SymbiosisSystems Posted February 20, 2021 Posted February 20, 2021 When there is a kernel panic the fans stop which causes the HDD and CPU temperatures to rise unchecked. I've just come back to find my board has crashed again and the HDD temperatures had risen above 60c which is not good. Is there a watchdog or boot setting to automatically reset the processor after a kernel panic ?
allen--smithee Posted February 20, 2021 Posted February 20, 2021 If you can shut down or restart the unit after the crash from the front panel buttons then maybe this can help increase HA of your unit. I have no turnkey solution to offer you but your question reminds me of another. Your problem is not that different from his after all. Would meet the needs of RiP WoL, User angst and system crashes. With the UPS on unit you cannot use a smart plug to blow the power. You must act directly on the unit, adding a health companion board that can act on Power and Reset is definitely the best way to go.
SymbiosisSystems Posted February 21, 2021 Author Posted February 21, 2021 Thanks for the suggestion, adding extra hardware could be an option but I'm ideally hoping there is a solution to this issue within the Helios64 hardware if possible.
FloBaoti Posted February 21, 2021 Posted February 21, 2021 What about rebooting after kernel panic ? You have to set sysctl parameter "kernel.panic" to a value in seconds, timer after kernel panic to reboot. As long as Helios64 isn't stable, it's a must have parameter! Quote # cat /etc/sysctl.d/panic.conf kernel.panic = 10 Expand
lanefu Posted February 22, 2021 Posted February 22, 2021 You should be able to enable the watchdog in systemd by uncommenting some lines in /etc/systemd/system.conf
gprovost Posted February 22, 2021 Posted February 22, 2021 You can install watchdog service and make use of the RK3399 hardware watchdog apt-get install watchdog
SymbiosisSystems Posted February 22, 2021 Author Posted February 22, 2021 @gprovost I've set the kernel.panic , installed the watchdog and disabled the dynamic frequency switching but it still hangs whilst booting and doesn't reset (I assume because it hasn't got to the point where the watchdog service is loaded). This makes it unuseable because I can't risk it crashing with the HDDs spinning and the fans not running. Even when it does occasionally boot it still crashes whilst doing an rsync. Until you resolve this issue it is no better to me than an expensive doorstop which is deeply deeply frustrating.
gprovost Posted February 23, 2021 Posted February 23, 2021 @SymbiosisSystems Does the same issue happen with a fresh install on legacy (LK 4.4) ?
SymbiosisSystems Posted February 23, 2021 Author Posted February 23, 2021 @gprovost on the first boot I was able to set the root password, then rebooted and it crashed with LK 4.4. Here is the dump Quote DDR Version 1.24 20191016 In soft reset SRX channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 323 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 80183 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe5af4 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Feb 03 2021 - 22:43:01 +0100) SoC: Rockchip rk3399 Reset cause: WDOG DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: eth0: ethernet@fe300000 scanning bus for devices... starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 4!? 4 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 5 ms (622.1 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 166 bytes read in 4 ms (40 KiB/s) 8508847 bytes read in 371 ms (21.9 MiB/s) 20770824 bytes read in 883 ms (22.4 MiB/s) 101557 bytes read in 12 ms (8.1 MiB/s) 2698 bytes read in 7 ms (376 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8508783 Bytes = 8.1 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f56d2000, end f5eef56f ... OK ERROR: reserving fdt memory region failed (addr=0 size=0) Loading Device Tree to 00000000f5650000, end 00000000f56d1fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.213-rk3399 (root@beast) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #14 SMP Wed Feb 3 20:52:28 CET 2021 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] PERCPU: Embedded 20 pages/cpu @ffffffc0f7ed2000 s42216 r8192 d31512 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: root=UUID=c99fadcc-25b5-485d-85e6-d859de7ee644 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=50f571e6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0xeec00000-0xf2c00000] (64MB) [ 0.000000] Memory: 3891628K/4061184K available (11582K kernel code, 1404K rwdata, 6148K rodata, 1088K init, 1956K bss, 169556K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff80091e0000 - 0xffffff80092f0000 ( 1088 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB) [ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff80091e0000 ( 6208 KB) [ 0.000000] .data : 0xffffff80092f0000 - 0xffffff800944f008 ( 1405 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ee900000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ee890000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ee8a0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001504] Console: colour dummy device 80x25 [ 0.003434] console [tty1] enabled [ 0.003483] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.003548] pid_max: default: 32768 minimum: 301 [ 0.003694] Security Framework initialized [ 0.003729] Yama: becoming mindful. [ 0.003780] AppArmor: AppArmor disabled by boot time parameter [ 0.003860] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.003901] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.004699] Initializing cgroup subsys io [ 0.004744] Initializing cgroup subsys memory [ 0.004802] Initializing cgroup subsys devices [ 0.004842] Initializing cgroup subsys freezer [ 0.004881] Initializing cgroup subsys net_cls [ 0.004919] Initializing cgroup subsys perf_event [ 0.004958] Initializing cgroup subsys net_prio [ 0.005001] Initializing cgroup subsys hugetlb [ 0.005037] Initializing cgroup subsys pids [ 0.005105] ftrace: allocating 41873 entries in 164 pages [ 0.119869] sched-energy: Sched-energy-costs installed from DT [ 0.119919] CPU0: update cpu_capacity 401 [ 0.120005] ASID allocator initialised with 32768 entries [ 0.123080] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.123717] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.125238] Detected VIPT I-cache on CPU1 [ 0.125277] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.125315] CPU1: using LPI pending table @0x00000000eeb30000 [ 0.125375] CPU1: update cpu_capacity 401 [ 0.125380] CPU1: Booted secondary processor [410fd034] [ 0.126188] Detected VIPT I-cache on CPU2 [ 0.126221] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.126258] CPU2: using LPI pending table @0x00000000eeb60000 [ 0.126315] CPU2: update cpu_capacity 401 [ 0.126319] CPU2: Booted secondary processor [410fd034] [ 0.127178] Detected VIPT I-cache on CPU3 [ 0.127210] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.127246] CPU3: using LPI pending table @0x00000000eebb0000 [ 0.127301] CPU3: update cpu_capacity 401 [ 0.127305] CPU3: Booted secondary processor [410fd034] [ 0.128138] Detected PIPT I-cache on CPU4 [ 0.128163] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.128203] CPU4: using LPI pending table @0x00000000eebf0000 [ 0.128240] CPU4: update cpu_capacity 1024 [ 0.128243] CPU4: Booted secondary processor [410fd082] [ 0.128936] Detected PIPT I-cache on CPU5 [ 0.128961] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.129001] CPU5: using LPI pending table @0x00000000ee020000 [ 0.129038] CPU5: update cpu_capacity 1024 [ 0.129042] CPU5: Booted secondary processor [410fd082] [ 0.129147] Brought up 6 CPUs [ 0.129868] SMP: Total of 6 processors activated. [ 0.129901] CPU features: detected feature: GIC system register CPU interface [ 0.129938] CPU features: detected feature: 32-bit EL0 Support [ 0.129975] CPU: All CPU(s) started at EL2 [ 0.130046] alternatives: patching kernel code [ 0.131527] devtmpfs: initialized [ 0.149176] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.149237] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.149740] xor: measuring software checksum speed [ 0.186867] 8regs : 2855.000 MB/sec [ 0.226929] 8regs_prefetch: 2558.000 MB/sec [ 0.266990] 32regs : 3210.000 MB/sec [ 0.307052] 32regs_prefetch: 2840.000 MB/sec [ 0.307072] xor: using function: 32regs (3210.000 MB/sec) [ 0.307112] pinctrl [ 0.703717] raid6: int64x2 xor() 608 MB/s [ 0.771834] raid6: int64x4 gen() 938 MB/s [ 0.839907] raid6: int64x4 xor() 673 MB/s [ 0.908029] raid6: int64x8 gen() 865 MB/s [ 0.976130] raid6: int64x8 xor() 608 MB/s [ 1.044251] raid6: neonx1 gen() 906 MB/s [ 1.112352] raid6: neonx1 xor() 679 MB/s [ 1.180449] raid6: neonx2 gen() 1520 MB/s [ 1.248560] raid6: neonx2 xor() 977 MB/s [ 1.316646] raid6: neonx4 gen() 1767 MB/s [ 1.384758] raid6: neonx4 xor() 1138 MB/s [ 1.452886] raid6: neonx8 gen() 1697 MB/s [ 1.520980] raid6: neonx8 xor() 1245 MB/s [ 1.521371] raid6: using algorithm neonx4 gen() 1767 MB/s [ 1.521864] raid6: .... xor() 1138 MB/s, rmw enabled [ 1.522323] raid6: using intx1 recovery algorithm [ 1.524543] vcc12v_dcin_bkup: supplied by vcc12v_dcin [ 1.525312] vcc12v_hdd: supplied by vcc12v_dcin_bkup [ 1.526192] vcc1v8_sys_s0: regulator get failed, ret=-517 [ 1.527000] vcc0v9_s3: regulator get failed, ret=-517 [ 1.527773] avdd_0v9_s0: regulator get failed, ret=-517 [ 1.528664] avdd_1v8_s0: regulator get failed, ret=-517 [ 1.544493] pcie_power: regulator get failed, ret=-517 [ 1.545462] vcc3v3_sys_s3: regulator get failed, ret=-517 [ 1.572575] vcc3v0_sd: regulator get failed, ret=-517 [ 1.573869] vcc5v0_usb: regulator get failed, ret=-517 [ 1.574929] vcc5v0_perdev: supplied by vcc12v_dcin_bkup [ 1.575864] pcie_power: supplied by vcc5v0_perdev [ 1.576524] vcc5v0_usb: supplied by vcc5v0_perdev [ 1.577113] vcc5v0_hdd: supplied by vcc12v_dcin_bkup [ 1.578243] vcc5v0_sys: supplied by vcc12v_dcin_bkup [ 1.579006] vcc3v3_sys_s3: supplied by vcc5v0_sys [ 1.579469] vcc0v9_s3: supplied by vcc3v3_sys_s3 [ 1.580000] avdd_1v8_s0: supplied by vcc3v3_sys_s3 [ 1.580518] vcc3v0_sd: supplied by vcc3v3_sys_s3 [ 1.581997] usblan_power: supplied by vcc5v0_usb [ 1.583410] iommu: Adding device ff650000.vpu_service to group 0 [ 1.584030] iommu: Adding device ff660000.rkvdec to group 1 [ 1.584668] iommu: Adding device ff8f0000.vop to group 2 [ 1.585239] iommu: Adding device ff900000.vop to group 3 [ 1.586240] rk_iommu ff650800.iommu: can't get sclk [ 1.586968] rk_iommu ff660480.iommu: can't get sclk [ 1.587622] rk_iommu ff8f3f00.iommu: can't get sclk [ 1.588236] rk_iommu ff903f00.iommu: can't get sclk [ 1.589097] SCSI subsystem initialized [ 1.589870] usbcore: registered new interface driver usbfs [ 1.590419] usbcore: registered new interface driver hub [ 1.591001] usbcore: registered new device driver usb [ 1.591548] media: Linux media interface: v0.10 [ 1.591991] Linux video capture interface: v2.00 [ 1.592522] pps_core: LinuxPPS API ver. 1 registered [ 1.592983] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.593841] PTP clock support registered [ 1.595427] Advanced Linux Sound Architecture Driver Initialized. [ 1.596875] NetLabel: Initializing [ 1.597198] NetLabel: domain hash size = 128 [ 1.597599] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.598106] NetLabel: unlabeled traffic allowed by default [ 1.598889] rockchip-cpuinfo cpuinfo: Serial : 85afff6e2668ee33 [ 1.600046] clocksource: Switched to clocksource arch_sys_counter [ 1.647522] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 1.648410] NET: Registered protocol family 2 [ 1.649286] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.650212] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 1.651734] TCP: Hash tables configured (established 32768 bind 32768) [ 1.652480] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 1.653191] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 1.654221] NET: Registered protocol family 1 [ 1.655403] Trying to unpack rootfs image as initramfs... [ 2.075422] Freeing initrd memory: 8308K [ 2.076355] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.077194] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 2.079537] kvm [1]: 8-bit VMID [ 2.079838] kvm [1]: Hyp mode initialized successfully [ 2.080475] kvm [1]: interrupt-controller@fff20000 IRQ10 [ 2.081168] kvm [1]: timer IRQ12 [ 2.084938] audit: initializing netlink subsys (disabled) [ 2.085489] audit: type=2000 audit(2.008:1): initialized [ 2.086366] Initialise system trusted keyring [ 2.087176] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 2.095235] VFS: Disk quotas dquot_6.6.0 [ 2.095763] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 2.097900] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.099111] fuse init (API version 7.23) [ 2.100082] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.106011] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 2.108457] Key type big_key registered [ 2.108824] [ 2.108824] TEE Core Framework initialization (ver 1:0.1) [ 2.109480] TEE armv7 Driver initialization [ 2.110347] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 2.110951] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 2.111710] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [ 2.117773] Key type asymmetric registered [ 2.118164] Asymmetric key parser 'x509' registered [ 2.118805] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 2.119642] io scheduler noop registered [ 2.120016] io scheduler deadline registered (default) [ 2.120539] io scheduler cfq registered [ 2.122489] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator [ 2.130329] rk-vcodec ff650000.vpu_service: no regulator for vcodec [ 2.131123] rk-vcodec ff650000.vpu_service: probe device [ 2.131839] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled [ 2.133160] rk-vcodec ff650000.vpu_service: could not find power_model node [ 2.133800] rk-vcodec ff650000.vpu_service: init success [ 2.134523] rk-vcodec ff660000.rkvdec: no regulator for vcodec [ 2.135444] rk-vcodec ff660000.rkvdec: probe device [ 2.136114] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled [ 2.137072] rk-vcodec ff660000.rkvdec: could not find power_model node [ 2.137663] rk-vcodec ff660000.rkvdec: init success [ 2.139630] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.140392] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 2.142647] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.143344] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.145304] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 2.147460] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [ 2.149308] [drm] Initialized drm 1.1.0 20060810 [ 2.153240] [drm] Rockchip DRM driver version: v1.0.1 [ 2.156097] Unable to detect cache hierarchy for CPU 0 [ 2.157391] brd: module loaded [ 2.163087] loop: module loaded [ 2.163761] lkdtm: No crash points registered, enable through debugfs [ 2.165538] rockchip-spi ff1d0000.spi: no high_speed pinctrl state [ 2.166622] m25p80 spi0.0: w25q128 (16384 Kbytes) [ 2.168310] rockchip-spi ff1e0000.spi: no high_speed pinctrl state [ 2.169507] rockchip-spi ff200000.spi: no high_speed pinctrl state [ 2.172168] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 2.172812] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 2.173334] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). [ 2.173869] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 2.174599] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 2.175235] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 2.180795] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 2.181420] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.181880] Ring mode enabled [ 2.182165] DMA HW capability register supported [ 2.182568] Normal descriptors [ 2.182899] RX Checksum Offload Engine supported (type 2) [ 2.183404] TX Checksum insertion supported [ 2.183793] Wake-Up On Lan supported [ 2.184179] Enable RX Mitigation via HW Watchdog Timer [ 2.272786] libphy: stmmac: probed [ 2.273128] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [ 2.273718] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01) [ 2.275697] usbcore: registered new interface driver rndis_wlan [ 2.276670] Rockchip WiFi SYS interface (V1.00) ... [ 2.277267] usbcore: registered new interface driver cdc_ether [ 2.277856] usbcore: registered new interface driver rndis_host [ 2.280687] rockchip-dwc3 usb0: failed to get drvdata dwc3 [ 2.286282] rockchip-dwc3 usb1: fail to get drvdata hcd [ 2.288091] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.288697] ehci-pci: EHCI PCI platform driver [ 2.289167] ehci-platform: EHCI generic platform driver [ 2.290186] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.290768] ohci-platform: OHCI generic platform driver [ 2.292092] usbcore: registered new interface driver cdc_acm [ 2.292612] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.293373] usbcore: registered new interface driver cdc_wdm [ 2.293965] usbcore: registered new interface driver usbserial [ 2.294522] usbcore: registered new interface driver usbserial_generic [ 2.295128] usbserial: USB Serial support registered for generic [ 2.296516] usbcore: registered new interface driver iforce [ 2.297071] usbcore: registered new interface driver xpad [ 2.297726] usbcore: registered new interface driver usbtouchscreen [ 2.298295] <<-GTP-INFO->> GTP driver installing [ 2.299088] sensor_register_slave:mma8452,id=17 [ 2.299508] sensor_register_slave:lis3dh,id=7 [ 2.299913] sensor_register_slave:mma7660,id=18 [ 2.300360] sensor_register_slave:lsm303d,id=22 [ 2.300779] sensor_register_slave:mpu6880_acc,id=24 [ 2.301231] sensor_register_slave:mpu6500_acc,id=25 [ 2.301682] sensor_register_slave:lsm330_acc,id=26 [ 2.302122] sensor_register_slave:akm8975,id=30 [ 2.302539] sensor_register_slave:akm8963,id=31 [ 2.302956] sensor_register_slave:l3g4200d,id=45 [ 2.303383] sensor_register_slave:l3g20d,id=46 [ 2.303800] sensor_register_slave:ewtsa,id=47 [ 2.304216] sensor_register_slave:lsm330_gyro,id=51 [ 2.304669] sensor_register_slave:cm3217,id=53 [ 2.305085] sensor_register_slave:cm3218,id=54 [ 2.305987] i2c /dev entries driver [ 2.307548] rk808 0-001b: Pmic Chip id: 0x0 [ 2.310659] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 2.311282] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 2.311963] DCDC_REG1: supplied by vcc5v0_sys [ 2.313279] DCDC_REG2: supplied by vcc5v0_sys [ 2.314367] DCDC_REG3: supplied by vcc5v0_sys [ 2.315164] DCDC_REG4: supplied by vcc5v0_sys [ 2.315967] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 [ 2.316513] avdd_0v9_s0: supplied by vcc1v8_sys_s3 [ 2.317087] LDO_REG1: supplied by vcc5v0_sys [ 2.318117] LDO_REG2: supplied by vcc5v0_sys [ 2.319018] LDO_REG3: supplied by vcc5v0_sys [ 2.320446] LDO_REG4: supplied by vcc5v0_sys [ 2.321861] LDO_REG5: supplied by vcc5v0_sys [ 2.322761] LDO_REG6: supplied by vcc5v0_sys [ 2.324206] LDO_REG7: supplied by vcc5v0_sys [ 2.325125] LDO_REG8: supplied by vcc5v0_sys [ 2.326550] SWITCH_REG1: supplied by vcc3v3_sys_s3 [ 2.327332] SWITCH_REG2: supplied by vcc3v3_sys_s3 [ 2.331272] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 2.333030] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 2.333725] fan53555-reg: supplied by vcc5v0_sys [ 2.336406] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 2.337084] fan53555-reg: supplied by vcc5v0_sys [ 2.339268] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097ce000 [ 2.341862] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80097d0000 [ 2.343015] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097d2000 [ 2.348130] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_UFP [ 2.349084] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input0 [ 2.350058] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d4000 [ 2.351213] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d6000 [ 2.353845] usbcore: registered new interface driver uvcvideo [ 2.354377] USB Video Class driver (1.1.1) [ 2.357224] B [ 2.504385] Error: Driver 'ov7750' is already registered, aborting... [ 2.504982] Error: Driver 'ov8858' is already registered, aborting... [ 2.505663] Error: Driver 'sc031gs' is already registered, aborting... [ 2.506901] Registered cp15_barrier emulation handler [ 2.507462] Registered setend emulation handler [ 2.508179] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 2.509105] registered taskstats version 1 [ 2.509262] mmc0: new high speed SDHC card at address aaaa [ 2.510019] Loading compiled-in X.509 certificates [ 2.510058] mmcblk0: mmc0:aaaa SM32G 29.7 GiB [ 2.511351] mmcblk0: p1 [ 2.513226] Btrfs loaded, integrity-checker=on [ 2.513783] BTRFS: selftest: Running btrfs free space cache tests [ 2.514378] BTRFS: selftest: Running extent only tests [ 2.514879] BTRFS: selftest: Running bitmap only tests [ 2.515383] BTRFS: selftest: Running bitmap and extent tests [ 2.515939] BTRFS: selftest: Running space stealing from bitmap to extent [ 2.517914] BTRFS: selftest: Free space cache tests finished [ 2.518443] BTRFS: selftest: Running extent buffer operation tests [ 2.518987] BTRFS: selftest: Running btrfs_split_item tests [ 2.519600] BTRFS: selftest: Running find delalloc tests [ 2.564281] mmc1: new HS200 MMC card at address 0001 [ 2.565691] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB [ 2.566613] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB [ 2.567581] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB [ 2.568618] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB [ 2.684786] BTRFS: selftest: Running btrfs_get_extent tests [ 2.685441] BTRFS: selftest: Running hole first btrfs_get_extent test [ 2.686028] BTRFS: selftest: Running outstanding_extents tests [ 2.686587] BTRFS: selftest: Running qgroup tests [ 2.687009] BTRFS: selftest: Qgroup basic add [ 2.687432] BTRFS: selftest: Qgroup multiple refs test [ 2.748598] random: nonblocking pool is initialized [ 2.759705] Key type encrypted registered [ 2.761474] rga2: Driver loaded successfully ver:3.02 [ 2.762501] rga2: Module initialized. [ 2.764966] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator [ 2.769845] rockchip-pcie f8000000.pcie: bus-scan-delay-ms in device tree is 2000 ms [ 2.770578] rockchip-pcie f8000000.pcie: missing "memory-region" property [ 2.771213] PCI host bridge /pcie@f8000000 ranges: [ 2.771682] MEM 0xfa000000..0xfbdfffff -> 0xfa000000 [ 2.772441] IO 0xfbe00000..0xfbefffff -> 0xfbe00000 [ 2.796280] rockchip-pcie f8000000.pcie: invalid power supply [ 2.901373] rockchip-pcie f8000000.pcie: wait 2000 ms (from device tree) before bus scan [ 3.009949] vendor storage:20190527 ret = 0 [ 4.904706] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 4.905358] pci_bus 0000:00: root bus resource [bus 00-1f] [ 4.905893] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 4.906550] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 4.908223] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.909447] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 4.910161] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 4.910870] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 4.911579] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 4.912317] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 4.920392] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff] [ 4.921038] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 4.921614] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [ 4.922304] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] [ 4.922952] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x107f] [ 4.923530] pci 0000:01:00.0: BAR 1: assigned [io 0x1080-0x10ff] [ 4.924130] pci 0000:01:00.0: BAR 2: assigned [io 0x1100-0x117f] [ 4.924709] pci 0000:01:00.0: BAR 3: assigned [io 0x1180-0x11ff] [ 4.925287] pci 0000:01:00.0: BAR 4: assigned [io 0x1200-0x127f] [ 4.925865] pci 0000:00:00.0: PCI bridge to [bus 01] [ 4.926339] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff] [ 4.926909] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 4.927706] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 4.928696] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 4.929346] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 4.930304] ahci 0000:01:00.0: enabling device (0000 -> 0003) [ 4.931242] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled [ 4.931953] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 4.932752] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh [ 4.938279] scsi host0: ahci [ 4.939200] scsi host1: ahci [ 4.940767] scsi host2: ahci [ 4.941995] scsi host3: ahci [ 4.942903] scsi host4: ahci [ 4.943409] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 255 [ 4.944130] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 256 [ 4.944831] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 257 [ 4.945529] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 258 [ 4.946228] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 259 [ 4.952497] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 4.953456] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 4.954338] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010 [ 4.955190] xhci-hcd xhci-hcd.2.auto: irq 223, io mem 0xfe800000 [ 4.956021] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.956678] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.957354] usb usb1: Product: xHCI Host Controller [ 4.957808] usb usb1: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 4.958365] usb usb1: SerialNumber: xhci-hcd.2.auto [ 4.959503] hub 1-0:1.0: USB hub found [ 4.959895] hub 1-0:1.0: 1 port detected [ 4.960656] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 4.961319] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 4.962096] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 4.962959] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 4.963589] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.964280] usb usb2: Product: xHCI Host Controller [ 4.964735] usb usb2: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 4.965292] usb usb2: SerialNumber: xhci-hcd.2.auto [ 4.966225] hub 2-0:1.0: USB hub found [ 4.966610] hub 2-0:1.0: 1 port detected [ 4.969604] xhci-hcd xhci-hcd.2.auto: remove, state 1 [ 4.970116] usb usb2: USB disconnect, device number 1 [ 4.987102] xhci-hcd xhci-hcd.2.auto: Host not halted after 16000 microseconds. [ 4.987775] xhci-hcd xhci-hcd.2.auto: Host controller not halted, aborting reset. [ 4.988512] xhci-hcd xhci-hcd.2.auto: USB bus 2 deregistered [ 4.989283] xhci-hcd xhci-hcd.2.auto: remove, state 1 [ 4.989784] usb usb1: USB disconnect, device number 1 [ 12.076053] BUG: spinlock lockup suspected on CPU#0, swapper/0/0 [ 12.076639] lock: 0xffffffc0f7f3f200, .magic: dead4ead, .owner: kworker/u12:6/220, .owner_cpu: 5 [ 12.077469] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.213-rk3399 #14 [ 12.078088] Hardware name: Helios64 (DT) [ 12.078465] Call trace: [ 12.078724] [<ffffff800808803c>] dump_backtrace+0x0/0x21c [ 12.079234] [<ffffff800808827c>] show_stack+0x24/0x30 [ 12.079721] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc [ 12.080207] [<ffffff80081939d8>] spin_dump+0x84/0xa4 [ 12.080682] [<ffffff8008105b74>] do_raw_spin_lock+0xdc/0x164 [ 12.081217] [<ffffff8008bbccf0>] _raw_spin_lock+0x20/0x2c [ 12.081727] [<ffffff80080fb160>] sched_rt_period_timer+0x11c/0x268 [ 12.082307] [<ffffff8008126544>] __hrtimer_run_queues+0x1bc/0x284 [ 12.082872] [<ffffff8008126b30>] hrtimer_interrupt+0xac/0x1bc [ 12.083416] [<ffffff800897ccd4>] arch_timer_handler_phys+0x3c/0x4c [ 12.083996] [<ffffff8008116a70>] handle_percpu_devid_irq+0xe8/0x178 [ 12.084584] [<ffffff8008112610>] generic_handle_irq+0x2c/0x44 [ 12.085126] [<ffffff800811298c>] __handle_domain_irq+0xb8/0xbc [ 12.085669] [<ffffff8008080e7c>] gic_handle_irq+0xc8/0x180 [ 12.086186] Exception stack(0xffffff80092f3d70 to 0xffffff80092f3ea0) [ 12.086786] 3d60: ffffffc0f7edb200 00000040eec0e000 [ 12.087531] 3d80: ffffffc0f7edb200 ffffff80092f3e80 00ffffffffffffff 0000000021169dbf [ 12.088275] 3da0: 00000000000009a6 ffffffc0f7ed80c0 ffffff8009301a60 ffffff80092f3ec0 [ 12.089008] 3dc0: 0000000000000a30 0000000000000191 0000000000000063 0000000100000000 [ 12.089742] 3de0: 0000000000000001 0000000000000001 ffffff8008ef47c9 ffffff8008ef47c9 [ 12.090485] 3e00: 0000000000000000 000000012a05f3f5 ffffffc0ebbfd000 0000000000000060 [ 12.091219] 3e20: 0000000000000000 ffffff800941b3f8 0000000000000000 000000012a0576a2 [ 12.091963] 3e40: ffffff80093d4490 0000000002bc323c 00000000031e001c ffffff80092f3ea0 [ 12.092697] 3e60: ffffff8008953748 ffffff80092f3ea0 ffffff800895377c 0000000060000145 [ 12.093430] 3e80: ffffff80092f3ea0 ffffff8008953748 ffffffffffffffff ffffffc0ebbfd000 [ 12.094174] [<ffffff80080827b4>] el1_irq+0xb4/0x140 [ 12.094639] [<ffffff800895377c>] cpuidle_enter_state+0x1f8/0x25c [ 12.095204] [<ffffff8008953854>] cpuidle_enter+0x34/0x44 [ 12.095703] [<ffffff80080ff2a4>] call_cpuidle+0x70/0x78 [ 12.096200] [<ffffff80080ff554>] cpu_startup_entry+0x2a8/0x2b8 [ 12.096743] [<ffffff8008bb8848>] rest_init+0x74/0x7c [ 12.097216] [<ffffff80091e0b84>] start_kernel+0x3c8/0x3ec [ 12.097723] [<ffffff80091e01c4>] __primary_switched+0x30/0x6c Expand
