tommitytom Posted March 24, 2021 Posted March 24, 2021 Like many others, I get constant reboots with my Helios. I'm not sure it's worth me posting logs as a number of people already seem to be doing that. My question is, does anyone have a stable system? If so what OS and kernel are you using? I don't care about latest and greatest features, I just want it to stop hard rebooting. 1 Quote
wurmfood Posted March 24, 2021 Posted March 24, 2021 I do. My system has been rock solid and is acting as a media storage device, NFS, and backup server. wurmfood@helios64:~$ uname -a Linux helios64 5.10.21-rockchip64 #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux ZFS on 4 Seagate 6 Tb disks plus a 250 Gb M.2 SSD. I haven't had to do any of the governor stuff other people have. The only problems I've run into have to do with remembering to rebuild the ZFS module when I update the kernel. One thing I've noticed is that a number of people having problem seem to be using OMV and I'm not. 0 Quote
tommitytom Posted March 24, 2021 Author Posted March 24, 2021 On 3/24/2021 at 2:47 AM, wurmfood said: One thing I've noticed is that a number of people having problem seem to be using OMV and I'm not. Expand Oh that's an interesting observation! I'm using OMV too. Maybe I should try going without it. Thanks! 0 Quote
gprovost Posted March 24, 2021 Posted March 24, 2021 @tommitytom Can you show us the early stage boot log (you will need to capture serial console output). Just want to check if you are using rockchip blob or u-boot TPL/SPL, since the latest one has still some instability. 0 Quote
RockBian Posted March 24, 2021 Posted March 24, 2021 @tommitytom: My system is solid too. Running kernel 5.10.21-rockchip64 on Buster. No ZFS, no raid, no OMV. Booting from an m2 sata disk. Since I got the box in november it has only rebooted for kernel updates. 0 Quote
NickS Posted March 24, 2021 Posted March 24, 2021 Stable System: Absolutely I'm running with all latest maintenance & OMV5. Linux 5.10.21-rockchip64, OMV 5.6.2-1(Usul) ---- but I'm keeping things very simple... NO RAID 4 x HDD ALL THE SAME NO ZFS BOOT FROM SD AUTO SHUTDOWN & RESTART EACH 24 hours -- until I get to the apps 21 Docker containers running various apps & services. I've had one docker image fail to come up on a couple of occasions. So ... I'm a very happy customer. My Data resilience doesn't come from RAID (which I really don't like 'cos 8TB disks take forever to rebuild). I just backup critical data to my old trusty Helios4! 2 Quote
SIGSEGV Posted March 24, 2021 Posted March 24, 2021 My case is similar to @wurmfood's - latest OS, ZFS and no OMV. @gprovost, how can we check and determine "if you are using rockchip blob or u-boot TPL/SPL"? 0 Quote
gprovost Posted March 25, 2021 Posted March 25, 2021 @SIGSEGV During boot up, the first messages output on the serial will show if it's U-boot TPL/SPL our Rockchip blob. This is the output with U-boot TPL/SPL U-Boot TPL 2020.10-armbian (Mar 14 2021 - 07:07:37) Channel 0: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB Channel 1: LPDDR4, 50MHz BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB 256B stride lpddr4_set_rate: change freq to 400000000 mhz 0, 1 lpddr4_set_rate: change freq to 800000000 mhz 1, 0 Trying to boot from BOOTROM Returning to boot ROM... U-Boot SPL 2020.10-armbian (Mar 14 2021 - 07:07:37 +0700) Trying to boot from MMC2 NOTICE: BL31: v2.2(release):a04808c-dirty NOTICE: BL31: Built : 07:07:20, Mar 14 2021 This is the output with Rockchip blob Quote DDR Version 1.24 20191016 In soft reset SRX channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x2 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 322 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 mmc0:cmd8,20 mmc0:cmd5,20 mmc0:cmd55,20 mmc0:cmd1,20 SdmmcInit=0 1 StorageInit ok = 68844 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe5b60 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 Expand 0 Quote
Vin Posted March 25, 2021 Posted March 25, 2021 Im also still having constant crashes. But recently it already happened 3 times where it crashed for no obvious reason (was running for 1-2 days, nothing has been changed) but then doesnt boot up anymore. So i already reinstalled it 3 times, before it happened again right now. Running latest armbian, with OMV, LUKS, Docker Reveal hidden contents [124209.830905] Internal error: Oops: 96000004 [#1] PREEMPT SMP [124209.831414] Modules linked in: dm_crypt algif_skcipher af_alg dm_mod softdog veth nf_conntrack_netlink xfrm_user xfrm_algo br_netfilter bridge wireguard libchacha20poly1305 poly1305_neon ip6_udp_tunnel udp_tunnel libblake2s libcurve25519_generic libblake2s_generic aufs governor_performance cfg80211 rfkill snd_soc_hdmi_codec rockchipdrm dw_mipi_dsi snd_soc_rockchip_i2s snd_soc_core rockchip_vdec(C) dw_hdmi hantro_vpu(C) snd_pcm_dmaengine snd_pcm analogix_dp v4l2_h264 panfrost snd_timer videobuf2_dma_contig rockchip_rga snd videobuf2_vmalloc drm_kms_helper videobuf2_dma_sg v4l2_mem2mem fusb302 videobuf2_memops tcpm cec rc_core videobuf2_v4l2 r8152 soundcore gpu_sched videobuf2_common typec videodev cdc_acm pwm_fan mc drm gpio_charger leds_pwm sg drm_panel_orientation_quirks gpio_beeper cpufreq_dt xt_conntrack nft_counter nft_chain_nat xt_nat xt_tcpudp xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_comment xt_addrtype nft_compat nf_tables nfnetlink nfsd ledtrig_netdev [124209.831575] auth_rpcgss lm75 nfs_acl lockd grace sunrpc ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod uas realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys [124209.841206] CPU: 5 PID: 9122 Comm: python3 Tainted: G C 5.10.21-rockchip64 #21.02.3 [124209.842001] Hardware name: Helios64 (DT) [124209.842359] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO BTYPE=--) [124209.842915] pc : idr_find+0xc/0x28 [124209.843233] lr : shrink_slab+0x1e0/0x2b8 [124209.843585] sp : ffff800015e936e0 [124209.843886] x29: ffff800015e936e0 x28: 0000000000000000 [124209.844364] x27: ffff00004422dc38 x26: ffff800011b7a7f4 [124209.844840] x25: ffff8000118b9948 x24: 0000000000000005 [124209.845317] x23: 0000000000112c4a x22: 000000000000003c [124209.845803] x21: 0000000000000000 x20: ffff000056c5a000 [124209.846286] x19: ffff800011968d68 x18: 0000000000000000 [124209.846762] x17: 0000000000000000 x16: 0000000000000000 [124209.847239] x15: 000014c43a847bc8 x14: 0000000000000034 [124209.847716] x13: 0000000000000034 x12: ffff800015e93468 [124209.848192] x11: 0000000000000040 x10: ffff800011968d98 [124209.848668] x9 : ffff800011968d90 x8 : ffff000040402b80 [124209.849156] x7 : 0000000000000000 x6 : 1040000148100100 [124209.849636] x5 : 000000000000003c x4 : 0000000000000000 [124209.850113] x3 : 000000000000003c x2 : 000000000000003c [124209.850589] x1 : 000000000000003c x0 : ffff800011968d90 [124209.851068] Call trace: [124209.851299] idr_find+0xc/0x28 [124209.851580] shrink_slab+0x1e0/0x2b8 [124209.851904] shrink_node+0x3b4/0x6b8 [124209.852228] do_try_to_free_pages+0xe0/0x440 [124209.852612] try_to_free_pages+0x10c/0x2b0 [124209.852984] __alloc_pages_slowpath.constprop.114+0x354/0xba0 [124209.853495] __alloc_pages_nodemask+0x2d8/0x340 [124209.853902] alloc_pages_current+0x84/0xf8 [124209.854273] __page_cache_alloc+0x88/0xb0 [124209.854635] page_cache_ra_unbounded+0x88/0x208 [124209.855041] do_page_cache_ra+0x40/0x50 [124209.855387] filemap_fault+0x5d4/0x860 [124209.855729] ext4_filemap_fault+0x34/0x820 [124209.856099] __do_fault+0x3c/0x100 [124209.856417] handle_mm_fault+0xd10/0x1060 [124209.856787] do_page_fault+0x130/0x3a8 [124209.857127] do_translation_fault+0x50/0x60 [124209.857503] do_mem_abort+0x40/0xa0 [124209.857821] el0_ia+0x64/0xc0 [124209.858092] el0_sync_handler+0x78/0xb8 [124209.858445] el0_sync+0x158/0x180 [124209.858754] Code: d65f03c0 d503233f a9bf7bfd 910003fd (b9401002) [124209.859296] ---[ end trace 722be31e7641f1e0 ]--- DDR Version 1.24 20191016 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 255 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30528MB FwPartOffset=2000 , 0 StorageInit ok = 65569 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xe5b60 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Mar 08 2021 - 14:54:58 +0000) SoC: Rockchip rk3399 Reset cause: POR DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: eth0: ethernet@fe300000 scanning bus for devices... starting USB... Bus usb@fe380000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 4!? 