u use ?
The info about the sources for my packages are in the first post.
Ah, I see.  In that case looking into missing patches is indeed the way to go.  The patches for the legacy librelec image I found to be wokring are here
https://github.com/LibreELEC/LibreELEC.tv/tree/libreelec-9.2/projects/Rockchip/patches
and the libdrm patch seems to be particularly interesting.  I'll see if it's missing from our version and try to apply it.
I'm very happy to hear (well read anyway) that, as I was worried I was being a bother.
Ah, this proved trickier that expected.  While looking for easily sharable content that exhibited the same problems, I found that most demo content I tried seemed, in fact, to work "mostly ok".  By mostly ok, I mean that while it did not switch the display to HDR, it did in fact play smoothly and with correct (albeit SDR, so correctly tonemapped) colors.  I tried all HDR trailers from here
https://www.demolandia.net/4k-video-test/hdr10.html
as well as a couple of HDR trailers from here
http://thedigitaltheater.com/dolby-trailers/
which were Dolby Vision and wouldn't have played in HDR on my display anyway, I suppose.  All of these played back smoothly in SDR.
Then I though perhaps the issue had to do with the aspect ratio, as the problematic content was generally 1600p and perhaps that had something to do with it, so I downloaded an HDR movie trailer from YouTube, which uses VP9.  This didn't play at all and in fact swamped the kernel logs with messages, but let's leave that for later.  I then converted it to HEVC HDR10 with
ffmpeg -i vp9.webm -c:a copy -c:v libx265 -tag:v hvc1 -crf 22 -pix_fmt yuv420p10le -x265-params "colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc" hdr10.mkv
and it also played "mostly ok".  Now, this video, according to ffprobe, is the same as one of the videos that plays back choppily.  Both are
Video: hevc (Main 10), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x1600 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
so I can only assume that the choppiness, is due to the larger size or something like this.   I therefore think that the the best course of action, would be to concentrate on getting the display to switch to HDR, and see if that also fixes the problematic content.  If it doesn't, we can investigate further from there.
This didn't make any difference, as far as I could see.
Playing with "mpv --gpu-context=drm" seems to result in SW decoding for all videos I've tried.  It displays correct frames in SDR, albeit slowly and hogging all the CPU.  These lines of output seem suspicious:
[vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device
[vo/gpu/opengl] Failed to set up VT switcher. Terminal switching will be unavailable.
[vo/gpu/opengl] Cannot open render node "/dev/dri/renderD128": Permission denied. VAAPI hwdec will be disabled
Running with sudo makes the last message go away, but doesn't change much.
Playing with "gst-play-1.0 --videosink=kmssink" seems to be the same as with kodi-gbm: smooth, HW decoded, SDR.  Excuse the long post, but this is a bit convoluted and I wanted to be as precise as possible.  I'll report back if I manage to find out anything more.
It shouldn't be like that. Can you post the full mpv output?
And also, the output of
cat /etc/mpv/mpv.conf
There was no "/etc/mpv/mpv.conf".  As far as I know there never was, unless I somehow deleted it inadvertently.  There was a "/etc/mpv/mpv-dist.conf" though and after "cp /etc/mpv/mpv-dist.conf /etc/mpv/mpv.conf" mpv did in fact run with HW decoding.  Console output follows:
LIBGL: Initialising gl4es
LIBGL: v1.1.5 built on Dec 22 2020 23:27:36
LIBGL: Using GLES 2.0 backend
LIBGL: loaded: libGLESv2.so
LIBGL: loaded: libEGL.so
LIBGL: loaded: libgbm.so
LIBGL: loaded: libdrm.so.2
LIBGL: Error while gathering supported extension (eglInitialize: EGL_NOT_INITIALIZED), default to none
LIBGL: Targeting OpenGL 2.1
LIBGL: WARNING, No Limited or Full NPOT support in hardware, Forcing NPOT have no effect!
LIBGL: Not trying to batch small subsequent glDrawXXXX
LIBGL: try to use VBO
LIBGL: Force texture for Attachment color0 on FBO
LIBGL: Hack to trigger a SwapBuffers when a Full Framebuffer Blit on default FBO is done
LIBGL: glX Will try to recycle EGL Surface
LIBGL: Current folder is:/home/pi
 (+) Video --vid=1 (*) (hevc 3840x2160 29.970fps)
[vaapi] libva: va_getDriverName() failed with unknown libva error,driver_name=(null)
mpi: mpp version: 11d98147 author: JMCC Import changes from fork Kwiboo/mpp, branch libreelec-hdr, and version bump
mpp_rt: NOT found ion allocator
mpp_rt: found drm allocator
mpp: deprecated block control, use timeout control instead
H265D_PARSER: No start code is found.
Using hardware decoding (rkmpp).
VO: [gpu] 3840x2160 drm_prime
[vo/gpu] Using HW-overlay mode. No GL filtering is performed on the video!
V: 00:00:04 / 00:00:30 (15%) Dropped: 9
Exiting... (Quit)
LIBGL: Shuting down
Playback was smooth, in terms of framerate, but there were (random, not constant) black lines/bands in the output and the whole image "shook" vertically, almost as if every 50 scanlines say, a band of 4-5 was shifted a random amount downwards each frame (or perhaps scaled vertically for a similar but more symmetric effect).
[Edit]: forgot to mention that the libdrm patches seem to be included in the repository you mention as your source, so that takes care of the low-hanging fruit.  The other patches concern the kernel, which is a different version (4.4.154 vs 4.4.213) than that used in Armbian and also seem to address other stuff, besides video, which means that they'll probably require some cherry-picking and/or modification prior to application and I'll also have to set up a kernel building environment.  Before I enter that world of pain, let me ask you:  do you think that efforts would perhaps be better spent trying to get the mainline kernel working, or is that still a long way away?
Edited by dpapavas
Yes, those patches are included in my repo. They only affect the headers, so are only meaningful during the compilation process, not on runtime.
