Rocket69 Posted November 30, 2021 Posted November 30, 2021 Armbianmonitor: http://ix.io/3GyJ Hello, I have an ARMBIAN image 08.21.6 kernel 5.10.16 it works very well on rockpi 4B + rev 1.6 I tested the last Kernel but without more success. when we fix the ip address and we up (several times) the eth0 network this one puts to work at a time. Do you have an idea ? Regards.
arox Posted November 30, 2021 Posted November 30, 2021 Does-it start if you unplug/replug the RJ45 connector (as on RPI...)
dvd741 Posted January 3, 2022 Posted January 3, 2022 I have some issues with the ethernet adapter on my Rock Pi 4B+ (v1.72) Connections seem to drop, sometimes Ping loses a packet. APT-GET UPDATE doesn't work.. Waiting For headers / Speed to low and constantly dropping -> Timeout On Wi-Fi everything seems to work, but for stability I'd ofcourse like the ethernet to work... IPERF3 Tests run successfull. (Server on LAN) PING drops 1 packet in the sequence then seems to run fine for a while (LAN) DMESG (Maybe this gives more information?): [ 7.997847] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 7.997855] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400 [ 7.997860] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 7.997864] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 7.999104] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.000699] usbcore: registered new interface driver brcmfmac [ 8.009791] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4b.txt failed with error -2 [ 8.012675] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 1 [ 8.013029] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned. [ 8.020903] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 8.021991] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2 [ 8.022409] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 [ 8.076933] Bluetooth: Core ver 2.22 [ 8.077056] NET: Registered protocol family 31 [ 8.077062] Bluetooth: HCI device and connection manager initialized [ 8.077082] Bluetooth: HCI socket layer initialized [ 8.077092] Bluetooth: L2CAP socket layer initialized [ 8.077117] Bluetooth: SCO socket layer initialized [ 8.133709] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9 [ 8.134711] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available [ 8.136106] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version 7.45.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3 [ 8.410774] rk_gmac-dwmac fe300000.ethernet eth0: PHY [stmmac-0:00] driver [RTL8211F Gigabit Ethernet] (irq=POLL) [ 8.410823] cma: cma_alloc: alloc failed, req-size: 2 pages, ret: -12 [ 8.411449] cma: cma_alloc: alloc failed, req-size: 2 pages, ret: -12 [ 8.413101] rk_gmac-dwmac fe300000.ethernet eth0: No Safety Features support found [ 8.413118] rk_gmac-dwmac fe300000.ethernet eth0: PTP not supported by HW [ 8.413677] rk_gmac-dwmac fe300000.ethernet eth0: configuring for phy/rgmii link mode [ 9.446580] random: crng init done [ 9.446588] random: 7 urandom warning(s) missed due to ratelimiting [ 12.519689] rk_gmac-dwmac fe300000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx I'm not sure where to look next, maybe someone can help?
Igor Posted January 3, 2022 Posted January 3, 2022 36 minutes ago, dvd741 said: I'm not sure where to look next I understand your frustration but Armbian have exact same problem. Support generate expenses while there is no income from you or vendor. 52 minutes ago, dvd741 said: maybe someone can help? Raising your problem attention from 0% https://forum.armbian.com/subscriptions/ Instead of putting a pressure to people you owe perhaps trying to solve the problem honest way? Cover 1-2 working days of research and expenses to developers and wait up to 30 days for a available slot that attempt on resolving can be made. https://forum.armbian.com/clients/donations/ Hire someone - which will cost you a lot more and share with others. We don't need this to work - you do: https://docs.armbian.com/Process_Contribute/ Armbian only ... https://forum.radxa.com/t/rock-pi-4b-1-72-ethernet-speed/8284
guidol Posted January 3, 2022 Posted January 3, 2022 1 hour ago, dvd741 said: [ 8.009791] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.radxa,rockpi4b.txt failed with error -2 try (and reboot) cp /usr/lib/firmware/brcm/brcmfmac43456-sdio.txt /usr/lib/firmware/brcm/brcmfmac43456-sdio.radxa,rockpi4b.txt