6 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 5 ms (622.1 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 220 bytes read in 4 ms (53.7 KiB/s) 16207980 bytes read in 690 ms (22.4 MiB/s) 28582400 bytes read in 1212 ms (22.5 MiB/s) 81913 bytes read in 12 ms (6.5 MiB/s) 2698 bytes read in 8 ms (329.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 16207916 Bytes = 15.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f4f7a000, end f5eef02c ... OK Loading Device Tree to 00000000f4efd000, end 00000000f4f79fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.21-rockchip64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 [ 0.000000] Machine model: Helios64 [ 0.000000] printk: debug: ignoring loglevel setting. [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 128 MiB at 0x00000000ecc00000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] NUMA: NODE_DATA [mem 0xf77d9100-0xf77dafff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000f7ffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff] [ 0.000000] On node 0 totalpages: 1015296 [ 0.000000] DMA zone: 4088 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 261632 pages, LIFO batch:63 [ 0.000000] DMA32 zone: 11776 pages used for memmap [ 0.000000] DMA32 zone: 753664 pages, LIFO batch:63 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072 [ 0.000000] pcpu-alloc: s94040 r8192 d28840 u131072 alloc=32*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 999432 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: root=UUID=c559a861-be25-4b41-a161-d0c3d75c0089 rootwait rootfstype=ext4 console=ttyS2,1500000 consoleblank=0 loglevel=7 ubootpart=559a8d18-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u earlyprintk ignore_loglevel cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear) [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] software IO TLB: mapped [mem 0x000000003bfff000-0x000000003ffff000] (64MB) [ 0.000000] Memory: 3738920K/4061184K available (14848K kernel code, 2632K rwdata, 5972K rodata, 4352K init, 580K bss, 191192K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: 256 SPIs implemented [ 0.000000] GICv3: 0 Extended SPIs implemented [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: 16 PPIs implemented [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000 [ 0.000000] ITS [mem 0xfee20000-0xfee3ffff] [ 0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @40100000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GICv3: using LPI property table @0x00000000400d0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000400e0000 [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] } [ 0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] } [ 0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001523] Console: colour dummy device 80x25 [ 0.001667] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001692] pid_max: default: 32768 minimum: 301 [ 0.001863] LSM: Security Framework initializing [ 0.001910] Yama: becoming mindful. [ 0.002061] AppArmor: AppArmor initialized [ 0.002168] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.002205] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 0.005919] rcu: Hierarchical SRCU implementation. [ 0.007134] Platform MSI: interrupt-controller@fee20000 domain created [ 0.007774] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created [ 0.010318] EFI services will not be available. [ 0.011047] smp: Bringing up secondary CPUs ... [ 0.012231] Detected VIPT I-cache on CPU1 [ 0.012282] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000 [ 0.012301] GICv3: CPU1: using allocated LPI pending table @0x00000000400f0000 [ 0.012380] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.013801] Detected VIPT I-cache on CPU2 [ 0.013850] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000 [ 0.013871] GICv3: CPU2: using allocated LPI pending table @0x0000000040180000 [ 0.013947] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.015404] Detected VIPT I-cache on CPU3 [ 0.015453] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000 [ 0.015473] GICv3: CPU3: using allocated LPI pending table @0x0000000040190000 [ 0.015549] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.016968] CPU features: detected: Spectre-v2 [ 0.016975] CPU features: detected: Spectre-v4 [ 0.016981] CPU features: detected: ARM errata 1165522, 1319367, or 1530923 [ 0.016989] Detected PIPT I-cache on CPU4 [ 0.017026] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000 [ 0.017041] GICv3: CPU4: using allocated LPI pending table @0x00000000401a0000 [ 0.017090] CPU4: Booted secondary processor 0x0000000100 [0x410fd082] [ 0.018358] Detected PIPT I-cache on CPU5 [ 0.018398] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000 [ 0.018413] GICv3: CPU5: using allocated LPI pending table @0x00000000401b0000 [ 0.018463] CPU5: Booted secondary processor 0x0000000101 [0x410fd082] [ 0.018659] smp: Brought up 1 node, 6 CPUs [ 0.018769] SMP: Total of 6 processors activated. [ 0.018785] CPU features: detected: 32-bit EL0 Support [ 0.018800] CPU features: detected: CRC32 instructions [ 0.018815] CPU features: detected: 32-bit EL1 Support [ 0.045618] CPU: All CPU(s) started at EL2 [ 0.045701] alternatives: patching kernel code [ 0.049491] devtmpfs: initialized [ 0.066176] Registered cp15_barrier emulation handler [ 0.066206] Registered setend emulation handler [ 0.066452] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.066532] futex hash table entries: 2048 (order: 5, 131072 bytes, linear) [ 0.069552] pinctrl core: initialized pinctrl subsystem [ 0.070232] D [ 2.874820] e1000e: Intel(R) PRO/1000 Network Driver [ 2.875262] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 2.875840] igb: Intel(R) Gigabit Ethernet Network Driver [ 2.876319] igb: Copyright (c) 2007-2014 Intel Corporation. [ 2.876843] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 2.877395] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 2.878240] sky2: driver version 1.30 [ 2.879311] VFIO - User Level meta-driver version: 0.3 [ 2.899300] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.899900] ehci-pci: EHCI PCI platform driver [ 2.900333] ehci-platform: EHCI generic platform driver [ 2.903214] ehci-platform fe380000.usb: EHCI Host Controller [ 2.903737] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1 [ 2.905097] ehci-platform fe380000.usb: irq 38, io mem 0xfe380000 [ 2.917850] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00 [ 2.918673] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 2.919404] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.920042] usb usb1: Product: EHCI Host Controller [ 2.920477] usb usb1: Manufacturer: Linux 5.10.21-rockchip64 ehci_hcd [ 2.921047] usb usb1: SerialNumber: fe380000.usb [ 2.922031] hub 1-0:1.0: USB hub found [ 2.922405] hub 1-0:1.0: 1 port detected [ 2.923569] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 2.924133] ohci-pci: OHCI PCI platform driver [ 2.924578] ohci-platform: OHCI generic platform driver [ 2.925363] ohci-platform fe3a0000.usb: Generic Platform OHCI controller [ 2.926005] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 2 [ 2.926817] ohci-platform fe3a0000.usb: irq 39, io mem 0xfe3a0000 [ 2.990054] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 2.990786] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.991424] usb