Well, the Armbian build script already does that for you, doesn't it? ;)
I'm ot sure what you mean with "getting the mainline kernel working".  If what you mean is keeping up-to date the VPU patches, well, that is fairly well taken care of by the main RK kernel maintainers at Armbian
In any case, I think your best efforts can be focused on figuring out what are the bits that LibreELEC is using to switch the display to HDR mode. It can be some kodi patch, not necessarily a kernel modification. Or even more simple, some default kodi setting without any modification to the code. I would start there, exploring all the Kodi settings and see if you find something that can be changed to enable HDR.
I never said it didn't, but one still has to read up on how it works, how to get it to compile just the kernel, after applying patches, how to use that kernel and handle unbootable systems etc.;  that sort of thing.  I'm very new to Armbian. :)
I meant that, since you're currently working on getting the Media Framework to work based on the mainline kernel and asssuming that this HDR issue is, at least in part, due to something missing from the kernel, whether it might be better to troubleshoot this in the mainline version of the Media Framework.  But read also below.
I sort of managed to do the reverse: find a libreelec setting that makes HDR output not work and exhibits the same behavior I get on Armbian.  As far as I can see, librelec for rockchip devices doesn't apply any KODI patches (although there is this).  I'm not sure if that means that the plain/unmodified source is used for KODI, or whether some patches are applied regardless of board, but on librelec, KODI has an extra option that lets you select the "HDMI output format".  This essentially sets the color space to RGB or YCbCr (4:2:2 or 4:4:4 ).  The display only switches to HDR with the (default) YCbCr mode, not with RGB.
The Media Framework version of KODI is missing that option.  In fact I haven't found any reference to it, outside of libreelec.  Output seems to default to RGB colorspace, as can be seen with:
$ sudo cat /sys/kernel/debug/dw-hdmi/status
PHY: enabled            Mode: HDMI
Pixel Clk: 148500000Hz        TMDS Clk: 148500000Hz
Color Format: RGB        Color Depth: 8 bit
Colorimetry: ITU.BT709        EOTF: Off
In contranst in librelec, I get something like:
# cat /sys/kernel/debug/dw-hdmi/status
Pixel Clk: 594000000Hz        TMDS Clk: 148500000Hz
Color Format: YUV444        Color Depth: 8 bit
I'm not sure of course, that getting KODI to switch to a YUV HDMI output mode will be enough to make the display switch to HDR, but it seems worth trying, especially since it should be easier than semi-blindly applying kernel patches.  That said, I can't seem to find much info on how to do so.  Let me know if you have any insight to share.
First: Can you send a screenshot of the option?
Second: I don't know if you said what board are you using. In any case, can you also post the output of "sudo armbianmonitor -u"
Third, I found these two LibreELEC kernel patches in master branch to be related to YCbCr:
projects/Rockchip/patches/linux/default/linux-0021-drm-from-list.patch
projects/Rockchip/patches/linux/default/linux-1001-drm-rockchip.patch
In the 9.2 branch, there is this one:
projects/Rockchip/patches/linux/rockchip-4.4/linux-0001-rockchip.patch
This is just from a "grep -rli ycbcr" on the sources. It will need further investigation.
Not sure if I can somehow attach it here (I see references to such functionality, but can't find it.)  Anyway see here.  This option is in the "Video Player" section and affects the color space used for video playback.  There's an identical one in the Display tab of the System settings, which controls the color space used in the GUI (and for games and such).  Read also below for more information.
I'm using a Rock Pi 4B.  See here for the output (which seems to be repeated 6 times for some reason).
Thanks for looking into it!  I think the master branch is built against the mainline kernel so patches from it are probably not applicable.  The patches from the 9.2 are applicable and as far as I've seen, most of the changes in the patch you mentioned are missing from the Armbian kernel.  A cursory look though, gave me the impression that they're mostly optimizations rather than fixes.  For instance the change you found forces  YCbCr mode under certain conditions (having to do with the current setting of the TMDS clock) and, while this may be useful, it woudln't allow choosing the color space yourself.  (Note: I have a hunch though that some of the changes in that patch, perhaps those augmenting the HDMI phy table and subsequent clocking-related changes might desirable, as I'm now fairly sure that the libreelec kernel is able to consistently connect at 4K@60, which the Armbian kenrel can't and changes such as these might be responsible for it.)
Some further research reveals the following:  The changes implementing that option seem never to have made it into upstream KODI.  As far as I could tell from the build scripts, the rockchip port of libreelec 9.2, is using this fork of KODI, which has the patch introducing the setting, as well as other HDR-related patches, that seem to be of interest.  If I manage to apply these patches onto the KODI sources you've used for your package and get HDR working, would you then be able/willing to introduce them into the package?
Sure. Just follow the instructions at the README.md. Set up an Armbian Buster image (or chroot) with enough free space on your Rockpi, and then compiling is just a copy-paste from the instructions -- well, I probably forgot to mention that you need to install ccache, IIRC. Compilation takes about an hour the first time, and shorter in subsequent runs.
If you get the patches to work, just make a PR and I will incorporate it.
@TheGuv Good news, I made some progress. I just got DP-out to work on the NanoPC T4. Now, I'll have to make a clean patch to incorporate the fix into the legacy kernel, and after that I can start to test and debug those errors you reported.
Well, I've had partial success.  First, regarding compiling KODI, I've run into a problem where compilation would fail, a bit before the end, complaining about "gbm_surface_create_with_modifiers" not being declared.  Now, as far as I an see, this is neither decalred in "/usr/include/gbm.h", as installed by the bundled "libmali-rk-dev" package, nor is the symbol contained in "/usr/lib/mali/libgbm.so".  The (immediate) reason for this failure is that CMake performs the following test to determine whether to use that call:
check_c_source_compiles("#include <gbm.h>
                         int main()
                           gbm_surface_create_with_modifiers(NULL, 0, 0, 0, NULL, 0);
                         " GBM_HAS_MODIFIERS)
This does not fail outright; it merely warns that "gbm_surface_create_with_modifiers" is implicitly declared.  (It would have failed the linking stage though, had that been tried.)  I forced this test to fail, in order to disable the offending call and it finished compilation, with a seemingly correct result, but what I don't understand, is how this could have worked for anyone, so I worry I may have done something wrong.  Have you had similar issues?