SymbiosisSystems Posted February 23, 2021 Author Posted February 23, 2021 and crash on third boot after installing OMV Quote [ 19.255872] mali ff9a0000.gpu: temp=44444, pvtm=121661 (121625 + 36) [ 19.260398] mali ff9a0000.gpu: pvtm-volt-sel=1 [ 19.261244] mali ff9a0000.gpu: avs=0 [ 19.268262] mali ff9a0000.gpu: GPU identified as 0x0860 r2p0 status 0 [ 19.272100] mali ff9a0000.gpu: Protected mode not available [ 19.274416] mali ff9a0000.gpu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 [ 19.275510] mali ff9a0000.gpu: Using configured power model mali-simple-power-model, and fallback mali-simple-power-model [ 19.282384] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devfreq.c; [Line] : 423; [Func] : kbase_devfreq_init(); success initing power_model_simple. [ 19.286237] mali ff9a0000.gpu: Probed as mali0 [ 19.288815] rk-hdmi-dp-sound hdmi-dp-sound: i2s-hifi <-> ff8a0000.i2s mapping ok [ 19.289743] hdmi-audio-codec hdmi-audio-codec.5.auto: ASoC: Failed to create Playback debugfs file [ 19.306941] systemd[1]: Found device /dev/ttyFIQ0. [ 19.469284] usb 4-1.4: reset SuperSpeed USB device number 3 using xhci-hcd [ 19.475150] zram1: detected capacity change from 0 to 52428800 [ 19.537757] systemd[1]: Started Armbian ZRAM config. [ 19.600662] netif_napi_add() called with weight 256 on device eth%d [ 19.607932] r8152 4-1.4:1.0 eth1: v2.13.0 (2020/04/20) [ 19.614311] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents: [ 19.614311] US6,570,884, US6,115,776, and US6,327,625. [ 19.614311] [ 19.633577] usbcore: registered new interface driver r8152 [ 19.750945] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ 19.757989] systemd[1]: Starting Armbian memory supported logging... [ 19.762852] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped. [ 19.767343] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped. [ 19.770186] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped. [ 19.772693] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped. [ 19.835823] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard [ 20.600100] cfg80211: World regulatory domain updated: [ 20.608298] cfg80211: DFS Master region: unset [ 20.608822] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time) [ 20.624848] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A) [ 20.633294] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 20.641842] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A) [ 20.641849] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A) [ 20.641857] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s) [ 20.641863] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s) [ 20.641868] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A) [ 20.641874] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A) [ 20.661541] systemd[1]: Started Set console font and keymap. [ 21.631510] systemd[1]: Started Armbian memory supported logging. [ 21.639940] systemd[1]: Starting Journal Service... [ 21.876138] systemd[1]: Started Journal Service. [ 21.931187] systemd-journald[885]: Received request to flush runtime journal from PID 1 [ 22.561894] nr_pdflush_threads exported in /proc is scheduled for removal [ 27.531677] tty_port_close_start: tty->count = 1 port count = 2. [ 27.832346] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 27.879259] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 27.900235] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 28.442507] NET: Registered protocol family 17 Armbian 21.02.1 Buster ttyFIQ0 helios64 login: [ 29.836447] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off root Password: Last login: Tue Feb 23 09:27:31 GMT 2021 on ttyFIQ0 _ _ _ _ __ _ _ | | | | ___| (_) ___ ___ / /_ | || | | |_| |/ _ \ | |/ _ \/ __| '_ \| || |_ | _ | __/ | | (_) \__ \ (_) |__ _| |_| |_|\___|_|_|\___/|___/\___/ |_| Welcome to Armbian 21.02.1 Buster with Linux 4.4.213-rk3399 No end-user support: work in progress System load: 31% Up time: 0 min Memory usage: 3% of 3.72G IP: CPU temp: 50°C Usage of /: 5% of 29G root@helios64:~# hddtemp /dev/sd[a-e] /dev/sda: WDC WUH721818ALE6L4: 28°C /dev/sdb: WDC WUH721818ALE6L4: 28°C /dev/sdc: WDC WUH721818ALE6L4: 28°C /dev/sdd: WDC WUH721818ALE6L4: 27°C root@helios64:~# armbian-config Configuration utility, Armbian 21.02.1 stable, 195.198.8.121 ────────────────────────────────────────────────────────────────────────────── ┌───────────────Please wait─────────────────┐ │ │ │ Loading Armbian configuration utility ... │ │ │ └───────────────────────────────────────────┘ Configuration utility, Armbian 21.02.1 stable, 195.198.8.121 ────────────────────────────────────────────────────────────────────────────── ┌────────────────────────── armbian-config ─────────────────────────────┐ │ │ │ Configure Debian buster based Armbian for the Helios64 │ │ │ │ SoC runs between 408 and 1800 MHz using ondemand governor. │ │ │ │ Support: https://forum.armbian.com │ │ │ │ ┌───────────────────────────────────────────────────────────────────┐ │ │ │ System System and security settings │ │ │ │ Network Wired, wireless, Bluetooth, access point │ │ │ │ Personal Timezone, language, hostname │ │ │ │ Software System and 3rd party software install │ │ │ │ Help Documentation, support, sources │ │ │ └───────────────────────────────────────────────────────────────────┘ │ ├───────────────────────────────────────────────────────────────────────┤ │ < OK > < Exit > │ └───────────────────────────────────────────────────────────────────────┘ Configuration utility, Armbian 21.02.1 stable, 195.198.8.121 ────────────────────────────────────────────────────────────────────────────── ┌─────────Please wait────────────┐ │ │ │ Loading software submodule ... │ │ │ └────────────────────────────────┘ Configuration utility, Armbian 21.02.1 stable, 195.198.8.121 ────────────────────────────────────────────────────────────────────────────── ┌──────────────────System and 3rd party software─────────────────────┐ │ ┌────────────────────────────────────────────────────────────────┐ │ │ │ Softy 3rd party applications installer │ │ │ │ Monitor Simple CLI board monitoring │ │ │ │ Benchmarking sbc-bench board benchmarking │ │ │ │ Diagnostics Send diagnostics │ │ │ │ Headers_install kernel headers │ │ │ │ Source_install kernel source │ │ │ │ Full Install full firmware package │ │ │ └────────────────────────────────────────────────────────────────┘ │ ├────────────────────────────────────────────────────────────────────┤ │ < OK > < Back > │ └────────────────────────────────────────────────────────────────────┘ Configuration utility, Armbian 21.02.1 stable, 195.198.8.121 ────────────────────────────────────────────────────────────────────────────── ┌─────── Please wait ─────────┐ │ │ │ Loading softy submodule ... │ │ │ └─────────────────────────────┘ Softy - Armbian post deployment scripts, https://www.armbian.com ────────────────────────────────────────────────────────────────────────────── ┌──────Please wait─────────┐ │ │ │ Loading install info ... │ │ │ └──────────────────────────┘ So┌────────────────────Installing to Debian buster──────────────────────┐ ──│ │───── │ Choose what you want to install: │ │ │ │ ┌─────────────────────────────────────────────────────────────────┐ │ │ │ [ ] Samba Windows compatible file sharing │ │ │ │ [ ] CUPS Common UNIX Printing System (CUPS) │ │ │ │ [ ] TV headend TV streaming server │ │ │ │ [ ] Syncthing Personal cloud @syncthing.net │ │ │ │ [ ] Hassio Home assistant smarthome suite │ │ │ │ [ ] OpenHAB2 Openhab smarthome suite │ │ │ │ [ ] OpenHAB3 Openhab smarthome suite │ │ │ │ [ ] NCP Nextcloud personal cloud │ │ │ │ [*] OMV OpenMediaVault NAS solution │ │ │ │ [ ] Plex Plex media server │ │ │ │ [ ] Emby Emby server │ │ │ │ [ ] Radarr Movies downloading server │ │ │ │ [ ] Sonarr TV shows downloading server │ │ │ │ [ ] Minidlna Lightweight DLNA/UPnP-AV server │ │ │ └─────↓(+)────────────────────────────────────────────────70%─────┘ │ ├─────────────────────────────────────────────────────────────────────┤ │ <Install> <Cancel > │ └─────────────────────────────────────────────────────────────────────┘ Softy - Armbian post deployment scripts, https://www.armbian.com ────────────────────────────────────────────────────────────────────────────── ┌────────────────────────── Downloading ─────────────────────────────┐ │ Please wait │ │ │ │ ┌──────────────────────────────────────────────────────────────┐ │ │ │ 100% │ │ │ └──────────────────────────────────────────────────────────────┘ │ └────────────────────────────────────────────────────────────────────┘ Now installing OpenMediaVault. Be patient, it will take several minutes... [ 362.447781] lvm2-activation-generator: lvmconfig failed [ 362.449641] lvm2-activation-generator: Activation generator failed. [ 362.792087] lvm2-activation-generator: lvmconfig failed [ 362.794060] lvm2-activation-generator: Activation generator failed. [ 363.284285] lvm2-activation-generator: lvmconfig failed [ 363.286079] lvm2-activation-generator: Activation generator failed. [ 363.686299] lvm2-activation-generator: lvmconfig failed [ 363.690151] lvm2-activation-generator: Activation generator failed. [ 365.615139] lvm2-activation-generator: lvmconfig failed [ 365.617036] lvm2-activation-generator: Activation generator failed. [ 365.995708] lvm2-activation-generator: lvmconfig failed [ 365.997520] lvm2-activation-generator: Activation generator failed. [ 368.578690] lvm2-activation-generator: lvmconfig failed [ 368.582483] lvm2-activation-generator: Activation generator failed. [ 368.935064] lvm2-activation-generator: lvmconfig failed [ 368.938756] lvm2-activation-generator: Activation generator failed. [ 369.377568] lvm2-activation-generator: lvmconfig failed [ 369.379178] lvm2-activation-generator: Activation generator failed. [ 370.741216] lvm2-activation-generator: lvmconfig failed [ 370.745129] lvm2-activation-generator: Activation generator failed. [ 371.476029] lvm2-activation-generator: lvmconfig failed [ 371.477678] lvm2-activation-generator: Activation generator failed. [ 372.179404] lvm2-activation-generator: lvmconfig failed [ 372.183052] lvm2-activation-generator: Activation generator failed. [ 372.614750] lvm2-activation-generator: lvmconfig failed [ 372.618267] lvm2-activation-generator: Activation generator failed. [ 375.570873] lvm2-activation-generator: lvmconfig failed [ 375.572645] lvm2-activation-generator: Activation generator failed. [ 375.956921] lvm2-activation-generator: lvmconfig failed [ 375.958568] lvm2-activation-generator: Activation generator failed. [ 400.854284] lvm2-activation-generator: lvmconfig failed [ 400.857904] lvm2-activation-generator: Activation generator failed. [ 401.255218] lvm2-activation-generator: lvmconfig failed [ 401.258716] lvm2-activation-generator: Activation generator failed. [ 401.915002] lvm2-activation-generator: lvmconfig failed [ 401.916811] lvm2-activation-generator: Activation generator failed. [ 402.917996] lvm2-activation-generator: lvmconfig failed [ 402.919701] lvm2-activation-generator: Activation generator failed. [ 416.205233] lvm2-activation-generator: lvmconfig failed [ 416.208571] lvm2-activation-generator: Activation generator failed. [ 416.896487] lvm2-activation-generator: lvmconfig failed [ 416.897955] lvm2-activation-generator: Activation generator failed. [ 417.239755] lvm2-activation-generator: lvmconfig failed [ 417.241392] lvm2-activation-generator: Activation generator failed. [ 418.002236] lvm2-activation-generator: lvmconfig failed [ 418.003973] lvm2-activation-generator: Activation generator failed. [ 418.735913] lvm2-activation-generator: lvmconfig failed [ 