usb2: Product: Generic Platform OHCI controller [ 2.991948] usb usb2: Manufacturer: Linux 5.10.21-rockchip64 ohci_hcd [ 2.992518] usb usb2: SerialNumber: fe3a0000.usb [ 2.993436] hub 2-0:1.0: USB hub found [ 2.993810] hub 2-0:1.0: 1 port detected [ 2.995844] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 2.996350] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 3 [ 2.997200] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010 [ 2.998107] xhci-hcd xhci-hcd.0.auto: irq 76, io mem 0xfe900000 [ 2.999054] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 2.999786] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.000423] usb usb3: Product: xHCI Host Controller [ 3.000857] usb usb3: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 3.001427] usb usb3: SerialNumber: xhci-hcd.0.auto [ 3.002454] hub 3-0:1.0: USB hub found [ 3.002833] hub 3-0:1.0: 1 port detected [ 3.003530] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.004026] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4 [ 3.004710] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.005364] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.006239] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 3.006969] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.007606] usb usb4: Product: xHCI Host Controller [ 3.008042] usb usb4: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 3.008610] usb usb4: SerialNumber: xhci-hcd.0.auto [ 3.009532] hub 4-0:1.0: USB hub found [ 3.009951] hub 4-0:1.0: 1 port detected [ 3.010784] usbcore: registered new interface driver usb-storage [ 3.014057] mousedev: PS/2 mouse device common for all mice [ 3.016000] i2c /dev entries driver [ 3.020395] pca953x 2-0020: using no AI [ 3.031513] rk808 0-001b: chip id: 0x0 [ 3.035758] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 3.036332] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 3.036880] rk808-regulator rk808-regulator: max buck steps per change: 4 [ 3.038662] vdd_center: supplied by vcc5v0_sys [ 3.039730] vdd_cpu_l: supplied by vcc5v0_sys [ 3.040461] vcc_ddr_s3: supplied by vcc5v0_sys [ 3.041533] vcc1v8_sys_s3: supplied by vcc5v0_sys [ 3.042646] vcc1v8_dvp: supplied by vcc5v0_sys [ 3.043528] vcc3v0_touch: supplied by vcc5v0_sys [ 3.045286] vcc1v8_s3: supplied by vcc5v0_sys [ 3.045984] vcc_sdio_s0: Bringing 3300000uV into 3000000-3000000uV [ 3.047688] vcc_sdio_s0: supplied by vcc5v0_sys [ 3.048598] vcca3v0_codec: supplied by vcc5v0_sys [ 3.050233] vcc1v5_s3: supplied by vcc5v0_sys [ 3.051126] vcca1v8_codec: supplied by vcc5v0_sys [ 3.052740] vcc3v0_s3: supplied by vcc5v0_sys [ 3.053289] vcc3v3_sys_s0: failed to get the current voltage: -EPROBE_DEFER [ 3.053944] vcc3v3_sys_s0: supplied by vcc3v3_sys_s3 [ 3.054928] vcc3v3_s0: supplied by vcc3v3_sys_s3 [ 3.059144] rk808-rtc rk808-rtc: registered as rtc0 [ 3.060147] rk808-rtc rk808-rtc: setting system clock to 2021-03-25T06:02:28 UTC (1616652148) [ 3.064034] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected! [ 3.065970] vcc1v8_sys_s0: supplied by vcc1v8_sys_s3 [ 3.066501] avdd_0v9_s0: supplied by vcc1v8_sys_s3 [ 3.067030] vdd_cpu_b: supplied by vcc5v0_sys [ 3.070468] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected! [ 3.072328] vdd_gpu: supplied by vcc5v0_sys [ 3.080429] dw_wdt ff848000.watchdog: No valid TOPs array specified [ 3.083114] sdhci: Secure Digital Host Controller Interface driver [ 3.083663] sdhci: Copyright(c) Pierre Ossman [ 3.084081] Synopsys Designware Multimedia Card Interface Driver [ 3.086005] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.086434] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode. [ 3.087152] dwmmc_rockchip fe320000.mmc: Using internal DMA controller. [ 3.087745] dwmmc_rockchip fe320000.mmc: Version ID is 270a [ 3.088296] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo [ 3.089659] mmc2: CQHCI version 5.10 [ 3.089684] dwmmc_rockchip fe320000.mmc: Got CD GPIO [ 3.091387] ledtrig-cpu: registered to indicate activity on CPUs [ 3.093095] hid: raw HID events driver (C) Jiri Kosina [ 3.093694] usbcore: registered new interface driver usbhid [ 3.094262] usbhid: USB HID core driver [ 3.100816] drop_monitor: Initializing network drop monitor service [ 3.102285] NET: Registered protocol family 10 [ 3.103420] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 3.116591] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA [ 3.117621] random: fast init done [ 3.159957] Segment Routing with IPv6 [ 3.160380] NET: Registered protocol family 17 [ 3.160930] 8021q: 802.1Q VLAN Support v1.8 [ 3.161367] Key type dns_resolver registered [ 3.162398] registered taskstats version 1 [ 3.162774] Loading compiled-in X.509 certificates [ 3.166754] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' [ 3.166871] mmc_host mmc1: Bus speed (slot 0) = 100000000Hz (slot req 100000000Hz, actual 100000000HZ div = 0) [ 3.174086] zswap: loaded using pool zstd/z3fold [ 3.174873] Key type ._fscrypt registered [ 3.175234] Key type .fscrypt registered [ 3.175585] Key type fscrypt-provisioning registered [ 3.179224] Btrfs loaded, crc32c=crc32c-generic [ 3.186617] mmc2: Command Queue Engine enabled [ 3.187051] mmc2: new HS400 Enhanced strobe MMC card at address 0001 [ 3.188716] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB [ 3.189440] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB [ 3.190401] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB [ 3.191204] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB, chardev (243:0) [ 3.193402] mmcblk2: p1 p2 [ 3.203410] Key type encrypted registered [ 3.203794] AppArmor: AppArmor sha1 policy hashing enabled [ 3.255881] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges: [ 3.256538] rockchip-pcie f8000000.pcie: MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000 [ 3.257296] rockchip-pcie f8000000.pcie: IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000 [ 3.315126] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00 [ 3.315721] pci_bus 0000:00: root bus resource [bus 00-1f] [ 3.316210] pci_bus 0000:00: root bus resource [mem 0xfa000000-0xfbdfffff] [ 3.316822] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0xfbe00000-0xfbefffff]) [ 3.317709] pci 0000:00:00.0: [1d87:0100] type 01 class 0x060400 [ 3.318412] pci 0000:00:00.0: supports D1 [ 3.318773] pci 0000:00:00.0: PME# supported from D0 D1 D3hot [ 3.325166] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 3.326141] pci 0000:01:00.0: [197b:0585] type 00 class 0x010601 [ 3.326736] pci 0000:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid [ 3.327360] pci 0000:01:00.0: reg 0x10: [io size 0x0080] [ 3.327867] pci 0000:01:00.0: reg 0x14: initial BAR value 0x00000000 invalid [ 3.328489] pci 0000:01:00.0: reg 0x14: [io size 0x0080] [ 3.328996] pci 0000:01:00.0: reg 0x18: initial BAR value 0x00000000 invalid [ 3.329618] pci 0000:01:00.0: reg 0x18: [io size 0x0080] [ 3.330141] pci 0000:01:00.0: reg 0x1c: initial BAR value 0x00000000 invalid [ 3.330763] pci 0000:01:00.0: reg 0x1c: [io size 0x0080] [ 3.331270] pci 0000:01:00.0: reg 0x20: initial BAR value 0x00000000 invalid [ 3.331892] pci 0000:01:00.0: reg 0x20: [io size 0x0080] [ 3.332399] pci 0000:01:00.0: reg 0x24: [mem 0x00000000-0x00001fff] [ 3.332981] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref] [ 3.333603] pci 0000:01:00.0: Max Payload Size set to 256 (was 128, max 512) [ 3.334584] pci 0000:01:00.0: PME# supported from D3hot [ 3.335289] pci 0000:01:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 5.0 GT/s PCIe x2 link at 0000:00:00.0 (capable of 15.752 Gb/s with 8.0 GT/s PCIe x2 link) [ 3.337879] usb 3-1: new high-speed USB device number 2 using xhci-hcd [ 3.342984] pci_bus 0000:01: busn_res: [bus 01-1f] end is updated to 01 [ 3.343592] pci 0000:00:00.0: BAR 14: assigned [mem 0xfa000000-0xfa0fffff] [ 3.344209] pci 0000:01:00.0: BAR 6: assigned [mem 