Armbianmonitor:
Hi forum,
I ran an apt-get upgrade a few days back and here linux-image-current-sunxi:armhf was updated from 21.05.6 to 21.08.2
After reboot my SATA was gone.
There was nothing in the logs which would have indicated that something is wrong.
After I reverted back to 21.05.6
apt-get install linux-image-current-sunxi=21.05.6
apt-get install armbian-firmware=21.05.8
apt-get install linux-dtb-current-sunxi=21.05.6
everything worked again.
Has anyone experienced something similar ?
Regards
Volker
I did the same and everything works on my cubietruck.
Your Armbianmonitor  is incomplete, there is no info from the previous boot that you claim no sata, so I can't help anymore.
I see some recent changes in the dts https://github.com/armbian/build/pull/3117/commits/a215617b78a05b5895e5eaca14b974d5968178de
but probably nothing to do with sata.
I also see that you have not installed the uboot package
Can you provide the output of:
cat /boot/armbianEnv.txt
strings /boot/boot.scr
strings /dev/mmcblk0 | grep "^U-Boot.*("
You might need to interrupt the last command (press Ctrl c) after a few lines of output
verbosity=1
bootlogo=false
console=display
disp_mode=1280x1024p60
overlay_prefix=sun7i-a20
rootdev=UUID=20af993b-ffec-4b81-91f5-51bc56163f75
rootfstype=ext4
  Reveal hidden contents
U-Boot SPL 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200)
U-Boot 2021.07-armbian (Sep 13 2021 - 23:19:26 +0200) Allwinner Technology
Edited by TRS-80
wrap long output in spoiler
Hello.
i have the same situation on my "Banana Pi Pro" :
Image: Armbian_21.05.1_Bananapipro_buster_current_5.10.34_minimal
http://ix.io/3zMe
Linux bananapipro 5.10.34-sunxi #21.05.1 SMP Thu May 6 20:13:21 UTC 2021 armv7l GNU/Linux
---> SSD available & working fine
Output from inxi -Fx
System:    Host: bananapipro Kernel: 5.10.34-sunxi armv7l bits: 32 compiler: N/A Console: tty 0
           Distro: Armbian GNU/Linux 10 (buster)
Machine:   Type: ARM Device System: LeMaker Banana Pro details: Allwinner sun7i (A20) Family rev: N/A
           serial: ###
CPU:       Topology: Dual Core model: ARMv7 v7l variant: cortex-a7 bits: 32 type: MCP arch: v7l rev: 4
           features: Use -f option to see features bogomips: 101
           Speed: 960 MHz min/max: 480/960 MHz Core speeds (MHz): 1: 960 2: 960
Graphics:  Device-1: sun7i-a20-mali driver: lima v: kernel bus ID: N/A
           Device-2: sun7i-a20-display-frontend driver: sun4i_frontend v: N/A bus ID: N/A
           Device-3: sun7i-a20-display-frontend driver: sun4i_frontend v: N/A bus ID: N/A
           Device-4: sun7i-a20-display-backend driver: sun4i_backend v: N/A bus ID: N/A
           Device-5: sun7i-a20-display-backend driver: sun4i_backend v: N/A bus ID: N/A
           Device-6: sun5i-a10s-hdmi driver: N/A bus ID: N/A
           Display: tty server: N/A driver: N/A tty: 127x40
           Message: Advanced graphics data unavailable in console for root.
Audio:     Device-1: sun5i-a10s-hdmi driver: N/A bus ID: N/A
           Sound Server: ALSA v: k5.10.34-sunxi
Network:   Device-1: sun7i-a20-gmac driver: sun7i_dwmac v: N/A port: N/A bus ID: N/A
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 02:87:04:01:ed:da
           Device-2: mmc-pwrseq-simple driver: pwrseq_simple v: kernel port: N/A bus ID: N/A
           Device-3: sun4i-a10-emac driver: N/A port: N/A bus ID: N/A
           IF-ID-1: wlan0 state: up mac: 98:3b:16:e8:1b:7c
Drives:    Local Storage: total: 119.27 GiB used: 1.79 GiB (1.5%)
           ID-1: /dev/mmcblk0 model: NCard size: 7.48 GiB
           ID-2: /dev/sda vendor: Patriot model: Burst size: 111.79 GiB temp: 33 C
Partition: ID-1: / size: 109.53 GiB used: 1.01 GiB (0.9%) fs: ext4 dev: /dev/sda1
           ID-2: /var/log size: 48.4 MiB used: 1.5 MiB (3.2%) fs: ext4 dev: /dev/zram1
Sensors:   Message: No sensors data was found. Is sensors configured?
Info:      Processes: 102 Uptime: 3h 04m Memory: 997.4 MiB used: 97.9 MiB (9.8%) Init: systemd runlevel: 5 Compilers:
           gcc: 8.3.0 Shell: bash v: 5.0.3 inxi: 3.0.32
After "apt update && apt upgrade" the SSD is gone:
http://ix.io/3zMg
Linux bananapipro 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l GNU/Linux
---> SSD completly unavailable (but still working fine via USB-SATA-Adapter on Linux-Laptop)
Using the Image "Armbian_21.08.3_Bananapipro_buster_current_5.10.60" as a complete new installation
doesn´t show up the SSD at all after installation ---> http://ix.io/3zM6
Linux bananapipro 5.10.60-sunxi #21.08.2 SMP Tue Sep 14 16:28:44 UTC 2021 armv7l GNU/Linux"
Cheers, Lelo.
