U-Boot SPL 2016.05-armbian (Jun 01 2016 - 19:42:08)
DRAM: 1024 MiB
Trying to boot from MMC1
U-Boot 2016.05-armbian (Jun 01 2016 - 19:42:08 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
I2C:   ready
DRAM:  1 GiB
MMC:   SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
2444 bytes read in 182 ms (12.7 KiB/s)
Wrong image format for "source" command
SCRIPT FAILED: continuing...
mmc1(part 0) is current device
Scanning mmc 1:1...
USB device 0: unknown device
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
I have tested with two SDs - the same result. But vanilla works perfect!
Strange is that after dd command I can't mount SDs with legacy, but vanilla I can.
I've downloaded legacy twice.
Jessie server legacy image for PC+
Armbian_5.14_Orangepipcplus_Debian_jessie_3.4.112.raw
SHA256: CD5EB351E777651EC4F4DE71E8FD32FDECF40088A467C3C8A8A55916E1A30669
Works fine for me:
DRAM: 1024 MiB
I2C:   ready
DRAM:  1 GiB
In:    serial
Out:   serial
Err:   serial
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning bus 5 for devices... 2 USB Device(s) found
Scanning mmc 0:1...
gpio: pin PL10 (gpio 298) value is 1
gpio: pin PG11 (gpio 203) value is 1
0 bytes read in 130 ms (0 Bytes/s)
** File not found /boot/.next **
** File not found .next **
37320 bytes read in 489 ms (74.2 KiB/s)
3112435 bytes read in 3349 ms (907.2 KiB/s)
5064616 bytes read in 5410 ms (914.1 KiB/s)
Kernel image @ 0x48000000 [ 0x000000 - 0x4d47a8 ]
## Loading init Ramdisk from Legacy Image at 42000000 ...
   Image Name:   uInitrd
   Data Size:    3112371 Bytes = 3 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
Using machid 0x1029 from environment
Starting kernel ...
SHA256 passed.
What about that? I can't mount uSD card with legacy image at my PC. Do you also use dd program to write raw image to SD?
I used Rufus this time, but it shouldn't make any difference if you use correct arguments for dd (I mean write to whole device i.e. /dev/sdb and not to partition i.e. /dev/sdb1)
Mounts fine for me:
➜  ~  % dmesg | tail
[462269.361450] scsi host1: usb-storage 2-1.4:1.0
[462270.359126] scsi 1:0:0:0: Direct-Access     Multi    Flash Reader     1.00 PQ: 0 ANSI: 0
[462270.369768] sd 1:0:0:0: Attached scsi generic sg1 type 0
[462271.100193] sd 1:0:0:0: [sdb] 30228480 512-byte logical blocks: (15.5 GB/14.4 GiB)
[462271.109039] sd 1:0:0:0: [sdb] Write Protect is off
[462271.113934] sd 1:0:0:0: [sdb] Mode Sense: 03 00 00 00
[462271.115030] sd 1:0:0:0: [sdb] No Caching mode page found
[462271.120498] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[462271.138014]  sdb: sdb1
[462271.156495] sd 1:0:0:0: [sdb] Attached SCSI removable disk
➜  ~  % mkdir -p /tmp/sdb1
➜  ~  % _ mount -v /dev/sdb1 /tmp/sdb1
mount: /dev/sdb1 mounted on /tmp/sdb1.
➜  ~  % ls /tmp/sdb1
bin   dev  home  lost+found  mnt  proc  run   selinux  sys  usr
boot  etc  lib   media       opt  root  sbin  srv      tmp  var
➜  ~  % dmesg | tail
[462284.603974] EXT4-fs (sdb1): mounted filesystem with writeback data mode. Opts: (null)
Yes, of course.
I'll try again in the morning. Maybe with Windows and other uSD adapter.
Have you make a "sync" after dd ?
I see also sometimes recommendations to wipe the cards (dd if=/dev/zero of=/dev/sdX) before copying an image. I never do this, as I never found a justification to do it. But I also sometimes copy images that will not boot ...
Yes, but it is also strange, because card with "good" image syncs in 0.5 s when "bad" few minutes. I'll try to make new partition table and maybe wipe it as you suggest.
Ok, everything works now. It was SD format fault, but I don't know why other images worked fine.
Usually, such issues can happened when doing a "dd" while sd is still mounted with previous partitions.
Making sure no partition are mounted before issuing the "dd" command is a good practice.
I think I have checked that every time, but I'm not sure.
Thank you everyone for helpful suggestions!
Hello! Is there any detailed instructions ( step by step ) how to write the image on the card?