0xfa000000-0xfa00ffff pref] [ 3.344850] pci 0000:01:00.0: BAR 5: assigned [mem 0xfa010000-0xfa011fff] [ 3.345463] pci 0000:01:00.0: BAR 0: no space for [io size 0x0080] [ 3.346034] pci 0000:01:00.0: BAR 0: failed to assign [io size 0x0080] [ 3.346621] pci 0000:01:00.0: BAR 1: no space for [io size 0x0080] [ 3.347175] pci 0000:01:00.0: BAR 1: failed to assign [io size 0x0080] [ 3.347759] pci 0000:01:00.0: BAR 2: no space for [io size 0x0080] [ 3.348313] pci 0000:01:00.0: BAR 2: failed to assign [io size 0x0080] [ 3.348898] pci 0000:01:00.0: BAR 3: no space for [io size 0x0080] [ 3.349452] pci 0000:01:00.0: BAR 3: failed to assign [io size 0x0080] [ 3.350080] pci 0000:01:00.0: BAR 4: no space for [io size 0x0080] [ 3.350634] pci 0000:01:00.0: BAR 4: failed to assign [io size 0x0080] [ 3.351221] pci 0000:00:00.0: PCI bridge to [bus 01] [ 3.351440] dwmmc_rockchip fe320000.mmc: All phases bad! [ 3.351672] pci 0000:00:00.0: bridge window [mem 0xfa000000-0xfa0fffff] [ 3.352144] mmc1: tuning execution failed: -5 [ 3.352968] pcieport 0000:00:00.0: enabling device (0000 -> 0002) [ 3.353990] pcieport 0000:00:00.0: PME: Signaling with IRQ 90 [ 3.354842] pcieport 0000:00:00.0: AER: enabled with IRQ 90 [ 3.355674] ahci 0000:01:00.0: version 3.0 [ 3.356061] ahci 0000:01:00.0: enabling device (0000 -> 0002) [ 3.357163] ahci 0000:01:00.0: SSS flag set, parallel bus scan disabled [ 3.357872] ahci 0000:01:00.0: AHCI 0001.0301 32 slots 5 ports 6 Gbps 0x1f impl SATA mode [ 3.358598] ahci 0000:01:00.0: flags: 64bit ncq sntf stag pm led clo pmp fbs pio slum part ccc apst boh [ 3.363118] scsi host0: ahci [ 3.364074] scsi host1: ahci [ 3.364942] scsi host2: ahci [ 3.365790] scsi host3: ahci [ 3.366651] scsi host4: ahci [ 3.367142] ata1: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010100 irq 91 [ 3.367799] ata2: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010180 irq 92 [ 3.368453] ata3: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010200 irq 93 [ 3.369107] ata4: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010280 irq 94 [ 3.369760] ata5: SATA max UDMA/133 abar m8192@0xfa010000 port 0xfa010300 irq 95 [ 3.378516] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 3.381047] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 3.381609] of_cfs_init [ 3.382171] of_cfs_init: OK [ 3.383916] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console [ 3.421067] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 3.422071] mmc1: new high speed SDHC card at address 0001 [ 3.424025] mmcblk1: mmc1:0001 00000 29.8 GiB [ 3.427438] mmcblk1: p1 [ 3.487785] usb 3-1: New USB device found, idVendor=2109, idProduct=2815, bcdDevice= 7.04 [ 3.488511] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.489141] usb 3-1: Product: USB2.0 Hub [ 3.489592] usb 3-1: Manufacturer: VIA Labs, Inc. [ 3.549696] hub 3-1:1.0: USB hub found [ 3.550274] hub 3-1:1.0: 4 ports detected [ 3.613930] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd [ 3.762956] usb 4-1: New USB device found, idVendor=2109, idProduct=0815, bcdDevice= 7.04 [ 3.763683] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.764313] usb 4-1: Product: USB3.0 Hub [ 3.764764] usb 4-1: Manufacturer: VIA Labs, Inc. [ 3.789664] hub 4-1:1.0: USB hub found [ 3.790147] hub 4-1:1.0: 4 ports detected [ 4.361855] usb 3-1.1: new full-speed USB device number 3 using xhci-hcd [ 4.511947] usb 3-1.1: New USB device found, idVendor=1cf1, idProduct=0030, bcdDevice= 1.00 [ 4.512687] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4.513332] usb 3-1.1: Product: ConBee II [ 4.513692] usb 3-1.1: Manufacturer: dresden elektronik ingenieurtechnik GmbH [ 4.514342] usb 3-1.1: SerialNumber: DE2140506 [ 4.589965] usb 4-1.3: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd [ 4.611153] usb 4-1.3: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00 [ 4.611890] usb 4-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4.612535] usb 4-1.3: Product: Flash Drive FIT [ 4.612940] usb 4-1.3: Manufacturer: Samsung [ 4.613323] usb 4-1.3: SerialNumber: 0361420010003905 [ 4.614822] usb-storage 4-1.3:1.0: USB Mass Storage device detected [ 4.615909] usb-storage 4-1.3:1.0: Quirks match for vid 090c pid 1000: 400 [ 4.616698] scsi host5: usb-storage 4-1.3:1.0 [ 4.697933] usb 4-1.4: new SuperSpeed Gen 1 USB device number 4 using xhci-hcd [ 4.718928] usb 4-1.4: New USB device found, idVendor=0bda, idProduct=8156, bcdDevice=30.00 [ 4.719667] usb 4-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=6 [ 4.720313] usb 4-1.4: Product: USB 10/100/1G/2.5G LAN [ 4.720770] usb 4-1.4: Manufacturer: Realtek [ 4.721152] usb 4-1.4: SerialNumber: 000000001 [ 6.531160] scsi 5:0:0:0: Direct-Access Samsung Flash Drive FIT 1100 PQ: 0 ANSI: 6 [ 6.533161] sd 5:0:0:0: [sda] 250626566 512-byte logical blocks: (128 GB/120 GiB) [ 6.534134] sd 5:0:0:0: [sda] Write Protect is off [ 6.534571] sd 5:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 6.535256] sd 5:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 6.540687] sd 5:0:0:0: [sda] Attached SCSI removable disk [ 9.661883] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 9.836972] ata1.00: ATA-9: WDC WD120EFAX-68UNTN0, 81.00A81, max UDMA/133 [ 9.837580] ata1.00: 23437770752 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 9.960706] ata1.00: configured for UDMA/133 [ 9.961495] scsi 0:0:0:0: Direct-Access ATA WDC WD120EFAX-68 0A81 PQ: 0 ANSI: 5 [ 9.963467] sd 0:0:0:0: [sdb] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB) [ 9.964170] sd 0:0:0:0: [sdb] 4096-byte physical blocks [ 9.964703] sd 0:0:0:0: [sdb] Write Protect is off [ 9.965141] sd 0:0:0:0: [sdb] Mode Sense: 00 3a 00 00 [ 9.965705] sd 0:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 10.104873] sd 0:0:0:0: [sdb] Attached SCSI disk [ 10.437862] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) [ 10.444890] ata2.00: ATA-9: WDC WD120EFAX-68UNTN0, 81.00A81, max UDMA/133 [ 10.445506] ata2.00: 23437770752 sectors, multi 0: LBA48 NCQ (depth 32), AA [ 10.458244] ata2.00: configured for UDMA/133 [ 10.459207] scsi 1:0:0:0: Direct-Access ATA WDC WD120EFAX-68 0A81 PQ: 0 ANSI: 5 [ 10.461291] sd 1:0:0:0: [sdc] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB) [ 10.462029] sd 1:0:0:0: [sdc] 4096-byte physical blocks [ 10.462563] sd 1:0:0:0: [sdc] Write Protect is off [ 10.463001] sd 1:0:0:0: [sdc] Mode Sense: 00 3a 00 00 [ 10.463567] sd 1:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 10.487844] sd 1:0:0:0: [sdc] Attached SCSI disk [ 10.776488] ata3: SATA link down (SStatus 0 SControl 300) [ 11.092279] ata4: SATA link down (SStatus 0 SControl 300) [ 11.408280] ata5: SATA link down (SStatus 0 SControl 300) [ 11.412037] Freeing unused kernel memory: 4352K [ 11.412622] Run /init as init process [ 11.412958] with arguments: [ 11.413230] /init [ 11.413440] earlyprintk [ 11.413695] with environment: [ 11.414036] HOME=/ [ 11.414255] TERM=linux [ 11.414504] ubootpart=559a8d18-01 [ 11.414834] cgroup_enable=memory [ 11.415157] cgroup_memory=1 Loading, please wait... Starting version 241 [ 12.377133] input: adc-keys as /devices/platform/adc-keys/input/input1 [ 12.448183] rk_gmac-dwmac fe300000.ethernet: IRQ eth_wake_irq not found [ 12.448801] rk_gmac-dwmac fe300000.ethernet: IRQ eth_lpi not found [ 12.449602] rk_gmac-dwmac fe300000.ethernet: PTP uses main clock [ 12.450889] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input). [ 12.451539] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28). [ 12.452056] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20). [ 12.452582] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no). [ 12.453269] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed [ 12.453979] rk_gmac-dwmac fe300000.ethernet: clock input from PHY [ 12.459563] rk_gmac-dwmac fe300000.ethernet: init for RGMII [ 12.461533] rk_gmac-dwmac fe300000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 12.463968] rk_gmac-dwmac