Hello.
Meanwhile I have also checked the Bullseye-Image. Results:
Armbian_21.08.3_Bananapipro_bullseye_current_5.10.60.img ---> SSD is not available --> http://ix.io/3A3L
---> apt update && apt upgrade -y ---> SSD is still not available ---> http://ix.io/3A3T
The only information abou SATA on Bananapi Pro I found here.
Cheers, Lelo.
Confirm that a fresh install of Armbian_21.08.3_Bananapipro_focal_current_5.10.60 does not get a visible sata connection (BananaPi Pro).
This cmd line followed by a reboot enables the sata (same is in first post, just all in one line).
apt install linux-image-current-sunxi=21.05.6 armbian-firmware=21.05.8 linux-dtb-current-sunxi=21.05.6
Dieter
Hi again,
more findings:
It is sufficient to downgrade the device tree:
apt install linux-dtb-current-sunxi=21.05.6
I had compared the kernel config (find current config in /proc/config.gz), no changes regarding sata. Only a very few changes, mostly adding drivers as module.
So far I had no time to compare the device tree yet. Someone wrote he did that but did not find relevant changes. Well, I hope he was wrong :-).
BTW: the next line will reverse the changes.
apt full-upgrade
PS: Running a kernel with a different device tree is not recommend, I did it only to hunt down the issue a bit.
Dieter
And more info:
Some people wrote that these events show up in the syslog and searched in that direction.
ahci-sunxi 1c18000.sata: supply ahci not found, using dummy regulator
ahci-sunxi 1c18000.sata: supply phy not found, using dummy regulator
ahci-sunxi 1c18000.sata: supply target not found, using dummy regulator
Since I was convinced these messages are normal, I double checked with working sata and they are there as well.
Dieter
Decompiled the DT, then compared.
This is a difference regarding sata:
		sata@1c18000 {
			clocks = <0x02 0x31 0x02 0x7a>;
			compatible = "allwinner,sun4i-a10-ahci";
			interrupts = <0x00 0x38 0x04>;
			phandle = <0x5f>;
			reg = <0x1c18000 0x1000>;
			status = "okay";
			target-supply = <0x24>;
This line is new in latest version:
It is not unlikely that this line causes the issue.
The 0x24 points to item ahci-5v and that is disabled.
	ahci-5v {
		compatible = "regulator-fixed";
		enable-active-high;
		gpio = <0x19 0x01 0x08 0x00>;
		phandle = <0x24>;
		regulator-boot-on;
		regulator-max-microvolt = <0x4c4b40>;
		regulator-min-microvolt = <0x4c4b40>;
		regulator-name = "ahci-5v";
		status = "disabled";
No change for this item between the versions.
I do not know how to enable it (yet). Any ideas ?
This is how I extracted the DT and decompiled:
  1. copy "/sys/firmware/devicetree" to my worksation
  2. running "dtc --in-format fs base --out-format dts --out dt.dts --symbols --auto-alias --phandle both  --sort"
  3. use meld to compare both versions
Dieter
Expand
Not sure what you mean, but `armbian-config` provides experimental device tree editor.
So if the difference is one added line, what happens if you delete this line in the current device tree using the editor?
Hi Lampra,
That is a good point. I am new to Armbian and would have used the dtc to rebuild the dt.
Packing it was my learning stuff, but I had no time to work on it. Will stay that way the next days at least.
One hope was that the maintainer would explain why he/she did add that line and perhaps fix it.
Many regards, Dieter
Expand
I doubt that the maintainer tracks all discussions here.
So for your benefit in the future and the benefit of the community, if you could spare some minutes (after the "next" days), go ahead and check the sources.
If this is not already fixed there you could open an issue in GitHub linking here or, if you have the skills, send a pull request that resolves this issue (i.e. deletes the line).
Greetings,
Today I did an apt update / upgrade on the system to bring it up to snuff.  On reboot it eventually dropped into initramfs without being able to find rootdev.  I boot from SDcard and run the root fs from external sata drive as setup by armbian-config.  after this latest update the sata device is no longer recognized.  I managed to swap out the UUID for the sata drive with the SD card and can boot the system now.  Alas, all my data and applications are not there.  I've run the armbianmonitor -u to get data about what's happening.  Did something change in the device tree that would mask the sata interface?  here's the armbianmonitor link:  http://ix.io/3BQ7
any and all help is greatly appreciated.  thanks
Thank you for dropping this in the correct place..  My google-fu is weak today.  I'm going to downgrade as Dieter suggested.  After the system is back up I can start to mess with it a bit and try to lend a hand.
i have no DTC in the system Menue, why?
This is the overlay:
I changed it to
overlay_prefix=sun7i-a20-bananapro
No change
Can you help me?
Thanks
Expand
may need to update the application "armbian-config"? My current version: 21.08.3
commands:
sudo apt update
sudo apt install --upgrade armbian-config
Expand
this is the correct value
  On 10/21/2021 at 7:48 AM, MAVr said:
But I would like the developers to fix this.
Expand
Likewise, but perhaps they are totally overloaded for years in advance?
I would also like too see more community involvement in maintaining the project, since wishes are way too big for capacity project has. A lot of solutions got stuck in this stage.
Armbian project already struggle and there is very little of interest to help project helping community.
https://docs.armbian.com/User-Guide_FAQ/#is-armbian-an-operating-system
How to proceed?
https://docs.armbian.com/Developer-Guide_Build-Preparation/
https://docs.armbian.com/Process_Contribute/
The process will receive support.