Regarding the result, after incorporating the patches, I get the missing settings (along with other needed functionality) and it sort of works.  The board insists it outputs HDR content in the correct colorspace, judging by the contents of:
sudo cat /sys/kernel/debug/dri/0/summary
The display on the other hand does not immediately switch to HDR.  It switches resolution but stays in SDR mode, until sometimes, some time later (triggered by I don't know what) it does switch to HDR.  Then it may again have trouble switching back to SDR when playback stops and it returns to the GUI, although that is more rare.  Apart from that, everything seems to match the libreelec image.  I tried installing the patched KODI version onto a fresh installation and in the fresh installation the content that used to be reproduced in false color before seems to work fine.  (The other, which stutters and hangs, exhibits the same problem in libreelec.   VP9 content also fails to play in both and only results in a flood of kernel error messages.)
Well, that's not quite true.  The Armbian image still has trouble connecting at 4K@60, which the libreelec image can consistently do.  I also get various kernel messages which don't look very confidence-inspiring, such as:
[  130.751002] dwhdmi-rockchip ff940000.hdmi: failed to get edid
[  131.371346] [drm:drm_scdc_set_scrambling] *ERROR* Failed to read tmds config, err=-11
[  131.471188] [drm:drm_scdc_set_high_tmds_clock_ratio] *ERROR* Failed to read tmds config, err=-11
[  131.579310] [drm:drm_scdc_set_high_tmds_clock_ratio] *ERROR* Failed to read tmds config, err=-11
And I also get exceptions in the VOP/DRI driver from time to time, after which resolution switching doesn't seem to work anymore.
For all of the above, I guess that kernel patches are the obvious place to look, so I won't be avoiding that after all.  If you have any advice about kernel debugging/troubleshooting, other than what's mentioned in the developer guide in docs.armbian.com, do tell.
No. I think it could be because of some pre-installed libs in your system. I always compile in a clean buster chroot , and everything goes smoothly, just copying & pasting the commands I put on the README.md.
Well, nothing special.
  • Put the patches in "userpatches/kernel/rockchip64-legacy".
  • Compile with "./compile.sh CREATE_PATCHES=yes", so it will stop after applying the patches and you can see if they worked or failed.
  • If they fail, look at the log in "output/debug/compilation.log", and see what is the problem.
I've just installed the media script on the Station P1. Video playback is 2x speed. Either in Youtube with Chromium, or with MPV and a normal video file.
Everything sounds like the chipmunks.
I also think not everything went correct with the chromium settings.
Problems are haunting me on the StationP1. :) I've been trying for a month to make a video about it and never was able to have everything working. When not filming it often worked. But when filming... Quantum mechanics are against me.
After patching the kernel, my Armbian + Legacy Media Framework image seems to work as well as librelec.  The improvement is not confined to HDR output.  I can now consistently connect at 4Kp60 resolution and many of the error messages (notably including those due to crashes within the VOP driver) are now gone.  Things are still not perfect though.  Some content still plays back with skips every few seconds, but these are played back like this on libreelec, too, so it's not as easy as picking the right patch to fix this. Looking though dmesg, you see repeated messages such as these:
[ 1781.674271] rk-vcodec ff660000.rkvdec: resetting...
[ 1781.674340] rk-vcodec ff660000.rkvdec: reset done
[ 1781.674346] rk-vcodec ff660000.rkvdec: reset done
[ 1781.906854] rk-vcodec ff660000.rkvdec: resetting...
[ 1781.906925] rk-vcodec ff660000.rkvdec: reset done
[ 1781.906931] rk-vcodec ff660000.rkvdec: reset done
[ 1782.075536] rk-vcodec ff660000.rkvdec: resetting...
[ 1782.075607] rk-vcodec ff660000.rkvdec: reset done
[ 1782.075612] rk-vcodec ff660000.rkvdec: reset done
Although to get HDR output to work, I'm pretty sure that only a single patch was necessary, I've gone ahead and selectively picked and applied patches on the basis of whether they were related to video and looked useful.  As such, some may not be welcome in a general-purpose kernel image (I can think only of one, which sets the GPU's governor from ondemand to performance) and further discussion may be necessary.  I've been using the patched versions of the kernel and KODI for a couple of days now without any problems, but I'll test them for a couple of days more before submitting PRs.
Do I understand correctly that I should open the PR for KODI on the Github repo I downloaded it from?  What about the kernel patches?
Yes, correct.
You should move them from the userpatches directory to patch/kernel/rockchip64-legacy, and then make a PR against armbian build repo. You can reference this thread in the PR description.
15 часов назад, NicoD сказал:
Select the correct audio output, either via HDMI or analog output. By default, output via DP\MPI is enabled. I can disable this channel in DTB, so that it does not interfere, but maybe someone will use it.  :)
Definitely, according to the picture, something went wrong. Can you do the installation again from scratch, and this time copy-paste the installation output? And also "armbianmonitor -u".
I've done the installation again. Again with the same outcome. Videos play 2 x too fast. If I play it in Youtube at 0.50x then the video plays fast enough, but the sound is still chipmunk.
@balbes150It's not because of the audio output. I disabled the unused ones.