fe300000.ethernet: DWMAC1000 [ 12.464447] rk_gmac-dwmac fe300000.ethernet: DMA HW capability register supported [ 12.465109] rk_gmac-dwmac fe300000.ethernet: RX Checksum Offload Engine supported [ 12.465770] rk_gmac-dwmac fe300000.ethernet: COE Type 2 [ 12.466679] rk_gmac-dwmac fe300000.ethernet: TX Checksum insertion supported [ 12.467304] rk_gmac-dwmac fe300000.ethernet: Wake-Up On Lan supported [ 12.468003] rk_gmac-dwmac fe300000.ethernet: Normal descriptors [ 12.468535] rk_gmac-dwmac fe300000.ethernet: Ring mode enabled [ 12.469053] rk_gmac-dwmac fe300000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 12.611720] libphy: stmmac: probed [ 12.612067] RTL8211F Gigabit Ethernet stmmac-0:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:00, irq=POLL) [ 12.613199] RTL8211F Gigabit Ethernet stmmac-0:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=stmmac-0:01, irq=POLL) [ 12.670078] usbcore: registered new interface driver uas Begin: Loading essential drivers ... [ 12.913990] async_tx: api initialized (async) done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.33.1 [/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1 /dev/mmcblk1p1: recovering journal /dev/mmcblk1p1: Clearing orphaned inode 771183 (uid=0, gid=0, mode=0100600, size=0) /dev/mmcblk1p1: Clearing orphaned inode 771182 (uid=0, gid=0, mode=0100600, size=0) /dev/mmcblk1p1: Clearing orphaned inode 771181 (uid=0, gid=0, mode=0100600, size=0) /dev/mmcblk1p1: Clearing orphaned inode 771180 (uid=0, gid=0, mode=0100600, size=0) /dev/mmcblk1p1: clean, 306997/2212736 files, 2670708/7732920 blocks [ 14.267611] random: crng init done done. [ 15.181482] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null) done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. [ 16.205219] systemd[1]: Inserted module 'autofs4' [ 16.284080] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid) [ 16.287433] systemd[1]: Detected architecture arm64. Welcome to Armbian 21.02.3 Buster! [ 16.338886] systemd[1]: Set hostname to <helios64>. [ 17.689649] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly. [ 17.711946] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly. [ 17.755630] systemd[1]: /lib/systemd/system/fancontrol.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/fancontrol.pid → /run/fancontrol.pid; please update the unit file accordingly. [ 17.760077] systemd[1]: /lib/systemd/system/fail2ban.service:12: PIDFile= references path below legacy directory /var/run/, updating /var/run/fail2ban/fail2ban.pid → /run/fail2ban/fail2ban.pid; please update the unit file accordingly. [ 17.811539] systemd[1]: /lib/systemd/system/rpc-statd.service:13: PIDFile= references path below legacy directory /var/run/, updating /var/run/rpc.statd.pid → /run/rpc.statd.pid; please update the unit file accordingly. [ 17.940013] systemd[1]: Reached target System Time Synchronized. [ OK ] Reached target System Time Synchronized. [ 17.950474] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Device-mapper event daemon FIFOs. [ OK ] Created slice User and Session Slice. [ OK ] Started Forward Password R…uests to Wall Directory Watch. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on LVM2 poll daemon socket. [ OK ] Listening on Journal Audit Socket. [ OK ] Listening on Syslog Socket. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Set up automount Arbitrary…s File System Automount Point. [ OK ] Listening on Journal Socket. Starting Set the console keyboard layout... Mounting Kernel Debug File System... Starting Monitoring of LVM…meventd or progress polling... Mounting Huge Pages File System... Starting Nameserver information manager... [ OK ] Reached target Swap. [ OK ] Created slice system-getty.slice. Starting Load Kernel Modules... [ OK ] Created slice system-wg\x2dquick.slice. Mounting POSIX Message Queue File System... [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Reached target Local Encrypted Volumes. Starting Uncomplicated firewall... [ OK ] Listening on Network Service Netlink Socket. [ 18.276563] lm75 2-004c: supply vs not found, using dummy regulator [ 18.277916] lm75 2-004c: hwmon2: sensor 'lm75' Mounting RPC Pipe File System... Mounting NFSD configuration filesystem... [ OK ] Listening on initctl Compatibility Named Pipe. Starting Create list of re…odes for the current kernel... [ OK ] Listening on Journal Socket (/dev/log). Starting Journal Service... [ OK ] Listening on fsck to fsckd communication Socket. Starting Remount Root and Kernel File Systems... [ OK ] Reached target Slices. Starting Availability of block devices... [ OK ] Listening on udev Control Socket. Starting udev Coldplug all Devices... [ 18.441120] RPC: Registered named UNIX socket transport module. [ 18.441656] RPC: Registered udp transport module. [ 18.442116] RPC: Registered tcp transport module. [ 18.442537] RPC: Registered tcp NFSv4.1 backchannel transport module. [ OK ] Started Set the console keyboard layout. [ 18.475928] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro [ OK ] Mounted Kernel Debug File System. [ OK ] Started Monitoring of LVM2… dmeventd or progress polling. [ OK ] Mounted Huge Pages File System. [FAILED] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Uncomplicated firewall. [ OK ] Mounted RPC Pipe File System. [ 18.584885] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ OK ] Started Create list of req… nodes for the current kernel. [ OK ] Mounted NFSD configuration filesystem. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Availability of block devices. [ OK ] Started Nameserver information manager. Starting Create System Users... Starting Load/Save Random Seed... Starting pNFS block layout mapping daemon... Starting Apply Kernel Variables... Mounting FUSE Control File System... Mounting Kernel Configuration File System... [ OK ] Started Journal Service. [ OK ] Started Create System Users. [ OK ] Started Load/Save Random Seed. [ OK ] Started pNFS block layout mapping daemon. [ OK ] Started Apply Kernel Variables. [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Kernel Configuration File System. Starting Create Static Device Nodes in /dev... Starting Flush Journal to Persistent Storage... [ 18.973972] systemd-journald[454]: Received request to flush runtime journal from PID 1 [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting Mount /tmp as tmp…e access to the root device... [ OK ] Mounted Mount /tmp as tmpf…ite access to the root device. [ OK ] Reached target Local File Systems. Starting netfilter persistent configuration... Starting Set console font and keymap... Starting Cleanup PHP session files... Starting Preprocess NFS configuration... Starting Load AppArmor profiles... Starting folder2ram systemd service... Starting Create Volatile Files and Directories... Starting Cleanup monit state file... [ OK ] Started udev Coldplug all Devices. [ OK ] Started Set console font and keymap. [ OK ] Started Cleanup PHP session files. [ OK ] Started Preprocess NFS configuration. [ OK ] Started Cleanup monit state file. Starting NFSv4 ID-name mapping service... [ OK ] Reached target NFS client services. Starting Helper to synchronize boot up for ifupdown... [ OK ] Started Create Volatile Files and Directories. Starting RPC bind portmap service... Starting Update UTMP about System Boot/Shutdown... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Helper to synchronize boot up for ifupdown. [ OK ] Started NFSv4 ID-name mapping service. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started RPC bind portmap service. [ OK ] Reached target RPC Port Mapper. [ 19.717425] audit: type=1400 audit(1616652165.152:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=578 comm="apparmor_parser" [ 19.725191] audit: type=1400 audit(1616652165.160:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=580 comm="apparmor_parser" [ 19.726588] audit: type=1400 audit(1616652165.160:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=580 comm="apparmor_parser" [ 19.727904] audit: type=1400 audit(1616652165.160:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_groff" pid=580 comm="apparmor_parser" [ 19.733939] audit: type=1400 audit(1616652165.172:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=579 comm="apparmor_parser" [ 19.736637] audit: type=1400 audit(1616652165.172:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=579 comm="apparmor_parser" [ 19.747792] audit: type=1400 audit(1616652165.184:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/chronyd" pid=576 comm="apparmor_parser" [ 19.778839] audit: type=1400 audit(1616652165.216:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=581 comm="apparmor_parser" [ 19.780355] audit: type=1400 audit(1616652165.216:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=581 comm="apparmor_parser" [ 19.781749] audit: type=1400 audit(1616652165.216:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd//third_party" pid=581 comm="apparmor_parser" [ OK ] Started Load AppArmor profiles. [ OK ] Started Entropy daemon using the HAVEGE algorithm. [ OK ] Reached target System Initialization. Starting Docker Socket for the API. [ OK ] Started Discard unused blocks once a week. [ OK ] Started Daily rotation of log files. Starting Armbian hardware optimization... [ OK ] Listening on CUPS Scheduler. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Started Trigger anacron every hour. [ OK ] Started Daily man-db regeneration. Starting Armbian hardware monitoring... [ OK ] Started Daily apt download activities. [ OK ] Started Daily apt upgrade and clean activities. [ 20.074420] input: beeper as /devices/platform/beeper/input/input2 [ OK ] Listening on saned incoming socket. [ OK ] Started Clean PHP session files every 30 mins. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Started CUPS Scheduler. [ OK ] Reached target Paths. [ OK ] Started netfilter persistent configuration. [ OK ] Listening on Docker Socket for the API. [ OK ] Started Armbian hardware monitoring. [ 20.275199] sd 5:0:0:0: Attached scsi generic sg0 type 0 [ 20.275820] sd 0:0:0:0: Attached scsi generic sg1 type 0 [ 20.276372] sd 1:0:0:0: Attached scsi generic sg2 type 0 [ OK ] Found device /dev/ttyS2. [ 20.300218] OF: graph: no port node found in /i2c@ff3d0000/typec-portc@22 [ 20.322090] mc: Linux media interface: v0.10 [ OK ] Started Armbian hardware optimization. [ 20.348180] OF: graph: no port node found in /syscon@ff770000/usb2-phy@e450/otg-port [ 20.351234] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 20.351772] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 5 [ 20.352644] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000010002010010 [ 20.353509] xhci-hcd xhci-hcd.2.auto: irq 75, io mem 0xfe800000 [ 20.354656] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 20.355392] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 20.356027] usb usb5: Product: xHCI Host Controller [ 20.356456] usb usb5: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 20.357022] usb usb5: SerialNumber: xhci-hcd.2.auto [ 20.358066] hub 5-0:1.0: USB hub found [ 20.358469] hub 5-0:1.0: 1 port detected [ 20.359270] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 20.359788] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6 [ 20.360495] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 20.361953] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. [ 20.362828] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 20.363560] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 20.364201] usb usb6: Product: xHCI Host Controller [ 20.364640] usb usb6: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 20.365212] usb usb6: SerialNumber: xhci-hcd.2.auto [ 20.366327] hub 6-0:1.0: USB hub found [ 20.366716] hub 6-0:1.0: 1 port detected [ 20.465560] panfrost ff9a0000.gpu: clock rate = 500000000 [ 20.479107] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 20.480522] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 [ 20.486530] videodev: Linux video capture interface: v2.00 [ 20.488460] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 20.489605] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 20.514357] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0 [ OK ] Reached target Sockets. [ OK ] Reached target Network (Pre). Starting Raise network interfaces... Starting Network Service... [ 21.603945] cdc_acm 3-1.1:1.0: ttyACM0: USB ACM device [ 21.605266] usbcore: registered new interface driver cdc_acm [ 21.605775] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ OK ] Found device Flash_Drive_FIT MyLinuxLive. [ 21.725734] usb 4-1.4: reset SuperSpeed Gen 1 USB device number 4 using xhci-hcd [ OK ] Found device WDC_WD120EFAX-68UNTN0 WDRED12TB1. [ 21.814653] rockchip-vop ff8f0000.vop: Adding to iommu group 2 [ 21.815731] rockchip-vop ff900000.vop: Adding to iommu group 3 [ OK ] Found device WDC_WD120EFAX-68UNTN0 WDRED12TB2. [ 21.823826] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm]) [ 21.824699] [drm] unsupported AFBC format[3231564e] [ 21.826674] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm]) [ 21.848609] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm]) [ 21.850020] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 21.851569] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 [ 21.866346] r8152 4-1.4:1.0 (unnamed net_device) (uninitialized): netif_napi_add() called with weight 256 [ 21.882371] r8152 4-1.4:1.0 eth1: v2.14.0 (2020/09/24) [ 21.882849] r8152 4-1.4:1.0 eth1: This product is covered by one or more of the following patents: [ 21.882849] US6,570,884, US6,115,776, and US6,327,625. [ 21.882849] [ 21.884444] usbcore: registered new interface driver r8152 Starting File System Check…ev/disk/by-label/WDRED12TB2... [ 21.924099] rockchip-rga ff680000.rga: HW Version: 0x03.02 [ 21.925055] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0 Starting File System Check…ev/disk/by-label/WDRED12TB1... Starting File System Check…/dev/disk/by-uuid/02ED-D7DD... [ 22.668617] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. [ 22.669035] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn [ 22.672774] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 22.674553] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [ 22.675653] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2 [ 22.692688] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned. [ 22.694987] rkvdec ff660000.video-codec: Adding to iommu group 1 [ OK ] Started File System Check …/dev/disk/by-label/WDRED12TB2. [ OK ] Started File System Check …/dev/disk/by-label/WDRED12TB1. [ OK ] Started File System Check Daemon to report status. [ 22.882126] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes Mounting /srv/dev-disk-by-label-WDRED12TB1... [ 23.658194] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) Mounting /srv/dev-disk-by-label-WDRED12TB2... [ 23.664639] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 23.665376] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 23.666947] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ OK ] Started Network Service. [FAILED] Failed to mount /srv/dev-disk-by-label-WDRED12TB1. See 'systemctl status "srv-dev\\x2ddisk…bel\\x2dWDRED12TB1.mount"' for details. [ 23.706758] Unable to handle kernel NULL pointer dereference at virtual address 00000000000009b0 [ 23.707534] Mem abort info: [ 23.707784] ESR = 0x96000044 [ 23.708059] EC = 0x25: DABT (current EL), IL = 32 bits [ 23.708526] SET = 0, FnV = 0 [ 23.708799] EA = 0, S1PTW = 0 [ 23.709076] Data abort info: [ 23.709333] ISV = 0, ISS = 0x00000044 [ 23.709672] CM = 0, WnR = 1 [ 23.709938] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000042080000 [ 23.710503] [00000000000009b0] pgd=0000000000000000, p4d=0000000000000000 [ 23.711109] Internal error: Oops: 96000044 [#1] PREEMPT SMP [ 23.711601] Modules linked in: rockchip_vdec(C) hantro_vpu(C) snd_soc_hdmi_codec rockchip_rga v4l2_h264 videobuf2_dma_contig rockchipdrm snd_soc_rockchip_i2s dw_mipi_dsi v4l2_mem2mem videobuf2_dma_sg snd_soc_core videobuf2_vmalloc videobuf2_memops dw_hdmi videobuf2_v4l2 r8152 cdc_acm analogix_dp snd_pcm_dmaengine snd_pcm videobuf2_common drm_kms_helper snd_timer videodev panfrost cec leds_pwm snd gpu_sched rc_core mc soundcore fusb302 gpio_charger pwm_fan sg drm tcpm typec drm_panel_orientation_quirks gpio_beeper xt_conntrack nft_counter cpufreq_dt nft_chain_nat xt_nat xt_tcpudp xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 xt_comment xt_addrtype nft_compat nf_tables nfnetlink nfsd auth_rpcgss nfs_acl lockd grace sunrpc ledtrig_netdev lm75 ip_tables x_tables autofs4 raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear md_mod uas realtek dwmac_rk stmmac_platform stmmac pcs_xpcs adc_keys [ 23.719224] CPU: 4 PID: 0 Comm: swapper/4 Tainted: G C 5.10.21-rockchip64 #21.02.3 [ 23.719999] Hardware name: Helios64 (DT) [ 23.720352] pstate: 80000085 (Nzcv daIf -PAN -UAO -TCO BTYPE=--) [ 23.720895] pc : update_rq_clock+0x28/0x108 [ 23.721268] lr : sched_ttwu_pending+0x78/0x160 [ 23.721661] sp : ffff800011c0be30 [ 23.721955] x29: ffff800011c0be30 x28: ffff000040310e80 [ 23.722430] x27: ffff000040004300 x26: ffff800011cebde0 [ 23.722903] x25: 0000000000000001 x24: 0000000000000000 [ 23.723376] x23: 0000000000000000 x22: ffff000040375738 [ 23.723849] x21: ffff8000118b9948 x20: ffff0000f77a7d00 [ 23.724322] x19: ffff0000f77a7d00 x18: 0000000000000000 [ 23.724796] x17: 0000000000000000 x16: 0000000000000000 [ 23.725268] x15: 00000244fdf180f8 x14: 0000000000000012 [ 23.725742] x13: 00000000000002c3 x12: 0000000000000001 0 Quote
wurmfood Posted March 25, 2021 Posted March 25, 2021 On 3/25/2021 at 6:18 AM, Vin said: WD120EFAX-68UNTN0 Expand One note: It looks like you have CMR drives from WD in there. Those are known to have a variety of problems and may be contributing to the issues you're seeing. 0 Quote
ShadowDance Posted March 25, 2021 Posted March 25, 2021 On 3/25/2021 at 11:51 PM, wurmfood said: One note: It looks like you have CMR drives from WD in there. Those are known to have a variety of problems and may be contributing to the issues you're seeing. Expand Are you sure about that? Generally CMR is considered good, SMR is what you'd want to stay away from. Is it something related to these specific drives? 0 Quote
wurmfood Posted March 26, 2021 Posted March 26, 2021 On 3/25/2021 at 11:58 PM, ShadowDance said: Are you sure about that? Generally CMR is considered good, SMR is what you'd want to stay away from. Is it something related to these specific drives? Expand Ah! Sorry, yes, you're right. I've been looking at these back and forth for the last few days. A lot of people here have been having trouble with WD drives and at least some of that seems to come down to the difference between the two types of drives. 1 Quote
SIGSEGV Posted March 26, 2021 Posted March 26, 2021 Thanks for the information @gprovost. From the looks of it - Armbian 21.02.03 seems to install the Rockchip Blob. Where does the U-boot TPL/SPL come from ?? the new beta builds? Regards. 0 Quote
gprovost Posted March 26, 2021 Posted March 26, 2021 On 3/26/2021 at 1:40 AM, SIGSEGV said: From the looks of it - Armbian 21.02.03 seems to install the Rockchip Blob. Expand Yes it install the package but doesn't automatically update the bootloader on the target (sdcard or eMMC) For this you will need nand-sata-install -> option 5 0 Quote
bunducafe Posted March 26, 2021 Posted March 26, 2021 After fiddeling aroud I finally have the helios64 also running solid. I never had any freezes before just some problems with getting the system to boot from the emmc device and, see other thread, with setting up OMV - LUKS - Snapraid - UnionFS I am currently under: Linux helios64 5.10.21-rockchip64 #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 aarch64 GNU/Linux OMV Version 5.6.2-1 (Usul) So I would say that OMV is not the culprit out of the box. The system works fine but it always depends on what kind of plugins you are using etc. So far I have no docker installed here but I certainly will do that again. I do recommend the OMV Backup Plugin so I can boot from the latest stable release via SDcard if I mess up with something. That's also nice. 1 Quote
alchemist Posted March 29, 2021 Posted March 29, 2021 Mine is rock solid too, running nextcloud on nginx, nfs, samba, mysql. I have a custom system. 0 Quote
yalman Posted March 29, 2021 Posted March 29, 2021 i must restart the helios64 every day. it is unusable at this time. :( 0 Quote
Alexander Eiblinger Posted March 29, 2021 Posted March 29, 2021 My Helios is "semi-table". The only issue I'm having is every now an then a "lost" disk in ZFS - usually during high load. uname -a Linux helios64 5.9.14-rockchip64 #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020 aarch64 GNU/Linux 0 Quote
hartraft Posted March 29, 2021 Posted March 29, 2021 My system has been "stable" running the LK 5.9. I updated to 5.10 in the past but had issues with stability under small load, not rebooting through omv etc. so I went back to the previous version. Running MergerFS / SnapRAID / LUKS on Seagate Ironwolves with the 1.2ghz frequency $ uname - a Linux helios64 5.9.14-rockchip64 #20.11.3 SMP PREEMPT Fri Dec 11 20:50:18 CET 2020 aarch64 GNU/Linux $ uptime 20:25:53 up 67 days, 19:23, 2 users, load average: 0.08, 0.12, 0.12 I'm sticking with this until things get clearer but would like to get full use of my NAS hardware... 1 Quote
axeleroy Posted April 15, 2021 Posted April 15, 2021 My Helios is stable, running LUKS, MergerFS, SnapRAID, OMV and 9 Docker containers from SD Card and with 3 HDDs. Although in order to get a stable system I had to lock CPU frequency at 1.2GHz, otherwise CPU intensive tasks (like SnapRAID's scrub) would cause my Helios to reboot. ================================================================================ = System information ================================================================================ Linux helios64 5.10.21-rockchip64 #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 aarch64 GNU/Linux ================================================================================ = Uptime ================================================================================ 12:25:17 up 8 days, 1:18, 0 users, load average: 0.01, 0.10, 0.15 ================================================================================ = openmediavault information ================================================================================ Release: 5.6.2-1 Codename: Usul ================================================================================ = openmediavault plugins ================================================================================ ii openmediavault-backup 5.2.4 all backup plugin for OpenMediaVault. ii openmediavault-flashmemory 5.0.8 all folder2ram plugin for OpenMediaVault ii openmediavault-keyring 1.0 all GnuPG archive keys of the OpenMediaVault archive ii openmediavault-luksencryption 5.0.2 all OpenMediaVault LUKS encryption plugin ii openmediavault-minidlna 5.0.5 all OpenMediaVault miniDLNA (DLNA server) plugin ii openmediavault-omvextrasorg 5.6 all OMV-Extras.org Package Repositories for OpenMediaVault ii openmediavault-snapraid 5.0.7 all snapraid plugin for OpenMediaVault. ii openmediavault-unionfilesystems 5.1.2 all Union filesystems plugin for OpenMediaVault. ii openmediavault-wol 3.4.2 all OpenMediaVault WOL plugin PS: don't mind the uptime, I had to reboot to apply an update. Otherwise no problem since mid-February. 1 Quote