418.739035] lvm2-activation-generator: Activation generator failed. [ 421.246893] lvm2-activation-generator: lvmconfig failed [ 421.249874] lvm2-activation-generator: Activation generator failed. [ 421.717364] lvm2-activation-generator: lvmconfig failed [ 421.720287] lvm2-activation-generator: Activation generator failed. [ 422.129259] lvm2-activation-generator: lvmconfig failed [ 422.130832] lvm2-activation-generator: Activation generator failed. [ 422.617320] lvm2-activation-generator: lvmconfig failed [ 422.620309] lvm2-activation-generator: Activation generator failed. [ 425.499225] lvm2-activation-generator: lvmconfig failed [ 425.500761] lvm2-activation-generator: Activation generator failed. [ 426.081921] lvm2-activation-generator: lvmconfig failed [ 426.083552] lvm2-activation-generator: Activation generator failed. [ 439.890626] lvm2-activation-generator: lvmconfig failed [ 439.892191] lvm2-activation-generator: Activation generator failed. [ 440.280891] lvm2-activation-generator: lvmconfig failed [ 440.283940] lvm2-activation-generator: Activation generator failed. [ 440.667616] RPC: Registered named UNIX socket transport module. [ 440.670694] RPC: Registered udp transport module. [ 440.673508] RPC: Registered tcp transport module. [ 440.676231] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 440.731707] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 442.558776] lvm2-activation-generator: lvmconfig failed [ 442.561750] lvm2-activation-generator: Activation generator failed. [ 442.914890] lvm2-activation-generator: lvmconfig failed [ 442.918161] lvm2-activation-generator: Activation generator failed. [ 443.322123] NFSD: starting 90-second grace period (net ffffff80093ea4c0) [ 448.501941] lvm2-activation-generator: lvmconfig failed [ 448.503715] lvm2-activation-generator: Activation generator failed. [ 449.001585] lvm2-activation-generator: lvmconfig failed [ 449.004903] lvm2-activation-generator: Activation generator failed. [ 449.368884] lvm2-activation-generator: lvmconfig failed [ 449.370570] lvm2-activation-generator: Activation generator failed. [ 462.619962] lvm2-activation-generator: lvmconfig failed [ 462.623249] lvm2-activation-generator: Activation generator failed. [ 463.372140] lvm2-activation-generator: lvmconfig failed [ 463.373696] lvm2-activation-generator: Activation generator failed. [ 464.083544] lvm2-activation-generator: lvmconfig failed [ 464.085138] lvm2-activation-generator: Activation generator failed. [ 464.552991] lvm2-activation-generator: lvmconfig failed [ 464.556273] lvm2-activation-generator: Activation generator failed. [ 465.035334] lvm2-activation-generator: lvmconfig failed [ 465.038485] lvm2-activation-generator: Activation generator failed. [ 466.335717] lvm2-activation-generator: lvmconfig failed [ 466.337187] lvm2-activation-generator: Activation generator failed. [ 466.940899] lvm2-activation-generator: lvmconfig failed [ 466.944154] lvm2-activation-generator: Activation generator failed. [ 467.447974] lvm2-activation-generator: lvmconfig failed [ 467.451133] lvm2-activation-generator: Activation generator failed. [ 468.114443] lvm2-activation-generator: lvmconfig failed [ 468.115880] lvm2-activation-generator: Activation generator failed. [ 469.061060] lvm2-activation-generator: lvmconfig failed [ 469.064286] lvm2-activation-generator: Activation generator failed. [ 469.446355] lvm2-activation-generator: lvmconfig failed [ 469.449611] lvm2-activation-generator: Activation generator failed. [ 469.852084] lvm2-activation-generator: lvmconfig failed [ 469.853656] lvm2-activation-generator: Activation generator failed. [ 474.483783] lvm2-activation-generator: lvmconfig failed [ 474.485506] lvm2-activation-generator: Activation generator failed. [ 474.902353] lvm2-activation-generator: lvmconfig failed [ 474.903899] lvm2-activation-generator: Activation generator failed. [ 475.297920] lvm2-activation-generator: lvmconfig failed [ 475.301176] lvm2-activation-generator: Activation generator failed. [ 476.184363] lvm2-activation-generator: lvmconfig failed [ 476.186053] lvm2-activation-generator: Activation generator failed. [ 476.657261] lvm2-activation-generator: lvmconfig failed [ 476.660657] lvm2-activation-generator: Activation generator failed. [ 477.229261] lvm2-activation-generator: lvmconfig failed [ 477.230801] lvm2-activation-generator: Activation generator failed. [ 477.623406] lvm2-activation-generator: lvmconfig failed [ 477.624904] lvm2-activation-generator: Activation generator failed. [ 478.430152] lvm2-activation-generator: lvmconfig failed [ 478.431667] lvm2-activation-generator: Activation generator failed. [ 479.501144] lvm2-activation-generator: lvmconfig failed [ 479.502722] lvm2-activation-generator: Activation generator failed. [ 480.285300] lvm2-activation-generator: lvmconfig failed [ 480.288433] lvm2-activation-generator: Activation generator failed. [ 480.714939] lvm2-activation-generator: lvmconfig failed [ 480.718095] lvm2-activation-generator: Activation generator failed. [ 481.603966] lvm2-activation-generator: lvmconfig failed [ 481.605600] lvm2-activation-generator: Activation generator failed. [ 482.040658] lvm2-activation-generator: lvmconfig failed [ 482.042240] lvm2-activation-generator: Activation generator failed. [ 491.006250] nfsd: last server has exited, flushing export cache Now applying board tweak if required... Softy - Armbian post deployment scripts, https://www.armbian.com ────────────────────────────────────────────────────────────────────────────── ┌──────Please wait─────────┐ │ │ │ Loading install info ... │ │ │ └──────────────────────────┘ [ 1077.320928] tty_port_close_start: tty->count = 1 port count = 3. [ 1080.509584] dw_wdt: unexpected close, system will reboot soon [ 1080.553832] systemd-shutdown[1]: Syncing filesystems and block devices. [ 1080.616689] systemd-shutdown[1]: Sending SIGTERM to remaining processes... [ 1080.633619] systemd-journald[885]: Received SIGTERM from PID 1 (systemd-shutdow). [ 1080.644670] systemd-shutdown[1]: Sending SIGKILL to remaining processes... [ 1080.658752] systemd-shutdown[1]: Hardware watchdog 'Synopsys DesignWare Watchdog', version 0 [ 1080.664845] systemd-shutdown[1]: Unmounting file systems. [ 1080.671090] [10646]: Remounting '/' read-only in with options 'errors=remount-ro,commit=600'. [ 1080.841962] EXT4-fs (mmcblk0p1): re-mounted. Opts: errors=remount-ro,commit=600 [ 1080.867131] systemd-shutdown[1]: All filesystems unmounted. [ 1080.870985] systemd-shutdown[1]: Deactivating swaps. [ 1080.874869] systemd-shutdown[1]: All swaps deactivated. [ 1080.878559] systemd-shutdown[1]: Detaching loop devices. [ 1080.885076] systemd-shutdown[1]: All loop devices detached. [ 1080.888853] systemd-shutdown[1]: Detaching DM devices. [ 1080.892808] systemd-shutdown[1]: All DM devices detached. [ 1080.896527] systemd-shutdown[1]: All filesystems, swaps, loop devices and DM devices detached. [ 1081.142894] systemd-shutdown[1]: Syncing filesystems and block devices. [ 1081.148970] systemd-shutdown[1]: Rebooting. [ 1081.152736] kvm: exiting hardware virtualization [ 1081.156676] cpu cpu4: min=816000, max=816000 [ 1081.161184] cpu cpu0: min=816000, max=816000 [ 1081.169202] sd 3:0:0:0: [sdd] Synchronizing SCSI cache [ 1081.177524] sd 2:0:0:0: [sdc] Synchronizing SCSI cache [ 1081.185806] sd 1:0:0:0: [sdb] Synchronizing SCSI cache [ 1081.193922] sd 0:0:0:0: [sda] Synchronizing SCSI cache DDR Version 1.24 20191016 In soft reset SRX channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 323 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 80589 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe5af4 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Feb 03 2021 - 22:43:01 +0100) SoC: Rockchip rk3399 Reset cause: WDOG DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: eth0: ethernet@fe300000 scanning bus for devices... starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 4!? 4 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 5 ms (622.1 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 166 bytes read in 4 ms (40 KiB/s) 10390562 bytes read in 445 ms (22.3 MiB/s) 20770824 bytes read in 883 ms (22.4 MiB/s) 101557 bytes read in 13 ms (7.5 MiB/s) 2698 bytes read in 8 ms (329.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 10390498 Bytes = 9.9 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f5506000, end f5eeebe2 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0) Loading Device Tree to 00000000f5484000, end 00000000f5505fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.213-rk3399 (root@beast) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #14 SMP Wed Feb 3 20:52:28 CET 2021 [ 0.000000] Boot CPU: AArch64 Processor [410fd034] [ 0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] PERCPU: Embedded 20 pages/cpu @ffffffc0f7ed2000 s42216 r8192 d31512 u81920 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 999432 [ 0.000000] Kernel command line: root=UUID=c99fadcc-25b5-485d-85e6-d859de7ee644 rootwait rootfstype=ext4 console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel=7 ubootpart=50f571e6-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0xeea00000-0xf2a00000] (64MB) [ 0.000000] Memory: 3889792K/4061184K available (11582K kernel code, 1404K rwdata, 6148K rodata, 1088K init, 1956K bss, 171392K reserved, 0K cma-reserved) [ 0.000000] Virtual kernel memory layout: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB) [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000 ( 246 GB) [ 0.000000] .init : 0xffffff80091e0000 - 0xffffff80092f0000 ( 1088 KB) [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008bd0000 ( 11584 KB) [ 0.000000] .rodata : 0xffffff8008bd0000 - 0xffffff80091e0000 ( 6208 KB) [ 0.000000] .data : 0xffffff80092f0000 - 0xffffff800944f008 ( 1405 KB) [ 0.000000] vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum) [ 0.000000] 0xffffffbdc0008000 - 0xffffffbdc3e00000 ( 61 MB actual) [ 0.000000] fixed : 0xffffffbffe7fb000 - 0xffffffbffec00000 ( 4116 KB) [ 0.000000] PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000 ( 16 MB) [ 0.000000] memory : 0xffffffc000200000 - 0xffffffc0f8000000 ( 3966 MB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 64. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6 [ 0.000000] NR_IRQS:64 nr_irqs:64 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000 [ 0.000000] ITS: allocated 65536 Devices @ee500000 (psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000000ee490000 [ 0.000000] ITS: Allocated 1792 chunks for LPIs [ 0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] CPU0: using LPI pending table @0x00000000ee4a0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work [ 0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001491] Console: colour dummy device 80x25 [ 0.003372] console [tty1] enabled [ 0.003468] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.003534] pid_max: default: 32768 minimum: 301 [ 0.003680] Security Framework initialized [ 0.003716] Yama: becoming mindful. [ 0.003766] AppArmor: AppArmor disabled by boot time parameter [ 0.003847] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.003888] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes) [ 0.004687] Initializing cgroup subsys io [ 0.004732] Initializing cgroup subsys memory [ 0.004791] Initializing cgroup subsys devices [ 0.004831] Initializing cgroup subsys freezer [ 0.004869] Initializing cgroup subsys net_cls [ 0.004907] Initializing cgroup subsys perf_event [ 0.004946] Initializing cgroup subsys net_prio [ 0.004989] Initializing cgroup subsys hugetlb [ 0.005025] Initializing cgroup subsys pids [ 0.005092] ftrace: allocating 41873 entries in 164 pages [ 0.120353] sched-energy: Sched-energy-costs installed from DT [ 0.120404] CPU0: update cpu_capacity 401 [ 0.120490] ASID allocator initialised with 32768 entries [ 0.123570] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.124197] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.125728] Detected VIPT I-cache on CPU1 [ 0.125767] CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.125804] CPU1: using LPI pending table @0x00000000ee730000 [ 0.125865] CPU1: update cpu_capacity 401 [ 0.125869] CPU1: Booted secondary processor [410fd034] [ 0.126668] Detected VIPT I-cache on CPU2 [ 0.126702] CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.126739] CPU2: using LPI pending table @0x00000000ee760000 [ 0.126795] CPU2: update cpu_capacity 401 [ 0.126800] CPU2: Booted secondary processor [410fd034] [ 0.127665] Detected VIPT I-cache on CPU3 [ 0.127696] CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.127732] CPU3: using LPI pending table @0x00000000ee7b0000 [ 0.127787] CPU3: update cpu_capacity 401 [ 0.127791] CPU3: Booted secondary processor [410fd034] [ 0.128630] Detected PIPT I-cache on CPU4 [ 0.128656] CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.128694] CPU4: using LPI pending table @0x00000000ee7f0000 [ 0.128730] CPU4: update cpu_capacity 1024 [ 0.128734] CPU4: Booted secondary processor [410fd082] [ 0.129429] Detected PIPT I-cache on CPU5 [ 0.129455] CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.129494] CPU5: using LPI pending table @0x00000000edc20000 [ 0.129532] CPU5: update cpu_capacity 1024 [ 0.129536] CPU5: Booted secondary processor [410fd082] [ 0.129640] Brought up 6 CPUs [ 0.130360] SMP: Total of 6 processors activated. [ 0.130393] CPU features: detected feature: GIC system register CPU interface [ 0.130431] CPU features: detected feature: 32-bit EL0 Support [ 0.130467] CPU: All CPU(s) started at EL2 [ 0.130540] alternatives: patching kernel code [ 0.132024] devtmpfs: initialized [ 0.149634] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.149694] futex hash table entries: 2048 (order: 5, 131072 bytes) [ 0.150202] xor: measuring software checksum speed [ 0.187353] 8regs : 2855.000 MB/sec [ 0.227416] 8regs_prefetch: 2558.000 MB/sec [ 0.267477] 32regs : 3211.000 MB/sec [ 0.307540] 32regs_prefetch: 2840.000 MB/sec [ 0.307561] xor: using function: 32regs (3211.000 MB/sec) [ 0.307599] pinctrl [ 0.644088] raid6: int64x2 gen() 753 MB/s [ 0.712202] raid6: int64x2 xor() 608 MB/s [ 0.780309] raid6: int64x4 gen() 945 MB/s [ 0.848373] raid6: int64x4 xor() 672 MB/s [ 0.916485] raid6: int64x8 gen() 866 MB/s [ 0.984604] raid6: int64x8 xor() 608 MB/s [ 1.052729] raid6: neonx1 gen() 906 MB/s [ 1.120829] raid6: neonx1 xor() 679 MB/s [ 1.188925] raid6: neonx2 gen() 1521 MB/s [ 1.257028] raid6: neonx2 xor() 977 MB/s [ 1.325109] raid6: neonx4 gen() 1767 MB/s [ 1.393219] raid6: neonx4 xor() 1138 MB/s [ 1.461307] raid6: neonx8 gen() 1696 MB/s [ 1.529412] raid6: neonx8 xor() 1244 MB/s [ 1.529803] raid6: using algorithm neonx4 gen() 1767 MB/s [ 1.530297] raid6: .... xor() 1138 MB/s, rmw enabled [ 1.530755] raid6: using intx1 recovery algorithm [ 1.532967] vcc12v_dcin_bkup: supplied by vcc12v_dcin [ 1.533738] vcc12v_hdd: supplied by vcc12v_dcin_bkup [ 1.534617] vcc1v8_sys_s0: regulator get failed, ret=-517 [ 1.535423] vcc0v9_s3: regulator get failed, ret=-517 [ 1.536193] avdd_0v9_s0: regulator get failed, ret=-517 [ 1.537083] avdd_1v8_s0: regulator get failed, ret=-517 [ 1.552907] pcie_power: regulator get failed, ret=-517 [ 1.553874] vcc3v3_sys_s3: regulator get failed, ret=-517 [ 1.580993] vcc3v0_sd: regulator get failed, ret=-517 [ 1.582284] vcc5v0_usb: regulator get failed, ret=-517 [ 1.583349] vcc5v0_perdev: supplied by vcc12v_dcin_bkup [ 1.584288] pcie_power: supplied by vcc5v0_perdev [ 1.584951] vcc5v0_usb: supplied by vcc5v0_perdev [ 1.585545] vcc5v0_hdd: supplied by vcc12v_dcin_bkup [ 1.586678] vcc5v0_sys: supplied by vcc12v_dcin_bkup [ 1.587441] vcc3v3_sys_s3: supplied by vcc5v0_sys [ 1.587904] vcc0v9_s3: supplied by vcc3v3_sys_s3 [ 1.588437] avdd_1v8_s0: supplied by vcc3v3_sys_s3 [ 1.588955] vcc3v0_sd: supplied by vcc3v3_sys_s3 [ 1.590437] usblan_power: supplied by vcc5v0_usb [ 1.591857] iommu: Adding device ff650000.vpu_service to group 0 [ 1.592478] iommu: Adding device ff660000.rkvdec to group 1 [ 1.593115] iommu: Adding device ff8f0000.vop to group 2 [ 1.593685] iommu: Adding device ff900000.vop to group 3 [ 1.594689] rk_iommu ff650800.iommu: can't get sclk [ 1.595419] rk_iommu ff660480.iommu: can't get sclk [ 1.596075] rk_iommu ff8f3f00.iommu: can't get sclk [ 1.596689] rk_iommu ff903f00.iommu: can't get sclk [ 1.597550] SCSI subsystem initialized [ 1.598328] usbcore: registered new interface driver usbfs [ 1.598878] usbcore: registered new interface driver hub [ 1.599458] usbcore: registered new device driver usb [ 1.600005] media: Linux media interface: v0.10 [ 1.600447] Linux video capture interface: v2.00 [ 1.600978] pps_core: LinuxPPS API ver. 1 registered [ 1.601439] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.602298] PTP clock support registered [ 1.603884] Advanced Linux Sound Architecture Driver Initialized. [ 1.605343] NetLabel: Initializing [ 1.605666] NetLabel: domain hash size = 128 [ 1.606068] NetLabel: protocols = UNLABELED CIPSOv4 [ 1.606575] NetLabel: unlabeled traffic allowed by default [ 1.607350] rockchip-cpuinfo cpuinfo: Serial : 85afff6e2668ee33 [ 1.608521] clocksource: Switched to clocksource arch_sys_counter [ 1.656212] thermal thermal_zone1: power_allocator: sustainable_power will be estimated [ 1.657102] NET: Registered protocol family 2 [ 1.657969] TCP established hash table entries: 32768 (order: 6, 262144 bytes) [ 1.658894] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes) [ 1.660314] TCP: Hash tables configured (established 32768 bind 32768) [ 1.661060] UDP hash table entries: 2048 (order: 5, 196608 bytes) [ 1.661773] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes) [ 1.662800] NET: Registered protocol family 1 [ 1.663984] Trying to unpack rootfs image as initramfs... [ 2.179789] Freeing initrd memory: 10144K [ 2.180728] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.181566] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available [ 2.183910] kvm [1]: 8-bit VMID [ 2.184211] kvm [1]: Hyp mode initialized successfully [ 2.184844] kvm [1]: interrupt-controller@fff20000 IRQ10 [ 2.185541] kvm [1]: timer IRQ12 [ 2.189203] audit: initializing netlink subsys (disabled) [ 2.189752] audit: type=2000 audit(2.112:1): initialized [ 2.190633] Initialise system trusted keyring [ 2.191429] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 2.199310] VFS: Disk quotas dquot_6.6.0 [ 2.199836] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 2.201903] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.203100] fuse init (API version 7.23) [ 2.204021] JFS: nTxBlock = 8192, nTxLock = 65536 [ 2.209973] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 2.212370] Key type big_key registered [ 2.212777] [ 2.212777] TEE Core Framework initialization (ver 1:0.1) [ 2.213435] TEE armv7 Driver initialization [ 2.214313] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0" [ 2.214918] TEE core: Alloc the misc device "opteearmtz00" (id=0) [ 2.215660] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62) [ 2.221717] Key type asymmetric registered [ 2.222110] Asymmetric key parser 'x509' registered [ 2.222751] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244) [ 2.223577] io scheduler noop registered [ 2.223951] io scheduler deadline registered (default) [ 2.224455] io scheduler cfq registered [ 2.226468] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator [ 2.234469] rk-vcodec ff650000.vpu_service: no regulator for vcodec [ 2.235271] rk-vcodec ff650000.vpu_service: probe device [ 2.235981] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled [ 2.237167] rk-vcodec ff650000.vpu_service: could not find power_model node [ 2.237806] rk-vcodec ff650000.vpu_service: init success [ 2.238526] rk-vcodec ff660000.rkvdec: no regulator for vcodec [ 2.239446] rk-vcodec ff660000.rkvdec: probe device [ 2.240088] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled [ 2.241082] rk-vcodec ff660000.rkvdec: could not find power_model node [ 2.241675] rk-vcodec ff660000.rkvdec: init success [ 2.243654] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.244353] dma-pl330 ff6d0000.dma-controller: DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12 [ 2.246634] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330 [ 2.247332] dma-pl330 ff6e0000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 2.249332] rockchip-system-monitor rockchip-system-monitor: system monitor probe [ 2.251489] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled [ 2.253305] [drm] Initialized drm 1.1.0 20060810 [ 2.257255] [drm] Rockchip DRM driver version: v1.0.1 [ 2.260087] Unable to detect cache hierarchy for CPU 0 [ 2.261405] brd: module loaded [ 2.267180] loop: module loaded [ 2.267867] lkdtm: No crash points registered, enable through debugfs [ 2.269647] rockchip-spi ff1d0000.spi: no high_speed pinctrl state [ 2.270722] m25p80 spi0.0: w25q128 (16384 Kbytes) [ 2.272351] rockchip-spi ff1e0000.spi: no high_speed pinctrl state [ 2.273564] rockchip-spi ff200000.spi: no high_speed pinctrl state [ 2.276161] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 2.276830] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 2.277352] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). [ 2.277887] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 2.278617] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 2.279252] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 2.284813] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 2.285436] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 2.285896] Ring mode enabled [ 2.286182] DMA HW capability register supported [ 2.286585] Normal descriptors [ 2.286917] RX Checksum Offload Engine supported (type 2) [ 2.287421] TX Checksum insertion supported [ 2.287810] Wake-Up On Lan supported [ 2.288188] Enable RX Mitigation via HW Watchdog Timer [ 2.377641] libphy: stmmac: probed [ 2.378000] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active [ 2.378599] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01) [ 2.381542] usbcore: registered new interface driver rndis_wlan [ 2.382347] Rockchip WiFi SYS interface (V1.00) ... [ 2.382916] usbcore: registered new interface driver cdc_ether [ 2.383504] usbcore: registered new interface driver rndis_host [ 2.386133] rockchip-dwc3 usb0: failed to get drvdata dwc3 [ 2.391577] rockchip-dwc3 usb1: fail to get drvdata hcd [ 2.393900] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.394514] ehci-pci: EHCI PCI platform driver [ 2.394990] ehci-platform: EHCI generic platform driver [ 2.396120] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.396720] ohci-platform: OHCI generic platform driver [ 2.398048] usbcore: registered new interface driver cdc_acm [ 2.398568] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 2.399335] usbcore: registered new interface driver cdc_wdm [ 2.399926] usbcore: registered new interface driver usbserial [ 2.400480] usbcore: registered new interface driver usbserial_generic [ 2.401130] usbserial: USB Serial support registered for generic [ 2.402523] usbcore: registered new interface driver iforce [ 2.403078] usbcore: registered new interface driver xpad [ 2.403748] usbcore: registered new interface driver usbtouchscreen [ 2.404318] <<-GTP-INFO->> GTP driver installing [ 2.405218] sensor_register_slave:mma8452,id=17 [ 2.405642] sensor_register_slave:lis3dh,id=7 [ 2.406049] sensor_register_slave:mma7660,id=18 [ 2.406467] sensor_register_slave:lsm303d,id=22 [ 2.406885] sensor_register_slave:mpu6880_acc,id=24 [ 2.407337] sensor_register_slave:mpu6500_acc,id=25 [ 2.407788] sensor_register_slave:lsm330_acc,id=26 [ 2.408229] sensor_register_slave:akm8975,id=30 [ 2.408675] sensor_register_slave:akm8963,id=31 [ 2.409094] sensor_register_slave:l3g4200d,id=45 [ 2.409522] sensor_register_slave:l3g20d,id=46 [ 2.409938] sensor_register_slave:ewtsa,id=47 [ 2.410344] sensor_register_slave:lsm330_gyro,id=51 [ 2.410795] sensor_register_slave:cm3217,id=53 [ 2.411212] sensor_register_slave:cm3218,id=54 [ 2.412112] i2c /dev entries driver [ 2.413724] rk808 0-001b: Pmic Chip id: 0x0 [ 2.416901] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 2.417525] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 2.418212] DCDC_REG1: supplied by vcc5v0_sys [ 2.419495] DCDC_REG2: supplied by vcc5v0_sys [ 2.420603] DCDC_REG3: supplied by vcc5v0_sys [ 2.421401] DCDC_REG4: supplied by vcc5v0_sys [ 2.422221] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 [ 2.422733] avdd_0v9_s0: supplied by vcc1v8_sys_s3 [ 2.423307] LDO_REG1: supplied by vcc5v0_sys [ 2.424337] LDO_REG2: supplied by vcc5v0_sys [ 2.425260] LDO_REG3: supplied by vcc5v0_sys [ 2.426680] LDO_REG4: supplied by vcc5v0_sys [ 2.428098] LDO_REG5: supplied by vcc5v0_sys [ 2.429031] LDO_REG6: supplied by vcc5v0_sys [ 2.430447] LDO_REG7: supplied by vcc5v0_sys [ 2.431359] LDO_REG8: supplied by vcc5v0_sys [ 2.432791] SWITCH_REG1: supplied by vcc3v3_sys_s3 [ 2.433574] SWITCH_REG2: supplied by vcc3v3_sys_s3 [ 2.437453] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 2.439141] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 2.439829] fan53555-reg: supplied by vcc5v0_sys [ 2.442448] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 2.443130] fan53555-reg: supplied by vcc5v0_sys [ 2.445270] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80097ce000 [ 2.447790] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80097d0000 [ 2.449006] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at ffffff80097d2000 [ 2.454070] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, try_role ROLE_MODE_UFP [ 2.455029] input: Typec_Headphone as /devices/platform/ff3d0000.i2c/i2c-4/4-0022/input/input0 [ 2.456022] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d4000 [ 2.457220] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80097d6000 [ 2.459772] usbcore: registered new interface driver uvcvideo [ 2.460303] USB Video Class driver (1.1.1) [ 2.463169] B [ 2.545492] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized [ 2.547661] sdhci-pltfm: SDHCI platform and OF driver helper [ 2.550429] sdhci-arasan fe330000.sdhci: No vmmc regulator found [ 2.550980] sdhci-arasan fe330000.sdhci: No vqmmc regulator found [ 2.584768] mmc1: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 2.590261] ledtrig-cpu: registered to indicate activity on CPUs [ 2.590949] hidraw: raw HID events driver (C) Jiri Kosina [ 2.591984] usbcore: registered new interface driver usbhid [ 2.592496] usbhid: USB HID core driver [ 2.593210] ashmem: initialized [ 2.603494] Initializing XFRM netlink socket [ 2.604550] NET: Registered protocol family 10 [ 2.606253] lib80211: common routines for IEEE802.11 drivers [ 2.606830] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.607606] [BT_RFKILL]: Enter rfkill_rk_init [ 2.608241] Key type dns_resolver registered [ 2.608259] fusb302 4-0022: CC connected in CC2 as UFP [ 2.609460] sensor_register_slave:mpu6880_gyro,id=50 [ 2.610097] Error: Driver 'ov7750' is already registered, aborting... [ 2.610725] Error: Driver 'ov8858' is already registered, aborting... [ 2.611491] Error: Driver 'sc031gs' is already registered, aborting... [ 2.613856] Registered cp15_barrier emulation handler [ 