I used the Buster Legacy Desktop from here : https://users.armbian.com/balbes150/firefly_station_p1/Armbian/
Here the install info :
nicod@station-p1:~$ sudo apt install media-buster-legacy-rk3399
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libavdevice58 libavfilter7 libmysofa0 libnorm1 libpgm-5.2-0 libpostproc55 libsdl2-2.0-0 libsodium23 libva-wayland2 libvidstab1.1
  libzmq5
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  fonts-liberation gstreamer1.0-rockchip1 gstreamer1.0-rockchip1-extra kodi-rk kodi-rk-bin libaacs0 libcec4 libdav1d4 libfstrcmp0
  libglew2.1 libglu1-mesa libimagequant0 libiso9660-11 liblirc-client0 libmali-rk-midgard-t86x-r14p0-r0p0 libmariadb3
  libmicrohttpd12 libp8-platform2 libpcrecpp0v5 libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediagsttools5
  libqt5multimediaquick5 libqt5multimediawidgets5 libqt5opengl5 libqt5qml5 libqt5quick5 librga2 librockchip-mpp1 librockchip-vpu0
  libshairplay0 libtinyxml2.6.2v5 mariadb-common mesa-utils mpv-legacy mysql-common python-bluez python-pil python-simplejson
  qml-module-qt-labs-folderlistmodel qml-module-qtmultimedia qml-module-qtquick2 qtgstreamer-plugins-qt5 qtmultimedia5-examples
  xserver-xorg-core-rockchip
Suggested packages:
  kodi-pvr-mythtv kodi-pvr-vuplus kodi-pvr-vdr-vnsi kodi-pvr-njoy kodi-pvr-nextpvr kodi-pvr-mediaportal-tvserver
  kodi-pvr-tvheadend-hts kodi-pvr-dvbviewer kodi-pvr-argustv kodi-pvr-iptvsimple kodi-audioencoder-vorbis kodi-audioencoder-flac
  kodi-audioencoder-lame glew-utils lirc qt5-qmltooling-plugins python-pil-doc python-pil-dbg xfonts-100dpi | xfonts-75dpi
  xfonts-scalable
Recommended packages:
  libva-intel-vaapi-driver libva1 libbdplus0 kodi-addons-full gl4es i965-va-driver | libva-intel-vaapi-driver | va-driver
  mesa-vdpau-drivers | nvidia-vdpau-driver | nvidia-driver-binary | nvidia-current | vdpau-driver python-olefile
The following packages will be REMOVED:
  mpv xserver-xorg-core
The following NEW packages will be installed:
  libshairplay0 libtinyxml2.6.2v5 mariadb-common media-buster-legacy-rk3399 mesa-utils mpv-legacy mysql-common python-bluez
  python-pil python-simplejson qml-module-qt-labs-folderlistmodel qml-module-qtmultimedia qml-module-qtquick2
  qtgstreamer-plugins-qt5 qtmultimedia5-examples xserver-xorg-core-rockchip
0 upgraded, 46 newly installed, 2 to remove and 0 not upgraded.
Need to get 71.1 MB of archives.
After this operation, 144 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://deb.debian.org/debian buster/main arm64 fonts-liberation all 1:1.07.4-9 [827 kB]
Get:2 http://deb.debian.org/debian buster/main arm64 libp8-platform2 arm64 2.1.0.1+dfsg1-2 [20.6 kB]
Get:3 http://deb.debian.org/debian buster/main arm64 libfstrcmp0 arm64 0.7.D001-1.1+b2 [8,364 B]
Get:4 http://deb.debian.org/debian buster/main arm64 libiso9660-11 arm64 2.0.0-2 [161 kB]
Get:5 http://deb.debian.org/debian buster/main arm64 liblirc-client0 arm64 0.10.1-6.2~deb10u1 [70.3 kB]
Get:6 http://deb.debian.org/debian buster/main arm64 mysql-common all 5.8+1.0.5 [7,324 B]
Get:7 http://deb.debian.org/debian buster/main arm64 mariadb-common all 1:10.3.27-0+deb10u1 [32.2 kB]
Get:8 http://deb.debian.org/debian buster/main arm64 libmariadb3 arm64 1:10.3.27-0+deb10u1 [161 kB]
Get:9 http://deb.debian.org/debian buster/main arm64 libmicrohttpd12 arm64 0.9.62-1 [91.5 kB]
Get:10 http://deb.debian.org/debian buster/main arm64 libpcrecpp0v5 arm64 2:8.39-12 [151 kB]
Get:11 http://deb.debian.org/debian buster/main arm64 libtinyxml2.6.2v5 arm64 2.6.2-4 [35.3 kB]
Get:12 http://deb.debian.org/debian buster/main arm64 libglew2.1 arm64 2.1.0-4 [160 kB]
Get:13 http://deb.debian.org/debian buster/main arm64 libglu1-mesa arm64 9.0.0-2.1+b3 [146 kB]
Get:14 http://deb.debian.org/debian buster/main arm64 mesa-utils arm64 8.4.0-1+b1 [33.4 kB]
Get:15 http://deb.debian.org/debian buster/main arm64 python-bluez arm64 0.22+really0.22-1 [55.3 kB]
Get:16 http://deb.debian.org/debian buster/main arm64 libimagequant0 arm64 2.12.2-1.1 [30.3 kB]
Get:17 http://deb.debian.org/debian buster/main arm64 python-pil arm64 5.4.1-2+deb10u2 [381 kB]
Get:18 http://deb.debian.org/debian buster/main arm64 python-simplejson arm64 3.16.0-1 [71.0 kB]
Get:19 http://deb.debian.org/debian buster-backports/main arm64 libshairplay0 arm64 0.9.0~git20180824.096b61a+dfsg1-2~bpo10+1 [99.6 kB]
Get:20 http://deb.debian.org/debian buster/main arm64 libaacs0 arm64 0.9.0-2 [48.2 kB]
Get:21 http://deb.debian.org/debian buster-backports/main arm64 libdav1d4 arm64 0.7.1-3~bpo10+1 [258 kB]