rupert Posted April 15, 2021 Posted April 15, 2021 HI, My poor little Kobol has to work very hard for a living: Plex NTP (GPSD) server SMB share Webmin Zabbix agent Zerotier client/bridge Docker Storj node Raid 5 across 5 disks And is as good as gold! Had a few niggles to start with ie first week, since then its only rebooted as the OS requests otherwise excellent! Running on a 64Gb SD Card CPU full speed Very pleased! Rup 1 Quote
dieKatze88 Posted April 16, 2021 Posted April 16, 2021 My system is still unstable and I have no idea what to do. I've given every suggestion I've seen on the internet a try and I think the only thing I can do is move on. 1 Quote
Polarisgeek Posted April 16, 2021 Posted April 16, 2021 Just wanted to add my experience as maybe someone can get something semi-useful out of it. I started out with 3 - 4TB drives with 2 of them in Raid 1 and the 3rd on it's own. I installed OMV and CUPS on a Micro SD card. Even from the very beginning, I always had trouble restarting the system. Sometimes it would boot after 3 tries, sometimes it would take 20 tries. I watched and it was never the same issue twice that caused the boot failure. I removed drives, plugged in different combo's, several fixes on the forums, anything I could think of and nothing really seemed to make a difference. The good news was that once it was up and running, it ran great. I had 2 months of uptime with no issues. Then i'd run an update and have a heck of a time getting it restarted. Just figured that's the way it was and hoped things would get better as the software matured. I'm now on my second iteration with 5 - 14TB (Thanks Uncle Joe) drives in Raid 6. After 2 months, i've had 2 random crashes for unknown reasons, one at 3 days and the other after 7 days. Aside from running updates and rebooting, it's been running solid for me. I'm only running OMV and a CUPS server. Getting to this point was a huge PITA. I spent nearly 8 hours trying to get it up and running over the course of a Sunday. It seemed like no matter what I did, i'd have a Kernel Panic during the setup process, and then the system wouldn't boot at all giving different errors every time. So i'd re-download the image, and attempt to install from scratch again. I played with installing different options, in different sequences (as much as possible), without much luck. I verified the download every time. I finally tried using USBImager, as an alternative to BalenaEtcher, and found that wring to the sdcard seemed better and the installation seemed better, although it did panic a couple times. Once I finally got it running, I gave it some time, installed all the updates, reboot several times in between setting up OMV for testing and have been happy with it since. The biggest difference now is that I don't worry about rebooting as it comes right up the first time instead of several tries like the first iteration. Overall, i've been happy with mine. I'm very new to the Linux environment so it's been fun learning a new thing. Keep up the great work! 2 Quote
CharlesGillanders Posted April 16, 2021 Posted April 16, 2021 (edited) Mine is running absolutely stable. Only ever have to reboot due to updates. I am running OMV - I have 5 x WDC WD40EFRX-68WT0N0 drives with Raid-6 and then LVM via the OMV LVM plugin - I'm running NFS, Samba, cloudflare tunnel daemon, and Docker (in docker there's portainer, duplicacy, traefik and authelia) If it helps I'm only using the 1GB NIC and I do have the battery for power supply stability. Oh and I'm on 5.10.21-rockchip64 #21.02.3 SMP PREEMPT Edited April 16, 2021 by CharlesGillanders added more information 0 Quote
tionebrr Posted April 16, 2021 Posted April 16, 2021 Guys, try to run your helios in whatever mode but always under 1.4GHz. I have mine set to performance and throttling from 400MHz to 1.4GHz. Uptime is 9 days now. Only two of the CPU cores can run above 1.4GHz (see these posts for reference) and that might be one of the cause of the crashes. 0 Quote
IcerJo Posted April 19, 2021 Posted April 19, 2021 I set my Helios64 up last week, and placed it at it's final home/location. My unit had been running perfectly fine for 2 days then sometime this morning before I woke up it crashed and auto rebooted. System has been up for 2 hours now. Following the guide above, I have changed my cpufreq to 400mhz-1.4Ghz and I set the governor to OnDemand and will see if stability will last beyond two days . Hopefully whatever the culprit is, will be fully ironed out by or before the Armbian becomes fully supported I was just on the site and it now says supported lol. Thanks again to all! 0 Quote
rupert Posted April 22, 2021 Posted April 22, 2021 HI, My poor little Kobol has to work very hard for a living: Plex NTP (GPSD) server SMB share Webmin Zabbix agent Zerotier client/bridge Docker Storj node Raid 5 across 5 disks And is as good as gold! Had a few niggles to start with ie first week, since then its only rebooted as the OS requests otherwise excellent! Running on a 64Gb SD Card CPU full speed Very pleased! I have to say the common factor in a LOT of those with issues is OMV as far as I can see, maybe there is an inherent issue there?? Rup 1 Quote
buster Posted May 3, 2021 Posted May 3, 2021 Mine is running just fine for months now. Just upgraded it (kernel 5.9... to 5.10..) and it's still running fine. openmediavault 5.6.5-1 Mirror Raid with XFS and 2 disks NFS, SMB Shares Welcome to Armbian 21.02.3 Buster with Linux 5.10.21-rockchip64 0 Quote
hartraft Posted May 3, 2021 Posted May 3, 2021 (edited) On 3/29/2021 at 6:30 PM, hartraft said: $ uptime 20:25:53 up 67 days, 19:23, 2 users, load average: 0.08, 0.12, 0.12 Expand Okay... So I had to jinx it... After 100 days of uptime, I had to do some electricity work in the house. Either the Helios64 shut-down after the UPS was spent or it rebooted / shut-down. Now I can't boot the thing back up anymore. Connected through picocom and it doesn't get past "Starting kernel". Tried without any disks attached, same thing. Similar to another thread, the LAN LEDs don't light up (obviously). Any ideas? Reveal hidden contents picocom v2.2 port is : /dev/ttyUSB0 flowcontrol : none baudrate is : 1500000 parity is : none databits are : 8 stopbits are : 1 escape is : C-a local echo is : no noinit is : no noreset is : no nolock is : no send_cmd is : sz -vv receive_cmd is : rz -vv -E imap is : omap is : emap is : crcrlf,delbs, Type [C-a] [C-h] to see available commands Terminal ready DDR Version 1.24 20191016 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 254 SdmmcInit=2 0 BootCapSize=100000 UserCapSize=14910MB FwPartOffset=2000 , 100000 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=121942MB FwPartOffset=2000 , 0 StorageInit ok = 77734 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xdd6b0 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.07-armbian (Dec 11 2020 - 22:44:41 +0100) SoC: Rockchip rk3399 Reset cause: POR DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Model: Helios64 Revision: 1.2 - 4GB non ECC Net: eth0: ethernet@fe300000 scanning bus for devices... Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 7 ms (444.3 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 182 bytes read in 5 ms (35.2 KiB/s) 9809293 bytes read in 426 ms (22 MiB/s) 22460424 bytes read in 955 ms (22.4 MiB/s) 81696 bytes read in 13 ms (6 MiB/s) 2698 bytes read in 8 ms (329.1 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 9809229 Bytes = 9.4 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to f558b000, end f5ee5d4d ... OK Loading Device Tree to 00000000f550e000, end 00000000f558afff ... OK Starting kernel ... Edited May 3, 2021 by hartraft Added logs 0 Quote
gprovost Posted May 4, 2021 Posted May 4, 2021 @hartraft Could you modify /boot/armbianEnv.txt and add/modify following lines: verbosity=7 console=serial extraargs=earlyprintk ignore_loglevel If you are booting from eMMC, you will need to first boot from a fresh image on microSD, then mount the eMMC to modify /boot/armbianEnv.txt 0 Quote