2.613936] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 2.614722] mmc0: new high speed SDHC card at address aaaa [ 2.615860] mmcblk0: mmc0:aaaa SM32G 29.7 GiB [ 2.615929] Registered setend emulation handler [ 2.617690] registered taskstats version 1 [ 2.618083] Loading compiled-in X.509 certificates [ 2.618548] mmcblk0: p1 [ 2.621296] Btrfs loaded, integrity-checker=on [ 2.621778] BTRFS: selftest: Running btrfs free space cache tests [ 2.622351] BTRFS: selftest: Running extent only tests [ 2.622835] BTRFS: selftest: Running bitmap only tests [ 2.623319] BTRFS: selftest: Running bitmap and extent tests [ 2.623857] BTRFS: selftest: Running space stealing from bitmap to extent [ 2.625220] BTRFS: selftest: Free space cache tests finished [ 2.625739] BTRFS: selftest: Running extent buffer operation tests [ 2.626270] BTRFS: selftest: Running btrfs_split_item tests [ 2.626842] BTRFS: selftest: Running find delalloc tests [ 2.670351] mmc1: new HS200 MMC card at address 0001 [ 2.671521] mmcblk1: mmc1:0001 AJTD4R 14.6 GiB [ 2.672416] mmcblk1boot0: mmc1:0001 AJTD4R partition 1 4.00 MiB [ 2.673694] mmcblk1boot1: mmc1:0001 AJTD4R partition 2 4.00 MiB [ 2.674968] mmcblk1rpmb: mmc1:0001 AJTD4R partition 3 4.00 MiB [ 2.773069] BTRFS: selftest: Running btrfs_get_extent tests [ 2.773710] BTRFS: selftest: Running hole first btrfs_get_extent test [ 2.774297] BTRFS: selftest: Running outstanding_extents tests [ 2.774856] BTRFS: selftest: Running qgroup tests [ 2.775277] BTRFS: selftest: Qgroup basic add [ 2.775706] BTRFS: selftest: Qgroup multiple refs test [ 2.821260] Key type encrypted registered [ 2.822557] rga2: Driver loaded successfully ver:3.02 [ 2.823199] rga2: Module initialized. [ 2.824431] phy phy-ff770000.syscon:usb2-phy@e450.7: Failed to get VBUS supply regulator [ 2.830754] rockchip-pcie f8000000.pcie: bus-scan-delay-ms in device tree is 2000 ms [ 2.831534] rockchip-pcie f8000000.pcie: missing "memory-region" property [ 2.832195] PCI host bridge /pcie@f8000000 ranges: [ 2.832811] MEM 0xfa000000..0xfbdfffff -> 0xfa000000 [ 2.833338] IO 0xfbe00000..0xfbefffff -> 0xfbe00000 [ 2.833957] rockchip-pcie f8000000.pcie: invalid power supply [ 2.931204] random: nonblocking pool is initialized [ 2.937672] rockchip-pcie f8000000.pcie: wait 2000 ms (from device tree) before bus scan [ 3.117998] vendor storage:20190527 ret = 0 [ 4.940963] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 4.941632] pci_bus 0000:00: root bus resource [bus 00-1f] [ 4.942180] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 4.942857] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 4.944657] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.945939] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 4.946677] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 4.947413] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 4.948148] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 4.948910] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 4.956713] pci 0000:00:00.0: BAR 8: assigned [mem 0xfa000000-0xfa0fffff] [ 4.957381] pci 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff] [ 4.957983] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [ 4.958719] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] [ 4.959383] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x107f] [ 4.959999] pci 0000:01:00.0: BAR 1: assigned [io 0x1080-0x10ff] [ 4.960647] pci 0000:01:00.0: BAR 2: assigned [io 0x1100-0x117f] [ 4.961272] pci 0000:01:00.0: BAR 3: assigned [io 0x1180-0x11ff] [ 4.961877] pci 0000:01:00.0: BAR 4: assigned [io 0x1200-0x127f] [ 4.962492] pci 0000:00:00.0: PCI bridge to [bus 01] [ 4.963012] pci 0000:00:00.0: bridge window [io 0x1000-0x1fff] [ 4.963608] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 4.964467] pcieport 0000:00:00.0: enabling device (0000 -> 0003) [ 4.965588] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt [ 4.966275] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt [ 4.967416] ahci 0000:01:00.0: enabling device (0000 -> 0003) [ 4.968576] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled [ 4.969342] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 4.970154] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh [ 4.976849] scsi host0: ahci [ 4.978202] scsi host1: ahci [ 4.979664] scsi host2: ahci [ 4.981032] scsi host3: ahci [ 4.982327] scsi host4: ahci [ 4.982835] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 255 [ 4.983541] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 256 [ 4.984238] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 257 [ 4.984962] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 258 [ 4.985659] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 259 [ 4.991469] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 4.992363] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 4.993258] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010 [ 4.994102] xhci-hcd xhci-hcd.2.auto: irq 223, io mem 0xfe800000 [ 4.994881] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.995504] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.996171] usb usb1: Product: xHCI Host Controller [ 4.996635] usb usb1: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 4.997198] usb usb1: SerialNumber: xhci-hcd.2.auto [ 4.998466] hub 1-0:1.0: USB hub found [ 4.998874] hub 1-0:1.0: 1 port detected [ 4.999632] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 5.000335] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 5.001170] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.002048] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 5.002677] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.003352] usb usb2: Product: xHCI Host Controller [ 5.003812] usb usb2: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 5.004376] usb usb2: SerialNumber: xhci-hcd.2.auto [ 5.005425] hub 2-0:1.0: USB hub found [ 5.005818] hub 2-0:1.0: 1 port detected [ 5.008282] xhci-hcd xhci-hcd.2.auto: remove, state 1 [ 5.008812] usb usb2: USB disconnect, device number 1 [ 5.013874] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 5.014579] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 3 [ 5.015456] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x06030010 [ 5.016311] xhci-hcd xhci-hcd.3.auto: irq 224, io mem 0xfe900000 [ 5.017154] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.017784] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.018459] usb usb3: Product: xHCI Host Controller [ 5.018919] usb usb3: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 5.019483] usb usb3: SerialNumber: xhci-hcd.3.auto [ 5.020507] hub 3-0:1.0: USB hub found [ 5.020927] hub 3-0:1.0: 1 port detected [ 5.021656] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller [ 5.022333] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 4 [ 5.023122] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 5.023996] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003 [ 5.024645] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.025320] usb usb4: Product: xHCI Host Controller [ 5.025779] usb usb4: Manufacturer: Linux 4.4.213-rk3399 xhci-hcd [ 5.026015] xhci-hcd xhci-hcd.2.auto: Host not halted after 16000 microseconds. [ 5.026022] xhci-hcd xhci-hcd.2.auto: Host controller not halted, aborting reset. [ 5.026067] xhci-hcd xhci-hcd.2.auto: USB bus 2 deregistered [ 5.028235] usb usb4: SerialNumber: xhci-hcd.3.auto [ 5.029274] hub 4-0:1.0: USB hub found [ 5.029660] hub 4-0:1.0: 1 port detected [ 5.031045] xhci-hcd xhci-hcd.2.auto: remove, state 1 [ 5.031537] usb usb1: USB disconnect, device number 1 [ 5.033140] xhci-hcd xhci-hcd.2.auto: USB bus 1 deregistered [ 5.034853] ehci-platform fe380000.usb: EHCI Host Controller [ 5.035578] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [ 5.036621] ehci-platform fe380000.usb: irq 27, io mem 0xfe380000 [ 5.048614] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 5.049574] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 5.050222] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.050934] usb usb1: Product: EHCI Host Controller [ 5.051409] usb usb1: Manufacturer: Linux 4.4.213-rk3399 ehci_hcd [ 5.051990] usb usb1: SerialNumber: fe380000.usb [ 5.053603] hub 1-0:1.0: USB hub found [ 5.054058] hub 1-0:1.0: 1 port detected [ 5.056276] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 5.057403] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2 [ 5.058398] ohci-platform fe3a0000.usb: irq 28, io mem 0xfe3a0000 [ 5.116753] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 5.117394] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 5.118082] usb usb2: Product: Generic Platform OHCI controller [ 5.118636] usb usb2: Manufacturer: Linux 4.4.213-rk3399 ohci_hcd [ 5.119201] usb usb2: SerialNumber: fe3a0000.usb [ 5.120654] hub 2-0:1.0: USB hub found [ 5.121086] hub 2-0:1.0: 1 port detected [ 5.122499] input: adc-keys as /devices/platform/adc-keys/input/input1 [ 5.126321 [ 5.332597] usb 3-1: new high-speed USB device number 2 using xhci-hcd [ 5.436698] wifi_platform_bus_enumerate device present 1 [ 5.437234] ======== Card detection to detect SDIO card! ======== [ 5.437822] sdio: host isn't initialization successfully. [ 5.462758] usb 3-1: New USB device found, idVendor=2109, idProduct=2815 [ 5.463426] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.464113] usb 3-1: Product: USB2.0 Hub [ 5.464648] usb 3-1: Manufacturer: VIA Labs, Inc. [ 5.471585] hub 3-1:1.0: USB hub found [ 5.472192] hub 3-1:1.0: 4 ports detected [ 5.496190] fusb302 4-0022: PD disabled [ 5.595065] usb 4-1: new SuperSpeed USB device number 2 using xhci-hcd [ 5.653047] usb 4-1: New USB device found, idVendor=2109, idProduct=0815 [ 5.653715] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.654401] usb 4-1: Product: USB3.0 Hub [ 5.654909] usb 4-1: Manufacturer: VIA Labs, Inc. [ 5.663635] hub 4-1:1.0: USB hub found [ 5.664277] hub 4-1:1.0: 4 ports detected [ 5.673292] phy phy-ff770000.syscon:usb2-phy@e450.7: charger = USB_FLOATING_CHARGER [ 5.678360] rockchip-dwc3 usb0: USB peripheral connected [ 6.289395] usb 4-1.4: new SuperSpeed USB device number 3 using xhci-hcd [ 6.308585] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156 [ 6.309258] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 6.309968] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN [ 6.310462] usb 4-1.4: Manufacturer: Realtek [ 6.310880] usb 4-1.4: SerialNumber: 000000001 [ 7.436571] failed to power up DHD generic adapter, 1 retry left [ 7.453270] wifi_platform_set_power = 0 [ 7.453671] ======== PULL WL_REG_ON(-1) LOW! ======== [ 7.454165] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 7.454643] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 7.455502] wifi_platform_bus_enumerate device present 0 [ 7.456025] ======== Card detection to remove SDIO card! ======== [ 7.456637] sdio: host isn't initialization successfully. [ 7.457244] wifi_platform_set_power = 1 [ 7.457642] ======== PULL WL_REG_ON(-1) HIGH! ======== [ 7.458146] [WLAN_RFKILL]: rockchip_wifi_power: 1 [ 7.458623] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 7.760560] wifi_platform_bus_enumerate device present 1 [ 7.761097] ======== Card detection to detect SDIO card! ======== [ 7.761694] sdio: host isn't initialization successfully. [ 9.760578] failed to power up DHD generic adapter, 0 retry left [ 9.777275] wifi_platform_set_power = 0 [ 9.777675] ======== PULL WL_REG_ON(-1) LOW! ======== [ 9.778168] [WLAN_RFKILL]: rockchip_wifi_power: 0 [ 9.778646] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized [ 9.779503] wifi_platform_bus_enumerate device present 0 [ 9.780026] ======== Card detection to remove SDIO card! ======== [ 9.780635] sdio: host isn't initialization successfully. [ 9.781186] failed to power up DHD generic adapter, max retry reached** [ 9.781819] unregister wifi platform drivers [ 9.782250] wifi_platform_bus_enumerate device present 0 [ 9.782763] ======== Card detection to remove SDIO card! ======== [ 9.783357] sdio: host isn't initialization successfully. [ 9.783894] ======== dhd_wlan_deinit_plat_data ======== [ 9.784421] dhd_module_init: Failed to load the driver, try cnt 0 [ 9.785182] dhd_module_init: Failed to load driver max retry reached** [ 9.785817] dhd_module_init: Exit err=-19 [ 12.924601] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 12.949714] ata1.00: ATA-11: WDC WUH721818ALE6L4, PCGNW120, max UDMA/133 [ 12.950361] ata1.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 12.960170] ata1.00: configured for UDMA/133 [ 12.961737] scsi 0:0:0:0: Direct-Access ATA WDC WUH721818AL W120 PQ: 0 ANSI: 5 [ 12.964163] sd 0:0:0:0: [sda] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB) [ 12.965022] sd 0:0:0:0: [sda] 4096-byte physical blocks [ 12.965943] sd 0:0:0:0: [sda] Write Protect is off [ 12.966593] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 13.015628] sda: sda1 sda9 [ 13.018289] sd 0:0:0:0: [sda] Attached SCSI disk [ 13.624802] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 13.697924] ata2.00: ATA-11: WDC WUH721818ALE6L4, PCGNW120, max UDMA/133 [ 13.698585] ata2.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 13.708344] ata2.00: configured for UDMA/133 [ 13.709819] scsi 1:0:0:0: Direct-Access ATA WDC WUH721818AL W120 PQ: 0 ANSI: 5 [ 13.711862] sd 1:0:0:0: [sdb] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB) [ 13.712660] sd 1:0:0:0: [sdb] 4096-byte physical blocks [ 13.713512] sd 1:0:0:0: [sdb] Write Protect is off [ 13.714144] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 13.762037] sdb: sdb1 sdb9 [ 13.764612] sd 1:0:0:0: [sdb] Attached SCSI disk [ 14.316597] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 14.331588] ata3.00: ATA-11: WDC WUH721818ALE6L4, PCGNW120, max UDMA/133 [ 14.332235] ata3.