Get:22 http://deb.debian.org/debian buster/main arm64 libqt5multimedia5 arm64 5.11.3-2 [277 kB]
Get:23 http://deb.debian.org/debian buster/main arm64 libqt5opengl5 arm64 5.11.3+dfsg1-1+deb10u4 [153 kB]
Get:24 http://deb.debian.org/debian buster/main arm64 libqt5multimediawidgets5 arm64 5.11.3-2 [40.3 kB]
Get:25 http://deb.debian.org/debian buster/main arm64 libqt5multimediagsttools5 arm64 5.11.3-2 [72.4 kB]
Get:26 http://deb.debian.org/debian buster/main arm64 libqt5multimedia5-plugins arm64 5.11.3-2 [209 kB]
Get:27 http://deb.debian.org/debian buster/main arm64 libqt5qml5 arm64 5.11.3-4 [1,147 kB]
Get:28 http://deb.debian.org/debian buster/main arm64 libqt5quick5 arm64 5.11.3-4 [1,190 kB]
Get:29 http://deb.debian.org/debian buster/main arm64 libqt5multimediaquick5 arm64 5.11.3-2 [42.5 kB]
Get:30 http://deb.debian.org/debian buster/main arm64 qml-module-qt-labs-folderlistmodel arm64 5.11.3-4 [46.9 kB]
Get:31 http://deb.debian.org/debian buster/main arm64 qml-module-qtquick2 arm64 5.11.3-4 [45.6 kB]
Get:32 http://deb.debian.org/debian buster/main arm64 qml-module-qtmultimedia arm64 5.11.3-2 [87.6 kB]
Get:33 http://deb.debian.org/debian buster/main arm64 qtmultimedia5-examples arm64 5.11.3-2 [779 kB]
Get:34 http://deb.debian.org/debian buster/main arm64 qtgstreamer-plugins-qt5 arm64 1.2.0-5 [41.5 kB]
Get:35 https://mirrors.dotsrc.org/armbian-apt buster/buster-desktop arm64 libmali-rk-midgard-t86x-r14p0-r0p0 arm64 1.6-1-1armbian3 [14.3 MB]
Get:36 https://imola.armbian.com/apt buster/buster-desktop arm64 librga2 arm64 2.0.0-1 [30.1 kB]
Get:37 https://mirrors.netix.net/armbian/apt buster/buster-desktop arm64 xserver-xorg-core-rockchip arm64 2:1.20.3-3armbian1 [1,289 kB]
Get:39 https://imola.armbian.com/apt buster/buster-desktop arm64 gstreamer1.0-rockchip1 arm64 2:1.10-0armbian1 [21.1 kB]
Get:42 https://imola.armbian.com/apt buster/buster-desktop arm64 kodi-rk-bin arm64 2:18.9-final-18.9buster0armbian3 [17.3 MB]
Get:40 https://mirrors.netix.net/armbian/apt buster/buster-desktop arm64 gstreamer1.0-rockchip1-extra arm64 3:20180115-3armbian1 [221 kB]
Get:43 https://mirrors.netix.net/armbian/apt buster/buster-desktop arm64 kodi-rk all 2:18.9-final-18.9buster0armbian3 [22.7 MB]
Get:38 https://mirrors.dotsrc.org/armbian-apt buster/buster-desktop arm64 librockchip-mpp1 arm64 1.4.0-3armbian3 [366 kB]
Get:41 https://mirrors.dotsrc.org/armbian-apt buster/buster-desktop arm64 libcec4 arm64 4.0.7.1~buster [213 kB]
Get:44 https://mirrors.dotsrc.org/armbian-apt buster/buster-desktop arm64 librockchip-vpu0 arm64 1.4.0-3armbian3 [23.0 kB]
Get:45 https://imola.armbian.com/apt buster/buster-desktop arm64 mpv-legacy arm64 2:2020.12.08.df805cfc84 [7,632 kB]
Get:46 https://mirrors.netix.net/armbian/apt buster/buster-desktop arm64 media-buster-legacy-rk3399 arm64 20.11.6 [24.9 kB]
Fetched 71.1 MB in 25s (2,813 kB/s)
Extracting templates from packages: 100%
(Reading database ... 91732 files and directories currently installed.)
Removing mpv (0.29.1-1) ...
Selecting previously unselected package libmali-rk-midgard-t86x-r14p0-r0p0:arm64.
(Reading database ... 91696 files and directories currently installed.)
Preparing to unpack .../libmali-rk-midgard-t86x-r14p0-r0p0_1.6-1-1armbian3_arm64.deb ...
Unpacking libmali-rk-midgard-t86x-r14p0-r0p0:arm64 (1.6-1-1armbian3) ...
Selecting previously unselected package librga2.
Preparing to unpack .../librga2_2.0.0-1_arm64.deb ...
Unpacking librga2 (2.0.0-1) ...
dpkg: xserver-xorg-core: dependency problems, but removing anyway as you requested:
 xserver-xorg-video-fbdev depends on xorg-video-abi-24; however:
  Package xorg-video-abi-24 is not installed.
  Package xserver-xorg-core which provides xorg-video-abi-24 is to be removed.
 xserver-xorg-video-fbdev depends on xserver-xorg-core (>= 2:1.18.99.901); however:
  Package xserver-xorg-core is to be removed.
 xserver-xorg-input-libinput depends on xorg-input-abi-24; however:
  Package xorg-input-abi-24 is not installed.
  Package xserver-xorg-core which provides xorg-input-abi-24 is to be removed.
 xserver-xorg-input-libinput depends on xserver-xorg-core (>= 2:1.18.99.901); however:
 xserver-xorg depends on xserver-xorg-core (>= 2:1.17.2-2).
(Reading database ... 91747 files and directories currently installed.)
Removing xserver-xorg-core (2:1.20.4-1+deb10u2) ...
Selecting previously unselected package xserver-xorg-core-rockchip.
(Reading database ... 91711 files and directories currently installed.)
Preparing to unpack .../00-xserver-xorg-core-rockchip_2%3a1.20.3-3armbian1_arm64.deb ...
