roswitina Posted January 1, 2021 Posted January 1, 2021 I have installed OMV via armbian-config (software). After that I tried to install Nextcloud the same way. In the process I noticed that Apache2 does not start due to a port mismatch (port 80). I was able to determine that obviously the web server nginx is already installed and used for OMV. Can someone please explain to me if this is intentional or if I made a mistake during the installation? Is it possible not to install OMV and Nextcloud in parallel? How can I solve this?
Werner Posted January 1, 2021 Posted January 1, 2021 2 minutes ago, roswitina said: How can I solve this? Install Nextcloud manually. Check their instructions how to do that.
roswitina Posted January 1, 2021 Author Posted January 1, 2021 (edited) Will probably have to do that if I want nextcloud in addition. Nevertheless, I wonder why both are offered for installation in armbian-config, but no indication that OMV nginx and Nextcloud apache2 is required in the offered installation in Helios64. Edited January 1, 2021 by roswitina
Werner Posted January 1, 2021 Posted January 1, 2021 Well armbian-config was never designed to catch such "dependencies" of parallel installations. As you can see for yourself in the source it is a rather simple tool to allow a quick installation of software: https://github.com/armbian/config There is always room for improvements and contributions are certainly appreciated
axeleroy Posted January 2, 2021 Posted January 2, 2021 Since OMV alters so much of Debian/Armbian, I would recommend deploying the Docker container. Docker also has the benefit of using any port you want. If you want an easy to use GUI, you can install Portainer using OMV-Extras (in the left menu, then under the Docker tab of OMV-Extras).
gprovost Posted January 4, 2021 Posted January 4, 2021 We will post soon instruction on our wiki on how to install Nextcloud via docker compose (along side OMV) with reverse proxy (nginx proxy manager). In the meantime find attached the the docker compose files for nextcloud I made. 1/ You will need to adjust the .yml file for the volumes location. 2/ You will need to update db.env to define DB user and password Note: This setup only exposes the port 80 via port host post 9001. It is meant for running behind a reverse proxy which would handle HTTPS. You need to install docker and docker-compose on your machine. Then decompress the attached folder and once inside the folder just do docker-compose up -d nextcloud.tar.gz
roswitina Posted January 5, 2021 Author Posted January 5, 2021 Thanks for the Docker file. I have Nextcloud running. The NginxProxyMangager in the current version 2.7.1 apparently has a BUG at the moment; login is not possible. However, Nextcloud itself is very very sluggishly responsive, so I'm considering moving my virtual machines to a NUC and using the Helios64 exclusively with OMV only, which is what I bought it for. Ps.: I have now disabled Collabora (it was automatically installed during initial setup) and now Nextcloud is much more responsive.
gprovost Posted January 7, 2021 Posted January 7, 2021 On 1/6/2021 at 2:47 AM, roswitina said: Ps.: I have now disabled Collabora (it was automatically installed during initial setup) and now Nextcloud is much more responsive. Hmm good point. Something to keep in view. Issue is already reported by other nextcloud user : https://github.com/nextcloud/richdocuments/issues/1282
TijuanaKez Posted March 3, 2021 Posted March 3, 2021 I would suggest following this guide, and choosing the Portainer Stack option. https://forum.openmediavault.org/index.php?thread/28216-how-to-nextcloud-with-letsencrypt-using-omv-and-docker-compose/ As well as being a streamlined and fairly painless way to install NextCloud and MariaDB at once, you'll get SWAG for free, which you will likely want. 1