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 14.342010] ata3.00: configured for UDMA/133 [ 14.344108] scsi 2:0:0:0: Direct-Access ATA WDC WUH721818AL W120 PQ: 0 ANSI: 5 [ 14.346359] sd 2:0:0:0: [sdc] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB) [ 14.347138] sd 2:0:0:0: [sdc] 4096-byte physical blocks [ 14.347985] sd 2:0:0:0: [sdc] Write Protect is off [ 14.348651] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 14.400145] sdc: sdc1 sdc9 [ 14.402989] sd 2:0:0:0: [sdc] Attached SCSI disk [ 14.952594] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 14.968569] ata4.00: ATA-11: WDC WUH721818ALE6L4, PCGNW120, max UDMA/133 [ 14.969217] ata4.00: 35156656128 sectors, multi 0: LBA48 NCQ (depth 31/32), AA [ 14.977608] ata4.00: configured for UDMA/133 [ 14.979601] scsi 3:0:0:0: Direct-Access ATA WDC WUH721818AL W120 PQ: 0 ANSI: 5 [ 14.981690] sd 3:0:0:0: [sdd] 35156656128 512-byte logical blocks: (18.0 TB/16.4 TiB) [ 14.982469] sd 3:0:0:0: [sdd] 4096-byte physical blocks [ 14.983312] sd 3:0:0:0: [sdd] Write Protect is off [ 14.983943] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 15.027700] sdd: sdd1 sdd9 [ 15.030613] sd 3:0:0:0: [sdd] Attached SCSI disk [ 15.304824] ata5: SATA link down (SStatus 0 SControl 300) [ 15.306393] Freeing unused kernel memory: 1088K [ 15.908250] md: linear personality registered for level -1 [ 15.916899] md: multipath personality registered for level -4 [ 15.924625] md: raid0 personality registered for level 0 [ 15.932454] md: raid1 personality registered for level 1 [ 15.939917] async_tx: api initialized (async) [ 15.945344] md: raid6 personality registered for level 6 [ 15.945841] md: raid5 personality registered for level 5 [ 15.946326] md: raid4 personality registered for level 4 [ 15.961288] Unable to handle kernel paging request at virtual address fffffc0f7f3f2098 [ 15.962023] pgd = ffffffc0e25be000 [ 15.962339] [fffffc0f7f3f2098] *pgd=0000000000000000, *pud=0000000000000000 [ 15.962992] Internal error: Oops: 96000004 [#1] SMP [ 15.963436] Modules linked in: raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod [ 15.964613] CPU: 5 PID: 297 Comm: modprobe Not tainted 4.4.213-rk3399 #14 [ 15.965219] Hardware name: Helios64 (DT) [ 15.965582] task: ffffffc0eb2db800 task.stack: ffffffc0e2260000 [ 15.966130] PC is at pick_next_task_fair+0x38/0x5b8 [ 15.966578] LR is at __schedule+0x180/0x654 [ 15.966964] pc : [<ffffff80080f7b50>] lr : [<ffffff8008bb9724>] pstate: 600001c5 [ 15.967633] sp : ffffffc0e2263dd0 [ 15.967938] x29: ffffffc0e2263dd0 x28: ffffffc0eb2dbe90 [ 15.968445] x27: ffffff80092f88a0 x26: ffffff8008bde6a8 [ 15.968951] x25: ffffffc0f7f3f200 x24: ffffff80092cd200 [ 15.969457] x23: ffffff8008bb9c60 x22: fffffc0f7f3f2088 [ 15.969963] x21: ffffffc0eb2db800 x20: ffffffc0eb2db800 [ 15.970469] x19: fffffc0f7f3f2000 x18: 0000000000000100 [ 15.970975] x17: 0000007f91aa7cf8 x16: 0000007f91ac3008 [ 15.971481] x15: 0000000000000a44 x14: 0000007f917c0690 [ 15.971987] x13: 0000000000048c30 x12: 0000000000000040 [ 15.972493] x11: 0000000000000030 x10: 0000007f91a52d00 [ 15.972999] x9 : 0000000000000000 x8 : 7f7f7f7f7f7f7f7f [ 15.973505] x7 : 0000000000000000 x6 : 00000003b75da4be [ 15.974012] x5 : 0000000000178ee4 x4 : 0000000000000000 [ 15.974517] x3 : 00000040eec72000 x2 : ffffff80080f7b18 [ 15.975023] x1 : ffffffc0eb2db800 x0 : ffffff8008bb9724 [ 15.975529] [ 15.975529] PC: 0xffffff80080f7ad0: [ 15.975992] 7ad0 aa1403e0 97ffa7be aa1403e0 97ffca27 aa1403e0 942b14bb 52800001 aa1403e0 [ 15.976792] 7af0 97ffff10 f9449680 eb150001 1a99535a f100003f 9a80a2b5 17ffffc5 f94033e0 [ 15.977590] 7b10 f9000815 17ffffd6 a9b87bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 [ 15.978389] 7b30 a90573fb aa0003f3 f000573a 91022276 911aa35a aa0103f5 aa1e03e0 d503201f [ 15.979189] 7b50 b94012c0 34001ae0 f9403ea0 eb1a001f 54001041 aa1603f4 f9401e97 b4000137 [ 15.979987] 7b70 b9403ae0 34000c60 aa1403e0 97ffde9e aa1403e0 97ffe8bf 72001c1f 54000ea1 [ 15.980786] 7b90 aa1403e0 aa1703e1 97ffdb9e f940fc14 b5fffe54 d1020014 eb1402bf 540001c0 [ 15.981584] 7bb0 910202b5 aa0003f6 f940faa0 f940fad7 eb0002ff 54000a21 b4000a17 aa1503e1 [ 15.982383] [ 15.982383] LR: 0xffffff8008bb96a4: [ 15.982845] 96a4 f9400e80 b40001a0 f9400e80 d2801021 ea01001f 540015a0 f9400281 36001561 [ 15.983642] 96c4 37000080 f943d280 7218001f 540014e0 f9000e9f 911a229c b9406680 7100041f [ 15.984440] 96e4 54000061 aa1303e0 97d4a0b8 f9403e81 b0000120 911aa000 eb00003f 54001f01 [ 15.985238] 9704 b9401a62 b9409e60 6b00005f 54001e81 f9401822 aa1303e0 aa1403e1 d63f0040 [ 15.986036] 9724 aa0003f5 b100041f 54001da0 b50000e0 b0000120 aa1403e1 f9430802 aa1303e0 [ 15.986834] 9744 d63f0040 aa0003f5 aa1403e1 52800020 97e4a14b b9093a7f eb15029f 54002300 [ 15.987632] 9764 f9404260 f9048a75 91000400 f9004260 f9400380 91000400 f9000380 b0004300 [ 15.988430] 9784 911d4000 91014000 b9400801 7100003f 540001cd aa1603e1 90000123 d538d082 [ 15.989229] [ 15.989229] SP: 0xffffffc0e2263d50: [ 15.989691] 3d50 7f3f2088 fffffc0f 08bb9c60 ffffff80 092cd200 ffffff80 f7f3f200 ffffffc0 [ 15.990489] 3d70 08bde6a8 ffffff80 092f88a0 ffffff80 eb2dbe90 ffffffc0 e2263dd0 ffffffc0 [ 15.991287] 3d90 08bb9724 ffffff80 e2263dd0 ffffffc0 080f7b50 ffffff80 600001c5 00000000 [ 15.992085] 3db0 092f88a0 ffffff80 00000000 ffffffc0 00000000 00000080 f7f3f288 ffffffc0 [ 15.992884] 3dd0 e2263e50 ffffffc0 08bb9724 ffffff80 f7f3f200 ffffffc0 eb2db800 ffffffc0 [ 15.993682] 3df0 00000005 00000000 092c4000 ffffff80 08bb9c60 ffffff80 092cd200 ffffff80 [ 15.994480] 3e10 f7f3f200 ffffffc0 00000000 00000000 092f88a0 ffffff80 eb2db800 ffffffc0 [ 15.995277] 3e30 e2263e50 ffffffc0 08bb96f0 ffffff80 f7f3f200 ffffffc0 092cd200 ffffff80 [ 15.996076] [ 15.996076] X0: 0xffffff8008bb96a4: [ 15.996538] 96a4 f9400e80 b40001a0 f9400e80 d2801021 ea01001f 540015a0 f9400281 36001561 [ 15.997336] 96c4 37000080 f943d280 7218001f 540014e0 f9000e9f 911a229c b9406680 7100041f [ 15.998134] 96e4 54000061 aa1303e0 97d4a0b8 f9403e81 b0000120 911aa000 eb00003f 54001f01 [ 15.998932] 9704 b9401a62 b9409e60 6b00005f 54001e81 f9401822 aa1303e0 aa1403e1 d63f0040 [ 15.999730] 9724 aa0003f5 b100041f 54001da0 b50000e0 b0000120 aa1403e1 f9430802 aa1303e0 [ 16.000529] 9744 d63f0040 aa0003f5 aa1403e1 52800020 97e4a14b b9093a7f eb15029f 54002300 [ 16.001327] 9764 f9404260 f9048a75 91000400 f9004260 f9400380 91000400 f9000380 b0004300 [ 16.002124] 9784 911d4000 91014000 b9400801 7100003f 540001cd aa1603e1 90000123 d538d082 [ 16.002924] [ 16.002924] X1: 0xffffffc0eb2db780: [ 16.003386] b780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.004183] b7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.004980] b7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.005778] b7e0 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 16.006576] b800 00000012 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000 [ 16.007373] b820 e2260000 ffffffc0 00000002 00404000 00000000 00000000 00000000 00000000 [ 16.008170] b840 00000001 00000005 0000005c 00000000 fffee9e9 00000000 edc3c600 ffffffc0 [ 16.008969] b860 00000005 00000001 00000078 00000078 00000078 00000000 08bde6a8 ffffff80 [ 16.009768] [ 16.009768] X2: 0xffffff80080f7a98: [ 16.010229] 7a98 a9446bf9 a94573fb a8c87bfd d65f03c0 f874daf4 aa1303e0 8b140014 f9403fe0 [ 16.011028] 7ab8 f940e001 f9449680 eb00003f 54000184 aa1403e0 942b1475 aa1403e0 97ffa7be [ 16.011826] 7ad8 aa1403e0 97ffca27 aa1403e0 942b14bb 52800001 aa1403e0 97ffff10 f9449680 [ 16.012625] 7af8 eb150001 1a99535a f100003f 9a80a2b5 17ffffc5 f94033e0 f9000815 17ffffd6 [ 16.013424] 7b18 a9b87bfd 910003fd a90153f3 a9025bf5 a90363f7 a9046bf9 a90573fb aa0003f3 [ 16.014222] 7b38 f000573a 91022276 911aa35a aa0103f5 aa1e03e0 d503201f b94012c0 34001ae0 [ 16.015020] 7b58 f9403ea0 eb1a001f 54001041 aa1603f4 f9401e97 b4000137 b9403ae0 34000c60 [ 16.015818] 7b78 aa1403e0 97ffde9e aa1403e0 97ffe8bf 72001c1f 54000ea1 aa1403e0 aa1703e1 [ 16.016623] [ 16.016623] X20: 0xffffffc0eb2db780: [ 16.017085] b780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.017882] b7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.018679] b7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.019476] b7e0 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 16.020274] b800 00000012 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000 [ 16.021071] b820 e2260000 ffffffc0 00000002 00404000 00000000 00000000 00000000 00000000 [ 16.021869] b840 00000001 00000005 0000005c 00000000 fffee9e9 00000000 edc3c600 ffffffc0 [ 16.022667] b860 00000005 00000001 00000078 00000078 00000078 00000000 08bde6a8 ffffff80 [ 16.023465] [ 16.023465] X21: 0xffffffc0eb2db780: [ 16.023927] b780 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.024724] b7a0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.025522] b7c0 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 16.026318] b7e0 00000000 00000000 00000000 00000000 ffffffff ffffffff ffffffff ffffffff [ 16.027116] b800 00000012 00000000 ffffffff ffffffff 00000000 00000000 00000000 00000000 [ 16.027914] b820 e2260000 ffffffc0 00000002 004 [ 23.027973] BUG: spinlock lockup suspected on CPU#0, swapper/0/0 [ 23.028559] lock: 0xffffffc0f7f3f200, .magic: dead4ead, .owner: modprobe/297, .owner_cpu: 5 [ 23.029353] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G D 4.4.213-rk3399 #14 [ 23.030095] Hardware name: Helios64 (DT) [ 23.030470] Call trace: [ 23.030727] [<ffffff800808803c>] dump_backtrace+0x0/0x21c [ 23.031236] [<ffffff800808827c>] show_stack+0x24/0x30 [ 23.031722] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc [ 23.032209] [<ffffff80081939d8>] spin_dump+0x84/0xa4 [ 23.032683] [<ffffff8008105b74>] do_raw_spin_lock+0xdc/0x164 [ 23.033217] [<ffffff8008bbccf0>] _raw_spin_lock+0x20/0x2c [ 23.033726] [<ffffff80080e3a18>] try_to_wake_up+0x1a0/0x358 [ 23.034246] [<ffffff80080e3c8c>] wake_up_process+0x2c/0x38 [ 23.034766] [<ffffff80080d0274>] wake_up_worker+0x34/0x40 [ 23.035273] [<ffffff80080d0310>] insert_work+0x90/0xa4 [ 23.035757] [<ffffff80080d05fc>] __queue_work+0x2d8/0x2e8 [ 23.036263] [<ffffff80080d0658>] queue_work_on+0x4c/0x6c [ 23.036773] [<ffffff80085ae4e0>] tty_schedule_flip+0x3c/0x48 [ 23.037303] [<ffffff80085ae50c>] tty_flip_buffer_push+0x20/0x2c [ 23.037862] [<ffffff800899afe0>] fiq_debugger_handle_irq_context+0xac/0x438 [ 23.038508] [<ffffff800899b4fc>] fiq_debugger_uart_irq+0x148/0xca8 [ 23.039087] [<ffffff8008112ee0>] handle_irq_event_percpu+0xdc/0x1f8 [ 23.039674] [<ffffff800811304c>] handle_irq_event+0x50/0x80 [ 23.040195] [<ffffff80081166bc>] handle_fasteoi_irq+0xcc/0x134 [ 23.040737] [<ffffff8008112610>] generic_handle_irq+0x2c/0x44 [ 23.041278] [<ffffff800811298c>] __handle_domain_irq+0xb8/0xbc [ 23.041820] [<ffffff8008080e7c>] gic_handle_irq+0xc8/0x180 [ 23.042337] Exception stack(0xffffff80092f3d70 to 0xffffff80092f3ea0) [ 23.042936] 3d60: ffffffc0f7edb200 00000040eec0e000 [ 23.043681] 3d80: ffffffc0f7edb200 ffffff80092f3e80 00ffffffffffffff 000000003100b56c [ 23.044425] 3da0: 0000000000001eda 0000000000000001 ffffff8009301a60 ffffff80092f3ec0 [ 23.045169] 3dc0: 0000000000000a30 0000000000000191 0000000000000003 0000000000000003 [ 23.045912] 3de0: 0000000000000001 000000000000000e 0000000000000028 00000000b151c1e7 [ 23.046657] 3e00: 00000000a1c14965 00000003b6c79f92 ffffffc0ead04c00 0000000000000060 [ 23.047401] 3e20: 0000000000000000 ffffff800941b3f8 0000000000000000 00000003b6c63668 [ 23.048145] 3e40: ffffff80093d4490 0000000002bc323c 00000000031e001c ffffff80092f3ea0 [ 23.048889] 3e60: ffffff8008953748 ffffff80092f3ea0 ffffff800895377c 0000000060000145 [ 23.049633] 3e80: ffffff80092f3ea0 ffffff8008953748 ffffffffffffffff ffffffc0ead04c00 [ 23.050377] [<ffffff80080827b4>] el1_irq+0xb4/0x140 [ 23.050842] [<ffffff800895377c>] cpuidle_enter_state+0x1f8/0x25c [ 23.051407] [<ffffff8008953854>] cpuidle_enter+0x34/0x44 [ 23.051906] [<ffffff80080ff2a4>] call_cpuidle+0x70/0x78 [ 23.052403] [<ffffff80080ff554>] cpu_startup_entry+0x2a8/0x2b8 [ 23.052946] [<ffffff8008bb8848>] rest_init+0x74/0x7c [ 23.053420] [<ffffff80091e0b84>] start_kernel+0x3c8/0x3ec [ 23.053927] [<ffffff80091e01c4>] __primary_switched+0x30/0x6c [ 23.076635] BUG: spinlock lockup suspected on CPU#4, swapper/4/0 [ 23.077191] lock: 0xffffffc0f7f3f200, .magic: dead4ead, .owner: modprobe/297, .owner_cpu: 5 [ 23.077957] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G D 4.4.213-rk3399 #14 [ 23.078673] Hardware name: Helios64 (DT) [ 23.079034] Call trace: [ 23.079273] [<ffffff800808803c>] dump_backtrace+0x0/0x21c [ 23.079765] [<ffffff800808827c>] show_stack+0x24/0x30 [ 23.080223] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc [ 23.080682] [<ffffff80081939d8>] spin_dump+0x84/0xa4 [ 23.081138] [<ffffff8008105b74>] do_raw_spin_lock+0xdc/0x164 [ 23.081654] [<ffffff8008bbccf0>] _raw_spin_lock+0x20/0x2c [ 23.082146] [<ffffff80080fb160>] sched_rt_period_timer+0x11c/0x268 [ 23.082707] [<ffffff8008126544>] __hrtimer_run_queues+0x1bc/0x284 [ 23.083256] [<ffffff8008126b30>] hrtimer_interrupt+0xac/0x1bc [ 23.083783] [<ffffff80081327b0>] tick_receive_broadcast+0x30/0x4c [ 23.084332] [<ffffff800808c3f8>] handle_IPI+0x1f0/0x258 [ 23.084810] [<ffffff8008080f30>] gic_handle_irq+0x17c/0x180 [ 23.085312] Exception stack(0xffffffc0ee6f7da0 to 0xffffffc0ee6f7ed0) [ 23.085896] 7da0: 0000000000000000 0000000000000004 00000040eec5e000 0000000000000004 [ 23.086602] 7dc0: 0000000000000010 0000000000000000 0000000000001eda 0000000000000004 [ 23.087308] 7de0: 00000034b5593519 ffffff8008081800 0000000000001000 0000000000000000 [ 