Unpacking xserver-xorg-core-rockchip (2:1.20.3-3armbian1) ...
Selecting previously unselected package fonts-liberation.
Preparing to unpack .../01-fonts-liberation_1%3a1.07.4-9_all.deb ...
Unpacking fonts-liberation (1:1.07.4-9) ...
Selecting previously unselected package librockchip-mpp1.
Preparing to unpack .../02-librockchip-mpp1_1.4.0-3armbian3_arm64.deb ...
Unpacking librockchip-mpp1 (1.4.0-3armbian3) ...
Selecting previously unselected package gstreamer1.0-rockchip1.
Preparing to unpack .../03-gstreamer1.0-rockchip1_2%3a1.10-0armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1 (2:1.10-0armbian1) ...
Selecting previously unselected package gstreamer1.0-rockchip1-extra.
Preparing to unpack .../04-gstreamer1.0-rockchip1-extra_3%3a20180115-3armbian1_arm64.deb ...
Unpacking gstreamer1.0-rockchip1-extra (3:20180115-3armbian1) ...
Selecting previously unselected package libp8-platform2:arm64.
Preparing to unpack .../05-libp8-platform2_2.1.0.1+dfsg1-2_arm64.deb ...
Unpacking libp8-platform2:arm64 (2.1.0.1+dfsg1-2) ...
Selecting previously unselected package libcec4:arm64.
Preparing to unpack .../06-libcec4_4.0.7.1~buster_arm64.deb ...
Unpacking libcec4:arm64 (4.0.7.1~buster) ...
Selecting previously unselected package libfstrcmp0.
Preparing to unpack .../07-libfstrcmp0_0.7.D001-1.1+b2_arm64.deb ...
Unpacking libfstrcmp0 (0.7.D001-1.1+b2) ...
Selecting previously unselected package libiso9660-11:arm64.
Preparing to unpack .../08-libiso9660-11_2.0.0-2_arm64.deb ...
Unpacking libiso9660-11:arm64 (2.0.0-2) ...
Selecting previously unselected package liblirc-client0:arm64.
Preparing to unpack .../09-liblirc-client0_0.10.1-6.2~deb10u1_arm64.deb ...
Unpacking liblirc-client0:arm64 (0.10.1-6.2~deb10u1) ...
Selecting previously unselected package mysql-common.
Preparing to unpack .../10-mysql-common_5.8+1.0.5_all.deb ...
Unpacking mysql-common (5.8+1.0.5) ...
Selecting previously unselected package mariadb-common.
Preparing to unpack .../11-mariadb-common_1%3a10.3.27-0+deb10u1_all.deb ...
Unpacking mariadb-common (1:10.3.27-0+deb10u1) ...
Selecting previously unselected package libmariadb3:arm64.
Preparing to unpack .../12-libmariadb3_1%3a10.3.27-0+deb10u1_arm64.deb ...
Unpacking libmariadb3:arm64 (1:10.3.27-0+deb10u1) ...
Selecting previously unselected package libmicrohttpd12.
Preparing to unpack .../13-libmicrohttpd12_0.9.62-1_arm64.deb ...
Unpacking libmicrohttpd12 (0.9.62-1) ...
Selecting previously unselected package libpcrecpp0v5:arm64.
Preparing to unpack .../14-libpcrecpp0v5_2%3a8.39-12_arm64.deb ...
Unpacking libpcrecpp0v5:arm64 (2:8.39-12) ...
Selecting previously unselected package libtinyxml2.6.2v5:arm64.
Preparing to unpack .../15-libtinyxml2.6.2v5_2.6.2-4_arm64.deb ...
Unpacking libtinyxml2.6.2v5:arm64 (2.6.2-4) ...
Selecting previously unselected package kodi-rk-bin.
Preparing to unpack .../16-kodi-rk-bin_2%3a18.9-final-18.9buster0armbian3_arm64.deb ...
Unpacking kodi-rk-bin (2:18.9-final-18.9buster0armbian3) ...
Selecting previously unselected package libglew2.1:arm64.
Preparing to unpack .../17-libglew2.1_2.1.0-4_arm64.deb ...
Unpacking libglew2.1:arm64 (2.1.0-4) ...
Selecting previously unselected package libglu1-mesa:arm64.
Preparing to unpack .../18-libglu1-mesa_9.0.0-2.1+b3_arm64.deb ...
Unpacking libglu1-mesa:arm64 (9.0.0-2.1+b3) ...
Selecting previously unselected package mesa-utils.
Preparing to unpack .../19-mesa-utils_8.4.0-1+b1_arm64.deb ...
Unpacking mesa-utils (8.4.0-1+b1) ...
Selecting previously unselected package python-bluez.
Preparing to unpack .../20-python-bluez_0.22+really0.22-1_arm64.deb ...
Unpacking python-bluez (0.22+really0.22-1) ...
Selecting previously unselected package libimagequant0:arm64.
Preparing to unpack .../21-libimagequant0_2.12.2-1.1_arm64.deb ...
Unpacking libimagequant0:arm64 (2.12.2-1.1) ...
Selecting previously unselected package python-pil:arm64.
Preparing to unpack .../22-python-pil_5.4.1-2+deb10u2_arm64.deb ...
Unpacking python-pil:arm64 (5.4.1-2+deb10u2) ...
Selecting previously unselected package python-simplejson.
Preparing to unpack .../23-python-simplejson_3.16.0-1_arm64.deb ...
Unpacking python-simplejson (3.16.0-1) ...
Selecting previously unselected package libshairplay0:arm64.
Preparing to unpack .../24-libshairplay0_0.9.0~git20180824.096b61a+dfsg1-2~bpo10+1_arm64.deb ...
Unpacking libshairplay0:arm64 (0.9.0~git20180824.096b61a+dfsg1-2~bpo10+1) ...
Selecting previously unselected package libaacs0:arm64.
Preparing to unpack .../25-libaacs0_0.9.0-2_arm64.deb ...
Unpacking libaacs0:arm64 (0.9.0-2) ...
Selecting previously unselected package kodi-rk.
Preparing to unpack .../26-kodi-rk_2%3a18.9-final-18.9buster0armbian3_all.deb ...
Unpacking kodi-rk (2:18.9-final-18.9buster0armbian3) ...
Selecting previously unselected package libdav1d4:arm64.
Preparing to unpack .../27-libdav1d4_0.7.1-3~bpo10+1_arm64.deb ...
Unpacking libdav1d4:arm64 (0.7.1-3~bpo10+1) ...
Selecting previously unselected package libqt5multimedia5:arm64.
Preparing to unpack .../28-libqt5multimedia5_5.11.3-2_arm64.deb ...
Unpacking libqt5multimedia5:arm64 (5.11.3-2) ...
Selecting previously unselected package libqt5opengl5:arm64.
Preparing to unpack .../29-libqt5opengl5_5.11.3+dfsg1-1+deb10u4_arm64.deb ...
Unpacking libqt5opengl5:arm64 (5.11.3+dfsg1-1+deb10u4) ...
Selecting previously unselected package libqt5multimediawidgets5:arm64.
Preparing to unpack .../30-libqt5multimediawidgets5_5.11.3-2_arm64.deb ...
Unpacking libqt5multimediawidgets5:arm64 (5.11.3-2) ...
Selecting previously unselected package libqt5multimediagsttools5:arm64.
Preparing to unpack .../31-libqt5multimediagsttools5_5.11.3-2_arm64.deb ...
Unpacking libqt5multimediagsttools5:arm64 (5.11.3-2) ...
Selecting previously unselected package libqt5multimedia5-plugins:arm64.
Preparing to unpack .../32-libqt5multimedia5-plugins_5.11.3-2_arm64.deb ...
Unpacking libqt5multimedia5-plugins:arm64 (5.11.3-2) ...
Selecting previously unselected package libqt5qml5:arm64.
Preparing to unpack .../33-libqt5qml5_5.11.3-4_arm64.deb ...
Unpacking libqt5qml5:arm64 (5.11.3-4) ...
Selecting previously unselected package libqt5quick5:arm64.
Preparing to unpack .../34-libqt5quick5_5.11.3-4_arm64.deb ...
Unpacking libqt5quick5:arm64 (5.11.3-4) ...
Selecting previously unselected package libqt5multimediaquick5:arm64.
Preparing to unpack .../35-libqt5multimediaquick5_5.11.3-2_arm64.deb ...
Unpacking libqt5multimediaquick5:arm64 (5.11.3-2) ...
Selecting previously unselected package librockchip-vpu0.
Preparing to unpack .../36-librockchip-vpu0_1.4.0-3armbian3_arm64.deb ...
Unpacking librockchip-vpu0 (1.4.0-3armbian3) ...
Selecting previously unselected package qml-module-qt-labs-folderlistmodel:arm64.
Preparing to unpack .../37-qml-module-qt-labs-folderlistmodel_5.11.3-4_arm64.deb ...
Unpacking qml-module-qt-labs-folderlistmodel:arm64 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtquick2:arm64.
Preparing to unpack .../38-qml-module-qtquick2_5.11.3-4_arm64.deb ...
Unpacking qml-module-qtquick2:arm64 (5.11.3-4) ...
Selecting previously unselected package qml-module-qtmultimedia:arm64.
Preparing to unpack .../39-qml-module-qtmultimedia_5.11.3-2_arm64.deb ...
Unpacking qml-module-qtmultimedia:arm64 (5.11.3-2) ...
Selecting previously unselected package qtmultimedia5-examples:arm64.
Preparing to unpack .../40-qtmultimedia5-examples_5.11.3-2_arm64.deb ...
Unpacking qtmultimedia5-examples:arm64 (5.11.3-2) ...
Selecting previously unselected package qtgstreamer-plugins-qt5:arm64.
Preparing to unpack .../41-qtgstreamer-plugins-qt5_1.2.0-5_arm64.deb ...
Unpacking qtgstreamer-plugins-qt5:arm64 (1.2.0-5) ...
Selecting previously unselected package mpv-legacy.
Preparing to unpack .../42-mpv-legacy_2%3a2020.12.08.df805cfc84_arm64.deb ...
Unpacking mpv-legacy (2:2020.12.08.df805cfc84) ...
Selecting previously unselected package media-buster-legacy-rk3399.
Preparing to unpack .../43-media-buster-legacy-rk3399_20.11.6_arm64.deb ...
Removing 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-buster-root-legacy-station-p1'
Unpacking media-buster-legacy-rk3399 (20.11.6) ...
Setting up libpcrecpp0v5:arm64 (2:8.39-12) ...
Setting up mysql-common (5.8+1.0.5) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Setting up libiso9660-11:arm64 (2.0.0-2) ...
Setting up gstreamer1.0-rockchip1-extra (3:20180115-3armbian1) ...
Setting up python-simplejson (3.16.0-1) ...
Setting up libmicrohttpd12 (0.9.62-1) ...
Setting up libqt5multimedia5:arm64 (5.11.3-2) ...
Setting up mariadb-common (1:10.3.27-0+deb10u1) ...
update-alternatives: using /etc/mysql/mariadb.cnf to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Setting up libp8-platform2:arm64 (2.1.0.1+dfsg1-2) ...
Setting up libqt5qml5:arm64 (5.11.3-4) ...
Setting up liblirc-client0:arm64 (0.10.1-6.2~deb10u1) ...
Setting up libimagequant0:arm64 (2.12.2-1.1) ...
Setting up libcec4:arm64 (4.0.7.1~buster) ...
Setting up libmariadb3:arm64 (1:10.3.27-0+deb10u1) ...
Setting up libaacs0:arm64 (0.9.0-2) ...