23.088014] 7e00: 0000000034d5d91d 00000040eec5e000 ffffffc0ee6e3800 0000000000000000 [ 23.088721] 7e20: 0000000000000000 0000000000000000 0000000030d00800 00000003b9ae4b6e [ 23.089426] 7e40: ffffffc0ead05400 0000000000000060 0000000000000002 ffffff800941b3f8 [ 23.090132] 7e60: 0000000000000001 00000003b971a5e1 ffffff80093d4550 0000000002bc3244 [ 23.090837] 7e80: 0000000000000000 ffffffc0ee6f7ed0 ffffff8008953778 ffffffc0ee6f7ed0 [ 23.091543] 7ea0: ffffff800895377c 0000000060000145 ffffffc0ee6f7ed0 ffffff8008953778 [ 23.092248] 7ec0: ffffffffffffffff ffffffc0ead05400 [ 23.092692] [<ffffff80080827b4>] el1_irq+0xb4/0x140 [ 23.093139] [<ffffff800895377c>] cpuidle_enter_state+0x1f8/0x25c [ 23.093688] [<ffffff8008953854>] cpuidle_enter+0x34/0x44 [ 23.094169] [<ffffff80080ff2a4>] call_cpuidle+0x70/0x78 [ 23.094649] [<ffffff80080ff554>] cpu_startup_entry+0x2a8/0x2b8 [ 23.095175] [<ffffff800808be58>] secondary_start_kernel+0x124/0x140 [ 23.095745] [<0000000002bc3188>] 0x2bc3188 [ 23.105781] BUG: spinlock lockup suspected on CPU#5, modprobe/297 [ 23.106331] lock: 0xffffffc0f7f3f200, .magic: dead4ead, .owner: modprobe/297, .owner_cpu: 5 [ 23.107096] CPU: 5 PID: 297 Comm: modprobe Tainted: G D 4.4.213-rk3399 #14 [ 23.107823] Hardware name: Helios64 (DT) [ 23.108183] Call trace: [ 23.108420] [<ffffff800808803c>] dump_backtrace+0x0/0x21c [ 23.108912] [<ffffff800808827c>] show_stack+0x24/0x30 [ 23.109369] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc [ 23.109826] [<ffffff80081939d8>] spin_dump+0x84/0xa4 [ 23.110282] [<ffffff8008105b74>] do_raw_spin_lock+0xdc/0x164 [ 23.110797] [<ffffff8008bbccc4>] _raw_spin_lock_irq+0x24/0x30 [ 23.111322] [<ffffff8008bb9690>] __schedule+0xec/0x654 [ 23.111790] [<ffffff8008bb9e30>] preempt_schedule_common+0x10/0x24 [ 23.112350] [<ffffff8008bb9e78>] _cond_resched+0x34/0x44 [ 23.112831] [<ffffff80080c8534>] exit_signals+0x20/0x17c [ 23.113313] [<ffffff80080bd2c0>] do_exit+0x104/0x8dc [ 23.113769] [<ffffff800808842c>] die+0x1a4/0x1b8 [ 23.114191] [<ffffff80080936b4>] __do_kernel_fault.part.1+0x78/0x88 [ 23.114761] [<ffffff8008093adc>] do_translation_fault+0xb8/0xc8 [ 23.115297] [<ffffff8008080b08>] do_mem_abort+0x54/0xac [ 23.115775] Exception stack(0xffffffc0e2263c00 to 0xffffffc0e2263d30) [ 23.116358] 3c00: fffffc0f7f3f2000 0000008000000000 ffffffc0e2263dd0 ffffff80080f7b50 [ 23.117064] 3c20: ffffffc0e2263c40 ffffff80081960d4 ffffffbdc3b30ec0 ffffffc0e1e830c0 [ 23.117769] 3c40: ffffffc0e2263cb0 ffffff80081c3708 ffffffc0ed8619a0 000000000000002a [ 23.118475] 3c60: 0000007f917e1000 ffffffc0e18e3458 ffffffc0e2263c90 ffffff8008bbcd90 [ 23.119180] 3c80: ffffffc0e149bbb8 ffffff80092f88e8 ffffffc0e2263cb0 ffffff80081c3800 [ 23.119886] 3ca0: ffffff8008bb9724 ffffffc0eb2db800 ffffff80080f7b18 00000040eec72000 [ 23.120592] 3cc0: 0000000000000000 0000000000178ee4 00000003b75da4be 0000000000000000 [ 23.121298] 3ce0: 7f7f7f7f7f7f7f7f 0000000000000000 0000007f91a5 [ 25.856645] BUG: spinlock lockup suspected on CPU#1, swapper/1/0 [ 25.857218] lock: 0xffffffc0ee4b9400, .magic: dead4ead, .owner: swapper/0/0, .owner_cpu: 0 [ 25.857999] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G D 4.4.213-rk3399 #14 [ 25.858740] Hardware name: Helios64 (DT) [ 25.859114] Call trace: [ 25.859366] [<ffffff800808803c>] dump_backtrace+0x0/0x21c [ 25.859875] [<ffffff800808827c>] show_stack+0x24/0x30 [ 25.860358] [<ffffff80084e3c68>] dump_stack+0xa4/0xcc [ 25.860842] [<ffffff80081939d8>] spin_dump+0x84/0xa4 [ 25.861314] [<ffffff8008105b74>] do_raw_spin_lock+0xdc/0x164 [ 25.861846] [<ffffff8008bbccf0>] _raw_spin_lock+0x20/0x2c [ 25.862354] [<ffffff80080d0470>] __queue_work+0x14c/0x2e8 [ 25.862863] [<ffffff80080d0b68>] delayed_work_timer_fn+0x28/0x34 [ 25.863428] [<ffffff80081247f8>] call_timer_fn+0xa0/0x154 [ 25.863935] [<ffffff8008124af0>] run_timer_softirq+0x218/0x244 [ 25.864476] [<ffffff800808115c>] __do_softirq+0x224/0x2f8 [ 25.864985] [<ffffff80080be9c0>] irq_exit+0x90/0xdc [ 25.865446] [<ffffff800808c390>] handle_IPI+0x188/0x258 [ 25.865940] [<ffffff8008080f30>] gic_handle_irq+0x17c/0x180 [ 25.866457] Exception stack(0xffffffc0ee6ebda0 to 0xffffffc0ee6ebed0) [ 25.867058] bda0: 0000000000000000 0000000000000001 00000040eec22000 0000000000000001 [ 25.867801] bdc0: 0000000000000002 0000000000000000 0000000000001ee0 0000000000000001 [ 25.868546] bde0: 00000032b5593519 ffffff8008081800 0000000000001000 0000000000000000 [ 25.869289] be00: 0000000034d5d91d 00000040eec22000 ffffffc0ee6e0e00 0000000000000000 [ 25.870033] be20: 0000000000000000 0000000000000000 0000000030d00800 000000045f61c022 [ 25.870776] be40: ffffffc0ead04e00 0000000000000060 0000000000000002 ffffff800941b3f8 [ 25.871520] be60: 0000000000000001 000000045f24df56 ffffff80093d4550 0000000002bc3244 [ 25.872264] be80: 0000000000000000 ffffffc0ee6ebed0 ffffff8008953778 ffffffc0ee6ebed0 [ 25.873008] bea0: ffffff800895377c 0000000060000145 ffffffc0ee6ebed0 ffffff8008953778 [ 25.873750] bec0: ffffffffffffffff ffffffc0ead04e00 [ 25.874209] [<ffffff80080827b4>] el1_irq+0xb4/0x140 [ 25.874671] [<ffffff800895377c>] cpuidle_enter_state+0x1f8/0x25c [ 25.875237] [<ffffff8008953854>] cpuidle_enter+0x34/0x44 [ 25.875744] [<ffffff80080ff2a4>] call_cpuidle+0x70/0x78 [ 25.876240] [<ffffff80080ff554>] cpu_startup_entry+0x2a8/0x2b8 [ 25.876782] [<ffffff800808be58>] secondary_start_kernel+0x124/0x140 [ 25.877368] [<0000000002bc3188>] 0x2bc3188 [ 36.132571] Watchdog detected hard LOCKUP on cpu 4 [ 36.133001] ------------[ cut here ]------------ [ 36.133479] WARNING: at kernel/watchdog.c:352 [ 36.133889] Modules linked in: raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod [ 36.135102] [ 36.135272] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G D 4.4.213-rk3399 #14 [ 36.136012] Hardware name: Helios64 (DT) [ 36.136389] task: ffffffc0ee6e2a00 task.stack: ffffffc0ee6f0000 [ 36.136945] PC is at watchdog_timer_fn+0x180/0x2c8 [ 36.137405] LR is at watchdog_timer_fn+0x180/0x2c8 [ 36.137863] pc : [<ffffff800815b7c0>] lr : [<ffffff800815b7c0>] pstate: 600001c5 [ 36.138557] sp : ffffffc0f7f11d10 [ 36.138874] x29: ffffffc0f7f11d10 x28: 0000000000000004 [ 36.139397] x27: ffffff80092f88a0 x26: ffffffc0f7f14250 [ 36.139920] x25: ffffffc0ee6f3da0 x24: 0000000000000000 [ 36.140442] x23: ffffff80092f7000 x22: 0000000000000000 [ 36.140966] x21: ffffff80092f7898 x20: ffffff80092ca2b0 [ 36.141489] x19: ffffff80092ca228 x18: 0000000000000000 [ 36.142011] x17: 0000000000000000 x16: 0000000000000000 [ 36.142534] x15: 00000000000205db x14: 000000000000000a [ 36.143057] x13: 0000000000000005 x12: ffffff8089456d23 [ 36.143580] x11: 0000000000000030 x10: ffffff8009456d2b [ 36.144102] x9 : 00000000fffffffe x8 : ffffff8008451ee8 [ 36.144625] x7 : ffffff8009356c20 x6 : 0000000000000035 [ 36.145148] x5 : 0000000000000000 x4 : 0000000000000000 [ 36.145670] x3 : 0000000000000034 x2 : 00000040eec4a000 [ 36.146192] x1 : 0000000000000003 x0 : 0000000000000026 [ 36.146715] [ 36.146715] PC: 0xffffff800815b740: [ 36.147201] b740 91022673 d538d080 38606a61 34000041 3833681f 97ffff7e 52800020 a94153f3 [ 36.148037] b760 a9425bf5 a94363f7 a9446bf9 a94573fb a8c67bfd d65f03c0 91020262 f8746860 [ 36.148871] b780 91022274 f8626864 eb04001f 54000101 38746860 35fffbc0 b94016a3 90006702 [ 36.149706] b7a0 911a3440 340000c3 9400df24 f8226860 f87c7b60 3834681f 17ffffd5 9400e31c [ 36.150540] b7c0 d4210000 f87c7b60 52800021 38346801 17ffffcf 97fe3578 f9444ee1 360808e1 [ 36.151374] b7e0 b94012a1 910003e2 34000881 531f7821 d35efc00 8b21c2c1 eb00003f 540007e5 [ 36.152208] b800 6b160016 540007a0 91022a74 d538d080 38606a81 34000101 91024273 f8736802 [ 36.153041] b820 d5384101 eb01005f 54fff980 3834681f 17ffffc9 34000158 f0009b01 52800000 [ 36.153876] [ 36.153876] LR: 0xffffff800815b740: [ 36.154362] b740 91022673 d538d080 38606a61 34000041 3833681f 97ffff7e 52800020 a94153f3 [ 36.155195] b760 a9425bf5 a94363f7 a9446bf9 a94573fb a8c67bfd d65f03c0 91020262 f8746860 [ 36.156029] b780 91022274 f8626864 eb04001f 54000101 38746860 35fffbc0 b94016a3 90006702 [ 36.156862] b7a0 911a3440 340000c3 9400df24 f8226860 f87c7b60 3834681f 17ffffd5 9400e31c [ 36.157696] b7c0 d4210000 f87c7b60 52800021 38346801 17ffffcf 97fe3578 f9444ee1 360808e1 [ 36.158530] b7e0 b94012a1 910003e2 34000881 531f7821 d35efc00 8b21c2c1 eb00003f 540007e5 [ 36.159364] b800 6b160016 540007a0 91022a74 d538d080 38606a81 34000101 91024273 f8736802 [ 36.160199] b820 d5384101 eb01005f 54fff980 3834681f 17ffffc9 34000158 f0009b01 52800000 [ 36.161034] [ 36.161034] SP: 0xffffffc0f7f11c90: [ 36.161520] 1c90 00000000 00000000 092f7000 ffffff80 00000000 00000000 ee6f3da0 ffffffc0 [ 36.162353] 1cb0 f7f14250 ffffffc0 092f88a0 ffffff80 00000004 00000000 f7f11d10 ffffffc0 [ 36.163186] 1cd0 0815b7c0 ffffff80 f7f11d10 ffffffc0 0815b7c0 ffffff80 600001c5 00000000 [ 36.164020] 1cf0 00000003 00000000 0000003f 00000000 00000000 00000080 ee000028 ffffffc0 [ 36.164854] 1d10 f7f11d70 ffffffc0 08126544 ffffff80 f7f14250 ffffffc0 f7f13c00 ffffffc0 [ 36.165688] 1d30 651bd210 00000008 f7f13c80 ffffffc0 092c4000 ffffff80 00000001 00000000 [ 36.166522] 1d50 0941aed0 ffffff80 651bd210 00000008 0815b640 ffffff80 651bcb3a 00000008 [ 36.167355] 1d70 f7f11de0 ffffffc0 08126b30 ffffff80 f7f13c00 ffffffc0 651bd210 00000008 [ 36.168194] [ 36.168194] X7: 0xffffff8009356ba0: [ 36.168680] 6ba0 eded7540 ffffffc0 00000000 00000000 00000000 00000000 00110000 00000000 [ 36.169513] 6bc0 000f0000 00000000 00000000 00000000 00040000 00000000 00080000 00000000 [ 36.170347] 6be0 00000000 00000000 00000000 00000000 00000001 00000000 00000000 00000000 [ 36.171180] 6c00 00000000 00000001 00000000 00000000 00000000 00000000 00000000 00000000 [ 36.172013] 6c20 00000000 00000000 08e67466 ffffff80 0bd90bd9 dead4ead ffffffff 00000000 [ 36.172846] 6c40 ffffffff ffffffff edf40000 ffffffc0 00040000 00000000 00000001 00000000 [ 36.173679] 6c60 00000000 dead4ead ffffffff 00000000 ffffffff ffffffff 09356c78 ffffff80 [ 36.174512] 6c80 09356c78 ffffff80 00000000 00000000 00000000 00000000 00000000 00000000 [ 36.175348] [ 36.175348] X8: 0xffffff8008451e68: [ 36.175833] 1e68 9400054e aa1303e0 94000558 52800000 a94153f3 f94013f5 a8c37bfd d65f03c0 [ 36.176667] 1e88 f9400413 17fffff6 f9400813 17fffff4 f9400c13 17fffff2 128002a0 17fffff5 [ 36.177501] 1ea8 71001c1f 54000161 f9405ce0 f9400c00 b4000140 a9bf7bfd aa0603e2 aa0403e1 [ 36.178335] 1ec8 910003fd 940004d2 a8c17bfd d65f03c0 128002a0 d65f03c0 12800160 d65f03c0 [ 36.179169] 1ee8 a9bb7bfd 7100081f 910003fd a90153f3 aa0603f4 a9025bf5 a90363f7 aa0403f8 [ 36.180002] 1f08 f9405cf3 54000181 f9400660 b4000a20 2a1403e2 aa1803e1 94000481 52800000 [ 36.180837] 1f28 a94153f3 a9425bf5 a94363f7 a8c57bfd d65f03c0 71000c1f 54000061 f9400a60 [ 36.181671] 1f48 17fffff3 71001c1f 54000061 f9400e60 17ffffef 35000820 51000420 7100041f [ 36.182507] [ 36.182507] X10: 0xffffff8009456cab: [ 36.183004] 6ca8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 36.183838] 6cc8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 36.184671] 6ce8 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 [ 36.185505] 6d08 00000000 00000000 00000000 00000000 00000000 00000000 00000001 30303020 [ 36.186338] 6d28 312e3633 33333633 36205d38 20383264 312e3633 30353238 58205d37 203a3031 [ 36.187172] 6d48 66667830 66666666 39303038 63363534 0a3a6261 35313830 30633762 70205d3e [ 36.188006] 6d68 74617473 36203a65 30303030 0a356331 31232039 3a750a34 0a0a3020 4620726f [ 36.188839] 6d88 6c0a4155 72702079 7265706f 69207974 6f6e206e 2f206564 65776f70 616d2d72 [ 36.189673] 6da8 6567616e 746e656d 33666640 30303031 6f702f30 2d726577 746e6f63 6c6c6f72 [ 36.190509] [ 36.190509] X12: 0xffffff8089456ca3: [ 36.191006] 6ca0 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.191843] 6cc0 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.192675] 6ce0 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.193509] 6d00 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.194342] 6d20 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.195176] 6d40 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.196009] 6d60 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.196842] 6d80 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.197676] 6da0 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.198515] [ 36.198515] X19: 0xffffff80092ca1a8: [ 36.199012] a1a8 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.199846] a1c8 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.200679] a1e8 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.201512] a208 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.202345] a228 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.203178] a248 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.204011] a268 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.204844] a288 ******** ******** ******** ******** ******** ******** ******** ******** [ 36.205679] [ 36.205679] X20: 0xffffff80092ca230: [ 36.206176] a230 ******** ******** ******** ******** ******** ******** *** [ 76.132626] INFO: rcu_sched detected stalls on CPUs/tasks: [ 76.133157] 5-...: (1 GPs behind) idle=ef1/140000000000000/0 softirq=769/774 fqs=0 [ 76.133886] (detected by 2, t=15043 jiffies, g=-84, c=-85, q=87) [ 76.134468] Task dump for CPU 5: [ 76.134785] modprobe R running task 0 297 1 0x00000012 [ 76.135461] Call trace: [ 76.135714] [<ffffff8008084f9c>] __switch_to+0x9c/0xc8 [ 76.136199] [<ffffff8008bb96f0>] __schedule+0x14c/0x654 [ 76.136694] [<ffffff8008bb9c60>] schedule+0x68/0x7c [ 76.137155] [<ffffff8008082e1c>] ret_to_user+0x0/0xc4 [ 76.137639] rcu_sched kthread starved for 15043 jiffies! g18446744073709551532 c18446744073709551531 f0x0 s3 ->state=0x1 Expand