Setting up libtinyxml2.6.2v5:arm64 (2.6.2-4) ...
Setting up python-bluez (0.22+really0.22-1) ...
Setting up libglew2.1:arm64 (2.1.0-4) ...
Setting up libqt5opengl5:arm64 (5.11.3+dfsg1-1+deb10u4) ...
Setting up libmali-rk-midgard-t86x-r14p0-r0p0:arm64 (1.6-1-1armbian3) ...
Setting up fonts-liberation (1:1.07.4-9) ...
Setting up librga2 (2.0.0-1) ...
Setting up libdav1d4:arm64 (0.7.1-3~bpo10+1) ...
Setting up libglu1-mesa:arm64 (9.0.0-2.1+b3) ...
Setting up libshairplay0:arm64 (0.9.0~git20180824.096b61a+dfsg1-2~bpo10+1) ...
Setting up libqt5quick5:arm64 (5.11.3-4) ...
Setting up libfstrcmp0 (0.7.D001-1.1+b2) ...
Setting up librockchip-mpp1 (1.4.0-3armbian3) ...
Setting up librockchip-vpu0 (1.4.0-3armbian3) ...
Setting up gstreamer1.0-rockchip1 (2:1.10-0armbian1) ...
Setting up mpv-legacy (2:2020.12.08.df805cfc84) ...
Setting up qtgstreamer-plugins-qt5:arm64 (1.2.0-5) ...
Setting up python-pil:arm64 (5.4.1-2+deb10u2) ...
Setting up qml-module-qt-labs-folderlistmodel:arm64 (5.11.3-4) ...
Setting up xserver-xorg-core-rockchip (2:1.20.3-3armbian1) ...
Setting up mesa-utils (8.4.0-1+b1) ...
Setting up libqt5multimediawidgets5:arm64 (5.11.3-2) ...
Setting up libqt5multimediagsttools5:arm64 (5.11.3-2) ...
Setting up libqt5multimedia5-plugins:arm64 (5.11.3-2) ...
Setting up kodi-rk-bin (2:18.9-final-18.9buster0armbian3) ...
Setting up libqt5multimediaquick5:arm64 (5.11.3-2) ...
Setting up qml-module-qtquick2:arm64 (5.11.3-4) ...
Setting up qml-module-qtmultimedia:arm64 (5.11.3-2) ...
Setting up qtmultimedia5-examples:arm64 (5.11.3-2) ...
Setting up kodi-rk (2:18.9-final-18.9buster0armbian3) ...
Setting up media-buster-legacy-rk3399 (20.11.6) ...
Creating group kodi with gid 998.
Creating group optical with gid 997.
Creating user kodi (Kodi User) with uid 998 and gid 998.
[/usr/lib/tmpfiles.d/speech-dispatcher.conf:1] Line references path below legacy directory /var/run/, updating /var/run/speech-dispatcher → /run/speech-dispatcher; please update the tmpfiles.d/ drop-in file accordingly.
[/usr/lib/tmpfiles.d/speech-dispatcher.conf:2] Line references path below legacy directory /var/run/, updating /var/run/speech-dispatcher/.cache → /run/speech-dispatcher/.cache; please update the tmpfiles.d/ drop-in file accordingly.
[/usr/lib/tmpfiles.d/speech-dispatcher.conf:3] Line references path below legacy directory /var/run/, updating /var/run/speech-dispatcher/.speech-dispatcher → /run/speech-dispatcher/.speech-dispatcher; please update the tmpfiles.d/ drop-in file accordingly.
[/usr/lib/tmpfiles.d/speech-dispatcher.conf:4] Line references path below legacy directory /var/run/, updating /var/run/speech-dispatcher/.cache/speech-dispatcher → /run/speech-dispatcher/.cache/speech-dispatcher; please update the tmpfiles.d/ drop-in file accordingly.
[/usr/lib/tmpfiles.d/speech-dispatcher.conf:5] Line references path below legacy directory /var/run/, updating /var/run/speech-dispatcher/log → /run/speech-dispatcher/log; please update the tmpfiles.d/ drop-in file accordingly.
-e
# Configuration finished. PLEASE REBOOT #
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for fontconfig (2.13.1-2) ...
Looks normal to me. But chromium isn't hw acc.
Graphics Feature Status
Canvas: Software only. Hardware acceleration disabled
Compositing: Software only. Hardware acceleration disabled
Multiple Raster Threads: Disabled
Out-of-process Rasterization: Disabled
OpenGL: Disabled
Hardware Protected Video Decode: Disabled
Rasterization: Software only. Hardware acceleration disabled
Skia Renderer: Enabled
Video Decode: Software only. Hardware acceleration disabled
Vulkan: Disabled
WebGL: Disabled
WebGL2: Disabled
Problems Detected
GPU process was unable to boot: GPU access is disabled due to frequent crashes.
Disabled Features: all
Gpu compositing has been disabled, either via blocklist, about:flags or the command line. The browser will fall back to software compositing and hardware acceleration will be unavailable.
Disabled Features: gpu_compositing
Accelerated video decode has been disabled, either via blocklist, about:flags or the command line.
Disabled Features: video_decode
Accelerated rasterization has been disabled, either via blocklist, about:flags or the command line.
Disabled Features: rasterization
I don't know anymore. I think it worked a few days ago. Any other image I can try?
13 minutes ago, JMCC said:
I suggest building or using a nightly
I just tried the image from the download page : https://www.armbian.com/station-p1/
There it works as it should.
Canvas: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Force enabled
OpenGL: Enabled
Hardware Protected Video Decode: Hardware accelerated
Vulkan: Disabled
WebGL: Hardware accelerated
WebGL2: Hardware accelerated
@balbes150You any idea why this happens? The image on the downloadpage doesn't have on-board wifi working. I'll see if the NVMe works with that dtb file. I use a 5Ghz usb wifi antenna so I don't care that much about on-board wifi. (yes I know, wifi bad :D )
